    4. [ESPHome] Beta release 0.5.0-beta.1 ready
      Dieter_P @Simon42 last edited by Dieter_P
      @simon42
      Vielen Dank. Das gibt mir schon mal eine Richtung vor.
      Habe Deinen Fork installiert und bekam wieder die Fehlermeldung im log. Dort war etwas bzgl. pip version angemerkt und habe danach pip von 24.0 auf 24.3.1 upgedated
      Aber nach Adapterneustart immer noch:
      esphome.0
      	2024-11-21 17:06:00.515	error	Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2024.11.0 pillow==10.2.0 ERROR: Cannot install esphome==2024.11.0 and pillow==10.2.0 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2024.11.0 Using cached esphome-2024.11.0-py3-none-any.whl.metadata (3.5 kB) Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl.metadata (9.7 kB) Collecting cryptography==43.0.0 (from esphome==2024.11.0) Using cached cryptography-43.0.0-cp39-abi3-manylinux_2_28_x86_64.whl.metadata (5.4 kB) Collecting voluptuous==0.14.2 (from esphome==2024.11.0) Using cached voluptuous-0.14.2-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.2 (from esphome==2024.11.0) Using cached PyYAML-6.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.1 kB) Collecting paho-mqtt==1.6.1 (from esphome==2024.11.0) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2024.11.0) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2024.11.0) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.4 (from esphome==2024.11.0) Using cached tornado-6.4-cp38-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.5 kB) Collecting tzlocal==5.2 (from esphome==2024.11.0) Using cached tzlocal-5.2-py3-none-any.whl.metadata (7.8 kB) Collecting tzdata>=2021.1 (from esphome==2024.11.0) Using cached tzdata-2024.2-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2024.11.0) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.16 (from esphome==2024.11.0) Using cached platformio-6.1.16.tar.gz (239 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting esptool==4.7.0 (from esphome==2024.11.0) Using cached esptool-4.7.0.tar.gz (285 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2024.11.0) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20241120.0 (from esphome==2024.11.0) Using cached esphome_dashboard-20241120.0-py3-none-any.whl.metadata (1.0 kB) Collecting aioesphomeapi==24.6.2 (from esphome==2024.11.0) Using cached aioesphomeapi-24.6.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.9 kB) Collecting zeroconf==0.132.2 (from esphome==2024.11.0) Using cached zeroconf-0.132.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (6.0 kB) Collecting puremagic==1.27 (from esphome==2024.11.0) Using cached puremagic-1.27-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.18.6 (from esphome==2024.11.0) Using cached ruamel.yaml-0.18.6-py3-none-any.whl.metadata (23 kB) Collecting glyphsets==1.0.0 (from esphome==2024.11.0) Using cached glyphsets-1.0.0-py3-none-any.whl.metadata (12 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.2.0 esphome 2024.11.0 depends on pillow==10.4.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2024.11.0 pillow==10.2.0 ERROR: Cannot install esphome==2024.11.0 and pillow==10.2.0 because these package versions have conflicting dependencies. ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2024.11.0 Using cached esphome-2024.11.0-py3-none-any.whl.metadata (3.5 kB) Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_x86_64.whl.metadata (9.7 kB) Collecting cryptography==43.0.0 (from esphome==2024.11.0) Using cached cryptography-43.0.0-cp39-abi3-manylinux_2_28_x86_64.whl.metadata (5.4 kB) Collecting voluptuous==0.14.2 (from esphome==2024.11.0) Using cached voluptuous-0.14.2-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.2 (from esphome==2024.11.0) Using cached PyYAML-6.0.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.1 kB) Collecting paho-mqtt==1.6.1 (from esphome==2024.11.0) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2024.11.0) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2024.11.0) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.4 (from esphome==2024.11.0) Using cached tornado-6.4-cp38-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.5 kB) Collecting tzlocal==5.2 (from esphome==2024.11.0) Using cached tzlocal-5.2-py3-none-any.whl.metadata (7.8 kB) Collecting tzdata>=2021.1 (from esphome==2024.11.0) Using cached tzdata-2024.2-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2024.11.0) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.16 (from esphome==2024.11.0) Using cached platformio-6.1.16.tar.gz (239 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting esptool==4.7.0 (from esphome==2024.11.0) Using cached esptool-4.7.0.tar.gz (285 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2024.11.0) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20241120.0 (from esphome==2024.11.0) Using cached esphome_dashboard-20241120.0-py3-none-any.whl.metadata (1.0 kB) Collecting aioesphomeapi==24.6.2 (from esphome==2024.11.0) Using cached aioesphomeapi-24.6.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (4.9 kB) Collecting zeroconf==0.132.2 (from esphome==2024.11.0) Using cached zeroconf-0.132.2-cp311-cp311-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (6.0 kB) Collecting puremagic==1.27 (from esphome==2024.11.0) Using cached puremagic-1.27-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.18.6 (from esphome==2024.11.0) Using cached ruamel.yaml-0.18.6-py3-none-any.whl.metadata (23 kB) Collecting glyphsets==1.0.0 (from esphome==2024.11.0) Using cached glyphsets-1.0.0-py3-none-any.whl.metadata (12 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.2.0 esphome 2024.11.0 depends on pillow==10.4.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:95:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13) at Esphome.espHomeDashboard (/Users/nl69zh/Developer/community/opensource/ioBroker.esphome/main.js:180:7) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
      Stimmt hier eine Version noch nicht bei mir? Hier steht was von pillow 10.1.0 und im Fehler von 10.2.0? Danke und sorry für die Fragen.
      Simon42 1 Reply Last reply Reply Quote 0
      • Simon42
        Simon42 @Dieter_P last edited by
        @dieter_p
        pip ist egal. war nur ne info, dass es halt eine neuere Version gibt.
        Wie hast du pip geupdated?
        Bitte nochmal versuchen. Gab schon wieder ein update.
        D 2 Replies Last reply Reply Quote 1
          @simon42 said in [ESPHome] Beta release 0.5.0-beta.1 ready:
          @dieter_p
          Bezogen auf die notiz:
          [notice] A new release of pip is available: 24.0 -> 24.3.1
          [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
          mit:
          sudo /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
          ok, danke versuchs.
            Vielen Dank. Ist schon was länger her, aber nun hab ich endlich wieder eine ESPHome Möglichkeit zum testen auf dem System🕺
            • Simon42
              @dieter_p said in [ESPHome] Beta release 0.5.0-beta.1 ready:
        [notice] A new release of pip is available: 24.0 -> 24.3.1        [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
              @dieter_p eben nur eine [notice]. Keine Warning oder ähnliches. aber ok
              Bitte (auf linux generell) nicht unbedacht sudo verwenden. Führt meist früher als später zu Berechtigungsproblemen (vom iobroker).
              Fix mit:
              sudo chown -R iobroker:iobroker /home/iobroker/.cache/autopy
              Zukünftig commands als iobroker user ausführen z.B.:
              sudo -Hu iobroker /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
              • Simon42
                No problem 👍
                  Tontechniker last edited by Tontechniker
                  Ich habe die 6.0.1 Installiert. Meine Probleme ist bei Angabe der IP-Adresse für das Dashboard unten stehende Fehlermeldungen:
                  Hier meine Einstellungen:
                  Das Problem bestand auch schon bei den vorigen Versionen. Ein User schrieb, dass es mit meinem Raspi Betriebssystem zusammenhängt (alles auf aktuellem Stand!)??!
                  Kann mir jemand weiterhelfen das Dashboard zum Laufen zu bringen?
                  Hans
                    Thomas Braun Most Active @Tontechniker last edited by
                    @tontechniker sagte in [ESPHome] Beta release 0.5.0-beta.1 ready:
                    Womit bist du denn da so unterwegs? Gesamtkonstrukt kannst du u.a. mittels
                    iob diag
                    sehen.
                      Tontechniker @Thomas Braun last edited by Tontechniker
                      Hallo Thomas,
                      danke für Deine Antwort! Im Anhang die geloggte IOB-Diag. Vielleicht kannst Du ja etwas damit anfangen?
                      iob_diag.log
                      Und nach fix:
                      iob_diag 1.log
                      Danke für Deine Hilfe!
                      Hans
                      • Simon42
                        Simon42 @Tontechniker last edited by
                        @tontechniker Hallo,
                        bereits bekanntes Problem:
                        OS is similar to: debian
                        Model		: Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 32 bit
                        Dein kernel ist 64bit aber 32bit userspace.
                        Bitte mal Standard 64-BIt Rasperry-Pi OS neu aufsetzen. (vorher backup machen! oder am besten Neuinstallation auf 2. SD-Karte und dann migrieren.
                        Node und 32bit macht nur Probleme und ein PI4 sollte das locker schaffen.
                          Tontechniker @Simon42 last edited by
                          @simon42
                          Hallo Simon42
                          Kannst Du mir bitte den Link zum 64-Bit Raspberry-Pi-OS schreiben? Habe auf Raspi-Seite gesucht un es nicht gefunden.
                          Danke!
                          Simon42 Thomas Braun 2 Replies Last reply Reply Quote 0
                          • Simon42
                            @tontechniker
                            https://www.raspberrypi.com/software/operating-systems/
                            Einfach etwas nach unten scrollen:
                            Alternativ auch mit dem Raspberry Pi Imager:
                              @tontechniker
                              Ich würde es mit dem PiImager machen. Da kann man direkt schon ein paar Grundeinstellungen vornehmen.
                              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                Danke euch Beiden! Bin die nächste 8 Wochen wegen Bestrahlung nicht bei mir zu Hause. Melde mich, wenn ich es ausgeführt habe.
                                Danke!
                                Hans
                                adapter entwicklung adapter update esphome
                                14
                                75
                                6454
