    4. Nach Nodejs 22 Update - Adapter nicht updatefähig
      Thomas Braun Most Active @MCU last edited by
      @mcu
      iob update
      iob upgrade
      sagt?
        MCU @Thomas Braun last edited by MCU
        Linux iobrokerProd 6.8.12-11-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-11 (2025-05-22T09:39Z) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Wed Jun 25 23:33:06 CEST 2025 on tty1
        prox@iobrokerProd:~$ iob update
        Used repository: beta
        Adapter    "admin"        : 7.7.1    , installed 7.7.1
        Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
        Adapter    "awattar"      : 1.0.6    , installed 1.0.6
        Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.3.3    , installed 3.3.0  [Updatable]
        Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
        Adapter    "bring"        : 1.9.1    , installed 1.9.1
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "cameras"      : 2.1.2    , installed 2.1.2
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
        Adapter    "devices"      : 1.2.7    , installed 1.2.7
        Adapter    "echarts"      : 2.0.6    , installed 2.0.6
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
        Adapter    "flexcharts"   : 0.4.1    , installed 0.4.1
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
        Adapter    "hue"          : 3.16.2   , installed 3.16.2
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "iot"          : 3.5.2    , installed 3.5.0  [Updatable]
        Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.17
        Adapter    "javascript"   : 9.0.6    , installed 9.0.6
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "lovelace"     : 5.0.0    , installed 5.0.0
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
        Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
        Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
        Adapter    "odl"          : 5.0.0    , installed 5.0.0
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openweathermap": 1.3.0   , installed 1.3.0
        Adapter    "parser"       : 2.3.1    , installed 2.3.1
        Adapter    "pegelalarm"   : 1.3.8    , installed 1.3.8
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
        Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
        Adapter    "ring"         : 6.3.0    , installed 6.3.0
        Adapter    "roadtraffic"  : 1.2.0    , installed 1.2.0
        Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
        Adapter    "shelly"       : 10.0.0   , installed 10.0.0
        Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
        Adapter    "slideshow"    : 0.2.1    , installed 0.2.1
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "snmp"         : 3.2.0    , installed 3.2.0
        Adapter    "socketio"     : 7.0.8    , installed 7.0.8
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
        Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
        Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
        Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
        Adapter    "vis-2"        : 2.12.10  , installed 2.12.10
        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
        Adapter    "web"          : 7.0.9    , installed 7.0.6  [Updatable]
        Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
        Adapter    "wled"         : 0.7.3    , installed 0.7.3
        Adapter    "ws"           : 3.0.19   , installed 3.0.19
        Adapter    "zigbee"       : 3.0.1    , installed 2.0.4  [Updatable]
        prox@iobrokerProd:~$ iob upgrade
        This upgrade of "zigbee" will introduce the following changes:
        -> 3.0.1:
        Fix for Ikea SOMRIG configuration raising 'definition.endpoint is not a function' error.
        Access to 'zigbee2mqtt options as settings in zigbee adapter (ALPHA Stage !)
        Fix for 'error: zigbee.0 (1118300) zigbee.0 already running' at adapter start (Alpha Stage)
        Updated hardware configuration panel - exchanged text buttons for buttons with icons.
        Limited states on device tiles to states which are read only or which can be modified sensibly via the device tile.
        -> 3.0.0:
        Breaking change: Start of zigbee subsystem requires configuration entry !!!
        Hardware configuration panel
        Update for external converter - detect /dist/ subfolder
        Update device image: use of icons defined in external converter (beta)
        -> 2.0.5:
        ZHC 23.6.0
        ZH 3.3.x
        removed extra logging
        fixed memory issue.
        Configure on Message - 5 attempts.
        update transmitPower
        fix crash in ZigbeeController.ByteArrayToString
        device designation for  devices without mapped model (allows use in groups and bindings)
        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
        Would you like to upgrade zigbee from @2.0.4 to @3.0.1 now? [(y)es, (n)o]:
        Nach Neustart vom System erhalte ich bei Update vom backitup
        $ iobroker upgrade backitup@3.3.3 --debug
        Update backitup from @3.3.0 to @3.3.3
        host.iobrokerProd Adapter "system.adapter.backitup.0" is stopped.
        NPM version: 10.9.2
        Installing iobroker.backitup@3.3.3... (System call)
        npm error code EBADENGINE
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_07_15_821Z-debug-0.log
        Updating objects from io-package.json for adapter "backitup" with version "3.3.0"
        upload [96] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/asset-manifest.json asset-manifest.json application/json
        upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/assets/zigbee2mqtt-tDEKhm15.png assets/zigbee2mqtt-tDEKhm15.png image/png
        upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js application/javascript
        upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/emotion-serialize.esm-BUa21YfQ.js custom/assets/emotion-serialize.esm-BUa21YfQ.js application/javascript
        upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/index-DHRZ46WI.js custom/assets/index-DHRZ46WI.js application/javascript
        upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/virtualExposes-Bgb1mEhK.js custom/assets/virtualExposes-Bgb1mEhK.js application/javascript
        upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
        upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/history.jsonConfig.json5 history.jsonConfig.json5 application/json5
        upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/influxdb.jsonConfig.json5 influxdb.jsonConfig.json5 application/json5
        upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/iob.jsonConfig.json5 iob.jsonConfig.json5 application/json5
        upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/jsonConfig.json5 jsonConfig.json5 application/json5
        upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
        upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
        upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
        host.iobrokerProd Adapter "system.adapter.backitup.0" is started
        Process exited with code 0
          @mcu
          Läuft doch...
            @thomas-braun siehe oben
              @thomas-braun Updateversuch auf der console
              This upgrade of "backitup" will introduce the following changes:
              -> 3.3.3:
              Translation updated
              Fix Grafana Backup & Restore
              Docu updated
              dependencies updated
              -> 3.3.2:
              Base Topic for z2m Remote Backup added
              -> 3.3.1:
              Fix z2m Remote Backup
              Would you like to upgrade backitup from @3.3.0 to @3.3.3 now? [(y)es, (n)o]: y
              NPM version: 10.9.2
              upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
              upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
              upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
              upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
              upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
              upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
              upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
              upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
              upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
              upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
              upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
              upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
              upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
              prox@iobrokerProd:~$ iob version backitup
              3.3.0
                @mcu
                Bitte immer vollständige Ein- wie Ausgaben zeigen.
                Und bitte auf die Spoiler verzichten, die Klickerei nervt.
                  @thomas-braun Hab bei iob upgrade die anderen Adapter mit N nicht upgegradet`, nur bei backitup mit Y.
                  Habe nochmal
                  iob stop
                  iob fix
                  laufen lassen, dann
                  3.3.0
                  prox@iobrokerProd:~$ iob upgrade backitup@3.3.3
                  -> 3.3.3:
                  Translation updated
                  Docu updated
                  -> 3.3.2:
                  -> 3.3.1:
                  NPM version: 10.9.2
                  3.3.0
                    @mcu
                    cd /opt/iobroker
                    npm ls
                    npm i --dry-run
                      @thomas-braun sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                      npm ls
                      prox@iobrokerProd:~$ cd /opt/iobroker
                      prox@iobrokerProd:/opt/iobroker$ npm ls
                      [sudo] password for prox:
                      iobroker.inst@3.0.0 /opt/iobroker
                      +-- @emnapi/runtime@1.3.1 extraneous
                      +-- @iobroker-javascript.0/axios@npm:axios@1.10.0
                      +-- @iobroker-javascript.0/cheerio@npm:cheerio@1.1.0
                      +-- @iobroker-javascript.0/decompress-targz@npm:decompress-targz@4.1.1
                      +-- @iobroker-javascript.0/decompress@npm:decompress@4.2.1
                      +-- @iobroker-javascript.0/form-data@npm:form-data@4.0.3
                      +-- @iobroker-javascript.0/html-pdf@npm:html-pdf@3.0.1
                      +-- @iobroker-javascript.0/html2json@npm:html2json@1.0.2
                      +-- @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
                      +-- @iobroker-javascript.0/jsdom@npm:jsdom@26.1.0
                      +-- @iobroker-javascript.0/node-ipc@npm:node-ipc@12.0.0
                      +-- @iobroker-javascript.0/puppeteer@npm:puppeteer@24.10.2
                      +-- @iobroker-javascript.0/uuid@npm:uuid@11.1.0
                      +-- @iobroker-javascript.0/xml2js@npm:xml2js@0.6.2
                      +-- @iobroker-javascript.0/xmldom@npm:xmldom@0.6.0
                      +-- iobroker.admin@7.7.1
                      +-- iobroker.alexa2@3.26.7
                      +-- iobroker.awattar@1.0.6
                      +-- iobroker.awtrix-light@2.0.0
                      +-- iobroker.backitup@3.3.0
                      +-- iobroker.birthdays@4.0.0
                      +-- iobroker.bring@1.9.1
                      +-- iobroker.broadlink2@2.3.0
                      +-- iobroker.cameras@2.1.2
                      +-- iobroker.chromecast@4.0.0
                      +-- iobroker.cloud@5.0.1
                      +-- iobroker.daswetter@3.2.3
                      +-- iobroker.devices@1.2.7
                      +-- iobroker.discovery@5.0.0
                      +-- iobroker.dwd@2.8.5
                      +-- iobroker.echarts@2.0.6
                      +-- iobroker.email@2.0.4
                      +-- iobroker.fahrplan@1.4.1
                      +-- iobroker.flexcharts@0.4.1
                      +-- iobroker.flot@1.12.0
                      +-- iobroker.fritzdect@2.6.2
                      +-- iobroker.fullybrowser@3.1.1
                      +-- iobroker.history@3.0.1
                      +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#1de8967c7f7150dfdc1c281899adc5d01777b050)
                      +-- iobroker.hue@3.16.2
                      +-- iobroker.ical@1.16.2
                      +-- iobroker.iot@3.5.0
                      +-- iobroker.jarvis@3.2.0-rc.17 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#65370bd2ad4617722447bcff04ba4dc6429bed9b)
                      +-- iobroker.javascript@9.0.6
                      +-- iobroker.js-controller@7.0.7
                      +-- iobroker.lovelace@5.0.0
                      +-- iobroker.meross@1.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.meross.git#89166c86e032b777b634e9fbe1e42544de9c9fb0)
                      +-- iobroker.mqtt-client@3.0.0
                      +-- iobroker.mqtt@6.1.4
                      +-- iobroker.notificationforandroidtv@3.0.4
                      +-- iobroker.odl@5.0.0
                      +-- iobroker.onvif@1.1.4
                      +-- iobroker.openweathermap@1.3.0
                      +-- iobroker.parser@2.3.1
                      +-- iobroker.pegelalarm@1.3.8
                      +-- iobroker.ping@1.7.9
                      +-- iobroker.proxmox@2.4.0
                      +-- iobroker.proxy@1.3.2
                      +-- iobroker.pushover@4.1.0
                      +-- iobroker.pvforecast@5.0.0
                      +-- iobroker.rest-api@3.0.1
                      +-- iobroker.ring@6.3.0
                      +-- iobroker.roadtraffic@1.2.0
                      +-- iobroker.rssfeed@3.5.2
                      +-- iobroker.shelly@10.0.0
                      +-- iobroker.simple-api@3.0.7
                      +-- iobroker.slideshow@0.2.1
                      +-- iobroker.smartcontrol@2.0.1
                      +-- iobroker.snmp@3.2.0
                      +-- iobroker.socketio@7.0.8
                      +-- iobroker.sonoff@3.2.1
                      +-- iobroker.spotify-premium@1.5.3
                      +-- iobroker.tankerkoenig@3.4.0
                      +-- iobroker.telegram@4.1.0
                      +-- iobroker.terminal@1.0.0
                      +-- iobroker.tr-064@4.3.0
                      +-- iobroker.trashschedule@3.3.0
                      +-- iobroker.tuya@3.17.0
                      +-- iobroker.tvprogram@4.0.0
                      +-- iobroker.tvspielfilm@2.1.0
                      +-- iobroker.twinkly@1.0.14
                      +-- iobroker.virtualpowermeter@1.5.0
                      +-- iobroker.vis-2-widgets-material@1.4.10
                      +-- iobroker.vis-2@2.12.10
                      +-- iobroker.vis-metro@1.2.0
                      +-- iobroker.vis@1.5.6
                      +-- iobroker.web@7.0.6
                      +-- iobroker.wifilight@2.0.3
                      +-- iobroker.wled@0.7.3
                      +-- iobroker.ws@3.0.19
                      `-- iobroker.zigbee@2.0.4
                      prox@iobrokerProd:/opt/iobroker$ npm i --dry-run
                      npm error engine Unsupported engine
                      npm error engine Not compatible with your version of node/npm: ring-client-api@13.1.0
                      npm error notsup Not compatible with your version of node/npm: ring-client-api@13.1.0
                      npm error notsup Required: {"node":"^18 || ^20"}
                      npm error notsup Actual:   {"npm":"10.9.2","node":"v22.17.0"}
                      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_35_49_020Z-debug-0.log
                      Problem wurde auch gemeldet
                      https://github.com/iobroker-community-adapters/ioBroker.ring/issues/820
                      mcuiobroker created this issue in iobroker-community-adapters/ioBroker.ring
                      closed Support of node.js 22 missing #820
                      T OliverIO 2 Replies Last reply Reply Quote 1
                        ticaki Developer @MCU last edited by ticaki
                        @mcu
                        Hab’s nicht ganz gelesen, bei meinem Update auf 22 hab ich yahka entfernen müssen da backitup sich nicht updaten lies wenn es installiert ist - da ist ein veraltetes packet in den deps von yahka. Frag mich nicht wieso das was mit backitup zutun hat.😅
                        Thomas Braun ? 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @ticaki last edited by
                          @ticaki sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                          Nichts direkt. Allerdings macht der Paketmanager npm nichts mehr, wenn da eine nicht auflösbare Konstellation auftaucht.
                          Also Trouble bei yahaka verhindert ein Update von backitup (oder anderen Adaptern).
                            A Former User @ticaki last edited by
                            @ticaki
                            Downgrade Yahka auf die 1.0.3 und es läuft unter node 22
                              MCU @Guest last edited by MCU
                              Fazit?
                              Wenn ein Adapter nicht für die aktuelle Nodejs Version (hier:22) aktuell gehalten wird, kann man ioBroker-Adapter nicht mehr updaten?
                              Der nicht korrekte Adapter muss dann deinstalliert werden!
                              Habe es mal bei chatGPT eingegeben:
                              ⚙️ Warum schlägt ein einzelnes Adapter-Upgrade unter Node.js 22 fehl?
                              📦 Hintergrund: Node.js + native Module
                              Viele ioBroker-Adapter (z. B. modbus, zigbee, mqtt, shelly) nutzen sogenannte native Node-Module (geschriebene C++-Addons). Diese Module sind kompiliert gegen eine bestimmte Node-ABI-Version, z. B. für Node.js 18 oder 20.
                              Wenn du ein Adapter-Update machst, dann passiert:
                              ioBroker nutzt npm → installiert Adapter inkl. package.json
                              npm prüft automatisch:
                              alle Abhängigkeiten
                              ob native Addons kompiliert werden müssen
                              Ist ein Abhängigkeitsmodul nicht kompatibel mit Node.js 22 → npm install schlägt fehl → Adapter-Update komplett abgebrochen
                              Und dabei prüft npm nicht nur das Zielmodul, sondern auch die Abhängigkeiten des gesamten Adapter-Trees, inklusive aller peer dependencies oder optionals.
                              💥 Typisches Beispiel:
                              Du willst hm-rega updaten, aber:
                              ein indirektes Abhängigkeitsmodul wie node-serialport ist noch nicht kompatibel mit Node.js 22
                              npm kann es nicht bauen → npm install schlägt komplett fehl → Adapter wird nicht aktualisiert
                              🔐 Warum kann ioBroker das nicht umgehen?
                              ioBroker selbst verwendet keine eigene Abhängigkeitsverwaltung – er nutzt npm install nativ. Das ist gewollt, da ioBroker-Adapter auf package.json-Basis gepflegt werden.
                              Der Update-Prozess ist also immer so etwas wie:
                              cd /opt/iobroker/node_modules/iobroker.adaptername
                              npm install iobroker.adaptername@latest
                              Wenn das fehlschlägt (egal bei welchem Modul), stoppt der gesamte Update-Prozess.
                              🧩 Lösungsideen (theoretisch):
                              📦 Adapter in isolierte Container packen (→ wäre Overhead)
                              💡 Adapter einzeln in eigene node_modules-Kontexte installieren (aber npm unterstützt das nicht gut)
                              🛠 iobroker könnte ein eigenes Paketmanagement nutzen (aber aktuell zu aufwendig)
                              EDIT
                              Da wäre dann die Frage, kann man das vorher durch einen Befehl prüfen lassen , bevor man das nodejs-update macht?
                              Bzw. Info an die Entwickler immer nur >={letzte geprüfte Nodejs-Version} in der packgae.json zu verwenden und nicht spezielle Angaben =20 || = 22.
                              • OliverIO
                                OliverIO @MCU last edited by
                                @mcu
                                Das bedeutet halt es ist nur 18 oder 20 zulässig.
                                Sonst nix
                                  MCU @OliverIO last edited by MCU
                                  @oliverio Wäre ja auch für einen Adapter (hier: ring) dann ok. Aber das dadurch auch das Update für andere Adapter scheitert, ist mir neu.
                                  EDIT
                                  Bedeutet dann, wenn die Abhängigkeiten aller genutzten Adapter nicht gepflegt wird, mit deren genutzten Abhängigkeiten, APIs usw., kann man ioBroker, in der ,für jeden unterschiedlichen, Ausprägung, nicht mehr komplett nutzen.
                                  • OliverIO
                                    @mcu
                                    Wir hatten da letztens schon einen komischen Fall. Ich glaube das was @ticaki erwähnte. Das müsste sich mal jemand anschauen der viel Ahnung von npm hat.
                                    Homoran T 2 Replies Last reply Reply Quote 0
                                      Homoran Global Moderator Administrators @OliverIO last edited by
                                      @oliverio sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                                      @mcu
                                      muss mal suchen, wenn es interessiert.
                                      @thomas-braun hatte sich da durch die npm Abhängigkeiten durchgekämpft
                                        ticaki Developer @OliverIO last edited by
                                        @mcu
                                        Ja das war ich, der das ansprochen hatte. Ist halt blöd das man nicht sofort beim nodejs-update eine Fehlermeldung bekommt, sondern irgendwann später mal.
                                          Thomas Braun Most Active @ticaki last edited by Thomas Braun
                                          Im aktuellen Code (aber noch nicht released) ist zumindest ein rudimentärer Check drin.
                                          Da wird nach dem nodejs-Ugrade ein
                                          cd /opt/iobroker
                                          npm i --dry-run
                                          ausgeführt und Fehler/Inkompaibilitäten werden dann ausgespuckt. Sieht dann im günstigsten Fall so aus:
                                          echad@chet:/opt/iobroker $ npm i --dry-run
                                          up to date in 6s
                                          248 packages are looking for funding
                                            run `npm fund` for details
                                          Im ungünstigen Fall kannst du eine ellenlange Liste mit Meldungen bekommen.
                                            ticaki Developer @Thomas Braun last edited by
                                            Nur zur Klarstellung - ich konnte damals noch pakete aktualisieren erst bei Backitup ist es dann nicht mehr gegangen - Apollon hat das mit Magie, Wetter, Sternenkonstellation erklärt ^^
                                            477
