    4. Backup bricht mit Fehlermeldung ab
    • frankthegreat
      frankthegreat @Homoran last edited by
      wie gewünscht:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.25+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       13:38:12 up 28 days, 23:15,  2 users,  load average: 0.06, 0.01, 0.00
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-07-13 13:38:12 CEST
                 Universal time: Sun 2025-07-13 11:38:12 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.2G        561M        6.9G        9.6M        855M        7.6G
      Swap:           536M          0B        536M
      Total:          8.7G        561M        7.4G
      Active iob-Instances:   3
               7821 M total memory
                535 M used memory
                523 M active memory
                555 M inactive memory
               6578 M free memory
                109 M buffer memory
                706 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 13:38:12 up 28 days, 23:15,  2 users,  load average: 0.06, 0.01, 0.00
      Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7821.4 total,   6576.7 free,    537.5 used,    816.1 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7283.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     783M  9.2M  774M   2% /run
      /dev/mmcblk0p2 ext4       29G  3.5G   24G  13% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     783M     0  783M   0% /run/user/1000
      [Sat Jun 14 14:23:07 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:CD:2E:4E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0f1a1b8d-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Jun 14 14:23:08 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
      [Sat Jun 14 14:23:09 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      951M    /var/
      274M    /var/cache
      268M    /var/cache/apt
      164M    /var/lib
      155M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      11M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      143M    /opt/iobroker/iobroker-data/
      63M     /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
      7.1M    /opt/iobroker/iobroker-data/states.jsonl
      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.2
      /usr/bin/node           v20.19.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1848)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Objects and States
      Objects:        149
      States:         98
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 37
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       186969     43229/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       184886     43229/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5533       588/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       187067     43258/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5535       588/sshd: /usr/sbin
      udp        0      0 0.0.0.0:33428           0.0.0.0:*                           104        5483       454/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5481       454/avahi-daemon: r
      udp6       0      0 fe80::15a1:40f4:468:546 :::*                                0          140460     528/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        5482       454/avahi-daemon: r
      udp6       0      0 :::51880                :::*                                104        5484       454/avahi-daemon: r
      2025-07-13 13:07:46.825  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
      2025-07-13 13:07:46.833  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
      2025-07-13 13:07:46.841  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
      2025-07-13 13:07:46.876  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
      2025-07-13 13:07:46.878  - info: host.raspberrypi iobroker npm-install: Updating objects from io-package.json for adapter "discovery" with version "5.0.0"
      2025-07-13 13:07:46.903  - info: host.raspberrypi iobroker npm-install: Update "system.adapter.discovery.0"
      2025-07-13 13:07:47.130  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:07:47.942  - info: host.raspberrypi iobroker npm-install: exit 0
      2025-07-13 13:07:49.027  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:07:50.227  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:07:57.535  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:08:00.569  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:13:15.772  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:13:15.979  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:13:15.999  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:13:19.129  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:14:48.460  - warn: admin.0 (43258) admin has an invalid jsonConfig: [{"instancePath":"/items/loadingTab/items/loading-bg.png/accept","schemaPath":"#/patternProperties/%5E.%2B/allOf/10/then/properties/accept/type","keyword":"type","params":{"type":"object"},"message":"must be object"},{"instancePath":"/items/loadingTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      2025-07-13 13:27:08.744  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:27:09.021  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:27:09.036  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:27:11.302  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:27:50.855  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:27:50.995  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      2025-07-13 13:27:51.011  - info: admin.0 (43258) <== Disconnect system.user.admin from ::ffff:192.168.181.83 admin
      2025-07-13 13:27:53.437  - info: admin.0 (43258) ==> Connected system.user.admin from ::ffff:192.168.181.83
      iob diag has finished.
      pi@raspberrypi:~ $
        @thomas-braun sagte in Backup bricht mit Fehlermeldung ab:
        @frankthegreat
        Wie weit liegen die Versionen auseinander?
        Inbesondere sowas wie js-controller usw.
        Da gibt es so ein tolles Tool, das zeigt alles interessante auf einmal an, dann muss man nicht alles einzeln abfragen 😉
        • frankthegreat
          frankthegreat @Thomas Braun last edited by
          js-controller sind beide auf 7.0.6
          • frankthegreat
            ...und hier iob diag vom bestehenden Raspi, von dem ich das Backup gezogen habe:
            ```bash
            Script v.2025-03-08
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             13:44:39 up 21 days, 23:32,  2 users,  load average: 1.06, 0.39, 0.20
            CPU threads: 4
            Current issues:
                           Local time: Sun 2025-07-13 13:44:39 CEST
                       Universal time: Sun 2025-07-13 11:44:39 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            1.9G        1.5G        216M        212K        248M        393M
            Swap:           209M        209M        225K
            Total:          2.1G        1.8G        216M
            Active iob-Instances:   19
                     1846 M total memory
                     1471 M used memory
                      656 M active memory
                      833 M inactive memory
                      205 M free memory
                       39 M buffer memory
                      197 M swap cache
                      199 M total swap
                      199 M used swap
                        0 M free swap
            top - 13:44:40 up 21 days, 23:32,  2 users,  load average: 1.06, 0.39, 0.20
            Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   1846.3 total,    205.1 free,   1472.1 used,    237.5 buff/cache
            MiB Swap:    200.0 total,      0.2 free,    199.8 used.    374.2 avail Mem
            *** FILESYSTEM ***
            udev           devtmpfs  659M     0  659M   0% /dev
            tmpfs          tmpfs     185M  1.2M  184M   1% /run
            /dev/mmcblk0p2 ext4       29G  7.3G   20G  27% /
            tmpfs          tmpfs     924M     0  924M   0% /dev/shm
            /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
            tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
            /var:
            1.1G    /var/
            407M    /var/log/journal/e7d192ca681d40e3974bbd03acd95af0
            407M    /var/log
            348M    /var/cache
            Archived and active journals take up 406.3M in the file system.
            22M     /opt/iobroker/backups/
            870M    /opt/iobroker/iobroker-data/
            385M    /opt/iobroker/iobroker-data/files
            175M    /opt/iobroker/iobroker-data/node-red
            174M    /opt/iobroker/iobroker-data/node-red/node_modules
            173M    /opt/iobroker/iobroker-data/history
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            29M     /opt/iobroker/iobroker-data/objects.jsonl
            26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
            26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
            24M     /opt/iobroker/iobroker-data/files/eventlist/static/js/main.bf7d9efc.js.map
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 60473)
            admin:          7.6.17
            javascript:     8.9.2
            Adapter State
            + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
            + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
            + system.adapter.eventlist.0              : eventlist             : raspberrypi                              -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
            + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.193.22
            + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
              system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
            + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
            + system.adapter.pushover.1               : pushover              : raspberrypi                              -  enabled
            + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.valloxmv.0               : valloxmv              : raspberrypi                              -  enabled, port: 80
              system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            Active repo(s): Stable (default)
            Used repository: Stable (default)
             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
             States database error: connect ECONNREFUSED 127.0.0.1:9000
            Adapter    "alarm"        : 3.7.0    , installed 3.7.0
            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
            Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
            Adapter    "fb-checkpresence": 1.4.0 , installed 1.3.1  [Updatable]
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Adapter    "knx"          : 2.0.30   , installed 2.0.30
            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
            Adapter    "openweathermap": 1.1.2   , installed 1.1.2
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "valloxmv"     : 1.4.1    , installed 1.4.1
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        5756
            States:         5028
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Pending Updates: 37
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       313324     57594/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       314041     57594/iobroker.js-c
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4093       633/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          4095       633/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4008       499/avahi-daemon: r
            udp        0      0 0.0.0.0:36653           0.0.0.0:*                           104        4010       499/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        4009       499/avahi-daemon: r
            udp6       0      0 fe80::f5c0:797a:f7d:546 :::*                                0          6220       576/NetworkManager
            udp6       0      0 :::44597                :::*                                104        4011       499/avahi-daemon: r
            2025-07-13 13:48:59.441  - error: pushover.0 (57703) pushover.0 already running
            2025-07-13 13:48:59.446  - warn: pushover.0 (57703) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-07-13 13:49:01.286  - error: host.raspberrypi instance system.adapter.pushover.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-07-13 13:49:01.287  - info: host.raspberrypi Restart adapter system.adapter.pushover.0 because enabled
            2025-07-13 13:49:01.328  - info: host.raspberrypi instance system.adapter.pushover.1 in version "4.1.0" started with pid 58057
            2025-07-13 13:49:03.585  - error: pushover.1 (58057) pushover.1 already running
            2025-07-13 13:49:03.590  - warn: pushover.1 (58057) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-07-13 13:49:05.206  - error: host.raspberrypi instance system.adapter.pushover.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-07-13 13:49:05.208  - info: host.raspberrypi Restart adapter system.adapter.pushover.1 because enabled
            2025-07-13 13:49:05.294  - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.2.2" started with pid 58101
            2025-07-13 13:49:08.366  - error: backitup.0 (58101) backitup.0 already running
            2025-07-13 13:49:08.373  - warn: backitup.0 (58101) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-07-13 13:49:09.160  - info: host.raspberrypi instance system.adapter.alarm.0 in version "3.7.0" started with pid 58487
            2025-07-13 13:49:09.268  - error: host.raspberrypi instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-07-13 13:49:09.269  - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
            2025-07-13 13:49:11.589  - error: alarm.0 (58487) alarm.0 already running
            2025-07-13 13:49:11.593  - warn: alarm.0 (58487) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-07-13 13:49:13.264  - error: host.raspberrypi instance system.adapter.alarm.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-07-13 13:49:13.265  - info: host.raspberrypi Restart adapter system.adapter.alarm.0 because enabled
            2025-07-13 13:49:13.306  - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.26.5" started with pid 58505
            2025-07-13 13:49:16.447  - error: alexa2.0 (58505) alexa2.0 already running
            2025-07-13 13:49:16.459  - warn: alexa2.0 (58505) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-07-13 13:49:17.068  - info: host.raspberrypi instance system.adapter.device-watcher.0 in version "2.12.1" started with pid 58518
            2025-07-13 13:49:17.359  - error: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-07-13 13:49:17.360  - info: host.raspberrypi Restart adapter system.adapter.alexa2.0 because enabled
            pi@raspberrypi:~ $
              Homoran Global Moderator Administrators @frankthegreat last edited by Homoran
              @frankthegreat erstmal Dinge, die wahrscheinlich nichts mit dem Problem zu tun haben
              @frankthegreat sagte in Backup bricht mit Fehlermeldung ab:
              damit kommst du nicht mehr weit!
              selbst der Notfallschirm ist bereits aufgebraucht!!
              bei
              sind 2GB seeeehr knapp bemessen
              Pending Updates: 37
              mach die mal?@frankthegreat sagte in Backup bricht mit Fehlermeldung ab:
              deutet auf unsauber gestoppte Instanzen hin.
              müsste durch ein Reboot nach den Updates behoben sein.
              wenn nicht, kann es doch am geringen RAM liegen
                Thomas Braun Most Active @frankthegreat last edited by
                Pending Updates: 37
                Losgelöst vom Problem: Updaten...
                Was ist den da auf dem Alt-System los?
                Ich würde erstmal schauen das Ding wieder richtig ans rennen zu bekommen und dann mit einem Backup davon umziehen.
                frankthegreat 1 Reply Last reply Reply Quote 0
                • frankthegreat
                  Pending Updates: 37
                  Hmmm, also der Raspi läuft ja. Hat aber nur 2GB Ram.
                  Deswegen dachte ich...machst einfach ein Backup und wollte auf ein 4GB Modell umziehen.
                  Ich wüsste jetzt nicht, was ich konkret machen muß???
                    Hau die Updates drauf (inkl. ioBroker) und starte den Rechner mal komplett neu.
                    Dann alle unnötigen Instanzen stoppen, nochmal per
                    iob diag
                    schauen, ob das jetzt ohne Meldungen läuft, davon dann ein frisches Backup ziehen.
                    frankthegreat 2 Replies Last reply Reply Quote 0
                    • frankthegreat
                      OK, werd ich mal tun...wird aber eine Weile dauern. 😎
                      Ich werde berichten.
                      • frankthegreat
                        iob diag
                        OK, Updates...Neustart...alle unnötigen Instanzen gestoppt... neues Backup gezogen.
                        Jetzt isser auf jeden Fall am "rödeln" und zieht fleißig die Adapter. Dauert erfahrungsgemäß ein paar Stunden.
                        Ich sag mal optimistisch-es geht.
                        Melde mich bei Erfolg.
                        Danke für eure Hilfe 👍 👍 👍
                          Das spricht dafür, das die Kiste zuvor beim RAM überlastet gewesen ist.
                          343
