    4. Wir Empfehlen: Node.js 20.x :-)
      Thomas Braun Most Active @shellyrulestheworld last edited by
      @shellyrulestheworld sagte in Wir Empfehlen: Node.js 20.x 🙂:
      Nächstes Mal kommt wieder Code
      Dann kann ich ja beim nächsten Mal antworten.
        shellyrulestheworld @Thomas Braun last edited by
        @thomas-braun das Angebot nehme ich an. Irgendwie scheint es jetzt geklappt zu haben, oder?
        ioBroker nodejs fixer 2024-10-10
        You requested to install latest version from nodejs v20 tree.
        Your current setup is:
        /usr/bin/nodejs         v18.20.6
        /usr/bin/node           v18.20.6
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.4
        We found these nodejs versions available for installation:
        nodejs:
          Installed: 18.20.6-1nodesource1
          Candidate: 18.20.6-1nodesource1
          Version table:
         *** 18.20.6-1nodesource1 100
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        Nothing to do - Your installation is using the correct paths.
        You are running nodejs v18.20.6. Do you want to install latest version from nodejs v.20 tree?
        Press <y> to continue or any other key to quit
        Trying to fix your installation now. Please be patient.
        rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
        Virtualization: lxc
        Waiting for ioBroker to shut down - Give me a minute...
        Removing dfsg-nodejs
        *** These repos are active on your system:
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
        Reading package lists... Done
        *** Installing ca-certificates, curl and gnupg, just in case they are missing.
        *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
        deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
        Package: nodejs
        Pin: origin deb.nodesource.com
        Pin-Priority: 1001
        *** These repos are active after the adjustments:
        Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
        Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
        Get:6 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [10.4 kB]
        Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
        Fetched 22.5 kB in 1s (18.6 kB/s)
        Installing nodejs now!
        (Reading database ... 43850 files and directories currently installed.)
        Preparing to unpack .../nodejs_20.18.2-1nodesource1_amd64.deb ...
        Detected old npm client, removing...
        Unpacking nodejs (20.18.2-1nodesource1) over (18.20.6-1nodesource1) ...
        Setting up nodejs (20.18.2-1nodesource1) ...
        Processing triggers for man-db (2.11.2-2) ...
        *** You need to manually restart your container/virtual machine now! ***
        We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        peter@iobroker:~$
          Vermutlich. Container neugestartet?
          Dann nochmal
          iob nodejs-update
          Da sollte dann auch was passendes stehen.
            @thomas-braun genau. Ich habe den Container neu gestartet. jetzt kommt folgdendes:
            Recommended nodejs-version is: 20.18.2
            Checking your installation now. Please be patient!
            /usr/bin/nodejs         v20.18.2
            /usr/bin/node           v20.18.2
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Installed: 20.18.2-1nodesource1
              Candidate: 20.18.2-1nodesource1
              Version table:
             *** 20.18.2-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
            Nothing to do - Your version is the recommended one.
            ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
            *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
             *** DO NOT use 'nodejs-update' as part of a regular update process! ***
            peter@iobroker:~$
            Komischerweise steht im IOB folgendes:
            CPU: 14,58 %
            RAM: 28 %
            Betriebszeit: 0h
            Verfügbar: 7.0.6
            Installiert: 7.0.6
            Ereignisse: ⇥40 / ↦13
            Plattform: linux
            Betriebssystem: linux
            Architektur: x64
            CPUs: 4
            Geschwindigkeit: 2799 MHz
            Modell: Intel(R) Celeron(R) N5105 @ 2.00GHz
            RAM: 8 GB
            System-Betriebszeit: 00:00:48
            Node.js: v18.20.6
            time: 1738393951080
            timeOffset: -60
            NPM: 10.8.2
            Adapter-Anzahl: 559
            Datenträgergröße: 13.7 GB
            Freier Festplattenspeicher: 5.3 GB
            Aktive Instanzen: 7
            Pfad: /opt/iobroker/
            Betriebszeit: 00:00:43
              Alles richtig. ioBroker-GUI neuladen.
                @thomas-braun perfekt. Wie immer: herzlichen Dank für deinen Support 🙂
                  Maddin77 last edited by
                  Servus zusammen
                  hoffe ich darf hier bissi Fragen
                  ich bin ziemlich neu in der Welt
                  und IOB möchte gerne das ich Node update, allerdings habe ich ziemlich keine Ahnung davon
                  bei mir läuft IOB auf einem Synology NAS als Container
                  soll ich im NAS Terminal updaten oder im IOB
                  was wäre zu bevorzugen?
                  danke schon mal für eure hilfe
                    Thomas Braun Most Active @Maddin77 last edited by
                    @maddin77
                    Von welcher Version auf welche neue Version?
                      Maddin77 @Thomas Braun last edited by
                      @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
                      @maddin77
                      im Terminal wird mir das angezeigt
                      /opt/iobroker$ node -v
                      v18.20.3
                      /opt/iobroker$
                      manche Adapter schreiben einfach >20
                        @maddin77
                        Dann roll einen aktuellen Container drüber.
                          @maddin77
                          ist das dann mit
                          sudo apt-get install -y nodejs
                            @maddin77
                            Nein. Du nimmst das aktuelle Container-Image und tauschst die Umgebung für den ioBroker aus.
                              o-Gott
                              da bin ich aktuell etwas überfordert damit, sorry
                              Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                                @maddin77
                                Gibt Anleitungen dazu.
                                Du musst deine Kiste ja verwalten und pflegen können.
                                  theoretisch wäre das schön, ja
                                  aber das meiste macht man selten.
                                  ich hoffe immer das Adapter Update im IOB langt.......
                                  aber so ein komplett hab ich immer zu viel angst, das danach was nicht mehr geht und ich nicht weiter komme.
                                  aber dann werde ich wohl mal lesen und suchen müssen
                                  danke
                                    @maddin77 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                    Nein, tut es nicht.
                                    Ja. Irgendwie haste das Ding ja auch drauf bekommen.
                                    • Samson71
                                      Samson71 Global Moderator @Maddin77 last edited by
                                      Dann werfe ich mal die ernsthafte Frage in den Raum warum man dann Container/Docker-Umgebungen nutzt anstatt das System nativ mit Debian auf einem Raspi oder Mini-PC zu betreiben.
                                      M 1 Reply Last reply Reply Quote 2
                                        Maddin77 @Samson71 last edited by
                                        @samson71 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                        weil man von beiden keine Ahnung hat, ein NAS im Haus war für Datensicherung.....
                                        und so ist eins zum anderen gekommen.....
                                        und irgendwie mit etwas Hilfe von Freunden und viel Lesen ist es dann irgendwann letztes jahr gelaufen.
                                        Aber ich frag lieber bevor ich was kaputt mache oder einen umständlichen Weg gehe.
                                        Mehr als zugeben das ich mich nicht gut auskenne, kann ich nun mal nicht.
                                        Werde aber wahrscheinlich nicht der einzigste sein 😖
                                        und ich habe auch keine Lust meine ganzen Daten zu verlieren nur weil ich zu stolz bin zu fragen.
                                        hoffe das ist okay
                                        Samson71 ? 2 Replies Last reply Reply Quote 0
                                        • Samson71
                                          Sehr weise 😉
                                          Absolut nicht. Ich bekenne ioBroker selber auf einer Syno unter Docker genutzt zu haben, bin aber davon aber weg weil ich mit Docker prinzipiell irgendwie nicht warm geworden bin.
                                          Das wäre wohl das dümmste was man tun könnte
                                          hoffe das ist okay
                                          Selbstverständlich
                                            A Former User @Maddin77 last edited by
                                            @maddin77
                                            dass du fragst, und sagst, wie dein Wissensstand ist, ist doch super!
                                            Viele markieren hier den Helden, und machen vieles falsch.
                                            Zum upgraden des Dockers ist zuerst das Backup wichtig, hier am besten einmal mit dem Backitup-Adapter den iobroker sichern auf ein anderes Device oder auf dem Nas in einen anderen Ordner.
                                            Dann stoppst du den Container und kopierst das komplette iobroker-Verzeichnis unter /docker zur Sicherheit
                                            Dann erst die aktuelle Docker-Version mit Node 20 (sollte was mit V10 sein) pullen.
                                            Nutzt du Portainer? Welches Nas? synology?
                                            M 2 Replies Last reply Reply Quote 2
                                            237
                                            71529
