    3. Off Topic
    4. Pflege des Betriebssystems
    5. Veraltetes System retten
      @syntetic sagte in Veraltetes System retten:
      es scheint tatsächlich alles zu funktionieren
      klingt gut!
      was sagt ein aktuelles iob diag?
        syntetic @Homoran last edited by
        @homoran said in Veraltetes System retten:
        klingt gut!
        Ich hab ein bisschen Angst, dass du mir gleich wieder den Wind aus den Segeln nimmst, weil irgendwas nicht passt 😰
        Script v.2025-03-08
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.25+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model		: Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         21:39:01 up  2:52,  2 users,  load average: 1.11, 0.78, 0.82
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-06-16 21:39:01 CEST
                   Universal time: Mon 2025-06-16 19:39:01 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        mitcho
        HOME=/home/mitcho
        GROUPS=mitcho adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Mem:            4.0G        2.2G        303M        8.7M        1.6G        1.7G
        Swap:           536M          0B        536M
        Total:          4.5G        2.2G        840M
        Active iob-Instances: 	14
                 3797 M total memory
                 2131 M used memory
                 2079 M active memory
                 1211 M inactive memory
                  289 M free memory
                   67 M buffer memory
                 1421 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 21:39:02 up  2:52,  2 users,  load average: 1.10, 0.78, 0.82
        Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3797.4 total,    288.7 free,   2131.7 used,   1488.6 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1665.8 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     380M  5.9M  374M   2% /run
        /dev/mmcblk0p2 ext4      235G  4.5G  218G   3% /
        tmpfs          tmpfs     1.9G  2.5M  1.9G   1% /dev/shm
        /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Mon Jun 16 18:46:23 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd7d57f9-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Jun 16 18:46:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
        [Mon Jun 16 18:46:25 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        898M	/var/
        208M	/var/cache
        202M	/var/cache/apt
        164M	/var/lib
        135M	/var/lib/apt/lists
        Archived and active journals take up 4.7M in the file system.
        /opt/iobroker/backups:
        4.9M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        289M	/opt/iobroker/iobroker-data/
        180M	/opt/iobroker/iobroker-data/files
        47M	/opt/iobroker/iobroker-data/files/admin.admin
        46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
        60M	/opt/iobroker/iobroker-data/objects.jsonl
        45M	/opt/iobroker/iobroker-data/states.jsonl
        24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
        8.4M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
        8.1M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
        *** ZigBee Settings ***
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.19.2
        /usr/bin/node 		v20.19.2
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.31.0
        nodejs:
          Installed: 20.19.2-1nodesource1
          Candidate: 20.19.2-1nodesource1
          Version table:
         *** 20.19.2-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 9063)
        Core adapters versions
        js-controller: 	7.0.6
        admin: 		7.6.17
        javascript: 	8.9.2
        nodejs modules from github: 	0
        Adapter State
        + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          system.adapter.history.0                : history               : raspberrypi                              - disabled
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
          system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
          system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
          system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
        + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Active repo(s): Stable (default)
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: Stable (default)
        Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "backitup"     : 3.2.2    , installed 3.2.2
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "shelly"       : 9.5.1    , installed 9.5.1
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
        Objects and States
        Objects: 	86932
        States: 	64365
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      995        9798       1936/pihole-FTL
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1847       600/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      995        11311      1936/pihole-FTL
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      995        9797       1936/pihole-FTL
        tcp        0      0 127.0.0.1:33217         0.0.0.0:*               LISTEN      1001       207245     4857/io.yahka.0
        tcp        0      0 0.0.0.0:34815           0.0.0.0:*               LISTEN      1001       207236     4857/io.yahka.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32916      3698/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31951      3698/iobroker.js-co
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       33376      3853/io.shelly.1
        tcp6       0      0 :::443                  :::*                    LISTEN      995        9800       1936/pihole-FTL
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1849       600/sshd: /usr/sbin
        tcp6       0      0 :::53                   :::*                    LISTEN      995        11313      1936/pihole-FTL
        tcp6       0      0 :::80                   :::*                    LISTEN      995        9799       1936/pihole-FTL
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33298      3915/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31487      3716/io.admin.0
        udp        0      0 0.0.0.0:36765           0.0.0.0:*                           104        4545       461/avahi-daemon: r
        udp        0      0 0.0.0.0:53              0.0.0.0:*                           995        11310      1936/pihole-FTL
        udp        0      0 0.0.0.0:123             0.0.0.0:*                           995        11407      1936/pihole-FTL
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4543       461/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       34178      3846/io.shelly.0
        udp6       0      0 :::57251                :::*                                104        4546       461/avahi-daemon: r
        udp6       0      0 :::53                   :::*                                995        11312      1936/pihole-FTL
        udp6       0      0 :::123                  :::*                                995        8894       1936/pihole-FTL
        udp6       0      0 :::5353                 :::*                                104        4544       461/avahi-daemon: r
        2025-06-16 21:14:31.745  - error: javascript.0 (3728) Script script.js.Überwachung.PV_Anlage_Datenabfrage is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
        2025-06-16 21:14:31.746  - info: javascript.0 (3728) Stopping script script.js.Überwachung.PV_Anlage_Datenabfrage
        2025-06-16 21:22:14.125  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
        2025-06-16 21:22:16.405  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
        2025-06-16 21:22:17.802  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
        2025-06-16 21:22:19.028  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
        2025-06-16 21:22:22.685  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
        2025-06-16 21:22:23.134  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
        2025-06-16 21:22:26.223  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
        2025-06-16 21:22:36.173  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
        2025-06-16 21:30:00.092  - info: host.raspberrypi instance system.adapter.ical.1 in version "1.16.1" started with pid 7005
        2025-06-16 21:30:04.144  - info: host.raspberrypi instance system.adapter.ical.2 in version "1.16.1" started with pid 7016
        2025-06-16 21:30:05.707  - info: ical.1 (7005) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
        2025-06-16 21:30:08.147  - info: ical.1 (7005) processing URL: Geburtstage http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7obrJTyh7JrvM5W7hWbXKYV98z6u1ArEpUzT0Qfx8u5BCClYRNKct5WlBkEJoZzDg4
        2025-06-16 21:30:08.445  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.1" started with pid 7031
        2025-06-16 21:30:11.141  - info: ical.2 (7016) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
        2025-06-16 21:30:14.810  - info: ical.1 (7005) Terminated (NO_ERROR): Without reason
        2025-06-16 21:30:15.279  - info: ical.2 (7016) processing URL: Termine http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7oYOZ-wGjmsa5xf0_Job--v
        2025-06-16 21:30:15.370  - info: host.raspberrypi instance system.adapter.ical.1 having pid 7005 terminated with code 0 (NO_ERROR)
        2025-06-16 21:30:16.034  - info: ical.0 (7031) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
        2025-06-16 21:30:17.850  - info: ical.0 (7031) processing URL: Abfallkalender http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7p4SoafHZSRCZlAgdEYtjMS7V69VebAe4k5Fje7F1AUj1kDgxQWHADWcnNrtdAr7CU
        2025-06-16 21:30:20.594  - info: ical.2 (7016) Terminated (NO_ERROR): Without reason
        2025-06-16 21:30:21.141  - info: host.raspberrypi instance system.adapter.ical.2 having pid 7016 terminated with code 0 (NO_ERROR)
        2025-06-16 21:30:23.177  - info: ical.0 (7031) Terminated (NO_ERROR): Without reason
        2025-06-16 21:30:23.713  - info: host.raspberrypi instance system.adapter.ical.0 having pid 7031 terminated with code 0 (NO_ERROR)
          Thomas Braun Most Active @syntetic last edited by
          Nö, passt soweit. Bring vis noch auf Stand.
            Homoran Global Moderator Administrators @syntetic last edited by
            wenn, dann nur um dir zu helfen.
            Aber ich sehe nichts, lediglich
            hat es da gehakt?
              hat es da gehakt?
              Nein. Schon erledigt.
                @syntetic
                Das würde ich mir aber anschauen:
                S Homoran 2 Replies Last reply Reply Quote 1
                  syntetic @Thomas Braun last edited by
                  @thomas-braun said in Veraltetes System retten:
                  @syntetic
                  Ich wollte das Abfrageintervall auf 10 Sekunden verkürzen. Das mochte er offenbar nicht. Bei 1 Minute gibts keine Probleme.
                    auf 10 Sekunden
                    sind das vielleicht Millisekunden?
                      Nein, Sekunden. Scheint bekannt zu sein, was ich so gelesen habe. 1 Minute reicht i.d.R. auch.
                        @thomas-braun sagte in Veraltetes System retten:
                        bei 10 Sekunden Intervall müssten das ja 200 setState() pro Aufruf sein
                          peterfido @Homoran last edited by
                          @homoran Hauptsache, da wird nicht auch jedesmal in den Flash vom Wechselrichter geschrieben.
                          1.0k
                          81.1k
                          1636
