      timbo @Guest last edited by
      @neuschwansteini Danke, funktioniert wieder
        TT-Tom @timbo last edited by TT-Tom
        @timbo
        kleiner Hinweis, Code Schnipsel oder Logausgaben bitte immer in Codetags packen, sonst kann das Keiner lesen.
          timbo @TT-Tom last edited by
          @tt-tom said in SONOFF NSPanel mit Lovelace UI:
          @timbo
          Danke dir, wird das nächste Mal gemacht 🙂
          • MichaelF
            MichaelF @Armilar last edited by MichaelF
            @armilar
            Hi, habe alle Objekte gelöscht da das abschalten des Displays immer noch nicht klappte.
            Jetzt habe ich folgende Fehlermeldung im Display:
            14:43:44.966 MQT: tele/tasmota_C82F70/SENSOR = {"Time":"2025-06-29T14:43:44","ANALOG":{"Temperature1":31.1},"ESP32":{"Temperature":64.4},"TempUnit":"C"}
            14:43:59.861 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:44"}
            14:44:59.911 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:45"}
            14:45:03.213 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND statusUpdate~~17299~梅78.60~17299~~~"}
            14:46:00.011 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:46"}
            14:46:59.811 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:47"}
            14:47:59.861 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:48"}
            14:48:23.311 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND statusUpdate~~17299~梅78.70~17299~~~"}
            14:48:44.956 MQT: tele/tasmota_C82F70/STATE = {"Time":"2025-06-29T14:48:44","Uptime":"0T00:30:11","UptimeSec":1811,"Heap":156,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"38:10:D5:13:AB:0E","Channel":1,"Mode":"HT40","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:03"}}
            14:48:44.967 MQT: tele/tasmota_C82F70/SENSOR = {"Time":"2025-06-29T14:48:44","ANALOG":{"Temperature1":31.2},"ESP32":{"Temperature":64.4},"TempUnit":"C"}
            14:48:59.813 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:49"}
            14:49:59.916 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:50"}
            14:50:59.811 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:51"}
            14:51:43.262 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND statusUpdate~~17299~梅78.80~17299~~~"}
            14:51:59.811 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:52"}
            14:52:59.811 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~15:53"}
            14:53:44.954 MQT: tele/tasmota_C82F70/STATE = {"Time":"2025-06-29T14:53:44","Uptime":"0T00:35:11","UptimeSec":2111,"Heap":157,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":2,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"38:10:D5:13:AB:0E","Channel":1,"Mode":"HT40","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}
            14:53:44.965 MQT: tele/tasmota_C82F70/SENSOR = {"Time":"2025-06-29T14:53:44","ANALOG":{"Temperature1":31.0},"ESP32":{"Temperature":64.4},"TempUnit":"C"}
            Nach einem Neustart:
            15:04:55.227 MQT: stat/tasmota_C82F70/STATUS0 = {"Status":{"Module":0,"DeviceName":"NSPanel","FriendlyName":["Panel1",""],"Topic":"tasmota_C82F70","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":0,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:46:22","StartupUTC":"2025-06-29T13:18:33","Sleep":0,"CfgHolder":4617,"BootCount":148,"BCResetTime":"2022-07-07T18:59:33","SaveCount":253},"StatusFWR":{"Version":"15.0.1(release-tasmota32)","BuildDateTime":"2025.06.14 10:39:16","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"448/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"192.168.178.69","LogPort":514,"SSId":["WLAN 7270",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","0505C80001000600003C5A0A192800000000","00800080","00006000","00004001","00000001"]},"StatusMEM":{"ProgramSize":2045,"Free":834,"Heap":148,"StackLowMark":3,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["0407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"tasmota-C82F70-3952","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","DNSServer2":"2003:df:3745:f600:9a9b:cbff:feae:d11b","Mac":"7C:87:CE:C8:2F:70","IP6Global":"2003:df:3745:f600:7e87:ceff:fec8:2f70","IP6Local":"fe80::7e87:ceff:fec8:2f70%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"fd63:a0ea:8156:0:9a9b:cbff:feae:d11b","DNSServer2":"2003:df:3745:f600:9a9b:cbff:feae:d11b","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":17.0},"StatusMQT":{"MqttHost":"192.168.178.69","MqttPort":1886,"MqttClientMask":"NS_Panel1","MqttClient":"NS_Panel1","MqttUser":"Mikeldk","MqttCount":2,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2025-06-29T14:04:55Z","Local":"2025-06-29T15:04:55","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":"+01:00","Sunrise":"04:50","Sunset":"20:57"},"StatusSNS":{"Time":"2025-06-29T15:04:55","ANALOG":{"Temperature1":30.9},"ESP32":{"Temperature":64.4},"TempUnit":"C"},"StatusSTS":{"Time":"2025-06-29T15:04:55","Uptime":"0T00:46:22","UptimeSec":2782,"Heap":145,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":1002,"MqttCount":2,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"WLAN 7270","BSSId":"38:10:D5:13:AB:0E","Channel":1,"Mode":"HT40","RSSI":56,"Signal":-72,"LinkCount":1,"Downtime":"0T00:00:03"}}}
            15:04:55.300 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND dimmode~8~100~6371~65535"}
            15:04:55.380 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND dimmode~8~100~6371~65535"}
            15:04:55.424 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND dimmode~8~100~6371~65535"}
            15:04:55.476 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND dimmode~8~100~6371~65535"}
            15:04:55.525 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:04"}
            15:04:55.575 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND date~Sonntag, 29. Juni 2025"}
            15:04:55.625 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"}
            15:04:56.419 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"GETDRIVERVERSION"}
            15:04:59.975 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:05"}
            15:05:59.926 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:06"}
            15:06:59.977 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:07"}
            15:07:44.479 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND statusUpdate~~17299~梅78.70~17299~~~"}
            15:07:59.925 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:08"}
            Wenn ich in der Konsole den Befehl eingebe:
            15:36:59.661 CMD: CustomSend time,12:39
            15:36:59.668 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time,12:39"}
            15:36:59.898 MQT: stat/tasmota_C82F70/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~16:37"}
            Vielleicht jemand anderes auch eine Idee, echt seltsam zwei weitere Display laufen ohne Probleme. Nur dieses hier will nicht so richtig.
            Hab es gefunden, die autoexec.be neu angelegt seit dem geht es wieder. Erstmal gelöst.
            Geändert habe ich daran nichts, lediglich Iobroker neu gestartet danach kam dieser Fehler.
            Ich glaube langsam das das Display ein Macke hat.
            • Armilar
              Armilar Most Active Forum Testing @Armilar last edited by Armilar
              Update v4.8.0
              NSPanel-Adapter Infos:
              heute geht der NSPanel-Adapter v0.2.x in die Beta-Phase, siehe auch: https://forum.iobroker.net/post/1280859
              Es fehlen noch ein paar wenige Features, jedoch ist er schon nutzbar und stabil... also gerne testen...
              NSPanel-Script Infos:
              Zu diesem Anlass haben wir die TFT-Version v4.8.0 erstellt, welche die optionalen Features auch für das Script bereitstellt.
              Was sind die wesentlichen Änderungen?:
              • popupShutter2
                Der Shutter ist in der Version 2 komplett überarbeitet, und hat zusätzlich 3 Custom-Icons (Switch, Press-Button oder Indicator) erhalten.
                Beispiel für den neuen Shutter (Version 2)
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#jalousien-channel-blind
              • popupLight2
                Light ist ebenfalls in der Version 2 komplett überarbeitet und ist für alle Licht-Aliase nutzbar
                Beispiel für eine HUE-Lampe:
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#version-2-ab-tft-475
              • popupSlider
                Neu unter den Popup's ist das popupSlider, welches zunächst in der cardMedia (Alexa) als optionale Variante des Equalizer implementiert ist.
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-‐-cardMedia-‐-Der-Amazon-Alexa-Player#9-equalizer
              Upgrade auf die v4.8.0
              https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
              Unteren Teil des Script's austauschen ab:
              Die neuen Features sind in der TFT v4.8.0 verfügbar
              • TFT EU STABLE Version:
                FlashNextion http://nspanel.de/nspanel-v4.8.0.tft
              • TFT US-L STABLE Version:
                FlashNextion http://nspanel.de/nspanel-us-l-v4.8.0.tft
              • TFT US-P STABLE Version:
                FlashNextion http://nspanel.de/nspanel-us-p-v4.8.0.tft
              Viel Spaß mit den neuen Features
              @TT-Tom , @ticaki , @Kuckuckmann und Armilar
              GregorS Rene55 2 Replies Last reply Reply Quote 5
              • GregorS
                GregorS @Armilar last edited by
                Nach Update auf die Version V4.7.1.2 laufen beide Panels wieder.
                Das Wohnzimmerpanel steht aber jeden morgen auf der Konfig-Seite.
                Der Screensaver wird nicht aufgerufen.
                Nach einem Reboot läuft es dann wieder in den Screensaver.
                Beide Panels haben das gleiche Script, nur im Flur sind ein paar mehr Seiten vorhanden.
                Alle Seiten im Wohnzimmer funktionieren ohne Probleme.
                Jemand eine Idee?
                Gregor
                • Rene55
                  Rene55 @Armilar last edited by
                  @armilar Gibt es für den Scriptadapter >9.x eine Lösung oder Workaround? Die Kluft zwischen 8.9.2 und mittlerweile 9.0.7 (ich weiß: alles beta) wird ja immer größer.
                  ? Armilar 2 Replies Last reply Reply Quote 0
                    A Former User @Rene55 last edited by
                    @rene55
                    nein, da muss man warten, bis bluefox oder wer daran auch immer arbeitet, an dem Thema drn ist.
                    Zur Zeit sind da nur Aenderungen an Blockly usw. drin..
                    Bin mal gespannt, was zuerst fertig ist, der ns-panel-Adapter oder der Fix im Javascript-Adapter 9.x... 🙂
                    • Armilar
                      Armilar Most Active Forum Testing @Rene55 last edited by Armilar
                      @rene55
                      wie @Neuschwansteini schon korrekt geantwortet hat, geht es hierbei um dieses Issue:
                      https://github.com/ioBroker/ioBroker.javascript/issues/1892
                      @Kuckuckmann hatte ein Issue:
                      https://github.com/ioBroker/ioBroker.javascript/issues/1906
                      eröffnet, welches dann als Duplikat mit dem oberen verschmolzen wurde...
                      Darüber hinaus, gibt es noch weitere Fehler im JS 9.x (beta), so dass man einen Wechsel aktuell nur versuchen sollte, wenn alle Skripte ausschließlich auf Blockly (auch keine funktionale Garantie) basieren... Die Umstellung des JS-Adapters komplett auf Type-Script, sorgt zumindest im Moment dafür, dass ironischerweise TypeScript nicht korrekt funktioniert 😉
                      Wir warten mal ab, was mit dem Ticket 1892 passiert... 😊
                      EDIT: Und noch ist die JS stable ja die v8.9.2 - Also erstmal keine Aufregung...
                      agross created this issue in ioBroker/ioBroker.javascript
                      open [Bug]: Type declaratons are broken with 9.x #1892
                      kuckuckmann created this issue in ioBroker/ioBroker.javascript
                      closed [Bug]: Wrong TypeDefinitons since adapter version 9.0.X #1906
                      • Rene55
                        @armilar Danke für die Hinweise. Mir ging es ja auch nur darum, ob der Bug überhaupt bearbeitet wird. Ist ja seit 9.0.1 bekannt und sind ja schon bei 9.07 - ohne dass sich hier was getan hätte.
                        Armilar 1 Reply Last reply Reply Quote 1
                        • Armilar
                          Armilar Most Active Forum Testing @GregorS last edited by Armilar
                          @gregors
                          Hier würde mir, aufgrund der Aussage: "dass es nach einem Reboot in den Screensaver läuft, sich sonst aber korrekt verhält", auf ein externes Script tippen, dass nachts versucht, eine Umstellung auf "was auch immer" vornimmt.
                          • Mit der Konfig-Seite meinst du die Service-Pages?
                          • Der Screensaver wird nicht aufgerufen, soll bedeuten, dass die Service-Pages morgens (z.B. durch Seitennavigation) nicht verlassen werden können?
                          • Wenn das Wohnzimmer-NSPanel den Screensaver verlässt, kehrt es dann wieder zurück in den Screensaver?
                          • Kannst du z.B. über das Log nachvollziehen, wann das passiert und ob dabei Fehler entstehen?
                          Prüfe bitte zunächst, ob es externe Skripte gibt, die Einfluss auf die externen Parameter (Triggerpunkte) des NSPanel haben könnten 😊
                          • Armilar
                            @rene55
                            eine 9.0.1 und eine 9.0.5 hat es ja nie gegeben... Unser Problem existiert seit der ersten Bereitstellung auf 9.0.2
                            9.0.2 (2025-06-04)
                            (@klein0r) Added possibility to escape chars in formatTimeDiff
                            (@GermanBluefox) Back-end was migrated to TypeScript
                            (@GermanBluefox) Breaking change: removed "request" module
                            (@GermanBluefox) Added prettier for scripts
                            Und die beschriebenen Changes weisen alle nicht auf unser Problem hin. Da ist entweder schon etwas in der 9.0.0 - 9.0.1 schief gelaufen, aber dem Log ist da nichts wirklich zu entnehmen...
                            EDIT: Und sollte es darüber hinaus gewollte Syntax- odeer Semantic-Änderungen geben, wäre ein kleiner "Entwickler-Hint" oder eine Dokumentation einer solchen Änderung hilfreich... 😉 Ich gehe solange zumindest von einem Bug aus...
                            EDIT2: Der einzige beschriebene Breaking Change ist die Entfernung von Request. Die ist seit langer Zeit bei uns auf Axios umgestellt...
                            • GregorS
                              @armilar
                              @armilar said in SONOFF NSPanel mit Lovelace UI:
                              @gregors
                                Ja, genau
                                Gerade ausprobiert, Nein. Das Panel bleibt auf der zuletzt aufgerufenen Seite
                                Das Log ist unauffällig. Sieht bei dem 2. Panel fast identisch aus.
                              Es gibt kein Script. Vor dem Update hat es immer funktioniert, und ich habe keine Änderungen o.ä. vorgenommen.
                              Ich kann den Screensaver doch auch manuell starten, oder?
                              Unterschied NSPanel_1 (das mit dem Problem)
                              Program Version 13.3.0(nspanel)
                              NSPanel_2
                              Program Version 14.3.0 (release-nspanel)
                              • Armilar
                                Armilar Most Active Forum Testing last edited by Armilar
                                @gregors
                                NSPanel_2
                                Ich gehe mal nicht davon aus, dass das Problem durch diese alten Tasmota-Versionen entstanden ist... Auf der anderen Seite kann es ja nicht schaden, diese mal auf den neuesten Stand zu bringen...
                                Was heißt Screensaver manuell starten? Es gibt hierfür keinen Trigger im Script...
                                Technisch gesehen läuft das wie folgt:
                                • Mit Startup (Initialisierung) wird das Timeout aus "0_userdata.0.NSPanel.X.Config.Screensaver.timeoutScreensaver" an das NSPanel übergeben und dort temporär zwischengespeichert, bis das Panel entweder stromlos wird oder der Parameter für das Timeout geändert wird.
                                • Wird jetzt eine "normale" Card oder ein Popup aufgerufen, dann startet ein interner Timer in dieser Card oder diesem Popup mit diesem Timeout (also alles in der TFT --> HMI)
                                • Ist dieser Timeout abgelaufen (wobei ein manuelles bedienen in der jeweiligen Card diesen Timeout immer wieder neu startet), dann wird ein Event per MQTT an den MQTT Datenpunkt mqtt.X...tele.RESULT gesendet (Im Falle der Serviceseiten also ein event,sleepReached,cardEntities, da es sich ja um eine cardEntities handelt)
                                • Das NSPanelTs.ts - Skript sendet daraufhin die - Informationen für den Screensaver an das NSPanel und dieses schaltet dann den Screensaver auf.
                                Da also der Screensaver beim Neustart aufgeschaltet wird, muss also der Parameter für das Timeout "0_userdata.0.NSPanel.X.Config.Screensaver.timeoutScreensaver" > 0 sein. Daher kann ich in deinem Fall auch nicht nachvollziehen, warum dein NSPanel (und ja auch nur ein NSPanel von 2) nachts auf die Serviceseiten springt. (und darüber hinaus nicht das Timeout aktiviert um zum Screensaver zurückzukehren)
                                Hier kann ich nur mit einem entsprechenden Log aus der Zeit des auftretenden Fehlers arbeiten, um dir entsprechende Hilfe zu geben...
                                GregorS 1 Reply Last reply Reply Quote 2
                                  arteck Developer Most Active @GregorS last edited by
                                  @gregors lass dich mal zum Testen das gleiche Script auf beiden Panels laufen.. es muss sich gleich verhalten
                                    Foradh 0 last edited by Foradh 0
                                    ich habe leider ein Problem mit der aktuellen Display Firmware bei einem von meinen 4 NSPanels.
                                    Bei 3en ist das Update sauber durchgelaufen. Bei einem kommt es im log gleich zu einer Fehlermeldung, danach läuft das Update bis 99% durch und bleibt dann stehen.
                                    16:03:25.864 CMD: FlashNextion http://nspanel.de/nspanel-v4.8.0.tft
                                    16:03:25.873 MQT: NsPanel/Schlafzimmer_9BEC18/stat/RESULT = {"FlashNextion":"Done"}
                                    16:03:25.894 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.8.0.tft
                                    16:03:26.267 FLH: Something has gone wrong flashing display firmware [bytes('1AFFFFFF')]
                                    16:03:26.434 FLH: Send (High Speed) flash start
                                    16:03:26.806 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 0, "time_elapsed": 0}}
                                    16:03:30.310 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.8.0.tft
                                    16:03:30.672 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 82, "time_elapsed": 4}}
                                    16:03:33.645 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 83, "time_elapsed": 7}}
                                    16:03:37.953 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 84, "time_elapsed": 11}}
                                    16:03:42.238 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 85, "time_elapsed": 15}}
                                    16:03:46.529 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 86, "time_elapsed": 20}}
                                    16:03:50.706 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 87, "time_elapsed": 24}}
                                    16:03:54.914 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 88, "time_elapsed": 28}}
                                    16:03:59.130 MQT: NsPanel/Schlafzimmer_9BEC18/tele/RESULT = {"Flashing":{"complete": 89, "time_elapsed": 32}}
                                    Hatte jemand das gleiche Problem und einen Tipp für mich wie ich das Problem beseitige. Auch mehrere Neustarts oder stromlos machen und erneutes Flashen bringt keine Abhilfe.
                                    Update:
                                    Hat sich gerade doch von alleine gelöst. Warum auch immer hat es nun doch geklappt
                                    Beste Grüße
                                    Foradh
                                    • GregorS
                                      @armilar
                                      Interessanterweise hat es die letzten 2 Tage wieder funktioniert.
                                      Habe keine Änderungen gemacht.
                                        ich such mir gerade einen ab
                                        irgendwo hab ich gesehen dass man auf einen icon sonnenauf und untergang legen konnte..
                                        hat das einer parat
                                                        ScreensaverEntity: 'javascript.0.variables.astro.sunrise',
                                                        ScreensaverEntityFactor: 1,
                                                        ScreensaverEntityDecimalPlaces: 0,
                                                        ScreensaverEntityDateFormat: {hour: '2-digit', minute: '2-digit'}, // Description at Wiki-Pages
                                                        ScreensaverEntityIconOn: 'weather-sunset-up',
                                                        ScreensaverEntityIconOff: null,
                                                        ScreensaverEntityText: 'Auf',
                                                        ScreensaverEntityUnitText: '%',
                                                        ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}
                                                    // bottomScreensaverEntity 4
                                                        ScreensaverEntity: 'javascript.0.variables.astro.sunset',
                                                        ScreensaverEntityIconOn: 'weather-sunset-down',
                                                        ScreensaverEntityText: 'Unter',
                                        also die 2 in einem
                                        T Armilar 2 Replies Last reply Reply Quote 0
                                          ticaki Developer @arteck last edited by ticaki
                                          @arteck
                                          Im Adapter:
                                                          type:'template',
                                                          template: 'text.accuweather.sunriseset',
                                                          dpInit: 'accuweather.0',
                                                          modeScr: 'bottom'
                                          In meiner Skriptkonfiguration zu dem NSPanel-Skript finde ich nichts vergleichbares - denke da mußt du mit einem externen Skript arbeiten.
                                          EDIT: Dazu bei accuweather
                                          accuweather.0.Daily.Day0.Sunrise - accuweather.0.Daily.Day0.Sunset - accuweather.0.Daily.Day1.Sunrise - accuweather.0.Daily.Day1.Sunset
                                          laden gegen < Date.now() prüfen und den ersten >= Date.now() in einen datenpunkt schreiben - in einen weiteren das passende Icon und die im screensaver verwenden. Hoffe der Screensaver unterstützt das laden der icons von einem datenpunkt 🙂
                                          EDIT2: Ups hab die roles aus dem adapter kopiert gehabt 😄
                                          EDIT3: Der 4. State ist drin, wenn man sich ausversehen das tageslimit geschrottet hat.
                                          • Armilar
                                            Armilar Most Active Forum Testing @arteck last edited by Armilar
                                            @arteck
                                            Im Script ist das 6. Icon für den advanced Screensaver dafür vorgesehen... Macht den Wechsel in der function HandleScreensaverUpdate automatisch siehe:
        if (weatherAdapterInstance == 'accuweather.' + weatherAdapterInstanceNumber + '.' && i == 6) {
        let nextSunEvent = 0;
        let valDateNow = new Date().getTime();
        let arraySunEvent: number[] = [];
        arraySunEvent[0] = getDateObject(getState('accuweather.' + weatherAdapterInstanceNumber + '.Daily.Day1.Sunrise').val).getTime();
        arraySunEvent[1] = getDateObject(getState('accuweather.' + weatherAdapterInstanceNumber + '.Daily.Day1.Sunset').val).getTime();
        arraySunEvent[2] = getDateObject(getState('accuweather.' + weatherAdapterInstanceNumber + '.Daily.Day2.Sunrise').val).getTime();
        let j = 0;
        for (j = 0; j < 3; j++) {
        if (arraySunEvent[j] > valDateNow) {
        nextSunEvent = j;
        break;
        let sun = '';
        if (j == 1) {
        sun = 'weather-sunset-down';
        } else {
        sun = 'weather-sunset-up';
        payloadString += '~' + '~' + Icons.GetIcon(sun) + '~' + rgb_dec565(MSYellow) + '~' + 'Sonne' + '~' + formatDate(getDateObject(arraySunEvent[nextSunEvent]), 'hh:mm') + '~';
        } else {
        payloadString += '~' + '~' + Icons.GetIcon(WeatherIcon) + '~' + WheatherColor + '~' + DayOfWeek + '~' + tempMinMaxString + '~';
                                            Ist eigentlich nur ein Lückenfüller, da es keine 6 Wetterprognosen je Wetter-Adapter gibt, sondern immer nur 5, aber 6 Icons zur Verfügung stehen...
                                            EDIT: nur so zur Info, falls sich jemand fragt, warum da zweimal der Sonnenaufgang berücksichtigt wird... Machen eigentlich fast alle Logiken falsch - aber nach dem letzten Sonnenuntergang folgt nicht der Sonnenuntergang für den aktuellen Tag (Der war ja schon 😉 ), sondern der Sonnenaufgang für den nächsten Tag... 😊
                                            lovelace ui nspanel sonoff
                                            267
                                            7490
                                            5329734
