    3. Cloud Dienste
    4. Kein Anmelden am Alexa Adapter mehr möglich
      Balkonfarmer @Thomas Braun last edited by
      ========== Start marking the full check here ===========
      Script v.2025-03-08
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       16:03:56 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-07-07 16:03:56 CEST
                 Universal time: Mon 2025-07-07 14:03:56 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            3.8G        1.2G        2.2G        0.0K        360M        2.8G
      Swap:            99M          0B         99M
      Total:          3.9G        1.2G        2.3G
      Active iob-Instances:   22
               3793 M total memory
               1207 M used memory
                912 M active memory
                527 M inactive memory
               2224 M free memory
                 58 M buffer memory
                302 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 16:03:57 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
      Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  5.6 us,  7.0 sy,  0.0 ni, 87.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3793.3 total,   2224.6 free,   1207.4 used,    361.3 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2828.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       15G  5.3G  8.4G  39% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  836K  758M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Mon Jul  7 13:38:05 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a97293b6-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Mon Jul  7 13:38:08 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Jul  7 13:38:08 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Mon Jul  7 13:38:10 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.0G    /var/
      1.5G    /var/log/journal/faf0bbffdeae42ee938bcf9ac7b405cd
      1.5G    /var/log
      345M    /var/cache
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      42M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      587M    /opt/iobroker/iobroker-data/
      231M    /opt/iobroker/iobroker-data/files
      220M    /opt/iobroker/iobroker-data/Luftdaten
      96M     /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
      12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
      9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
      7.6M    /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      nodejs:                 N/A
      /usr/bin/node           v14.21.3
      /usr/bin/npm            6.14.18
      /usr/bin/npx            6.14.18
      /usr/bin/corepack       0.15.1
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 14.21.3-deb-1nodesource1
        Candidate: 14.21.3-deb-1nodesource1
        Version table:
       *** 14.21.3-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
              100 /var/lib/dpkg/status
           12.22.12~dfsg-1~deb11u7 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Hosts:
      raspberrypi         raspberrypi (version: 4.0.24, hostname: raspberrypi   , alive, uptime: 8750)
      Core adapters versions
      js-controller:  4.0.24
      admin:          5.3.8
      javascript:     5.7.0
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
      + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
        system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : raspberrypi                              - disabled
        system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.78
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Active repo(s): Stable (default)
      Installed ioBroker-Adapters
      Used repository: Stable (default)
      Adapter    "admin"        : 7.6.17   , installed 5.3.8  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.11.2 [Updatable]
      Adapter    "backitup"     : 3.2.2    , installed 2.4.9  [Updatable]
      Adapter    "broadlink2"   : 2.3.0    , installed 2.0.3  [Updatable]
      Adapter    "chromecast"   : 4.0.0    , installed 2.3.1  [Updatable]
      Adapter    "discovery"    : 5.0.0    , installed 3.0.3  [Updatable]
      Adapter    "email"        : 2.0.4    , installed 1.1.3  [Updatable]
      Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
      Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
      Adapter    "history"      : 3.0.1    , installed 1.11.1 [Updatable]
      Adapter    "hmip"         : 1.27.0   , installed 1.17.0 [Updatable]
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.3.0    , installed 1.11.4 [Updatable]
      Adapter    "javascript"   : 8.9.2    , installed 5.7.0  [Updatable]
      Controller "js-controller": 7.0.6    , installed 4.0.24 [Updatable]
      Adapter    "luftdaten"    : 4.0.0    , installed 2.2.4  [Updatable]
      Adapter    "meross"       : 1.17.0   , installed 1.12.0 [Updatable]
      Adapter    "mqtt"         : 6.1.2    , installed 3.0.6  [Updatable]
      Adapter    "mqtt-client"  : 3.0.0    , installed 1.6.2  [Updatable]
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
      Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
      Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.7.0  [Updatable]
      Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
      Adapter    "sonoff"       : 3.1.2    , installed 2.5.1  [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.16 [Updatable]
      Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
      Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
      Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.2.0  [Updatable]
      Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
      Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
      Objects and States
      Objects:        4815
      States:         3719
      Get:1 http://giteduberger.fr rpimonitor/ InRelease [1933 B]
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
      Fetched 1933 B in 1s (1653 B/s)
      Reading package lists...
      Pending Updates: 28
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          3867       569/perl
      tcp        0      0 192.168.178.78:1883     0.0.0.0:*               LISTEN      1001       17575      1175/io.sonoff.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3838       532/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        13895      508/redis-server 12
      tcp        0      0 0.0.0.0:34675           0.0.0.0:*               LISTEN      1001       732532     12412/io.alexa2.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14849      545/iobroker.js-con
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3840       532/sshd: /usr/sbin
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21035      2085/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17140      1851/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14940      591/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21983      2438/io.web.0
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        13896      508/redis-server 12
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18476      1266/io.chromecast.
      udp        0      0 192.168.178.78:5353     0.0.0.0:*                           1001       15953      1192/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13833      389/avahi-daemon: r
      udp        0      0 0.0.0.0:46726           0.0.0.0:*                           108        13835      389/avahi-daemon: r
      udp        0      0 0.0.0.0:57137           0.0.0.0:*                           1001       18452      1244/io.broadlink2.
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3893       795/dhcpcd
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18450      1244/io.broadlink2.
      udp6       0      0 :::5353                 :::*                                108        13834      389/avahi-daemon: r
      udp6       0      0 :::36482                :::*                                108        13836      389/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14908      795/dhcpcd
      2025-07-07 16:01:28.952  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:01:38.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:01:48.986  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:01:58.978  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:09.029  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:14.063  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751896934062_9433
      2025-07-07 16:02:18.997  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:28.974  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:48.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:02:58.969  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:09.018  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:14.264  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
      2025-07-07 16:03:18.995  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:28.981  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:45.085  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751897025083_575
      2025-07-07 16:03:49.008  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:03:58.972  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:04:09.012  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:04:19.001  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:04:28.975  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:04:39.016  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      2025-07-07 16:04:45.115  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
      2025-07-07 16:04:48.982  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
      iob diag has finished.
        Thomas Braun Most Active @Balkonfarmer last edited by Thomas Braun
        @balkonfarmer
        Kannste sinnvoll nur komplett Neuinstallieren.
        Zuerst den ioBroker samt Unterbau auf einen aktuellen Stand bringen.
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        iob stop
        iob fix
        iob nodejs-update 20
        iob update
        iob upgrade all
        iob upgrade self
        iob update
        iob upgrade all
        iob start
        Dann davon ein Backup ziehen und mit dem auf ein frisch installiertes RaspberryOS 12 'Bookworm' in der 64Bit-Lite-Version umziehen.
          Da habe ich einige Probleme:
          • kann ich die Skripte sichern? So dass ich sie in die Neuinstallation integrieren kann.
          • der Adapter Broadlink ist mir sehr wichtig. Leider habe ich die Fernbedienungen nicht mehr und die Funkcodes liegen nur noch in den Objekten vor. (die könnte ich notfalls händisch kopieren,aber das macht viel Arbeit)
          • kann ich VIS irgendwie übernehmen?
            @balkonfarmer sagte in Kein Anmelden am Alexa Adapter mehr möglich:
            Geht mit dem Backitup-Adapter.
            Kann ich ja nix zu.
            Lass einfach Kiste künftig nicht mehr so versumpfen, dann ist das auch alles viel leichter handlebar.
              @thomas-braun Ich danke Dir schonmal. Das werde ich morgen mal in Angriff nehmen.
                @thomas-braun sagte in Kein Anmelden am Alexa Adapter mehr möglich:
                @balkonfarmer
                Das habe ich nun getan, aber nachdem ich das Backup wiederhergestellt habe, komme ich nicht mehr auf die Oberfläche von IoBroker.
                Ro75 Thomas Braun 2 Replies Last reply Reply Quote 0
                • Ro75
                  Ro75 @Balkonfarmer last edited by
                  @balkonfarmer wie lange hast du gewartet? 5 Minuten oder eine Stunde? Aber das gehört nicht hier her.
                  Ro75.
                    Balkonfarmer @Ro75 last edited by
                    @ro75 Ich hab gewartet, bis sich das Fenster geschlossen hat. Das war nach ein paar Minuten.
                    Wohin soll ich es denn posten, ich habe ihm ja nur geantwortet.
                    Ro75 1 Reply Last reply Reply Quote 0
                    • Ro75
                      du warst zu schnell. Da hat gerade erst die Wiederherstellung begonnen. Du musst warten, ruhig ne Stunde.
                      Ro75.
                        Kann eine Stunde dauern, kann aber im logfile beobachtet werden
                        iob logs --watch
                        Wenn das dann da ruhig ist kommst du auch wieder auf den Admin, sonst ggfls den Admin von Hand starten, wenn alle Stricke reißen per
                        iob diag
                        den Zustand prüfen.
                        B 3 Replies Last reply Reply Quote 0
                          @ro75
                          Das Backup zu erstellen hat auch nur so kurz gedauert.
                          Das ist auch der Grund, warum ich kaum Updates gemacht habe, denn immer war irgendwas. Ich bin jetzt mit meinem Latein am Ende.
                            iob logs --watch
                            Der sagt im Log immer das gleiche
                            2025-07-09 17:37:21.843  - error: host.PiHole No connection to databases possibl                 e, restart
                            2025-07-09 17:37:21.863  - info: host.PiHole iobroker _restart
                            2025-07-09 17:37:28.057  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                            2025-07-09 17:37:28.063  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                            2025-07-09 17:37:28.065  - info: host.PiHole hostname: PiHole, node: v20.19.3
                            2025-07-09 17:37:28.066  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                            2025-07-09 17:37:58.080  - error: host.PiHole No connection to databases possibl                 e, restart
                            2025-07-09 17:37:58.101  - info: host.PiHole iobroker _restart
                            2025-07-09 17:38:04.320  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                            2025-07-09 17:38:04.328  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                            2025-07-09 17:38:04.329  - info: host.PiHole hostname: PiHole, node: v20.19.3
                            2025-07-09 17:38:04.331  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                              Ich mach das jetzt nochmal neu.
                                Den roten Text habe ich beim ersten Mal nicht gesehen. Jetzt habe ich IoBroker nochmal neu installiert. Im Log steht weiterhin das, was ich schon beim letzten Mal gepostet habe.
                                • Ro75
                                  Ro75 @Balkonfarmer last edited by Ro75
                                  @balkonfarmer hast du eine Stunde gewartet, bevor du irgend etwas versucht hast zu öffnen oder zu starten? Die Meldung besagt nur, dass die Wiederherstellung der gespeicherten "Parameter" abgeschlossen ist. Danach beginnt der Download und die Einrichtung der Adapter. Genau dieser Vorgang dauert... Warten... Wenn du da rein "stürmst", wird es immer wieder in die Hose gehen.
                                  Ro75.
                                    @ro75
                                    Ich habe nur in den Log geschaut und nichts weiter gemacht.
                                      Balkonfarmer @Balkonfarmer last edited by
                                      Also ich habe jetzt 2 Stunden gewartet und es tut sich immer noch nichts.
                                      Log sagt:
                                      2025-07-09 20:52:28.396  - error: host.PiHole No connection to databases possible, restart
                                      2025-07-09 20:52:28.417  - info: host.PiHole iobroker _restart
                                      2025-07-09 20:52:34.614  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                      2025-07-09 20:52:34.622  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                      2025-07-09 20:52:34.623  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                      2025-07-09 20:52:34.624  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                      iob diag sagt:
                                      /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
                                        @balkonfarmer
                                        Du musst nach einer frischen Installation als erstes den
                                        iob fix
                                        ausführen. Steht auch in einer entsprechenden Meldung drin.
                                          Hab ich jetzt gemacht.
                                          jetzt steht das drin:
                                          ```bash
                                          Script v.2025-03-08
                                          *** BASE SYSTEM ***
                                           Static hostname: PiHole
                                                 Icon name: computer
                                                    Kernel: Linux 6.12.34+rpt-rpi-v8
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                           21:04:58 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                          CPU threads: 4
                                          Operating System is the current Debian stable version codenamed 'bookworm'!
                                          Current issues:
                                                         Local time: Wed 2025-07-09 21:04:58 CEST
                                                     Universal time: Wed 2025-07-09 19:04:58 UTC
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          pi
                                          HOME=/home/pi
                                          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            4.0G        303M        3.2G        8.5M        565M        3.7G
                                          Swap:           536M          0B        536M
                                          Total:          4.5G        303M        3.7G
                                          Active iob-Instances:   0
                                                   3795 M total memory
                                                    289 M used memory
                                                    252 M active memory
                                                    352 M inactive memory
                                                   3043 M free memory
                                                     48 M buffer memory
                                                    490 M swap cache
                                                    511 M total swap
                                                      0 M used swap
                                                    511 M free swap
                                          top - 21:04:59 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                          Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                                          %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                          MiB Mem :   3795.9 total,   3043.2 free,    290.0 used,    539.3 buff/cache
                                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3505.9 avail Mem
                                          *** FILESYSTEM ***
                                          udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                          tmpfs          tmpfs     380M  8.1M  372M   3% /run
                                          /dev/sda2      ext4       14G  3.2G   11G  25% /
                                          /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
                                          [Wed Jul  9 18:12:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f11aec40-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
                                          [Wed Jul  9 18:12:30 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                                          [Wed Jul  9 18:12:32 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                                          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          885M    /var/
                                          205M    /var/cache
                                          199M    /var/cache/apt
                                          168M    /var/lib
                                          135M    /var/lib/apt/lists
                                          Archived and active journals take up 6.9M in the file system.
                                          2.8M    /opt/iobroker/backups/
                                          69M     /opt/iobroker/iobroker-data/
                                          63M     /opt/iobroker/iobroker-data/files
                                          47M     /opt/iobroker/iobroker-data/files/admin.admin
                                          46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                          8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                                          5.3M    /opt/iobroker/iobroker-data/objects.jsonl
                                          3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
                                          3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                                          3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/nodejs         v20.19.3
                                          /usr/bin/node           v20.19.3
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          /usr/bin/corepack       0.32.0
                                          nodejs:
                                            Installed: 20.19.3-1nodesource1
                                            Candidate: 20.19.3-1nodesource1
                                            Version table:
                                           *** 20.19.3-1nodesource1 1001
                                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                               20.19.2-1nodesource1 1001
                                               20.19.1-1nodesource1 1001
                                               20.19.0-1nodesource1 1001
                                               20.18.3-1nodesource1 1001
                                               20.18.2-1nodesource1 1001
                                               20.18.1-1nodesource1 1001
                                               20.18.0-1nodesource1 1001
                                               20.17.0-1nodesource1 1001
                                               20.16.0-1nodesource1 1001
                                               20.15.1-1nodesource1 1001
                                               20.15.0-1nodesource1 1001
                                               20.14.0-1nodesource1 1001
                                               20.13.1-1nodesource1 1001
                                               20.13.0-1nodesource1 1001
                                               20.12.2-1nodesource1 1001
                                               20.12.1-1nodesource1 1001
                                               20.12.0-1nodesource1 1001
                                               20.11.1-1nodesource1 1001
                                               20.11.0-1nodesource1 1001
                                               20.10.0-1nodesource1 1001
                                               20.9.0-1nodesource1 1001
                                               20.8.1-1nodesource1 1001
                                               20.8.0-1nodesource1 1001
                                               20.7.0-1nodesource1 1001
                                               20.6.1-1nodesource1 1001
                                               20.6.0-1nodesource1 1001
                                               20.5.1-1nodesource1 1001
                                               20.5.0-1nodesource1 1001
                                               20.4.0-1nodesource1 1001
                                               20.3.1-1nodesource1 1001
                                               20.3.0-1nodesource1 1001
                                               20.2.0-1nodesource1 1001
                                               20.1.0-1nodesource1 1001
                                               20.0.0-1nodesource1 1001
                                               18.19.0+dfsg-6~deb12u2 500
                                               18.19.0+dfsg-6~deb12u1 500
                                          ioBroker Status
                                          No connection to states 127.0.0.1:6379[redis]
                                          Hosts:
                                          js-controller:  7.0.6
                                          admin:          "admin" not found
                                          javascript:     "javascript" not found
                                          Adapter State
                                          Objects and States
                                          Objects:        2
                                          States:         1
                                          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                          Pending Updates: 0
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4527       621/sshd: /usr/sbin
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          4529       621/sshd: /usr/sbin
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2646       478/avahi-daemon: r
                                          udp        0      0 0.0.0.0:48814           0.0.0.0:*                           104        2648       478/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                104        2647       478/avahi-daemon: r
                                          udp6       0      0 :::47074                :::*                                104        2649       478/avahi-daemon: r
                                          udp6       0      0 fe80::523d:8bd6:ead:546 :::*                                0          5567       558/NetworkManager
                                          2025-07-09 21:04:15.162  - info: host.PiHole iobroker _restart
                                          2025-07-09 21:04:21.369  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                          2025-07-09 21:04:21.375  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                          2025-07-09 21:04:21.376  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                          2025-07-09 21:04:21.378  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                          2025-07-09 21:04:51.393  - error: host.PiHole No connection to databases possible, restart
                                          2025-07-09 21:04:51.409  - info: host.PiHole iobroker _restart
                                          2025-07-09 21:04:57.617  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                          2025-07-09 21:04:57.623  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                          2025-07-09 21:04:57.625  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                          2025-07-09 21:04:57.626  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                          2025-07-09 21:05:27.642  - error: host.PiHole No connection to databases possible, restart
                                          2025-07-09 21:05:27.650  - info: host.PiHole iobroker _restart
                                          2025-07-09 21:05:34.095  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                          2025-07-09 21:05:34.103  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                          2025-07-09 21:05:34.104  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                          2025-07-09 21:05:34.106  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                          2025-07-09 21:06:04.121  - error: host.PiHole No connection to databases possible, restart
                                          2025-07-09 21:06:04.129  - info: host.PiHole iobroker _restart
                                          2025-07-09 21:06:10.367  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                          2025-07-09 21:06:10.374  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                          2025-07-09 21:06:10.375  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                          2025-07-09 21:06:10.376  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                          2025-07-09 21:06:40.404  - error: host.PiHole No connection to databases possible, restart
                                          2025-07-09 21:06:40.413  - info: host.PiHole iobroker _restart
                                          kann man da noch etwas retten?
                                            @balkonfarmer
                                            Hast du auch zuvor 'redis' installiert?
                                            Die alte Installation lief wohl offenbar darauf.
                                            sudo apt update
                                            apt policy redis
                                            81.1k
                                            3818
