    3. Off Topic
    4. Pflege des Betriebssystems
    5. pnpm Fehler
    pnpm Fehler
      Thomas Braun Most Active @Autodidakt last edited by
      @autodidakt
      Der user 'pi' darf nicht nach /usr/lib/ schreiben, das darf nur root.
      nodemodule, die global verfügbar sein sollen muss also der root dort hinlegen.
      Wird dir aber auch angesagt:
      npm error If you believe this might be a permissions issue, please double-check the
      npm error permissions of the file and its containing directories, or try running
      npm error the command again as root/Administrator.
      Also:
      sudo npm install -g pnpm
      Autodidakt 1 Reply Last reply Reply Quote 0
      • Autodidakt
        Autodidakt @Thomas Braun last edited by
        @thomas-braun Danke, wieder was gelernt...
        • Autodidakt
          Autodidakt last edited by Autodidakt
          Und schon kommt das nächste Problem.
          Zigbee2Mqtt will ums verrecken nicht starten.
          pi@pi4-Master:/opt/zigbee2mqtt $ pnpm start
          > zigbee2mqtt@2.4.0 start /opt/zigbee2mqtt
          > node index.js
          Starting Zigbee2MQTT without watchdog.
          [2025-06-23 16:21:03] info:     z2m: Logging to console, file (filename: log.log)
          [2025-06-23 16:21:04] info:     z2m: Starting Zigbee2MQTT version 2.4.0 (commit #bdb94da4)
          [2025-06-23 16:21:04] info:     z2m: Starting zigbee-herdsman (4.1.0)
          [2025-06-23 16:21:04] info:     zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"ac315ae1c912ef1184ed6fb8bf9df066","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_ac315ae1c912ef1184ed6fb8bf9df066-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: 4
          [2025-06-23 16:21:04] info:     zh:ember: Using default stack config.
          [2025-06-23 16:21:04] info:     zh:ember: ======== Ember Adapter Starting ========
          [2025-06-23 16:21:04] info:     zh:ember:ezsp: ======== EZSP starting ========
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ASH COUNTERS since last clear:
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Total frames: RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA frames : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry frames: RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   CRC errors      : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Comm errors     : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length < minimum: RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length > maximum: RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad controls    : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad lengths     : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad ACK numbers : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of buffers  : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry dupes     : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of sequence : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK timeouts    : RX=0
          [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH stopped ========
          [2025-06-23 16:21:04] error:    zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port
          [2025-06-23 16:21:04] error:    z2m: Error while starting zigbee-herdsman
          [2025-06-23 16:21:04] error:    z2m: Failed to start zigbee-herdsman
          [2025-06-23 16:21:04] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
          [2025-06-23 16:21:04] error:    z2m: Exiting...
          [2025-06-23 16:21:04] error:    z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
              at EmberAdapter.initEzsp (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
              at EmberAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
              at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
              at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:71:27)
              at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:102:13)
              at start (/opt/zigbee2mqtt/index.js:149:5)
           ELIFECYCLE  Command failed with exit code 1.
          Hier die Config
          version: 4
          mqtt:
            base_topic: zigbee2mqtt
            server: mqtt://localhost:1883
            user: xxxxxxxx
            password: xxxxxxxx
          serial:
            port: /dev/ttyUSB0
            adapter: ember
            baudrate: 115200
            rtscts: false
          advanced:
            log_level: info
            channel: 11
            network_key:
              - 223
              - 25
              - 181
              - 70
              - 48
              - 140
              - 164
              - 218
              - 20
              - 78
              - 112
              - 96
              - 167
              - 137
              - 205
              - 12
            pan_id: 53749
            ext_pan_id:
              - 230
              - 19
              - 60
              - 177
              - 44
              - 17
              - 21
              - 12
          frontend:
            enabled: true
            port: 8080
          homeassistant:
            enabled: false
          Muss ich evtl die Porteinstellung ändern?
            @autodidakt
            Bist du sicher, dass die Choose so installiert werden soll?
            • Autodidakt
              @thomas-braun Asolut nicht.
              Ich humpel hald jetz mal ein wenig hin und her.
              Ich brauche das Zigbee2Mqtt weil ich einen Feuchtesensor einbinden muss.
              Ich hab mich vor einiger zeit schon mal eingelesen, bin aber dann doch beim alten zigbee geblieben.
              Ich hab mich an die Anleitungen gehalten, die ich gefunden hab. Moquitto läuft schon mal.
                Homoran Global Moderator Administrators @Autodidakt last edited by
                @autodidakt sagte in pnpm Fehler:
                im zigbee Adapter werkelt auch due zigbee²mqtt Engine!
                Wwofü genau benötigst du Z2m?
                was geht nicht mit dem Zigbee Adapter?
                • Autodidakt
                  Autodidakt @Homoran last edited by
                  für den da.
                  https://www.zigbee2mqtt.io/devices/3RSM0147Z.html
                    @autodidakt und
                    @homoran sagte in pnpm Fehler:
                    • Autodidakt
                      Ich hab das wohl falsch verstanden. Ich dacht dafür brauch ich Z2M...
                      Dummer weise habe ich meinem Sonoff Zigbee 3.0 heute eine neue Firmware verpasst, nun läuft auch der Zigbee Adapter nicht mehr.🙄
                        @autodidakt womit wolltest du den z2m betreiben?
                        welchen Koordinator hast du denn noch?
                        • Autodidakt
                          Autodidakt @Homoran last edited by Autodidakt
                          @homoran Der Sonoff war mein Koordinator, oder täusch ich mich?
                          Mit dem wollte ich Z2M betreiben.
                            Homoran Global Moderator Administrators @Autodidakt last edited by Homoran
                            @autodidakt ....und jetzt hast du gar nichts mehr 😞 ?
                            Dann musdt du den sonoff wiederbeleben oder was anderes kaufen.
                            • Autodidakt
                              @homoran Ich versuch Ihn grade neu zu flashen. Ist aber nicht ganz einfach in dem ganzen Firmware-Gewirr.
                              Wenn das nichts wird, muss hald ein neuer her.
                              • Autodidakt
                                Hallo nochmal.
                                Ich habe jetzt einen neuen Stick (Zigbee 3.0 USB Dongle Plus) den Zigbee Adapter V3.0.1 neu installiert und versuche nun meine Geräte neu anzulernen.
                                Leider kommt immer ein Herdsman Fehler.
                                zigbee.0
                                2025-06-25 11:06:24.603	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.602	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.601	warn	ELEVATED:I01 (a0ca) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:24.598	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.597	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.596	warn	ELEVATED:I01 (a0c2) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:24.592	warn	ELEVATED:I02 (a0c0) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                zigbee.0
                                2025-06-25 11:06:24.592	warn	ELEVATED:I01 (a0c0) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:24.591	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.590	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:24.589	warn	ELEVATED:I01 (a0b3) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:24.587	warn	ELEVATED:I01 (a0ca) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":97,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:24.578	warn	ELEVATED:I01 (a0c2) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":168,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":96,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:24.576	warn	ELEVATED:I01 (a0c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":168,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":95,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:24.565	warn	ELEVATED:I01 (a0b3) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":168,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":94,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:09.592	warn	ELEVATED:I02 (661d) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                zigbee.0
                                2025-06-25 11:06:09.591	warn	ELEVATED:I01 (661d) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:09.578	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.576	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.575	warn	ELEVATED:I01 (6611) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:09.574	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.573	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.573	warn	ELEVATED:I01 (660e) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:09.566	warn	ELEVATED:I01 (661d) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":174,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":93,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:09.553	warn	ELEVATED:I01 (6611) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":92,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:09.551	warn	ELEVATED:I01 (660e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":171,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":91,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                zigbee.0
                                2025-06-25 11:06:09.393	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.392	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                zigbee.0
                                2025-06-25 11:06:09.391	warn	ELEVATED:I01 (6568) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                                zigbee.0
                                2025-06-25 11:06:09.385	warn	ELEVATED:I01 (6568) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":174,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":88,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                Irgendwo steckt wohl noch was fest. Gibt es eine Möglichkeit Zigbee komplett mit allem zu entfernen und neu zu beginnen?
                                Failed to open the network: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:47:23) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:263:41 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at Znp.requestZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:257:27) at func (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:322:32) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at ZStackAdapter.sendZdoInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:341:60) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:263:27) at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:176:24) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:249:32)
                                Mfg
                                Tom
                                81.1k
                                557
