      Supernils last edited by Supernils
      Hallo zusammen, mein iobroker log ist voll mit
      2025-07-01 16:05:50.419 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
      2025-07-01 16:05:52.281 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
      2025-07-01 16:30:50.602 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
      2025-07-01 16:31:10.644 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Sportzimmer value: 25%
      2025-07-01 16:33:43.440 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
      Die Rollladen fahren mehrmals am Tag sporadisch zwischen den zwei Positionen 25% (Sonnenschutz) und 0% (Wärmeschutz).
      Mit debug log sieht es wie folgt aus:
      2025-07-01 17:10:50.388 - debug: shuttercontrol.0 (23613) Start pendingAlarm to check whether an alarm is currently pending (except in the event of frost)
      2025-07-01 17:10:50.390 - debug: shuttercontrol.0 (23613) status alarm pending for alias.0.Esszimmer.Rolllade_Esszimmer.SET: false
      2025-07-01 17:10:50.397 - info: shuttercontrol.0 (23613) Lightsensor #5 Set ID: Esszimmer value: 25%
      2025-07-01 17:10:50.405 - debug: shuttercontrol.0 (23613) #0 wait for shutter check started
      2025-07-01 17:10:50.415 - debug: shuttercontrol.0 (23613) #0 wait for shutter check end
      2025-07-01 17:10:50.423 - debug: shuttercontrol.0 (23613) Shutter state changed: Esszimmer old value = 0% | new value = 25%
      2025-07-01 17:10:50.423 - debug: shuttercontrol.0 (23613) Esszimmer Old value = 0% | New value = 25% | automatic is active
      2025-07-01 17:10:50.477 - debug: shuttercontrol.0 (23613) last automatic Action for Esszimmer: up_Brightness
      2025-07-01 17:10:50.477 - debug: shuttercontrol.0 (23613) save current height: 25% from Esszimmer
      2025-07-01 17:10:52.158 - debug: shuttercontrol.0 (23613) Start pendingAlarm to check whether an alarm is currently pending (except in the event of frost)
      2025-07-01 17:10:52.201 - debug: shuttercontrol.0 (23613) status alarm pending for alias.0.Esszimmer.Rolllade_Esszimmer.SET: false
      2025-07-01 17:10:52.221 - debug: shuttercontrol.0 (23613) Heat Protection for Esszimmer is active
      2025-07-01 17:10:52.226 - debug: shuttercontrol.0 (23613) Esszimmer: Check basis for sunprotect. Height:25 > HeightDownSun: 0 AND Height:25 == currentHeight:25 AND currentHeight:25 == heightUp:99
      2025-07-01 17:10:52.227 - info: shuttercontrol.0 (23613) Sunprotect #412 Set ID: Esszimmer value: 0%
      2025-07-01 17:10:52.264 - debug: shuttercontrol.0 (23613) #0 wait for shutter check started
      2025-07-01 17:10:52.274 - debug: shuttercontrol.0 (23613) #0 wait for shutter check end
      2025-07-01 17:10:52.281 - debug: shuttercontrol.0 (23613) Sunprotect for Esszimmer is active
      2025-07-01 17:10:52.281 - debug: shuttercontrol.0 (23613) Temperature inside: 23.53 > 20.5 AND ( Temperatur outside: 33.19 > 25 AND Light: 30234.30570511337 > 28000 )
      2025-07-01 17:10:52.282 - debug: shuttercontrol.0 (23613) Sunprotect Esszimmer old height: 0% new height: 0%
      2025-07-01 17:10:52.282 - debug: shuttercontrol.0 (23613) last automatic Action for Esszimmer: down_Sunprotect
      Was mache ich falsch? 🙂
      Meine Konfig (als Beispiel für alle Rollladen):
        Homoran Global Moderator Administrators @Supernils last edited by
        @supernils sagte in Test Adapter shuttercontrol v2.0.x:
        das ist normal, wenn sie ihre Position über den Adapter verändern.
        oder liegt dein Problem bei
        im Sinne von ungewollt?
          Supernils @Homoran last edited by
          Das mehrmalige sporadische Fahren zwischen 25% (Sonnenschutz) und 0% (Wärmeschutz) ist das eignetliche Problem, richtig.
          Der obere log zeigt zwei Fälle:
          Zeile 1/2: Kommt der Wechsel zwischen Sonnenschutz und Wärmeschutz schnell hintereinander, fahren die Rollladen nicht.
          Zeile 4/6: Sporadisch sind mehrere Minuten zwischen Sonnenschutz und Wärmeschutz und dann fahren die Rollladen (vermutlich).
            Homoran Global Moderator Administrators @Supernils last edited by Homoran
            vermutlich
            du hast beim Hitzeschutz 30 Minuten Zwangspause eingestellt!
            Aus 2 Sekunden debug-log kann man nichts erkennen.
            Ich vermute
            dass zwischendurch die Helligkeit unter den Grenzwert fällt.
            das ist eine einzige UND-Verknüpfung
              @homoran said in Test Adapter shuttercontrol v2.0.x:
              Woran erkennst du das? An welcher Stelle wird das konfiguriert?
              Das wird nicht die Ursache sein. Der Wert hat sich seit 11:37 nicht geändert.
              Ist schon merkwürdig... Ich werde das morgen nochmal beobachten und den debug log posten.
                sorry, sind wohl 60.
                ich kann diese schwarzen Microfilme so schlecht entziffern
                  docsnyder7 @docsnyder7 last edited by
                  @Homoran Ergänzung und auch logisch im NAchgang... die später Schließung ist ja ein zusätzlicher Trigger und wird somit auch erst dann aktiv, wenn man das Rollo auf den entsprechenden bereich einstellt INKL. Automatik.. sonst greift der Trigger ja gar nicht.
                  Hatte ich im ersten Lesen der Adapterbeschreibung nicht aufgenommen, beim erneuten Lesen dann !
                  • rtwl
                    rtwl @rtwl last edited by
                    @rtwl sagte in Test Adapter shuttercontrol v2.0.x:
                    @simatec
                    Was bedeutet der Status "OpenInSunProtect"? Wann wird dieser gesetzt?
                    @simatec, wärst du so nett und beschreibst kurz wann und warum dieser Status gesetzt wird?
                    Arne Dieckmann 1 Reply Last reply Reply Quote 0
                    • Arne Dieckmann
                      Arne Dieckmann @rtwl last edited by
                      @rtwl Falls Du es noch nicht selber ausprobiert hast...
                      Für den betroffenen Rollladen ist eine SunProtect Einstellung hinterlegt (z.B. Sonnenstand +/- Winkel vor und nach dem Sonnenstand als Zeitraum). Ist der Rollladen morgens noch geschlossen und der eingestellte Sonnenstand ist +/- des Winkels ist erreicht, ABER der Rolladen soll erst danach automatisch geöffnet werden, dann springt er in den Zustand "OpenInSunProtect". Er fährt also von geschlossen direkt in die SunProtect Einstellung. Klingt komisch, ist aber so.
                      rtwl 1 Reply Last reply Reply Quote 2
                      • rtwl
                        rtwl @Arne Dieckmann last edited by
                        @arne-dieckmann Vielen Dank für die Erklärung! Macht Sinn so.
                          Manolo last edited by
                          ich bin schon die ganze Zeit am herum probieren mit dem Adapter.
                          Inzwischen funktioniert das Öffnen und Schließen der einzelnen Rolläden und auch die verzögerte Öffnung im Schlafzimmer am Wochenende mit den Schlafzimmer EInstellungen.
                          Was ich aber bisher nicht hin bekommen habe ist die Sonnenschutzeinstellung.
                          Egal was ich dort einstelle, die Rolläden fahren nicht herunter.
                          Hier die Einstellungen:
                          Egal was ich bei den Testwerten eintrage, der Rolladen bewegt sich nicht.
                          Kann mir jemand helfen oder schreiben was ich falsch eingestellt habe?
                            Homoran Global Moderator Administrators @Manolo last edited by Homoran
                            @manolo sagte in Test Adapter shuttercontrol v2.0.x:
                            das sagt dir (und uns) das debug-log.
                            was steht darun, wenn du einen Wert änderst?
                            steht der Rollladen möglicherweise im Manu_Mode?
                            zeig mal screenshots von dem Sidebar Menü
                              Manolo @Homoran last edited by
                              @homoran erstmal vielen Dank für deine Hilfe
                              Die Werte aus den Testvariablen kommen in Shuttercontrol an und werden wohl auch verarbeitet.
                              Ich habe nur 2 Rolladen mit den Testwerten belegt, alle anderen laufen mit den regulären Variablen für Aussentemperatur und Helligkeit.
                              Seltsamerweise funktioniert die Sonnenschutzeinstellung für die Dachfenster.
                              shuttercontrol.0
                              2025-07-12 10:30:44.094	debug	Rolladen Dach Rechts Zielposition: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:0
                              shuttercontrol.0
                              2025-07-12 10:30:37.077	debug	Rolladen Dach Links Zielposition: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:0
                              shuttercontrol.0
                              2025-07-12 10:30:37.065	debug	Rolladen Dach Links Zielposition: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:0
                              shuttercontrol.0
                              2025-07-12 10:30:32.074	debug	Rolladen Dach Rechts Zielposition: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:0
                              shuttercontrol.0
                              2025-07-12 10:30:32.029	debug	Rolladen Dach Rechts Zielposition: Check basis for sunprotect. Height:100 > HeightDownSun: 100 AND Height:100 == currentHeight:100 AND currentHeight:100 == heightUp:0
                              shuttercontrol.0
                              2025-07-12 10:30:12.084	debug	Lightsensor changed: alias.0.Energie.Strom.Erzeugung.Gesamt.Leistung | Value: 8661lux
                              shuttercontrol.0
                              2025-07-12 10:30:00.019	debug	outsidetemperature changed: alias.0.Umwelt.Temperatur.Aussen | Value: 23.3°C
                              Und auch der Rolladen im Schlafzimmer ist auf die Sonnenschutzposition gefahren. Das ist der einzige Rolladen der anstatt öffnen bei Sonnenaufgang die Schlafzimmer Automatik drin hat.
                              Und tatsächlich stehen alle Rolläden, außer die vom Dach, auf Manu_Mode.
                              Aber wo kann ich das einstellen?
                                Manu_Mode wird von shuttercontrol gesetzt, wenn während des Tages irgendetwas anderes sls shuttercontrol den Rolladen bewegt.
                                Damit wird die Beschattungsautomatik bis zum Abend außer Kraft gesetzt.
                                Je nach deinen Einstellungen wird Manu_Mode auch wieder aufgehoben wenn du den Rollladrn auf eine für Shuttercontrol konfigurierte Höhe setzst.
                                @homoran sagte in Test Adapter shuttercontrol v2.0.x:
                                bitte noch nachholen
                                  Ok, das mit dem Manu_Mode habe ich jetzt verstanden.
                                  Hab dann alle Rolladen über Control/SunProtect verfahren. Nach einer Weile sind 3 der Rolladen hoch gefahren und wurden vom Program wieder auf Manu_Mode gesetzt.
                                  Ich habe dabei nicht extern eingegriffen.
                                  Was meinst du mit Sidebar Menü?
                                    hast du "Behanghöhe verzögert ermitteln" o.ä. konfiguriert?
                                    ggf. meldet dein aktor zwischendurch schon die gerade aktuelle Höhe.
                                    Die wird dann als neue Höhe genommen, und die später gemeldete richtige Höhe als zusätzlicher Eingriff gewertet
                                      Stoffel @simatec last edited by
                                      @simatec said in Test Adapter shuttercontrol v2.0.x:
                                      Ab sofort steht die Version 2.0.0 auf Github und in kürze auch im latest zur Verfügung.
                                      In dieser Version wurde ein innovatives Tab Menü zur Bedienung der Rollladensteuerung hinzugefügt.
                                      Es ist über die linke Tableiste im iobroker erreichbar.
                                      Voraussetzung für diese Version ist die aktuelle Admin Version >= 7.6.3
                                      Bildschirmfoto 2025-03-23 um 16.51.17.png Bildschirmfoto 2025-03-23 um 16.51.40.png
                                      Ich finde diesen Tab super, gibt es eine Möglichkeit diesen auch direkt in einer VIS ( in meinem Fall iQontrol) anzuzeigen.
                                      Wenn ich es über den Link versuche kommt Verbindung abgelehnt.
                                      Grüße Stoffel
                                        Sorry für die späte Rückmeldung, habe die letzten Tage erstmal ausprobieren müssen.
                                        Mit dem letzten Tipp hast du mich auf die richtige Fährte gebracht.
                                        Die Somfy Rolladen werden über ESP-Somfy-RTS angesteuert und senden kontinuierlich ihre Position, bzw. die wird vom ESP per Zeitberechnung immer aktualisiert. Deswegen wurden die beim Fahren immer von Shuttercontroll auf Manu_Mode gesetzt.
                                        Ich habe bei diesen Rolladen nun die Option "Blockieren des Manu Modus für bekannte Rolladenhöhen" aktiviert und seither funktioniert es fast immer.
                                        Die Rolladen fahren zwar heute den ganzen Tag wie wild hin und her, aber das liegt eher am aktuellen Wetter mit Sonne und Regen im Wechselspiel.
                                        Ich werde wohl noch ein wenig experimentieren müssen, aber aktuell passt es soweit.
                                        Vielen Dank für deine Hilfe und Geduld!
                                          ist aber nicht
                                          was hast du da geändert?
                                          bitte immer alles zeigen!
                                          Nacherzählungen sind nicht immer hilfreich
                                            Da habe ich überhaupt nichts geändert.
                                            Um ehrlich zu sein habe ich diesen Punkt nirgends in den Einstellungen gefunden.
                                            Wenn du mir sagst wo ich den finde, schaue ich nach was da drin steht.
                                            332
                                            7402
                                            10490764
