    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
    • Dr. Bakterius
      Dr. Bakterius Most Active @JoergK 0 last edited by
      @joergk-0 sagte in Adapter Worx Landroid v3.x.x:
      Device Header: {"date":"Fri, 27 Jun 2025 16:20:24 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","server":"nginx","retry-after":"5643575","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
      Ich habe keinen Device Header, sondern nur Token Header und Login Header und die sehen so aus:
      Token Header: {"date":"Sat, 28 Jun 2025 07:10:48 GMT","content-type":"text/plain","content-length":"21","connection":"close","cf-ray":"956b5dd25ab96c45-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=":443"; ma=86400"}
      Ich sehe also nicht wie lange ich gesperrt bin.
      Das Startlog des Adapters (GIT-Version) sieht komplett so aus:
      2025-06-28 12:48:25.265 - info: worx.0 (5394) Got terminate signal TERMINATE_YOURSELF
      2025-06-28 12:48:25.266 - info: worx.0 (5394) terminating
      2025-06-28 12:48:25.267 - debug: worx.0 (5394) Plugin sentry destroyed
      2025-06-28 12:48:25.267 - info: worx.0 (5394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-28 12:48:25.768 - info: worx.0 (5394) terminating
      2025-06-28 12:48:29.584 - debug: worx.0 (5604) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2025-06-28 12:48:29.593 - debug: worx.0 (5604) Objects client ready ... initialize now
      2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create System PubSub Client
      2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create User PubSub Client
      2025-06-28 12:48:29.629 - debug: worx.0 (5604) Objects client initialize lua scripts
      2025-06-28 12:48:29.631 - debug: worx.0 (5604) Objects connected to redis: 127.0.0.1:6379
      2025-06-28 12:48:29.637 - debug: worx.0 (5604) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create System PubSub Client
      2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create User PubSub Client
      2025-06-28 12:48:29.716 - debug: worx.0 (5604) States connected to redis: 127.0.0.1:9000
      2025-06-28 12:48:29.736 - debug: worx.0 (5604) Plugin sentry Initialize Plugin (enabled=true)
      2025-06-28 12:48:30.002 - info: worx.0 (5604) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
      2025-06-28 12:48:30.066 - debug: worx.0 (5604) Use old blocking data!
      2025-06-28 12:48:30.114 - info: worx.0 (5604) Reset Login counter. Restarting now!
      2025-06-28 12:48:30.119 - info: worx.0 (5604) Got terminate signal TERMINATE_YOURSELF
      2025-06-28 12:48:30.120 - info: worx.0 (5604) terminating
      2025-06-28 12:48:30.120 - debug: worx.0 (5604) Plugin sentry destroyed
      2025-06-28 12:48:30.120 - info: worx.0 (5604) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-28 12:48:30.122 - debug: worx.0 (5604) User and password have not been changed!
      2025-06-28 12:48:30.122 - debug: worx.0 (5604) Server have not been changed!
      2025-06-28 12:48:30.152 - info: worx.0 (5604) Login to worx
      2025-06-28 12:48:30.156 - debug: worx.0 (5604) Session value: 0
      2025-06-28 12:48:30.156 - info: worx.0 (5604) Start login
      2025-06-28 12:48:30.417 - error: worx.0 (5604) AxiosError: Request failed with status code 429
      2025-06-28 12:48:30.417 - info: worx.0 (5604) The maximum number of requests has been reached!
      2025-06-28 12:48:30.417 - error: worx.0 (5604) Login Header: {"date":"Sat, 28 Jun 2025 10:48:30 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cb50b105b9b-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
      2025-06-28 12:48:30.417 - error: worx.0 (5604) "429 TOO MANY REQUESTS"
      2025-06-28 12:48:30.621 - info: worx.0 (5604) terminating
      2025-06-28 12:48:34.342 - debug: worx.0 (5661) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2025-06-28 12:48:34.353 - debug: worx.0 (5661) Objects client ready ... initialize now
      2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create System PubSub Client
      2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create User PubSub Client
      2025-06-28 12:48:34.419 - debug: worx.0 (5661) Objects client initialize lua scripts
      2025-06-28 12:48:34.423 - debug: worx.0 (5661) Objects connected to redis: 127.0.0.1:6379
      2025-06-28 12:48:34.431 - debug: worx.0 (5661) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-06-28 12:48:34.488 - debug: worx.0 (5661) States create System PubSub Client
      2025-06-28 12:48:34.489 - debug: worx.0 (5661) States create User PubSub Client
      2025-06-28 12:48:34.521 - debug: worx.0 (5661) States connected to redis: 127.0.0.1:9000
      2025-06-28 12:48:34.542 - debug: worx.0 (5661) Plugin sentry Initialize Plugin (enabled=true)
      2025-06-28 12:48:34.724 - info: worx.0 (5661) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
      2025-06-28 12:48:34.747 - debug: worx.0 (5661) Use old blocking data!
      2025-06-28 12:48:34.756 - debug: worx.0 (5661) User and password have not been changed!
      2025-06-28 12:48:34.756 - debug: worx.0 (5661) Server have not been changed!
      2025-06-28 12:48:34.782 - info: worx.0 (5661) Login to worx
      2025-06-28 12:48:34.787 - debug: worx.0 (5661) Session value: 0
      2025-06-28 12:48:34.788 - info: worx.0 (5661) Start login
      2025-06-28 12:48:35.051 - error: worx.0 (5661) AxiosError: Request failed with status code 429
      2025-06-28 12:48:35.051 - info: worx.0 (5661) The maximum number of requests has been reached!
      2025-06-28 12:48:35.051 - error: worx.0 (5661) Login Header: {"date":"Sat, 28 Jun 2025 10:48:34 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cd1ff6e3264-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
      2025-06-28 12:48:35.051 - error: worx.0 (5661) "429 TOO MANY REQUESTS"
        Lucky_ESA Developer Most Active @Guest last edited by
        @neuschwansteini sagte in Adapter Worx Landroid v3.x.x:
        @lucky_esa
        Hatte gestern abends von git neu installiert, heute Morgen die Daten eingegeben und den Adapter gestartet.
        Und läuft?
          A Former User @Lucky_ESA last edited by A Former User
          @lucky_esa
          Nein, sofort wieder Error 429
          Hatte vorher die App installiert und da kam auch zu langsam…
          Also entweder noch gesperrt oder die App sorgt für die Sperre..
          Ich ruf da am Montag mal an.. hab n Ansprechpartner gefunden…
            PRO84 @Guest last edited by
            @neuschwansteini
            Ich habe bereits mehrfach mit dem Support gesprochen. Ohne jeden Erfolg!
            Angeblich bin ich mit dem techn. Support verbunden, aber bei jeder Kleinigkeit musste bei Kollegen nachgefragt werden. Dadurch hat sich aber die Antwort nicht geändert...
            Ich bekomme immer nur die Antwort das ich 24 Std. warten soll.
            Warte jetzt aber schon 48 Std. und kann mich immer noch nicht einloggen...
            • N
              nullfreizeit last edited by nullfreizeit
              Habe das gleiche Problem - nie wieder Worx!!! Echt nur Probleme. Mit dem Mäher, der App und dem Support.
              • Dr. Bakterius
                Dr. Bakterius Most Active last edited by
                Die sollen den Account auf Kundenwunsch wenigsten wieder freischalten damit man überhaupt was machen kann. Einfach stur für eine unbestimmte Zeitspanne den Account ohne Vorwarnung zu sperren ist eine Frechheit! Vor allem wenn man nichts falsch gemacht hat.
                  Powertrain01 last edited by Powertrain01
                  Hallo zusammen ich hab nun mehrfach iob update /iob upgrade /iob fix gemach
                  auch mehrfach versucht npm install Axios alles schein ohne Probleme gelaufen zu sein.
                  aber beim Update des Works Adapter bekomme ich immer noch die Meldung, dass Axios nicht gefunden wird. was kann ich noch tun dammit ich den Adapter upgedatet bekomme.
                    JoergK 0 @Dr. Bakterius last edited by
                    @dr-bakterius said in Adapter Worx Landroid v3.x.x:
                    Ich würde mal vermuten daß Deine Sperrzeit in "ma=86400" steht, also die üblichen 24h
                    • Dr. Bakterius
                      Das habe ich mir auch gedacht. Leider war die Sperre nach 25 Stunden immer noch aktiv. Ich werde jetzt zusätzlich den Roboter ausschalten. Dann kann wirklich nichts mehr auf meinen Account zugreifen versuchen.
                        saeft_2003 Most Active last edited by
                        Ich bin auch betroffen... Das Problem ist das ich es nicht hinbekomme 😞
                        Ich hatte jetzt schon mehrfach 24 Stunden gewartet app und adapter sind gelöscht. Nach 24 Stunden komm ich wieder auf id.worx.com dann installiere ich die app und will mich anmelden --> langsamer!
                        Langsam bekomme ich einen dicken Hals. Habt ihr noch Tipps was ich noch tun kann?
                          Lucky_ESA Developer Most Active @saeft_2003 last edited by
                          @saeft_2003 Wenn man hier liest dann ist es klar, dass das Login vielleicht nach 24h freigegeben wird aber der nächste API Abruf ist für 72 Tage blockiert. Das schafft man eigentlich nur mit einer DDoS Attacke. Wann hat es dich denn erwischt??? Hast du noch das Logfile? Bei so einer Sperre muss das komplett rote Einträge haben.
                          Die aktuelle Version 3.2.6 ist bald verfügbar. Habe dort zur Sicherheit ein RateLimit hinzugefügt. Allerdings nur für die API Abfrage und nicht für MQTT...Kommt noch...
                          Gruß//Lucky
                          pajda 1 Reply Last reply Reply Quote 0
                          • pajda
                            pajda @Lucky_ESA last edited by
                            @lucky_esa
                            Hallo an alle ich gehöre auch zu Betroffenen
                            Meine frage haben alle Betroffenen auch FindMyLandroid
                            WA0862 verbaut oder ist das nur bei mir so da ich mir vorstellen könnte das das den fehler machen könnte "FindMyLandroid
                            WA0862"
                            Lg.
                              martenn @pajda last edited by
                              Ich bin auch seit 3 Tagen von dem Problem betroffen, habe meinen Adapater seit Freitag deaktiviert und auch auf dem Smartphone habe ich die App nicht aktiv genutzt. Trotzdem bekomme ich noch immer die Fehlermeldung, dass ich zu viele Anfragen stellen würde.
                              Ich habe gestern abend allerdings einen interessanten Beitrag in einer Worx-Landroid-Gruppe auf Facebook gelesen. Dort hat ein User von den identischen Problemen berichtet und er nutzt keine Smarthome-Integrationen, sondern nur die native App von Worx.
                              Es scheint also offenbar ein generelles Problem bei Worx zu geben. Irgendwer schrieb in der FB-Gruppe auch, dass die wohl seit Tagen mit DDOS-Attacken zu kämpfen haben und das ggf. deren Abwehrmaßnahmen zu unbeabsichtigten Blocks fürhren.
                                Wuschl @martenn last edited by Wuschl
                                @martenn Ich bin mittlerweile überzeugt davon daß es ein Problem bei Worx ist. Mein Adapter läuft absolut zuverlässig 3.2.5.
                                Ich hatte mittlerweile die 2. Sperre diese Woche, aber erst nachdem ich die App geöffnet hatte. Wir haben auf unseren Grundstück 2 Worx laufen, mit 2 verschiedenen Accounts. Einer wird nur über den Adapter gesteuert, der andere nur über die App.
                                Einmal die App aufgerufen, zack, beide gesperrt... gestern Nachmittag, dann kam die Fehlermeldung 429 im Adapter, aber ich konnte den einen Worx über den Adapter um 20 Uhr ganz normal starten. Ich habe nichts gestoppt oder gelöscht, die App und der Adapter liefen ganz normal weiter
                                Klar, laufen über die selbe Internet IP.
                                • Q
                                  quinti @Wuschl last edited by quinti
                                  Zitat aus facebook gruppenbeitrag:
                                  Das Problem wird wohl durch verschärfte Drosselungsmaßnahmen seitens Positec hervorgerufen.
                                  Diese sind laut Entwicklern aktuell notwendig, da scheinbar seit über einer Woche DDOS-Angriffe gegen die Worx-Cloud gefahren werden.
                                  Hier die orginale Aussage:
                                  "We're having issues with a (probably) involuntary DDOS of MQTT connect packages in the last 12 days. ...
                                  The DDoS issues I've mentioned … are getting worse. We've deployed a more aggressive throttling mechanics to contain the issue, including disabling user accounts for longer periods. "
                                  Die verschärften Drosselungsmaßnahmen scheinen Nebenwirkungen zu haben, besonders häufig werden aktuell Probleme im Zusammenhang mit ioBroker gemeldet.
                                  Die Aussage "(...) including disabling user accounts for longer periods" erklärt, warum die Sperrungen nicht wie erwartet nach 24 Stunden enden.
                                  Es scheint außerdem so zu sein, dass jeder Loginversuch innerhalb der Sperrzeit dazu führt, dass die Sperrung verlängert wird.
                                  Daher kann ich aktuell nur empfehlen, sämtliche Hausautomatisierungs-Software auszuschalten und ein paar Tage abzuwarten.
                                  Und währenddessen die Worx-App und den Worx-Account nicht zu benutzen.
                                  Wenn das so stimmt hilft wohl alles nix ausser abwarten, Eistee trinken und zugucken wie aus rasen Wiese wird.
                                  falke69 Homoran 2 Replies Last reply Reply Quote 0
                                  • Dr. Bakterius
                                    So etwas darf sich ein Unternehmen mit seinen Kunden nicht erlauben! Sie machen damit das Eigentum ihrer Kunden unbenutzbar. Ein Armutszeugnis ist auch, wenn sie reguläre Zugriffe von DDOS nicht unterscheiden können. Da dieses Problem scheinbar schon länger andauert, sollten sie das schon im Griff haben.
                                    Allen die die API regulär verwenden einfach zu sperren, dazu noch ohne Warnung oder Hinweis für wie lange, kann Positec noch teuer zu stehen kommen.
                                    Wenn die das in den nächsten Tagen nicht in den Griff bekommen, werde ich auf Wandlung des Kaufvertrags bei meinem Händler bestehen. Ich habe noch Gewährleistung und Garantie.
                                    hsteinme 1 Reply Last reply Reply Quote 1
                                      Lucky_ESA Developer Most Active last edited by Lucky_ESA
                                      Ihr seid dann wohl nicht mehr alleine Issue
                                      Ab hier solltet ihr den Intervall auf 360 stellen und ALLE Scripte deaktivieren. Die Supportanfragen sollten nun auch nicht mehr nett sein. Bitte davon Erzählen das ihr 72 Tage gesperrt seit.
                                      Edit: Bei Openhab melden sich nun auch die ersten User....
                                      Gruß//Lucky
                                      • hsteinme
                                        hsteinme @Dr. Bakterius last edited by
                                        @dr-bakterius sagte in Adapter Worx Landroid v3.x.x:
                                        Allen? Ist dies wirklich so? Bei mir z.B. hat noch keine Sperre zugeschlagen trotz Nutzung von Worx und Kress 3rd pParty Apps.
                                          Matt77CHE last edited by
                                          Bei mir hat es gestern zugeschlagen....
                                            Lucky_ESA Developer Most Active @Powertrain01 last edited by
                                            @powertrain01 sagte in Adapter Worx Landroid v3.x.x:
                                            Bei nächsten Release sollte es funktionieren.
                                            788
                                            122862
