      docsnyder7 @Homoran last edited by
      @homoran alles klar... werde es erleben heute abend, denn hier in Niedersachsen ist heute kein Feiertag, somit hab die Rollos heute Morgen korrekt geöffnet...
        guitardoc @Homoran last edited by
        @homoran said in Test Adapter shuttercontrol v2.0.x:
        das sollte ein debug-log geworden sein
        So, hier ist das Debug-log. Diesmal ist es das Fenster im Schlafzimmer.
        Hoffentlich kann @simatec damit was anfangen...
        shuttercontrol.2
        2025-06-22 20:21:40.112	debug	Brightness sensor value: 16300.137167466379
        shuttercontrol.2
        2025-06-22 20:21:50.113	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:22:04.503	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.9°C
        shuttercontrol.2
        2025-06-22 20:22:41.337	debug	Brightness sensor value: 16300.137167466379
        shuttercontrol.2
        2025-06-22 20:22:42.049	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.8°C
        shuttercontrol.2
        2025-06-22 20:22:42.574	debug	Brightness sensor value: 16300.137167466379
        shuttercontrol.2
        2025-06-22 20:22:51.338	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:22:52.574	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:23:16.386	debug	Brightness sensor value: 14400.953864180206
        shuttercontrol.2
        2025-06-22 20:23:16.429	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 14400.953864180206lux
        shuttercontrol.2
        2025-06-22 20:23:26.386	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:23:32.054	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.7°C
        shuttercontrol.2
        2025-06-22 20:23:38.071	debug	Brightness sensor value: 14400.953864180206
        shuttercontrol.2
        2025-06-22 20:23:45.100	debug	Brightness sensor value: 14400.953864180206
        shuttercontrol.2
        2025-06-22 20:23:48.070	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:23:55.100	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:24:09.539	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.6°C
        shuttercontrol.2
        2025-06-22 20:24:30.817	debug	Brightness sensor value: 12787.66525239548
        shuttercontrol.2
        2025-06-22 20:24:40.817	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:24:47.052	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.5°C
        shuttercontrol.2
        2025-06-22 20:24:47.593	debug	Brightness sensor value: 12787.66525239548
        shuttercontrol.2
        2025-06-22 20:24:57.593	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:25:00.003	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:25:00.003	debug	Sun Azimut: 298.4°
        shuttercontrol.2
        2025-06-22 20:25:00.003	debug	Sun Elevation: 7.5°
        shuttercontrol.2
        2025-06-22 20:25:20.454	debug	Brightness sensor value: 11323.775719054229
        shuttercontrol.2
        2025-06-22 20:25:30.455	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:25:50.025	debug	Brightness sensor value: 11323.775719054229
        shuttercontrol.2
        2025-06-22 20:26:00.026	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:26:07.398	debug	Brightness sensor value: 11323.775719054229
        shuttercontrol.2
        2025-06-22 20:26:10.097	debug	Brightness sensor value: 10078.392296644535
        shuttercontrol.2
        2025-06-22 20:26:10.140	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 10078.392296644535lux
        shuttercontrol.2
        2025-06-22 20:26:17.399	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:26:20.097	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:26:39.551	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.4°C
        shuttercontrol.2
        2025-06-22 20:26:52.717	debug	Brightness sensor value: 10078.392296644535
        shuttercontrol.2
        2025-06-22 20:27:02.717	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:27:55.064	debug	Brightness sensor value: 10078.392296644535
        shuttercontrol.2
        2025-06-22 20:28:05.064	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:28:09.226	debug	Brightness sensor value: 11352.493425314617
        shuttercontrol.2
        2025-06-22 20:28:19.227	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:28:48.983	debug	Brightness sensor value: 12858.528123126092
        shuttercontrol.2
        2025-06-22 20:28:49.026	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 12858.528123126092lux
        shuttercontrol.2
        2025-06-22 20:28:57.659	debug	Brightness sensor value: 12858.528123126092
        shuttercontrol.2
        2025-06-22 20:28:58.983	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:29:07.659	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:29:22.025	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.3°C
        shuttercontrol.2
        2025-06-22 20:30:00.007	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:30:00.007	debug	Sun Azimut: 299.4°
        shuttercontrol.2
        2025-06-22 20:30:00.007	debug	Sun Elevation: 6.9°
        shuttercontrol.2
        2025-06-22 20:30:00.073	debug	Brightness sensor value: 12858.528123126092
        shuttercontrol.2
        2025-06-22 20:30:10.073	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:30:36.088	debug	Brightness sensor value: 12858.528123126092
        shuttercontrol.2
        2025-06-22 20:30:37.025	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.2°C
        shuttercontrol.2
        2025-06-22 20:30:46.088	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:30:48.067	debug	Brightness sensor value: 11232.883612824658
        shuttercontrol.2
        2025-06-22 20:30:58.067	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:31:02.562	debug	Brightness sensor value: 11232.883612824658
        shuttercontrol.2
        2025-06-22 20:31:12.564	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:31:12.884	debug	Brightness sensor value: 9905.83886217818
        shuttercontrol.2
        2025-06-22 20:31:22.884	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:31:32.745	debug	Brightness sensor value: 8725.518809440335
        shuttercontrol.2
        2025-06-22 20:31:32.787	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 8725.518809440335lux
        shuttercontrol.2
        2025-06-22 20:31:42.745	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:31:47.634	debug	Brightness sensor value: 7664.631135820139
        shuttercontrol.2
        2025-06-22 20:31:57.634	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:32:05.066	debug	Brightness sensor value: 7664.631135820139
        shuttercontrol.2
        2025-06-22 20:32:07.488	debug	Brightness sensor value: 6751.359887184253
        shuttercontrol.2
        2025-06-22 20:32:15.066	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:32:17.022	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.1°C
        shuttercontrol.2
        2025-06-22 20:32:17.489	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:32:25.553	debug	Brightness sensor value: 6751.359887184253
        shuttercontrol.2
        2025-06-22 20:32:35.554	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:32:37.280	debug	Brightness sensor value: 5919.58497314797
        shuttercontrol.2
        2025-06-22 20:32:47.280	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:32:54.489	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29°C
        shuttercontrol.2
        2025-06-22 20:33:07.600	debug	Brightness sensor value: 5919.58497314797
        shuttercontrol.2
        2025-06-22 20:33:17.601	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:34:10.126	debug	Brightness sensor value: 5919.58497314797
        shuttercontrol.2
        2025-06-22 20:34:20.126	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:34:51.293	debug	Brightness sensor value: 5264.913727005191
        shuttercontrol.2
        2025-06-22 20:34:51.337	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 5264.913727005191lux
        shuttercontrol.2
        2025-06-22 20:35:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:35:00.001	debug	Sun Azimut: 300.3°
        shuttercontrol.2
        2025-06-22 20:35:00.001	debug	Sun Elevation: 6.2°
        shuttercontrol.2
        2025-06-22 20:35:01.294	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:35:12.303	debug	insidetemperature changed: alias.0.Temperatur.Gästezimmer.Tür zur Terrasse | Value: 29.4°C
        shuttercontrol.2
        2025-06-22 20:35:14.759	debug	Brightness sensor value: 5264.913727005191
        shuttercontrol.2
        2025-06-22 20:35:24.470	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.9°C
        shuttercontrol.2
        2025-06-22 20:35:24.759	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:35:25.009	debug	Brightness sensor value: 5264.913727005191
        shuttercontrol.2
        2025-06-22 20:35:35.010	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:35:55.823	debug	Brightness sensor value: 4631.175713381168
        shuttercontrol.2
        2025-06-22 20:36:05.766	debug	Brightness sensor value: 4519.5
        shuttercontrol.2
        2025-06-22 20:36:05.823	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:36:15.767	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:36:15.915	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.8°C
        shuttercontrol.2
        2025-06-22 20:36:16.022	debug	Brightness sensor value: 4519.5
        shuttercontrol.2
        2025-06-22 20:36:26.022	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:36:49.315	debug	Brightness sensor value: 4519.5
        shuttercontrol.2
        2025-06-22 20:36:51.999	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.7°C
        shuttercontrol.2
        2025-06-22 20:36:59.315	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:37:17.252	debug	Brightness sensor value: 4111.4144607271155
        shuttercontrol.2
        2025-06-22 20:37:18.023	debug	Brightness sensor value: 4111.4144607271155
        shuttercontrol.2
        2025-06-22 20:37:27.252	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:37:28.023	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:37:42.007	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.6°C
        shuttercontrol.2
        2025-06-22 20:38:19.566	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.5°C
        shuttercontrol.2
        2025-06-22 20:38:20.018	debug	Brightness sensor value: 4111.4144607271155
        shuttercontrol.2
        2025-06-22 20:38:30.018	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:39:01.492	debug	Brightness sensor value: 3808
        shuttercontrol.2
        2025-06-22 20:39:01.538	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 3808lux
        shuttercontrol.2
        2025-06-22 20:39:11.492	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:39:13.707	debug	Brightness sensor value: 3808
        shuttercontrol.2
        2025-06-22 20:39:21.998	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.4°C
        shuttercontrol.2
        2025-06-22 20:39:22.521	debug	Brightness sensor value: 3709
        shuttercontrol.2
        2025-06-22 20:39:23.707	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:39:32.521	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:40:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:40:00.001	debug	Sun Azimut: 301.2°
        shuttercontrol.2
        2025-06-22 20:40:00.001	debug	Sun Elevation: 5.5°
        shuttercontrol.2
        2025-06-22 20:40:11.990	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.3°C
        shuttercontrol.2
        2025-06-22 20:40:24.969	debug	Brightness sensor value: 3644.9473465548463
        shuttercontrol.2
        2025-06-22 20:40:34.969	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:40:37.038	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.2°C
        shuttercontrol.2
        2025-06-22 20:40:45.726	debug	Brightness sensor value: 3609
        shuttercontrol.2
        2025-06-22 20:40:55.726	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:41:13.052	debug	Brightness sensor value: 3609
        shuttercontrol.2
        2025-06-22 20:41:23.052	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:41:27.481	debug	Brightness sensor value: 3504
        shuttercontrol.2
        2025-06-22 20:41:37.482	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:41:52.029	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28.1°C
        shuttercontrol.2
        2025-06-22 20:42:29.940	debug	Brightness sensor value: 3392
        shuttercontrol.2
        2025-06-22 20:42:29.986	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 3392lux
        shuttercontrol.2
        2025-06-22 20:42:39.940	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:43:06.970	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 28°C
        shuttercontrol.2
        2025-06-22 20:43:32.446	debug	Brightness sensor value: 3285
        shuttercontrol.2
        2025-06-22 20:43:42.446	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:44:34.464	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.9°C
        shuttercontrol.2
        2025-06-22 20:44:35.004	debug	Brightness sensor value: 3226.199793447175
        shuttercontrol.2
        2025-06-22 20:44:41.814	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: false
        shuttercontrol.2
        2025-06-22 20:44:41.814	debug	TriggerID changed: 0_userdata.0.Fenster.Schlafzimmer.Kombination_der_Kontaktsensoren | Value: false
        shuttercontrol.2
        2025-06-22 20:44:41.815	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 20:44:41.815	debug	Schlafzimmer - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Wohnzimmer Tür zur Terrasse - shutter current Height is: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Height is: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Action is: up
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Change is: upDown
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Schlafzimmer - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Schlafzimmer - shutter current Height is: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Schlafzimmer - shutter trigger Height is: 30%
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Schlafzimmer - shutter trigger Action is: sunProtect
        shuttercontrol.2
        2025-06-22 20:44:41.858	debug	Schlafzimmer - shutter trigger Change is: upDown
        shuttercontrol.2
        2025-06-22 20:44:41.903	debug	#1 shutter trigger released Wohnzimmer Tür zur Terrasse already in place: 100%
        shuttercontrol.2
        2025-06-22 20:44:41.903	debug	save back trigger action: up for device Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 20:44:43.860	info	Window is still closed -> drive to last height: Set ID: Schlafzimmer value: 30%
        shuttercontrol.2
        2025-06-22 20:44:43.903	debug	#0 wait for shutter check started
        shuttercontrol.2
        2025-06-22 20:44:43.948	debug	save back trigger action: sunProtect for device: Schlafzimmer
        shuttercontrol.2
        2025-06-22 20:44:45.004	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:44:45.727	debug	#3 Started sunprotect end delay for Schlafzimmer with 10 minutes
        shuttercontrol.2
        2025-06-22 20:45:00.003	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:45:00.003	debug	Sun Azimut: 302.2°
        shuttercontrol.2
        2025-06-22 20:45:00.003	debug	Sun Elevation: 4.8°
        shuttercontrol.2
        2025-06-22 20:45:02.012	debug	Schlafzimmer level conversion is disabled ...
        shuttercontrol.2
        2025-06-22 20:45:02.014	debug	Stopping sunprotect delay for Schlafzimmer
        shuttercontrol.2
        2025-06-22 20:45:02.054	info	Sunprotect #422 Set ID: Schlafzimmer value: 100%
        shuttercontrol.2
        2025-06-22 20:45:02.097	debug	#0 wait for shutter check started
        shuttercontrol.2
        2025-06-22 20:45:02.141	debug	Sunprotect for Schlafzimmer is completed
        shuttercontrol.2
        2025-06-22 20:45:02.141	debug	last automatic Action for Schlafzimmer: up_Sunprotect_end
        shuttercontrol.2
        2025-06-22 20:45:02.141	debug	save current height: 100% from Schlafzimmer
        shuttercontrol.2
        2025-06-22 20:45:37.513	debug	Brightness sensor value: 3226.199793447175
        shuttercontrol.2
        2025-06-22 20:45:43.903	debug	#0 wait for shutter check end
        shuttercontrol.2
        2025-06-22 20:45:47.513	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:46:01.971	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.8°C
        shuttercontrol.2
        2025-06-22 20:46:02.098	debug	#0 wait for shutter check end
        shuttercontrol.2
        2025-06-22 20:46:48.055	debug	Brightness sensor value: 3132
        shuttercontrol.2
        2025-06-22 20:46:48.098	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 3132lux
        shuttercontrol.2
        2025-06-22 20:46:52.482	debug	Brightness sensor value: 3040
        shuttercontrol.2
        2025-06-22 20:46:58.056	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:47:02.483	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:47:42.794	debug	Brightness sensor value: 2960
        shuttercontrol.2
        2025-06-22 20:47:52.794	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:47:56.101	debug	Brightness sensor value: 2960
        shuttercontrol.2
        2025-06-22 20:48:06.102	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:48:06.981	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.7°C
        shuttercontrol.2
        2025-06-22 20:48:31.970	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.6°C
        shuttercontrol.2
        2025-06-22 20:48:44.929	debug	Brightness sensor value: 2896
        shuttercontrol.2
        2025-06-22 20:48:54.930	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:49:26.883	debug	Brightness sensor value: 2896
        shuttercontrol.2
        2025-06-22 20:49:31.096	debug	Brightness sensor value: 2896
        shuttercontrol.2
        2025-06-22 20:49:36.882	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:49:41.096	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:49:46.946	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.5°C
        shuttercontrol.2
        2025-06-22 20:49:47.465	debug	Brightness sensor value: 2812
        shuttercontrol.2
        2025-06-22 20:49:47.510	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 2812lux
        shuttercontrol.2
        2025-06-22 20:49:57.465	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:50:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 20:50:00.001	debug	Sun Azimut: 303.1°
        shuttercontrol.2
        2025-06-22 20:50:00.001	debug	Sun Elevation: 4.2°
        shuttercontrol.2
        2025-06-22 20:50:24.039	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: true
        shuttercontrol.2
        2025-06-22 20:50:24.041	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 20:50:24.083	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 20:50:24.083	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 20:50:24.083	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 20:50:24.083	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 20:50:24.083	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 20:50:49.452	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.4°C
        shuttercontrol.2
        2025-06-22 20:50:50.027	debug	Brightness sensor value: 2720
        shuttercontrol.2
        2025-06-22 20:51:00.027	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:51:49.958	debug	Brightness sensor value: 2720
        shuttercontrol.2
        2025-06-22 20:51:52.442	debug	Brightness sensor value: 2637
        shuttercontrol.2
        2025-06-22 20:51:59.958	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:52:02.442	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:52:40.454	debug	Brightness sensor value: 2637
        shuttercontrol.2
        2025-06-22 20:52:50.454	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:52:54.510	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 27.3°C
        shuttercontrol.2
        2025-06-22 20:52:55.133	debug	Brightness sensor value: 2533
        shuttercontrol.2
        2025-06-22 20:52:55.182	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 2533lux
        shuttercontrol.2
        2025-06-22 20:53:05.133	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:53:14.548	debug	Brightness sensor value: 2533
        shuttercontrol.2
        2025-06-22 20:53:24.548	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 20:53:31.256	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: false
        shuttercontrol.2
        2025-06-22 20:53:31.257	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 20:53:31.258	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 20:53:31.258	debug	Wohnzimmer Tür zur Terrasse - shutter current Height is: 100%
        shuttercontrol.2
        2025-06-22 20:53:31.258	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Height is: 100%
        shuttercontrol.2
        2025-06-22 20:53:31.258	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Action is: up
        shuttercontrol.2
        2025-06-22 20:53:31.258	debug	Wohnzimmer Tür zur Terrasse - shutter trigger Change is: upDown
        shuttercontrol.2
        2025-06-22 20:53:31.303	debug	#1 shutter trigger released Wohnzimmer Tür zur Terrasse already in place: 100%
        shuttercontrol.2
        2025-06-22 20:53:31.303	debug	save back trigger action: up for device Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:04:32.483	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:05:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:05:00.001	debug	Sun Azimut: 306°
        shuttercontrol.2
        2025-06-22 21:05:00.001	debug	Sun Elevation: 2.3°
        shuttercontrol.2
        2025-06-22 21:05:11.930	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 26.3°C
        shuttercontrol.2
        2025-06-22 21:05:24.959	debug	Brightness sensor value: 1418.7022550565198
        shuttercontrol.2
        2025-06-22 21:05:26.018	debug	Brightness sensor value: 1418.7022550565198
        shuttercontrol.2
        2025-06-22 21:05:34.959	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:05:36.018	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:06:24.361	debug	Brightness sensor value: 1401
        shuttercontrol.2
        2025-06-22 21:06:26.992	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 26.2°C
        shuttercontrol.2
        2025-06-22 21:06:27.529	debug	Brightness sensor value: 1329
        shuttercontrol.2
        2025-06-22 21:06:34.362	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:06:37.531	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:07:29.935	debug	Brightness sensor value: 1265
        shuttercontrol.2
        2025-06-22 21:07:29.980	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 1265lux
        shuttercontrol.2
        2025-06-22 21:07:39.936	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:07:55.240	debug	Brightness sensor value: 1265
        shuttercontrol.2
        2025-06-22 21:08:05.240	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:08:06.986	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 26.1°C
        shuttercontrol.2
        2025-06-22 21:08:32.473	debug	Brightness sensor value: 1259.7699917368716
        shuttercontrol.2
        2025-06-22 21:08:42.473	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:08:44.492	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 26°C
        shuttercontrol.2
        2025-06-22 21:08:48.297	debug	Brightness sensor value: 1209
        shuttercontrol.2
        2025-06-22 21:08:58.296	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:09:09.893	debug	Brightness sensor value: 1209
        shuttercontrol.2
        2025-06-22 21:09:19.893	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:09:34.940	debug	Brightness sensor value: 1148
        shuttercontrol.2
        2025-06-22 21:09:44.940	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:10:00.002	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:10:00.002	debug	Sun Azimut: 306.9°
        shuttercontrol.2
        2025-06-22 21:10:00.002	debug	Sun Elevation: 1.6°
        shuttercontrol.2
        2025-06-22 21:10:37.559	debug	Brightness sensor value: 1117.3552117861636
        shuttercontrol.2
        2025-06-22 21:10:37.602	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 1117.3552117861636lux
        shuttercontrol.2
        2025-06-22 21:10:47.559	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:10:52.813	debug	Brightness sensor value: 1076
        shuttercontrol.2
        2025-06-22 21:11:01.935	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.9°C
        shuttercontrol.2
        2025-06-22 21:11:02.813	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:11:39.955	debug	Brightness sensor value: 1017
        shuttercontrol.2
        2025-06-22 21:11:49.955	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:11:54.213	debug	Brightness sensor value: 1017
        shuttercontrol.2
        2025-06-22 21:12:04.212	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:12:42.505	debug	Brightness sensor value: 992.8674179116819
        shuttercontrol.2
        2025-06-22 21:12:42.591	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: true
        shuttercontrol.2
        2025-06-22 21:12:42.592	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 21:12:42.633	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 21:12:42.633	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:12:42.633	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:12:42.633	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:12:42.633	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:12:51.761	debug	Brightness sensor value: 964
        shuttercontrol.2
        2025-06-22 21:12:52.507	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:12:54.470	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.8°C
        shuttercontrol.2
        2025-06-22 21:13:01.761	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:13:38.555	debug	Brightness sensor value: 964
        shuttercontrol.2
        2025-06-22 21:13:44.942	debug	Brightness sensor value: 905
        shuttercontrol.2
        2025-06-22 21:13:44.985	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 905lux
        shuttercontrol.2
        2025-06-22 21:13:48.556	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:13:54.942	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:14:18.398	debug	Brightness sensor value: 905
        shuttercontrol.2
        2025-06-22 21:14:28.398	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:14:34.415	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.7°C
        shuttercontrol.2
        2025-06-22 21:14:45.661	debug	Brightness sensor value: 905
        shuttercontrol.2
        2025-06-22 21:14:47.425	debug	Brightness sensor value: 845
        shuttercontrol.2
        2025-06-22 21:14:55.661	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:14:57.426	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:14:59.472	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.6°C
        shuttercontrol.2
        2025-06-22 21:15:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:15:00.001	debug	Sun Azimut: 307.9°
        shuttercontrol.2
        2025-06-22 21:15:00.001	debug	Sun Elevation: 1°
        shuttercontrol.2
        2025-06-22 21:15:13.109	debug	Brightness sensor value: 845
        shuttercontrol.2
        2025-06-22 21:15:23.109	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:15:49.886	debug	Brightness sensor value: 789
        shuttercontrol.2
        2025-06-22 21:15:59.886	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:16:01.933	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.5°C
        shuttercontrol.2
        2025-06-22 21:16:52.426	debug	Brightness sensor value: 782.8728987531722
        shuttercontrol.2
        2025-06-22 21:16:52.468	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 782.8728987531722lux
        shuttercontrol.2
        2025-06-22 21:16:57.577	debug	Brightness sensor value: 782.8728987531722
        shuttercontrol.2
        2025-06-22 21:17:02.427	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:17:07.578	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:17:14.557	debug	Brightness sensor value: 744
        shuttercontrol.2
        2025-06-22 21:17:24.556	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:17:27.446	debug	Brightness sensor value: 744
        shuttercontrol.2
        2025-06-22 21:17:37.447	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:17:54.924	debug	Brightness sensor value: 712
        shuttercontrol.2
        2025-06-22 21:18:04.924	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:18:06.895	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.4°C
        shuttercontrol.2
        2025-06-22 21:18:57.420	debug	Brightness sensor value: 672
        shuttercontrol.2
        2025-06-22 21:19:07.422	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:19:09.424	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.3°C
        shuttercontrol.2
        2025-06-22 21:19:28.554	debug	Brightness sensor value: 672
        shuttercontrol.2
        2025-06-22 21:19:38.554	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:19:40.160	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: false
        shuttercontrol.2
        2025-06-22 21:19:40.160	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: true
        shuttercontrol.2
        2025-06-22 21:19:40.161	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        shuttercontrol.2
        2025-06-22 21:19:40.203	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 21:19:40.203	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:19:40.203	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:19:40.203	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:19:40.203	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        shuttercontrol.2
        2025-06-22 21:19:40.204	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:19:40.204	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:19:40.204	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:19:40.204	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:19:59.998	debug	Brightness sensor value: 636
        shuttercontrol.2
        2025-06-22 21:20:00.001	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:20:00.001	debug	Sun Azimut: 308.8°
        shuttercontrol.2
        2025-06-22 21:20:00.001	debug	Sun Elevation: 0.4°
        shuttercontrol.2
        2025-06-22 21:20:00.014	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 636lux
        shuttercontrol.2
        2025-06-22 21:20:09.998	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:21:02.424	debug	Brightness sensor value: 604
        shuttercontrol.2
        2025-06-22 21:21:08.414	debug	Brightness sensor value: 604
        shuttercontrol.2
        2025-06-22 21:21:12.425	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:21:14.400	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.2°C
        shuttercontrol.2
        2025-06-22 21:21:18.414	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:21:32.630	debug	Brightness sensor value: 604
        shuttercontrol.2
        2025-06-22 21:21:42.631	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:22:05.185	debug	Brightness sensor value: 568
        shuttercontrol.2
        2025-06-22 21:22:15.186	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:22:38.336	debug	insidetemperature changed: alias.0.Temperatur.Schlafzimmer.Fenster | Value: 29°C
        shuttercontrol.2
        2025-06-22 21:23:08.199	debug	Brightness sensor value: 538
        shuttercontrol.2
        2025-06-22 21:23:08.257	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 538lux
        shuttercontrol.2
        2025-06-22 21:23:18.199	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:23:19.435	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25.1°C
        shuttercontrol.2
        2025-06-22 21:23:21.818	debug	Brightness sensor value: 538
        shuttercontrol.2
        2025-06-22 21:23:31.818	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:23:47.595	debug	Brightness sensor value: 538
        shuttercontrol.2
        2025-06-22 21:23:57.597	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:24:09.907	debug	Brightness sensor value: 495
        shuttercontrol.2
        2025-06-22 21:24:19.907	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:24:37.337	debug	Brightness sensor value: 495
        shuttercontrol.2
        2025-06-22 21:24:47.337	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:25:00.004	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:25:00.004	debug	Sun Azimut: 309.8°
        shuttercontrol.2
        2025-06-22 21:25:00.004	debug	Sun Elevation: -0.2°
        shuttercontrol.2
        2025-06-22 21:25:06.085	debug	Brightness sensor value: 495
        shuttercontrol.2
        2025-06-22 21:25:12.464	debug	Brightness sensor value: 472
        shuttercontrol.2
        2025-06-22 21:25:16.086	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:25:22.464	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:25:24.448	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 25°C
        shuttercontrol.2
        2025-06-22 21:25:52.616	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: false
        shuttercontrol.2
        2025-06-22 21:25:52.616	debug	TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: true
        shuttercontrol.2
        2025-06-22 21:25:52.617	debug	Wohnzimmer Tür zur Terrasse - shutter conversion is: false
        shuttercontrol.2
        shuttercontrol.2
        2025-06-22 21:25:52.659	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 21:25:52.659	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:25:52.659	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:25:52.659	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:25:52.659	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:25:52.660	debug	Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
        shuttercontrol.2
        2025-06-22 21:25:52.660	debug	Wohnzimmer Tür zur Terrasse - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:25:52.660	debug	Wohnzimmer Tür zur Terrasse - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:25:52.660	debug	#2 save trigger action: up for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:25:52.660	debug	#2 save trigger height: 100% for device: Wohnzimmer Tür zur Terrasse
        shuttercontrol.2
        2025-06-22 21:26:14.950	debug	Brightness sensor value: 440
        shuttercontrol.2
        2025-06-22 21:26:14.995	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 440lux
        shuttercontrol.2
        2025-06-22 21:26:24.951	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:26:31.821	debug	Brightness sensor value: 440
        shuttercontrol.2
        2025-06-22 21:26:36.753	debug	Brightness sensor value: 440
        shuttercontrol.2
        2025-06-22 21:26:41.822	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:26:43.560	debug	insidetemperature changed: alias.0.Temperatur.Gästezimmer.Tür zur Terrasse | Value: 28.5°C
        shuttercontrol.2
        2025-06-22 21:26:45.306	debug	Brightness sensor value: 440
        shuttercontrol.2
        2025-06-22 21:26:46.753	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:26:55.306	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:27:04.389	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 24.9°C
        shuttercontrol.2
        2025-06-22 21:27:17.378	debug	Brightness sensor value: 410
        shuttercontrol.2
        2025-06-22 21:27:27.378	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:28:19.929	debug	Brightness sensor value: 383
        shuttercontrol.2
        2025-06-22 21:28:26.212	debug	Brightness sensor value: 383
        shuttercontrol.2
        2025-06-22 21:28:29.530	debug	Brightness sensor value: 383
        shuttercontrol.2
        2025-06-22 21:28:29.929	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:28:31.956	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 24.8°C
        shuttercontrol.2
        2025-06-22 21:28:36.212	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:28:39.531	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:29:01.042	debug	Brightness sensor value: 383
        shuttercontrol.2
        2025-06-22 21:29:11.042	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:29:22.444	debug	Brightness sensor value: 360
        shuttercontrol.2
        2025-06-22 21:29:22.487	debug	Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 360lux
        shuttercontrol.2
        2025-06-22 21:29:32.444	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:30:00.007	debug	calculate astrodata ...
        shuttercontrol.2
        2025-06-22 21:30:00.007	debug	Sun Azimut: 310.8°
        shuttercontrol.2
        2025-06-22 21:30:00.007	debug	Sun Elevation: -0.8°
        shuttercontrol.2
        2025-06-22 21:30:08.784	debug	Brightness sensor value: 360
        shuttercontrol.2
        2025-06-22 21:30:10.713	debug	Brightness sensor value: 360
        shuttercontrol.2
        2025-06-22 21:30:18.784	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:30:20.714	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:30:24.927	debug	Brightness sensor value: 340
        shuttercontrol.2
        2025-06-22 21:30:34.927	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:30:43.542	debug	Brightness sensor value: 340
        shuttercontrol.2
        2025-06-22 21:30:53.543	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:31:26.952	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 24.7°C
        shuttercontrol.2
        2025-06-22 21:31:27.515	debug	Brightness sensor value: 316
        shuttercontrol.2
        2025-06-22 21:31:37.515	debug	Brightness State Down is: false
        shuttercontrol.2
        2025-06-22 21:31:39.430	debug	outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 24.6°C
        shuttercontrol.2
        2025-06-22 21:31:41.345	debug	TriggerID changed: 0_userdata.0.Fenster.Schlafzimmer.Kombination_der_Kontaktsensoren | Value: true
        shuttercontrol.2
        2025-06-22 21:31:41.345	debug	Schlafzimmer - shutter conversion is: false
        shuttercontrol.2
        2025-06-22 21:31:41.387	debug	Schlafzimmer - shutter current state.val is: 30%
        shuttercontrol.2
        2025-06-22 21:31:41.387	debug	Schlafzimmer - shutter trigger drive-up is: 100%
        shuttercontrol.2
        2025-06-22 21:31:41.387	debug	Schlafzimmer - shutter trigger change is: upDown
        shuttercontrol.2
        2025-06-22 21:31:43.387	debug	#1 save trigger height: 30% for device Schlafzimmer
        shuttercontrol.2
        2025-06-22 21:31:43.387	debug	#1 save trigger action: sunProtect for device Schlafzimmer
        shuttercontrol.2
        2025-06-22 21:31:43.387	info	#1 Set ID: Schlafzimmer value: 100%
        shuttercontrol.2
        2025-06-22 21:31:43.392	debug	#1 current height: 100% for device Schlafzimmer
        shuttercontrol.2
        2025-06-22 21:31:43.392	debug	#1 current action: triggered for device Schlafzimmer
        shuttercontrol.2
        2025-06-22 21:31:43.392	info	triggered #1 Set ID: Schlafzimmer value: 100%
        shuttercontrol.2
        2025-06-22 21:31:43.457	debug	#0 wait for shutter check started
        shuttercontrol.2
        2025-06-22 21:31:43.502	debug	Schlafzimmer - window is still open -> driving now to: 100%
        shuttercontrol.2
        2025-06-22 21:31:50.221	debug	Brightness sensor value: 316
        shuttercontrol.2
        2025-06-22 21:32:00.221	debug	Brightness State Down is: false
          @homoran 1750330222794-shutter1.jpg wenn ich diesen Punkt auf "nur manueller Modus" stelle... sollte dann der DP unter autoDown beim betreffenden Rollo auf false springen?
            Homoran Global Moderator Administrators @docsnyder7 last edited by
            @docsnyder7 sagte in Test Adapter shuttercontrol v2.0.x:
            @homoran sagte in Test Adapter shuttercontrol v2.0.x:
            Wobei ich keine Ahnung habe, wie es sich beim Modus AUS verhält.
              @homoran ich habs jetzt anders gelöst... das Rollo Küche steckt jetzt in ner 2. shuttercontrol Instanz..hätte icha uch früher drauf kommen können 🙄
              G D 2 Replies Last reply Reply Quote 0
                guitardoc @docsnyder7 last edited by
                @Homoran Hab heute wieder so einen Zustand gehabt, der nicht mit dem Erwarteten übereinstimmt. Es betrifft die Tür im Wohnzimmer zur Terrasse. Die Verschattung ist nicht mehr gegeben, da es bewölkt ist. Trotzdem fährt die Jalousie herunter, weil die Tür geschlossen wurde, welche zwischenzeitlich offen war. Ca. 15:09 hab ich es beobachtet. Hier das Log:
                2025-06-29 15:00:00.004  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:00:00.004  - debug: shuttercontrol.2 (85596) Sun Azimut: 226.2°
                2025-06-29 15:00:00.004  - debug: shuttercontrol.2 (85596) Sun Elevation: 55.3°
                2025-06-29 15:00:05.029  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:00:06.031  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:00:06.073  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:00:23.266  - debug: shuttercontrol.2 (85596) Brightness sensor value: 98163
                2025-06-29 15:00:33.266  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:01:15.457  - debug: shuttercontrol.2 (85596) Brightness sensor value: 98163
                2025-06-29 15:01:25.459  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:01:26.494  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97736
                2025-06-29 15:01:35.831  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97736
                2025-06-29 15:01:36.494  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:01:45.831  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:02:28.397  - debug: shuttercontrol.2 (85596) Brightness sensor value: 100299
                2025-06-29 15:02:28.403  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 100299lux
                2025-06-29 15:02:33.893  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:02:34.895  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:02:34.937  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:02:38.397  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:03:30.722  - debug: shuttercontrol.2 (85596) Brightness sensor value: 75536
                2025-06-29 15:03:40.722  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:03:49.753  - debug: shuttercontrol.2 (85596) Brightness sensor value: 75536
                2025-06-29 15:03:54.902  - debug: shuttercontrol.2 (85596) Brightness sensor value: 75536
                2025-06-29 15:03:59.700  - debug: shuttercontrol.2 (85596) Brightness sensor value: 75536
                2025-06-29 15:03:59.753  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:04:04.902  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:04:09.700  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:04:33.706  - debug: shuttercontrol.2 (85596) Brightness sensor value: 35568
                2025-06-29 15:04:43.707  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:05:00.003  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:05:00.003  - debug: shuttercontrol.2 (85596) Sun Azimut: 227.9°
                2025-06-29 15:05:00.003  - debug: shuttercontrol.2 (85596) Sun Elevation: 54.7°
                2025-06-29 15:05:19.359  - debug: shuttercontrol.2 (85596) Brightness sensor value: 35568
                2025-06-29 15:05:29.359  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:05:35.888  - debug: shuttercontrol.2 (85596) Brightness sensor value: 31683
                2025-06-29 15:05:35.928  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 31683lux
                2025-06-29 15:05:38.933  - info: shuttercontrol.2 (85596) Sunprotect #413 Set ID: Wohnzimmer Südseite value: 100%
                2025-06-29 15:05:38.975  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:05:39.019  - debug: shuttercontrol.2 (85596) last automatic Action for Wohnzimmer Südseite: up_Sunprotect_end
                2025-06-29 15:05:39.020  - debug: shuttercontrol.2 (85596) Sunprotect for Wohnzimmer Südseite is not active
                2025-06-29 15:05:39.020  - debug: shuttercontrol.2 (85596) Range: 250 < 227.9 OR Temperature inside: 27.4 < 21.85 OR ( Temperature outside: 31 < 18.00 OR Light: 31683 < 35000.00)
                2025-06-29 15:05:39.020  - debug: shuttercontrol.2 (85596) Sunprotect Wohnzimmer Südseite old height: 26% new height: 100%
                2025-06-29 15:05:40.022  - info: shuttercontrol.2 (85596) Sunprotect #413 Set ID: Wohnzimmer Südwestseite value: 100%
                2025-06-29 15:05:40.064  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:05:40.108  - debug: shuttercontrol.2 (85596) last automatic Action for Wohnzimmer Südwestseite: up_Sunprotect_end
                2025-06-29 15:05:40.108  - debug: shuttercontrol.2 (85596) Sunprotect for Wohnzimmer Südwestseite is not active
                2025-06-29 15:05:40.108  - debug: shuttercontrol.2 (85596) Range: 275 < 227.9 OR Temperature inside: 27.4 < 21.85 OR ( Temperature outside: 31 < 18.00 OR Light: 31683 < 35000.00)
                2025-06-29 15:05:40.108  - debug: shuttercontrol.2 (85596) Sunprotect Wohnzimmer Südwestseite old height: 28% new height: 100%
                2025-06-29 15:05:45.888  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:05:47.122  - info: shuttercontrol.2 (85596) Sunprotect #413 Set ID: Schlafzimmer value: 100%
                2025-06-29 15:05:47.164  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:05:47.208  - debug: shuttercontrol.2 (85596) last automatic Action for Schlafzimmer: up_Sunprotect_end
                2025-06-29 15:05:47.208  - debug: shuttercontrol.2 (85596) Sunprotect for Schlafzimmer is not active
                2025-06-29 15:05:47.208  - debug: shuttercontrol.2 (85596) Range: 350 < 227.9 OR Temperature inside: 29.2 < 21.85 OR ( Temperature outside: 31 < 18.00 OR Light: 31683 < 35000.00)
                2025-06-29 15:05:47.208  - debug: shuttercontrol.2 (85596) Sunprotect Schlafzimmer old height: 30% new height: 100%
                2025-06-29 15:06:38.227  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34980
                2025-06-29 15:06:38.976  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:06:38.977  - debug: shuttercontrol.2 (85596) Shutter state changed: Wohnzimmer Südseite old value = 26% | new value = 100%
                2025-06-29 15:06:39.026  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34980
                2025-06-29 15:06:40.065  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:06:40.066  - debug: shuttercontrol.2 (85596) Shutter state changed: Wohnzimmer Südwestseite old value = 28% | new value = 100%
                2025-06-29 15:06:47.165  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:06:47.166  - debug: shuttercontrol.2 (85596) Shutter state changed: Schlafzimmer old value = 30% | new value = 100%
                2025-06-29 15:06:48.228  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:06:49.026  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:07:40.707  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34275
                2025-06-29 15:07:50.707  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:08:08.619  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34275
                2025-06-29 15:08:13.174  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34275
                2025-06-29 15:08:18.619  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:08:23.173  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:08:28.909  - debug: shuttercontrol.2 (85596) insidetemperature changed: alias.0.Temperatur.Wohnzimmer.Tür zum Wintergarten | Value: 28.1°C
                2025-06-29 15:08:35.077  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34275
                2025-06-29 15:08:43.235  - debug: shuttercontrol.2 (85596) Brightness sensor value: 33729
                2025-06-29 15:08:43.278  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 33729lux
                2025-06-29 15:08:45.077  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:08:53.236  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:09:16.386  - debug: shuttercontrol.2 (85596) TriggerID changed: 0_userdata.0.Fenster.Wohnzimmer.Tür_zur_Terrasse.Kombination_der_Kontaktsensoren | Value: false
                2025-06-29 15:09:16.428  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter conversion is: false
                2025-06-29 15:09:16.470  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter current state.val is: 100%
                2025-06-29 15:09:16.470  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter current Height is: 100%
                2025-06-29 15:09:16.470  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter trigger Height is: 33%
                2025-06-29 15:09:16.470  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter trigger Action is: sunProtect
                2025-06-29 15:09:16.470  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse - shutter trigger Change is: upDown
                2025-06-29 15:09:18.471  - info: shuttercontrol.2 (85596) Window is still closed -> drive to last height: Set ID: Wohnzimmer Tür zur Terrasse value: 33%
                2025-06-29 15:09:18.513  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:09:18.557  - debug: shuttercontrol.2 (85596) save back trigger action: sunProtect for device: Wohnzimmer Tür zur Terrasse
                2025-06-29 15:09:45.779  - debug: shuttercontrol.2 (85596) Brightness sensor value: 32939
                2025-06-29 15:09:55.779  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:10:00.005  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:10:00.005  - debug: shuttercontrol.2 (85596) Sun Azimut: 229.6°
                2025-06-29 15:10:00.005  - debug: shuttercontrol.2 (85596) Sun Elevation: 54.1°
                2025-06-29 15:10:07.016  - debug: shuttercontrol.2 (85596) #3 Started sunprotect end delay for Wohnzimmer Tür zur Terrasse with 10 minutes
                2025-06-29 15:10:15.678  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 30.1°C
                2025-06-29 15:10:18.514  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:10:18.516  - debug: shuttercontrol.2 (85596) Shutter state changed: Wohnzimmer Tür zur Terrasse old value = 100% | new value = 33%
                2025-06-29 15:10:18.516  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zur Terrasse Old value = 100% | New value = 33% | automatic is active
                2025-06-29 15:10:48.207  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34060
                2025-06-29 15:10:49.131  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34060
                2025-06-29 15:10:58.207  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:10:59.131  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:11:50.889  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:11:50.930  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 36658lux
                2025-06-29 15:12:00.889  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:18.528  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:12:22.519  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:12:28.461  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:12:28.528  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:32.470  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:12:32.520  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:37.460  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36658
                2025-06-29 15:12:38.461  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:42.470  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:47.460  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:12:53.463  - debug: shuttercontrol.2 (85596) Brightness sensor value: 40474
                2025-06-29 15:13:03.463  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:13:07.447  - debug: shuttercontrol.2 (85596) Brightness sensor value: 40474
                2025-06-29 15:13:13.162  - debug: shuttercontrol.2 (85596) Brightness sensor value: 40474
                2025-06-29 15:13:17.448  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:13:23.163  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:13:55.766  - debug: shuttercontrol.2 (85596) Brightness sensor value: 47093
                2025-06-29 15:13:57.858  - debug: shuttercontrol.2 (85596) Brightness sensor value: 47093
                2025-06-29 15:14:05.766  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:14:07.199  - debug: shuttercontrol.2 (85596) Brightness sensor value: 47093
                2025-06-29 15:14:07.859  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:14:17.200  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:14:58.381  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34477
                2025-06-29 15:14:58.422  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 34477lux
                2025-06-29 15:15:00.003  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:15:00.003  - debug: shuttercontrol.2 (85596) Sun Azimut: 231.2°
                2025-06-29 15:15:00.003  - debug: shuttercontrol.2 (85596) Sun Elevation: 53.5°
                2025-06-29 15:15:08.381  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:16:00.717  - debug: shuttercontrol.2 (85596) Brightness sensor value: 33603
                2025-06-29 15:16:10.718  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:17:03.321  - debug: shuttercontrol.2 (85596) Brightness sensor value: 34341
                2025-06-29 15:17:13.322  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:18:05.805  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36492
                2025-06-29 15:18:05.848  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 36492lux
                2025-06-29 15:18:15.805  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:19:05.879  - debug: shuttercontrol.2 (85596) Brightness sensor value: 36492
                2025-06-29 15:19:08.250  - debug: shuttercontrol.2 (85596) Brightness sensor value: 38831
                2025-06-29 15:19:15.880  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:19:18.250  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:20:00.002  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:20:00.002  - debug: shuttercontrol.2 (85596) Sun Azimut: 232.9°
                2025-06-29 15:20:00.002  - debug: shuttercontrol.2 (85596) Sun Elevation: 52.9°
                2025-06-29 15:20:07.017  - debug: shuttercontrol.2 (85596) #3.1 End sunprotect delay for Wohnzimmer Tür zur Terrasse
                2025-06-29 15:20:10.822  - debug: shuttercontrol.2 (85596) Brightness sensor value: 39430
                2025-06-29 15:20:15.224  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.4°C
                2025-06-29 15:20:20.823  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:20:35.165  - debug: shuttercontrol.2 (85596) Brightness sensor value: 39430
                2025-06-29 15:20:35.524  - debug: shuttercontrol.2 (85596) Brightness sensor value: 39430
                2025-06-29 15:20:45.165  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:20:45.524  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:21:13.333  - debug: shuttercontrol.2 (85596) Brightness sensor value: 61796
                2025-06-29 15:21:13.335  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 61796lux
                2025-06-29 15:21:16.340  - debug: shuttercontrol.2 (85596) Wohnzimmer Südseite: Check basis for sunprotect. Height:100 > HeightDownSun: 26 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:21:16.340  - info: shuttercontrol.2 (85596) Sunprotect #412 Set ID: Wohnzimmer Südseite value: 26%
                2025-06-29 15:21:16.382  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:21:16.427  - debug: shuttercontrol.2 (85596) Sunprotect for Wohnzimmer Südseite is active
                2025-06-29 15:21:16.427  - debug: shuttercontrol.2 (85596) Temperature inside: 28.1 > 23 AND ( Temperatur outside: 29.4 > 20 AND Light: 61796 > 50000 )
                2025-06-29 15:21:16.427  - debug: shuttercontrol.2 (85596) Sunprotect Wohnzimmer Südseite old height: 100% new height: 26%
                2025-06-29 15:21:16.427  - debug: shuttercontrol.2 (85596) last automatic Action for Wohnzimmer Südseite: down_Sunprotect
                2025-06-29 15:21:17.429  - debug: shuttercontrol.2 (85596) Wohnzimmer Südwestseite: Check basis for sunprotect. Height:100 > HeightDownSun: 28 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:21:17.429  - info: shuttercontrol.2 (85596) Sunprotect #412 Set ID: Wohnzimmer Südwestseite value: 28%
                2025-06-29 15:21:17.472  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:21:17.517  - debug: shuttercontrol.2 (85596) Sunprotect for Wohnzimmer Südwestseite is active
                2025-06-29 15:21:17.517  - debug: shuttercontrol.2 (85596) Temperature inside: 28.1 > 23 AND ( Temperatur outside: 29.4 > 20 AND Light: 61796 > 50000 )
                2025-06-29 15:21:17.517  - debug: shuttercontrol.2 (85596) Sunprotect Wohnzimmer Südwestseite old height: 100% new height: 28%
                2025-06-29 15:21:17.517  - debug: shuttercontrol.2 (85596) last automatic Action for Wohnzimmer Südwestseite: down_Sunprotect
                2025-06-29 15:21:18.520  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:21:19.523  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:21:19.563  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:21:23.333  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:21:24.575  - debug: shuttercontrol.2 (85596) Schlafzimmer: Check basis for sunprotect. Height:100 > HeightDownSun: 30 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:21:24.575  - info: shuttercontrol.2 (85596) Sunprotect #412 Set ID: Schlafzimmer value: 30%
                2025-06-29 15:21:24.617  - debug: shuttercontrol.2 (85596) #0 wait for shutter check started
                2025-06-29 15:21:24.661  - debug: shuttercontrol.2 (85596) Sunprotect for Schlafzimmer is active
                2025-06-29 15:21:24.661  - debug: shuttercontrol.2 (85596) Temperature inside: 29.2 > 23 AND ( Temperatur outside: 29.4 > 20 AND Light: 61796 > 50000 )
                2025-06-29 15:21:24.661  - debug: shuttercontrol.2 (85596) Sunprotect Schlafzimmer old height: 100% new height: 30%
                2025-06-29 15:21:24.661  - debug: shuttercontrol.2 (85596) last automatic Action for Schlafzimmer: down_Sunprotect
                2025-06-29 15:22:05.155  - debug: shuttercontrol.2 (85596) Brightness sensor value: 61796
                2025-06-29 15:22:15.155  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:22:15.791  - debug: shuttercontrol.2 (85596) Brightness sensor value: 102324
                2025-06-29 15:22:16.383  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:22:16.424  - debug: shuttercontrol.2 (85596) Shutter state changed: Wohnzimmer Südseite old value = 100% | new value = 26%
                2025-06-29 15:22:17.472  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:22:17.474  - debug: shuttercontrol.2 (85596) Shutter state changed: Wohnzimmer Südwestseite old value = 100% | new value = 28%
                2025-06-29 15:22:24.618  - debug: shuttercontrol.2 (85596) #0 wait for shutter check end
                2025-06-29 15:22:24.619  - debug: shuttercontrol.2 (85596) Shutter state changed: Schlafzimmer old value = 100% | new value = 30%
                2025-06-29 15:22:25.791  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:23:18.257  - debug: shuttercontrol.2 (85596) Brightness sensor value: 100808
                2025-06-29 15:23:28.257  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:24:33.272  - debug: shuttercontrol.2 (85596) Brightness sensor value: 99535
                2025-06-29 15:24:33.317  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 99535lux
                2025-06-29 15:24:38.327  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:24:39.329  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:24:39.371  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:24:43.272  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:25:00.003  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                2025-06-29 15:25:00.003  - debug: shuttercontrol.2 (85596) Sun Azimut: 234.4°
                2025-06-29 15:25:00.003  - debug: shuttercontrol.2 (85596) Sun Elevation: 52.3°
                2025-06-29 15:25:05.585  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:25:06.587  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:25:06.629  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:25:23.327  - debug: shuttercontrol.2 (85596) Brightness sensor value: 98295
                2025-06-29 15:25:33.327  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:26:12.739  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.5°C
                2025-06-29 15:26:17.751  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:26:18.753  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:26:18.798  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:26:25.749  - debug: shuttercontrol.2 (85596) Brightness sensor value: 96085
                2025-06-29 15:26:35.750  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:26:46.193  - debug: shuttercontrol.2 (85596) insidetemperature changed: alias.0.Temperatur.Gästezimmer.Tür zur Terrasse | Value: 29.9°C
                2025-06-29 15:26:51.201  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:26:52.202  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:26:52.244  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:02.703  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.6°C
                2025-06-29 15:27:07.504  - debug: shuttercontrol.2 (85596) Brightness sensor value: 96085
                2025-06-29 15:27:08.048  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:09.323  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:27:09.323  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:17.504  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:27:28.316  - debug: shuttercontrol.2 (85596) Brightness sensor value: 95480
                2025-06-29 15:27:28.358  - debug: shuttercontrol.2 (85596) Lightsensor changed: 0_userdata.0.Helligkeit.Maximalwert_mit_Bewölkung | Value: 95480lux
                2025-06-29 15:27:33.408  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:34.412  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:27:34.455  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:38.317  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:27:43.800  - debug: shuttercontrol.2 (85596) insidetemperature changed: alias.0.Temperatur.Wintergarten.HT | Value: 30.75°C
                2025-06-29 15:27:48.810  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:27:49.812  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:27:49.854  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:28:05.226  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.7°C
                2025-06-29 15:28:11.025  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:28:12.027  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:28:12.069  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:28:30.682  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97240
                2025-06-29 15:28:40.682  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:28:42.733  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.8°C
                2025-06-29 15:28:43.415  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97240
                2025-06-29 15:28:47.743  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:28:48.745  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:28:48.787  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:28:53.378  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97240
                2025-06-29 15:28:53.415  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:29:03.378  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:29:32.679  - debug: shuttercontrol.2 (85596) outsidetemperature changed: 0_userdata.0.Temperatur.Vorhersage_mit_Offset | Value: 29.9°C
                2025-06-29 15:29:33.247  - debug: shuttercontrol.2 (85596) Brightness sensor value: 97589
                2025-06-29 15:29:37.689  - debug: shuttercontrol.2 (85596) Wohnzimmer Tür zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:29:38.692  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100
                2025-06-29 15:29:38.734  - debug: shuttercontrol.2 (85596) Wohnzimmer Fenster zum Wintergarten: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:100 AND triggerAction:up != down
                2025-06-29 15:29:43.247  - debug: shuttercontrol.2 (85596) Brightness State Down is: false
                2025-06-29 15:30:00.001  - debug: shuttercontrol.2 (85596) calculate astrodata ...
                Hoffentlich kann @simatec damit was anfangen? Danke schon mal für die Mühe!
                • rtwl
                  rtwl last edited by
                  @simatec
                  Was bedeutet der Status "OpenInSunProtect"? Wann wird dieser gesetzt?
                  Homoran rtwl 2 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @rtwl last edited by
                    @rtwl sagte in Test Adapter shuttercontrol v2.0.x:
                    @simatec
                    wo steht das?
                    müsste so ohne Kontext, heißen
                    geöffnet während der Rollladen im sunprotect war
                    geht wahrscheinlich um eine Tür oder ein Fenster
                    rtwl 1 Reply Last reply Reply Quote 0
                    • rtwl
                      rtwl @Homoran last edited by
                      Es ist ein state der Rollläden (shuttercontrol.0.shutters.autoState).
                      Hier ist auch gut zu sehen:
                      gibt ja aktuell eh kein Problem (denke ich). Will nur genau wissen warum und wann dieser state definiert wird.
                        Supernils last edited by Supernils
                        Hallo zusammen, mein iobroker log ist voll mit
                        2025-07-01 16:05:50.419 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
                        2025-07-01 16:05:52.281 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
                        2025-07-01 16:30:50.602 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
                        2025-07-01 16:31:10.644 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Sportzimmer value: 25%
                        2025-07-01 16:33:43.440 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
                        Die Rollladen fahren mehrmals am Tag sporadisch zwischen den zwei Positionen 25% (Sonnenschutz) und 0% (Wärmeschutz).
                        Mit debug log sieht es wie folgt aus:
                        2025-07-01 17:10:50.388 - debug: shuttercontrol.0 (23613) Start pendingAlarm to check whether an alarm is currently pending (except in the event of frost)
                        2025-07-01 17:10:50.390 - debug: shuttercontrol.0 (23613) status alarm pending for alias.0.Esszimmer.Rolllade_Esszimmer.SET: false
                        2025-07-01 17:10:50.397 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
                        2025-07-01 17:10:50.405 - debug: shuttercontrol.0 (23613) #0 wait for shutter check started
                        2025-07-01 17:10:50.415 - debug: shuttercontrol.0 (23613) #0 wait for shutter check end
                        2025-07-01 17:10:50.423 - debug: shuttercontrol.0 (23613) Shutter state changed: Esszimmer old value = 0% | new value = 25%
                        2025-07-01 17:10:50.423 - debug: shuttercontrol.0 (23613) Esszimmer Old value = 0% | New value = 25% | automatic is active
                        2025-07-01 17:10:50.477 - debug: shuttercontrol.0 (23613) last automatic Action for Esszimmer: up_Brightness
                        2025-07-01 17:10:50.477 - debug: shuttercontrol.0 (23613) save current height: 25% from Esszimmer
                        2025-07-01 17:10:52.158 - debug: shuttercontrol.0 (23613) Start pendingAlarm to check whether an alarm is currently pending (except in the event of frost)
                        2025-07-01 17:10:52.201 - debug: shuttercontrol.0 (23613) status alarm pending for alias.0.Esszimmer.Rolllade_Esszimmer.SET: false
                        2025-07-01 17:10:52.221 - debug: shuttercontrol.0 (23613) Heat Protection for Esszimmer is active
                        2025-07-01 17:10:52.226 - debug: shuttercontrol.0 (23613) Esszimmer: Check basis for sunprotect. Height:25 > HeightDownSun: 0 AND Height:25 == currentHeight:25 AND currentHeight:25 == heightUp:99
                        2025-07-01 17:10:52.227 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
                        2025-07-01 17:10:52.264 - debug: shuttercontrol.0 (23613) #0 wait for shutter check started
                        2025-07-01 17:10:52.274 - debug: shuttercontrol.0 (23613) #0 wait for shutter check end
                        2025-07-01 17:10:52.281 - debug: shuttercontrol.0 (23613) Sunprotect for Esszimmer is active
                        2025-07-01 17:10:52.281 - debug: shuttercontrol.0 (23613) Temperature inside: 23.53 > 20.5 AND ( Temperatur outside: 33.19 > 25 AND Light: 30234.30570511337 > 28000 )
                        2025-07-01 17:10:52.282 - debug: shuttercontrol.0 (23613) Sunprotect Esszimmer old height: 0% new height: 0%
                        2025-07-01 17:10:52.282 - debug: shuttercontrol.0 (23613) last automatic Action for Esszimmer: down_Sunprotect
                        Was mache ich falsch? 🙂
                        Meine Konfig (als Beispiel für alle Rollladen):
                          Homoran Global Moderator Administrators @Supernils last edited by
                          @supernils sagte in Test Adapter shuttercontrol v2.0.x:
                          das ist normal, wenn sie ihre Position über den Adapter verändern.
                          oder liegt dein Problem bei
                          im Sinne von ungewollt?
                            Supernils @Homoran last edited by
                            Das mehrmalige sporadische Fahren zwischen 25% (Sonnenschutz) und 0% (Wärmeschutz) ist das eignetliche Problem, richtig.
                            Der obere log zeigt zwei Fälle:
                            Zeile 1/2: Kommt der Wechsel zwischen Sonnenschutz und Wärmeschutz schnell hintereinander, fahren die Rollladen nicht.
                            Zeile 4/6: Sporadisch sind mehrere Minuten zwischen Sonnenschutz und Wärmeschutz und dann fahren die Rollladen (vermutlich).
                              Homoran Global Moderator Administrators @Supernils last edited by Homoran
                              vermutlich
                              du hast beim Hitzeschutz 30 Minuten Zwangspause eingestellt!
                              Aus 2 Sekunden debug-log kann man nichts erkennen.
                              Ich vermute
                              dass zwischendurch die Helligkeit unter den Grenzwert fällt.
                              das ist eine einzige UND-Verknüpfung
                                @homoran said in Test Adapter shuttercontrol v2.0.x:
                                Woran erkennst du das? An welcher Stelle wird das konfiguriert?
                                Das wird nicht die Ursache sein. Der Wert hat sich seit 11:37 nicht geändert.
                                Ist schon merkwürdig... Ich werde das morgen nochmal beobachten und den debug log posten.
                                  sorry, sind wohl 60.
                                  ich kann diese schwarzen Microfilme so schlecht entziffern
                                    docsnyder7 @docsnyder7 last edited by
                                    @Homoran Ergänzung und auch logisch im NAchgang... die später Schließung ist ja ein zusätzlicher Trigger und wird somit auch erst dann aktiv, wenn man das Rollo auf den entsprechenden bereich einstellt INKL. Automatik.. sonst greift der Trigger ja gar nicht.
                                    Hatte ich im ersten Lesen der Adapterbeschreibung nicht aufgenommen, beim erneuten Lesen dann !
                                    • rtwl
                                      rtwl @rtwl last edited by
                                      @simatec
                                      @simatec, wärst du so nett und beschreibst kurz wann und warum dieser Status gesetzt wird?
                                      Arne Dieckmann 1 Reply Last reply Reply Quote 0
                                      • Arne Dieckmann
                                        Arne Dieckmann @rtwl last edited by
                                        @rtwl Falls Du es noch nicht selber ausprobiert hast...
                                        Für den betroffenen Rollladen ist eine SunProtect Einstellung hinterlegt (z.B. Sonnenstand +/- Winkel vor und nach dem Sonnenstand als Zeitraum). Ist der Rollladen morgens noch geschlossen und der eingestellte Sonnenstand ist +/- des Winkels ist erreicht, ABER der Rolladen soll erst danach automatisch geöffnet werden, dann springt er in den Zustand "OpenInSunProtect". Er fährt also von geschlossen direkt in die SunProtect Einstellung. Klingt komisch, ist aber so.
                                        rtwl 1 Reply Last reply Reply Quote 2
                                        • rtwl
                                          rtwl @Arne Dieckmann last edited by
                                          @arne-dieckmann Vielen Dank für die Erklärung! Macht Sinn so.
                                            Manolo last edited by
                                            ich bin schon die ganze Zeit am herum probieren mit dem Adapter.
                                            Inzwischen funktioniert das Öffnen und Schließen der einzelnen Rolläden und auch die verzögerte Öffnung im Schlafzimmer am Wochenende mit den Schlafzimmer EInstellungen.
                                            Was ich aber bisher nicht hin bekommen habe ist die Sonnenschutzeinstellung.
                                            Egal was ich dort einstelle, die Rolläden fahren nicht herunter.
                                            Hier die Einstellungen:
                                            Egal was ich bei den Testwerten eintrage, der Rolladen bewegt sich nicht.
                                            Kann mir jemand helfen oder schreiben was ich falsch eingestellt habe?
                                            332
                                            7402
                                            10490761
