    4. Zigbee Adapter schmeißt warnungen
    • Autodidakt
      Autodidakt @Thomas Braun last edited by Autodidakt
      2025-06-25 21:25:46.719  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] Installation of module node-red-contrib-zigbee failed:
      2025-06-25 21:25:46.720  - warn: node-red.0 (25486) Node-RED: 25 Jun 21:25:46 - [warn] ------------------------------------------
      25 Jun 21:25:46 - [warn] npm warn config production Use `--omit=dev` instead.
      npm warn deprecated vis@4.21.0: Please consider using https://github.com/visjs
      npm error code 1
      npm error path /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
      npm error command failed
      npm error command sh -c node-gyp rebuild
      npm error make: Entering directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
      npm error   CXX(target) Release/obj.target/bindings/src/serialport.o
      npm error make: Leaving directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
      npm error gyp info it worked if it ends with ok
      npm error gyp info using node-gyp@8.4.1
      npm error gyp info using node@20.19.3 | linux | arm64
      npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      npm error gyp info spawn /usr/bin/python3
      npm error gyp info spawn args [
      npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
      npm error gyp info spawn args   'binding.gyp',
      npm error gyp info spawn args   '-f',
      npm error gyp info spawn args   'make',
      npm error gyp info spawn args   '-I',
      npm error gyp info spawn args   '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/config.gypi',
      npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
      npm error gyp info spawn args   '/home/iobroker/.cache/node-gyp/20.19.3/include/node/common.gypi',
      npm error gyp info spawn args   '-Dlibrary=shared_library',
      npm error gyp info spawn args   '-Dvisibility=default',
      npm error gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.3',
      npm error gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
      npm error gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.3/<(target_arch)/node.lib',
      npm error gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings',
      npm error gyp info spawn args   '-Dnode_engine=v8',
      npm error gyp info spawn args   '--depth=.',
      npm error gyp info spawn args   '--no-parallel',
      npm error gyp info spawn args   '--generator-output',
      npm error gyp info spawn args   'build',
      npm error gyp info spawn args   '-Goutput_dir=.'
      npm error gyp info spawn args ]
      npm error gyp info spawn make
      npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
      npm error In file included from ../../../nan/nan.h:178,
      npm error                  from ../src/./serialport.h:13,
      npm error                  from ../src/serialport.cpp:1:
      npm error ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’
      npm error    55 | typedef v8::Local<v8::AccessorSignature> Sig;
      npm error       |                       ^~~~~~~~~~~~~~~~~
      npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid
      npm error       |                                        ^
      npm error In file included from ../src/./serialport.h:13,
      npm error ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
      npm error ../../../nan/nan.h:2551:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’
      npm error  2551 |     , signature);
      npm error       |                ^
      npm error In file included from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-function.h:15,
      npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8.h:33,
      npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:73,
      npm error                  from ../../../nan/nan.h:58,
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:809:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
      npm error   809 |   void SetAccessor(
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:814:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
      npm error   814 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
      npm error       |       ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:816:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
      npm error   816 |   void SetAccessor(
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:821:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
      npm error   821 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      npm error       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      npm error       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      npm error       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
      npm error   412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      npm error ../src/serialport.cpp: At global scope:
      npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
      npm error   433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      npm error       |                            ^
      npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
      npm error   452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      npm error       |                              ^
      npm error In file included from ../../../nan/nan.h:58,
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1227:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      npm error  1227 |       (node::addon_register_func) (regfunc),                          \
      npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1261:3: note: in expansion of macro ‘NODE_MODULE_X’
      npm error  1261 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      npm error ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
      npm error   486 | NODE_MODULE(serialport, init);
      npm error make: *** [bindings.target.mk:109: Release/obj.target/bindings/src/serialport.o] Error 1
      npm error gyp ERR! build error
      npm error gyp ERR! stack Error: `make` failed with exit code: 2
      npm error gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
      npm error gyp ERR! stack     at ChildProcess.emit (node:events:524:28)
      npm error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
      npm error gyp ERR! System Linux 6.1.21-v8+
      npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      npm error gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
      npm error gyp ERR! node -v v20.19.3
      npm error gyp ERR! node-gyp -v v8.4.1
      npm error gyp ERR! not ok
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
      pi@pi4-Master:~ $ tail /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
      1028 silly unfinished npm timer build:deps 1750879540508
      1029 silly unfinished npm timer build:run:install 1750879540638
      1030 silly unfinished npm timer build:run:install:node_modules/zigbee-herdsman/node_modules/@serialport/bindings 1750879540657
      1031 verbose cwd /opt/iobroker/iobroker-data/node-red
      1032 verbose os Linux 6.1.21-v8+
      1033 verbose node v20.19.3
      1034 verbose npm  v10.8.2
      1035 verbose exit 1
      1036 verbose code 1
      1037 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-25T19_25_26_960Z-debug-0.log
      pi@pi4-Master:~ $
      • Autodidakt
        Autodidakt @arteck last edited by
        @arteck sagte in Zigbee Adapter schmeißt warnungen:
        @autodidakt
        ELEVATED
        bedeutet dass da irgend zu einem Gerät die Debug infos an sind
        steht hier was - >
        zigbee.0.info.debugmessages
        Nein, logstufe ist auf Info
          arteck Developer Most Active @Autodidakt last edited by
          @autodidakt es geht nicht um die logstufe sondern um den eintrag da drin.. aber da wird ehh nix mehr drin stehen..
          Autodidakt 1 Reply Last reply Reply Quote 0
          • Autodidakt
            @arteck Ich kann Dir nicht folgen...
              Brokerti last edited by
              Ich habe ein ähnliches Problem, allerdings steht bei mir nirgends was von Debug und der Käfer ist auch weiß.
                AlexHaxe @Brokerti last edited by
                @brokerti said in Zigbee Adapter schmeißt warnungen:
                Bist Du sicher, dass Du die richtige Kachel angeschaut hast? Vielleicht sind bei Dir auch die Farben anders, wenn Du mit der Maus über dem Käfer "hoverst", was sagt der Tooltip? Er sollte "Enable Debug" anzeigen, wenn Debug ausgeschaltet ist (klingt komisch, ist aber so).
                gfs. danach den Adapter neu starten, dabei auf Meldungen im Log schauen:
                2025-06-25 20:14:15.705 info debug devices set to ["xxxxxxxx"]
                Mit grünem Käfer wird in den eckigen Klammern eine Liste der Debug-Geräte angezeigt. Ohne Debug-Geräte sollte dort [] stehen.
                  Brokerti @AlexHaxe last edited by
                  @alexhaxe korrekt. Es steht dann enabled debug da. wenn ich Debug aktiviere, erhalte ich dennoch Nicht die besagte Debugmeldung!
                  Selbst wenn ich den BWM lösche und Batterien entferne kommen alle 15sec die Log Einträge.
                  Auch wenn ich ihn in der Instanz deaktiviere.
                  Folglich "spukt" sich die Instanz selbst etwas vor.
                  Vorhin habe ich mal auf "reconfigure" geklickt und damit kam dann zumindest die Occupancy Funktion zurück.
                  Angefangen hat das Problem, seit der Ventilator im Zimmer steht :D.
                    Das klingt sehr unwahrscheinlich. Ein Batterie-Gerät ohne Batterien sendet nichts. Bist Du Dir sicher, dass Du den richtigen Bewegungsmelder anschaust? Die Hex-Zahlen sehen sich ja immer zum Verwechseln ähnlich.
                    Die Meldung info debug devices set to [] kommt nur beim Hochfahren des Adapters, oder beim Anklicken der Käfer. Wobei die [] durch eine Liste der IDs ersetzt wird, sobald Debug aktiv ist.
                    Ob ein Ventilator mit einem Bewegungsmelder interagiert, bzw. dessen Belegt Status beeinflussen kann, entzieht sich derzeit meiner Kenntnis. Die Debug-Meldungen sind aber unabhängig davon.
                      @alexhaxe du hattest recht!
                      Ich hätte schwören können, ich war am richtigen BWM.
                      Nummer verglichen und siehe da, es war ein anderer. Weshalb dieser auf Debug stand, kann ich mir nicht erklären..
                      Somit wünsche ich eine ruhige und kühle Nacht. Vielen Dank! 🙂
                      • Autodidakt
                        Autodidakt @Brokerti last edited by
                        Was ist ein BWM?
                          sigi234 Forum Testing Most Active @Autodidakt last edited by
                          @autodidakt sagte in Zigbee Adapter schmeißt warnungen:
                          Was ist ein BWM?
                          Bewegungsmelder
                          • Autodidakt
                            Kann niemand mit dieser Fehlermeldung etwas anfangen?
                            2025-06-26T08:09:05.411Z Installieren : node-red-contrib-zigbee 0.21.0
                            2025-06-26T08:09:05.300Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-zigbee@0.21.0
                            2025-06-26T08:09:05.697Z [err] npm warn config production Use `--omit=dev` instead.
                            2025-06-26T08:09:21.023Z [err] npm warn deprecated vis@4.21.0: Please consider using https://github.com/visjs
                            2025-06-26T08:09:27.263Z [err] npm error code 1
                            2025-06-26T08:09:27.264Z [err] npm error path /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                            2025-06-26T08:09:27.264Z [err] npm error command failed
                            2025-06-26T08:09:27.264Z [err] npm error command sh -c node-gyp rebuild
                            2025-06-26T08:09:27.264Z [err] npm error make: Entering directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                            2025-06-26T08:09:27.264Z [err] npm error   CXX(target) Release/obj.target/bindings/src/serialport.o
                            2025-06-26T08:09:27.264Z [err] npm error make: Leaving directory '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build'
                            2025-06-26T08:09:27.266Z [err] npm error gyp info it worked if it ends with ok
                            2025-06-26T08:09:27.266Z [err] npm error gyp info using node-gyp@8.4.1
                            2025-06-26T08:09:27.266Z [err] npm error gyp info using node@20.19.3 | linux | arm64
                            2025-06-26T08:09:27.266Z [err] npm error gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn /usr/bin/python3
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args [
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'binding.gyp',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-f',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'make',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-I',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/config.gypi',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '/home/iobroker/.cache/node-gyp/20.19.3/include/node/common.gypi',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dlibrary=shared_library',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dvisibility=default',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.19.3',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.19.3/<(target_arch)/node.lib',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Dnode_engine=v8',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--depth=.',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--no-parallel',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '--generator-output',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   'build',
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args   '-Goutput_dir=.'
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args ]
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn make
                            2025-06-26T08:09:27.266Z [err] npm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
                            2025-06-26T08:09:27.266Z [err] npm error In file included from ../../../nan/nan.h:178,
                            2025-06-26T08:09:27.266Z [err] npm error                  from ../src/./serialport.h:13,
                            2025-06-26T08:09:27.266Z [err] npm error                  from ../src/serialport.cpp:1:
                            2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’
                            2025-06-26T08:09:27.266Z [err] npm error    55 | typedef v8::Local<v8::AccessorSignature> Sig;
                            2025-06-26T08:09:27.266Z [err] npm error       |                       ^~~~~~~~~~~~~~~~~
                            2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan_callbacks.h:55:40: error: template argument 1 is invalid
                            2025-06-26T08:09:27.266Z [err] npm error In file included from ../src/./serialport.h:13,
                            2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../../../nan/nan.h:2551:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’
                            2025-06-26T08:09:27.266Z [err] npm error  2551 |     , signature);
                            2025-06-26T08:09:27.266Z [err] npm error In file included from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-function.h:15,
                            2025-06-26T08:09:27.266Z [err] npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8.h:33,
                            2025-06-26T08:09:27.266Z [err] npm error                  from /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:73,
                            2025-06-26T08:09:27.266Z [err] npm error                  from ../../../nan/nan.h:58,
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:809:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                            2025-06-26T08:09:27.266Z [err] npm error   809 |   void SetAccessor(
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:814:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
                            2025-06-26T08:09:27.266Z [err] npm error   814 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
                            2025-06-26T08:09:27.266Z [err] npm error       |       ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:816:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                            2025-06-26T08:09:27.266Z [err] npm error   816 |   void SetAccessor(
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/v8-template.h:821:22: note:   no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’
                            2025-06-26T08:09:27.266Z [err] npm error   821 |       SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                            2025-06-26T08:09:27.266Z [err] npm error       |                                                   ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                            2025-06-26T08:09:27.266Z [err] npm error       |                                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                            2025-06-26T08:09:27.266Z [err] npm error       |                                                          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error   412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp: At global scope:
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                            2025-06-26T08:09:27.266Z [err] npm error   433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                            2025-06-26T08:09:27.266Z [err] npm error   452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                            2025-06-26T08:09:27.266Z [err] npm error In file included from ../../../nan/nan.h:58,
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1227:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                            2025-06-26T08:09:27.266Z [err] npm error  1227 |       (node::addon_register_func) (regfunc),                          \
                            2025-06-26T08:09:27.266Z [err] npm error /home/iobroker/.cache/node-gyp/20.19.3/include/node/node.h:1261:3: note: in expansion of macro ‘NODE_MODULE_X’
                            2025-06-26T08:09:27.266Z [err] npm error  1261 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                            2025-06-26T08:09:27.266Z [err] npm error ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
                            2025-06-26T08:09:27.266Z [err] npm error   486 | NODE_MODULE(serialport, init);
                            2025-06-26T08:09:27.266Z [err] npm error make: *** [bindings.target.mk:109: Release/obj.target/bindings/src/serialport.o] Error 1
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! build error
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack Error: `make` failed with exit code: 2
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/node-gyp/lib/build.js:194:23)
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess.emit (node:events:524:28)
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! System Linux 6.1.21-v8+
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! cwd /opt/iobroker/iobroker-data/node-red/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! node -v v20.19.3
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! node-gyp -v v8.4.1
                            2025-06-26T08:09:27.266Z [err] npm error gyp ERR! not ok
                            2025-06-26T08:09:27.274Z [err] npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T08_09_05_562Z-debug-0.log
                            2025-06-26T08:09:27.317Z rc=1
                              Homoran Global Moderator Administrators @Autodidakt last edited by
                              doch!
                              aber du bist falsch hier!
                              hat nichts mit dem zigbee-Adapter zu tun!
                              • Autodidakt
                                @homoran Achso, wo muss ich denn damit hin?
                                  roter und fetter konnte ich es nicht machen.
                                  es besteht natürlich noch die Möglichkeit dass du da gerade irgendwas ganz snderes tust.
                                  Da du nicht sagst was du tust, wenn diese Meldung auftritt, kann ich dir nicht sagen wohin du genau musst
                                  • Autodidakt
                                    Autodidakt @Homoran last edited by Autodidakt
                                    Ich möchte nur installieren.
                                    Ich möchte auf meinem Node red Dashboard einen ein/aus Button für ein zigbee Gerät.
                                    Ich weiß nicht, was ich Dir verheimlicht hätte...
                                    STOP! Node red schreibt, dass dieser Knoten aufgegeben wurde. IoB hat also nichts damit zu tun.
                                    Dank euch.
                                    Mfg
                                    Tom
                                      was?
                                      wo?
                                      wie?
                                      und warum
                                      oder hast du nicht den node-red Adapter, sondern eine standalone node-red Installation?
                                      siehe die noch immer offenen Fragen
                                      • Autodidakt
                                        @homoran sagte in Zigbee Adapter schmeißt warnungen:
                                        was?
                                        wo?
                                        wie?
                                        und warum
                                        was?
                                        wo?
                                        node-red Adapter V 5.2.1 in IoBroker
                                        wie
                                        über die Palletten im node-red Adapter
                                        617
