pnpm Fehler
@thomas-braun Danke, wieder was gelernt...
Und schon kommt das nächste Problem.
Zigbee2Mqtt will ums verrecken nicht starten.
pi@pi4-Master:/opt/zigbee2mqtt $ pnpm start > zigbee2mqtt@2.4.0 start /opt/zigbee2mqtt > node index.js Starting Zigbee2MQTT without watchdog. [2025-06-23 16:21:03] info: z2m: Logging to console, file (filename: log.log) [2025-06-23 16:21:04] info: z2m: Starting Zigbee2MQTT version 2.4.0 (commit #bdb94da4) [2025-06-23 16:21:04] info: z2m: Starting zigbee-herdsman (4.1.0) [2025-06-23 16:21:04] info: zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"ac315ae1c912ef1184ed6fb8bf9df066","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_ac315ae1c912ef1184ed6fb8bf9df066-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: 4 [2025-06-23 16:21:04] info: zh:ember: Using default stack config. [2025-06-23 16:21:04] info: zh:ember: ======== Ember Adapter Starting ======== [2025-06-23 16:21:04] info: zh:ember:ezsp: ======== EZSP starting ======== [2025-06-23 16:21:04] info: zh:ember:uart:ash: ======== ASH Adapter reset ======== [2025-06-23 16:21:04] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control. [2025-06-23 16:21:04] info: zh:ember:uart:ash: ASH COUNTERS since last clear: [2025-06-23 16:21:04] info: zh:ember:uart:ash: Total frames: RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Cancelled : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: DATA frames : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: DATA bytes : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Retry frames: RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: ACK frames : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: NAK frames : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: CRC errors : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Comm errors : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Length < minimum: RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Length > maximum: RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Bad controls : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Bad lengths : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Bad ACK numbers : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Out of buffers : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Retry dupes : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: Out of sequence : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: ACK timeouts : RX=0 [2025-06-23 16:21:04] info: zh:ember:uart:ash: ======== ASH stopped ======== [2025-06-23 16:21:04] error: zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port [2025-06-23 16:21:04] error: z2m: Error while starting zigbee-herdsman [2025-06-23 16:21:04] error: z2m: Failed to start zigbee-herdsman [2025-06-23 16:21:04] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions [2025-06-23 16:21:04] error: z2m: Exiting... [2025-06-23 16:21:04] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR. at EmberAdapter.initEzsp (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19) at EmberAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24) at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29) at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:71:27) at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:102:13) at start (/opt/zigbee2mqtt/index.js:149:5) ELIFECYCLE Command failed with exit code 1.Hier die Config
version: 4 mqtt: base_topic: zigbee2mqtt server: mqtt://localhost:1883 user: xxxxxxxx password: xxxxxxxx serial: port: /dev/ttyUSB0 adapter: ember baudrate: 115200 rtscts: false advanced: log_level: info channel: 11 network_key: - 223 - 25 - 181 - 70 - 48 - 140 - 164 - 218 - 20 - 78 - 112 - 96 - 167 - 137 - 205 - 12 pan_id: 53749 ext_pan_id: - 230 - 19 - 60 - 177 - 44 - 17 - 21 - 12 frontend: enabled: true port: 8080 homeassistant: enabled: falseMuss ich evtl die Porteinstellung ändern?
Bist du sicher, dass die Choose so installiert werden soll?
@thomas-braun Asolut nicht.
Ich humpel hald jetz mal ein wenig hin und her.
Ich brauche das Zigbee2Mqtt weil ich einen Feuchtesensor einbinden muss.
Ich hab mich vor einiger zeit schon mal eingelesen, bin aber dann doch beim alten zigbee geblieben.Ich hab mich an die Anleitungen gehalten, die ich gefunden hab. Moquitto läuft schon mal.
@autodidakt sagte in pnpm Fehler:
Ich hab mich vor einiger zeit schon mal eingelesen, bin aber dann doch beim alten zigbee gebliebenim zigbee Adapter werkelt auch due zigbee²mqtt Engine!
Wwofü genau benötigst du Z2m?
was geht nicht mit dem Zigbee Adapter? -
Ich hab das wohl falsch verstanden. Ich dacht dafür brauch ich Z2M...
Dummer weise habe ich meinem Sonoff Zigbee 3.0 heute eine neue Firmware verpasst, nun läuft auch der Zigbee Adapter nicht mehr.
@autodidakt womit wolltest du den z2m betreiben?
welchen Koordinator hast du denn noch? -
@homoran Der Sonoff war mein Koordinator, oder täusch ich mich?
Mit dem wollte ich Z2M betreiben. -
@autodidakt ....und jetzt hast du gar nichts mehr
Dann musdt du den sonoff wiederbeleben oder was anderes kaufen. -
@homoran Ich versuch Ihn grade neu zu flashen. Ist aber nicht ganz einfach in dem ganzen Firmware-Gewirr.
Wenn das nichts wird, muss hald ein neuer her.
Hallo nochmal.
Ich habe jetzt einen neuen Stick (Zigbee 3.0 USB Dongle Plus) den Zigbee Adapter V3.0.1 neu installiert und versuche nun meine Geräte neu anzulernen.
Leider kommt immer ein Herdsman Fehler.
zigbee.0 2025-06-25 11:06:24.603 warn ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.602 warn ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.601 warn ELEVATED:I01 (a0ca) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:24.598 warn ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.597 warn ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.596 warn ELEVATED:I01 (a0c2) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:24.592 warn ELEVATED:I02 (a0c0) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.592 warn ELEVATED:I02 (a0c0) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.592 warn ELEVATED:I01 (a0c0) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:24.591 warn ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.590 warn ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:24.589 warn ELEVATED:I01 (a0b3) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:24.587 warn ELEVATED:I01 (a0ca) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":97,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:24.578 warn ELEVATED:I01 (a0c2) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":168,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":96,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:24.576 warn ELEVATED:I01 (a0c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":168,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":95,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:24.565 warn ELEVATED:I01 (a0b3) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":168,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":94,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:09.592 warn ELEVATED:I02 (661d) value generated '174' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.592 warn ELEVATED:I02 (661d) value generated '174' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.591 warn ELEVATED:I01 (661d) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:09.578 warn ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.576 warn ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.575 warn ELEVATED:I01 (6611) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:09.574 warn ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.573 warn ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.573 warn ELEVATED:I01 (660e) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:09.566 warn ELEVATED:I01 (661d) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":174,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":93,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:09.553 warn ELEVATED:I01 (6611) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":92,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:09.551 warn ELEVATED:I01 (660e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":171,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":91,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1} zigbee.0 2025-06-25 11:06:09.393 warn ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.392 warn ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality' zigbee.0 2025-06-25 11:06:09.391 warn ELEVATED:I01 (6568) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined' zigbee.0 2025-06-25 11:06:09.385 warn ELEVATED:I01 (6568) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":174,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":88,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}Irgendwo steckt wohl noch was fest. Gibt es eine Möglichkeit Zigbee komplett mit allem zu entfernen und neu zu beginnen?
Failed to open the network: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:47:23) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:263:41 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at Znp.requestZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:257:27) at func (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:322:32) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at ZStackAdapter.sendZdoInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:341:60) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:263:27) at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:176:24) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:249:32)Mfg
Tom
