    4. Shutter Controladapter Adapter macht plötzlich Probleme!
      biker1602 @Homoran last edited by
      Das Problem ist das im Log nichts als Error oder so steht.
      2025-07-11 15:14:17.516 - debug: shuttercontrol.0 (235325) Fensterrollo: save settings
      2025-07-11 15:14:17.618 - debug: shuttercontrol.0 (235325) Rollo_Schlafzimmer: save settings
      2025-07-11 15:14:17.718 - debug: shuttercontrol.0 (235325) Rollo_Tür: save settings
      2025-07-11 15:14:17.819 - debug: shuttercontrol.0 (235325) Reserverollo: save settings
      2025-07-11 15:14:20.808 - debug: shuttercontrol.0 (235325) Travel times of the shutters are calculated
      2025-07-11 15:14:20.808 - debug: shuttercontrol.0 (235325) calculate astrodata ...
      2025-07-11 15:14:20.809 - debug: shuttercontrol.0 (235325) goldenHourEnd today: 06:04
      2025-07-11 15:14:20.809 - debug: shuttercontrol.0 (235325) goldenHour today: 20:44
      2025-07-11 15:14:20.809 - debug: shuttercontrol.0 (235325) current day: 5
      2025-07-11 15:14:20.809 - debug: shuttercontrol.0 (235325) Sunrise today: 05:10
      2025-07-11 15:14:20.810 - debug: shuttercontrol.0 (235325) Sunset today: 21:38
      2025-07-11 15:14:20.810 - debug: shuttercontrol.0 (235325) Starting up shutters GoldenHour area: 06:04
      2025-07-11 15:14:20.810 - debug: shuttercontrol.0 (235325) Shutdown shutters GoldenHour area: 20:44
      2025-07-11 15:14:20.810 - debug: shuttercontrol.0 (235325) Starting up shutters Sunrise area: 05:10
      2025-07-11 15:14:20.810 - debug: shuttercontrol.0 (235325) Shutdown shutters Sunset area: 21:38
      2025-07-11 15:14:20.818 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 08:00
      2025-07-11 15:14:20.818 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 05:00
      2025-07-11 15:14:20.818 - debug: shuttercontrol.0 (235325) yes, IsLater: 05:10 " " 05:00
      2025-07-11 15:14:20.818 - debug: shuttercontrol.0 (235325) check IsEarlier: 05:10 " " 08:00
      2025-07-11 15:14:20.819 - debug: shuttercontrol.0 (235325) yes, IsEarlier: 05:10 " " 08:00
      2025-07-11 15:14:20.819 - debug: shuttercontrol.0 (235325) Starting up shutters living area: 05:10 | debug: 5
      2025-07-11 15:14:20.820 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 06:30
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 06:00
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) check IsEqual: 06:00 " " 06:30
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) check IsEqual: 05:10 " " 06:30
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) check IsEarlier: 05:10 " " 06:00
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) yes, IsEarlier: 05:10 " " 06:00
      2025-07-11 15:14:20.821 - debug: shuttercontrol.0 (235325) Starting up shutters sleep area: 06:00 | debug 8
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 06:30
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) check IsLater: 05:10 " " 06:00
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) check IsEqual: 06:00 " " 06:30
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) check IsEqual: 05:10 " " 06:30
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) check IsEarlier: 05:10 " " 06:00
      2025-07-11 15:14:20.823 - debug: shuttercontrol.0 (235325) yes, IsEarlier: 05:10 " " 06:00
      2025-07-11 15:14:20.824 - debug: shuttercontrol.0 (235325) Starting up shutters children area: 06:00 | debug 8
      2025-07-11 15:14:20.825 - debug: shuttercontrol.0 (235325) check IsEarlier: 00:00 " " 21:38
      2025-07-11 15:14:20.825 - debug: shuttercontrol.0 (235325) yes, IsEarlier: 00:00 " " 21:38
      2025-07-11 15:14:20.825 - debug: shuttercontrol.0 (235325) Shutdown shutters living area: 00:00 | debug 3
      2025-07-11 15:14:20.825 - debug: shuttercontrol.0 (235325) shutterDownLiving
      2025-07-11 15:14:20.826 - debug: shuttercontrol.0 (235325) Shutdown shutters children area: 21:00 | debug 3
      2025-07-11 15:14:20.827 - debug: shuttercontrol.0 (235325) Shutdown shutters sleep area: 21:00 | debug 3
      2025-07-11 15:14:20.828 - debug: shuttercontrol.0 (235325) late down at 22:00
      2025-07-11 15:14:20.828 - debug: shuttercontrol.0 (235325) complete down at 22:00
      Das in die Einstellungen vom Fensterrollo genau die gleichen wie bei Schlafzimmer. Dort funktioniert der Sonnenschutz aber nicht bei Fensterrollo
        Homoran Global Moderator Administrators @biker1602 last edited by
        @biker1602 in welchem Zustand ist der Rollo?
          @homoran said in Shutter Controladapter Adapter macht plötzlich Probleme!:
          Im Schlafzimmer unten im Fensterrollo oben
            Homoran Global Moderator Administrators @biker1602 last edited by Homoran
            @biker1602 sagte in Shutter Controladapter Adapter macht plötzlich Probleme!:
            bitte das Sidebarmenü zeigen
              Welches Sidebarmenü meinst du?
                das von shuttercontrol natürlich
                  Meinst du das?
                    Meinst du das?
                    nein!
                    das in diesem Post gezeigte
                    @homoran sagte in Shutter Controladapter Adapter macht plötzlich Probleme!:
                        @biker1602 und jetzt noch einen Reiter nach rechts
                            @biker1602 Schlafzimmer steht wie vermutet im Manu_Mode, dann findet keine automatische Beschattung statt
                              Aber Schlafzimmer funktioniert ja
                                @biker1602 kann es eigentlich nicht!
                                aber erstmal egal!
                                ist das der Datenpunkt des Rollos?
                                und der ändert sich nicht?
                                  biker1602 @Homoran last edited by biker1602
                                  Nein der ändert sich nicht.
                                  Wenn ich dort eine Prozentzahl manuell eingebe, fährt es rauf bzw. runter
                                    @biker1602 gut, kreisen wir es weiter ein!
                                    wirklich?
                                    auch gleiche Bereiche?
                                      der Wert ist aber unbestätigt!
                                      keine Ahnung, ob das schuld ist, aber mach das mal bestätigt
                                        wirklich?
                                        Das ist vom Schlafzimmer Die Bereiche sind einmal Wohnzimmer und einmal Schlafzimmer
                                          @biker1602 wer hat die roten 100% in den Datenpunkt eingegeben?
                                            Das war ich aber jetzt ist mir etwas aufgefallen. Ich habe nochmal bei meinen Scripten nachgeschaut und da habe ich noch ein zusätzliches Script was für das Schlafzimmer ist. Das habe ich deaktiviert und jetzt fährt das rollo Schlafzimmer auch nicht mehr runter. Ich werde jetzt nochmal die Einstellungen bei Shuttercontrol überprüfe und melde mich dann nochmal.
                                            Aber erstmal schon Dankeschön für deine Unterstützung
                                            adpater blockly broadlink2 broadlink iobroker shutter control
                                            1187
