    4. Tester Zigbee Adapter 3.x gesucht
    • Eduard77
      Eduard77 @arteck last edited by Eduard77
      @arteck
      Ich habe wieder versucht Vibrationssensor zu koppeln. (https://forum.iobroker.net/topic/80035/tester-für-zigbee-adapter-2-0-x-gesucht/524?_=1750953573650)
      Aber jedes Mal wenn ich den koppeln will, stürzt ZigBee Adapter v3 ab.
      Mein Debug LOG ist recht Groß:
      host.DebianIO LOG.txt, 2025-06-26 175036.959 - debug zigbe.txt
      2025-06-26 17:50:36.959 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":64,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:36.960 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
      2025-06-26 17:50:36.961 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":64,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":64,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":64,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:50:39.960 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":65,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:39.960 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
      2025-06-26 17:50:39.961 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":65,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":65,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:39.968 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":65,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:50:39.968 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:42.961 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":66,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:42.962 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
      2025-06-26 17:50:42.962 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":66,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":66,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":66,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:50:44.780 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c987c SNZB-03P was last seen '231.914' seconds ago.
      2025-06-26 17:50:44.783 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x08ddebfffed98402 SNZB-02P was last seen '640.874' seconds ago.
      2025-06-26 17:50:44.785 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c9f4e SNZB-03P was last seen '2056.22' seconds ago.
      2025-06-26 17:50:44.786 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c138ba25a96096 TY0201 was last seen '1592.687' seconds ago.
      2025-06-26 17:50:44.790 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c1389e3efbd451 TY0201 was last seen '25.904' seconds ago.
      2025-06-26 17:50:44.791 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x286847fffe753954 TS0601 was last seen '930.545' seconds ago.
      2025-06-26 17:50:44.794 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x187a3efffe39a1e4 SWV was last seen '82.87' seconds ago.
      2025-06-26 17:50:45.574 - info: javascript.0 (389) script.js.VIS.View_wechsel: View to check:Samsung_TAB/Haupmenu
      2025-06-26 17:50:45.575 - info: javascript.0 (389) script.js.VIS.View_wechsel: View found in:0
      2025-06-26 17:50:45.967 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":67,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:45.967 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
      2025-06-26 17:50:45.968 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":67,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":67,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":67,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:50:48.970 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":68,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:48.970 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
      2025-06-26 17:50:48.971 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":68,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
      2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
      2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":68,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:50:48.975 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":68,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:50:48.975 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:51:39.929 - debug: zigbee.0 (239349) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":102,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":69,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
      2025-06-26 17:51:39.930 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 1 with groupID 0
      2025-06-26 17:51:39.931 - debug: zigbee.0 (239349) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":69,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":69,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":102,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":69,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
      2025-06-26 17:51:39.933 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"occupancy\":0},\"linkquality\":102,\"groupID\":0,\"cluster\":\"msOccupancySensing\",\"meta\":{\"zclTransactionSequenceNumber\":69,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated '"{\"type\":\"attributeReport\",\"data\":{\"occupancy\":0},\"linkquality\":102,\"groupID\":0,\"cluster\":\"msOccupancySensing\",\"meta\":{\"zclTransactionSequenceNumber\":69,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) message received '{"occupancy":false}' from device 08ddebfffe0fefec type 'SNZB-06P'
      2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated 'false' from device 08ddebfffe0fefec for 'Occupancy'
      2025-06-26 17:51:39.935 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
      2025-06-26 17:51:44.781 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c987c SNZB-03P was last seen '291.915' seconds ago.
      2025-06-26 17:51:44.783 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x08ddebfffed98402 SNZB-02P was last seen '700.874' seconds ago.
      2025-06-26 17:51:44.785 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c9f4e SNZB-03P was last seen '2116.22' seconds ago.
      2025-06-26 17:51:44.786 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c138ba25a96096 TY0201 was last seen '1652.687' seconds ago.
      2025-06-26 17:51:44.791 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c1389e3efbd451 TY0201 was last seen '85.905' seconds ago.
      2025-06-26 17:51:44.792 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x286847fffe753954 TS0601 was last seen '990.546' seconds ago.
      2025-06-26 17:51:44.794 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x187a3efffe39a1e4 SWV was last seen '142.87' seconds ago.
      Eduard77 1 Reply Last reply Reply Quote 0
      • Eduard77
        Eduard77 @Eduard77 last edited by
        @arteck
        Oder ist das Sensor kaputt und lässt das Adapter anstürzen?
        kein anderes Gerät, was ich erfolgreich gekoppelt habe, hat Adapter zum Abstürzt gebracht.
        Danke für deine Mühe
        Eduard
          AlexHaxe @Eduard77 last edited by
          @edis77 said in Tester Zigbee Adapter 3.x gesucht:
          @arteck
          Deine herdsman Konverter sind mit 23.13.0 relativ alt. Wenn ich die Commit-Historie richtig lese, dann wird Dein Gerät frühestens mit Version 23.44.0 unterstützt.
          • Eduard77
            Eduard77 last edited by Eduard77
            @alexhaxe
            Wo kann ich diese Info finden und was kann man machen.
            EDIT:
            Hab ich diese Info im Log gefunden.
            Installed Version: iobroker.zigbee@latest (Converters 23.13.0 Herdsman 3.3.2)
            Also lasse ich den Sensor liegen. Bis es Kompatibel wird.
              Hadebe @Asgothian last edited by
              @asgothian Da es wohl keinen externen Konverter in meiner Installation gibt, woran könnte es noch liegen, dass das Gerät unerkannt bleibt?
              • Asgothian
                Asgothian Developer @Hadebe last edited by
                @hadebe Installier bitte die Version vonGitHub. Dann sollte zumindest der Fehler weg sein. Ob Dein Gerät in der da heran gezogenen ZHC version unterstützt ist weiss ich nicht - es ist aber fraglich.
                A.
                  @asgothian Ergebnis wie vorher, Pairing wird gestartet, aber unsupported device:
                  2025-06-29 10:54:55.526 - info: zigbee.0 (1106366) 0x54ef44100123779e (addr 28846): Unsupported (model lumi.sensor_ht.agl001)(EndDevice)
                  Laut Z2M wird das Gerät unterstützt (hatte Homoran auch schon bestätitgt).
                  Muss ich jetzt nur auf eine aktueller ZHC warten oder was kann ich noch machen?
                  Eduard77 Asgothian 2 Replies Last reply Reply Quote 0
                  • Eduard77
                    Eduard77 @Hadebe last edited by Eduard77
                    @hadebe
                    Du hast das gleich Problem wie ich oben.
                    Dein Gerät wird frühestens mit Version 23.36.0 unterstützt.
                    • Asgothian
                      Asgothian Developer @Hadebe last edited by Asgothian
                      @hadebe auf GitHub gibt es seit heute einen Branch der immer die latest ZHC nutzt. Du kannst diesen installieren - allerdings ist das aktuell nicht aktiv getestet, da ich für die kommenden 6 Wochen keine Tests durchführen kann.
                      Link zur Installation ist:
                      https://github.com/ioBroker/ioBroker.zigbee/tarball/ZHC_latest
                      Wichtig: Die ZHC Version die installiert wird hängt davon ab zu welchem Zeitpunkt diese Version installiert wird. Ansonsten bleibt der Adapter-Code synchron zum Hauptzweig. Ich kann aber nicht garantieren das durch Anpassungen am ZHC sich etwas verändert.
                      Ansonsten kannst du versuchen einen externen Konverter für das Gerät zu bauen. Das erfordert etwas wissen in JS. Der Normale Weg ist:
                      • im Qelltext der ZHC den Converter finden
                      • Identifizieren welche Includes / Requires dieser benötigt (alles in der gleichen Datei)
                      • Aus diesen Daten eine JS Datei wie im Spoiler als Beispiel hinterlegt erzeugen
                      const tuya = require('zigbee-herdsman-converters/lib/tuya');
                      const modernExtend = require('zigbee-herdsman-converters/lib/modernExtend');
                      const {deviceEndpoints, onOff} = require('zigbee-herdsman-converters/lib/modernExtend');
                      const exposes = require("zigbee-herdsman-converters/lib/exposes");
                      const ea = exposes.access;
                      const e = exposes.presets;
                      const definition = {
                         zigbeeModel: ['TS000F'], // The model ID from the device.
                         model: 'TS000F',
                         vendor: 'inventwo',
                         description: '1-Kanal-Relais mit DS18B20',
                         fingerprint: [{modelID: 'TS000F', manufacturerName: '_TZ3218_7fiyo3kv'}], // This helps z2m identify the device
                         fromZigbee: [tuya.fz.datapoints], // Define converters that are used to convert from Zigbee messages to MQTT messages.
                         toZigbee: [], // Define converters that are used to convert from MQTT messages to Zigbee messages.
                         extend: [
                             deviceEndpoints({"endpoints":{"0":0,"1":1}}),
                             onOff({"powerOnBehavior":false,"endpointNames":["1"]}),
                             // tuya.modernExtend.dpTemperature({dp: 0x66, scale: 10})
                          exposes: [
                             e.temperature().withDescription('inventwo Innenraum'),
                         ], // Defines what capabilities (like temperature or on/off) are exposed to MQTT
                         meta: {
                             multiEndpoint: true,
                             tuyaDatapoints: [
                                 [102, 'temperature', tuya.valueConverter.divideBy10]
                         configure: async (device, coordinatorEndpoint, logger) => {
                             const endpoint = device.getEndpoint(1);
                             await endpoint.bind('genOnOff', coordinatorEndpoint);
                             // More configurations can be added here
                      module.exports = definition;
                      • diese Datei im Zigbee Datenverzeichnis ablegen (/opt/iobroker/iobroker-data/zigbee_0)
                      • den Dateinamen in der Adapter-Konfig unter 'external converters' ablegen.
                      • Adapter neu starten, und im Log prüfen ob er geladen wird.
                      A.
                        Hadebe @Eduard77 last edited by
                        @edis77 Das ist ein sehr guter Tip, danke dafür. Wie bei dir 23.13.0
                        Nachdem ich wie von @Asgothian vorgeschlagen von github den Adapter installiert habe, sieht die ZHC Welt besser aus:
                        2025-06-29 10:50:55.502 - info: zigbee.0 (1106116) Installed Version: ioBroker/ioBroker.zigbee (Converters 23.35.0 Herdsman 4.0.0)
                        Das ist zwar gut, aber noch knapp vor der von @Edis77 zitierten. Ich warte dann weiter...
                          @asgothian habe deinen Link bei "Adapter installieren" > "aus eigener URL" >"benutzerdefiniert" eingegeben (so war es vermutlich gemeint). Leider wird die selbe Konverter Version angezogen wie bei Installation von github:
                          2025-06-30 08:29:21.581 - info: zigbee.0 (1183192) Installed Version: ioBroker/ioBroker.zigbee#ZHC_latest (Converters 23.35.0 Herdsman 4.0.0)
                          Habe ich dich richtig verstanden, dass unter deinem Link häufiger Updates erfolgen als im github Hauptzweig, d.h. ich würde die Installation in ein paar Tagen wiederholen und hätte eine höhere Version?
                          Und danke für deinen Versuch meine Skills auf einen neuen Level zu heben, aber mein Wissen über JS bewegt sich nah bei Null
                          Ansonsten bleibt für mich warten.
                          • Asgothian
                            Asgothian Developer last edited by
                            @hadebe da muss bei deiner Installation etwas schief gegangen sein. Eigentlich solltest du ZHC 23.66.0 bekommen haben.
                            Bitte unter /opt/iobroker/node-modules prüfen welche ZHC versione(en) installiert sind.
                            Eduard77 H 2 Replies Last reply Reply Quote 0
                            • Eduard77
                              Eduard77 @Asgothian last edited by Eduard77
                              @asgothian
                              ich habe jetzt von deinem Github Link installiert und bei mir sieht es jetzt so aus.
                              zigbee.0 2025-06-30 09:07:29.423	info	Installed Version: ioBroker/ioBroker.zigbee#ZHC_latest (Converters 23.67.0 Herdsman 4.0.0)
                                Hadebe @Asgothian last edited by Hadebe
                                @asgothian dein Link funktioniert offensichtlich. War mein Vorgehen korrekt?
                                Bin in dem Verzeichnis, aber wie finde ich die Version - in package.json ist nur 23.35.0 eingetragen?
                                • Asgothian
                                  @hadebe du musst über npm auf der Konsole auflisten lassen welche version(en) installiert sind - es kann mehrere geben. Ich hab den Befehl nicht im Kopf und kann das auch nicht mal eben prüfen, sorry.
                                  A.
                                  Gaspode H 2 Replies Last reply Reply Quote 0
                                  • Gaspode
                                    Gaspode @Asgothian last edited by Gaspode
                                    @asgothian said in Tester Zigbee Adapter 3.x gesucht:
                                    @hadebe
                                    z.B. so:
                                    npm ls zigbee-herdsman-converters
                                      @Asgothian bei mir ist nur die ältere Version vorhanden:
                                      pi@raspi01:/opt/iobroker/node_modules $ npm ls zigbee-herdsman-converters
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      └─┬ iobroker.zigbee@3.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#ae472aefab7fbb3c70b56d3c477662e265e52f03)
                                        └── zigbee-herdsman-converters@23.35.0
                                        Hadebe @Gaspode last edited by
                                        @gaspode danke, da hätte ich lange forschen müssen
                                        • Asgothian
                                          @hadebe bitte nochmal vom gleichen link installieren. Du solltest jetzt eine neuere Version bekommen.
                                          H Eduard77 2 Replies Last reply Reply Quote 0
                                            @asgothian Super! So geht's.
                                            └─┬ iobroker.zigbee@3.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#7a9fc13062e49f8aea5b8e7b5cccfb4f90d45b3c)
                                              └── zigbee-herdsman-converters@23.67.0
                                            Mit der neuen Version wird auch das Gerät erkannt
                                            zigbee zigbee adapter
                                            27
                                            259
                                            36343
