    4. Test Adapter OpenLigaDB
    • Meister Mopper
      Meister Mopper @OliverIO last edited by
      😁 Ui, da hat sich jemand beim Datentypisieren offenbar vertan:
      • OliverIO
        OliverIO @Meister Mopper last edited by OliverIO
        @meister-mopper
        Probiere mal nochmal. Bei mir zeigt es ordentlich an.
        Evtl. Waren die gerade bei der Eingabe?
        • Meister Mopper
          @oliverio
          Habe den Adapter mal gestoppt und die Objekte gelöscht.
          Nach Adapterneustart beginnt die Saison nach wie vor am 16.05. 🤷‍♂️
          • OliverIO
            @meister-mopper
            Dann poste bitte die Konfiguration des Widgets (Widget Export)
            Sowie den Inhalt der eingestellten datenpunkte
            • Meister Mopper
              @oliverio
              Das Widget ist:
              [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-allmatches":"openligadb.0.bl1.2025.allmatches","oid-currgameday":"openligadb.0.bl1.2025.currgameday"},"style":{"left":"649px","top":"54px","color":"white","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"large"},"widgetSet":"openligadb"}]
              Datenpunkt ist currgameday.
              OliverIO 2 Replies Last reply Reply Quote 0
              • OliverIO
                @meister-mopper
                Allgames?
                Ach dein curgameday ist allgames.
                • OliverIO
                  @meister-mopper
                  Ah jetzt.
                  Die Berechnung von curgameday ist falsch. Da wird 34 berechnet.
                  Die Anzeige ist damit korrekt, weil es der 16.5.2026 ist.
                  Mal schauen, da ist ne Besonderheit von Corona drin, weil damals die Spieltage nicht wirklich immer squenziell abgeschlossen waren.
                  Evtl mach ich die wieder raus.
                  Ok, der aktuelle Spieltag wird aus der folgenden api entnommen
                  https://api.openligadb.de/getcurrentgroup/Bl1
                  Ergebnis ist 34
                  Beschreibung der api ist
                  /getcurrentgroup/{leagueShortcut}
                  Gibt die aktuelle Group (entspricht z.B. bei der Fussball-Bundesliga dem 'Spieltag') des als Parameter zu übergebenden leagueShortcuts (z.B. 'bl1') aus. Der aktuelle Spieltag
                  wird jeweils zur Hälfte der Zeit zwischen dem letzten Spiel des letzten Spieltages und dem ersten Spiel des nächsten Spieltages erhöht.
                  Also 17.5.2025 und 22.8.25
                  Also ab ca 5.7.2025 oder so, wenn ich richtig gerechnet habe, müsste dann da 1 kommen
                  D4vE 1 Reply Last reply Reply Quote 2
                  • D4vE
                    D4vE @OliverIO last edited by D4vE
                    @oliverio ist bei mir auch so 🙂
                    aber das nächste spiel stimmt schonmal nur das erste nicht ^^ mal gucken ob die das noch fixxen 🙂
                    • OliverIO
                      OliverIO @D4vE last edited by
                      @d4ve
                      Solange bei curgameday noch eine hohe Zahl drin steht, klappt die Berechnung nicht. Der 5.7. war grob geschätzt von mir.
                      In den nächsten Tagen wird da dann 1 drin stehen.
                      Muss mal schauen ob ich da etwas verbessere, aber aktuell sind die Prioritäten nicht bei den Adaptern ☀️😎🚴🏊
                      D4vE 1 Reply Last reply Reply Quote 0
                      • D4vE
                        @oliverio sagte in Test Adapter OpenLigaDB:
                        @d4ve
                        Supi ❤ ne das teil läuft schon super. und hilft mir sehr. danke für die gute Arbeit.
                        • OliverIO
                          OliverIO last edited by OliverIO
                          So, für bl1 2025/2026 steht jetzt 1 drin.
                          Jetzt passt alles.
                          Ich überlege mir aber mal was bei Gelegenheit.
                          https://github.com/oweitman/ioBroker.openligadb/issues/691
                          Meister Mopper 1 Reply Last reply Reply Quote 1
                          • Meister Mopper
                            @oliverio
                            Durch Zeitablauf erledigt 😊
                            Aus meiner Sicht musste da nüscht ändern.
                            • OliverIO
                              @meister-mopper
                              Ja, aber es hat schon verwirrt und ich kann schon rausfinden, wenn eine Liga generell noch nicht begonnen hat um das dann auf 1 zu setzen.
                              • OliverIO
                                Neue Version 1.9.0
                                • der Abruf erfolgt nun per axios
                                • zur Standardisierung wird nun eine Utility Klasse von mir eingesetzt
                                • Die Funktionsstruktur wurde zu einer Klasse umgearbeitet
                                • von callbacks wurde nun zu async/await gewechselt.
                                • Die Berechnung von Current Gameday, also der aktuelle Spieltag wurde verbessert. Bis zum ersten Spiel wird generell der Spieltag 1 angenommen. Danach wird der von openligadb bereitgestellte Wert verwendet. Der openligadb Wert hat in der Vergangenheit manchmal noch den letzten Spieltag der Vorgängersaison ergeben, da die API hier nicht saison spezifisch ist.
                                OliverIO 1 Reply Last reply Reply Quote 1
                                • OliverIO
                                  OliverIO @OliverIO last edited by
                                  Version wird nun demnächst im stable auftauchen
                                  Neue Version 1.9.0
                                  adapter openligadb test
                                  56
                                  687
                                  122609
