    4. tap-adapters bleibt leer und zeigt Fehlermeldung
      Lollo_C @wendy2702 last edited by
      @wendy2702
      Okay, da werde ich mich mal einlesen. Muss für Heute aber Schluss machen. Morgen geht es weiter.
      Bisher vielen Dank für die Unterstützung.
      • mcm1957
        mcm1957 @Lollo_C last edited by mcm1957
        @lollo_c
        Ich glaub nicht dass da admin selbst oder der browser mitspielt. Da gibts ein Problem mit der Installation selbst.
        wenn iob diag keine Adapter listet stimmt was in der Installation selbst nicht.
        EDiT
        vermutung defeketes package.json gelöscht da ja npm ls funktioniert hat
        L wendy2702 2 Replies Last reply Reply Quote 0
          Lollo_C @mcm1957 last edited by
          @mcm1957
          Guten Morgen,
          die package.json ist vorhanden. Ihr Inhalt ist:
          {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=16.0.0"},"dependencies":{"iobroker.admin":"7.6.3","iobroker.backitup":"3.0.31","iobroker.devices":"1.1.5","iobroker.discovery":"5.0.0","iobroker.flot":"1.12.0","iobroker.hm-rega":"5.1.0","iobroker.hm-rpc":"2.0.2","iobroker.hmip":"1.27.0","iobroker.influxdb":"4.0.2","iobroker.javascript":"8.8.3","iobroker.js-controller":"7.0.6","iobroker.modbus":"6.3.2","iobroker.mqtt":"6.1.2","iobroker.nut":"1.6.0","iobroker.openweathermap":"1.1.2","iobroker.ping":"1.6.2","iobroker.rpi2":"2.4.0","iobroker.scenes":"3.2.3","iobroker.shelly":"8.5.1","iobroker.simple-api":"2.8.0","iobroker.smartmeter":"3.4.0","iobroker.socketio":"6.7.1","iobroker.sonos":"3.0.0","iobroker.telegram":"4.1.0","iobroker.tr-064":"4.3.0","iobroker.vis":"1.5.6","iobroker.vis-colorpicker":"2.0.3","iobroker.vis-inventwo":"3.3.4","iobroker.vis-jqui-mfd":"1.1.1","iobroker.vis-material":"0.2.0","iobroker.vis-materialdesign":"0.5.9","iobroker.vis-players":"0.1.6","iobroker.vis-timeandweather":"1.2.2","iobroker.web":"7.0.8","iobroker.ws":"2.6.2","iobroker.zigbee":"1.10.14"},"overrides":{"@iobroker/adapter-core":"^3.2.1"}}
          • wendy2702
            wendy2702 @mcm1957 last edited by wendy2702
            Hier stand Blödsinn.
            Gerade gesehen das im log installierte Adapter nur auf dem Slave diag ausgegeben werden.
              Lollo_C @Lollo_C last edited by
              Hallo Zusammen,
              hat keiner mehr eine Idee, wo ich suchen könnte?
              Ro75 1 Reply Last reply Reply Quote 0
              • Ro75
                Ro75 @Lollo_C last edited by
                @lollo_c wenn du ein aktuelles Backup hast, dann baue das System komplett neu auf - ist vielleicht effizienter und schneller.
                Ro75.
                • mcm1957
                  mcm1957 @Ro75 last edited by
                  Abrr VORSOCHT
                  Hab jetzt dein System nicht im Kopf. Wenn möglich installier auf be NEUE SD Karte od. SSD. Da dein System keibe Adapter anzeigt würd ich bis zum Gegenbeweis nicht drauf vertraun dass die Adapteringos im Backup landen.
                    @mcm1957
                    ich habe noch ein Image der Karte vom Januar, bei dem es lt. iob diag noch die Adapter angezeigt hat. Frage: Kann ich das einlegen und dann aktualisieren? Und wie verhält es sich dann mit dem Slave, der ja zwischenzeitlich auf einem neuen Stand ist? ... und kann ich dann ein aktuelles Backitup über die dann vorhandenen "alten" Daten einfach drüberziehen?
                    • mcm1957
                      @lollo_c
                      Wenn du SD Karten verwendest wütde ich eine aktuellr Neuinstallation nachen und das aktuellste Backup das du gast installieren.
                      Und dann mal schaun ob alles da ist.
                      Wenn nicht hast da ja weitethin die derzeitige Karte als Rückstieg.
                      ABER ich habe null Erfahrung mit Master Slave setups. Bittr warte bis jemand der sich damit auskennt sagt ob bzw eas da brsonderes zu brachten wäre.
                      Ich wollte nur auf.erksam machen dass ein heutr erstelltrs Backup ev nicht alles enthält da ja da Adaptertsb bzw iob diag auch nivhz alle Adapter anzeigt. Und da wär es blöd wenn du den IST Stand überschreibst.
                        Homoran Global Moderator Administrators @mcm1957 last edited by
                        @mcm1957 sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
                        ob bzw was da besonderes zu beachten wäre.
                        Wenn das Multihost System sauber aufgebaut wurde, sollte nach erneuter Kopplung des Slaves an den "neuen" Master der Slave automatisch auf den Stand des zurückgespielten Backups gehen.
                        Voraussetzung ist, dass beim Neuaufetzen der selbe Hostname beim Master verwendet word, der auch vor dem Backup existierte
                          Lollo_C @Homoran last edited by Lollo_C
                          @homoran sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
                          Wenn das Multihost System sauber aufgebaut wurde, ...
                          was hälts Du von der Idee eine Image vom Januar zu verwenden und darauf das Backup einzuspielen?
                            Homoran Global Moderator Administrators @Lollo_C last edited by
                            @lollo_c ich halte überhaupt nichts von "Images"
                            da sind sämtliche Dateileichen und sonstiger Müll mit drin.
                            Das wäre kein sauberer Neuaufbau
                              Dann frage ich mal anders. Ich habe das System vor einem Jahr erst neu aufgesetzt. Das war (für mich) dann doch schon etwas Arbeit, da ich auf dem Master neben dem ioBroker auch noch influxdb, Grafana, Mosquitto u.a. installiert habe.
                              Was ist denn, wenn ich jetzt ein Image, dass ich unmittelbar nach der Neuinstallation gemacht habe, verwende und darauf das Backup einspiele?
                              Homoran Ro75 2 Replies Last reply Reply Quote 0
                                @lollo_c sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
                                Was ist denn,
                                kann ich dir nicht sagen.
                                So eine Installation habe ich nicht, nur iobroker eigene Adapter (history/flot)
                                ich würde so etwas grundsätzlich trennen
                                auf mini-pc mit Proxmox in verschiedenen VMs, oder auf verschiedene RasPis
                                • Ro75
                                  Versuche es doch einfach. Im besten Fall funktioniert es, im schlimmsten nicht. Nimm aber bitte eine andere, neue SD Karte.
                                  Ro75.
                                    Lollo_C @Ro75 last edited by
                                    @ro75 sagte in tap-adapters bleibt leer und zeigt Fehlermeldung:
                                    Hallo Zusammen,
                                    kurzes Update: Auch mit dem Einspielen der Images bekam ich den "tab-adapters" nicht angezeigt. Ich konnte dann über Konsolenbefehle 4 Adapter auf dem Slave updaten. Danach funktionierte die Anzeige des "tab-adapters" plötzlich wieder und ich konnte auch dort über die Web-Ui 5 Adapter updaten. Dann kam wieder die besagte Fehlermeldung und der "tab-adapters" wurde nicht mehr angezeigt.
                                    Gestern habe ich dann zufällig festgestellt, dass die Adapter wieder normal angezeigt werden. Da fiel mir ein, das ich vor ein paar Tagen die Fritz-Box auf Grund eines Netzwerkfehlers neu starten musste.
                                    Jetzt mein Gedanke: Kann es sein, das der "tab-adapters" die Fehlermeldung
                                    Cannot get adapters info: TypeError: Cannot create property 'rating' on string '<'
                                    bringt, wenn der Zugriff auf eine (welche?) externe URL nicht möglich ist?
                                      Das wäre das Repo/die Adapterbewertung.
                                      Sollte aber nicht zum "Nicht-Anzeigen" führen, sondern nur Info, dass dies nicht aktuell ist
                                      2052
