    4. Zigbee Adapter schmeißt warnungen
    • Autodidakt
      Autodidakt last edited by
      Hallo und guten Abend.
      Mein Zigbee Adapter V 2.0.5 Gibt bei jedem Start Warnungen aus.
      zigbee.0
      2025-06-25 20:16:20.380	warn	ELEVATED:I02 (1a87) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
      zigbee.0
      2025-06-25 20:16:20.379	warn	ELEVATED:I01 (1a87) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.378	warn	ELEVATED:I02 (1a87) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:20.377	warn	ELEVATED:I01 (1a87) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.373	warn	ELEVATED:NOVAL (1a83) No value published for device ffffb40e060599a0
      zigbee.0
      2025-06-25 20:16:20.373	warn	ELEVATED:I01 (1a83) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.371	warn	ELEVATED:I02 (1a83) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:20.371	warn	ELEVATED:I01 (1a83) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.367	warn	ELEVATED:I02 (1a7b) value generated '0' from device ffffb40e060599a0 for 'Humidity'
      zigbee.0
      2025-06-25 20:16:20.367	warn	ELEVATED:I01 (1a7b) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.366	warn	ELEVATED:I02 (1a7b) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:20.366	warn	ELEVATED:I01 (1a7b) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.365	warn	ELEVATED:I02 (1a79) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
      zigbee.0
      2025-06-25 20:16:20.365	warn	ELEVATED:I01 (1a79) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.363	warn	ELEVATED:I02 (1a79) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:20.362	warn	ELEVATED:I01 (1a79) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:20.359	warn	ELEVATED:I01 (1a87) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":211,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:20.356	warn	ELEVATED:I01 (1a83) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":210,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:20.347	warn	ELEVATED:I01 (1a7b) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":209,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:20.345	warn	ELEVATED:I01 (1a79) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":208,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.388	warn	ELEVATED:I02 (dfee) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
      zigbee.0
      2025-06-25 20:16:05.387	warn	ELEVATED:I01 (dfee) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.385	warn	ELEVATED:I02 (dfee) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.385	warn	ELEVATED:I01 (dfee) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.380	warn	ELEVATED:NOVAL (dfed) No value published for device ffffb40e060599a0
      zigbee.0
      2025-06-25 20:16:05.380	warn	ELEVATED:I01 (dfed) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.378	warn	ELEVATED:I02 (dfed) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.377	warn	ELEVATED:I01 (dfed) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.369	warn	ELEVATED:I02 (dfe1) value generated '0' from device ffffb40e060599a0 for 'Humidity'
      zigbee.0
      2025-06-25 20:16:05.369	warn	ELEVATED:I01 (dfe1) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.368	warn	ELEVATED:I02 (dfe1) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.367	warn	ELEVATED:I01 (dfe1) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.366	warn	ELEVATED:I02 (dfdd) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
      zigbee.0
      2025-06-25 20:16:05.366	warn	ELEVATED:I01 (dfdd) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.365	warn	ELEVATED:I02 (dfdd) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.364	warn	ELEVATED:I01 (dfdd) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.358	warn	ELEVATED:I01 (dfee) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":207,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.357	warn	ELEVATED:I01 (dfed) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":206,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.345	warn	ELEVATED:I01 (dfe1) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":205,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.341	warn	ELEVATED:I01 (dfdd) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":204,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.293	warn	ELEVATED:I02 (df38) value generated '0' from device ffffb40e060599a0 for 'Humidity'
      zigbee.0
      2025-06-25 20:16:05.292	warn	ELEVATED:I01 (df38) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.290	warn	ELEVATED:I02 (df38) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.290	warn	ELEVATED:I01 (df38) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.289	warn	ELEVATED:I02 (df2e) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
      zigbee.0
      2025-06-25 20:16:05.288	warn	ELEVATED:I01 (df2e) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.286	warn	ELEVATED:I02 (df2e) value generated '229' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:16:05.286	warn	ELEVATED:I01 (df2e) message received '{"linkquality":229}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:16:05.176	warn	ELEVATED:I01 (df38) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":203,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:16:05.166	warn	ELEVATED:I01 (df2e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":229,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":202,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:50.311	warn	ELEVATED:I02 (a50e) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
      zigbee.0
      2025-06-25 20:15:50.311	warn	ELEVATED:I01 (a50e) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.309	warn	ELEVATED:I02 (a50e) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:50.308	warn	ELEVATED:I01 (a50e) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.305	warn	ELEVATED:NOVAL (a50b) No value published for device ffffb40e060599a0
      zigbee.0
      2025-06-25 20:15:50.305	warn	ELEVATED:I01 (a50b) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.303	warn	ELEVATED:I02 (a50b) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:50.302	warn	ELEVATED:I01 (a50b) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.299	warn	ELEVATED:I02 (a4f7) value generated '0' from device ffffb40e060599a0 for 'Humidity'
      zigbee.0
      2025-06-25 20:15:50.298	warn	ELEVATED:I01 (a4f7) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.297	warn	ELEVATED:I02 (a4f7) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:50.296	warn	ELEVATED:I01 (a4f7) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.295	warn	ELEVATED:I02 (a4f1) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
      zigbee.0
      2025-06-25 20:15:50.295	warn	ELEVATED:I01 (a4f1) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.292	warn	ELEVATED:I02 (a4f1) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:50.292	warn	ELEVATED:I01 (a4f1) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:50.287	warn	ELEVATED:I01 (a50e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":201,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:50.283	warn	ELEVATED:I01 (a50b) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":200,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:50.263	warn	ELEVATED:I01 (a4f7) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":199,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:50.258	warn	ELEVATED:I01 (a4f1) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":198,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:39.159	warn	ELEVATED:I02 (7990) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:39.159	warn	ELEVATED:I01 (7990) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:39.158	warn	ELEVATED:NOCONV (7990) No converter available for '3RSM0147Z' 'ffffb40e060599a0' with cluster 'genBasic' and type 'attributeReport'
      zigbee.0
      2025-06-25 20:15:39.152	warn	ELEVATED:I01 (7990) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"swBuildId":"v1.00.38"},"linkquality":225,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":197,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:37.184	warn	ELEVATED:I02 (71c5) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
      zigbee.0
      2025-06-25 20:15:37.183	warn	ELEVATED:I01 (71c5) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:37.179	warn	ELEVATED:I02 (71c5) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:37.178	warn	ELEVATED:I01 (71c5) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:37.172	warn	ELEVATED:NOVAL (71c0) No value published for device ffffb40e060599a0
      zigbee.0
      2025-06-25 20:15:37.171	warn	ELEVATED:I01 (71c0) message received '{}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:37.168	warn	ELEVATED:I02 (71c0) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:37.167	warn	ELEVATED:I01 (71c0) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:37.158	warn	ELEVATED:I01 (71c5) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":196,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:37.152	warn	ELEVATED:I01 (71c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":16},"linkquality":225,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":195,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:36.071	warn	ELEVATED:I02 (6d85) value generated '10' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:36.070	warn	ELEVATED:I01 (6d85) message received '{"linkquality":10}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:36.070	warn	ELEVATED:I02 (6d85) value generated 'true' from device ffffb40e060599a0 for 'Available'
      zigbee.0
      2025-06-25 20:15:36.069	warn	ELEVATED:I01 (6d85) message received '{"available":true}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:35.187	warn	ELEVATED:I02 (6a04) value generated '0' from device ffffb40e060599a0 for 'Humidity'
      zigbee.0
      2025-06-25 20:15:35.186	warn	ELEVATED:I01 (6a04) message received '{"humidity":0}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:35.183	warn	ELEVATED:I02 (6a04) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:35.182	warn	ELEVATED:I01 (6a04) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:35.179	warn	ELEVATED:I02 (69fc) value generated '30.81' from device ffffb40e060599a0 for 'Temperature'
      zigbee.0
      2025-06-25 20:15:35.179	warn	ELEVATED:I01 (69fc) message received '{"temperature":30.81}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:35.177	warn	ELEVATED:I02 (69fc) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:15:35.176	warn	ELEVATED:I01 (69fc) message received '{"linkquality":225}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:15:35.172	warn	ELEVATED:I01 (6a04) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":225,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":194,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:35.164	warn	ELEVATED:I01 (69fc) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":3081},"linkquality":225,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":193,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.0
      2025-06-25 20:15:35.066	warn	ELEVATED:Ida (699a) Device '0xffffb40e060599a0' announced itself
      zigbee.0
      2025-06-25 20:14:54.818	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"dad0c14dc174ef11b4f0cd8c8fcc3fa0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_dad0c14dc174ef11b4f0cd8c8fcc3fa0-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyACM0","manufacturer":"0658","serialNumber":"E3040A02-4A02-0113-1510-041500BFCC64","pnpId":"usb-0658_0200_E3040A02-4A02-0113-1510-041500BFCC64-if00","vendorId":"0658","productId":"0200"},{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      zigbee.0
      2025-06-25 20:14:16.430	warn	ELEVATED:I02 (3665) value generated '10' from device ffffb40e060599a0 for 'Link quality'
      zigbee.0
      2025-06-25 20:14:16.429	warn	ELEVATED:I01 (3665) message received '{"linkquality":10}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:14:16.424	warn	ELEVATED:I02 (3664) value generated 'true' from device ffffb40e060599a0 for 'Available'
      zigbee.0
      2025-06-25 20:14:16.423	warn	ELEVATED:I01 (3664) message received '{"available":true}' from device ffffb40e060599a0 type '3RSM0147Z'
      zigbee.0
      2025-06-25 20:14:15.705	info	debug devices set to ["ffffb40e060599a0"]
      zigbee.0
      2025-06-25 20:14:15.666	info	Zigbee started
      zigbee.0
      2025-06-25 20:14:15.663	info	Currently 4 devices are joined:
      zigbee.0
      2025-06-25 20:14:15.663	info	0x8c65a3fffe5256c2 (addr 11312): ZBDongle-E - SONOFF Sonoff Zigbee 3.0 USB Dongle Plus (EFR32MG21) with router firmware (Router)
      zigbee.0
      2025-06-25 20:14:15.660	info	0x70b3d52b600a59f0 (addr 12676): TS011F_plug_3 - Tuya Smart plug (with power monitoring by polling) (Router)
      zigbee.0
      2025-06-25 20:14:15.419	info	0xffffb40e060599a0 (addr 22929): 3RSM0147Z - Third Reality Soil sensor (EndDevice)
      zigbee.0
      2025-06-25 20:14:15.391	info	0x0ceff6fffe5a0306 (addr 30247): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
      zigbee.0
      2025-06-25 20:14:15.315	info	Unable to disable LED, unsupported function.
      zigbee.0
      2025-06-25 20:14:15.313	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20240710}}
      zigbee.0
      2025-06-25 20:14:14.661	info	Starting Zigbee-Herdsman
      zigbee.0
      2025-06-25 20:14:14.659	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0
      2025-06-25 20:14:14.606	info	Starting Adapter npm ...
      zigbee.0
      2025-06-25 20:14:14.604	info	--- creating device debug ---
      zigbee.0
      2025-06-25 20:14:14.600	info	delete old Backup files. keep only last 10
      zigbee.0
      2025-06-25 20:14:14.582	info	--> transmitPower : high+
      zigbee.0
      2025-06-25 20:14:14.571	info	init localConfig
      zigbee.0
      2025-06-25 20:14:14.540	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.3, js-controller: 7.0.6
      Hier die Ausgabe von IoB Diag
      ======== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
         Static hostname: pi4-Master
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:19:41 up  8:00,  2 users,  load average: 0.63, 0.76, 0.72
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-06-25 20:19:42 CEST
                 Universal time: Wed 2025-06-25 18:19:42 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        3.4G        374M        0.0K        4.1G        4.3G
      Swap:            99M         63M         36M
      Total:          7.9G        3.4G        410M
      Active iob-Instances:   45
               7811 M total memory
               3382 M used memory
               3803 M active memory
               3190 M inactive memory
                374 M free memory
                 76 M buffer memory
               3977 M swap cache
                 99 M total swap
                 63 M used swap
                 36 M free swap
      top - 20:19:42 up  8:00,  2 users,  load average: 0.63, 0.76, 0.72
      Tasks: 219 total,   2 running, 216 sleeping,   0 stopped,   1 zombie
      %Cpu(s): 15.3 us,  8.3 sy,  0.0 ni, 76.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7811.3 total,    374.5 free,   3382.3 used,   4054.5 buff/cache
      MiB Swap:    100.0 total,     36.1 free,     63.9 used.   4298.3 avail Mem
      *** FAILED SERVICES ***
        UNIT              LOAD   ACTIVE SUB    DESCRIPTION
      * mosquitto.service loaded failed failed Mosquitto MQTT Broker
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4      220G   34G  178G  16% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
      [Wed Jun 25 12:19:18 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:84:59:3C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e432a575-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jun 25 12:19:21 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jun 25 12:19:21 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Wed Jun 25 12:19:23 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      9.6G    /var/
      4.3G    /var/log
      4.1G    /var/log/journal/eefdb7bad79f4dbab7d9171e992a2beb
      3.4G    /var/lib
      Archived and active journals take up 4.0G in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.3G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/backup-objects
      775M    /opt/iobroker/iobroker-data/files
      156M    /opt/iobroker/iobroker-data/files/vis-2
      110M    /opt/iobroker/iobroker-data/node-red
      570M    /opt/iobroker/iobroker-data/backup-objects/historyDB_2022_11_16-02_45_10_backupiobroker.tar.gz
      461M    /opt/iobroker/iobroker-data/backup-objects/influxDB_2022_11_16-02_40_53_backupiobroker.tar.gz
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-0658_0200_E3040A02-4A02-0113-1510-041500BFCC64-if00
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_dad0c14dc174ef11b4f0cd8c8fcc3fa0-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.3
      /usr/bin/node           v20.19.3
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.3-1nodesource1
        Candidate: 20.19.3-1nodesource1
        Version table:
       *** 20.19.3-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.2-1nodesource1 600
           20.19.1-1nodesource1 600
           20.19.0-1nodesource1 600
           20.18.3-1nodesource1 600
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u7 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      pi4-Master          pi4-Master (version: 7.0.6, hostname: pi4-Master    , alive, uptime: 24898)
      Core adapters versions
      admin:          7.7.0
      javascript:     8.9.2
      nodejs modules from github:     5
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      +-- iobroker.life360@0.2.21 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#888e08024c2d93d86aa6eb74f281c574dce86c42)
      +-- iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      Adapter State
      + system.adapter.admin.0                  : admin                 : pi4-Master                               -  enabled, port: 6969, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : pi4-Master                               -  enabled
      + system.adapter.backitup.0               : backitup              : pi4-Master                               -  enabled
      + system.adapter.ble.0                    : ble                   : pi4-Master                               -  enabled
      + system.adapter.cloud.0                  : cloud                 : pi4-Master                               -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : pi4-Master                               -  enabled
      + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : pi4-Master                               -  enabled
        system.adapter.feiertage.0              : feiertage             : pi4-Master                               -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : pi4-Master                               -  enabled
        system.adapter.fritzdect.0              : fritzdect             : pi4-Master                               - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : pi4-Master                               -  enabled
        system.adapter.ham.0                    : ham                   : pi4-Master                               - disabled
      + system.adapter.history.0                : history               : pi4-Master                               -  enabled
      + system.adapter.homeconnect.0            : homeconnect           : pi4-Master                               -  enabled
      + system.adapter.i2c.0                    : i2c                   : pi4-Master                               -  enabled
        system.adapter.ical.0                   : ical                  : pi4-Master                               -  enabled
        system.adapter.ical.1                   : ical                  : pi4-Master                               -  enabled
        system.adapter.ical.2                   : ical                  : pi4-Master                               -  enabled
        system.adapter.ical.3                   : ical                  : pi4-Master                               -  enabled
        system.adapter.ical.4                   : ical                  : pi4-Master                               -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pi4-Master                               -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : pi4-Master                               -  enabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : pi4-Master                               -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : pi4-Master                               -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4-Master                               -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: pi4-Master                               -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : pi4-Master                               -  enabled
      + system.adapter.influxdb.0               : influxdb              : pi4-Master                               -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : pi4-Master                               -  enabled
      + system.adapter.javascript.0             : javascript            : pi4-Master                               -  enabled
      + system.adapter.knx.0                    : knx                   : pi4-Master                               -  enabled, bind: 192.168.178.185
      + system.adapter.lgtv.0                   : lgtv                  : pi4-Master                               -  enabled
        system.adapter.life360.0                : life360               : pi4-Master                               - disabled
      + system.adapter.meross.0                 : meross                : pi4-Master                               -  enabled
        system.adapter.midea.0                  : midea                 : pi4-Master                               - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : pi4-Master                               -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : pi4-Master                               -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : pi4-Master                               -  enabled, port: 1879, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : pi4-Master                               - disabled, port: 1783, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : pi4-Master                               -  enabled
      + system.adapter.node-red.0               : node-red              : pi4-Master                               -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : pi4-Master                               -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : pi4-Master                               -  enabled
        system.adapter.samsung.0                : samsung               : pi4-Master                               - disabled
      + system.adapter.scenes.0                 : scenes                : pi4-Master                               -  enabled
        system.adapter.schoolfree.0             : schoolfree            : pi4-Master                               -  enabled
      + system.adapter.shelly.0                 : shelly                : pi4-Master                               -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : pi4-Master                               -  enabled
      + system.adapter.simple-api.0             : simple-api            : pi4-Master                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonnen.0                 : sonnen                : pi4-Master                               -  enabled
      + system.adapter.sonoff.0                 : sonoff                : pi4-Master                               -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : pi4-Master                               -  enabled
      + system.adapter.sql.0                    : sql                   : pi4-Master                               -  enabled, port: 3307
      + system.adapter.tankerkoenig.0           : tankerkoenig          : pi4-Master                               -  enabled
      + system.adapter.telegram.0               : telegram              : pi4-Master                               -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : pi4-Master                               - disabled
      + system.adapter.tr-064.0                 : tr-064                : pi4-Master                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : pi4-Master                               -  enabled
      + system.adapter.tuya.0                   : tuya                  : pi4-Master                               -  enabled
        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: pi4-Master                               -  enabled
        system.adapter.vis-2.0                  : vis-2                 : pi4-Master                               - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : pi4-Master                               -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4-Master                               -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : pi4-Master                               -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : pi4-Master                               -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4-Master                               -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : pi4-Master                               -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4-Master                               -  enabled
        system.adapter.vis-metro.0              : vis-metro             : pi4-Master                               -  enabled
        system.adapter.vis-players.0            : vis-players           : pi4-Master                               -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : pi4-Master                               -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4-Master                               -  enabled
        system.adapter.vis.0                    : vis                   : pi4-Master                               -  enabled
      + system.adapter.web.0                    : web                   : pi4-Master                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : pi4-Master                               -  enabled
      + system.adapter.worx.0                   : worx                  : pi4-Master                               -  enabled
      + system.adapter.zigbee.0                 : zigbee                : pi4-Master                               -  enabled, port: /dev/ttyUSB0
      + system.adapter.zwave2.0                 : zwave2                : pi4-Master                               -  enabled
      + instance is alive
      ioBroker-Repositories
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.7.0
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "ds18b20"      : 3.0.1    , installed 3.0.1
      Adapter    "epson_ecotank_et_2750": 1.0.1, installed 1.0.1
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.1  [Updatable]
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "knx"          : 2.0.30   , installed 2.0.30
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "midea"        : 0.0.7    , installed 0.1.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "scenes"       : 3.2.3    , installed 4.0.2
      Adapter    "schoolfree"   : 1.1.9    , installed 1.1.9
      Adapter    "shelly"       : 9.5.1    , installed 9.5.1
      Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonnen"       : 1.18.1   , installed 1.18.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-jaeger-design": 1.2.7, installed 1.2.7
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "worx"         : 3.2.4    , installed 3.2.4
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
      Objects and States
      Objects:        19833
      States:         17847
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://repos.influxdata.com/debian stretch InRelease
      Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       189723     25382/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       188953     25382/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14559      654/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:1879            0.0.0.0:*               LISTEN      1001       190455     25928/io.mqtt.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       190059     25580/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       195060     26220/io.sonoff.0
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11677      696/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14562      654/sshd: /usr/sbin
      tcp6       0      0 :::1821                 :::*                    LISTEN      1001       195880     26380/io.ds18b20.0
      tcp6       0      0 :::3030                 :::*                    LISTEN      1001       191039     25693/io.fullybrows
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        15485      808/grafana
      tcp6       0      0 :::6969                 :::*                    LISTEN      1001       189057     25400/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       196567     26747/io.web.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       194545     26471/io.simple-api
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        13294      696/influxd
      udp        0      0 192.168.178.185:33436   0.0.0.0:*                           1001       970178     25847/io.knx.0
      udp        0      0 192.168.178.185:37561   0.0.0.0:*                           1001       934363     25847/io.knx.0
      udp        0      0 192.168.178.185:50320   0.0.0.0:*                           1001       851723     25847/io.knx.0
      udp        0      0 192.168.178.185:38034   0.0.0.0:*                           1001       1204940    25847/io.knx.0
      udp        0      0 192.168.178.185:5353    0.0.0.0:*                           1001       195713     26246/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11598      522/avahi-daemon: r
      udp        0      0 192.168.178.185:38188   0.0.0.0:*                           1001       503118     25847/io.knx.0
      udp        0      0 192.168.178.185:42299   0.0.0.0:*                           1001       1199623    25847/io.knx.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       191462     26127/io.shelly.0
      udp        0      0 192.168.178.185:58972   0.0.0.0:*                           1001       934750     25847/io.knx.0
      udp        0      0 192.168.178.185:38501   0.0.0.0:*                           1001       306739     25847/io.knx.0
      udp        0      0 0.0.0.0:55133           0.0.0.0:*                           108        11600      522/avahi-daemon: r
      udp        0      0 192.168.178.185:39140   0.0.0.0:*                           1001       968220     25847/io.knx.0
      udp        0      0 192.168.178.185:47373   0.0.0.0:*                           1001       318632     25847/io.knx.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       196195     26279/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       196196     26279/io.tuya.0
      udp        0      0 192.168.178.185:43684   0.0.0.0:*                           1001       1013029    25847/io.knx.0
      udp        0      0 192.168.178.185:39720   0.0.0.0:*                           1001       931937     25847/io.knx.0
      udp        0      0 192.168.178.185:56110   0.0.0.0:*                           1001       911755     25847/io.knx.0
      udp        0      0 192.168.178.185:60235   0.0.0.0:*                           1001       474397     25847/io.knx.0
      udp        0      0 192.168.178.185:39839   0.0.0.0:*                           1001       999258     25847/io.knx.0
      udp        0      0 192.168.178.185:39989   0.0.0.0:*                           1001       201298     25847/io.knx.0
      udp        0      0 192.168.178.185:56379   0.0.0.0:*                           1001       325796     25847/io.knx.0
      udp        0      0 192.168.178.185:48380   0.0.0.0:*                           1001       194001     25847/io.knx.0
      udp        0      0 192.168.178.185:44379   0.0.0.0:*                           1001       850925     25847/io.knx.0
      udp        0      0 192.168.178.185:60959   0.0.0.0:*                           1001       1009835    25847/io.knx.0
      udp        0      0 192.168.178.185:32847   0.0.0.0:*                           1001       205725     25847/io.knx.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       192258     25902/io.mihome-vac
      udp        0      0 192.168.178.185:41156   0.0.0.0:*                           1001       302699     25847/io.knx.0
      udp        0      0 192.168.178.185:41274   0.0.0.0:*                           1001       190969     25580/node-red
      udp6       0      0 :::5353                 :::*                                108        11599      522/avahi-daemon: r
      udp6       0      0 :::41173                :::*                                108        11601      522/avahi-daemon: r
      2025-06-25 20:16:20.378  - warn: zigbee.0 (154603) ELEVATED:I02 (1a87) value generated '225' from device ffffb40e060599a0 for 'Link quality'
      2025-06-25 20:16:20.379  - warn: zigbee.0 (154603) ELEVATED:I01 (1a87) message received '{"battery":100}' from device ffffb40e060599a0 type '3RSM0147Z'
      2025-06-25 20:16:20.380  - warn: zigbee.0 (154603) ELEVATED:I02 (1a87) value generated '100' from device ffffb40e060599a0 for 'Battery percent'
      2025-06-25 20:16:22.969  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
      2025-06-25 20:17:02.120  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875422120_3859
      2025-06-25 20:17:02.972  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
      2025-06-25 20:17:46.857  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
      2025-06-25 20:18:01.564  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875481564_5212
      2025-06-25 20:18:02.386  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
      2025-06-25 20:18:04.113  - debug: alexa2.0 (25628) Alexa-Remote HTTP2-PUSH: Send Ping
      2025-06-25 20:18:14.284  - debug: shuttercontrol.0 (26159) outsidetemperature changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Temperatur_Messwert | Value: 32.4°C
      2025-06-25 20:19:01.991  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875541990_2988
      2025-06-25 20:19:02.869  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
      2025-06-25 20:19:16.824  - info: influxdb.0 (25437) Store 504 buffered influxDB history points
      2025-06-25 20:19:50.308  - debug: shuttercontrol.0 (26159) Lightsensor changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Helligjkeit_Süd_Messwert | Value: 10199.04lux
      2025-06-25 20:20:00.007  - debug: shuttercontrol.0 (26159) calculate astrodata ...
      2025-06-25 20:20:00.008  - debug: shuttercontrol.0 (26159) Sun Azimut: 296.6°
      2025-06-25 20:20:00.008  - debug: shuttercontrol.0 (26159) Sun Elevation: 7.9°
      2025-06-25 20:20:02.438  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875602437_3871
      2025-06-25 20:20:03.289  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
      2025-06-25 20:20:24.266  - debug: shuttercontrol.0 (26159) outsidetemperature changed: knx.0.Melden_Sensor.Wetterstation_Regensensor.Temperatur_Messwert | Value: 32.3°C
      2025-06-25 20:20:43.970  - info: influxdb.0 (25437) Store 501 buffered influxDB history points
      2025-06-25 20:21:01.886  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connected with secret 1750875661886_7516
      2025-06-25 20:21:02.713  - info: mqtt.0 (25928) Client [Holzhütte-Tür] connection closed: disconnected
      2025-06-25 20:21:04.114  - debug: alexa2.0 (25628) Alexa-Remote HTTP2-PUSH: Send Ping
      Kann mir jemand weiter helfen?
      Mfg
      Tom
      Thomas Braun A arteck 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Autodidakt last edited by Thomas Braun
        @autodidakt sagte in Zigbee Adapter schmeißt warnungen:
        Losgelöst vom Problem:
        Bring das Ding in allernächster Zeit auf das aktuelle Release Debian 12 'Bookworm'.
        Per Neuinstallation.
        Zum Problem:
        Setz das Gerät auf den 'link-by-id' fest, nicht auf /dev/ttyUSB0. Das Gerät kann u. U. beim nächsten Boot woanders liegen.
        USB-Devices by-id:
        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
        HINT:
        /dev/ttyUSB0
        Autodidakt 1 Reply Last reply Reply Quote 0
          AlexHaxe @Autodidakt last edited by
          @autodidakt said in Zigbee Adapter schmeißt warnungen:
          das ist die relevante Zeile. Du hast das Debugging für das betroffene Gerät eingeschaltet. Schau Dir mal die Kachel des Geräts an. Der grüne Käfer dort sollte weiß sein, dann bleiben auch die Meldungen stumm.
          • Autodidakt
            Danke euch, Läuft.
            • Autodidakt
              Autodidakt @Thomas Braun last edited by Autodidakt
              @thomas-braun sagte in Zigbee Adapter schmeißt warnungen:
              Gibt es dazu eine Anleitung?
              Reicht es, den Iobroker Ordner nach neuinstallation in die neue Installation zu kopieren?
                Ja. Neuinstallieren.
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                • Autodidakt
                  @thomas-braun Merci, schau ich mir an.
                    Nein, das macht man über ein ordentliches Backup mit dem Backitup-Adapter.
                    • Autodidakt
                      @thomas-braun Auch nicht schlecht, die Idee... 😊
                        @autodidakt
                        Ist jedenfalls eine bessere Idee als 'irgendwas wild' in die neue Installation zu kopieren.
                        • Autodidakt
                          @thomas-braun Super Sache, Danke für eure Hilfe. Jetzt komm ich wieder ein Stück weiter...
                          • Autodidakt
                            Und was könnte denn da falsch gelaufen sein?
                            node-red.0
                            2025-06-25 20:50:44.811	error	Node-RED: Error: Install failed at /opt/iobroker/node_modules/@node-red/registry/lib/installer.js:288:25 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 25 Jun 20:50:44 - [error] Error: Install failed at /opt/iobroker/node_modules/@node-red/registry/lib/installer.js:288:25 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                            node-red.0
                            2025-06-25 20:50:44.809	warn	Node-RED: 25 Jun 20:50:44 - [warn] npm warn config production Use `--omit=dev` instead. npm warn deprecated vis@4.21.0: Please consider using https://github.com/visjs npm error code 1 npm error path /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings npm error command failed npm error command sh -c node-gyp rebuild npm error make: Entering directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' npm error CXX(target) Release/obj.target/bindings/src/serialport.o npm error make: Leaving directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build' npm error gyp info it worked if it ends with ok npm error gyp info using node-gyp@8.4.1 npm error gyp info using node@20.19.3 | linux | arm64 npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3" npm error gyp info spawn /usr/bin/python3 npm error gyp info spawn args [ npm error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py', npm error gyp info spawn args 'binding.gyp', npm error gyp info spawn args '-f', npm error gyp info spawn args 'make', npm error gyp info spawn args '-I', npm error gyp info spawn args '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/config.gypi', npm error gyp info spawn args '-I', npm error gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi', npm error gyp info spawn args '-I', npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.19.3/include/node/common.gypi', npm error gyp info spawn args '-Dlibrary=shared_library', npm error gyp info spawn args '-Dvisibility=default', npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.3', npm error gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp', npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.3/<(target_arch)/node.lib', npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings', npm error gyp info spawn args '-Dnode_engine=v8', npm error gyp info spawn args '--depth=.', npm error gyp info spawn args '--no-parallel', npm error gyp info spawn args '--generator-output', npm error gyp info spawn args 'build', npm error gyp info spawn args '-Goutput_dir=.' npm error gyp info spawn args ] npm error gyp info spawn make npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ] npm error In file included from ../../../nan/nan.h:178, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’ npm error 55 | typedef v8::Local<v8::AccessorSignature> Sig; npm error | ^~~~~~~~~~~~~~~~~ npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid npm error 55 | typedef v8::Local<v8::AccessorSignature> Sig; npm error | ^ npm error In file included from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’: npm error ../../../nan/nan.h:2551:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’ npm error 2551 | , signature); npm error | ^ npm error In file included from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-function.h:15, npm error from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8.h:33, npm error from /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:73, npm error from ../../../nan/nan.h:58, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:809:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ npm error 809 | void SetAccessor( npm error | ^~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:814:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’ npm error 814 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect, npm error | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:816:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’ npm error 816 | void SetAccessor( npm error | ^~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:821:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’ npm error 821 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect, npm error | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 271 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 316 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 366 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’: npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] npm error 412 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error ../src/serialport.cpp: At global scope: npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] npm error 433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) { npm error | ^ npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] npm error 452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { npm error | ^ npm error In file included from ../../../nan/nan.h:58, npm error from ../src/./serialport.h:13, npm error from ../src/serialport.cpp:1: npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1227:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] npm error 1227 | (node::addon_register_func) (regfunc), \ npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1261:3: note: in expansion of macro ‘NODE_MODULE_X’ npm error 1261 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) npm error | ^~~~~~~~~~~~~ npm error ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’ npm error 486 | NODE_MODULE(serialport, init); npm error | ^~~~~~~~~~~ npm error make: *** [bindings.target.mk:109: Release/obj.target/bindings/src/serialport.o] Error 1 npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2 npm error gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23) npm error gyp ERR! stack at ChildProcess.emit (node:events:524:28) npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12) npm error gyp ERR! System Linux 6.1.21-v8+ npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild" npm error gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings npm error gyp ERR! node -v v20.19.3 npm error gyp ERR! node-gyp -v v8.4.1 npm error gyp ERR! not ok npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T18_50_27_905Z-debug-0.log 25 Jun 20:50:44 - [warn] ------------------------------------------
                            node-red.0
                            2025-06-25 20:50:44.808	warn	Node-RED: 25 Jun 20:50:44 - [warn] ------------------------------------------
                            node-red.0
                            2025-06-25 20:50:44.807	warn	Node-RED: 25 Jun 20:50:44 - [warn] Installation of module node-red-contrib-zigbee failed:
                              arteck Developer Most Active @Autodidakt last edited by
                              @autodidakt
                              ELEVATED
                              bedeutet dass da irgend zu einem Gerät die Debug infos an sind
                              steht hier was - >
                              zigbee.0.info.debugmessages
                                Könnte man evtl sehen, wenn du das direkte Log unter /opt/iobroker/logs
                                Posten würdest und nicht den GUI-Hantier.
                                • Autodidakt
                                  2025-06-25 21:25:46.719  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] Installation of module node-red-contrib-zigbee failed:
                                  2025-06-25 21:25:46.720  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] ------------------------------------------
                                  25 Jun 21:25:46 - [warn] npm warn config production Use `--omit=dev` instead.
                                  npm error code 1
                                  npm error       |                                        ^
                                  npm error       |                ^
                                  npm error       |                            ^
                                  npm error       |                              ^
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
                                  pi@pi4-Master:~ $ tail /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
                                  1028 silly unfinished npm timer build:deps 1750879540508
                                  1029 silly unfinished npm timer build:run:install 1750879540638
                                  1030 silly unfinished npm timer build:run:install:node_modules/zigbee-herdsman/node_modules/@serialport/bindings 1750879540657
                                  1031 verbose cwd /opt/iobroker/iobroker-data/node-red
                                  1032 verbose os Linux 6.1.21-v8+
                                  1033 verbose node v20.19.3
                                  1034 verbose npm  v10.8.2
                                  1035 verbose exit 1
                                  1036 verbose code 1
                                  1037 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
                                  pi@pi4-Master:~ $
                                  • Autodidakt
                                    Autodidakt @arteck last edited by
                                    @arteck sagte in Zigbee Adapter schmeißt warnungen:
                                    @autodidakt
                                    ELEVATED
                                    steht hier was - >
                                    Nein, logstufe ist auf Info
                                      @autodidakt es geht nicht um die logstufe sondern um den eintrag da drin.. aber da wird ehh nix mehr drin stehen..
                                      • Autodidakt
                                        @arteck Ich kann Dir nicht folgen...
                                          Brokerti last edited by
                                          Ich habe ein ähnliches Problem, allerdings steht bei mir nirgends was von Debug und der Käfer ist auch weiß.
                                            AlexHaxe @Brokerti last edited by
                                            @brokerti said in Zigbee Adapter schmeißt warnungen:
                                            Bist Du sicher, dass Du die richtige Kachel angeschaut hast? Vielleicht sind bei Dir auch die Farben anders, wenn Du mit der Maus über dem Käfer "hoverst", was sagt der Tooltip? Er sollte "Enable Debug" anzeigen, wenn Debug ausgeschaltet ist (klingt komisch, ist aber so).
                                            gfs. danach den Adapter neu starten, dabei auf Meldungen im Log schauen:
                                            2025-06-25 20:14:15.705 info debug devices set to ["xxxxxxxx"]
                                            Mit grünem Käfer wird in den eckigen Klammern eine Liste der Debug-Geräte angezeigt. Ohne Debug-Geräte sollte dort [] stehen.
                                            617
