    4. Skript reagiert nicht mehr auf Aktualisierung von Objekt
      Homoran Global Moderator Administrators @daniello last edited by
      @daniello sagte in Skript reagiert nicht mehr auf Aktualisierung von Objekt:
      aber bei App passiert Unterschiedliches.
      was denn?
      bitte beachten:
      das hier
      kann ich nicht entziffern
      und aus den Objektdaten kann ich nicht zitieren
        daniello @Homoran last edited by
        Oje .. hab ich inzwsichen alles verbastelt?
        @Homoran
          "_id": "0_userdata.0.lg_firetv",
          "type": "state",
          "common": {
            "name": "lg_firetv",
            "role": "",
            "type": "boolean",
            "read": true,
            "write": true,
            "states": "false:no;true:yes",
            "desc": "Manuell erzeugt",
            "def": "",
            "smartName": {
              "de": "",
              "smartType": "SWITCH"
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636,
            "owner": "system.user.admin",
          "user": "system.user.admin",
          "ts": 1750594714227
        App über Skript
        2025-06-22 16:50:05.608 - debug: lgtv.0 (1610) State change
        "states.launch" - VALUE: Fire TV
        2025-06-22 16:50:05.609 - debug: lgtv.0 (1610) Sending launch command
        Fire TV to WebOS TV: 192.168.178.221
        2025-06-22 16:50:05.609 - debug: lgtv.0 (1610) Opening app Fire TV on
        App über Adapterobjekt
        2025-06-22 16:47:55.329 - debug: lgtv.0 (1610) Connection closed: 1000
        2025-06-22 16:47:55.821 - debug: lgtv.0 (1610) Connecting to WebOS TV:
        wss://192.168.178.221:3001
        2025-06-22 16:47:55.960 - debug: lgtv.0 (1610) WebOS TV Connected
        2025-06-22 16:47:56.180 - debug: lgtv.0 (1610) audio/getSoundOutput: {}
        2025-06-22 16:47:56.184 - debug: lgtv.0 (1610) audio/getVolume:
        {"muted":false,"scenario":"mastervolume_tv_speaker","active":false,"action":"requested","volume":10,"returnValue":true,"subscribed":true,"changed":["muted","volume"]}
        2025-06-22 16:47:56.187 - debug: lgtv.0 (1610) DEBUGGING
        getForegroundAppInfo:
        {"appId":"com.webos.app.livetv","subscribed":true,"returnValue":true,"windowId":"","processId":"n-2205"}
        2025-06-22 16:47:56.188 - debug: lgtv.0 (1610) cur app is
        2025-06-22 16:47:56.196 - debug: lgtv.0 (1610) tv/getCurrentChannel:
        {"channelId":"3_49_2_0_1079_11110_1","signalChannelId":"1079_11110_1","channelModeId":1,"channelModeName":"Cable","channelTypeId":4,"channelTypeName":"Cable Digital TV","channelNumber":"2","channelName":"ZDF HD","physicalNumber":49,"isSkipped":false,"isLocked":false,"isDescrambled":false,"isScrambled":false,"isFineTuned":false,"isInvisible":false,"favoriteGroup":null,"hybridtvType":"HBBTV","dualChannel":{"dualChannelId":null,"dualChannelTypeId":null,"dualChannelTypeName":null,"dualChannelNumber":null},"returnValue":true}
        2025-06-22 16:47:56.225 - debug: lgtv.0 (1610) getCurrentSWInformation:
        {"returnValue":true,"product_name":"webOS","model_name":"HE_DTV_WT1M_AFAAABAA","sw_type":"FIRMWARE","major_ver":"05","minor_ver":"05.90","country":"DE","device_id":"3c:cd:93:68:dc:dc","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"}
        2025-06-22 16:47:56.227 - debug: lgtv.0 (1610) getSystemInfo:
        {"features":
        {"3d":true,"dvr":true},"receiverType":"dvb","modelName":"42LB730V-
        ZD","returnValue":true}
        2025-06-22 16:47:56.233 - debug: lgtv.0 (1610) Service list:
        {"services":[{"name":"api","version":1},{"name":"audio","version":1},
        {"name":"media.controls","version":1},
        {"name":"media.viewer","version":1},{"name":"pairing","version":1},
        {"name":"system","version":1},{"name":"system.launcher","version":1},
        {"name":"system.notifications","version":1},{"name":"tv","version":1},
        {"name":"webapp","version":2}],"returnValue":true}
        2025-06-22 16:47:59.219 - debug: lgtv.0 (1610) tv/getCurrentChannel:
        2025-06-22 16:48:00.840 - debug: lgtv.0 (1610) State change
        "states.launch" - VALUE: com.webos.app.hdmi2
        2025-06-22 16:48:00.840 - debug: lgtv.0 (1610) Sending launch command
        com.webos.app.hdmi2 to WebOS TV: 192.168.178.221
        2025-06-22 16:48:00.841 - debug: lgtv.0 (1610) Opening app
        com.webos.app.hdmi2 on WebOS TV: 192.168.178.221
        2025-06-22 16:48:01.186 - debug: lgtv.0 (1610) DEBUGGING
        {"appId":"com.webos.app.hdmi2","returnValue":true,"windowId":"","processId":"1054"}
        2025-06-22 16:48:01.186 - debug: lgtv.0 (1610) cur app is
        com.webos.app.hdmi2
          paul53 @daniello last edited by paul53
          @daniello sagte: hab ich inzwsichen alles verbastelt?
          Wenn es nun doch "boolean" sein soll, ändere:
              "role": "switch",
              "type": "boolean",
              "read": true,
              "write": true,
              "states": {
                  "false": "no",
                  "true": "yes"
              "def": false,
            daniello @paul53 last edited by
            Danke Paul .. hab ich gemacht .. wirft allerdings sofort wieder diese Warnung:
            Object 0_userdata.0.lg_firetv is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
            Macht mich Irre diese Meldung .. hatte vormals auf String gestellt war aber auch wieder falsch 😞
              @daniello sagte: Expected "object"
              Das kann nicht sein, wenn common.type = "boolean" ist.
              Woher kommt der String?
              Offenbar wird doch ein String geschrieben?
              EDIT: Die Meldung betrifft common.states
                daniello @paul53 last edited by daniello
                Hab mal history angemacht für das Objekt:
                Wobei die Warnung von Admin kommt .. also wenn ich am Objekt ändere. Beschicken tut das Feld nur der iot Adapter.
                Kann es sein, das IOT ordentlich True/False sendet und der Admin das was wiederum beim Ändern des Objekts True und False als String interpretiert?
                  Homoran Global Moderator Administrators @daniello last edited by Homoran
                  @daniello schreibt der true/false oder 1/0 oder "true"/"false"?
                  edit:
                  oder gar
                    @daniello sagte: Wobei die Warnung von Admin kommt
                    Die Warnung erzeugt der js-controller.
                    Nein, es kann sein dass IOT "false" und "true" (als String) sendet? Ich kenne IOT nicht.
                    Es lässt sich leicht prüfen:
                      Danke, gibt "boolean" aus.
                      @Homoran
                      Ist die Idee von
                      zu ändern in
                      "states": "false:false;true:true",
                        Ist die Idee
                        nein, ich will nur wissen was da ankommt.
                        gibt "boolean" aus.
                        das dürfte dann nicht als String interpretiert werden.
                        auch loggen von Quelle aktiviert?
                        kommt da von verschiedenen Quellen ein Wert?
                          @daniello sagte: obj.common.states has an invalid type! Expected "object"
                          Lösche "states" oder mache es richtig wie hier gezeigt (Zeilen 5 bis 8).
                            danke .. Objekt scheint jetzt ok zu sein
                            @Homoran
                            "Quelle aktivieren" finde ich nicht .. aber es kommt nur was von iot.0
                            Input schalten funktioniert weiterhin auch per Skript. Launch app funktioniert weiterhin nur in den Objekten.
                            Für mein Seelenfrieden genügt die Umschaltung über Input .. aber technisch sollte auch das andere funktionieren.
                            1525
