    4. Wir Empfehlen: Node.js 20.x :-)
      shellyrulestheworld @Thomas Braun last edited by
      @thomas-braun genau. Ich habe den Container neu gestartet. jetzt kommt folgdendes:
      ioBroker nodejs fixer 2024-10-10
      Recommended nodejs-version is: 20.18.2
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      Nothing to do - Your installation is using the correct paths.
      Nothing to do - Your version is the recommended one.
      ***You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands. ***
      *** DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation! ***
       *** DO NOT use 'nodejs-update' as part of a regular update process! ***
      peter@iobroker:~$
      Komischerweise steht im IOB folgendes:
      CPU: 14,58 %
      RAM: 28 %
      Betriebszeit: 0h
      Verfügbar: 7.0.6
      Installiert: 7.0.6
      Ereignisse: ⇥40 / ↦13
      Plattform: linux
      Betriebssystem: linux
      Architektur: x64
      CPUs: 4
      Geschwindigkeit: 2799 MHz
      Modell: Intel(R) Celeron(R) N5105 @ 2.00GHz
      RAM: 8 GB
      System-Betriebszeit: 00:00:48
      Node.js: v18.20.6
      time: 1738393951080
      timeOffset: -60
      NPM: 10.8.2
      Adapter-Anzahl: 559
      Datenträgergröße: 13.7 GB
      Freier Festplattenspeicher: 5.3 GB
      Aktive Instanzen: 7
      Pfad: /opt/iobroker/
      Betriebszeit: 00:00:43
        Thomas Braun Most Active @shellyrulestheworld last edited by
        @shellyrulestheworld sagte in Wir Empfehlen: Node.js 20.x 🙂:
        Alles richtig. ioBroker-GUI neuladen.
          @thomas-braun perfekt. Wie immer: herzlichen Dank für deinen Support 🙂
            Maddin77 last edited by
            Servus zusammen
            hoffe ich darf hier bissi Fragen
            ich bin ziemlich neu in der Welt
            und IOB möchte gerne das ich Node update, allerdings habe ich ziemlich keine Ahnung davon
            bei mir läuft IOB auf einem Synology NAS als Container
            soll ich im NAS Terminal updaten oder im IOB
            was wäre zu bevorzugen?
            danke schon mal für eure hilfe
              Thomas Braun Most Active @Maddin77 last edited by
              @maddin77
              Von welcher Version auf welche neue Version?
                Maddin77 @Thomas Braun last edited by
                @thomas-braun sagte in Wir Empfehlen: Node.js 20.x 🙂:
                @maddin77
                im Terminal wird mir das angezeigt
                /opt/iobroker$ node -v
                v18.20.3
                /opt/iobroker$
                manche Adapter schreiben einfach >20
                  @maddin77
                  Dann roll einen aktuellen Container drüber.
                    @maddin77
                    ist das dann mit
                    sudo apt-get install -y nodejs
                      @maddin77
                      Nein. Du nimmst das aktuelle Container-Image und tauschst die Umgebung für den ioBroker aus.
                        o-Gott
                        da bin ich aktuell etwas überfordert damit, sorry
                        Thomas Braun Samson71 2 Replies Last reply Reply Quote 0
                          @maddin77
                          Gibt Anleitungen dazu.
                          Du musst deine Kiste ja verwalten und pflegen können.
                            theoretisch wäre das schön, ja
                            aber das meiste macht man selten.
                            ich hoffe immer das Adapter Update im IOB langt.......
                            aber so ein komplett hab ich immer zu viel angst, das danach was nicht mehr geht und ich nicht weiter komme.
                            aber dann werde ich wohl mal lesen und suchen müssen
                            danke
                              @maddin77 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                              Nein, tut es nicht.
                              Ja. Irgendwie haste das Ding ja auch drauf bekommen.
                              • Samson71
                                Samson71 Global Moderator @Maddin77 last edited by
                                Dann werfe ich mal die ernsthafte Frage in den Raum warum man dann Container/Docker-Umgebungen nutzt anstatt das System nativ mit Debian auf einem Raspi oder Mini-PC zu betreiben.
                                M 1 Reply Last reply Reply Quote 2
                                  Maddin77 @Samson71 last edited by
                                  @samson71 sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                  weil man von beiden keine Ahnung hat, ein NAS im Haus war für Datensicherung.....
                                  und so ist eins zum anderen gekommen.....
                                  und irgendwie mit etwas Hilfe von Freunden und viel Lesen ist es dann irgendwann letztes jahr gelaufen.
                                  Aber ich frag lieber bevor ich was kaputt mache oder einen umständlichen Weg gehe.
                                  Mehr als zugeben das ich mich nicht gut auskenne, kann ich nun mal nicht.
                                  Werde aber wahrscheinlich nicht der einzigste sein 😖
                                  und ich habe auch keine Lust meine ganzen Daten zu verlieren nur weil ich zu stolz bin zu fragen.
                                  hoffe das ist okay
                                  Samson71 ? 2 Replies Last reply Reply Quote 0
                                  • Samson71
                                    Sehr weise 😉
                                    Absolut nicht. Ich bekenne ioBroker selber auf einer Syno unter Docker genutzt zu haben, bin aber davon aber weg weil ich mit Docker prinzipiell irgendwie nicht warm geworden bin.
                                    Das wäre wohl das dümmste was man tun könnte
                                    hoffe das ist okay
                                    Selbstverständlich
                                      A Former User @Maddin77 last edited by
                                      @maddin77
                                      dass du fragst, und sagst, wie dein Wissensstand ist, ist doch super!
                                      Viele markieren hier den Helden, und machen vieles falsch.
                                      Zum upgraden des Dockers ist zuerst das Backup wichtig, hier am besten einmal mit dem Backitup-Adapter den iobroker sichern auf ein anderes Device oder auf dem Nas in einen anderen Ordner.
                                      Dann stoppst du den Container und kopierst das komplette iobroker-Verzeichnis unter /docker zur Sicherheit
                                      Dann erst die aktuelle Docker-Version mit Node 20 (sollte was mit V10 sein) pullen.
                                      Nutzt du Portainer? Welches Nas? synology?
                                      M 2 Replies Last reply Reply Quote 2
                                        Maddin77 @Guest last edited by
                                        @neuschwansteini sagte in Wir Empfehlen: Node.js 20.x 🙂:
                                        danke
                                        Zum upgraden des Dockers ist zuerst das Backup wichtig, hier am besten einmal mit dem Backitup-Adapter den >iobroker sichern auf ein anderes Device oder auf dem Nas in einen anderen Ordner.
                                        das hab ich laufen auf FTP gesichert IOB/JAVA/Zigbee hab ich als Sicherung täglich
                                        auch Container exportiert komplett und Einstellungen extra auch skripte exportiert
                                        okay suche ich und versuche das
                                        Image Downloaden meinst damit
                                        Portainer sagt mir nichts, Container Manager nennt sich das auf dem NAS
                                        ich habe eine Synology DS224+ mit Speicher update auf 16
                                          unter FileStation?
                                            @maddin77
                                            Bitte die Grundlagen in einem eigenen Thread erwerben, das ist hier komplett am Thema vorbei.
                                            1.2k
                                            237
                                            71495
