    4. Test Adapter OpenLigaDB
    • Meister Mopper
      Meister Mopper @OliverIO last edited by
      @oliverio
      Habe den Adapter mal gestoppt und die Objekte gelöscht.
      Nach Adapterneustart beginnt die Saison nach wie vor am 16.05. 🤷‍♂️
      • OliverIO
        OliverIO @Meister Mopper last edited by
        @meister-mopper
        Dann poste bitte die Konfiguration des Widgets (Widget Export)
        Sowie den Inhalt der eingestellten datenpunkte
        • Meister Mopper
          @oliverio
          Das Widget ist:
          [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-allmatches":"openligadb.0.bl1.2025.allmatches","oid-currgameday":"openligadb.0.bl1.2025.currgameday"},"style":{"left":"649px","top":"54px","color":"white","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"large"},"widgetSet":"openligadb"}]
          Datenpunkt ist currgameday.
          OliverIO 2 Replies Last reply Reply Quote 0
          • OliverIO
            OliverIO @Meister Mopper last edited by OliverIO
            @meister-mopper
            Allgames?
            Ach dein curgameday ist allgames.
            • OliverIO
              @meister-mopper
              Ah jetzt.
              Die Berechnung von curgameday ist falsch. Da wird 34 berechnet.
              Die Anzeige ist damit korrekt, weil es der 16.5.2026 ist.
              Mal schauen, da ist ne Besonderheit von Corona drin, weil damals die Spieltage nicht wirklich immer squenziell abgeschlossen waren.
              Evtl mach ich die wieder raus.
              Ok, der aktuelle Spieltag wird aus der folgenden api entnommen
              https://api.openligadb.de/getcurrentgroup/Bl1
              Ergebnis ist 34
              Beschreibung der api ist
              /getcurrentgroup/{leagueShortcut}
              Gibt die aktuelle Group (entspricht z.B. bei der Fussball-Bundesliga dem 'Spieltag') des als Parameter zu übergebenden leagueShortcuts (z.B. 'bl1') aus. Der aktuelle Spieltag
              wird jeweils zur Hälfte der Zeit zwischen dem letzten Spiel des letzten Spieltages und dem ersten Spiel des nächsten Spieltages erhöht.
              Also 17.5.2025 und 22.8.25
              Also ab ca 5.7.2025 oder so, wenn ich richtig gerechnet habe, müsste dann da 1 kommen
              D4vE 1 Reply Last reply Reply Quote 2
              • D4vE
                D4vE @OliverIO last edited by D4vE
                @oliverio ist bei mir auch so 🙂
                aber das nächste spiel stimmt schonmal nur das erste nicht ^^ mal gucken ob die das noch fixxen 🙂
                • OliverIO
                  OliverIO @D4vE last edited by
                  @d4ve
                  Solange bei curgameday noch eine hohe Zahl drin steht, klappt die Berechnung nicht. Der 5.7. war grob geschätzt von mir.
                  In den nächsten Tagen wird da dann 1 drin stehen.
                  Muss mal schauen ob ich da etwas verbessere, aber aktuell sind die Prioritäten nicht bei den Adaptern ☀️😎🚴🏊
                  D4vE 1 Reply Last reply Reply Quote 0
                  • D4vE
                    @oliverio sagte in Test Adapter OpenLigaDB:
                    @d4ve
                    Supi ❤ ne das teil läuft schon super. und hilft mir sehr. danke für die gute Arbeit.
                    • OliverIO
                      OliverIO last edited by OliverIO
                      So, für bl1 2025/2026 steht jetzt 1 drin.
                      Jetzt passt alles.
                      Ich überlege mir aber mal was bei Gelegenheit.
                      https://github.com/oweitman/ioBroker.openligadb/issues/691
                      oweitman created this issue in oweitman/ioBroker.openligadb
                      closed Curgameday vor Start der Liga zeigt manchmal noch den letzten Spieltag der letzten Saison #691
                      Meister Mopper 1 Reply Last reply Reply Quote 1
                      • Meister Mopper
                        @oliverio
                        Durch Zeitablauf erledigt 😊
                        Aus meiner Sicht musste da nüscht ändern.
                        • OliverIO
                          @meister-mopper
                          Ja, aber es hat schon verwirrt und ich kann schon rausfinden, wenn eine Liga generell noch nicht begonnen hat um das dann auf 1 zu setzen.
                          • OliverIO
                            Neue Version 1.9.0
                            • der Abruf erfolgt nun per axios
                            • zur Standardisierung wird nun eine Utility Klasse von mir eingesetzt
                            • Die Funktionsstruktur wurde zu einer Klasse umgearbeitet
                            • von callbacks wurde nun zu async/await gewechselt.
                            • Die Berechnung von Current Gameday, also der aktuelle Spieltag wurde verbessert. Bis zum ersten Spiel wird generell der Spieltag 1 angenommen. Danach wird der von openligadb bereitgestellte Wert verwendet. Der openligadb Wert hat in der Vergangenheit manchmal noch den letzten Spieltag der Vorgängersaison ergeben, da die API hier nicht saison spezifisch ist.
                            OliverIO 1 Reply Last reply Reply Quote 1
                            • OliverIO
                              OliverIO @OliverIO last edited by
                              Version wird nun demnächst im stable auftauchen
                              Neue Version 1.9.0
                              adapter openligadb test
                              56
                              687
                              122548
