    4. Neuer Adapter pi-hole2 für pihole>=V6
    • Meister Mopper
      Meister Mopper @OliverIO last edited by
      @oliverio
      Perfekt, dann werde ich den mal auf meinem Testsystem installieren und mit einem Pihole v6 LXC testen.
      Vielen Dank für Dein Engagement 😊 !
      • Meister Mopper
        @oliverio
        Ich bekomme keine Verbindung.
        host.ioTest 2025-06-24 17:16:05.578 error startInstance system.adapter.pi-hole2.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "7.6.17", required "7.0.23"!
        iob diag:
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
        Static hostname: ioTest
              Icon name: computer-container
                Chassis: container ☐
         Virtualization: lxc
                 Kernel: Linux 6.8.12-11-pve
           Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
        17:18:29 up 12 min,  1 user,  load average: 1.24, 1.20, 1.16
        CPU threads: 1
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                      Local time: Tue 2025-06-24 17:18:29 CEST
                  Universal time: Tue 2025-06-24 15:18:29 UTC
                        RTC time: n/a
                     NTP service: inactive
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        thomas
        HOME=/home/thomas
        GROUPS=thomas adm sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev redis
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            2.1G        758M        1.2G        118K        168M        1.4G
        Swap:             0B          0B          0B
        Total:          2.1G        758M        1.2G
        Active iob-Instances:   6
                2048 M total memory
                 723 M used memory
                 850 M active memory
                   0 M inactive memory
                1163 M free memory
                   0 M buffer memory
                 161 M swap cache
                   0 M total swap
                   0 M used swap
                   0 M free swap
        top - 17:18:29 up 12 min,  1 user,  load average: 1.24, 1.20, 1.16
        Tasks:  31 total,   1 running,  30 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2048.0 total,   1161.3 free,    725.5 used,    161.3 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1322.5 avail Mem
        *** FAILED SERVICES ***
         UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                   Type      Size  Used Avail Use% Mounted on
        rpool/data/subvol-300-disk-0 zfs        12G  6.2G  5.9G  51% /
        none                         tmpfs     492K  4.0K  488K   1% /dev
        udev                         devtmpfs   16G     0   16G   0% /dev/tty
        tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                        tmpfs     6.3G  112K  6.3G   1% /run
        tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1001
        Show mounted filesystems:
        TARGET SOURCE                       FSTYPE OPTIONS
        /      rpool/data/subvol-300-disk-0 zfs    rw,noatime,xattr,posixacl,casesensitive
        /var:
        751M    /var/
        404M    /var/log
        403M    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
        208M    /var/lib
        Archived and active journals take up 402.8M in the file system.
        /opt/iobroker/backups:
        686M    /opt/iobroker/backups/
        8.5K    /opt/iobroker/backups/scripte0
        /opt/iobroker/iobroker-data:
        165M    /opt/iobroker/iobroker-data/
        105M    /opt/iobroker/iobroker-data/files
        47M     /opt/iobroker/iobroker-data/files/javascript.admin
        40M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        3.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        3.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
        3.4M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.c2161e55.chunk.js.map
        3.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.69975cd7.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.3
        /usr/bin/node           v20.19.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
         Installed: 20.19.3-1nodesource1
         Candidate: 20.19.3-1nodesource1
         Version table:
        *** 20.19.3-1nodesource1 1001
               500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               100 /var/lib/dpkg/status
            20.19.2-1nodesource1 1001
            20.19.1-1nodesource1 1001
            20.19.0-1nodesource1 1001
            20.18.3-1nodesource1 1001
            20.18.2-1nodesource1 1001
            20.18.1-1nodesource1 1001
            20.18.0-1nodesource1 1001
            20.17.0-1nodesource1 1001
            20.16.0-1nodesource1 1001
            20.15.1-1nodesource1 1001
            20.15.0-1nodesource1 1001
            20.14.0-1nodesource1 1001
            20.13.1-1nodesource1 1001
            20.13.0-1nodesource1 1001
            20.12.2-1nodesource1 1001
            20.12.1-1nodesource1 1001
            20.12.0-1nodesource1 1001
            20.11.1-1nodesource1 1001
            20.11.0-1nodesource1 1001
            20.10.0-1nodesource1 1001
            20.9.0-1nodesource1 1001
            20.8.1-1nodesource1 1001
            20.8.0-1nodesource1 1001
            20.7.0-1nodesource1 1001
            20.6.1-1nodesource1 1001
            20.6.0-1nodesource1 1001
            20.5.1-1nodesource1 1001
            20.5.0-1nodesource1 1001
            20.4.0-1nodesource1 1001
            20.3.1-1nodesource1 1001
            20.3.0-1nodesource1 1001
            20.2.0-1nodesource1 1001
            20.1.0-1nodesource1 1001
            20.0.0-1nodesource1 1001
            18.19.0+dfsg-6~deb12u2 500
               500 http://deb.debian.org/debian bookworm/main amd64 Packages
            18.19.0+dfsg-6~deb12u1 500
               500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        At least one iobroker host is running.
        Objects type: redis
        States  type: redis
        Hosts:
        ioTest              ioTest (version: 7.0.6, hostname: ioTest        , alive, uptime: 752)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.6.17
        javascript:     8.9.2
        nodejs modules from github:     3
        +-- iobroker.pi-hole2@0.0.1 (git+ssh://git@github.com/oweitman/ioBroker.pi-hole2.git#d6284153a1f850bbcca76c0286188ad36057cafc)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioTest                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
         system.adapter.alias-manager.0          : alias-manager         : ioTest                                   -  enabled
        + system.adapter.backitup.0               : backitup              : ioTest                                   -  enabled
         system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioTest                                   - disabled
         system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioTest                                   - disabled
        + system.adapter.javascript.0             : javascript            : ioTest                                   -  enabled
        + system.adapter.linux-control.0          : linux-control         : ioTest                                   -  enabled
         system.adapter.mielecloudservice.0      : mielecloudservice     : ioTest                                   - disabled
         system.adapter.pi-hole2.0               : pi-hole2              : ioTest                                   -  enabled, port: 80
         system.adapter.vis-bars.0               : vis-bars              : ioTest                                   - disabled
         system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioTest                                   - disabled
         system.adapter.vis-fancyswitch.0        : vis                   : ioTest                                   - disabled
         system.adapter.vis-history.0            : vis-history           : ioTest                                   - disabled
         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioTest                                   - disabled
         system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioTest                                   - disabled
         system.adapter.vis-justgage.0           : vis-justgage          : ioTest                                   - disabled
         system.adapter.vis-metro.0              : vis                   : ioTest                                   - disabled
         system.adapter.vis-plumb.0              : vis                   : ioTest                                   - disabled
         system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioTest                                   - disabled
         system.adapter.vis.0                    : vis                   : ioTest                                   -  enabled
        + system.adapter.web.0                    : web                   : ioTest                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.17   , installed 7.6.17
        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.2.2    , installed 3.2.2
        Adapter    "bluelink"     : 3.1.3    , installed 3.1.3
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "heos"         : 2.2.1    , installed 2.2.1
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "linux-control": 1.1.5    , installed 1.1.5
        Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "openligadb"   : 1.8.1    , installed 1.8.1
        Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
        Adapter    "samsung"      : 0.6.1    , installed 0.6.1
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solax"        : 0.9.17   , installed 0.9.17
        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "traccar"      : 1.1.6    , installed 1.1.6
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        582
        States:         418
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.gierens.de stable InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      107        95003015   116/redis-server 12
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          94999379   1/systemd
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          95002954   127/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          94999381   1/systemd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          95002956   127/sshd: /usr/sbin
        tcp6       0      0 ::1:6379                :::*                    LISTEN      107        95003016   116/redis-server 12
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       95001528   265/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       95026792   7537/io.admin.0
        tcp6       0      0 :::6556                 :::*                    LISTEN      0          95002785   1/systemd
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          94999380   1/systemd
        udp6       0      0 :::111                  :::*                                0          94999382   1/systemd
        2025-06-24 17:06:10.818  - info: javascript.0 (212) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.19.2, js-controller: 7.0.6
        2025-06-24 17:06:11.015  - info: javascript.0 (212) requesting all states
        2025-06-24 17:06:11.016  - info: javascript.0 (212) requesting all objects
        2025-06-24 17:06:11.037  - info: javascript.0 (212) received all states
        2025-06-24 17:06:11.233  - info: javascript.0 (212) received all objects
        2025-06-24 17:06:11.263  - info: javascript.0 (212) Start JavaScript script.js.common.Test.Spuema (Blockly)
        2025-06-24 17:06:11.290  - info: javascript.0 (212) script.js.common.Test.Spuema: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2025-06-24 17:06:24.973  - error: linux-control.0 (295) Object linux-control.0.command.host is invalid: obj.common.states has an invalid type! Expected "object", received "string"
        2025-06-24 17:11:15.556  - info: javascript.0 (212) Got terminate signal TERMINATE_YOURSELF
        2025-06-24 17:11:15.557  - info: javascript.0 (212) Stopping script script.js.common.Test.Spuema
        2025-06-24 17:11:15.558  - info: javascript.0 (212) terminating
        2025-06-24 17:11:15.559  - info: javascript.0 (212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-06-24 17:11:16.057  - info: javascript.0 (212) terminating
        2025-06-24 17:11:20.881  - info: javascript.0 (7599) starting. Version 8.9.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.19.3, js-controller: 7.0.6
        2025-06-24 17:11:20.967  - info: javascript.0 (7599) requesting all states
        2025-06-24 17:11:20.968  - info: javascript.0 (7599) requesting all objects
        2025-06-24 17:11:20.980  - info: javascript.0 (7599) received all states
        2025-06-24 17:11:21.152  - info: javascript.0 (7599) received all objects
        2025-06-24 17:11:21.167  - info: javascript.0 (7599) Start JavaScript script.js.common.Test.Spuema (Blockly)
        2025-06-24 17:11:21.185  - info: javascript.0 (7599) script.js.common.Test.Spuema: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
        2025-06-24 17:14:10.109  - error: host.ioTest startInstance system.adapter.pi-hole2.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "7.6.17", required "7.0.23"!
        2025-06-24 17:16:05.578  - error: host.ioTest startInstance system.adapter.pi-hole2.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "7.6.17", required "7.0.23"!
        • OliverIO
          OliverIO @Meister Mopper last edited by
          @meister-mopper
          probiere bitte nochmal.
          weiß nicht ob das aus dem adapter creator kommt oder ich da aus versehen dran gekommen bin. es war fixe admin version eingetragen
          • Meister Mopper
            @oliverio
            Nö, will (noch) nicht:
            host.ioTest 2025-06-24 17:58:07.904 error startInstance system.adapter.pi-hole2.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "7.6.17", required "7.0.23"!
            • OliverIO
              OliverIO @Meister Mopper last edited by OliverIO
              @meister-mopper
              hier hat es funktioniert
              $ iobroker url oweitman/ioBroker.pi-hole2 --host iobroker_test --debug
              install oweitman/ioBroker.pi-hole2
              NPM version: 10.8.2
              Installing oweitman/ioBroker.pi-hole2... (System call)
              added 2 packages in 20s
              90 packages are looking for funding run `npm fund` for details
              upload [2] pi-hole2.admin /opt/iobroker/node_modules/iobroker.pi-hole2/admin/i18n/en.json i18n/en.json application/json
              upload [0] pi-hole2.admin /opt/iobroker/node_modules/iobroker.pi-hole2/admin/pi-hole2.png pi-hole2.png image/png
              Updating objects from io-package.json for adapter "pi-hole2" with version "0.0.1"
              Process exited with code 0
              drücke mal nochmal vorher den repo aktualisieren knopf in der adapterliste
              habe festgestellt, das ich im dev-server lokal installiert habe,
              neuer test auf einem richtigen testserver hat aber auch funktioniert
              $ iobroker url https://github.com/oweitman/ioBroker.pi-hole2 --host iobroker_test --debug
              install oweitman/ioBroker.pi-hole2#592ba12212cf67103d630a7233688d1f59631c62
              NPM version: 10.8.2
              Installing oweitman/ioBroker.pi-hole2#592ba12212cf67103d630a7233688d1f59631c62... (System call)
              npm warn skipping integrity check for git dependency ssh://git@github.com/oweitman/ioBroker.pi-hole2.git
              added 2 packages in 11s
              95 packages are looking for funding run `npm fund` for details
              Meister Mopper 2 Replies Last reply Reply Quote 0
              • Meister Mopper
                @oliverio
                Da isser, war mal wieder das 40 cm Problem.
                • Meister Mopper
                  @oliverio
                  Ok, mein reduntanter Pihole läuft jetzt am Router als DNS.
                  Mal schauen, was der Adapter liefert.
                  • mcm1957
                    mcm1957 @Meister Mopper last edited by mcm1957
                    @OliverIO
                    DANKE.
                    Damit hab ich einen Staupunkt weniger auf meiner Liste.
                    Ich würde nur anregen den Adapter pi-hole6 zu nennen. Wäre meiner Ansicht nach klarer zu finden.
                    • OliverIO
                      Der Adapter steht nun auch per NPM zur Verfügung.
                      • Meister Mopper
                        @oliverio sagte in Neuer Adapter pi-hole2 für pihole>=V6:
                        Wer weitere Vorschläge machen möchte, kann gerne in seiner piholev6 installation die folgende Seite aufrufen: http://pi.hole/api/docs/, trägt dann oben sein Passwort ein und kann dann alle API-Endpunkte durchprobieren.
                        Was muss eingegeben werden, um API-Endpunkte durchzuprobieren (habe da noch keine Erfahrung)?
                        • OliverIO
                          @meister-mopper
                          Ist eigentlich einfach
                          Schritt1 pi-hole API Seite aufrufen
                          Diese Adresse ist direkt eurer pi-hole im Netz
                          Schritt2 Passwort eingeben
                          Protokoll auswählen (ich konnte nur http ausprobieren), dann Passwort eintragen, dann Login-Knopf drücken. Nach Erfolg wird der Login-Knopf dann in Logout umbenannt und wird grün.
                          Schritt3 API-aussuchen ohne Parameter Vorbereitung
                          Aufklappen des entsprechenden Bereichs und dann Try Knopf drücken
                          Schritt4 API-aussuchen ohne Parameter Ergebnis
                          Ergebnis erscheint dann
                          Schritt5 API-aussuchen mit Parameter Vorbereitung
                          Aufklappen Parameter füllen (hier schon erledigt), boolean ist true oder false oder leer, und try drücken
                          Schritt6 API-aussuchen mit Parameter Ergebnis
                          API in iobroker nutzen
                          Wenn man dann eine API gefunden hat, kann man sie wie hier beschrieben per javascript im iobroker einbinden
                          https://github.com/oweitman/ioBroker.pi-hole2?tab=readme-ov-file#general-sendto-function
                          The sendTo function is used to send commands to the pi-hole device. You can try the api on your local machine. Go to http://pi.hole/api/docs/# and enter your password and press login button.
                          Example
                          sendTo(
                            "pi-hole2.0",
                            "piholeapi",
                              method: "GET",
                              endpoint: "/history/clients",
                              params: {
                                N: 20,
                            function (data) {
                              console.log(data);
                          Wenn bei der Eingabe Zeitstempel benötigt werden, ist zu beachten, das dies in UNIX-Zeit zu erfolgen hat. UNIX timestamps sind Sekunden seit 1.1.70, daher muss der Javascript ts noch durch 1000 geteilt werden.
                          • Meister Mopper
                            Meister Mopper @OliverIO last edited by Meister Mopper
                            Auch habe ich keine pi-hole V5 Installation verfügbar, so das ich nicht nachschauen kann, wie die Daten bisher aussahen.
                            Der Adapter v5 hat schon viele Datenpunkte generiert. Aus meiner Sicht ist das oversized, wer in diese Informationstiefe gehen möchte, kann ja das pi-hole frontend aufrufen, da wird es sogar grafisch aufgearbeitet.
                            Gut fände ich, wenn der Adapter Auskunft über die laufende Version und ggf. eine neue Version informiert.
                            Ich nutze derzeit diese Informationen aus der v5:
                            pi-hole.0.versions.FTL_current
                            pi-hole.0.versions.core_current
                            pi-hole.0.versions.web_current
                            pi-hole.0.versions.FTL_latest
                            pi-hole.0.versions.core_latest
                            pi-hole.0.versions.web_latest
                            pi-hole.0.versions.FTL_update
                            pi-hole.0.summary.domains_being_blocked
                            pi-hole.0.summary.ads_blocked_today
                            pi-hole.0.summary.ads_percentage_today
                            • OliverIO
                              OliverIO last edited by OliverIO
                              @meister-mopper
                              Die Frage ist halt, sollte sowas automatisiert durch den Adapter aufbereitet werden und in einen Datenpunkt geschrieben werden und wenn ja, in welchem Ausmaß und Detailgenauigkeit oder sollte so etwas nach bedarf dann durch jeden aufbereitet werden.
                              Das ist der Inhalt des Datenpunkts Version
                                "version": {
                                  "core": {
                                    "local": {
                                      "version": "v6.0.6",
                                      "branch": "master",
                                      "hash": "0f7803b7"
                                    "remote": {
                                      "version": "v6.1.2",
                                      "hash": "ec892ec0"
                                  "web": {
                                    "local": {
                                      "version": "v6.1",
                                      "branch": "master",
                                      "hash": "1eaddca8"
                                    "remote": {
                                      "version": "v6.2.1",
                                      "hash": "cc1cc285"
                                  "ftl": {
                                    "local": {
                                      "hash": "a3313229",
                                      "branch": "master",
                                      "version": "v6.1",
                                      "date": "2025-03-30 17:53:24 +0100"
                                    "remote": {
                                      "version": "v6.2.3",
                                      "hash": "88737f62"
                                  "docker": {
                                    "local": "2025.04.0",
                                    "remote": "2025.06.2"
                                "took": 0.0002613067626953125
                              Das könnte man dann mit dem widget jsontemplate
                              https://forum.iobroker.net/topic/31521/test-widget-json-template
                              auf dem Datenpunkt
                              pi-hole2.0.Version
                              mit folgendem Template sehr einfach in vis darstellen
                              <style>
                                 p.pihole {
                                     margin: 0px;
                              </style>
                              <p class="pihole">core.local: <%- data.version.core.local.version %></p>
                              <p class="pihole">core.remote: <%- data.version.core.remote.version %></p>
                              <p class="pihole">web.local: <%- data.version.web.local.version %></p>
                              <p class="pihole">web.remote: <%- data.version.web.remote.version %></p>
                              <p class="pihole">ftl.local: <%- data.version.ftl.local.version %></p>
                              <p class="pihole">ftl.remote: <%- data.version.ftl.remote.version %></p>
                              Natürlich kann man das auch durch den javascript/blockly adapter genauso aufbereiten. Bei JSON hilft jsonata was ja im javascript-adapter ebenfalls bereits eingebaut ist
                              • Meister Mopper
                                Ja, das ist eher ein philosophischer Ansatz.
                                Streng genommen bedarf es keines Adapters, weil jeder die API-Daten direkt abfragen kann (es gab ja auch schon ein Skriptangebot für v6, kann man nutzen, keine Frage).
                                Selbstüberheblich könnte ich jetzt sagen, dass ich mir aufgrund meiner Pensionierung und der dadurch generierten Zeit bis in zwei Jahren das coden zutraue.
                                Wahrscheinlich wird es aber einige User überfordern, die sich auf eine middleware-Lösung eingelassen haben und auch die entsprechenden Datenpunkte - ohne eigene Programmierung - erhoffen).
                                Philosophisch wegen der Fragen:
                                Wo will der ioBroker hin? Eine Anleitung zum Programmieren für Newbies? Smarthome in einem Guss?
                                • OliverIO
                                  @meister-mopper
                                  generell ist es kein problem ausgewählte werte direkt als datenpunkt anzulegen und zu aktualisieren.
                                  hast du diese werte in den aktuellen daten gefunden?
                                  ich habe nur
                                  queries.total
                                  queries.blocked
                                  gefunden
                                  • OliverIO
                                    Neue Version 0.2.3
                                    • Kleine Fehlerbehebung in der Dokumentation
                                    • Benutzeragent anpassen und Informationen zur Fehlerbehebung "too many seats" hinzufügen
                                    • Visualisierungsbeispiel für Versions hinzugefügt
                                    • Visualisierungsbeispiel für Summary hinzugefügt
                                    • OliverIO
                                      Neue Version 0.3.0
                                      • Übersetzungsdateien hinzugefügt
                                      • Aktualisierungslogik und Refreshzeiten an Pihole angepasst
                                      • Passwort verschlüsselt (Passwort muss bei Aktualisierung erneut eingegeben werden)
                                      • Ausgewählte Detail-Datenpunkte für Summary und Version hinzugefügt.
                                      • OliverIO
                                        Neue Version 0.4.0
                                        • Die Extraktion von Detailwerten für Version/Summary kann deaktiviert werden.
                                        • Negalein
                                          Negalein Global Moderator @OliverIO last edited by
                                          Fehler, Ideen, Anregungen dann bitte hier.
                                          Hallo Oliver
                                          Ist das Grau so gewollt?
                                          • OliverIO
                                            OliverIO @Negalein last edited by
                                            @negalein
                                            ah, danke. habe nicht mit hellem hintergrund getestet.
                                            hatte aber einen ähnlichen effekt bei dunkel.
                                            ist leider ein automatismus des admin.
                                            muss mir für hell dann eine anderen grünton suchen, bei rot ist es ja ok.
                                            der admin prüft den kontrast der farbe und schaltet dann halt einen anderen grünton dazu.
                                            2156
