    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      martenn @EvilEls last edited by
      @evilels said in Adapter Worx Landroid v3.x.x:
      Nachdem meine Device retry-after: Sperre abgelaufen war (Support nerven), habe ich mir neue IP besorgt und auf https://id.worx.com/user/applications
      die Lagacy App rausgeschmissen.
      Dann im Adapter roten Button, danach Adapter gestartet:
      2025-07-04 00:18:13.524	info	Start Update for all devices
      2025-07-04 00:18:13.523	info	Request Counter: 1
      2025-07-04 00:18:13.244	info	Start check devices object!
      2025-07-04 00:18:13.082	info	Start MQTT connection
      2025-07-04 00:18:13.014	info	Autolock found! Create State : AutoLockTimer
      2025-07-04 00:18:13.013	info	Autolock found! Create State : AutoLock
      2025-07-04 00:18:13.005	info	ACS Module found! Create State : US.ACS_Status
      2025-07-04 00:18:13.002	info	ACS Module found! Create State : US.ACS
      2025-07-04 00:18:12.998	info	ACS Module found! Create State : US
      2025-07-04 00:18:12.991	info	Torque control found, create states...
      2025-07-04 00:18:12.632	info	Create product folder and states for WR165E
      2025-07-04 00:18:12.215	info	Create folder activityLog and set states.
      2025-07-04 00:18:12.204	info	No new Firmware found, create dummy states...
      2025-07-04 00:18:12.201	info	No new Firmware found, check states...
      2025-07-04 00:18:12.193	info	PartyModus found, create states...
      2025-07-04 00:18:12.191	info	OneTimeShedule found, create states...
      2025-07-04 00:18:12.168	info	DoubleShedule found, create states...
      2025-07-04 00:18:11.987	info	Multi-ZoneKeeper found! Create State : zoneKeeper
      2025-07-04 00:18:11.913	info	Found device M with id xxx
      2025-07-04 00:18:11.912	info	Found 1 devices
      2025-07-04 00:18:11.701	info	Connected to worx server
      2025-07-04 00:18:11.114	info	Start login
      2025-07-04 00:18:11.111	info	Login to worx
      2025-07-04 00:18:10.960	info	starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.7
      Kein Fehler mehr.
      Adapter Neustarts ebenfalls problemlos.
      Einstellungen über Adapter ändern klappt auch:
      2025-07-04 00:36:10.999	debug	Test Status: 1
      2025-07-04 00:36:10.966	debug	GET MQTT DATA from API: {xxx}
      2025-07-04 00:36:10.961	debug	Set new timestamp
      2025-07-04 00:36:10.961	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
      2025-07-04 00:36:10.960	debug	Request ID 57099 has been passed to the mower
      2025-07-04 00:36:10.960	debug	Worxcloud MQTT get Message for mower M (xxx)
      2025-07-04 00:36:10.960	debug	topic: PRM100/xxx/commandOut
      2025-07-04 00:36:10.960	debug	Mower MQTT: {xxx}
      2025-07-04 00:36:10.785	debug	Test Status: 1
      2025-07-04 00:36:10.762	debug	GET MQTT DATA from API: {xxx}
      2025-07-04 00:36:10.760	debug	Update this.deviceArray: 0
      2025-07-04 00:36:10.760	debug	Index Update: 0
      2025-07-04 00:36:10.561	info	Start Update for all devices
      2025-07-04 00:36:10.560	debug	Mower Endpoint : iot.eu-west-1.worxlandroid.com with user id xxx and mqtt registered true iot_registered true online true
      2025-07-04 00:36:10.558	debug	MQTT connected to: iot.eu-west-1.worxlandroid.com
      2025-07-04 00:36:10.557	debug	MQTT connection: {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}
      2025-07-04 00:36:10.229	debug	MQTT reconnect
      2025-07-04 00:36:09.228	debug	Offline
      2025-07-04 00:36:09.184	debug	sendData: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
      2025-07-04 00:36:09.184	debug	this.mqtt_response_check: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
      2025-07-04 00:36:09.177	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}}
      2025-07-04 00:36:09.176	debug	Start MQTT ping: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
      2025-07-04 00:36:09.176	debug	length: 0
      2025-07-04 00:36:09.176	info	Request Counter: 2
      2025-07-04 00:36:09.175	debug	Worxcloud MQTT sendMessage to xxx Message: {"sc":{ "m":1, "distm": 0}}
      2025-07-04 00:36:09.175	debug	state change: id_____ worx.0.xxx.mower.partyModus Mower xxx_____partyModus______{xxx}
      2025-07-04 00:36:09.174	debug	this.modules! {"xxx":{"edgeCut":false,"notify":true,"notify_excluded":["4","5","16","18"],"tq":0,"channel":true,"US":{"enabled":1},"al":{"lvl":0,"t":300},"al_last":300}}
      2025-07-04 00:36:09.174	debug	Request SN: xxx
      App ist seit Tagen deinstalliert.
      Nach Neuinstallation funktioniert diese auch wieder.
      Nachdem ich einen neuen Account erstellt hatte, war ich schon einmal so weit.
      Mal sehen, wie lange das nun funktioniert.
      Letztens hielt es für 3 oder 4 Tage.
      Habe vorhin genau diese Lösung ausprobiert und was soll ich sagen, ich kann wieder per App zugreifen. Den Adapter lasse ich aber zunächst einmal aus.
      • Q
        quinti last edited by
        Ich war etwa 10 Tage gesperrt. Adapter/App/Webseiten, überall 429.
        Seit Montag läuft bei mir wie alles.Was ich gemacht habe:
        -Iobroker Instanz gestoppt
        -App komplett gelöscht
        -Roboter ausgeschaltet.
        -3 komplette Tage alles ausgelassen und auch kein Einlogversuch gemacht.
        Dann habe mich zunächst auf der worx Seite eingelogt und hab etwas herumgesurft. Da das funktioniert hat, habe ich den Roboter wieder eingeschaltet und von Hand mähen lassen. Während dessen habe ich die App neu installiert. Die lief dann ohne "langsamer". Daten wurden brav angezeigt. Weil auch das geklappt hat, habe ich Adapter komplett gelöscht und die Version 3.2.6 neu installiert. Adapter startete ohne Probleme.
        Seit nun 5 Tagen läuft alles wieder ohne Fehler.
          bubus last edited by
          Das ist schön für euch, aber ich glaube, solange die Sperre nicht abgelaufen oder aufgehoben worden ist, kann ich machen, was ich will:
          Device retry-after: 58d - 10:12:10, zumindest läuft sie runter, hatte schon 62d 😀
          Auf die Antwort meiner 5. Konversation mit dem Suppert warte ich seit 2. Tagen.
          Heute den telefonischen Support gesprochen, das Problem wäre bekannt, es wird daran gearbeitet, ich soll bis Montag abwarten...
          Jetzt sperre ich dem Mäher vom Internet, lösche die App, stoppe den Adapter und warte bis Montag nach 17.00 Uhr.
          Ansonsten rufe ich Dienstag den Support wieder an.
            Lucky_ESA Developer Most Active @manny4566 last edited by
            @manny4566 sagte in Adapter Worx Landroid v3.x.x:
            @lucky_esa
            Hi, ja das klappt. Die Webseite geht und ich kann mich normal anmelden. Sie lädt auch schnell im Browser.
            Ganz es sein, dass der Adapter gebremst wird durch z.b. pihole? Der läuft bei mir.
            5000ms ist ja nicht wirklich viel.
            Am nächsten Tag kam der Fehler übrigens nicht mehr. Natürlich samt IP Wechsel in der Nacht.
            Diesen Timeout habe ich gewählt. Wenn du länger als 5 Sekunden benötigst dann stimmt was nicht mit deiner Internetverbindung. Du hast wahrscheinlich WLAN, oder?
              Lucky_ESA Developer Most Active @bubus last edited by
              @bubus sagte in Adapter Worx Landroid v3.x.x:
              Worx Support am besten 10 x pro Tag anrufen. Eine 72 Tage Sperrung ist echt nicht nett.
              Gruß//Lucky
              falke69 1 Reply Last reply Reply Quote 0
              • falke69
                falke69 @Lucky_ESA last edited by
                @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                Gruß//Lucky
                Guten Morgen @Lucky_ESA
                Da hast Du Dich aber noch gewählt ausgedrückt mit "nett".
                Ich finde das es komplett unverschämt ist, überhaupt eine Sperre zu verhängen, ohne den User vorher zu informieren, das er "zuviele" Anfragen stellt.
                Weiterhin könnte ich mir auch vorstellen, dass die weniger Mäher verkaufen würden, wenn man die Dinger nicht irgendwie in das eigene Smarthome System integrieren kann (auf welche Weise auch immer)
                Eine 72 Tage Sperre geht überhaupt nicht, ich würde dort permanent Terror machen auch wenn am Ende die an der Hotline nichts dafür können.
                • Ben1983
                  Ben1983 last edited by
                  Mit der App komme ich wieder drauf.
                  Den Adapter aus github installieren, oder ist er auf NPM?
                    bubus @falke69 last edited by bubus
                    Zitat falke69:
                    "Weiterhin könnte ich mir auch vorstellen, dass die weniger Mäher verkaufen würden, wenn man die Dinger nicht irgendwie in das eigene Smarthome System integrieren kann"
                    Nur deswegen habe ich mich für den Mäher entschieden!
                    Dr. Bakterius 1 Reply Last reply Reply Quote 1
                    • Dr. Bakterius
                      Dr. Bakterius Most Active @bubus last edited by
                      • EvilEls
                        @saeft_2003 sagte in Adapter Worx Landroid v3.x.x:
                        Der Iobroker darf keinen Zugriff auf die WORX Landroid APP haben.
                        Wenn Sie eine inoffizielle App, Software oder Suite nutzen, sollten Sie diese deinstallieren und vom Roboter trennen. Wir unterstützen nur die offizielle Worx-Landroid-App, die Sie im App Store/Play Store herunterladen können. Die meisten Apps von Drittanbietern können sich negativ auf die Servereinstellungen auswirken, sodass wir sie vorerst nicht unterstützen. Wir weisen darauf hin, dass einige dieser Apps von unseren Sicherheitssystemen als bösartig eingestuft werden könnten, was eine vorübergehende Sperrung des Kontos zur Folge hat.
                        Warum bieten sie dann eine Schnittstelle für Third-Party Apps an? 🤔
                        S falke69 2 Replies Last reply Reply Quote 1
                          saeft_2003 Most Active @EvilEls last edited by
                          @evilels
                          Genau das habe ich auch in meiner Antwort auf diese Mail geschrieben.
                          Zurück kam nur Standard blablabla das ich mich gedulden muss usw…
                          • falke69
                            falke69 @EvilEls last edited by
                            @evilels
                            Ich finde das es nur eine billige Austede ist.
                            Wenn es den Adapter für Iobroker nicht gäbe würden die Verlaufszahlen sicherlich bescheiden aussehen.
                            Und viele nutzen nur die App und bekommen den selben Mist als Antwort.
                            Die werden ein Problem mit der Cloud oder dem Anbieter der Cloud haben.
                            Alles kostet Geld.
                            Vielleicht haben die auch nur die abgespeckte Version genommen.
                            Aber egal. Es liegt an Worx und nicht an dem Adapter.
                            Ich war wie viele für eine Woche (andere länger) gesperrt und das hatte werder mit dem Adapter noch der App zu tun.
                            Worx hat hier eindeutig die Schuld und ist für den Mist verantwortlich!
                            Homoran M 2 Replies Last reply Reply Quote 1
                              Homoran Global Moderator Administrators @falke69 last edited by Homoran
                              @falke69 sagte in Adapter Worx Landroid v3.x.x:
                              naja, wenn die weltweit in 6 Jahren nur 3200 Mäher verkauft haben sähe es sowieso mau aus
                                manny4566 @falke69 last edited by
                                @falke69
                                Ich glaube der Adapter hat mal so null mit den Verkaufszahlen zu tun 😄
                                • falke69
                                  falke69 @manny4566 last edited by
                                  @manny4566
                                  Es kann jeder für sich entscheiden. Ich hätte mir zum Beispiel das Teil auch nicht gekauft,
                                  wenn ich das Teil nicht irgenwie integriegen hätte können.
                                  Wenn ich das richtig mitgebkommen habe gibt es bei Kress die selben Probleme.
                                  Ich finde immer noch, dass es nicht sein kann das die User ohne Vorwarnung gesperrt werden.
                                  Selbts wenn man 10 oder zwanzig Mäher in der App verwalten würde, würde man laut Worx gesperrt, weil man über seinen Account zu viele Anfragen stellt. Für mich persönlich immer noch unbereiflich und nicht nachvollziehbar.
                                  Ich persönlich habe nicht nur den Mäher, sondern auch noch andere Produkte von Worx, weil ich bisher zufrieden war und auch die Akkus untereinander tauschen konnte.
                                  Aber nach so einem Disaster, was die sich da geleistet haben und die User vor den Kopf gestoßen haben, werde ich warscheinlich nach dem Ablebem meines Mähers mich für einen anderen Hersteller entscheiden.
                                  Wie gesagt, das ist meine persönliche Meinung.
                                    HA, Alexa-Skill, AvaDeskApp?
                                    • BananaJoe
                                      BananaJoe Most Active @Homoran last edited by
                                      @homoran sagte in Adapter Worx Landroid v3.x.x:
                                      In Home Assistant sind es 7205:
                                      Also rund 10.000
                                      Hinzu kommen diejenigen welche z.B. die Pythonsskripte direkt nutzen bzw. andere Smarthome Systeme.
                                        huzzel @EvilEls last edited by
                                        @evilels Exakt so habe ich es nun auch gemacht, und aktuell läuft es.
                                        • fu_zhou
                                          fu_zhou last edited by
                                          ich habe eben mit meinem Arbeits-PC zuhause aber mit Tunnel auf id.worx.com zugreifen können um die Legacy Application zu löschen. Auf dem privaten Laptop kommt beim Zugriff 429, während ich mit dem getunnelten Laptop weiter zugreifen kann. Also scheint die Blockade doch etwas mit der IP zu tun zu haben und nicht (nur) mit dem eingeloggten Account, oder?
                                            bubus @fu_zhou last edited by
                                            @fu_zhou sagte in Adapter Worx Landroid v3.x.x:
                                            Das hält nicht lange, versuche es ein paar Mal.
                                            788
                                            122894
