    4. jarvis v3.1.x - just another remarkable vis
      Stadtschloss last edited by
      ich würde gerne mein IKEA Tredansen Rollo als BlindLevelAction Trigger einfügen in dem StateList Widget. Leider bekomme ich das einfach nicht hin... könnt ihr mit weiterhelfen?
      Das ist der Objektbaum vom Rollo:
        "zigbee.0.b4e3f9fffe528XXX": {
          "type": "device",
          "common": {
            "name": "Wohnzimmer Rollo Rechts",
            "type": "E2103",
            "icon": "img/E2103.png",
            "statusStates": {
              "onlineId": "zigbee.0.b4e3f9fffe528XXX.available"
            "modelIcon": "https://www.zigbee2mqtt.io/images/devices/E2103.png"
          "native": {
            "id": "b4e3f9fffe528XXX"
          "from": "system.adapter.zigbee.0",
          "user": "system.user.admin",
          "ts": 1749842556131,
          "_id": "zigbee.0.b4e3f9fffe528XXX",
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
        "zigbee.0.b4e3f9fffe528XXX.available": {
          "type": "state",
          "common": {
            "name": "Available",
            "type": "boolean",
            "read": true,
            "write": false,
            "role": "state"
          "native": {},
          "ts": 1743693233611,
          "_id": "zigbee.0.b4e3f9fffe528XXX.available",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": true,
          "ack": true
        "zigbee.0.b4e3f9fffe528XXX.battery": {
          "type": "state",
          "common": {
            "name": "Battery percent",
            "type": "number",
            "unit": "%",
            "read": true,
            "write": false,
            "role": "value.battery",
            "min": 0,
            "max": 120,
            "icon": "img/battery_p.png"
          "native": {},
          "ts": 1747980451501,
          "_id": "zigbee.0.b4e3f9fffe528XXX.battery",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": 120,
          "ack": true
        "zigbee.0.b4e3f9fffe528XXX.device_query": {
          "type": "state",
          "common": {
            "name": "Trigger device query",
            "type": "boolean",
            "read": false,
            "write": true,
            "role": "button"
          "native": {},
          "ts": 1743693232861,
          "_id": "zigbee.0.b4e3f9fffe528XXX.device_query",
          "acl": {
            "object": 1636,
            "state": 1636,
        "zigbee.0.b4e3f9fffe528XXX.identify": {
          "type": "state",
          "common": {
            "name": "Initiate device identification",
            "type": "string",
            "states": {
              "identify": "identify"
            "read": true,
            "write": true,
            "role": "state"
          "native": {},
          "ts": 1749842559467,
          "_id": "zigbee.0.b4e3f9fffe528XXX.identify",
          "acl": {
            "object": 1636,
            "state": 1636,
        "zigbee.0.b4e3f9fffe528XXX.link_quality": {
          "type": "state",
          "common": {
            "name": "Link quality",
            "type": "number",
            "read": true,
            "write": false,
            "role": "state",
            "min": 0,
            "max": 255
          "native": {},
          "_id": "zigbee.0.b4e3f9fffe528XXX.link_quality",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": 69,
          "ack": true
        "zigbee.0.b4e3f9fffe528XXX.msg_from_zigbee": {
          "type": "state",
          "common": {
            "name": "Message from Zigbee",
            "type": "string",
            "read": true,
            "write": false,
            "role": "state"
          "native": {},
          "_id": "zigbee.0.b4e3f9fffe528XXX.msg_from_zigbee",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": "{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":1,\"manufacturerCode\":4476,\"imageType\":4487,\"fileVersion\":604241936},\"linkquality\":69,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":54,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}",
          "ack": true
        "zigbee.0.b4e3f9fffe528XXX.position": {
          "type": "state",
          "common": {
            "name": "Position of this cover",
            "type": "number",
            "unit": "%",
            "read": true,
            "write": true,
            "role": "state",
            "min": 0,
            "max": 100
          "native": {},
          "_id": "zigbee.0.b4e3f9fffe528XXX.position",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": 100,
          "ack": true
        "zigbee.0.b4e3f9fffe528XXX.send_payload": {
          "type": "state",
          "common": {
            "name": "Send to Device",
            "type": "string",
            "read": true,
            "write": true,
            "role": "state"
          "native": {},
          "_id": "zigbee.0.b4e3f9fffe528XXX.send_payload",
          "acl": {
            "object": 1636,
            "state": 1636,
        "zigbee.0.b4e3f9fffe528XXX.state": {
          "type": "state",
          "common": {
            "name": "state",
            "type": "string",
            "states": {
              "OPEN": "OPEN",
              "CLOSE": "CLOSE",
              "STOP": "STOP"
            "read": true,
            "write": true,
            "role": "switch"
          "native": {},
          "_id": "zigbee.0.b4e3f9fffe528XXX.state",
          "acl": {
            "object": 1636,
            "state": 1636,
          "val": "OPEN",
          "ack": false
      Nur welche werte muss ich hier eintragen? Hoch und runter funktioniert. Aber der Stop button meldet "true" auf dem State statt "STOP"
        MCU @Stadtschloss last edited by
        @stadtschloss Mach mal bitte ein GIF (screenToGif) und zeige was beim State passiert wenn du STOP auf der Fernbedienung drückst und was passiert, wenn du STOP beim State auswählst.
          Stadtschloss @MCU last edited by
          @mcu Habe keine Fernbedienung verbunden. Der State nimmt folgendes an: "CLOSE" "OPEN" und "STOP".
          Close - Schließt das Rollo
          Open - Öffnet das Rollo
          Stop - Unterbricht den Verfahrvorgang des Rollos
          Wenn ich Stop in Jarvis drücke, wird "true" in den State bei meiner aktuellen Config eingegeben.
            MCU @Stadtschloss last edited by MCU
            @stadtschloss Ok, man braucht für den STOP-Vorgang einen eigenen DP. Die Logik muss man sich dann im Programm aufbauen. Kannst du das? Hast du mehrere von den zigbee Rollos im Einsatz?
            Beispiel für ein Rollo
            den DP 0_userdata.0.jarvis.zigbeeRollo.stop muss man dann in jarvis zuordnen
            // zigbeeRollo v1.0.0
            // Zigbee Rollos mit einem STATE-DP zigbee.0.bxxxxx.state OPEN,CLOSE,STOP
            let zigbeeRolloDP   = '0_userdata.0.jarvis.zigbeeRollo'
            let jarvisStopDP    = zigbeeRolloDP + '.stop'
            let stateDP         = zigbeeRolloDP + '.stateDP'
            createStateAsync(jarvisStopDP,           {read: true, write: true, name: "STOP für Jarvis", desc:'', type: "boolean", role: "", def: false });
            createStateAsync(stateDP,           {read: true, write: true, name: "STATE vom Rollo", desc:'', type: "string", role: "", def: '' });
            on({id: jarvisStopDP, change: "any"}, function (obj) {
                let value = obj.state.val;
                if(value){
                    let dp = getState(stateDP).val
                    setState(dp, 'STOP',true)
                    setTimeout(()=>{
                        setState(jarvisStopDP, false,true)
                    },500)
              Hohenbostler last edited by
              Hi zusammen. Ich bin ( glaube ich ) auf der V3.2 R17 . Und seit ewigen Monaten möchte ich mal wieder Geräte prüfen un importieren. Leider bekomme ich aber keine Geräte angezeigt.
              Die Konsole zeigt mir folgende Meldungen:
              Jemand eine Ahnung wo das Problem ist ? Den Roborock habe ich schon seit ewigkeiten nicht mehr. Theoretisch aber noch die als Seite im Jarvis von ihm.
              Vielleicht hat ja jemand eine Ahnung
                MCU @Hohenbostler last edited by MCU
                @hohenbostler
                Hab ich noch nicht gesehen. Im ioBroker.log ein Hinweis?
                Versuche
                • Sprache verstellen -> F2 - Einstellungen
                • Jarvis-Instanz neu starten
                • evtl auf der console ein Upload durchführen
                iob upload jarvis
                  Hohenbostler @MCU last edited by
                  @mcu
                  Danke für die Antwort.
                  Log ist fehlerfrei. Sprache mal testweise auf englisch gestellt. Instanz neugestartet. Problem besteht weiterhin.
                  Zurück auf deutsch. Instanz neu gestartet leider weiterhin das Problem.
                    @hohenbostler Dann versuch mal ein Upload
                    siehe oben
                    oder über die Adapter
                      @mcu
                      pload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                      upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                      upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                      upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                      upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                      upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                      upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                      upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                      upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                      upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                      upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index.html index.html text/html
                      upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                      upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/bootstrap.min.css lib/bootstrap.min.css text/css
                      upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/bootstrap.min.js lib/bootstrap.min.js application/javascript
                      upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/jquery-3.7.1.min.js lib/jquery-3.7.1.min.js application/javascript
                      upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                      Updating objects from io-package.json for adapter "jarvis" with version "3.2.0-rc.17"
                      upload [205] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/index.html index.html text/html
                      upload [200] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/apple-touch-icon-ipad.png jarvis/apple-touch-icon-ipad.png image/png
                      upload [150] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set1_1.1593123e.png jarvis/assets/weather_set1_1.1593123e.png image/png
                      upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set5_14.894b9d30.png jarvis/assets/weather_set5_14.894b9d30.png image/png
                      upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set5_6.2c556b53.png jarvis/assets/weather_set5_6.2c556b53.png image/png
                      upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icon-192x192.png jarvis/icon-192x192.png image/png
                      upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/drawable-hdpi/ic_launcher.png jarvis/icons/android/drawable-hdpi/ic_launcher.png image/png
                      upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/mipmap-hdpi/ic_launcher_foreground.png jarvis/icons/android/mipmap-hdpi/ic_launcher_foreground.png image/png
                      upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/mipmap-xxxhdpi/ic_launcher.png jarvis/icons/android/mipmap-xxxhdpi/ic_launcher.png image/png
                      upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/icon-1024x1024.png jarvis/icons/icon-1024x1024.png image/png
                      upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-29.png jarvis/icons/ios/AppIcon-29.png image/png
                      upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-60@3x~car.png jarvis/icons/ios/AppIcon-60@3x~car.png image/png
                      upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-83.5@2x~ipad.png jarvis/icons/ios/AppIcon-83.5@2x~ipad.png image/png
                      upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@2x.png jarvis/icons/ios/AppIcon@2x.png image/png
                      upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@2x~ipad.png jarvis/icons/ios/AppIcon@2x~ipad.png image/png
                      upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@3x.png jarvis/icons/ios/AppIcon@3x.png image/png
                      upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon~ios-marketing.png jarvis/icons/ios/AppIcon~ios-marketing.png image/png
                      upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon~ipad.png jarvis/icons/ios/AppIcon~ipad.png image/png
                      upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/README.txt jarvis/icons/web/README.txt text/plain
                      upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/apple-touch-icon.png jarvis/icons/web/apple-touch-icon.png image/png
                      upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/favicon.ico jarvis/icons/web/favicon.ico image/vnd.microsoft.icon
                      upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-192-maskable.png jarvis/icons/web/icon-192-maskable.png image/png
                      upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-192.png jarvis/icons/web/icon-192.png image/png
                      upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-512-maskable.png jarvis/icons/web/icon-512-maskable.png image/png
                      upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-512.png jarvis/icons/web/icon-512.png image/png
                      upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/index.html jarvis/index.html text/html
                      upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/app.hash.json jarvis/js/app.hash.json application/json
                      upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/app.licences.json jarvis/js/app.licences.json application/json
                      upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/index-259e1438.js jarvis/js/index-259e1438.js application/javascript
                      upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.hash.json js/app.hash.json application/json
                      upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.licences.json js/app.licences.json application/json
                      upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/user/example.js user/example.js application/javascript
                      Leider erfolglos. Geräte noch immer leer
                        @hohenbostler Hast du Systemupdates gemacht?
                        Zwischen dem Zeitpunkt wo noch alles funktioniert hat und jetzt
                          @mcu
                          Wie gesagt ich habe nach neuen Geräten seit Monaten wenn nicht sogar 1-2 Jahren eigentlich nicht geschaut.
                          Iobrokder updates in der Zeit einige.
                          PlatformBetriebssystem:linux
                          Architektur:x64
                          CPUs:4
                          Geschwindigkeit:3100 MHz
                          Modell:Intel(R) Core(TM) i3-8100T CPU @ 3.10GHz
                          RAM:8 GB
                          System-Betriebszeit:7 T. 02:54:38
                          Node.js:v20.19.2
                          Zeit:1751047866852
                          Zeitversatz:-120
                          NPM:10.8.2
                          Adapter-Anzahl:569
                          Datenträgergröße:29.4 GB
                          Freier Festplattenspeicher:15.3 GB
                          Aktive Instanzen:39
                          Pfad:/opt/iobroker/
                          Betriebszeit:7 T. 02:54:36
                          aktiv:true
                          _nodeCurrent:20.19.2
                          _nodeNewest:20.19.3
                          _nodeNewestNext:20.19.3
                          _npmCurrent:10.8.2
                          _npmNewest:10.8.2
                          _npmNewestNext:10.8.2
                            @hohenbostler Hast du mal ein komplett-Neustart vom System durchgeführt?
                            Wenn nein, dann vorher system updates machen, es gibt schon neuere Version
                            Du klickst hier?
                              @mcu
                              System sicher auch schon x mal neu gestartet
                              ja genau da und dann wird dort nichts angezeigt
                                @hohenbostler Hast du in der Zeit neue Adapter installiert? Ich vermute es hat mit irgendeiner nicht gesetzten Übersetzung zu tun.
                                i18n -> Internationalisierung - Übersetzung von Begriffen
                                  @mcu
                                  Hey sorry für die späte Antwort.
                                  Also sicherlich gibt es adapter die ich installiert habe. Wie gesagt das ist ja schon ewig so.
                                    @hohenbostler Dann bitte als Issue in github eintragen. Danke.
                                    • U
                                      uwe72 @MCU last edited by
                                      @mcu wollte fragen, ob man die Buttons von ihrer Bedeutung her "umdrehen" kann?
                                      d.h. aktuell geht "hoch" auf 100 und "runter" auf 0. Da es eine Markise ist, wäre anders herum intuitiver.
                                      Danke!
                                        MCU @uwe72 last edited by MCU
                                        @uwe72
                                        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/styles/blindlevelaction-rollladen/button-tauschen
                                        Bedeutung? Evtl mit min und max in Datenpunkt-Eigenschaft ändern
                                        92
                                        1815
                                        659046
