Skript reagiert nicht mehr auf Aktualisierung von Objekt
Oje .. hab ich inzwsichen alles verbastelt?
{ "_id": "0_userdata.0.lg_firetv", "type": "state", "common": { "name": "lg_firetv", "role": "", "type": "boolean", "read": true, "write": true, "states": "false:no;true:yes", "desc": "Manuell erzeugt", "def": "", "smartName": { "de": "", "smartType": "SWITCH" } }, "native": {}, "acl": { "object": 1636, "state": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator" }, "from": "system.adapter.admin.0", "user": "system.user.admin", "ts": 1750594714227 }App über Skript
2025-06-22 16:50:05.608 - debug: lgtv.0 (1610) State change "states.launch" - VALUE: Fire TV 2025-06-22 16:50:05.609 - debug: lgtv.0 (1610) Sending launch command Fire TV to WebOS TV: 192.168.178.221 2025-06-22 16:50:05.609 - debug: lgtv.0 (1610) Opening app Fire TV on WebOS TV: 192.168.178.221App über Adapterobjekt
2025-06-22 16:47:55.329 - debug: lgtv.0 (1610) Connection closed: 1000 2025-06-22 16:47:55.821 - debug: lgtv.0 (1610) Connecting to WebOS TV: wss://192.168.178.221:3001 2025-06-22 16:47:55.960 - debug: lgtv.0 (1610) WebOS TV Connected 2025-06-22 16:47:56.180 - debug: lgtv.0 (1610) audio/getSoundOutput: {} 2025-06-22 16:47:56.184 - debug: lgtv.0 (1610) audio/getVolume: {"muted":false,"scenario":"mastervolume_tv_speaker","active":false,"action":"requested","volume":10,"returnValue":true,"subscribed":true,"changed":["muted","volume"]} 2025-06-22 16:47:56.187 - debug: lgtv.0 (1610) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.livetv","subscribed":true,"returnValue":true,"windowId":"","processId":"n-2205"} 2025-06-22 16:47:56.188 - debug: lgtv.0 (1610) cur app is com.webos.app.livetv 2025-06-22 16:47:56.196 - debug: lgtv.0 (1610) tv/getCurrentChannel: {"channelId":"3_49_2_0_1079_11110_1","signalChannelId":"1079_11110_1","channelModeId":1,"channelModeName":"Cable","channelTypeId":4,"channelTypeName":"Cable Digital TV","channelNumber":"2","channelName":"ZDF HD","physicalNumber":49,"isSkipped":false,"isLocked":false,"isDescrambled":false,"isScrambled":false,"isFineTuned":false,"isInvisible":false,"favoriteGroup":null,"hybridtvType":"HBBTV","dualChannel":{"dualChannelId":null,"dualChannelTypeId":null,"dualChannelTypeName":null,"dualChannelNumber":null},"returnValue":true} 2025-06-22 16:47:56.225 - debug: lgtv.0 (1610) getCurrentSWInformation: {"returnValue":true,"product_name":"webOS","model_name":"HE_DTV_WT1M_AFAAABAA","sw_type":"FIRMWARE","major_ver":"05","minor_ver":"05.90","country":"DE","device_id":"3c:cd:93:68:dc:dc","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"} 2025-06-22 16:47:56.227 - debug: lgtv.0 (1610) getSystemInfo: {"features": {"3d":true,"dvr":true},"receiverType":"dvb","modelName":"42LB730V- ZD","returnValue":true} 2025-06-22 16:47:56.233 - debug: lgtv.0 (1610) Service list: {"services":[{"name":"api","version":1},{"name":"audio","version":1}, {"name":"media.controls","version":1}, {"name":"media.viewer","version":1},{"name":"pairing","version":1}, {"name":"system","version":1},{"name":"system.launcher","version":1}, {"name":"system.notifications","version":1},{"name":"tv","version":1}, {"name":"webapp","version":2}],"returnValue":true} 2025-06-22 16:47:59.219 - debug: lgtv.0 (1610) tv/getCurrentChannel: {"channelId":"3_49_2_0_1079_11110_1","signalChannelId":"1079_11110_1","channelModeId":1,"channelModeName":"Cable","channelTypeId":4,"channelTypeName":"Cable Digital TV","channelNumber":"2","channelName":"ZDF HD","physicalNumber":49,"isSkipped":false,"isLocked":false,"isDescrambled":false,"isScrambled":false,"isFineTuned":false,"isInvisible":false,"favoriteGroup":null,"hybridtvType":"HBBTV","dualChannel":{"dualChannelId":null,"dualChannelTypeId":null,"dualChannelTypeName":null,"dualChannelNumber":null},"returnValue":true} 2025-06-22 16:48:00.840 - debug: lgtv.0 (1610) State change "states.launch" - VALUE: com.webos.app.hdmi2 2025-06-22 16:48:00.840 - debug: lgtv.0 (1610) Sending launch command com.webos.app.hdmi2 to WebOS TV: 192.168.178.221 2025-06-22 16:48:00.841 - debug: lgtv.0 (1610) Opening app com.webos.app.hdmi2 on WebOS TV: 192.168.178.221 2025-06-22 16:48:01.186 - debug: lgtv.0 (1610) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi2","returnValue":true,"windowId":"","processId":"1054"} 2025-06-22 16:48:01.186 - debug: lgtv.0 (1610) cur app is com.webos.app.hdmi2 -
@daniello sagte: hab ich inzwsichen alles verbastelt?
Wenn es nun doch "boolean" sein soll, ändere:
"role": "switch", "type": "boolean", "read": true, "write": true, "states": { "false": "no", "true": "yes" }, "desc": "Manuell erzeugt", "def": false, -
Danke Paul .. hab ich gemacht .. wirft allerdings sofort wieder diese Warnung:
Object 0_userdata.0.lg_firetv is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
Macht mich Irre diese Meldung .. hatte vormals auf String gestellt war aber auch wieder falsch
@daniello sagte: Expected "object"
Das kann nicht sein, wenn common.type = "boolean" ist.
Woher kommt der String?@daniello sagte in Skript reagiert nicht mehr auf Aktualisierung von Objekt:
Offenbar wird doch ein String geschrieben?EDIT: Die Meldung betrifft common.states
Hab mal history angemacht für das Objekt:
Wobei die Warnung von Admin kommt .. also wenn ich am Objekt ändere. Beschicken tut das Feld nur der iot Adapter.
Kann es sein, das IOT ordentlich True/False sendet und der Admin das was wiederum beim Ändern des Objekts True und False als String interpretiert?
@daniello schreibt der true/false oder 1/0 oder "true"/"false"?
edit:
oder gar
@daniello sagte in Skript reagiert nicht mehr auf Aktualisierung von Objekt:"states": "false:no;true:yes", -
@daniello sagte: Wobei die Warnung von Admin kommt
Die Warnung erzeugt der js-controller.
Nein, es kann sein dass IOT "false" und "true" (als String) sendet? Ich kenne IOT nicht.
Es lässt sich leicht prüfen:
Ist die Idee
nein, ich will nur wissen was da ankommt.
gibt "boolean" aus.
das dürfte dann nicht als String interpretiert werden.
auch loggen von Quelle aktiviert?
kommt da von verschiedenen Quellen ein Wert? -
danke .. Objekt scheint jetzt ok zu sein
"Quelle aktivieren" finde ich nicht .. aber es kommt nur was von iot.0
Input schalten funktioniert weiterhin auch per Skript. Launch app funktioniert weiterhin nur in den Objekten.
Für mein Seelenfrieden genügt die Umschaltung über Input .. aber technisch sollte auch das andere funktionieren.
