    3. Off Topic
    4. Pflege des Betriebssystems
    5. Veraltetes System retten
      Homoran Global Moderator Administrators @syntetic last edited by Homoran
      @syntetic sagte in Veraltetes System retten:
      Debian 10
      ist seit Jahren tot!
      Jetzt funktioniert es nicht mehr.
      Da wird es schwer
      bitte als allererstes die Langfassung von iob diag in code-tags posten
        syntetic @Homoran last edited by syntetic
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
           Static hostname: raspberrypiMitcho
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         14:56:04 up 27 min,  2 users,  load average: 1.02, 0.94, 1.08
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed 'buster'. Please check yourself if the Operating System is actively maintained.
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-06-16 14:56:04 CEST
                   Universal time: Mon 2025-06-16 12:56:04 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:           3.8G        1.6G        1.4G         11M        829M        2.1G
        Swap:           99M          0B         99M
        Total:         3.9G        1.6G        1.5G
        Active iob-Instances:   17
                 3838 M total memory
                 1635 M used memory
                  443 M active memory
                 1891 M inactive memory
                 1373 M free memory
                  106 M buffer memory
                  722 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 14:56:05 up 27 min,  2 users,  load average: 1.02, 0.94, 1.08
        Tasks: 164 total,   2 running, 162 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.7 us,  5.5 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3838.7 total,   1374.9 free,   1633.9 used,    829.9 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2077.6 avail Mem
        *** FAILED SERVICES ***
          UNIT                LOAD   ACTIVE SUB    DESCRIPTION
        * deconz-init.service loaded failed failed deCONZ: ZigBee gateway -- Initialisation
        * lightdm.service     loaded failed failed Light Display Manager
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        2 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      235G   30G  196G  14% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G  732K  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/999
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        [Mon Jun 16 14:28:29 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=d0d2e9f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jun 16 14:28:30 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Jun 16 14:28:30 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Jun 16 14:28:33 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        3.2G    /var/
        2.4G    /var/lib
        1.4G    /var/lib/unifi/db
        1.4G    /var/lib/unifi
        801M    /var/lib/mongodb
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        816M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        71M     /opt/iobroker/iobroker-data/objects.jsonl
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        23M     /opt/iobroker/iobroker-data/states.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
        *** ZigBee Settings ***
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.8
        /usr/bin/node           v18.20.8
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
          Installed: 18.20.8-1nodesource1
          Candidate: 18.20.8-1nodesource1
          Version table:
         *** 18.20.8-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.6-1nodesource1 500
             18.20.5-1nodesource1 500
             18.20.4-1nodesource1 500
             18.20.3-1nodesource1 500
             18.20.2-1nodesource1 500
             18.20.1-1nodesource1 500
             18.20.0-1nodesource1 500
             18.19.1-1nodesource1 500
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypiMitcho   raspberrypiMitcho (version: 7.0.6, hostname: raspberrypiMitcho, alive, uptime: 1478)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.6.17
        javascript:     8.8.3
        nodejs modules from github:     0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : raspberrypiMitcho                        -  enabled
        + system.adapter.admin.0                  : admin                 : raspberrypiMitcho                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypiMitcho                        -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypiMitcho                        -  enabled
        + system.adapter.history.0                : history               : raspberrypiMitcho                        -  enabled
          system.adapter.ical.0                   : ical                  : raspberrypiMitcho                        -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypiMitcho                        -  enabled
          system.adapter.ical.2                   : ical                  : raspberrypiMitcho                        -  enabled
        + system.adapter.info.0                   : info                  : raspberrypiMitcho                        -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypiMitcho                        -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : raspberrypiMitcho                        -  enabled
        + system.adapter.scenes.0                 : scenes                : raspberrypiMitcho                        -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypiMitcho                        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspberrypiMitcho                        -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : raspberrypiMitcho                        -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypiMitcho                        -  enabled
        + system.adapter.unifi.0                  : unifi                 : raspberrypiMitcho                        -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypiMitcho                        -  enabled
        + system.adapter.web.0                    : web                   : raspberrypiMitcho                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : raspberrypiMitcho                        -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypiMitcho                        -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
        + instance is alive
        ioBroker-Repositories
        │ (index) │        name        │                           url                           │ auto upgrade │
        │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
        │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
        Active repo(s): Stable (default)
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: Stable (default)
        Adapter    "accuweather"  : 2.1.0    , installed 1.5.0  [Updatable]
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "backitup"     : 3.2.2    , installed 3.2.2
        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "javascript"   : 8.9.2    , installed 8.8.3  [Updatable]
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
        Adapter    "shelly"       : 9.5.1    , installed 8.2.1  [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "telegram"     : 4.1.0    , installed 3.9.0  [Updatable]
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
        Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
        Objects and States
        Objects:        85977
        States:         63605
        W: GPG error: http://ftp.debian.org/debian bullseye-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://ftp.debian.org/debian bullseye-backports InRelease' is not signed.
        W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY 605C66F00D6C9793
        E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
        W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 54404762BBB6E853 NO_PUBKEY BDE6D2B9216EC7A8
        E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not signed.
        W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
        E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21247      365/deCONZ
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          19905      699/lighttpd
        tcp        0      0 127.0.0.1:28017         0.0.0.0:*               LISTEN      116        19938      412/mongod
        tcp        0      0 0.0.0.0:40373           0.0.0.0:*               LISTEN      1001       35592      3752/io.yahka.0
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19927      711/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18877      620/sshd
        tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          21255      354/cupsd
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       40311      3640/io.shelly.1
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       21928      365/deCONZ
        tcp        0      0 127.0.0.1:42917         0.0.0.0:*               LISTEN      1001       38276      3752/io.yahka.0
        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21248      711/pihole-FTL
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33096      2806/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31414      2806/iobroker.js-co
        tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      116        19193      412/mongod
        tcp6       0      0 :::80                   :::*                    LISTEN      0          19906      699/lighttpd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35888      2932/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39045      3778/io.web.0
        tcp6       0      0 :::53                   :::*                    LISTEN      999        19929      711/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18879      620/sshd
        tcp6       0      0 :::631                  :::*                    LISTEN      0          21256      354/cupsd
        tcp6       0      0 :::8581                 :::*                    LISTEN      115        25620      936/hb-service
        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18175      711/pihole-FTL
        tcp6       0      0 :::51560                :::*                    LISTEN      115        25155      1167/homebridge
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       42490      3463/io.shelly.0
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19926      711/pihole-FTL
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19208      462/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19936      530/cups-browsed
        udp        0      0 0.0.0.0:56962           0.0.0.0:*                           108        17171      362/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25617      936/hb-service
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17169      362/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       21940      365/deCONZ
        udp6       0      0 :::53                   :::*                                999        19928      711/pihole-FTL
        udp6       0      0 :::5353                 :::*                                108        17170      362/avahi-daemon: r
        udp6       0      0 :::57104                :::*                                108        17172      362/avahi-daemon: r
        2025-06-16 14:41:41.792  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-b0a73246f8c8 / shellyplus2pm#b0a73246f8c8#1) (false)
        2025-06-16 14:41:44.407  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-10061cfb1860 / shellyplus2pm#10061cfb1860#1) (false)
        2025-06-16 14:41:45.413  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-3ce90e2ea41c / shellyplus2pm#3ce90e2ea41c#1) (false)
        2025-06-16 14:41:47.548  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a732477aa4"
        2025-06-16 14:41:47.556  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-3ce90e2ea41c"
        2025-06-16 14:41:47.570  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-10061cfae058"
        2025-06-16 14:41:47.572  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-10061cfb1860"
        2025-06-16 14:41:47.633  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73246f8c8"
        2025-06-16 14:41:47.635  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73248b5c0"
        2025-06-16 14:41:50.600  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a7324738a8" connected!
        2025-06-16 14:41:53.896  - info: admin.0 (2932) <== Disconnect system.user.admin from ::ffff:192.168.2.101 javascript
        2025-06-16 14:42:33.274  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-10061cfae058" connected!
        2025-06-16 14:42:36.002  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73248b5c0" connected!
        2025-06-16 14:42:39.308  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a732477aa4" connected!
        2025-06-16 14:42:40.254  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73246f8c8" connected!
        2025-06-16 14:42:42.091  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-3ce90e2ea41c" connected!
        2025-06-16 14:42:43.763  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-10061cfb1860" connected!
        2025-06-16 14:42:49.306  - info: shelly.1 (3640) [MQTT] Client Close: 192.168.2.176 (shellyplus2pm / shellyplus2pm-b0a732477aa4 / shellyplus2pm#b0a732477aa4#1) (false)
        2025-06-16 14:42:49.741  - error: shelly.1 (3640) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
        2025-06-16 14:42:49.742  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a732477aa4"
        2025-06-16 14:42:50.250  - info: shelly.1 (3640) [MQTT] Client Close: 192.168.2.175 (shellyplus2pm / shellyplus2pm-b0a73246f8c8 / shellyplus2pm#b0a73246f8c8#1) (false)
        2025-06-16 14:42:50.259  - error: shelly.1 (3640) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
        2025-06-16 14:42:50.260  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73246f8c8"
        2025-06-16 14:43:45.975  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a732477aa4" connected!
        2025-06-16 14:43:48.644  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73246f8c8" connected!
        Es funktioniert schon prinzipiell alles - bis auf die enphase Skripte jetzt.
        Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
          das läuft auch nicht
          Bitte keine Illusionen!
          Das System ist hin!.
          Zieh schonmal ein aktuelles ioBroker Backup.
          mit gaaaanz viel Glück lässt dich das auf einem neu aufgesetzten aktuellen System wiederherstellen.
          Dazu gibt es schon keinerlei Unterstützung mehr.
            viel zu alt für neuere Adapter-Versionen
            die sind dermaßen alt, dass nicht einmal mehr Versionsinformationen zur Verfügung stehen, und daher fälschlicherweise 0 anstehende Updates angezeigt werden.
            Da bietet nämlich niemand mehr Updates an.
              Thomas Braun Most Active @syntetic last edited by
              @syntetic
              ioBroker soweit wie es geht updaten, Backup vom ioBroker ziehen, Betriebssystem komplett NEU als 64Bit-Lite 'Booworm' (Debian 12) aufsetzen, Backup einspielen, künfitg nicht mehr nach dem schwachsinnigen 'Never tatsch a running süstäm' verfahren. Das ist ganz großer Bullshit.
                @homoran sagte in Veraltetes System retten:
                Jein, die sind so alt, dass keine aktuellen Schlüssel vorhanden sind und deswegen daraus keine Updates angezogen werden.
                Man käme aber ohnehin mit der Aktion nicht auf eine ordentliche Basis. Bleibt nur die Neuinstallation von dem ganzen Sums.
                  syntetic @Thomas Braun last edited by
                  Ok, wir machen alles neu. Da ich mich echt gar nicht auskenne und mir alles anlesen muss, was ich dort mache, könnt ihr mich vielleicht da durch leiten.
                  Wäre schon gut, wenn ich den ioBroker wieder importieren könnte.
                    Thomas Braun Most Active @syntetic last edited by Thomas Braun
                    @syntetic
                    Was brauchst du konkret?
                    Ich werde dir nicht alles vorflüstern, du wirst um ein wenig Beschäftigen mit dem System nicht drumherumkommen.
                    RaspberryOS:
                    https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                    ioBroker:
                    https://www.iobroker.net/#de/documentation/install/linux.md
                    ioBroker-Backup via Backitup-Adapter einspielen.
                    Zu den anderen Diensten kann ich dir nichts sagen, muss der Admin von der Kiste ja wissen, was da warum wie installiert ist und wie man da Backups macht.
                      da gibt es nicht viel auszukennen!
                      Als erstes nimmst du eine neue gute SD-Karte.
                      Dann hast du für den Notfall immer noch die alte als Hardwarebackup.
                      Wobei ich nicht weiß ob das auch nur annähernd einen Sinn ergibt.
                      Dann
                      mit dem Backitup Adapter.
                      Das Ergebnis sicherst du außerhalb des RasPis
                      Die Infos für das OS und für ioB hat dir @Thomas-Braun schon verlinkt.
                      Wofür man einen
                      Printserver
                      auf einem Server benötigt erschließt sich mir nicht.
                      Ob und wie man die Konfig von pihole sichern kann weiß ich nicht.
                      wendy2702 1 Reply Last reply Reply Quote 1
                      • wendy2702
                        wendy2702 @Homoran last edited by
                        @homoran Printserver..
                        Vermutung: am PI hängt ein USB Drucker der über den Server im Netzwerk verfügbar gemacht wird.!?
                          syntetic @wendy2702 last edited by syntetic
                          So, erstmal tausend Dank an alle helfenden Köpfe, v.a. @Homoran und @Thomas-Braun. Ich habe ein Backup vom ioBroker per Backitup aufs NAS gespielt. Anschließend den Raspberry komplett neu installiert mit aktuellem OS, alle Updates gezogen und anschließend das Backup aufgespielt. Hat einige Zeit gedauert, aber es scheint tatsächlich alles zu funktionieren. Ich versuche, es in Zukunft aktuell zu halten und regelmäßige Updates zu machen.
                          @wendy2702 said in Veraltetes System retten:
                          Richtig, der Drucker kann kein AirPrint. Damit ich trotzdem über alle Geräte inkl. iPhones drucken kann, hab ich das per Printserver auf dem Raspberry gemacht.
                            klingt gut!
                            was sagt ein aktuelles iob diag?
                              @homoran said in Veraltetes System retten:
                              klingt gut!
                              Ich hab ein bisschen Angst, dass du mir gleich wieder den Wind aus den Segeln nimmst, weil irgendwas nicht passt 😰
                              Script v.2025-03-08
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                        Kernel: Linux 6.12.25+rpt-rpi-v8
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               21:39:01 up  2:52,  2 users,  load average: 1.11, 0.78, 0.82
                              CPU threads: 4
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              Current issues:
                                             Local time: Mon 2025-06-16 21:39:01 CEST
                                         Universal time: Mon 2025-06-16 19:39:01 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              mitcho
                              HOME=/home/mitcho
                              GROUPS=mitcho adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Mem:            4.0G        2.2G        303M        8.7M        1.6G        1.7G
                              Swap:           536M          0B        536M
                              Total:          4.5G        2.2G        840M
                              Active iob-Instances: 	14
                                       3797 M total memory
                                       2131 M used memory
                                       2079 M active memory
                                       1211 M inactive memory
                                        289 M free memory
                                         67 M buffer memory
                                       1421 M swap cache
                                        511 M total swap
                                          0 M used swap
                                        511 M free swap
                              top - 21:39:02 up  2:52,  2 users,  load average: 1.10, 0.78, 0.82
                              Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   3797.4 total,    288.7 free,   2131.7 used,   1488.6 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1665.8 avail Mem
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.6G     0  1.6G   0% /dev
                              tmpfs          tmpfs     380M  5.9M  374M   2% /run
                              /dev/mmcblk0p2 ext4      235G  4.5G  218G   3% /
                              tmpfs          tmpfs     1.9G  2.5M  1.9G   1% /dev/shm
                              /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                              [Mon Jun 16 18:46:23 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd7d57f9-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Mon Jun 16 18:46:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                              [Mon Jun 16 18:46:25 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                              /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                              `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              898M	/var/
                              208M	/var/cache
                              202M	/var/cache/apt
                              164M	/var/lib
                              135M	/var/lib/apt/lists
                              Archived and active journals take up 4.7M in the file system.
                              4.9M	/opt/iobroker/backups/
                              289M	/opt/iobroker/iobroker-data/
                              180M	/opt/iobroker/iobroker-data/files
                              47M	/opt/iobroker/iobroker-data/files/admin.admin
                              46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                              60M	/opt/iobroker/iobroker-data/objects.jsonl
                              45M	/opt/iobroker/iobroker-data/states.jsonl
                              24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                              8.4M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
                              8.1M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/nodejs 	v20.19.2
                              /usr/bin/node 		v20.19.2
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              /usr/bin/corepack 	0.31.0
                              nodejs:
                                Installed: 20.19.2-1nodesource1
                                Candidate: 20.19.2-1nodesource1
                                Version table:
                               *** 20.19.2-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                   20.19.1-1nodesource1 1001
                                   20.19.0-1nodesource1 1001
                                   20.18.3-1nodesource1 1001
                                   20.18.2-1nodesource1 1001
                                   20.18.1-1nodesource1 1001
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                   18.19.0+dfsg-6~deb12u1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 9063)
                              admin: 		7.6.17
                              javascript: 	8.9.2
                              Adapter State
                              + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                system.adapter.history.0                : history               : raspberrypi                              - disabled
                                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                                system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                              + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
                                system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                              + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
                                system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
                              + instance is alive
                              Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                              Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                              Adapter    "shelly"       : 9.5.1    , installed 9.5.1
                              Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                              Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                              Adapter    "web"          : 7.0.8    , installed 7.0.8
                              Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                              Objects and States
                              Objects: 	86932
                              States: 	64365
                              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      995        9798       1936/pihole-FTL
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1847       600/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      995        11311      1936/pihole-FTL
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      995        9797       1936/pihole-FTL
                              tcp        0      0 127.0.0.1:33217         0.0.0.0:*               LISTEN      1001       207245     4857/io.yahka.0
                              tcp        0      0 0.0.0.0:34815           0.0.0.0:*               LISTEN      1001       207236     4857/io.yahka.0
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32916      3698/iobroker.js-co
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31951      3698/iobroker.js-co
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       33376      3853/io.shelly.1
                              tcp6       0      0 :::443                  :::*                    LISTEN      995        9800       1936/pihole-FTL
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          1849       600/sshd: /usr/sbin
                              tcp6       0      0 :::53                   :::*                    LISTEN      995        11313      1936/pihole-FTL
                              tcp6       0      0 :::80                   :::*                    LISTEN      995        9799       1936/pihole-FTL
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33298      3915/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31487      3716/io.admin.0
                              udp        0      0 0.0.0.0:36765           0.0.0.0:*                           104        4545       461/avahi-daemon: r
                              udp        0      0 0.0.0.0:53              0.0.0.0:*                           995        11310      1936/pihole-FTL
                              udp        0      0 0.0.0.0:123             0.0.0.0:*                           995        11407      1936/pihole-FTL
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4543       461/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       34178      3846/io.shelly.0
                              udp6       0      0 :::57251                :::*                                104        4546       461/avahi-daemon: r
                              udp6       0      0 :::53                   :::*                                995        11312      1936/pihole-FTL
                              udp6       0      0 :::123                  :::*                                995        8894       1936/pihole-FTL
                              udp6       0      0 :::5353                 :::*                                104        4544       461/avahi-daemon: r
                              2025-06-16 21:14:31.745  - error: javascript.0 (3728) Script script.js.Überwachung.PV_Anlage_Datenabfrage is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
                              2025-06-16 21:14:31.746  - info: javascript.0 (3728) Stopping script script.js.Überwachung.PV_Anlage_Datenabfrage
                              2025-06-16 21:22:14.125  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                              2025-06-16 21:22:16.405  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                              2025-06-16 21:22:17.802  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                              2025-06-16 21:22:19.028  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                              2025-06-16 21:22:22.685  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                              2025-06-16 21:22:23.134  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                              2025-06-16 21:22:26.223  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                              2025-06-16 21:22:36.173  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                              2025-06-16 21:30:00.092  - info: host.raspberrypi instance system.adapter.ical.1 in version "1.16.1" started with pid 7005
                              2025-06-16 21:30:04.144  - info: host.raspberrypi instance system.adapter.ical.2 in version "1.16.1" started with pid 7016
                              2025-06-16 21:30:05.707  - info: ical.1 (7005) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                              2025-06-16 21:30:08.147  - info: ical.1 (7005) processing URL: Geburtstage http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7obrJTyh7JrvM5W7hWbXKYV98z6u1ArEpUzT0Qfx8u5BCClYRNKct5WlBkEJoZzDg4
                              2025-06-16 21:30:08.445  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.1" started with pid 7031
                              2025-06-16 21:30:11.141  - info: ical.2 (7016) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                              2025-06-16 21:30:14.810  - info: ical.1 (7005) Terminated (NO_ERROR): Without reason
                              2025-06-16 21:30:15.279  - info: ical.2 (7016) processing URL: Termine http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7oYOZ-wGjmsa5xf0_Job--v
                              2025-06-16 21:30:15.370  - info: host.raspberrypi instance system.adapter.ical.1 having pid 7005 terminated with code 0 (NO_ERROR)
                              2025-06-16 21:30:16.034  - info: ical.0 (7031) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                              2025-06-16 21:30:17.850  - info: ical.0 (7031) processing URL: Abfallkalender http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7p4SoafHZSRCZlAgdEYtjMS7V69VebAe4k5Fje7F1AUj1kDgxQWHADWcnNrtdAr7CU
                              2025-06-16 21:30:20.594  - info: ical.2 (7016) Terminated (NO_ERROR): Without reason
                              2025-06-16 21:30:21.141  - info: host.raspberrypi instance system.adapter.ical.2 having pid 7016 terminated with code 0 (NO_ERROR)
                              2025-06-16 21:30:23.177  - info: ical.0 (7031) Terminated (NO_ERROR): Without reason
                              2025-06-16 21:30:23.713  - info: host.raspberrypi instance system.adapter.ical.0 having pid 7031 terminated with code 0 (NO_ERROR)
                                Nö, passt soweit. Bring vis noch auf Stand.
                                  wenn, dann nur um dir zu helfen.
                                  Aber ich sehe nichts, lediglich
                                  hat es da gehakt?
                                    hat es da gehakt?
                                    Nein. Schon erledigt.
                                      @syntetic
                                      Das würde ich mir aber anschauen:
                                      S Homoran 2 Replies Last reply Reply Quote 1
                                        @thomas-braun said in Veraltetes System retten:
                                        @syntetic
                                        Ich wollte das Abfrageintervall auf 10 Sekunden verkürzen. Das mochte er offenbar nicht. Bei 1 Minute gibts keine Probleme.
                                          auf 10 Sekunden
                                          sind das vielleicht Millisekunden?
                                            Nein, Sekunden. Scheint bekannt zu sein, was ich so gelesen habe. 1 Minute reicht i.d.R. auch.
                                            81.1k
                                            1636
