    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      A Former User @Lucky_ESA last edited by
      @lucky_esa
      nach 2 Tagen offline von App(deinstalliert), Maeher aus, Adapter gestoppt, heute auf id.worx.com eingeloggt, alles gut.
      App installiert, angemeldet, sofort "Verbindung zu langsam".
      Adapter gestartet, und wieder gestoppt.
      2025-06-28 10:00:31.422  - info: host.iobroker instance system.adapter.worx.0 in version "3.2.5" (non-npm: iobroker-community-adapters/ioBroker.worx) started with pid 806110
      2025-06-28 10:00:32.807  - info: worx.0 (806110) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v22.17.0, js-controller: 7.0.7
      2025-06-28 10:00:32.883  - info: worx.0 (806110) Login to worx
      2025-06-28 10:00:32.883  - info: worx.0 (806110) Start login
      2025-06-28 10:00:33.083  - error: worx.0 (806110) AxiosError: Request failed with status code 429
      2025-06-28 10:00:33.084  - info: worx.0 (806110) The maximum number of requests has been reached!
      2025-06-28 10:00:33.084  - error: worx.0 (806110) Login Header: {"date":"Sat, 28 Jun 2025 08:00:33 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956ba6ae0b433a5e-FRA","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
      2025-06-28 10:00:33.084  - error: worx.0 (806110) "429 TOO MANY REQUESTS"
      • EvilEls
        EvilEls @JoergK 0 last edited by
        @joergk-0
        Neuer Account bringt nichts. Hab es versucht.
        Nach 4 Tagen selbes Problem.
        ? L 2 Replies Last reply Reply Quote 0
          A Former User @EvilEls last edited by
          @evilels
          nach ein paar Wochen ist Gras ueber den Worx gewachsen... 😄 😄 😄
          • Nasenbohrer
            Nasenbohrer @Dr. Bakterius last edited by
            @dr-bakterius
            https://eu.worx.com/de-de/support-fuer-landroid/
              Lucky_ESA Developer Most Active @EvilEls last edited by
              @evilels sagte in Adapter Worx Landroid v3.x.x:
              @joergk-0
              Hattest du in den 4 Tagen den Adapter an gehabt?
              EvilEls 1 Reply Last reply Reply Quote 0
                Lucky_ESA Developer Most Active @Guest last edited by
                @neuschwansteini Mit der aktuellen GIT Version? Ich meine nicht de 3.2.5
                Wenn die Zahlen hier stimmen, dann ist man für > 50 Tage gesperrt. Hier sollte jetzt mal der Support von Worx aktiv werden.
                Gruß//Lucky
                  Matt77CHE @Nasenbohrer last edited by Matt77CHE
                  @heiner-kappenhagen sagte in Adapter Worx Landroid v3.x.x:
                  @dr-bakterius
                  Was soll man da genau machen? - Telefon-Support nur mo-fr zu Bürozeiten und email Support gibt es auch nicht.
                  Sobald meiner die Grätsche macht, bin ich weg von Worx.....
                  Nasenbohrer 1 Reply Last reply Reply Quote 0
                    Lucky_ESA Developer Most Active @JoergK 0 last edited by
                    @joergk-0 sagte in Adapter Worx Landroid v3.x.x:
                    "retry-after":"5643575","x-ratelimit-throttle":"true"
                    Wo genau wird das ausgegeben?
                      JoergK 0 @Lucky_ESA last edited by
                      @lucky_esa said in Adapter Worx Landroid v3.x.x:
                      Log-Eintrag des Worx-Adapters.
                      Hier die gesamte Zeile:
                      Device Header: {"date":"Fri, 27 Jun 2025 16:20:24 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","server":"nginx","retry-after":"5643575","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
                      • Nasenbohrer
                        Nasenbohrer @Matt77CHE last edited by
                        @matt77che
                        Versuch mal diese (ist die Adresse aus der Antwort vom Support)
                        support@positecgroup.com.hs-inbox.com
                          @lucky_esa
                          Hatte gestern abends von git neu installiert, heute Morgen die Daten eingegeben und den Adapter gestartet.
                          • Dr. Bakterius
                            Dr. Bakterius Most Active @JoergK 0 last edited by
                            Ich habe keinen Device Header, sondern nur Token Header und Login Header und die sehen so aus:
                            Token Header: {"date":"Sat, 28 Jun 2025 07:10:48 GMT","content-type":"text/plain","content-length":"21","connection":"close","cf-ray":"956b5dd25ab96c45-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=":443"; ma=86400"}
                            Ich sehe also nicht wie lange ich gesperrt bin.
                            Das Startlog des Adapters (GIT-Version) sieht komplett so aus:
                            2025-06-28 12:48:25.265 - info: worx.0 (5394) Got terminate signal TERMINATE_YOURSELF
                            2025-06-28 12:48:25.266 - info: worx.0 (5394) terminating
                            2025-06-28 12:48:25.267 - debug: worx.0 (5394) Plugin sentry destroyed
                            2025-06-28 12:48:25.267 - info: worx.0 (5394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2025-06-28 12:48:25.768 - info: worx.0 (5394) terminating
                            2025-06-28 12:48:29.584 - debug: worx.0 (5604) Redis Objects: Use Redis connection: 127.0.0.1:6379
                            2025-06-28 12:48:29.593 - debug: worx.0 (5604) Objects client ready ... initialize now
                            2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create System PubSub Client
                            2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create User PubSub Client
                            2025-06-28 12:48:29.629 - debug: worx.0 (5604) Objects client initialize lua scripts
                            2025-06-28 12:48:29.631 - debug: worx.0 (5604) Objects connected to redis: 127.0.0.1:6379
                            2025-06-28 12:48:29.637 - debug: worx.0 (5604) Redis States: Use Redis connection: 127.0.0.1:9000
                            2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create System PubSub Client
                            2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create User PubSub Client
                            2025-06-28 12:48:29.716 - debug: worx.0 (5604) States connected to redis: 127.0.0.1:9000
                            2025-06-28 12:48:29.736 - debug: worx.0 (5604) Plugin sentry Initialize Plugin (enabled=true)
                            2025-06-28 12:48:30.002 - info: worx.0 (5604) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
                            2025-06-28 12:48:30.066 - debug: worx.0 (5604) Use old blocking data!
                            2025-06-28 12:48:30.114 - info: worx.0 (5604) Reset Login counter. Restarting now!
                            2025-06-28 12:48:30.119 - info: worx.0 (5604) Got terminate signal TERMINATE_YOURSELF
                            2025-06-28 12:48:30.120 - info: worx.0 (5604) terminating
                            2025-06-28 12:48:30.120 - debug: worx.0 (5604) Plugin sentry destroyed
                            2025-06-28 12:48:30.120 - info: worx.0 (5604) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2025-06-28 12:48:30.122 - debug: worx.0 (5604) User and password have not been changed!
                            2025-06-28 12:48:30.122 - debug: worx.0 (5604) Server have not been changed!
                            2025-06-28 12:48:30.152 - info: worx.0 (5604) Login to worx
                            2025-06-28 12:48:30.156 - debug: worx.0 (5604) Session value: 0
                            2025-06-28 12:48:30.156 - info: worx.0 (5604) Start login
                            2025-06-28 12:48:30.417 - error: worx.0 (5604) AxiosError: Request failed with status code 429
                            2025-06-28 12:48:30.417 - info: worx.0 (5604) The maximum number of requests has been reached!
                            2025-06-28 12:48:30.417 - error: worx.0 (5604) Login Header: {"date":"Sat, 28 Jun 2025 10:48:30 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cb50b105b9b-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
                            2025-06-28 12:48:30.417 - error: worx.0 (5604) "429 TOO MANY REQUESTS"
                            2025-06-28 12:48:30.621 - info: worx.0 (5604) terminating
                            2025-06-28 12:48:34.342 - debug: worx.0 (5661) Redis Objects: Use Redis connection: 127.0.0.1:6379
                            2025-06-28 12:48:34.353 - debug: worx.0 (5661) Objects client ready ... initialize now
                            2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create System PubSub Client
                            2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create User PubSub Client
                            2025-06-28 12:48:34.419 - debug: worx.0 (5661) Objects client initialize lua scripts
                            2025-06-28 12:48:34.423 - debug: worx.0 (5661) Objects connected to redis: 127.0.0.1:6379
                            2025-06-28 12:48:34.431 - debug: worx.0 (5661) Redis States: Use Redis connection: 127.0.0.1:9000
                            2025-06-28 12:48:34.488 - debug: worx.0 (5661) States create System PubSub Client
                            2025-06-28 12:48:34.489 - debug: worx.0 (5661) States create User PubSub Client
                            2025-06-28 12:48:34.521 - debug: worx.0 (5661) States connected to redis: 127.0.0.1:9000
                            2025-06-28 12:48:34.542 - debug: worx.0 (5661) Plugin sentry Initialize Plugin (enabled=true)
                            2025-06-28 12:48:34.724 - info: worx.0 (5661) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
                            2025-06-28 12:48:34.747 - debug: worx.0 (5661) Use old blocking data!
                            2025-06-28 12:48:34.756 - debug: worx.0 (5661) User and password have not been changed!
                            2025-06-28 12:48:34.756 - debug: worx.0 (5661) Server have not been changed!
                            2025-06-28 12:48:34.782 - info: worx.0 (5661) Login to worx
                            2025-06-28 12:48:34.787 - debug: worx.0 (5661) Session value: 0
                            2025-06-28 12:48:34.788 - info: worx.0 (5661) Start login
                            2025-06-28 12:48:35.051 - error: worx.0 (5661) AxiosError: Request failed with status code 429
                            2025-06-28 12:48:35.051 - info: worx.0 (5661) The maximum number of requests has been reached!
                            2025-06-28 12:48:35.051 - error: worx.0 (5661) Login Header: {"date":"Sat, 28 Jun 2025 10:48:34 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cd1ff6e3264-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
                            2025-06-28 12:48:35.051 - error: worx.0 (5661) "429 TOO MANY REQUESTS"
                              @neuschwansteini sagte in Adapter Worx Landroid v3.x.x:
                              @lucky_esa
                              Und läuft?
                                A Former User @Lucky_ESA last edited by A Former User
                                @lucky_esa
                                Nein, sofort wieder Error 429
                                Hatte vorher die App installiert und da kam auch zu langsam…
                                Also entweder noch gesperrt oder die App sorgt für die Sperre..
                                Ich ruf da am Montag mal an.. hab n Ansprechpartner gefunden…
                                  PRO84 @Guest last edited by
                                  @neuschwansteini
                                  Ich habe bereits mehrfach mit dem Support gesprochen. Ohne jeden Erfolg!
                                  Angeblich bin ich mit dem techn. Support verbunden, aber bei jeder Kleinigkeit musste bei Kollegen nachgefragt werden. Dadurch hat sich aber die Antwort nicht geändert...
                                  Ich bekomme immer nur die Antwort das ich 24 Std. warten soll.
                                  Warte jetzt aber schon 48 Std. und kann mich immer noch nicht einloggen...
                                  • N
                                    nullfreizeit last edited by nullfreizeit
                                    Habe das gleiche Problem - nie wieder Worx!!! Echt nur Probleme. Mit dem Mäher, der App und dem Support.
                                    • Dr. Bakterius
                                      Dr. Bakterius Most Active last edited by
                                      Die sollen den Account auf Kundenwunsch wenigsten wieder freischalten damit man überhaupt was machen kann. Einfach stur für eine unbestimmte Zeitspanne den Account ohne Vorwarnung zu sperren ist eine Frechheit! Vor allem wenn man nichts falsch gemacht hat.
                                        Powertrain01 last edited by Powertrain01
                                        Hallo zusammen ich hab nun mehrfach iob update /iob upgrade /iob fix gemach
                                        auch mehrfach versucht npm install Axios alles schein ohne Probleme gelaufen zu sein.
                                        aber beim Update des Works Adapter bekomme ich immer noch die Meldung, dass Axios nicht gefunden wird. was kann ich noch tun dammit ich den Adapter upgedatet bekomme.
                                          JoergK 0 @Dr. Bakterius last edited by
                                          @dr-bakterius said in Adapter Worx Landroid v3.x.x:
                                          Ich würde mal vermuten daß Deine Sperrzeit in "ma=86400" steht, also die üblichen 24h
                                          • Dr. Bakterius
                                            Das habe ich mir auch gedacht. Leider war die Sperre nach 25 Stunden immer noch aktiv. Ich werde jetzt zusätzlich den Roboter ausschalten. Dann kann wirklich nichts mehr auf meinen Account zugreifen versuchen.
                                            1.0k
                                            788
                                            125018
