    3. Cloud Dienste
    4. Kein Anmelden am Alexa Adapter mehr möglich
      Thomas Braun Most Active @Balkonfarmer last edited by
      @balkonfarmer
      Ja, hier rein, den vielen Text.
        Balkonfarmer @Thomas Braun last edited by
        ========== Start marking the full check here ===========
        Script v.2025-03-08
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         16:03:56 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-07-07 16:03:56 CEST
                   Universal time: Mon 2025-07-07 14:03:56 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:            3.8G        1.2G        2.2G        0.0K        360M        2.8G
        Swap:            99M          0B         99M
        Total:          3.9G        1.2G        2.3G
        Active iob-Instances:   22
                 3793 M total memory
                 1207 M used memory
                  912 M active memory
                  527 M inactive memory
                 2224 M free memory
                   58 M buffer memory
                  302 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 16:03:57 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
        Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  5.6 us,  7.0 sy,  0.0 ni, 87.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3793.3 total,   2224.6 free,   1207.4 used,    361.3 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2828.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       15G  5.3G  8.4G  39% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  836K  758M   1% /run
        /dev/sda1      vfat      253M   51M  202M  20% /boot
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Mon Jul  7 13:38:05 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a97293b6-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Mon Jul  7 13:38:08 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Jul  7 13:38:08 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Mon Jul  7 13:38:10 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
        /var:
        2.0G    /var/
        1.5G    /var/log/journal/faf0bbffdeae42ee938bcf9ac7b405cd
        1.5G    /var/log
        345M    /var/cache
        Archived and active journals take up 1.4G in the file system.
        /opt/iobroker/backups:
        42M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        587M    /opt/iobroker/iobroker-data/
        231M    /opt/iobroker/iobroker-data/files
        220M    /opt/iobroker/iobroker-data/Luftdaten
        96M     /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
        12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
        9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
        7.6M    /opt/iobroker/iobroker-data/objects.json.migrated
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        nodejs:                 N/A
        /usr/bin/node           v14.21.3
        /usr/bin/npm            6.14.18
        /usr/bin/npx            6.14.18
        /usr/bin/corepack       0.15.1
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 14.21.3-deb-1nodesource1
          Candidate: 14.21.3-deb-1nodesource1
          Version table:
         *** 14.21.3-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u7 500
                500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Hosts:
        raspberrypi         raspberrypi (version: 4.0.24, hostname: raspberrypi   , alive, uptime: 8750)
        Core adapters versions
        js-controller:  4.0.24
        admin:          5.3.8
        javascript:     5.7.0
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
        + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
        + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
        + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
          system.adapter.nina.0                   : nina                  : raspberrypi                              - disabled
          system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
        + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.78
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Stable (default)
        Installed ioBroker-Adapters
        Used repository: Stable (default)
        Adapter    "admin"        : 7.6.17   , installed 5.3.8  [Updatable]
        Adapter    "alexa2"       : 3.26.5   , installed 3.11.2 [Updatable]
        Adapter    "backitup"     : 3.2.2    , installed 2.4.9  [Updatable]
        Adapter    "broadlink2"   : 2.3.0    , installed 2.0.3  [Updatable]
        Adapter    "chromecast"   : 4.0.0    , installed 2.3.1  [Updatable]
        Adapter    "discovery"    : 5.0.0    , installed 3.0.3  [Updatable]
        Adapter    "email"        : 2.0.4    , installed 1.1.3  [Updatable]
        Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
        Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
        Adapter    "history"      : 3.0.1    , installed 1.11.1 [Updatable]
        Adapter    "hmip"         : 1.27.0   , installed 1.17.0 [Updatable]
        Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
        Adapter    "iot"          : 3.3.0    , installed 1.11.4 [Updatable]
        Adapter    "javascript"   : 8.9.2    , installed 5.7.0  [Updatable]
        Controller "js-controller": 7.0.6    , installed 4.0.24 [Updatable]
        Adapter    "luftdaten"    : 4.0.0    , installed 2.2.4  [Updatable]
        Adapter    "meross"       : 1.17.0   , installed 1.12.0 [Updatable]
        Adapter    "mqtt"         : 6.1.2    , installed 3.0.6  [Updatable]
        Adapter    "mqtt-client"  : 3.0.0    , installed 1.6.2  [Updatable]
        Adapter    "nina"         : 0.0.25   , installed 0.0.25
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
        Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
        Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
        Adapter    "simple-api"   : 2.8.0    , installed 2.7.0  [Updatable]
        Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
        Adapter    "sonoff"       : 3.1.2    , installed 2.5.1  [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.2.16 [Updatable]
        Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
        Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
        Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
        Adapter    "vis-hqwidgets": 1.5.1    , installed 1.2.0  [Updatable]
        Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
        Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
        Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
        Objects and States
        Objects:        4815
        States:         3719
        Get:1 http://giteduberger.fr rpimonitor/ InRelease [1933 B]
        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
        Fetched 1933 B in 1s (1653 B/s)
        Reading package lists...
        Pending Updates: 28
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          3867       569/perl
        tcp        0      0 192.168.178.78:1883     0.0.0.0:*               LISTEN      1001       17575      1175/io.sonoff.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3838       532/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        13895      508/redis-server 12
        tcp        0      0 0.0.0.0:34675           0.0.0.0:*               LISTEN      1001       732532     12412/io.alexa2.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14849      545/iobroker.js-con
        tcp6       0      0 :::22                   :::*                    LISTEN      0          3840       532/sshd: /usr/sbin
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21035      2085/io.socketio.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17140      1851/io.simple-api.
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14940      591/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21983      2438/io.web.0
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        13896      508/redis-server 12
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18476      1266/io.chromecast.
        udp        0      0 192.168.178.78:5353     0.0.0.0:*                           1001       15953      1192/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13833      389/avahi-daemon: r
        udp        0      0 0.0.0.0:46726           0.0.0.0:*                           108        13835      389/avahi-daemon: r
        udp        0      0 0.0.0.0:57137           0.0.0.0:*                           1001       18452      1244/io.broadlink2.
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3893       795/dhcpcd
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18450      1244/io.broadlink2.
        udp6       0      0 :::5353                 :::*                                108        13834      389/avahi-daemon: r
        udp6       0      0 :::36482                :::*                                108        13836      389/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14908      795/dhcpcd
        2025-07-07 16:01:28.952  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:01:38.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:01:48.986  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:01:58.978  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:09.029  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:14.063  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751896934062_9433
        2025-07-07 16:02:18.997  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:28.974  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:48.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:02:58.969  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:09.018  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:14.264  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
        2025-07-07 16:03:18.995  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:28.981  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:45.085  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751897025083_575
        2025-07-07 16:03:49.008  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:03:58.972  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:04:09.012  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:04:19.001  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:04:28.975  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:04:39.016  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        2025-07-07 16:04:45.115  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
        2025-07-07 16:04:48.982  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
        iob diag has finished.
          Thomas Braun Most Active @Balkonfarmer last edited by Thomas Braun
          @balkonfarmer
          Kannste sinnvoll nur komplett Neuinstallieren.
          Zuerst den ioBroker samt Unterbau auf einen aktuellen Stand bringen.
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
          iob stop
          iob fix
          iob nodejs-update 20
          iob update
          iob upgrade all
          iob upgrade self
          iob update
          iob upgrade all
          iob start
          Dann davon ein Backup ziehen und mit dem auf ein frisch installiertes RaspberryOS 12 'Bookworm' in der 64Bit-Lite-Version umziehen.
            Da habe ich einige Probleme:
            • kann ich die Skripte sichern? So dass ich sie in die Neuinstallation integrieren kann.
            • der Adapter Broadlink ist mir sehr wichtig. Leider habe ich die Fernbedienungen nicht mehr und die Funkcodes liegen nur noch in den Objekten vor. (die könnte ich notfalls händisch kopieren,aber das macht viel Arbeit)
            • kann ich VIS irgendwie übernehmen?
              @balkonfarmer sagte in Kein Anmelden am Alexa Adapter mehr möglich:
              Geht mit dem Backitup-Adapter.
              Kann ich ja nix zu.
              Lass einfach Kiste künftig nicht mehr so versumpfen, dann ist das auch alles viel leichter handlebar.
                @thomas-braun Ich danke Dir schonmal. Das werde ich morgen mal in Angriff nehmen.
                  @thomas-braun sagte in Kein Anmelden am Alexa Adapter mehr möglich:
                  @balkonfarmer
                  Das habe ich nun getan, aber nachdem ich das Backup wiederhergestellt habe, komme ich nicht mehr auf die Oberfläche von IoBroker.
                  Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Ro75
                    Ro75 @Balkonfarmer last edited by
                    @balkonfarmer wie lange hast du gewartet? 5 Minuten oder eine Stunde? Aber das gehört nicht hier her.
                    Ro75.
                      Balkonfarmer @Ro75 last edited by
                      @ro75 Ich hab gewartet, bis sich das Fenster geschlossen hat. Das war nach ein paar Minuten.
                      Wohin soll ich es denn posten, ich habe ihm ja nur geantwortet.
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Ro75
                        du warst zu schnell. Da hat gerade erst die Wiederherstellung begonnen. Du musst warten, ruhig ne Stunde.
                        Ro75.
                          Kann eine Stunde dauern, kann aber im logfile beobachtet werden
                          iob logs --watch
                          Wenn das dann da ruhig ist kommst du auch wieder auf den Admin, sonst ggfls den Admin von Hand starten, wenn alle Stricke reißen per
                          iob diag
                          den Zustand prüfen.
                          B 3 Replies Last reply Reply Quote 0
                            @ro75
                            Das Backup zu erstellen hat auch nur so kurz gedauert.
                            Das ist auch der Grund, warum ich kaum Updates gemacht habe, denn immer war irgendwas. Ich bin jetzt mit meinem Latein am Ende.
                              iob logs --watch
                              Der sagt im Log immer das gleiche
                              2025-07-09 17:37:21.843  - error: host.PiHole No connection to databases possibl                 e, restart
                              2025-07-09 17:37:21.863  - info: host.PiHole iobroker _restart
                              2025-07-09 17:37:28.057  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                              2025-07-09 17:37:28.063  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                              2025-07-09 17:37:28.065  - info: host.PiHole hostname: PiHole, node: v20.19.3
                              2025-07-09 17:37:28.066  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                              2025-07-09 17:37:58.080  - error: host.PiHole No connection to databases possibl                 e, restart
                              2025-07-09 17:37:58.101  - info: host.PiHole iobroker _restart
                              2025-07-09 17:38:04.320  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                              2025-07-09 17:38:04.328  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                              2025-07-09 17:38:04.329  - info: host.PiHole hostname: PiHole, node: v20.19.3
                              2025-07-09 17:38:04.331  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                                Ich mach das jetzt nochmal neu.
                                  Den roten Text habe ich beim ersten Mal nicht gesehen. Jetzt habe ich IoBroker nochmal neu installiert. Im Log steht weiterhin das, was ich schon beim letzten Mal gepostet habe.
                                  • Ro75
                                    Ro75 @Balkonfarmer last edited by Ro75
                                    @balkonfarmer hast du eine Stunde gewartet, bevor du irgend etwas versucht hast zu öffnen oder zu starten? Die Meldung besagt nur, dass die Wiederherstellung der gespeicherten "Parameter" abgeschlossen ist. Danach beginnt der Download und die Einrichtung der Adapter. Genau dieser Vorgang dauert... Warten... Wenn du da rein "stürmst", wird es immer wieder in die Hose gehen.
                                    Ro75.
                                      @ro75
                                      Ich habe nur in den Log geschaut und nichts weiter gemacht.
                                        Balkonfarmer @Balkonfarmer last edited by
                                        Also ich habe jetzt 2 Stunden gewartet und es tut sich immer noch nichts.
                                        Log sagt:
                                        2025-07-09 20:52:28.396  - error: host.PiHole No connection to databases possible, restart
                                        2025-07-09 20:52:28.417  - info: host.PiHole iobroker _restart
                                        2025-07-09 20:52:34.614  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                        2025-07-09 20:52:34.622  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                        2025-07-09 20:52:34.623  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                        2025-07-09 20:52:34.624  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                        iob diag sagt:
                                        /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
                                          @balkonfarmer
                                          Du musst nach einer frischen Installation als erstes den
                                          iob fix
                                          ausführen. Steht auch in einer entsprechenden Meldung drin.
                                            Hab ich jetzt gemacht.
                                            jetzt steht das drin:
                                            ```bash
                                            Script v.2025-03-08
                                            *** BASE SYSTEM ***
                                             Static hostname: PiHole
                                                   Icon name: computer
                                                      Kernel: Linux 6.12.34+rpt-rpi-v8
                                                Architecture: arm64
                                            OS is similar to:
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : 64 bit
                                             21:04:58 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                            CPU threads: 4
                                            Operating System is the current Debian stable version codenamed 'bookworm'!
                                            Current issues:
                                                           Local time: Wed 2025-07-09 21:04:58 CEST
                                                       Universal time: Wed 2025-07-09 19:04:58 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            pi
                                            HOME=/home/pi
                                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                            iobroker
                                            HOME=/home/iobroker
                                            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                            Desktop:
                                            Terminal:       tty
                                            *** MEMORY ***
                                            Mem:            4.0G        303M        3.2G        8.5M        565M        3.7G
                                            Swap:           536M          0B        536M
                                            Total:          4.5G        303M        3.7G
                                            Active iob-Instances:   0
                                                     3795 M total memory
                                                      289 M used memory
                                                      252 M active memory
                                                      352 M inactive memory
                                                     3043 M free memory
                                                       48 M buffer memory
                                                      490 M swap cache
                                                      511 M total swap
                                                        0 M used swap
                                                      511 M free swap
                                            top - 21:04:59 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                            Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :   3795.9 total,   3043.2 free,    290.0 used,    539.3 buff/cache
                                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3505.9 avail Mem
                                            *** FILESYSTEM ***
                                            udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                            tmpfs          tmpfs     380M  8.1M  372M   3% /run
                                            /dev/sda2      ext4       14G  3.2G   11G  25% /
                                            /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
                                            [Wed Jul  9 18:12:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f11aec40-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
                                            [Wed Jul  9 18:12:30 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                                            [Wed Jul  9 18:12:32 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                                            `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                            /var:
                                            885M    /var/
                                            205M    /var/cache
                                            199M    /var/cache/apt
                                            168M    /var/lib
                                            135M    /var/lib/apt/lists
                                            Archived and active journals take up 6.9M in the file system.
                                            2.8M    /opt/iobroker/backups/
                                            69M     /opt/iobroker/iobroker-data/
                                            63M     /opt/iobroker/iobroker-data/files
                                            47M     /opt/iobroker/iobroker-data/files/admin.admin
                                            46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                            8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                                            5.3M    /opt/iobroker/iobroker-data/objects.jsonl
                                            3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
                                            3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                                            3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                                            USB-Devices by-id:
                                            zigbee.X
                                            Extended Pan ID:
                                            *** MASKED ***
                                            Pan ID:
                                            *** MASKED ***
                                            Channel:
                                            *** MASKED ***
                                            Network Key:
                                            *** MASKED ***
                                            /usr/bin/nodejs         v20.19.3
                                            /usr/bin/node           v20.19.3
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            /usr/bin/corepack       0.32.0
                                            nodejs:
                                              Installed: 20.19.3-1nodesource1
                                              Candidate: 20.19.3-1nodesource1
                                              Version table:
                                             *** 20.19.3-1nodesource1 1001
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                                 20.19.2-1nodesource1 1001
                                                 20.19.1-1nodesource1 1001
                                                 20.19.0-1nodesource1 1001
                                                 20.18.3-1nodesource1 1001
                                                 20.18.2-1nodesource1 1001
                                                 20.18.1-1nodesource1 1001
                                                 20.18.0-1nodesource1 1001
                                                 20.17.0-1nodesource1 1001
                                                 20.16.0-1nodesource1 1001
                                                 20.15.1-1nodesource1 1001
                                                 20.15.0-1nodesource1 1001
                                                 20.14.0-1nodesource1 1001
                                                 20.13.1-1nodesource1 1001
                                                 20.13.0-1nodesource1 1001
                                                 20.12.2-1nodesource1 1001
                                                 20.12.1-1nodesource1 1001
                                                 20.12.0-1nodesource1 1001
                                                 20.11.1-1nodesource1 1001
                                                 20.11.0-1nodesource1 1001
                                                 20.10.0-1nodesource1 1001
                                                 20.9.0-1nodesource1 1001
                                                 20.8.1-1nodesource1 1001
                                                 20.8.0-1nodesource1 1001
                                                 20.7.0-1nodesource1 1001
                                                 20.6.1-1nodesource1 1001
                                                 20.6.0-1nodesource1 1001
                                                 20.5.1-1nodesource1 1001
                                                 20.5.0-1nodesource1 1001
                                                 20.4.0-1nodesource1 1001
                                                 20.3.1-1nodesource1 1001
                                                 20.3.0-1nodesource1 1001
                                                 20.2.0-1nodesource1 1001
                                                 20.1.0-1nodesource1 1001
                                                 20.0.0-1nodesource1 1001
                                                 18.19.0+dfsg-6~deb12u2 500
                                                 18.19.0+dfsg-6~deb12u1 500
                                            ioBroker Status
                                            No connection to states 127.0.0.1:6379[redis]
                                            Hosts:
                                            js-controller:  7.0.6
                                            admin:          "admin" not found
                                            javascript:     "javascript" not found
                                            Adapter State
                                            Objects and States
                                            Objects:        2
                                            States:         1
                                            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                            Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Pending Updates: 0
                                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4527       621/sshd: /usr/sbin
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          4529       621/sshd: /usr/sbin
                                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2646       478/avahi-daemon: r
                                            udp        0      0 0.0.0.0:48814           0.0.0.0:*                           104        2648       478/avahi-daemon: r
                                            udp6       0      0 :::5353                 :::*                                104        2647       478/avahi-daemon: r
                                            udp6       0      0 :::47074                :::*                                104        2649       478/avahi-daemon: r
                                            udp6       0      0 fe80::523d:8bd6:ead:546 :::*                                0          5567       558/NetworkManager
                                            2025-07-09 21:04:15.162  - info: host.PiHole iobroker _restart
                                            2025-07-09 21:04:21.369  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                            2025-07-09 21:04:21.375  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                            2025-07-09 21:04:21.376  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                            2025-07-09 21:04:21.378  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                            2025-07-09 21:04:51.393  - error: host.PiHole No connection to databases possible, restart
                                            2025-07-09 21:04:51.409  - info: host.PiHole iobroker _restart
                                            2025-07-09 21:04:57.617  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                            2025-07-09 21:04:57.623  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                            2025-07-09 21:04:57.625  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                            2025-07-09 21:04:57.626  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                            2025-07-09 21:05:27.642  - error: host.PiHole No connection to databases possible, restart
                                            2025-07-09 21:05:27.650  - info: host.PiHole iobroker _restart
                                            2025-07-09 21:05:34.095  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                            2025-07-09 21:05:34.103  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                            2025-07-09 21:05:34.104  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                            2025-07-09 21:05:34.106  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                            2025-07-09 21:06:04.121  - error: host.PiHole No connection to databases possible, restart
                                            2025-07-09 21:06:04.129  - info: host.PiHole iobroker _restart
                                            2025-07-09 21:06:10.367  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                            2025-07-09 21:06:10.374  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                            2025-07-09 21:06:10.375  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                            2025-07-09 21:06:10.376  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                            2025-07-09 21:06:40.404  - error: host.PiHole No connection to databases possible, restart
                                            2025-07-09 21:06:40.413  - info: host.PiHole iobroker _restart
                                            kann man da noch etwas retten?
                                            81.1k
                                            3818
