    4. Fully Browser verbinden sich nicht mehr *gelöst*
      gluecksmann last edited by gluecksmann
      Hallo, meine 3 Tablets verbinden sich nicht mehr mit dem FullyBrowser. Bin mir keiner Schuld bewusst was geändert zu haben. System sollte aktuell sein.
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.20+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       08:26:32 up  5:26,  4 users,  load average: 0.60, 0.42, 0.44
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-07-06 08:26:32 CEST
                 Universal time: Sun 2025-07-06 06:26:32 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.2G        3.2G        3.6G         20M        1.7G        5.0G
      Swap:           209M          0B        209M
      Total:          8.4G        3.2G        3.8G
      Active iob-Instances:   36
               7809 M total memory
               3016 M used memory
               3301 M active memory
                778 M inactive memory
               3406 M free memory
                141 M buffer memory
               1434 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 08:26:33 up  5:26,  4 users,  load average: 0.60, 0.42, 0.44
      Tasks: 254 total,   4 running, 250 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7809.4 total,   3405.9 free,   3015.9 used,   1577.1 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4793.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     781M  1.3M  780M   1% /run
      /dev/mmcblk0p2 ext4       58G   13G   43G  22% /
      tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   77M  434M  16% /boot/firmware
      tmpfs          tmpfs     781M   48K  781M   1% /run/user/1000
      Show mounted filesystems:
      TARGET               SOURCE         FSTYPE      OPTIONS
      /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
      |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.3G    /var/
      1.1G    /var/log/journal/4577005cbad945408993919bfbab79bf
      1.1G    /var/log
      777M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      667M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      573M    /opt/iobroker/iobroker-data/
      359M    /opt/iobroker/iobroker-data/files
      90M     /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      80M     /opt/iobroker/iobroker-data/influxdata.json
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/states.jsonl
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.3-1nodesource1
        Version table:
           20.19.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
       *** 20.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 4264)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.ankersolix2.0            : ankersolix2           : raspberrypi                              -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
        system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
      + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
      + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
      + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
        system.adapter.history.0                : history               : raspberrypi                              - disabled
      + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
      + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
      + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
      + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
      + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
      + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
      + system.adapter.signifylights.0          : signifylights         : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.2
      Adapter    "awtrix-light" : 1.7.0    , installed 1.7.0
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.1.16 [Updatable]
      Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
      Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "hue"          : 3.16.1   , installed 3.16.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
      Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 10.0.0   , installed 10.0.0
      Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
      Adapter    "signifylights": 1.0.0    , installed 1.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        12220
      States:         10030
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 216
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       484961     570378/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8337       789/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7620       777/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       485424     570043/iobroker.js-
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       485419     570043/iobroker.js-
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7619       777/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8339       789/sshd: /usr/sbin
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        8934       1107/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       485011     570447/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       486430     570061/io.admin.0
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       486518     570151/io.sonos.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      112        12501      1267/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6564       576/avahi-daemon: r
      udp        0      0 0.0.0.0:34045           0.0.0.0:*                           104        6566       576/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       484191     570307/io.shelly.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       486689     570318/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       486690     570318/io.tuya.0
      udp        0      0 0.0.0.0:60626           0.0.0.0:*                           1001       484860     570258/io.philips-a
      udp        0      0 0.0.0.0:36461           0.0.0.0:*                           1001       484160     570273/io.philips-a
      udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       487606     570626/io.musiccast
      udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          8633       712/NetworkManager
      udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          6959       712/NetworkManager
      udp6       0      0 :::37802                :::*                                104        6567       576/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        6565       576/avahi-daemon: r
      2025-07-06 08:27:19.111  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.timerMinutes" has to be type "number" but received type "string"
      2025-07-06 08:27:19.167  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.preFilterCleanInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:19.215  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:19.268  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:23.496  - warn: fullybrowser.0 (577073) [REST] 192.168.2.176: Sending command get axiosGetDevicesInfo  failed: No response
      2025-07-06 08:27:23.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
      2025-07-06 08:27:25.500  - warn: fullybrowser.0 (577073) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
      2025-07-06 08:27:25.546  - error: fullybrowser.0 (577073) [REST] 192.168.2.206: Sending command first Login  failed: Error: Please login
      2025-07-06 08:27:28.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
      2025-07-06 08:27:32.895  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.lightBrightness" has to be type "number" but received type "string"
      2025-07-06 08:27:32.944  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
      2025-07-06 08:27:33.001  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.allergenIndex" has to be type "number" but received type "string"
      2025-07-06 08:27:33.048  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.childLock" has to be type "boolean" but received type "string"
      2025-07-06 08:27:33.146  - info: philips-air.1 (570273) State value to set for "philips-air.1.device.uptime" has to be type "number" but received type "string"
      2025-07-06 08:27:33.208  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.pm25" has to be type "number" but received type "string"
      2025-07-06 08:27:33.273  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.timerHours" has to be type "number" but received type "string"
      2025-07-06 08:27:33.321  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.timerMinutes" has to be type "number" but received type "string"
      2025-07-06 08:27:33.383  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.preFilterCleanInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:33.433  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:33.480  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
      2025-07-06 08:27:33.496  - warn: fullybrowser.0 (577073) [REST] 192.168.2.176: Sending command get axiosGetDevicesInfo  failed: No response
      2025-07-06 08:27:33.851  - error: govee.0 (570544) AxiosError: Request failed with status code 429
      2025-07-06 08:27:35.500  - warn: fullybrowser.0 (577073) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
      2025-07-06 08:27:35.583  - error: fullybrowser.0 (577073) [REST] 192.168.2.206: Sending command first Login  failed: Error: Please login
      2025-07-06 08:27:38.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
      iob diag has finished.
      Thomas Braun Z BananaJoe 3 Replies Last reply Reply Quote 0
      • wendy2702
        wendy2702 last edited by
        Sind die Tablets denn unter den IP Adressen vom iobroker aus per Ping erreichbar?
          Thomas Braun Most Active @gluecksmann last edited by Thomas Braun
          @gluecksmann sagte in Fully Browser verbinden sich nicht mehr:
          HUST
          Updates fahren.
          Solltest du auch umstellen:
          vis läuft nicht.
          • Z
            zahnheinrich @gluecksmann last edited by
            @gluecksmann
            Schuss ins blaue:
            Mqtt Einstellungen im iobroker und/oder auf den tablets falsch
            • BananaJoe
              BananaJoe Most Active @gluecksmann last edited by BananaJoe
              @gluecksmann Testen ob du die 3 Tablets denn auch über deren IP-Adresse und Port 2323 erreichen kannst,
              dann ob bei denen MQTT eingestellt ist.
              Und dann ob die Adapter Einstellungen passen (MQTT oder http mode etc.)
              Eventuell hast du ja auch noch etwas anderes gemacht und die 3 Tablets haben jetzt neue IP-Adressen per DHCP bekommen
                @bananajoe
                Hallo, habe Updates gefahren. Neu gestartet, Passwörter neu gesetzt ect. Irgendwas hat geholfen. Ich danke für die Unterstützung.
                  Homoran Global Moderator Administrators @gluecksmann last edited by
                  @gluecksmann sagte in Fully Browser verbinden sich nicht mehr *gelöst*:
                  @thomas-braun sagte in Fully Browser verbinden sich nicht mehr *gelöst*:
                  vis läuft nicht.
                  wird jetzt wohl laufen
