    4. Test Adapter toyota v.0.0.x
      tombox @MarvinTheRobot last edited by
      @marvintherobot Aber die version scheint nicht via GitHub installiert zu sein
      Alex1808 MarvinTheRobot 2 Replies Last reply Reply Quote 0
      • Alex1808
        Alex1808 @tombox last edited by
        @tombox
        gleiche Problem..
        toyota.0
        	2025-04-29 16:12:56.056	error	{"status":{"messages":[{"responseCode":"APIGW-403","description":"Unauthorized","detailedDescription":"Unauthorized client "}]}}
        toyota.0
        	2025-04-29 16:12:56.055	error	AxiosError: Request failed with status code 403
        toyota.0
        	2025-04-29 16:12:55.944	info	Get Vehicles
        toyota.0
        	2025-04-29 16:12:55.943	info	Login successful
        toyota.0
        	2025-04-29 16:12:55.801	info	Start token exchange
        toyota.0
        	2025-04-29 16:12:54.978	info	Login to Toyota
        toyota.0
        	2025-04-29 16:12:54.969	info	starting. Version 0.2.6 (non-npm: TA2k/ioBroker.toyota#3db29ad8b_lange_code_15119) in /opt/iobroker/node_modules/iobroker.toyota, node: v20.19.1, js-controller: 7.0.7
        host.iobroker
        	2025-04-29 16:12:54.125	info	instance system.adapter.toyota.0 in version "0.2.6" (non-npm: TA2k/ioBroker.toyota#3db29ad8b_lange_code_15119) started with pid 2140519
        • MarvinTheRobot
          MarvinTheRobot @tombox last edited by
          @tombox
          sorry du hast recht, ich hab vergessen oben bei der katze auf "github" zu klicken und die version von npm installiert, hab den adapter nun gelöscht und komplett neu installiert.
          toyota.0 2025-04-29 18:18:25.173	info	starting. Version 0.2.6 (non-npm: TA2k/ioBroker.toyota) in /opt/iobroker/node_modules/iobroker.toyota, node: v20.19.1, js-controller: 7.0.6
          toyota.0 2025-04-29 18:18:25.192	info	Login to Toyota
          toyota.0 2025-04-29 18:18:26.222	info	Start token exchange
          toyota.0 2025-04-29 18:18:26.372	info	Login successful
          toyota.0 2025-04-29 18:18:26.373	info	Get Vehicles
          toyota.0 2025-04-29 18:18:26.529	error	AxiosError: Request failed with status code 403
          toyota.0 2025-04-29 18:18:26.531	error	{"status":{"messages":[{"responseCode":"APIGW-403","description":"Unauthorized","detailedDescription":"Unauthorized client "}]}}
          sieht leider nicht anders aus...?
            ETGermany last edited by
            @MarvinTheRobot: Ihr seid noch nicht weitergekommen, habe mir jetzt erst einmal den Python Skript eingerichtet. Benötige nur einige Angaben für meine Ladesteuerung.
            • I
              IOSD @ETGermany last edited by
              Bei mir geht es auch nicht mehr. Ich brauche es auch für den Ladestand. Hat jemand einen Workaround?
                Filo last edited by
                Hallo allerseits,
                bei mir das gleiche, keine Funktion seit 22.04..
                Grus Filo
                  baschtlbaschtl @Filo last edited by
                  Moin,
                  bei mir sieht es seit etwa einem Monat leider ganz genau so aus.
                  • mcm1957
                    mcm1957 @baschtlbaschtl last edited by
                    Issue ist offen:
                    https://github.com/TA2k/ioBroker.toyota/issues/24
                    MarvinTheRobot 1 Reply Last reply Reply Quote 0
                    • MarvinTheRobot
                      MarvinTheRobot @mcm1957 last edited by
                      ...gibt es schon Neuigkeiten? Wird noch daran gearbeitet oder gibt es einen Alternativ Adapter?
                        ETGermany @MarvinTheRobot last edited by
                        @marvintherobot: Wie bereits am 9. Mai geschrieben eine alternative wäre https://github.com/pytoyoda/pytoyoda
                        @tombox hat je bereits einige Anpassungen beim Login versucht, die bisher aber keinen Erfolg brachten. Wo auch immer der Hase im Pfeffer liegt.
                        • Alex1808
                          Alex1808 @ETGermany last edited by
                          @etgermany
                          Eventuell lohnt sich ein Blick in den Code von EVCC – dort funktioniert die Einbindung ohne Probleme.
                          https://github.com/evcc-io/evcc/tree/master/vehicle/toyota
                            tombox @Alex1808 last edited by
                            @alex1808 ich habe KI versuch die version fixen zu lassen aber ich habe keine Zugangsdaten zum testen einfach via GitHub testen
                              solver @tombox last edited by
                              @tombox Hallo, hab die Version auf Github probiert. Folgende Meldung kam danach:
                              toyota.0 2025-07-09 13:13:36.833 error No Token Response
                              toyota.0 2025-07-09 13:13:35.538 info Login to Toyota
                              toyota.0 2025-07-09 13:13:35.530 info starting. Version 0.2.6 (non-npm: TA2k/ioBroker.toyota) in /opt/iobroker/node_modules/iobroker.toyota, node: v20.19.3, js-controller: 7.0.7
                              lg
                              solver
                                tombox @solver last edited by
                                @solver kompletter debug log wäre besser
                                  @tombox
                                  toyota.0
                                  2025-07-10 07:11:47.988 error No Token Response
                                  toyota.0
                                  2025-07-10 07:11:47.713 debug {"tokenId":"iYoAnxn73tw87U0PsxV9qxwtleg.AAJTSQACMDIAAlNLABxkNDNGUzhaQk0wM2hqa0w1aGNtbFJzQ0ZTSmM9AAR0eXBlAANDVFMAAlMxAAIwMQ..","successUrl":"/console","realm":"/tme"}
                                  toyota.0
                                  2025-07-10 07:11:47.459 debug {"authId":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.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.obafNuKSTE45BbmjeIIr0V1idTQXZ1XLUaO3tFELONQ","callbacks":[{"type":"PasswordCallback","output":[{"name":"prompt","value":"Password"}],"input":[{"name":"IDToken1","value":""}],"_id":5},{"type":"ChoiceCallback","output":[{"name":"prompt","value":"Prompt"},{"name":"choices","value":["continue","resetpass"]},{"name":"defaultChoice","value":0}],"input":[{"name":"IDToken2","value":0}],"_id":6}]}
                                  toyota.0
                                  2025-07-10 07:11:47.249 debug {"authId":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.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.JDFy58EY3PJFpHbASbcHvqy2wbjKPsPJX4RGvafIn0Q","callbacks":[{"type":"NameCallback","output":[{"name":"prompt","value":"User Name"}],"input":[{"name":"IDToken1","value":""}],"_id":3},{"type":"ChoiceCallback","output":[{"name":"prompt","value":"Prompt"},{"name":"choices","value":["Local","Google","Facebook","Apple"]},{"name":"defaultChoice","value":0}],"input":[{"name":"IDToken2","value":0}],"_id":4}]}
                                  toyota.0
                                  2025-07-10 07:11:47.078 debug {"authId":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.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.Qci9sOzklLw8iYEl3axjk_o79C9_QHUJF9fYzAk1ctk","callbacks":[{"type":"NameCallback","output":[{"name":"prompt","value":"Market Locale"}],"input":[{"name":"IDToken1","value":""}],"_id":0},{"type":"NameCallback","output":[{"name":"prompt","value":"Internationalization"}],"input":[{"name":"IDToken2","value":""}],"_id":1},{"type":"NameCallback","output":[{"name":"prompt","value":"UI Locales"}],"input":[{"name":"IDToken3","value":""}],"_id":2}]}
                                  toyota.0
                                  2025-07-10 07:11:46.808 info Login to Toyota
                                  toyota.0
                                  2025-07-10 07:11:46.801 info starting. Version 0.2.6 (non-npm: TA2k/ioBroker.toyota) in /opt/iobroker/node_modules/iobroker.toyota, node: v20.19.3, js-controller: 7.0.7
                                    markusw67 last edited by
                                    Hi, Anfänger Frage-> wo muss ich meine Logindaten eintippen?
                                    • MarvinTheRobot
                                      MarvinTheRobot @ETGermany last edited by
                                      @etgermany
                                      Ich habs jetzt mit pytoyoda geschafft daten aus meinem Fahrzeug auszulesen, das python script nach meinen vorstellungen angepasst. mit einem bashscript ruf ich das ganze auf und geb mir die für mich relevanten werte mit "jq" (json filter) einfach aus. Den output verwend ich in iobroker weiter für javascript/blockly. funktioniert, ist aber ein hässlicher quirks.
                                      langer rede kurzer sinn - ein login ist möglich, das py script funktioniert. Wäre es möglich das zu "portieren"?
                                      lg!
                                      96
                                      11229
