    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Modbus: Solax Hybrid X3 Gen4 schreiben
    • Codierknecht
      Codierknecht Developer Most Active @Homoran last edited by
      @homoran sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
      was zeigt denn der debug log wenn du den Wert unbestätigt änderst?
      2025-06-16 18:54:53.989	info	Disconnected from slave 192.168.179.39
      2025-06-16 18:54:53.989	debug	Closing client on purpose.
      2025-06-16 18:54:52.989	debug	Cleaning up request fifo.
      2025-06-16 18:54:52.989	debug	Clearing timeout of the current request.
      2025-06-16 18:54:52.989	debug	Socket closed with error
      2025-06-16 18:54:52.989	error	Cannot write single register [31]: {"err":"timeout","timeout":5000}
      2025-06-16 18:54:52.988	error	Client in error state.
      2025-06-16 18:54:52.988	error	Request timed out.
      2025-06-16 18:54:52.988	warn	Error: undefined
      2025-06-16 18:54:52.175	debug	[DevID_1/inputRegs] Poll address 0 - 36 registers
      2025-06-16 18:54:52.175	debug	[DevID_1] Poll start ---------------------
      2025-06-16 18:54:47.987	debug	state Changed ack=false: modbus.0.holdingRegisters._0x001F_SolarChargerUseMode: {"val":1,"ack":false,"ts":1750092887986,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1750092887986}
      2025-06-16 18:54:47.104	debug	[DevID_1/holdingRegs] Poll address 186 DONE
      2025-06-16 18:54:47.102	debug	[DevID_1/holdingRegs] Poll address 186 - 1 registers
      2025-06-16 18:54:47.093	debug	[DevID_1/holdingRegs] Poll address 170 DONE
      2025-06-16 18:54:47.091	debug	[DevID_1/holdingRegs] Poll address 170 - 5 registers
      2025-06-16 18:54:47.080	debug	[DevID_1/holdingRegs] Poll address 133 DONE
      2025-06-16 18:54:47.079	debug	[DevID_1/holdingRegs] Poll address 133 - 12 registers
      2025-06-16 18:54:47.069	debug	[DevID_1/holdingRegs] Poll address 31 DONE
      2025-06-16 18:54:47.067	debug	[DevID_1/holdingRegs] Poll address 31 - 2 registers
      2025-06-16 18:54:47.057	debug	[DevID_1/holdingRegs] Poll address 0 DONE
      2025-06-16 18:54:47.056	debug	[DevID_1/holdingRegs] Poll address 0 - 14 registers
      versuch da mal nur einzelne Register schreiben.
        Homoran Global Moderator Administrators @Codierknecht last edited by
        @codierknecht sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
        puuuh, doch der tcp2rtu konverter schuld?
        • Codierknecht
          Ausschließen möchte ich das nicht.
          Viel einstellen lässt sich da aber auch nicht:
          Bei Änderung der Baudrate oder des Protokolls steigt der Adapter aus.
            @codierknecht da kenn ich mich nicht mit aus
            vielleicht @wendy2702
            du kannst nicht zufällig testweise einen rtu2usb einbauen?
            wendy2702 Codierknecht 2 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @Homoran last edited by
              @homoran ich habe zwar noch nen Konverter liegen aber gerade kein Gerät zum beschreiben.
              Bin jetzt nur am Handy aber FC06 ist eigentlich Holding Register. Ist das da eingetragen?
              Zufälligerweise mal mit einem Offset +1 probiert?
              • Codierknecht
                Ich befürchte, ich habe beim Versuch die Firmware upzudaten, den Konverter zerlegt 😞
                • wendy2702
                  wendy2702 @Codierknecht last edited by
                  @codierknecht das ist ärgerlich.
                  • Codierknecht
                    Codierknecht Developer Most Active @wendy2702 last edited by
                    @wendy2702
                    Kommt morgen neu.
                    Gibt's bessere Alternativen zu Waveshare?
                    DIN-Montage mit PoE?
                    wendy2702 Homoran 2 Replies Last reply Reply Quote 0
                    • wendy2702
                      @codierknecht ich bin mit den Waveshare bisher super zufrieden.
                      Habe allerdings am Waveshare nur ein Gerät was ich beschreiben könnte… steht aber erst im Winter an das umzusetzen.
                        Homoran Global Moderator Administrators @Codierknecht last edited by Homoran
                        USB am iob-Slave
                        :duckundwech:
                        • wendy2702
                          @homoran damit könnte man zumindest mal testen und wenn es geht weiter mit Waveshare forschen
                          • Codierknecht
                            USB am iob-Slave
                            Muss das ein ioB-Slave sein?
                            Ich gehe mal davon aus, dass man erstmal einen USB-RS485-Konverter benötigt (den ich nicht besitze).
                            Könnte man den dann nicht auch an einen ESP mit Tasmota klemmen?
                              da hab ich dich anders eingeschätzt 😉
                              wasndas? 😂
                              damit hättest du jegliche weiteren Fehlerquellen ausgeschaltet.
                              Die Modbus Instanz auf dem Slave wäre dann direkt via RTU mit dem WR verbunden.
                              aber ohne RTU Stick geht's nicht "mal eben"
                              • wendy2702
                                So ein USB-RS485 Teil kostet 10-15€, dann könntest du mit irgendeinem Rechner auch erstmal mit Modbus Tool testen.
                                Oder auf einem alten PI oder so einfach erstmal IOB Installieren.
                                  Homoran Global Moderator Administrators @wendy2702 last edited by Homoran
                                  @wendy2702 sagte in Modbus: Solax Hybrid X3 Gen4 schreiben:
                                  dafür bekommst du sogar schon gute, ggf. mit galvanischer Trennung.
                                  https://www.welectron.com/Waveshare-17286-USB-TO-RS485
                                  Billige kosten einstellige Euros
                                  https://www.berrybase.de/usb-rs485-konverter
                                  (den kenn ich nicht!)
                                  • wendy2702
                                    @homoran Ich bin mit denen hier bisher immer gut gefahren:
                                    https://amzn.eu/d/0gFPUyH
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Homoran last edited by Codierknecht
                                      Werd' mir mal einen besorgen. Schadet ja nicht.
                                      wasndas?
                                      Da hätte ich Dich anders eingeschätzt 😀
                                      Microcontroller. ESP32 o.ä.
                                      Sowas in der Art:
                                      Dem verpasst man Tasmota als Firmware: https://tasmota.github.io/docs/Modbus-Bridge/
                                      Davon hab' ich immer welche rumliegen. 5V Spannung krieg ich problemlos zum WR.
                                      Da einen Slave hinzustellen, gestaltet sich schon schwieriger. Erstmal müsste ich meinen NUC aus dem Schaltschrank holen und dann noch für die Stromversorgung sorgen.
                                      Vielleicht besorg' ich mir ja doch mal 'nen Pi ... als Bastelbüchse.
                                      Morgen werde ich erstmal den Konverter tauschen, damit ich wieder Daten bekomme.
                                      Laut diese Info https://github.com/alienatedsec/solis-ha-modbus-cloud/discussions/17 bereitet wohl die veraltete Standard-FW Probleme. Beim Update hat's mir den Konverter zerschossen. Ist nicht mehr über Netz erreichbar und damit allem Anschein nach Elektroschrott.
                                      Weitere Versuche werde ich dann wohl erst mit dem USB/RS485 unternehmen.
                                      Danke euch für's Erste!
                                      • wendy2702
                                        @codierknecht hast du mal mit „Vircom“ geschaut? Nicht der nur ne default IP bekommen hat.
                                        • Codierknecht
                                          VirCom findet den nicht mehr. Zeigt auch keinen Link an ... es leuchtet nur die Power-LED.
                                          Und ja - den habe ich auch schon mal stromlos gemacht.
                                          • wendy2702
                                            @codierknecht ok.
                                            Dann wäre das die Gelegenheit das Gehäuse mal zu öffnen um zu gucken was da so drin ist 😚🫣
                                            3314
