    4. Neuer Adapter ioBroker.evcc
    • JLeg
      JLeg @arteck last edited by JLeg
      @arteck Hallo, der evcc-Adapter läuft prima - ausser, man aktiviert auf evcc.io-Seite einen "solar forecast tariff". Dann stürzt der Adapter sofort ab:
      2025-04-26 15:39:12.907  - error: evcc.0 (2727246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reje
      cting a promise which was not handled with .catch().
      2025-04-26 15:39:12.908  - error: evcc.0 (2727246) unhandled promise rejection: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.910  - error: evcc.0 (2727246) Error: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.911  - error: evcc.0 (2727246) The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.911  - error: evcc.0 (2727246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reje
      2025-04-26 15:39:12.912  - error: evcc.0 (2727246) unhandled promise rejection: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.912  - error: evcc.0 (2727246) Error: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.912  - error: evcc.0 (2727246) The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.913  - error: evcc.0 (2727246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reje
      2025-04-26 15:39:12.913  - error: evcc.0 (2727246) unhandled promise rejection: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.913  - error: evcc.0 (2727246) Error: The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.913  - error: evcc.0 (2727246) The state contains the forbidden properties energy, complete!
      2025-04-26 15:39:12.926  - info: evcc.0 (2727246) terminating
      2025-04-26 15:39:12.926  - warn: evcc.0 (2727246) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-04-26 15:39:13.023  - info: evcc.0 (2727246) State value to set for "evcc.0.status.Forecast.Solar.timeseries" has to be stringified but received type "object"
      2025-04-26 15:39:13.427  - info: evcc.0 (2727246) terminating
      2025-04-26 15:39:13.447  - warn: evcc.0 (2727246) get state error: Connection is closed.
      2025-04-26 15:39:13.466  - error: evcc.0 (2727246) DB closed
      2025-04-26 15:39:13.466  - error: evcc.0 (2727246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-04-26 15:39:13.466  - error: evcc.0 (2727246) unhandled promise rejection: DB closed
      2025-04-26 15:39:13.467  - error: evcc.0 (2727246) Error: DB closed
      2025-04-26 15:39:13.467  - error: evcc.0 (2727246) DB closed
      Im Objjektbaum werden zwar unter status->forecast->solar einige DP angelegt, die bleiben aber leer (bis auf 'timeseries').
      Wäre es hilfreich, nochmal Daten im "debug"-Mode zu ziehen?
      Tatsächlich scheinen die Keys "energy" und "complete" das Problem zu sein:
         "forecast": {
            "solar": {
              "today": {
                "energy": 16484.574046565634,
                "complete": true
              "tomorrow": {
                "energy": 41381,
                "complete": true
              "dayAfterTomorrow": {
                "energy": 0,
                "complete": false
              "timeseries": [
                  "ts": "2025-04-26T00:00:00+02:00",
                  "val": 0
        arteck Developer Most Active @JLeg last edited by
        @jlegist korrigiert.. in der neuen GIT version
        und es hängt nicht mit dem forecast zusammen.. sondern wenn du die Ordner aufgelösst willst..das habe ich aber auch im issue geschrieben
        JLeg 1 Reply Last reply Reply Quote 0
        • JLeg
          @arteck sagte in Neuer Adapter ioBroker.evcc:
          1000 Dank füe den schnellen Fix!
          ...hängt von der Perspektive ab, würde ich sagen 😉
          • Merlin123
            Merlin123 last edited by
            Wenn man Fahrzeuge über die UI von EVCC einrichtet steht als Name in den Objekten sowas wie db:1. Bekommt man über den Adapter den Namen raus, den man in der UI eingestellt hat?
            (Nicht das ich "umsonst" eine Übersetzung in ioBroker bastle
              arteck Developer Most Active @Merlin123 last edited by
              @merlin123 sagte in Neuer Adapter ioBroker.evcc:
              wo genau .. ich habdie unter
              ansonsten bei laden werden die unter
              evcc.0.loadpoint.1.status.vehicleName
              angezeigt welcher gerade am Kabel hängt
              • Merlin123
                Merlin123 @arteck last edited by Merlin123
                @arteck Da
                evcc.0.loadpoint.1.control.vehicleName
                und da
                steht bei mir
                db:1 bzw. db:2
                Aber das da
                die Übersetzung steht wusste ich nicht. Wäre irgendwie cool, wenn bei Status und Control auch der "echte" Namen stehen würde.
                  @merlin123 du hast die nicht im evcc über die yaml eingebunden richtig ??
                  • Merlin123
                    @arteck yup. Wie geschrieben über die UI eingetragen. Aber kann die via dein Einträgen unter "vehicle" übersetzten. Nur direkt wäre schöner 🙂
                      machmal ein issue auf evcc auf (nicht im Adapter wir übernhemen nur das was von evcc rüber kommt) .. dass die es über die Schnitstelle korrigieren, bzw anpassen
                        lesiflo Most Active last edited by lesiflo
                        Moin,
                        hat jemand einen Tip für mich wie ich aus dem Objekt "pv" die einzelnen Werte extrahieren kann. Es wird ja nur die gesamte PV Leistung als "pvPower" ausgegeben. Ich habe aber 2 PV Quellen und hätte gerne jeden einzeln einer Variablen zugewiesen.
                        pv sieht bei mir z.B. so aus [{"power":3905,"energy":64860.072},{"power":1086}]
                        So geht es nicht:
                        Hab's selber hinbekommen
                        • ChrisPrefect
                          ChrisPrefect last edited by
                          Hi!
                          Ich hatte auf Github einen Bug reportet, ich denke der Report ging unter:
                          https://github.com/Newan/ioBroker.evcc/issues/48
                          Kann ich das irgendwie selbst fixen damit "gridPower" den korrekten Wert anzeigt?
                          Merci! 🙂
                          ChrisPrefect created this issue in Newan/ioBroker.evcc
                          closed Datenpunkt "gridPower" wird ist nicht korrekt aktualisiert #48
                            arteck Developer Most Active @ChrisPrefect last edited by
                            @chrisprefect ich kann mich entsinnen dass ich da was eingebaut habe
                            hast du das an.. ?
                            ChrisPrefect 1 Reply Last reply Reply Quote 1
                            • ChrisPrefect
                              ChrisPrefect @arteck last edited by
                              @arteck Merci für die Antwort. Ich habe das mal aktiviert. Jetzt wird aber auch das topic "grid" mit dem json nicht mehr aktualisiert. Nicht mal, wenn ich den Adapter neustarte. Sobald ich die Checkbox wieder rausnehmen wird "grid" wieder aktualisiert. Aber "gridPower" wird gar nie aktualisiert.
                                arteck Developer Most Active @ChrisPrefect last edited by arteck
                                @chrisprefect
                                ich hab aufgeräumt und die einzelnen Objekte sind die Ordner gewandert (bei nutzung der checkbox). du hast noch die alte struktur ..deshalb wird da nix aktualisiert
                                lösche mal alle objekte und lasse die neu erstellen.. lass auch die checkbox an und nutze dann diese objekte
                                JoSilverguard 1 Reply Last reply Reply Quote 1
                                • JoSilverguard
                                  JoSilverguard @arteck last edited by
                                  @arteck Seit der Installation der aktuellen Version von EVCC v0.207 erhalte ich im Takt des eingestellten Refresh-Intervalls die Fehlermeldung, dass der Adapter die Information der Loadpoints nicht auslesen kann. Nach mehreren Versuchen den Fehler durch Neustart bzw. De- In- stallation des Adapters (installierte Version 0.1.1) zu beheben, habe ich ein Downgrade auf der Version 0.206.1 durchgeführt. Damit funktioniert der Adapter makellos. Leider habe ich die Logdatei nicht gespeichert und kann den Fehler somit nicht belegen. Aus der Erinnerung: unidentified loadpoints. Ich denke aber, dass ich damit nicht alleine bin und die Meldung grundsätzlich nach der Installation der Version v0.207 auftritt.
                                  Ich vermute (d.h. es ist eine Annahme) dass das Problem durch die Änderung an der REST API verursacht wird. Michael Geers beschreibt diese hier: LINK.
                                  Vielleicht kannst du dir das mal ansehen. Grüße Jo
                                    arteck Developer Most Active @JoSilverguard last edited by
                                    @josilverguard das ist schon längst behoben.. auf GIT
                                    JoSilverguard 2 Replies Last reply Reply Quote 0
                                    • JoSilverguard
                                      @arteck
                                      • JoSilverguard
                                        @arteck
                                        Nun hab ich wieder auf EVCC 0.207.0 upgedatet. Und erhalte genau den von mir beschriebenen Fehler wieder.
                                        Was checke ich nicht, wo und wie kann ich das beheben?
                                        arteck JLeg 2 Replies Last reply Reply Quote 0
                                          @josilverguard muss ich mir anschauen..hab noch die 205 am laufen
                                          • JLeg
                                            JLeg @JoSilverguard last edited by
                                            @josilverguard oben lese ich "Adapter Version 0.1.1" - kann das sein? Jedenfalls - mit der aktuellen 0.2.3 habe ich keinerlei Probleme mit evcc 0.207...
                                            JoSilverguard 1 Reply Last reply Reply Quote 0
                                            1.2k
                                            244
                                            41899
