    4. [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren
      Honnkoponko @JoSbg last edited by Honnkoponko
      ich habe Lösung gefunden
      • wendy2702
        wendy2702 @Honnkoponko last edited by
        @honnkoponko sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
        Aha, und wofür?
          Honnkoponko @wendy2702 last edited by
          @wendy2702
          ich hatte Problem mit v1.x zu 2.x update.
          Musste mehrmals neu installieren aber am Ende hat geklappt und funtkioniert jetzt 🙂
            tklein last edited by
            hi,
            ich kann auf proxmox auf meiner linux ct keine influxdb installieren.
            The repository 'https://repos.influxdata.com/debian stable InRelease' is not signed.
            kommt, nachdem ich folgendes gemacht habe:
            influxdb login: root
            Password:
            Linux influxdb 6.8.12-1-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-1 (2024-08-05T16:17Z) x86_64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Mon Jul  7 15:59:12 UTC 2025 on tty1
            root@influxdb:~# sudo
            -bash: sudo: command not found
            root@influxdb:~# get update
            -bash: get: command not found
            root@influxdb:~# uname -m
            x86_64
            root@influxdb:~# cat /etc/debian_version
            12.11
            root@influxdb:~# getconf LONG_BIT
            64
            root@influxdb:~# cat /etc/*release
            PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
            NAME="Debian GNU/Linux"
            VERSION_ID="12"
            VERSION="12 (bookworm)"
            VERSION_CODENAME=bookworm
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            root@influxdb:~# wget -q https://repos.influxdata.com/influxdata-archive_compat.key
            root@influxdb:~# echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
            root@influxdb:~# echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | tee /etc/apt/so
            root@influxdb:~# cat influxdata-archive_compat.key | gpg --dearmor | tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
            -bash: gpg: command not found
            root@influxdb:~# install gpg
            install: missing destination file operand after 'gpg'
            Try 'install --help' for more information.
            root@influxdb:~# apt install gnupg
            Reading package lists... Done
            Building dependency tree... Done
            The following additional packages will be installed:
              dirmngr gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm libassuan0 libksba8 libnpth0 pinentry-curses
            Suggested packages:
              dbus-user-session pinentry-gnome3 tor parcimonie xloadimage scdaemon pinentry-doc
            The following NEW packages will be installed:
              dirmngr gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm libassuan0 libksba8 libnpth0 pinentry-curses
            0 upgraded, 14 newly installed, 0 to remove and 0 not upgraded.
            Need to get 7881 kB of archives.
            After this operation, 16.0 MB of additional disk space will be used.
            Do you want to continue? [Y/n] Y
            Get:1 http://deb.debian.org/debian bookworm/main amd64 libassuan0 amd64 2.5.5-5 [48.5 kB]
            Get:2 http://deb.debian.org/debian bookworm/main amd64 gpgconf amd64 2.2.40-1.1 [564 kB]
            Get:3 http://deb.debian.org/debian bookworm/main amd64 libksba8 amd64 1.6.3-2 [128 kB]
            Get:4 http://deb.debian.org/debian bookworm/main amd64 libnpth0 amd64 1.6-3 [19.0 kB]
            Get:5 http://deb.debian.org/debian bookworm/main amd64 dirmngr amd64 2.2.40-1.1 [792 kB]
            Get:6 http://deb.debian.org/debian bookworm/main amd64 gnupg-l10n all 2.2.40-1.1 [1093 kB]
            Get:7 http://deb.debian.org/debian bookworm/main amd64 gnupg-utils amd64 2.2.40-1.1 [927 kB]
            Get:8 http://deb.debian.org/debian bookworm/main amd64 gpg amd64 2.2.40-1.1 [949 kB]
            Get:9 http://deb.debian.org/debian bookworm/main amd64 pinentry-curses amd64 1.2.1-1 [77.4 kB]
            Get:10 http://deb.debian.org/debian bookworm/main amd64 gpg-agent amd64 2.2.40-1.1 [695 kB]
            Get:11 http://deb.debian.org/debian bookworm/main amd64 gpg-wks-client amd64 2.2.40-1.1 [541 kB]
            Get:12 http://deb.debian.org/debian bookworm/main amd64 gpg-wks-server amd64 2.2.40-1.1 [531 kB]
            Get:13 http://deb.debian.org/debian bookworm/main amd64 gpgsm amd64 2.2.40-1.1 [671 kB]
            Get:14 http://deb.debian.org/debian bookworm/main amd64 gnupg all 2.2.40-1.1 [846 kB]
            Fetched 7881 kB in 12s (641 kB/s)
            Selecting previously unselected package libassuan0:amd64.
            (Reading database ... 19137 files and directories currently installed.)
            Preparing to unpack .../00-libassuan0_2.5.5-5_amd64.deb ...
            Unpacking libassuan0:amd64 (2.5.5-5) ...
            Selecting previously unselected package gpgconf.
            Preparing to unpack .../01-gpgconf_2.2.40-1.1_amd64.deb ...
            Unpacking gpgconf (2.2.40-1.1) ...
            Selecting previously unselected package libksba8:amd64.
            Preparing to unpack .../02-libksba8_1.6.3-2_amd64.deb ...
            Unpacking libksba8:amd64 (1.6.3-2) ...
            Selecting previously unselected package libnpth0:amd64.
            Preparing to unpack .../03-libnpth0_1.6-3_amd64.deb ...
            Unpacking libnpth0:amd64 (1.6-3) ...
            Selecting previously unselected package dirmngr.
            Preparing to unpack .../04-dirmngr_2.2.40-1.1_amd64.deb ...
            Unpacking dirmngr (2.2.40-1.1) ...
            Selecting previously unselected package gnupg-l10n.
            Preparing to unpack .../05-gnupg-l10n_2.2.40-1.1_all.deb ...
            Unpacking gnupg-l10n (2.2.40-1.1) ...
            Selecting previously unselected package gnupg-utils.
            Preparing to unpack .../06-gnupg-utils_2.2.40-1.1_amd64.deb ...
            Unpacking gnupg-utils (2.2.40-1.1) ...
            Selecting previously unselected package gpg.
            Preparing to unpack .../07-gpg_2.2.40-1.1_amd64.deb ...
            Unpacking gpg (2.2.40-1.1) ...
            Selecting previously unselected package pinentry-curses.
            Preparing to unpack .../08-pinentry-curses_1.2.1-1_amd64.deb ...
            Unpacking pinentry-curses (1.2.1-1) ...
            Selecting previously unselected package gpg-agent.
            Preparing to unpack .../09-gpg-agent_2.2.40-1.1_amd64.deb ...
            Unpacking gpg-agent (2.2.40-1.1) ...
            Selecting previously unselected package gpg-wks-client.
            Preparing to unpack .../10-gpg-wks-client_2.2.40-1.1_amd64.deb ...
            Unpacking gpg-wks-client (2.2.40-1.1) ...
            Selecting previously unselected package gpg-wks-server.
            Preparing to unpack .../11-gpg-wks-server_2.2.40-1.1_amd64.deb ...
            Unpacking gpg-wks-server (2.2.40-1.1) ...
            Selecting previously unselected package gpgsm.
            Preparing to unpack .../12-gpgsm_2.2.40-1.1_amd64.deb ...
            Unpacking gpgsm (2.2.40-1.1) ...
            Selecting previously unselected package gnupg.
            Preparing to unpack .../13-gnupg_2.2.40-1.1_all.deb ...
            Unpacking gnupg (2.2.40-1.1) ...
            Setting up libksba8:amd64 (1.6.3-2) ...
            Setting up libnpth0:amd64 (1.6-3) ...
            Setting up libassuan0:amd64 (2.5.5-5) ...
            Setting up gnupg-l10n (2.2.40-1.1) ...
            Setting up gpgconf (2.2.40-1.1) ...
            Setting up gpg (2.2.40-1.1) ...
            Setting up gnupg-utils (2.2.40-1.1) ...
            Setting up pinentry-curses (1.2.1-1) ...
            Setting up gpg-agent (2.2.40-1.1) ...
            Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-browser.socket -> /usr/lib/systemd/user/gpg-agent-browser.socket.
            Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-extra.socket -> /usr/lib/systemd/user/gpg-agent-extra.socket.
            Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-ssh.socket -> /usr/lib/systemd/user/gpg-agent-ssh.socket.
            Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent.socket -> /usr/lib/systemd/user/gpg-agent.socket.
            Setting up gpgsm (2.2.40-1.1) ...
            Setting up dirmngr (2.2.40-1.1) ...
            Created symlink /etc/systemd/user/sockets.target.wants/dirmngr.socket -> /usr/lib/systemd/user/dirmngr.socket.
            Setting up gpg-wks-server (2.2.40-1.1) ...
            Setting up gpg-wks-client (2.2.40-1.1) ...
            Setting up gnupg (2.2.40-1.1) ...
            Processing triggers for man-db (2.11.2-2) ...
            Processing triggers for libc-bin (2.36-9+deb12u10) ...
            root@influxdb:~# apt install lsb-release
              lsb-release
            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
            Need to get 6416 B of archives.
            After this operation, 17.4 kB of additional disk space will be used.
            Get:1 http://deb.debian.org/debian bookworm/main amd64 lsb-release all 12.0-1 [6416 B]
            Fetched 6416 B in 10s (626 B/s)
            Selecting previously unselected package lsb-release.
            (Reading database ... 19392 files and directories currently installed.)
            Preparing to unpack .../lsb-release_12.0-1_all.deb ...
            Unpacking lsb-release (12.0-1) ...
            Setting up lsb-release (12.0-1) ...
            root@influxdb:~# apt update && apt install -y influxdb2
            Hit:1 http://security.debian.org bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Get:4 https://repos.influxdata.com/debian stable InRelease [6907 B]
            Err:4 https://repos.influxdata.com/debian stable InRelease
              The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            W: GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
            E: The repository 'https://repos.influxdata.com/debian stable InRelease' is not signed.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            **root@influxdb:~# apt update**
            **root@influxdb:~# apt install influxdb2**
            E: Unable to locate package influxdb2
            was kann ich machen?
              Thomas Braun Most Active @tklein last edited by
              @tklein
              Was veranstaltest du da? Und dann noch mit vollem root-Zugang.
                tklein @Thomas Braun last edited by
                @thomas-braun kann es halt (noch) nicht besser.
                was/wie kann ich besser machen. hatte eine frische ct angelegt. dann wollte ich influxdb2 installieren, damit ich die daten aus meinem iobroker in die db schreiben kann.
                viele videos/tut haben bei mir nicht geklappt. 😞
                  @tklein sagte in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                  Zunächst legt man sich einen User an, den man statt des root verwendet.
                  Wie das geht steht u.a. in der Anleitung, wie man man den ioBroker richtig auf einem lxc installiert.
                  Und mit diesem user funktionieren dann auch die Befehle von hier:
                  https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                  Vorausgesetzt, dass gpg usw. bereits vorhanden ist. Ist bei richtigen Installationen der Fall, bei Containern halt nicht unbedingt. (Weswegen ich auch Container nicht für Linux-Anfänger empfehlen würde...)
                    @thomas-braun den iob hatte ich auch als ct angelegt. das hat soweit geklappt. für influxdb wollte ich eine separate installation.
                    dann werde ich mal schauen wie ich linux als lxc installiert bekomme.
                    danke dir für deine hilfe!
                      Aber deine Turnübungen da oben waren doch im ioBroker-Container, oder nicht?
                        @thomas-braun nee, die baucghlandung waren im influx ct
                          LXC IST ein LinuXContainer. Was willst du denn da 'Linux' installieren?
                            @thomas-braun sorry habe da CT/VM und LxC durcheinandergeworfen
                              @thomas-braun said in [HowTo] InfluxDB 2.1 auf Debian 11 (proxmox CT) installieren:
                              --> welche Anleitung kannst du empfehlen. Finde oft nur welche, wo mit curl die Scriptdatei aufgerufen wird
                              --> was würdest du empfehlen?
                                Und genau das (neben dem wirren Zeug von weiter oben) zeigt mir, das du nicht im entferntesten weißt, was du da warum veranstaltest.
                                Im jedem Beruf, Hobby, Sport oder sonst im Leben startest du auch nicht in der Profiklasse sondern musst dir die Grundlagen drauf schaffen und erstmal in den Einsteigerklassen etwas Luft schnupperrn.
                                Nur bei IT-Themen scheint das nicht erforderlich zu sein. Klar, tut ja auch nicht weh, wenn die Kiste total schief gegen die Wand fährt. Zieht man halt den nächsten Container aus dem Hut, kost ja nix.
                                Ich würde empfehlen, erstmal mit einem Raspberry oder ähnlichem zu lernen. Und wenn du da sattelfest bist und solche Grundlagen wie 'Navigation durch das Dateisystem', 'Paketmanager' usw. drauf hast, dann würde ich mir einen LXC oder sowas ans Bein binden.
                                  @tklein
                                  Installation von z. B. ioBroker in einem LXC ist hier ausführlich beschrieben.
                                  Inklusive der Anlage eines users mit sudo-Recht.
                                  https://www.iobroker.net/#de/documentation/install/proxmox.md
                                    @thomas-braun danke
                                    131
                                    32595
