    3. Entwicklung
    4. Anker Adapter
    Anker Adapter
    • UweRLP
      UweRLP @ronny130286 last edited by
      @ronny130286 sagte in Anker Adapter:
      Versuch mal folgendes:
      • Adapter stoppen
      • session.json löschen
      • Login im Adapter neu eingeben => sollte der Speicherbutton aus gegraut sein, dann einmal die Pollingtime +1, dann sollte es wieder gehen.
      • Adapter wieder starten
      Erhalte immer noch den Fehler "loginAPI: username are different"
      2025-06-20 07:11:19.251  - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" enabled
      2025-06-20 07:11:19.760  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 12068
      2025-06-20 07:11:20.898  - debug: ankersolix2.0 (12068) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-06-20 07:11:20.933  - debug: ankersolix2.0 (12068) Objects client ready ... initialize now
      2025-06-20 07:11:20.934  - debug: ankersolix2.0 (12068) Objects create System PubSub Client
      2025-06-20 07:11:20.934  - debug: ankersolix2.0 (12068) Objects create User PubSub Client
      2025-06-20 07:11:21.015  - debug: ankersolix2.0 (12068) Objects client initialize lua scripts
      2025-06-20 07:11:21.040  - debug: ankersolix2.0 (12068) Objects connected to redis: 127.0.0.1:9001
      2025-06-20 07:11:21.093  - debug: ankersolix2.0 (12068) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-06-20 07:11:21.121  - debug: ankersolix2.0 (12068) States create System PubSub Client
      2025-06-20 07:11:21.122  - debug: ankersolix2.0 (12068) States create User PubSub Client
      2025-06-20 07:11:21.157  - debug: ankersolix2.0 (12068) States connected to redis: 127.0.0.1:9000
      2025-06-20 07:11:21.225  - info: ankersolix2.0 (12068) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:11:21.235  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:11:21.236  - debug: ankersolix2.0 (12068) RestoreLoginData: ENOENT: no such file or directory, open 'c:\iobroker\iobroker-data\ankersolix2.0\session.json'
      2025-06-20 07:11:21.489  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:11:21.489  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:11:21.491  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:11:21.492  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:11:21.591  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:11:21.591  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:11:21.740  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:11:21.741  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 1290
      2025-06-20 07:12:21.749  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:12:21.750  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:12:21.944  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:12:21.944  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:12:22.082  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:12:22.082  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 2670
      2025-06-20 07:13:22.089  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:13:22.091  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:13:22.258  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:13:22.258  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:13:22.386  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:13:22.387  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 4054
      2025-06-20 07:14:22.388  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:14:22.388  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:14:22.562  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:14:22.563  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:14:22.676  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:14:22.676  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 5438
      2025-06-20 07:15:22.687  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:15:22.688  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:15:22.874  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:15:22.874  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:15:23.060  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:15:23.060  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 6823
      2025-06-20 07:16:23.071  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:16:23.072  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:16:23.269  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:16:23.269  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:16:23.407  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:16:23.408  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 8200
      2025-06-20 07:17:23.416  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:17:23.417  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:17:23.604  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:17:23.604  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:17:23.746  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:17:23.746  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 9602
      2025-06-20 07:18:23.762  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:18:23.764  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:18:23.946  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:18:23.946  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:18:24.069  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:18:24.070  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 11187
      2025-06-20 07:19:24.076  - debug: ankersolix2.0 (12068) Try to restore data from File
      2025-06-20 07:19:24.077  - debug: ankersolix2.0 (12068) loginAPI: username are different
      2025-06-20 07:19:24.290  - debug: ankersolix2.0 (12068) LoginResponseCode: 0 => success!
      2025-06-20 07:19:24.290  - debug: ankersolix2.0 (12068) Write data to file
      2025-06-20 07:19:24.407  - debug: ankersolix2.0 (12068) Published Data.
      2025-06-20 07:19:24.408  - debug: ankersolix2.0 (12068) Sleeping for 60000ms... TimerId 12642
      2025-06-20 07:20:18.677  - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
      2025-06-20 07:20:18.677  - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 (force=false, process=true)
      2025-06-20 07:20:18.688  - info: ankersolix2.0 (12068) Got terminate signal TERMINATE_YOURSELF
      2025-06-20 07:20:18.688  - debug: ankersolix2.0 (12068) refreshTimeout: Unload
      2025-06-20 07:20:18.689  - info: ankersolix2.0 (12068) terminating
      2025-06-20 07:20:18.689  - info: ankersolix2.0 (12068) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-20 07:20:18.679  - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 send kill signal
      2025-06-20 07:20:19.203  - info: ankersolix2.0 (12068) terminating
      2025-06-20 07:20:19.278  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Habe nun mal die Holzhammermethode angewendet und den kompletten Adapter (Instance und Adapter) deinstalliert. Dabei ist mir aufgefallen, dass das Verzeichnis "\10.111.112.39\iobroker\iobroker-data\ankersolix2.0" inklusive Inhalt nicht gelöscht wird. So gewollt?
      Nun erhalte ich neue Fehlermeldungen und der Adapter wird nicht mehr Grün.
      2025-06-20 07:20:59.481  - info: host.DESKTOP-77OGRTU iobroker del ankersolix2 --debug
      2025-06-20 07:21:01.058  - info: host.DESKTOP-77OGRTU iobroker Delete adapter "ankersolix2"
      2025-06-20 07:21:01.086  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 1 instances of ankersolix2
      2025-06-20 07:21:01.190  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 1 meta of ankersolix2
      2025-06-20 07:21:01.192  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 1 adapter for ankersolix2
      2025-06-20 07:21:01.233  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 1 devices of ankersolix2
      2025-06-20 07:21:01.286  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 97 states of ankersolix2
      2025-06-20 07:21:01.312  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 14 states of system.adapter.ankersolix2
      2025-06-20 07:21:01.331  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 98 states (io.ankersolix2.*) from states
      2025-06-20 07:21:01.397  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 6 states (system.adapter.ankersolix2.*) from states
      2025-06-20 07:21:02.261  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Counted 17 objects of ankersolix2
      2025-06-20 07:21:02.355  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU file ankersolix2.admin deleted
      2025-06-20 07:21:02.361  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object ankersolix2 deleted
      2025-06-20 07:21:02.364  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object ankersolix2.admin deleted
      2025-06-20 07:21:02.365  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Deleting 133 object(s).
      2025-06-20 07:21:02.534  - info: host.DESKTOP-77OGRTU object deleted system.adapter.ankersolix2.0
      2025-06-20 07:21:02.537  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Deleting 104 state(s).
      2025-06-20 07:23:40.799  - info: host.DESKTOP-77OGRTU iobroker NPM version: 10.9.2
      2025-06-20 07:23:40.800  - info: host.DESKTOP-77OGRTU iobroker Installing iobroker.ankersolix2@2.1.2... (System call)
      2025-06-20 07:23:52.258  - info: host.DESKTOP-77OGRTU iobroker
      2025-06-20 07:23:52.435  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU install adapter ankersolix2
      2025-06-20 07:23:52.515  - info: host.DESKTOP-77OGRTU iobroker upload [12] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/ankersolix2.png ankersolix2.png image/png
      2025-06-20 07:23:52.520  - info: host.DESKTOP-77OGRTU iobroker upload [11] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2025-06-20 07:23:52.524  - info: host.DESKTOP-77OGRTU iobroker upload [10] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2025-06-20 07:23:52.527  - info: host.DESKTOP-77OGRTU iobroker upload [9] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2025-06-20 07:23:52.531  - info: host.DESKTOP-77OGRTU iobroker upload [8] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2025-06-20 07:23:52.535  - info: host.DESKTOP-77OGRTU iobroker upload [7] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2025-06-20 07:23:52.539  - info: host.DESKTOP-77OGRTU iobroker upload [6] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2025-06-20 07:23:52.542  - info: host.DESKTOP-77OGRTU iobroker upload [5] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2025-06-20 07:23:52.547  - info: host.DESKTOP-77OGRTU iobroker upload [4] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2025-06-20 07:23:52.556  - info: host.DESKTOP-77OGRTU iobroker upload [3] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2025-06-20 07:23:52.560  - info: host.DESKTOP-77OGRTU iobroker upload [2] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      2025-06-20 07:23:52.564  - info: host.DESKTOP-77OGRTU iobroker upload [1] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2025-06-20 07:23:52.568  - info: host.DESKTOP-77OGRTU iobroker upload [0] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/jsonConfig.json jsonConfig.json application/json
      2025-06-20 07:23:52.660  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2 created/updated
      2025-06-20 07:23:52.662  - info: host.DESKTOP-77OGRTU iobroker Updating objects from io-package.json for adapter "ankersolix2" with version "2.1.2"
      2025-06-20 07:23:52.748  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU create instance ankersolix2
      2025-06-20 07:23:52.753  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.alive created
      2025-06-20 07:23:52.755  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.connected created
      2025-06-20 07:23:52.757  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.compactMode created
      2025-06-20 07:23:52.759  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.cpu created
      2025-06-20 07:23:52.762  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.cputime created
      2025-06-20 07:23:52.764  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memHeapUsed created
      2025-06-20 07:23:52.766  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memHeapTotal created
      2025-06-20 07:23:52.769  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memRss created
      2025-06-20 07:23:52.771  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.uptime created
      2025-06-20 07:23:52.773  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.inputCount created
      2025-06-20 07:23:52.775  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.outputCount created
      2025-06-20 07:23:52.778  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.eventLoopLag created
      2025-06-20 07:23:52.780  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.sigKill created
      2025-06-20 07:23:52.782  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.logLevel created
      2025-06-20 07:23:52.784  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object ankersolix2.0.info.apiconnection created
      2025-06-20 07:23:52.798  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Set default value of ankersolix2.0.info.apiconnection: false
      2025-06-20 07:23:52.803  - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0 created
      2025-06-20 07:23:53.865  - info: host.DESKTOP-77OGRTU iobroker exit 0
      2025-06-20 07:23:56.347  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 12252
      2025-06-20 07:23:57.789  - info: ankersolix2.0 (12252) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:23:57.798  - error: ankersolix2.0 (12252) User name and/or user password empty - please check instance configuration of ankersolix2.0
      2025-06-20 07:24:26.291  - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 (force=false, process=true)
      2025-06-20 07:24:26.293  - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 send kill signal
      2025-06-20 07:24:26.286  - info: ankersolix2.0 (12252) Got terminate signal TERMINATE_YOURSELF
      2025-06-20 07:24:26.286  - info: ankersolix2.0 (12252) terminating
      2025-06-20 07:24:26.287  - info: ankersolix2.0 (12252) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-20 07:24:26.796  - info: ankersolix2.0 (12252) terminating
      2025-06-20 07:24:26.912  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-06-20 07:24:30.135  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 10484
      2025-06-20 07:24:31.464  - info: ankersolix2.0 (10484) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:24:31.475  - error: ankersolix2.0 (10484) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:24:31.475  - error: ankersolix2.0 (10484) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:24:31.476  - error: ankersolix2.0 (10484) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
          at new SolixApi (c:\iobroker\node_modules\iobroker.ankersolix2\build\api.js:116:36)
          at Ankersolix2.loginAPI (c:\iobroker\node_modules\iobroker.ankersolix2\build\main.js:84:16)
          at Ankersolix2.onReady (c:\iobroker\node_modules\iobroker.ankersolix2\build\main.js:75:33)
          at Ankersolix2.emit (node:events:518:28)
          at Ankersolix2._callReadyHandler (c:\iobroker\node_modules\@iobroker\js-controller-adapter\build\cjs\lib\adapter\adapter.js:7857:12)
          at Ankersolix2._initAdapter (c:\iobroker\node_modules\@iobroker\js-controller-adapter\build\cjs\lib\adapter\adapter.js:7840:12)
      2025-06-20 07:24:31.476  - error: ankersolix2.0 (10484) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:24:31.479  - info: ankersolix2.0 (10484) terminating
      2025-06-20 07:24:31.479  - warn: ankersolix2.0 (10484) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:24:31.994  - info: ankersolix2.0 (10484) terminating
      2025-06-20 07:24:32.081  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:24:32.081  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:25:03.790  - info: ankersolix2.0 (12060) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:25:03.800  - error: ankersolix2.0 (12060) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:25:03.800  - error: ankersolix2.0 (12060) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:03.801  - error: ankersolix2.0 (12060) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:03.801  - error: ankersolix2.0 (12060) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:03.804  - info: ankersolix2.0 (12060) terminating
      2025-06-20 07:25:03.804  - warn: ankersolix2.0 (12060) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:25:04.316  - info: ankersolix2.0 (12060) terminating
      2025-06-20 07:25:04.421  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:25:04.421  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:25:34.764  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 10668
      2025-06-20 07:25:36.086  - info: ankersolix2.0 (10668) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:25:36.096  - error: ankersolix2.0 (10668) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:25:36.096  - error: ankersolix2.0 (10668) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:36.097  - error: ankersolix2.0 (10668) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:36.097  - error: ankersolix2.0 (10668) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:25:36.099  - info: ankersolix2.0 (10668) terminating
      2025-06-20 07:25:36.100  - warn: ankersolix2.0 (10668) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:25:36.615  - info: ankersolix2.0 (10668) terminating
      2025-06-20 07:25:36.720  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:25:36.720  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:25:36.720  - warn: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because restart loop detected
      2025-06-20 07:26:00.481  - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
      2025-06-20 07:26:11.003  - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" enabled
      2025-06-20 07:26:11.495  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 11744
      2025-06-20 07:26:12.897  - info: ankersolix2.0 (11744) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:26:12.908  - error: ankersolix2.0 (11744) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:26:12.908  - error: ankersolix2.0 (11744) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:12.909  - error: ankersolix2.0 (11744) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:12.909  - error: ankersolix2.0 (11744) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:12.911  - info: ankersolix2.0 (11744) terminating
      2025-06-20 07:26:12.912  - warn: ankersolix2.0 (11744) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:26:13.419  - info: ankersolix2.0 (11744) terminating
      2025-06-20 07:26:13.532  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:26:13.532  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:26:43.897  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 2864
      2025-06-20 07:26:45.203  - info: ankersolix2.0 (2864) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:26:45.212  - error: ankersolix2.0 (2864) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:26:45.213  - error: ankersolix2.0 (2864) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:45.214  - error: ankersolix2.0 (2864) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:45.214  - error: ankersolix2.0 (2864) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:26:45.216  - info: ankersolix2.0 (2864) terminating
      2025-06-20 07:26:45.217  - warn: ankersolix2.0 (2864) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:26:45.724  - info: ankersolix2.0 (2864) terminating
      2025-06-20 07:26:45.820  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:26:45.820  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:27:16.202  - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 12300
      2025-06-20 07:27:17.537  - info: ankersolix2.0 (12300) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v22.16.0, js-controller: 7.0.7
      2025-06-20 07:27:17.547  - error: ankersolix2.0 (12300) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-06-20 07:27:17.547  - error: ankersolix2.0 (12300) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:27:17.548  - error: ankersolix2.0 (12300) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:27:17.548  - error: ankersolix2.0 (12300) Cannot read properties of undefined (reading 'toUpperCase')
      2025-06-20 07:27:17.551  - info: ankersolix2.0 (12300) terminating
      2025-06-20 07:27:17.551  - warn: ankersolix2.0 (12300) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-06-20 07:27:18.060  - info: ankersolix2.0 (12300) terminating
      2025-06-20 07:27:18.163  - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-06-20 07:27:18.163  - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
      2025-06-20 07:27:18.163  - warn: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because restart loop detected
      2025-06-20 07:27:24.150  - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
      Vielleicht hilft das dem Problem auf die Spur zu kommen.
      R UweRLP 2 Replies Last reply Reply Quote 0
        ronny130286 @UweRLP last edited by
        @uwerlp said in Anker Adapter:
        Hast du die Daten im Adapter neu eingegeben?
        Weil er sagt: User name and/or user password empty - please check instance configuration of ankersolix2.0
        UweRLP 1 Reply Last reply Reply Quote 0
        • UweRLP
          @ronny130286 Vermutlich zu viel LOG, entschuldigung 😊
          In dem Log sieht man von oben nach unten die Deinstallation, neue Installation und den Aufruf zur Eingabe der Daten.
          Die Meldung kam nach der neuen Installation des Adapters, war/ist für mich auch klar weil in dem Moment noch keine Daten eingegeben waren.
          Die Daten sind aber eingegeben und gespeichert.
          Ab Zeile 73 im letzten Poste https://forum.iobroker.net/post/1278840 , zweites Log.
          Bin kein Programmierer deswegen nur leihenhaftes Verständnis.
          "This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch()."
          Könnte das bedeuten, dass was nicht Syncron läuft bzw. was versucht wird bevor was andere fertig ist?
          Deutet 'toUpperCase' nicht auf Groß-/Kleinschreibung hin wobei es zu Problemen kommt?
            @UweRLP
            Das "toUpperCase" wird benötigt um der Ländercode immer groß zu schreiben, jegliche Kleinschreibung wird zur Großschreibung bspw. de => DE, en => EN und so weiter
            Deshalb wundert es mich, dass er damit nicht umgehen kann, weil das schon immer vorhanden war.
            Der einzige Unterschied momentan wäre, du nutzt Nodejs 22 und ich 20.
            Hast du mit anderen Adaptern auch Probleme?
            Thomas Braun Homoran UweRLP 3 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @ronny130286 last edited by
              Hier läuft der Adapter mit nodejs 20, 22 und 24.
                Homoran Global Moderator Administrators @ronny130286 last edited by
                ...windows
                  ronny130286 @Homoran last edited by
                  stimmt, dann war es nicht der einzige Unterschied.
                  • V
                    Volker3.0 @ronny130286 last edited by
                    @ronny130286
                    Danke für die Antwort!
                    Bis wann denkst du, kannst du dir die API mal anschauen? Ich mache den Kauf des Anker von deinem Adapter abhängig, da ich die Steuerung über den ioBroker benötige 🫣😉
                    Gruß Volker
                    • UweRLP
                      UweRLP @ronny130286 last edited by UweRLP
                      Habe nun nochmal die Instance und den Adapter gelöscht. Dann Node auf Version 20.19.3 downgrade.
                      Bekomme den Adapter nicht mehr zum laufen, hier nochmals Protokoll mit Node 20.19.3
                      2025-06-24 08:34:32.468 - info: host.DESKTOP-77OGRTU iobroker add ankersolix2 --host DESKTOP-77OGRTU
                      2025-06-24 08:34:34.443 - info: host.DESKTOP-77OGRTU iobroker NPM version: 10.8.2
                      2025-06-24 08:34:34.444 - info: host.DESKTOP-77OGRTU iobroker Installing iobroker.ankersolix2@2.1.2... (System call)
                      2025-06-24 08:34:56.771 - info: host.DESKTOP-77OGRTU iobroker
                      added 1 package, and audited 2663 packages in 22s
                      328 packages are looking for funding
                      run `npm fund` for details
                      2025-06-24 08:34:56.910 - info: host.DESKTOP-77OGRTU iobroker
                      112 vulnerabilities (9 low, 39 moderate, 54 high, 10 critical)
                      To address issues that do not require attention, run:
                      2025-06-24 08:34:56.911 - info: host.DESKTOP-77OGRTU iobroker npm audit fix
                      To address all issues possible (including breaking changes), run:
                      npm audit fix --force
                      Some issues need review, and may require choosing
                      a different dependency.
                      Run `npm audit` for details.
                      2025-06-24 08:34:56.940 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU install adapter ankersolix2
                      2025-06-24 08:34:57.009 - info: host.DESKTOP-77OGRTU iobroker upload [12] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/ankersolix2.png ankersolix2.png image/png
                      2025-06-24 08:34:57.014 - info: host.DESKTOP-77OGRTU iobroker upload [11] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      2025-06-24 08:34:57.019 - info: host.DESKTOP-77OGRTU iobroker upload [10] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      2025-06-24 08:34:57.023 - info: host.DESKTOP-77OGRTU iobroker upload [9] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      2025-06-24 08:34:57.027 - info: host.DESKTOP-77OGRTU iobroker upload [8] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      2025-06-24 08:34:57.031 - info: host.DESKTOP-77OGRTU iobroker upload [7] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      2025-06-24 08:34:57.035 - info: host.DESKTOP-77OGRTU iobroker upload [6] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      2025-06-24 08:34:57.039 - info: host.DESKTOP-77OGRTU iobroker upload [5] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      2025-06-24 08:34:57.043 - info: host.DESKTOP-77OGRTU iobroker upload [4] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      2025-06-24 08:34:57.052 - info: host.DESKTOP-77OGRTU iobroker upload [3] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      2025-06-24 08:34:57.056 - info: host.DESKTOP-77OGRTU iobroker upload [2] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                      2025-06-24 08:34:57.059 - info: host.DESKTOP-77OGRTU iobroker upload [1] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      2025-06-24 08:34:57.063 - info: host.DESKTOP-77OGRTU iobroker upload [0] ankersolix2.admin c:/iobroker/node_modules/iobroker.ankersolix2/admin/jsonConfig.json jsonConfig.json application/json
                      2025-06-24 08:34:57.150 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2 created/updated
                      2025-06-24 08:34:57.151 - info: host.DESKTOP-77OGRTU iobroker Updating objects from io-package.json for adapter "ankersolix2" with version "2.1.2"
                      2025-06-24 08:34:57.225 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU create instance ankersolix2
                      2025-06-24 08:34:57.230 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.alive created
                      2025-06-24 08:34:57.232 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.connected created
                      2025-06-24 08:34:57.235 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.compactMode created
                      2025-06-24 08:34:57.238 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.cpu created
                      2025-06-24 08:34:57.241 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.cputime created
                      2025-06-24 08:34:57.244 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memHeapUsed created
                      2025-06-24 08:34:57.246 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memHeapTotal created
                      2025-06-24 08:34:57.249 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.memRss created
                      2025-06-24 08:34:57.252 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.uptime created
                      2025-06-24 08:34:57.254 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.inputCount created
                      2025-06-24 08:34:57.257 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.outputCount created
                      2025-06-24 08:34:57.259 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.eventLoopLag created
                      2025-06-24 08:34:57.262 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.sigKill created
                      2025-06-24 08:34:57.265 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0.logLevel created
                      2025-06-24 08:34:57.267 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object ankersolix2.0.info.apiconnection created
                      2025-06-24 08:34:57.269 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU Set default value of ankersolix2.0.info.apiconnection: false
                      2025-06-24 08:34:57.274 - info: host.DESKTOP-77OGRTU iobroker host.DESKTOP-77OGRTU object system.adapter.ankersolix2.0 created
                      2025-06-24 08:34:58.334 - info: host.DESKTOP-77OGRTU iobroker exit 0
                      2025-06-24 08:35:00.625 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 8744
                      2025-06-24 08:35:02.126 - info: ankersolix2.0 (8744) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:35:02.134 - error: ankersolix2.0 (8744) User name and/or user password empty - please check instance configuration of ankersolix2.0
                      2025-06-24 08:35:06.370 - info: homee.0 (5284) initialize 1 nodes
                      2025-06-24 08:35:35.057 - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 (force=false, process=true)
                      2025-06-24 08:35:35.050 - info: ankersolix2.0 (8744) Got terminate signal TERMINATE_YOURSELF
                      2025-06-24 08:35:35.059 - info: host.DESKTOP-77OGRTU stopInstance system.adapter.ankersolix2.0 send kill signal
                      2025-06-24 08:35:35.050 - info: ankersolix2.0 (8744) terminating
                      2025-06-24 08:35:35.051 - info: ankersolix2.0 (8744) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-06-24 08:35:35.552 - info: ankersolix2.0 (8744) terminating
                      2025-06-24 08:35:35.644 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-06-24 08:35:38.952 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 9192
                      2025-06-24 08:35:40.231 - info: ankersolix2.0 (9192) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:35:40.242 - error: ankersolix2.0 (9192) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:35:40.242 - error: ankersolix2.0 (9192) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:35:40.244 - error: ankersolix2.0 (9192) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      at Ankersolix2.emit (node:events:524:28)
                      2025-06-24 08:35:40.244 - error: ankersolix2.0 (9192) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:35:40.268 - info: ankersolix2.0 (9192) terminating
                      2025-06-24 08:35:40.269 - warn: ankersolix2.0 (9192) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:35:40.775 - info: ankersolix2.0 (9192) terminating
                      2025-06-24 08:35:40.866 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:35:40.866 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:36:00.977 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
                      2025-06-24 08:36:12.750 - error: ankersolix2.0 (7836) adapter disabled
                      2025-06-24 08:36:12.757 - warn: ankersolix2.0 (7836) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                      2025-06-24 08:36:13.384 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      2025-06-24 08:36:13.385 - info: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because disabled or deleted
                      2025-06-24 08:36:17.332 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" enabled
                      2025-06-24 08:36:17.855 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 4040
                      2025-06-24 08:36:19.138 - info: ankersolix2.0 (4040) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:36:19.148 - error: ankersolix2.0 (4040) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:36:19.148 - error: ankersolix2.0 (4040) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:19.149 - error: ankersolix2.0 (4040) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:19.149 - error: ankersolix2.0 (4040) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:19.152 - info: ankersolix2.0 (4040) terminating
                      2025-06-24 08:36:19.152 - warn: ankersolix2.0 (4040) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:36:19.666 - info: ankersolix2.0 (4040) terminating
                      2025-06-24 08:36:19.756 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:36:19.756 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:36:50.113 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 4608
                      2025-06-24 08:36:51.397 - info: ankersolix2.0 (4608) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:36:51.407 - error: ankersolix2.0 (4608) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:36:51.408 - error: ankersolix2.0 (4608) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:51.409 - error: ankersolix2.0 (4608) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:51.409 - error: ankersolix2.0 (4608) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:36:51.411 - info: ankersolix2.0 (4608) terminating
                      2025-06-24 08:36:51.412 - warn: ankersolix2.0 (4608) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:36:51.914 - info: ankersolix2.0 (4608) terminating
                      2025-06-24 08:36:52.012 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:36:52.012 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:36:52.012 - warn: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because restart loop detected
                      2025-06-24 08:36:52.021 - info: notification-manager.0 (9232) Send notification "system.restartLoop" to "email.0"
                      2025-06-24 08:37:08.808 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
                      2025-06-24 08:37:30.221 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" enabled
                      2025-06-24 08:37:30.753 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 10260
                      2025-06-24 08:37:32.013 - info: ankersolix2.0 (10260) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:37:32.024 - error: ankersolix2.0 (10260) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:37:32.024 - error: ankersolix2.0 (10260) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:37:32.025 - error: ankersolix2.0 (10260) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:37:32.025 - error: ankersolix2.0 (10260) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:37:32.028 - info: ankersolix2.0 (10260) terminating
                      2025-06-24 08:37:32.028 - warn: ankersolix2.0 (10260) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:37:32.539 - info: ankersolix2.0 (10260) terminating
                      2025-06-24 08:37:32.618 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:37:32.619 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:37:43.350 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" disabled
                      2025-06-24 08:38:04.162 - error: ankersolix2.0 (12256) adapter disabled
                      2025-06-24 08:38:04.170 - warn: ankersolix2.0 (12256) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                      2025-06-24 08:38:04.760 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                      2025-06-24 08:38:04.760 - info: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because disabled or deleted
                      2025-06-24 08:40:00.108 - info: host.DESKTOP-77OGRTU "system.adapter.ankersolix2.0" enabled
                      2025-06-24 08:40:00.644 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 2652
                      2025-06-24 08:40:01.532 - debug: ankersolix2.0 (2652) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2025-06-24 08:40:01.564 - debug: ankersolix2.0 (2652) Objects client ready ... initialize now
                      2025-06-24 08:40:01.565 - debug: ankersolix2.0 (2652) Objects create System PubSub Client
                      2025-06-24 08:40:01.565 - debug: ankersolix2.0 (2652) Objects create User PubSub Client
                      2025-06-24 08:40:01.629 - debug: ankersolix2.0 (2652) Objects client initialize lua scripts
                      2025-06-24 08:40:01.635 - debug: ankersolix2.0 (2652) Objects connected to redis: 127.0.0.1:9001
                      2025-06-24 08:40:01.684 - debug: ankersolix2.0 (2652) Redis States: Use Redis connection: 127.0.0.1:9000
                      2025-06-24 08:40:01.708 - debug: ankersolix2.0 (2652) States create System PubSub Client
                      2025-06-24 08:40:01.708 - debug: ankersolix2.0 (2652) States create User PubSub Client
                      2025-06-24 08:40:01.757 - debug: ankersolix2.0 (2652) States connected to redis: 127.0.0.1:9000
                      2025-06-24 08:40:01.830 - info: ankersolix2.0 (2652) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:40:01.839 - error: ankersolix2.0 (2652) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:40:01.840 - error: ankersolix2.0 (2652) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:01.841 - error: ankersolix2.0 (2652) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:01.841 - error: ankersolix2.0 (2652) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:01.843 - info: ankersolix2.0 (2652) terminating
                      2025-06-24 08:40:01.843 - warn: ankersolix2.0 (2652) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:40:02.350 - info: ankersolix2.0 (2652) terminating
                      2025-06-24 08:40:02.454 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:40:02.455 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:40:32.861 - info: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 in version "2.1.2" started with pid 5592
                      2025-06-24 08:40:33.852 - debug: ankersolix2.0 (5592) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2025-06-24 08:40:33.879 - debug: ankersolix2.0 (5592) Objects client ready ... initialize now
                      2025-06-24 08:40:33.880 - debug: ankersolix2.0 (5592) Objects create System PubSub Client
                      2025-06-24 08:40:33.881 - debug: ankersolix2.0 (5592) Objects create User PubSub Client
                      2025-06-24 08:40:33.936 - debug: ankersolix2.0 (5592) Objects client initialize lua scripts
                      2025-06-24 08:40:33.940 - debug: ankersolix2.0 (5592) Objects connected to redis: 127.0.0.1:9001
                      2025-06-24 08:40:33.978 - debug: ankersolix2.0 (5592) Redis States: Use Redis connection: 127.0.0.1:9000
                      2025-06-24 08:40:34.007 - debug: ankersolix2.0 (5592) States create System PubSub Client
                      2025-06-24 08:40:34.008 - debug: ankersolix2.0 (5592) States create User PubSub Client
                      2025-06-24 08:40:34.052 - debug: ankersolix2.0 (5592) States connected to redis: 127.0.0.1:9000
                      2025-06-24 08:40:34.127 - info: ankersolix2.0 (5592) starting. Version 2.1.2 in c:/iobroker/node_modules/iobroker.ankersolix2, node: v20.19.3, js-controller: 7.0.7
                      2025-06-24 08:40:34.137 - error: ankersolix2.0 (5592) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-06-24 08:40:34.137 - error: ankersolix2.0 (5592) unhandled promise rejection: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:34.138 - error: ankersolix2.0 (5592) TypeError: Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:34.138 - error: ankersolix2.0 (5592) Cannot read properties of undefined (reading 'toUpperCase')
                      2025-06-24 08:40:34.172 - info: ankersolix2.0 (5592) terminating
                      2025-06-24 08:40:34.172 - warn: ankersolix2.0 (5592) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-06-24 08:40:34.679 - info: ankersolix2.0 (5592) terminating
                      2025-06-24 08:40:34.760 - error: host.DESKTOP-77OGRTU instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-06-24 08:40:34.760 - info: host.DESKTOP-77OGRTU Restart adapter system.adapter.ankersolix2.0 because enabled
                      2025-06-24 08:40:34.760 - warn: host.DESKTOP-77OGRTU Do not restart adapter system.adapter.ankersolix2.0 because restart loop detected
                      Nein keine.
                      Ich habe auch die Version 2.1.1 vom Adapter getestet, läuft auch nicht.
                      Was mich verwundert, der Adapter lief ja schon mal hatte aber das Problem mit dem Login/Token. Nun bekomme ich noch nicht mal mehr den Adapter zum laufen, wird nicht grün.
                      @homoran sagte in Anker Adapter:
                      ...windows
                      Ja, System läuft unter Windows 10 x64
                      Wenn keiner eine Idee hat gebe ich jetzt erst mal auf. Ich komme leider nicht weiter.
                      @ronny130286 Wenn dir noch was einfällt oder du was versuchen möchtes bitte bescheit geben. Aktuell ist der Adapter deinstalliert. Wenn du magst stelle ich dir auch gerne die Logindaten für den Gast Account per PM zur Verfügung.
                        ronny130286 @UweRLP last edited by ronny130286
                        @UweRLP
                        der Gast Account funktioniert aber, wenn du den in der App benutzt oder?
                        Also du hast ihn eingeladen und im Gast-Account die Einladung auch angenommen, richtig?
                        • UweRLP
                          @ronny130286 Der Gast Account funktioniert in der App. Habe der Einladung zugestimmt und konnte die Werte in der App darstellen. Den Gast Account habe ich dann wieder in der App abgemeldet und seidem nur noch für ioBroker verwendet.
                          Ups, sehe gerade das ich nicht gemeint war 😊
                            ronny130286 last edited by ronny130286
                            @uwerlp
                            Alles gut, ich meinte schon dich... hab scheinbar aufs falsche Reply gedrückt.
                            Hast du irgendwelche speziellen Konfigurationen für den Windows Rechner/Server?
                            Weiterhin auf welches Ankerserver bist du unterwegs, hast du den im Adapter richtig konfiguriert?
                              mabeca96 last edited by
                              erst einmal vielen Dank für den Adapter.
                              kann man den Adapter noch mit den SmartPlug von Anker verbinden, um diese zu steuern?
                              • UweRLP
                                Nichts was mir bekannt ist.
                                Ja diese Einstellung nutze ich.
                                • V
                                  Volker3.0 last edited by
                                  was ist denn eurer Erfahrung nach im Adapter die minimalste Abfragezeit, wo der Account nicht gesperrt wird?
                                  Gehen 20 Sekunden oder minimum 30 Sekunden?
                                  • UweRLP
                                    UweRLP @UweRLP last edited by
                                    @ronny130286
                                    @uwerlp sagte in Anker Adapter:
                                    Schande über mein Haupt. 😖
                                    Habe mich heute nochmals in Ruhe mit dem Adapter befasst.
                                    Erst mal wieder den Fehlereintrag im Protokoll.
                                    Dann ist mir aufgefallen, dass die Landesvorwahl nicht korrekt ist. Entweder war diese leer bzw. war "-" eingetragen, genau weis ich es nicht mehr. Vermutlich habe ich ständig diesen Eintrag missachtet.
                                    Diese umgestellt auf "DE" nun läuft der Adapter erst mal und holt sich auch Werte ohne Meldung im Protokoll.
                                    Entschuldige bitte meine Oberflächlichkeit und die schlaflosen Nächte die ich dir bereitet habe.
                                    • UweRLP
                                      @ronny130286
                                      Möglicherweise habe ich auch dafür die Lösung.
                                      Aus optischen und Gründen der Lesbarkeit benutze ich bei eMail Adressen Groß-/Kleinschreibung.
                                      Kann es sein, dass der Adapter darüber stolpert?
                                      Thomas Braun UweRLP 2 Replies Last reply Reply Quote 0
                                        Thomas Braun Most Active @UweRLP last edited by
                                        Dann gib die eMail-Adresse mal in Kleinschreibung an.
                                        Es gibt ohnehin keine email-Adressen, die Großbuchstaben enthalten, das wird ohnehin intern immer auf Kleinschreibung umgestellt.
                                        • UweRLP
                                          UweRLP @Thomas Braun last edited by
                                          Ja gebe ich dir recht, bei eMail spielt es keine Rolle als Login Name kann es eine Rolle spielen.
                                          Habe ich auch schon versucht die komplette Adresse nur Kleinbuchstaben bekomme ich dann
                                          2025-07-05 09:38:46.484  - debug: ankersolix2.0 (7224) LoginResponseCode: 26161 => Failed to request.
                                          Ich warte nun bis morgen, vielleicht ist der Account, wegen zu vielen Versuchen, noch gesperrt.
                                          • UweRLP
                                            @ronny130286
                                            Neuer Tag, neuer Versuch.
                                            eMail Adresse (Solix-Username) komplett mit Kleinbuchstaben eingegeben.
                                            Sieht erst mal vielversprechend aus. Der Fehler "loginAPI: username are different" taucht nicht mehr im Protokoll auf und Daten kommen an. Ich werde den Adapter nun weiter laufen lassen und beobachten ob Datenabruf länger als 30-45 Minuten möglich ist und mich hier nochmals melden.
                                            359
                                            87564
