    4. Test Adapter Philips-TV v0.2.x
    • AlCalzone
      @dali3:
      Philips PUS8700 `
      Sieht mir nach nem Timeout aus. Bitte neueste Version probieren, da gibts mehr Logs. Kannst du zum Vergleich auch mal die Links durchprobieren?
      http://192.168.0.87:1925/1/audio/volume
      http://192.168.0.87:1925/5/audio/volume
      https://192.168.0.87:1926/6/audio/volume
      • integer63
        integer63 last edited by
        Wow, ging sehr schnell auf grün:
        philips-tv.0	2018-01-30 21:16:50.936	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:16:50.846	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:16:40.753	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:16:40.712	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:16:30.654	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:16:30.577	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:16:20.516	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:16:20.418	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:16:10.373	debug	state with id philips-tv.0.info.connection updated: ack=true; val=true
        philips-tv.0	2018-01-30 21:16:10.372	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":true,"ack":true,"ts":1517343370356,"q":0,"from":"system.adapter.philips-tv.0","lc":1517343370356}
        philips-tv.0	2018-01-30 21:16:10.358	info	The TV at 192.168.11.118 is now reachable.
        philips-tv.0	2018-01-30 21:16:10.350	debug	TV has APIv5
        philips-tv.0	2018-01-30 21:16:10.294	debug	testing APIv5
        philips-tv.0	2018-01-30 21:16:10.157	debug	testing APIv1
        philips-tv.0	2018-01-30 21:16:10.156	debug	detecting API version
        philips-tv.0	2018-01-30 21:16:10.155	debug	connection is ALIVE
        philips-tv.0	2018-01-30 21:16:10.129	debug	state with id philips-tv.0.info.connection updated: ack=true; val=false
        philips-tv.0	2018-01-30 21:16:10.122	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":false,"ack":true,"ts":1517343370104,"q":0,"from":"system.adapter.philips-tv.0","lc":1517340176850}
        philips-tv.0	2018-01-30 21:16:10.078	debug	checking if connection is alive
        philips-tv.0	2018-01-30 21:16:10.068	debug	initializing connection to 192.168.11.118
        philips-tv.0	2018-01-30 21:16:09.992	info	starting. Version 0.3.0-alpha4 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.11.4
        philips-tv.0	2018-01-30 21:16:09.935	info	States connected to redis: 192.168.11.33:6379
        philips-tv.0	2018-01-30 21:16:09.923	debug	statesDB connected
        philips-tv.0	2018-01-30 21:16:09.870	debug	objectDB connected
        • AlCalzone
          @integer63:
          Wow, ging sehr schnell auf grün: `
          Prima, das ist ein Haken mehr auf der Liste. Bitte mal beobachten ob das so bleibt.
            dali3 last edited by
            http://192.168.0.87:1925/6/system
            Not Found
            The server has not found anything matching the request URI
            You can get technical details here.
            Please continue your visit at our home page.
            http://192.168.0.87:1925/system
            {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"cXxPJYO2Jd7cDIA2EVdcnlAJ7u3hHME1wGMcClXPKAw=\n","softwareversion_encrypted":"XYlnb20zZkKE3LL\/Vj3vwh+viBBi72vdK9ead64bFVE=\n","model_encrypted":"MaZqqUUf53LzdAflDuBMRtZDVgoCF0795oOzz3aR8EI=\n","deviceid_encrypted":"I1iDm1ydAOVzZ+Q8tqPbkZPy\/t9pDSwRgVKcKN2EHvk=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
            http://192.168.0.87:1925/5/system
            {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"r6JNErTrk01mgMdYKDrcZhO2h8wxGWbU3\/oCU1YabU4=\n","softwareversion_encrypted":"64nDPvAaqHDiAVZbDPMDvBovcPmyT\/USuWhpBxNi1vE=\n","model_encrypted":"gHBfHO0\/ZcUFiP\/AhZXqohTJArRKu74yN9NoyUSqlEk=\n","deviceid_encrypted":"q6Tjl9HOpRMEqHn37o9fmjiqWOfzhcbVBqw6E4R8Bz0=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
            Not Found
            Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?)
            • N
              NemoN last edited by
              philips-tv.0	2018-01-30 21:37:45.671	warn	The TV at 192.168.5.109 needs to be paired before you can use the adapter. Go to the adapter config to continue!
              philips-tv.0	2018-01-30 21:37:45.670	debug	TV has APIv6
              philips-tv.0	2018-01-30 21:37:45.493	debug	testing APIv6
              philips-tv.0	2018-01-30 21:37:45.392	debug	API test for v5 failed. Reason: [undefined] 404 - "\n\n \n\n\n
              philips-tv.0	2018-01-30 21:37:45.365	debug	testing APIv5
              philips-tv.0	2018-01-30 21:37:45.262	debug	API test for v1 failed. Reason: [undefined] 404 - "\n\n \n\n\n
              philips-tv.0	2018-01-30 21:37:45.245	debug	testing APIv1
              philips-tv.0	2018-01-30 21:37:45.245	debug	detecting API version
              philips-tv.0	2018-01-30 21:37:45.245	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:37:45.224	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:37:45.222	debug	initializing connection to 192.168.5.109
              er erkennt das noch nicht gepairt wurde. super 🙂
              • AlCalzone
                @dali3:
                Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?) `
                Ja das passt, habe die Version bei den letzten Änderungen nicht mehr angepasst. Bist du etwa einer der Leute mit der 4. (anderen) API?
                Kommt da was?
                http://192.168.0.87:49154/nmrRenderingControl.xml
                  @AlCalzone:
                  @dali3:
                  Kommt da was?
                  http://192.168.0.87:49154/nmrRenderingControl.xml `
                  JA!
                  This XML file does not appear to have any style information associated with it. The document tree is shown below.
                  <scpd xmlns="urn:schemas-upnp-org:service-1-0"><specversion><major>1</major>
                  <minor>0</minor></specversion>
                  <servicestatetable><statevariable sendevents="no"><name>PresetNameList</name>
                  <datatype>string</datatype></statevariable>
                  <statevariable sendevents="yes"><name>LastChange</name>
                  <statevariable sendevents="no"><name>A_ARG_TYPE_Channel</name>
                  <allowedvaluelist><allowedvalue>Master</allowedvalue></allowedvaluelist></statevariable>
                  <statevariable sendevents="no"><name>A_ARG_TYPE_InstanceID</name>
                  <datatype>ui4</datatype></statevariable>
                  <statevariable sendevents="no"><name>A_ARG_TYPE_PresetName</name>
                  <allowedvaluelist><allowedvalue>FactoryDefaults</allowedvalue></allowedvaluelist></statevariable>
                  <statevariable sendevents="no"><name>Volume</name>
                  <datatype>ui2</datatype>
                  <allowedvaluerange><minimum>0</minimum>
                  <maximum>100</maximum>
                  <step>1</step></allowedvaluerange></statevariable>
                  <statevariable sendevents="no"><name>Mute</name>
                  <datatype>boolean</datatype></statevariable></servicestatetable>
                  <actionlist><action><name>ListPresets</name>
                  <argumentlist><argument><name>InstanceID</name>
                  <direction>in</direction>
                  <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument>
                  <argument><name>CurrentPresetNameList</name>
                  <direction>out</direction>
                  <relatedstatevariable>PresetNameList</relatedstatevariable></argument></argumentlist></action>
                  <action><name>SelectPreset</name>
                  <argument><name>PresetName</name>
                  <relatedstatevariable>A_ARG_TYPE_PresetName</relatedstatevariable></argument></argumentlist></action>
                  <action><name>GetVolume</name>
                  <argument><name>Channel</name>
                  <relatedstatevariable>A_ARG_TYPE_Channel</relatedstatevariable></argument>
                  <argument><name>CurrentVolume</name>
                  <relatedstatevariable>Volume</relatedstatevariable></argument></argumentlist></action>
                  <action><name>SetVolume</name>
                  <argument><name>DesiredVolume</name>
                  <action><name>SetMute</name>
                  <argument><name>DesiredMute</name>
                  <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action>
                  <action><name>GetMute</name>
                  <argument><name>CurrentMute</name>
                  <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
                  • AlCalzone
                    @dali3:
                    JA! `
                    Hm das geht bei mir aber auch und ich hab API v1. Mich wundert, dass beim Rest nix kommt. Kannst ja nochmal ein paar der Links in diesem Thread probieren - wenn da außer /system nix geht, musst du dich wohl noch etwas gedulden.
                    Aber jetzt ist erst mal Feierabend 🙂
                      @AlCalzone:
                      @dali3:
                      JA! `
                      Aber jetzt ist erst mal Feierabend 🙂 `
                      AlCalzone, hatte gestern auch Feierabend 🙂
                      Habe die Links jetzt zusammentragen und werde diese heute Abend zu Hause testen!
                      Liste IP:
                      • X= getestet
                      X [https://IPvomTV:1926/6/audio/volume](https://IPvomTV:1926/6/audio/volume)
                      X [http://IPvomTV:1925/5/audio/volume](http://IPvomTV:1925/5/audio/volume)
                      X [http://IPvomTV:1925/1/audio/volume](http://IPvomTV:1925/1/audio/volume)
                      X [http://IPvomTV:1925/system](http://IPvomTV:1925/system)
                      X [http://IPvomTV:1925/5/system](http://IPvomTV:1925/5/system)
                      X [http://IPvomTV:1925/6/system](http://IPvomTV:1925/6/system)
                      X [http://IPvomTV:49154/nmrRenderingControl.xml](http://IPvomTV:49154/nmrRenderingControl.xml)
                      [http://IPvomTV:49153/nmrRenderingControl.xml](http://IPvomTV:49153/nmrRenderingControl.xml)
                      [https://IPvomTV:1926/input/Key](https://IPvomTV:1926/input/Key)
                      [http://IPvomTV:49154/nmsDescription.xml](http://IPvomTV:49154/nmsDescription.xml)
                      [http://IPvomTV:49154/nmrAVTransport.xml](http://IPvomTV:49154/nmrAVTransport.xml)
                      [http://IPvomTV:49154/nmsContentDirectorySCPD.xml](http://IPvomTV:49154/nmsContentDirectorySCPD.xml)
                      [http://IPvomTV:49154/nmrConnectionManager.xml](http://IPvomTV:49154/nmrConnectionManager.xml)
                      Falls ich eine übersehen habe, bitte kurz mitteilen 🙂
                      Danke für deinen Einsatz!!!
                        dali3 last edited by Negalein
                        so wie versprochen noch die offenen Punkte:
                         <statevariable sendevents="no"><name>AllowedTransformSettings</name>
                         <statevariable sendevents="no"><name>TransformSettings</name>
                         <action><name>GetAllowedTransforms</name>
                         <argument><name>CurrentAllowedTransformSettings</name>
                        <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetTransforms</name>
                         <argument><name>CurrentTransformValues</name>
                        <relatedstatevariable>TransformSettings</relatedstatevariable></argument></argumentlist></action>
                         <action><name>SetTransforms</name>
                         <argument><name>DesiredTransformValues</name>
                         <action><name>GetAllAvailableTransforms</name>
                         <argumentlist><argument><name>AllAllowedTransformSettings</name>
                        <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
                        Not Found
                        >! The server has not found anything matching the request URI
                        >! You can get technical details here.
                         <root xmlns="urn:schemas-upnp-org:device-1-0"><specversion><major>1</major>
                         <device><devicetype>urn:schemas-upnp-org:device:MediaServer:3</devicetype>
                        <friendlyname>65PUS8700/12</friendlyname>
                        <manufacturer>Royal Philips Electronics</manufacturer>
                        <manufacturerurl>http://www.philips.com</manufacturerurl>
                        <modeldescription>Philips TV Server</modeldescription>
                        <modelname>Philips TV Server</modelname>
                        <modelnumber>2k15Marvel</modelnumber>
                        <modelurl>http://www.philips.com/</modelurl>
                        <serialnumber>123456789-serial</serialnumber>
                        <udn>uuid:5AFEF00D-BABE-DADA-FA5A-b886870336ed</udn>
                        <upc>123456789123</upc>
                         <iconlist><icon><mimetype>image/png</mimetype>
                        <height>48</height>
                        <width>48</width>
                        <depth>24</depth>
                        <url>CP_logo_0.png</url></icon>
                        <height>120</height>
                        <width>120</width>
                        <depth>24</depth>
                        <url>CP_logo_1.png</url></icon>
                         <icon><mimetype>image/jpeg</mimetype>
                        <height>48</height>
                        <width>48</width>
                        <depth>24</depth>
                        <url>CP_logo_2.jpg</url></icon>
                        <width>120</width>
                        <depth>24</depth>
                        <url>CP_logo_3.jpg</url></icon></iconlist>
                         <servicelist><service><servicetype>urn:schemas-upnp-org:service:ContentDirectory:3</servicetype>
                        <serviceid>urn:upnp-org:serviceId:ContentDirectory</serviceid>
                        <controlurl>upnp/control/ContentDirectoryNmsO</controlurl>
                        <eventsuburl>upnp/event/ContentDirectoryNmsO</eventsuburl>
                        <scpdurl>nmsContentDirectorySCPD.xml</scpdurl></service>
                         <service><servicetype>urn:schemas-upnp-org:service:ConnectionManager:2</servicetype>
                        <serviceid>urn:upnp-org:serviceId:ConnectionManager</serviceid>
                        <controlurl>upnp/control/ConnectionManagerNmsO</controlurl>
                        <eventsuburl>upnp/event/ConnectionManagerNmsO</eventsuburl>
                        <scpdurl>nmsConnectionManagerSCPD.xml</scpdurl></service></servicelist></device></root>
                         <actionlist><action><name>Play</name>
                         <argument><name>Speed</name>
                        <relatedstatevariable>TransportPlaySpeed</relatedstatevariable></argument></argumentlist></action>
                         <action><name>Stop</name>
                        <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument></argumentlist></action>
                         <action><name>Next</name>
                         <action><name>Previous</name>
                         <action><name>GetMediaInfo</name>
                         <argument><name>NrTracks</name>
                        <relatedstatevariable>NumberOfTracks</relatedstatevariable></argument>
                         <argument><name>MediaDuration</name>
                        <relatedstatevariable>CurrentMediaDuration</relatedstatevariable></argument>
                         <argument><name>CurrentURI</name>
                        <relatedstatevariable>AVTransportURI</relatedstatevariable></argument>
                         <argument><name>CurrentURIMetaData</name>
                        <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument>
                         <argument><name>NextURI</name>
                        <relatedstatevariable>NextAVTransportURI</relatedstatevariable></argument>
                         <argument><name>NextURIMetaData</name>
                        <relatedstatevariable>NextAVTransportURIMetaData</relatedstatevariable></argument>
                         <argument><name>PlayMedium</name>
                        <relatedstatevariable>PlaybackStorageMedium</relatedstatevariable></argument>
                         <argument><name>RecordMedium</name>
                        <relatedstatevariable>RecordStorageMedium</relatedstatevariable></argument>
                         <argument><name>WriteStatus</name>
                        <relatedstatevariable>RecordMediumWriteStatus</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetDeviceCapabilities</name>
                         <argument><name>PlayMedia</name>
                        <relatedstatevariable>PossiblePlaybackStorageMedia</relatedstatevariable></argument>
                         <argument><name>RecMedia</name>
                        <relatedstatevariable>PossibleRecordStorageMedia</relatedstatevariable></argument>
                         <argument><name>RecQualityModes</name>
                        <relatedstatevariable>PossibleRecordQualityModes</relatedstatevariable></argument></argumentlist></action>
                         <action><name>SetAVTransportURI</name>
                        <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetCurrentTransportActions</name>
                         <argument><name>Actions</name>
                        <relatedstatevariable>CurrentTransportActions</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetTransportSettings</name>
                         <argument><name>PlayMode</name>
                        <relatedstatevariable>CurrentPlayMode</relatedstatevariable></argument>
                         <argument><name>RecQualityMode</name>
                        <relatedstatevariable>CurrentRecordQualityMode</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetTransportInfo</name>
                         <argument><name>CurrentTransportState</name>
                        <relatedstatevariable>TransportState</relatedstatevariable></argument>
                         <argument><name>CurrentTransportStatus</name>
                        <relatedstatevariable>TransportStatus</relatedstatevariable></argument>
                         <argument><name>CurrentSpeed</name>
                         <action><name>Pause</name>
                         <action><name>Seek</name>
                         <argument><name>Unit</name>
                        <relatedstatevariable>A_ARG_TYPE_SeekMode</relatedstatevariable></argument>
                         <argument><name>Target</name>
                        <relatedstatevariable>A_ARG_TYPE_SeekTarget</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetPositionInfo</name>
                         <argument><name>Track</name>
                        <relatedstatevariable>CurrentTrack</relatedstatevariable></argument>
                         <argument><name>TrackDuration</name>
                        <relatedstatevariable>CurrentTrackDuration</relatedstatevariable></argument>
                         <argument><name>TrackMetaData</name>
                        <relatedstatevariable>CurrentTrackMetaData</relatedstatevariable></argument>
                         <argument><name>TrackURI</name>
                        <relatedstatevariable>CurrentTrackURI</relatedstatevariable></argument>
                         <argument><name>RelTime</name>
                        <relatedstatevariable>RelativeTimePosition</relatedstatevariable></argument>
                         <argument><name>AbsTime</name>
                        <relatedstatevariable>AbsoluteTimePosition</relatedstatevariable></argument>
                         <argument><name>RelCount</name>
                        <relatedstatevariable>RelativeCounterPosition</relatedstatevariable></argument>
                         <argument><name>AbsCount</name>
                        <relatedstatevariable>AbsoluteCounterPosition</relatedstatevariable></argument></argumentlist></action></actionlist>
                         <servicestatetable><statevariable sendevents="no"><name>CurrentPlayMode</name>
                        <defaultvalue>NORMAL</defaultvalue>
                         <allowedvaluelist><allowedvalue>NORMAL</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>RecordStorageMedium</name>
                         <allowedvaluelist><allowedvalue>UNKNOWN</allowedvalue>
                        <allowedvalue>DV</allowedvalue>
                        <allowedvalue>MINI-DV</allowedvalue>
                        <allowedvalue>VHS</allowedvalue>
                        <allowedvalue>W-VHS</allowedvalue>
                        <allowedvalue>S-VHS</allowedvalue>
                        <allowedvalue>D-VHS</allowedvalue>
                        <allowedvalue>VHSC</allowedvalue>
                        <allowedvalue>VIDEO8</allowedvalue>
                        <allowedvalue>HI8</allowedvalue>
                        <allowedvalue>CD-ROM</allowedvalue>
                        <allowedvalue>CD-DA</allowedvalue>
                        <allowedvalue>CD-R</allowedvalue>
                        <allowedvalue>CD-RW</allowedvalue>
                        <allowedvalue>VIDEO-CD</allowedvalue>
                        <allowedvalue>SACD</allowedvalue>
                        <allowedvalue>MD-AUDIO</allowedvalue>
                        <allowedvalue>MD-PICTURE</allowedvalue>
                        <allowedvalue>DVD-ROM</allowedvalue>
                        <allowedvalue>DVD-VIDEO</allowedvalue>
                        <allowedvalue>DVD-R</allowedvalue>
                        <allowedvalue>DVD+RW</allowedvalue>
                        <allowedvalue>DVD-RW</allowedvalue>
                        <allowedvalue>DVD-RAM</allowedvalue>
                        <allowedvalue>DVD-AUDIO</allowedvalue>
                        <allowedvalue>DAT</allowedvalue>
                        <allowedvalue>LD</allowedvalue>
                        <allowedvalue>HDD</allowedvalue>
                        <allowedvalue>MICRO-MV</allowedvalue>
                        <allowedvalue>NETWORK</allowedvalue>
                        <allowedvalue>NONE</allowedvalue>
                        <allowedvalue>NOT_IMPLEMENTED</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>RelativeTimePosition</name>
                         <statevariable sendevents="no"><name>CurrentTrackURI</name>
                         <statevariable sendevents="no"><name>CurrentTrackDuration</name>
                         <statevariable sendevents="no"><name>CurrentRecordQualityMode</name>
                         <allowedvaluelist><allowedvalue>0:EP</allowedvalue>
                        <allowedvalue>1:LP</allowedvalue>
                        <allowedvalue>2:SP</allowedvalue>
                        <allowedvalue>0:BASIC</allowedvalue>
                        <allowedvalue>1:MEDIUM</allowedvalue>
                        <allowedvalue>2:HIGH</allowedvalue>
                         <statevariable sendevents="no"><name>CurrentMediaDuration</name>
                         <statevariable sendevents="no"><name>AbsoluteCounterPosition</name>
                        <datatype>i4</datatype></statevariable>
                         <statevariable sendevents="no"><name>RelativeCounterPosition</name>
                         <statevariable sendevents="no"><name>AVTransportURI</name>
                         <statevariable sendevents="no"><name>TransportState</name>
                         <allowedvaluelist><allowedvalue>STOPPED</allowedvalue>
                        <allowedvalue>PAUSED_PLAYBACK</allowedvalue>
                        <allowedvalue>PAUSED_RECORDING</allowedvalue>
                        <allowedvalue>PLAYING</allowedvalue>
                        <allowedvalue>RECORDING</allowedvalue>
                        <allowedvalue>TRANSITIONING</allowedvalue>
                        <allowedvalue>NO_MEDIA_PRESENT</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>CurrentTrackMetaData</name>
                         <statevariable sendevents="no"><name>NextAVTransportURI</name>
                         <statevariable sendevents="no"><name>PossibleRecordQualityModes</name>
                         <statevariable sendevents="no"><name>CurrentTrack</name>
                        <maximum>4294967295</maximum>
                         <statevariable sendevents="no"><name>AbsoluteTimePosition</name>
                         <statevariable sendevents="no"><name>NextAVTransportURIMetaData</name>
                         <statevariable sendevents="no"><name>PlaybackStorageMedium</name>
                         <statevariable sendevents="no"><name>RecordMediumWriteStatus</name>
                         <allowedvaluelist><allowedvalue>WRITABLE</allowedvalue>
                        <allowedvalue>PROTECTED</allowedvalue>
                        <allowedvalue>NOT_WRITABLE</allowedvalue>
                         <statevariable sendevents="no"><name>PossiblePlaybackStorageMedia</name>
                         <statevariable sendevents="no"><name>AVTransportURIMetaData</name>
                         <statevariable sendevents="no"><name>NumberOfTracks</name>
                        <maximum>4294967295</maximum></allowedvaluerange></statevariable>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_SeekMode</name>
                         <allowedvaluelist><allowedvalue>ABS_TIME</allowedvalue>
                        <allowedvalue>REL_TIME</allowedvalue>
                        <allowedvalue>TRACK_NR</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_SeekTarget</name>
                         <statevariable sendevents="no"><name>PossibleRecordStorageMedia</name>
                         <statevariable sendevents="no"><name>TransportStatus</name>
                         <allowedvaluelist><allowedvalue>OK</allowedvalue>
                        <allowedvalue>ERROR_OCCURRED</allowedvalue>
                        <allowedvalue>UNKNOWN</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>TransportPlaySpeed</name>
                         <allowedvaluelist><allowedvalue>1</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>CurrentTransportActions</name>
                        <datatype>string</datatype></statevariable></servicestatetable></scpd>
                        http://IPvomTV:49154/nmsContentDirectorySCPD.…
                         <actionlist><action><name>GetSearchCapabilities</name>
                         <argumentlist><argument><name>SearchCaps</name>
                        <relatedstatevariable>SearchCapabilities</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetSortCapabilities</name>
                         <argumentlist><argument><name>SortCaps</name>
                        <relatedstatevariable>SortCapabilities</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetSystemUpdateID</name>
                         <argumentlist><argument><name>Id</name>
                        <relatedstatevariable>SystemUpdateID</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetServiceResetToken</name>
                         <argumentlist><argument><name>ResetToken</name>
                        <relatedstatevariable>ServiceResetToken</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetFeatureList</name>
                         <argumentlist><argument><name>FeatureList</name>
                        <relatedstatevariable>FeatureList</relatedstatevariable></argument></argumentlist></action>
                         <action><name>Browse</name>
                         <argumentlist><argument><name>ObjectID</name>
                        <relatedstatevariable>A_ARG_TYPE_ObjectID</relatedstatevariable></argument>
                         <argument><name>BrowseFlag</name>
                        <relatedstatevariable>A_ARG_TYPE_BrowseFlag</relatedstatevariable></argument>
                         <argument><name>Filter</name>
                        <relatedstatevariable>A_ARG_TYPE_Filter</relatedstatevariable></argument>
                         <argument><name>StartingIndex</name>
                        <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument>
                         <argument><name>RequestedCount</name>
                        <relatedstatevariable>A_ARG_TYPE_Count</relatedstatevariable></argument>
                         <argument><name>SortCriteria</name>
                        <relatedstatevariable>A_ARG_TYPE_SortCriteria</relatedstatevariable></argument>
                         <argument><name>Result</name>
                        <relatedstatevariable>A_ARG_TYPE_Result</relatedstatevariable></argument>
                         <argument><name>NumberReturned</name>
                         <argument><name>TotalMatches</name>
                         <argument><name>UpdateID</name>
                        <relatedstatevariable>A_ARG_TYPE_UpdateID</relatedstatevariable></argument></argumentlist></action>
                         <action><name>X_BrowseByLetter</name>
                         <argument><name>StartingLetter</name>
                        <relatedstatevariable>A_ARG_TYPE_BrowseLetter</relatedstatevariable></argument>
                        <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument></argumentlist></action>
                         <action><name>X_Philips_PauseStream</name>
                         <argumentlist><argument><name>Result</name>
                        <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action>
                         <action><name>X_Philips_ResumeStream</name>
                         <action><name>X_Philips_JumpToPosition</name>
                         <argumentlist><argument><name>PositionFlag</name>
                        <relatedstatevariable>X_Philips_A_ARG_TYPE_PositionFlag</relatedstatevariable></argument>
                         <argument><name>Position</name>
                        <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument>
                         <action><name>X_Philips_GetPlaybackPosition</name>
                        <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument></argumentlist></action>
                         <action><name>X_Philips_GetTimeShiftInfo</name>
                         <argumentlist><argument><name>BufferDuration</name>
                        <relatedstatevariable>X_Philips_A_ARG_TYPE_BufferedDuration</relatedstatevariable></argument>
                         <argument><name>CurrentPosition</name>
                         <argument><name>MaxDuration</name>
                        <relatedstatevariable>X_Philips_A_ARG_TYPE_MaxDuration</relatedstatevariable></argument>
                        <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action></actionlist>
                         <servicestatetable><statevariable sendevents="yes"><name>TransferIDs</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_ObjectID</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_Result</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseFlag</name>
                         <allowedvaluelist><allowedvalue>BrowseMetadata</allowedvalue>
                        <allowedvalue>BrowseDirectChildren</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseLetter</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_Filter</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_SortCriteria</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_Index</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_Count</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_UpdateID</name>
                         <statevariable sendevents="no"><name>SearchCapabilities</name>
                         <statevariable sendevents="no"><name>SortCapabilities</name>
                         <statevariable sendevents="yes"><name>SystemUpdateID</name>
                         <statevariable sendevents="no"><name>ServiceResetToken</name>
                         <statevariable sendevents="yes"><name>ContainerUpdateIDs</name>
                         <statevariable sendevents="no"><name>FeatureList</name>
                         <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_Result</name>
                         <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_PositionFlag</name>
                         <statevariable sendevents="no"><name>X_Philips_A_ARG_Position</name>
                         <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_BufferedDuration</name>
                         <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_MaxDuration</name>
                         <actionlist><action><name>GetProtocolInfo</name>
                         <argumentlist><argument><name>Source</name>
                        <relatedstatevariable>SourceProtocolInfo</relatedstatevariable></argument>
                         <argument><name>Sink</name>
                        <relatedstatevariable>SinkProtocolInfo</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetCurrentConnectionIDs</name>
                         <argumentlist><argument><name>ConnectionIDs</name>
                        <relatedstatevariable>CurrentConnectionIDs</relatedstatevariable></argument></argumentlist></action>
                         <action><name>GetCurrentConnectionInfo</name>
                         <argumentlist><argument><name>ConnectionID</name>
                        <relatedstatevariable>A_ARG_TYPE_ConnectionID</relatedstatevariable></argument>
                         <argument><name>RcsID</name>
                        <relatedstatevariable>A_ARG_TYPE_RcsID</relatedstatevariable></argument>
                         <argument><name>AVTransportID</name>
                        <relatedstatevariable>A_ARG_TYPE_AVTransportID</relatedstatevariable></argument>
                         <argument><name>ProtocolInfo</name>
                        <relatedstatevariable>A_ARG_TYPE_ProtocolInfo</relatedstatevariable></argument>
                         <argument><name>PeerConnectionManager</name>
                        <relatedstatevariable>A_ARG_TYPE_ConnectionManager</relatedstatevariable></argument>
                         <argument><name>PeerConnectionID</name>
                         <argument><name>Direction</name>
                        <relatedstatevariable>A_ARG_TYPE_Direction</relatedstatevariable></argument>
                         <argument><name>Status</name>
                        <relatedstatevariable>A_ARG_TYPE_ConnectionStatus</relatedstatevariable></argument></argumentlist></action></actionlist>
                         <servicestatetable><statevariable sendevents="yes"><name>SourceProtocolInfo</name>
                         <statevariable sendevents="yes"><name>SinkProtocolInfo</name>
                         <statevariable sendevents="yes"><name>CurrentConnectionIDs</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionStatus</name>
                        <allowedvalue>ContentFormatMismatch</allowedvalue>
                        <allowedvalue>InsufficientBandwidth</allowedvalue>
                        <allowedvalue>UnreliableChannel</allowedvalue>
                        <allowedvalue>Unknown</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionManager</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_Direction</name>
                         <allowedvaluelist><allowedvalue>Input</allowedvalue>
                        <allowedvalue>Output</allowedvalue></allowedvaluelist></statevariable>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_ProtocolInfo</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionID</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_AVTransportID</name>
                         <statevariable sendevents="no"><name>A_ARG_TYPE_RcsID</name>
                        <datatype>i4</datatype></statevariable></servicestatetable></scpd>
                        • wendy2702
                          wendy2702 last edited by
                          @dali3:
                          http://IPvomTV:49153/nmrRenderingControl.xml `
                          Kannst du die vielleicht noch in "SPOILER" verpacken!?
                          Erleichtert das scrollen 😉
                            @wendy2702:
                            @dali3:
                            Erleichtert das scrollen 😉 `
                            So eingepackt, danke für den Input 🙂
                            • AlCalzone
                              Danke für die Logs, das scheint aktuell keine unterstützte API zu sein. Falls du Lust hast, kannst du dich mal in Google austoben. Für sachdienliche Hinweise zur Einbindung bin ich dankbar 😄
                                Ist diese Seite schob bekannt?
                                http://jointspace.sourceforge.net/proje … c/API.html
                                Bzw.
                                https://github.com/stevenle/googletv-anymote ?
                                • AlCalzone
                                  @dali3:
                                  Bzw.
                                  https://github.com/stevenle/googletv-anymote ? `
                                  1. ja, darauf bauen die aktuellen API-Implementationen
                                  2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt?
                                    @AlCalzone:
                                    @dali3:
                                    Bzw.
                                    2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt? `
                                    Ich werde es dieses Weekend probieren, leider sind meine Programmierkenntnisse sehr begrenzt 🙂
                                      Mater1984 last edited by
                                      Ich habe ebenfalls einen TV mit API v6
                                      Das Pairing manuell funktioniert. Dort habe ich jetzt Username und Passwort ausgelesen
                                      Kann man das schon manuell in der Settings Datei eintragen?
                                      Was muss denn noch am Admin Modul geändert werden?
                                      Viele Grüße
                                      • AlCalzone
                                        @Mater1984:
                                        Viele Grüße `
                                        Ich kämpfe aktuell mit der Schnittstelle zum Admin v3, sonst wäre ich gestern schon fertig geworden. Bin mir nicht sicher ob ich das schon fertig implementiert hab, aber die neueste Version von github sollte mit username/Passwort funktionieren. Dazu das Objekt system.adapter.philips-tv.0 bearbeiten und bei username und password deine Daten eintragen.
                                        Gesendet von unterwegs
                                          @AlCalzone:
                                          @Mater1984:
                                          Viele Grüße `
                                          Gesendet von unterwegs `
                                          Von wann ist die aktuelle Version?
                                          Hab es gestern Abend via git heruntergeladen.
                                          Schau es mit nachher mal an. Aber leider sind meine Programmierkenntnisse in dem Bereich nicht so Dolle. Eher dann in Cloudformation und Lambda 😉
                                            @AlCalzone:
                                            @Mater1984:
                                            Viele Grüße `
                                            Irgendwie finde ich das Bearbeiten nicht. Bin aber auch ganz neu bei iobroker.
                                            philips philips tv
                                            84
                                            550
                                            131228
