    4. TS0601 Zigbee
    TS0601 Zigbee
      peterfido @arteck last edited by peterfido
      @arteck @Asgothian :
      Ich habe das Teil zum Laufen bekommen. In der Datei tuya.js habe ich zwei Zeilen ergänzt. (Zeilen 13 und 41)
              fingerprint: tuya.fingerprint('TS0601', [
                  '_TZE200_yjjdcqsq',
                  '_TZE200_9yapgbuv',
                  '_TZE200_utkemkbs',
                  '_TZE204_utkemkbs',
                  '_TZE204_9yapgbuv',
                  '_TZE204_upagmta9',
                  '_TZE200_cirvgep4',
                  '_TZE200_upagmta9',
                  '_TZE204_yjjdcqsq',
                  '_TZE204_cirvgep4',
      			'_TZE204_jygvp6fk',
              model: 'TS0601_temperature_humidity_sensor_2',
              vendor: 'Tuya',
              description: 'Temperature and humidity sensor',
              fromZigbee: [tuya.fz.datapoints],
              toZigbee: [tuya.tz.datapoints],
              onEvent: tuya.onEvent({ queryOnDeviceAnnounce: true }),
              configure: async (device, coordinatorEndpoint) => {
                  await tuya.configureMagicPacket(device, coordinatorEndpoint);
                  // Required to get the device to start reporting
                  await device.getEndpoint(1).command('manuSpecificTuya', 'dataQuery', {});
              exposes: [e.temperature(), e.humidity(), tuya.exposes.batteryState(), tuya.exposes.temperatureUnit()],
              meta: {
                  tuyaDatapoints: [
                      [1, 'temperature', tuya.valueConverter.divideBy10],
                      [2, 'humidity', tuya.valueConverter.raw],
                      [3, 'battery_state', tuya.valueConverter.batteryState],
                      [9, 'temperature_unit', tuya.valueConverter.temperatureUnitEnum],
              whiteLabel: [
                  tuya.whitelabel('Tuya', 'ZTH01', 'Temperature and humidity sensor', ['_TZE200_yjjdcqsq', '_TZE204_yjjdcqsq']),
                  tuya.whitelabel('Tuya', 'SZTH02', 'Temperature and humidity sensor', ['_TZE200_utkemkbs', '_TZE204_utkemkbs']),
                  tuya.whitelabel('Tuya', 'ZTH02', 'Temperature and humidity sensor', ['_TZE200_9yapgbuv', '_TZE204_9yapgbuv']),
                  tuya.whitelabel('Tuya', 'ZTH05', 'Temperature and humidity sensor', ['_TZE204_upagmta9', '_TZE200_upagmta9']),
                  tuya.whitelabel('Tuya', 'ZTH08-E', 'Temperature and humidity sensor', ['_TZE200_cirvgep4', '_TZE204_cirvgep4']),
      			tuya.whitelabel('Tuya', 'ZTH07-E', 'Temperature and humidity sensor', ['_TZE201_jygvp6fk', '_TZE204_jygvp6fk']),
      Die Uhrzeit stimmt und die Werte trudeln ein:
      Jetzt probiere ich es auf meinem Produktivsystem.
      • Asgothian
        Asgothian Developer @peterfido last edited by
        @peterfido sagte in TS0601 Zigbee:
        Wichtiger Hinweis: diese Anpassung wird verloren gehen sobald du den Zigbee-Adapter aktualisierst / neu installierst. Darüber musst du dir im klaren sein. ggf. musst du diese Anpassung wiederholen.
        Ein Einspielen bei den zigbee-herdsman-converters ist ausgeschlossen, da diese Änderung da bereits vorhanden ist, aber erst in einer 21.x Version, die nicht mit dem Zigbee-Adapter 1.10 funktioniert.
        A
        P 2 Replies Last reply Reply Quote 0
          peterfido @Asgothian last edited by peterfido
          @asgothian Ist mir bewusst. Wie müsste denn in diesem Fall eine eigene Converter-Datei aussehen?
          Edit: Bei der 1.11.x ist das Gerät noch unbekannt. Da hatte ich die Änderung zuerst auf meinem Testsystem durchgeführt.
            @asgothian im Github unter zigbee-herdsman-converters/.../tuya.ts
            wird das Gerät noch nicht aufgeführt. Müsste dort ab Zeile 1100 stehen. Gibt es für die 21.x Version eine andere Quelle?
              peterfido @peterfido last edited by peterfido
              Ich habe jetzt eine wohl gute Lösung gefunden.
              In Proxmox habe ich eine VM erstellt, auf welcher ich zusätzlich curl, mosquitto, zigbee2mqtt und vsftpd installiert habe.
              Geht man nach der Anleitung von zigbee2mqtt vor, dann verschwinden bei jedem Neustart die Rechte, den USB-Stick zu nutzen. Ist mir jetzt allerdings egal, da ich heute Morgen mein LAN-Gateway vom Zigbee-Adapter auf zigbee2mqtt umgezogen habe.
              Der Umzug war etwas trickreich, da die Konfiguration bei z2m die ext. Pan ID und den Transport-Key in einzelnen dezimalen Zahlen haben möchte. Obendrein ist die ext. Pan ID rückwärts einzutragen. Also die letzte Zahl zuerst und zuletzt die erste Zahl.
              Dann noch die Konfigurations-Dateien nach /opt/zigbee2mqtt/data kopieren und umbenennen. Das habe ich dann mit FileZilla über ftp gemacht. Die shepherd.db muss in database.db umbenannt werden.
              Dann noch im data Ordner einen Unterordner external_converters erstellen und da die selbst erstellte (ok - zusammenkopierte) Datei reinkopieren.
              var __importStar = (this && this.__importStar) || (function () {
                  var ownKeys = function(o) {
                      ownKeys = Object.getOwnPropertyNames || function (o) {
                          var ar = [];
                          for (var k in o) if (Object.prototype.hasOwnProperty.call(o, k)) ar[ar.length] = k;
                          return ar;
                      return ownKeys(o);
                  return function (mod) {
                      if (mod && mod.__esModule) return mod;
                      var result = {};
                      if (mod != null) for (var k = ownKeys(mod), i = 0; i < k.length; i++) if (k[i] !== "default") __createBinding(result, mod, k[i]);
                      __setModuleDefault(result, mod);
                      return result;
              const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
              const tz = require('zigbee-herdsman-converters/converters/toZigbee');
              const exposes = require('zigbee-herdsman-converters/lib/exposes');
              const reporting = require('zigbee-herdsman-converters/lib/reporting');
              const ota = require('zigbee-herdsman-converters/lib/ota');
              const utils = require('zigbee-herdsman-converters/lib/utils');
              const globalStore = require('zigbee-herdsman-converters/lib/store');
              const e = exposes.presets;
              const ea = exposes.access;
              const tuya = __importStar(require("zigbee-herdsman-converters/lib/tuya"));
              const definition = {
              		'_TZE204_jygvp6fk',
                  zigbeeModel: ['lumi.sens'],
                  vendor: 'EMOS',
                  extend: [],
                   * Clusters reporting "from zigbee"
                   * Clusters to send commands "to zigbee"
                   * Defines which fields are exposed in the definition message to configure a frontend
                   * (e.g. Z2M frontend, Home Assistant, Domoticz)
                      meta: {
                          tuyaDatapoints: [
              	whiteLabel: [
              		tuya.whitelabel('Tuya', 'EGS0101', 'Temperature and humidity sensor', ['_TZE200_jygvp6fk', '_TZE204_jygvp6fk']),
              module.exports = definition;
              Danach können die Thermometer mit Uhr genutzt werden. Es gibt zwar beim Anlernen eine Meldung, dass diese nur von einer älteren Zigbee-Revision unterstützt werden, läuft aber trotzdem.
              info 2025-01-12 09:23:39zh:controller:device: Device '0xa4c1385f24e9365e' is only compliant to revision '21' of the ZigBee specification (current revision: 23).
              info 2025-01-12 09:23:43zh:controller: Succesfully interviewed '0xa4c1385f24e9365e'
              info 2025-01-12 09:23:43z2m: Successfully interviewed '0xa4c1385f24e9365e', device has successfully been paired
              info 2025-01-12 09:23:43z2m: Device '0xa4c1385f24e9365e' is supported, identified as: Tuya Temperature and humidity sensor (EGS0101)
              und taucht im ioBroker mit Werten auf.
                Ich hatte ein Issue auf Github eröffnet, und Koenkk hat das Gerät im dev branch hinzugefügt.
                Das ging echt flott.
                • Sleepless135
                  Sleepless135 last edited by
                  Moin in die Runde,
                  bin auch über das End Gerät TS0601 gekommen.
                  Es ist ein Bodensensor von Ali, wollte mal schauen ob dann weniger Blumen bei mir sterben 😄
                  Die Zigbee Version ist so weit ich sehen kann die neuste.
                  type:zStack3x0
                  version:2-1.2.7.1.
                  revision:20210708
                  port:/dev/ttyUSB0
                  channel:12
                  Wie bekomme ich diesen kleinen Sensor in mein Netzwerk eingebunden ?
                  Hat jemand einen Tipp für mich ?
                  danke 🙂
                  Gruß aus dem kühlen Keller
                  Tim
                  modelZigbee:TS0601
                  type:EndDevice
                  nwk:25184
                  manuf id:4742
                  manufacturer:_TZE200_npj9bug3
                  power:Battery
                  app version:149
                  hard version:1
                  zcl version:3
                  stack version:2
                  build:0122052017
                  interviewed:true
                  configured:true
                  endpoint:1
                  profile:260
                  input clusters:genBasic (0)
                  genIdentify (3)
                  msTemperatureMeasurement (1026)
                  msRelativeHumidity (1029)
                  genPowerCfg (1)
                  output clusters:genIdentify (3)
                  • Asgothian
                    Asgothian Developer @Sleepless135 last edited by
                    @sleepless135 dumm gefragt:
                    • welchen Adapter nutzt du ?
                    • in welcher Version ?
                    • ist genau dein Gerät sicher bei zigbee2mqtt.io als supported gelistet ?
                    A.
                      Homoran Global Moderator Administrators @Asgothian last edited by Homoran
                      @asgothian sagte in TS0601 Zigbee:
                      wenn es
                      @sleepless135 sagte in TS0601 Zigbee:
                      als Bodensendor sein soll, müsste es eins von diesen
                      sein
                      • Asgothian
                        Asgothian Developer @Homoran last edited by
                        @homoran sagte in TS0601 Zigbee:
                        Optimist.
                        Du unterschätzt das Chaos von TuYa gewaltig. Das kann ein beliebiges sein. Selbst wenn es so wie eines von denen aussieht heisst es nicht das es sich auch so betreiben lässt,
                        A.
                          Optimist
                          mistverständnis.
                          Das kommt davon wenn man zu schreibfaul ist.
                          Also neu:
                          Wenn @Sleepless135 tatsächlich einen Senso hätte, der
                          ist, müsste er einen der drei abgebildeten haben.
                          • Asgothian
                            leider nein.
                            • es gibt TuYa Geräte die unterschiedlich aussehen, sich aber gleich melden und auch gleich verhalten
                            • es gibt TuYa Geräte, die gleich aussehen, sich aber unterschiedlich melden und auch unterschiedlich verhalten.
                            Wirklich sicher sein kann man sich da nur dann wenn auch der Hersteller / Whitelabel Eintrag zusammen passt.
                            TuYa ist ein Sumpf.
                            A.
                            Sleepless135 1 Reply Last reply Reply Quote 1
                            • Sleepless135
                              Sleepless135 @Asgothian last edited by
                              @asgothian
                              Nabend,
                              mache meinen Namen mal Ehre 😄 Schlaflos aus der Nacht
                              https://www.zigbee2mqtt.io/devices/SNT858Z.html
                              das hier "sollte" er sein. Optik sieht zumindest gleich aus.
                              Zigbee Version ist 2.0.5
                              Screenshot 2025-07-03 001920.png Screenshot 2025-07-03 001856.png Screenshot 2025-07-03 002215.png
                                AlexHaxe @Sleepless135 last edited by
                                @sleepless135 said in TS0601 Zigbee:
                                zigbee-herdsman-converters Bibliothek hat dieses Gerät erst vor drei Wochen eingepflegt. Du musst also mindestens die Version 23.59.0 davon installiert haben, um eine Chance zu haben, dass es automatisch unterstützt wird.
                                Zigbee Adapter 2.0.5 ist da um Längen zu alt, um diese Version zu mitliefern (selbst die 3.0.1 reicht da nicht aus).
                                Lies Dir mal https://forum.iobroker.net/topic/80644/tester-zigbee-adapter-3-x-gesucht/173 durch, um auf Zigbee Adapter 3.x mit neuer zigbee-herdsman-converters Bibliothek upzudaten, und Dein Gerät zum Laufen zu bringen.
                                Alternativ: den Konverter aus der Bibliothek klauen und als externen Konverter im Adapter einbinden.
                                • Sleepless135
                                  Sleepless135 @AlexHaxe last edited by
                                  @alexhaxe
                                  Moin,
                                  bin noch nicht so tief im Zigbee Game drin, wie "sicher Bugfrei" ist denn der 3.0 er Adapter ?
                                  Ich würde ungern ein Beziehungskrieg beginnen für einen Sensor und Licht was nicht angeht 😄
                                  Tut mir leid für die Frage, wie gut und fix ist denn der Gid Support version oder lieber an der Version vom IO Broker bleiben ?
                                  Externer Link hatte ich schon irgendwo hier etwas gelesen, wie kann ich denn so etwas für denn Sensor dort einbringen ?
                                  Dachte mit der Version 2.XX bin ich gut dabei. DIe ist ja eigentlich auch erst vor ein paar Monaten raus gekommen.
                                  Homoran Asgothian 2 Replies Last reply Reply Quote 0
                                    Homoran Global Moderator Administrators @Sleepless135 last edited by
                                    aber
                                    @alexhaxe sagte in TS0601 Zigbee:
                                    • Asgothian
                                      @sleepless135 als aktiver zigbee adapter Entwickler rate ich dir aktuell nicht zum Update auf die GitHub Version.
                                      Nicht weil sie nicht gut oder stabil ist, aber weil ich auf mittlere Sicht keine bugs beheben kann. Wenn also etwas nicht geht dann geht es erst in 2 Monaten.
                                      A.
                                      • Sleepless135
                                        @asgothian
                                        Danke für deine Arbeit am Adapter !! An dich wird jetzt bei jedem Adapter Start gedacht 😉
                                        Eben mal ein Update auf 3.XX gemacht, danach waren alle Zigbee Geräte aus der Instanz verschwunden 😄 i Love my Backup 🙂
                                        Meine Frage, wie kann ich denn über dem externe Bibliothek dort etwas hinzufügen ?
                                        Weiß leider nicht mal welchen Begriff ich suchen muss, mein einziger Ansatz war TS0601 und der hat mich hier landen lassen.
                                        Homoran Eduard77 2 Replies Last reply Reply Quote 0
                                          hattest du denn auch den Haken bei "automatisch starten" gesetzt?
                                          Sleepless135 1 Reply Last reply Reply Quote 0
                                          • Sleepless135
                                            Sleepless135 @Homoran last edited by
                                            yes Adapter war online und ich konnte nach neuen Geräten suchen.
                                            Er hat nur leider keine Altgeräte die vorher in der Instanz waren übernommen.
                                            75
                                            13641
