    4. iob startet nicht mehr nach js-controller-Update
      Thomas Braun Most Active @andisoft1 last edited by
      @andisoft1 sagte in iob startet nicht mehr nach js-controller-Update:
      Core adapters versions
      js-controller: 5.0.19
      Bring das Etappenweise über js-controller@6 auf den aktuellen js-controller.
      Und regelmäßiger updaten...
      Die Ausgabe von iob diag ist nicht vollständig.
      andisoft1 1 Reply Last reply Reply Quote 0
      • andisoft1
        andisoft1 @andisoft1 last edited by
        Ausgabe nach der Installation von js-controller 7.0.6
        ========== Start marking the full check here ===========
        Script v.2025-03-08
        *** BASE SYSTEM ***
         Static hostname: iob
               Icon name: computer-laptop
                 Chassis: laptop 💻
        Operating System: Ubuntu 24.04.2 LTS
                  Kernel: Linux 6.8.0-63-generic
            Architecture: x86-64
         Hardware Vendor: GEEKOM
          Hardware Model: MiniAir 11
        Firmware Version: 2.09
           Firmware Date: Wed 2023-02-08
            Firmware Age: 2y 5month 1w 1d
        OS is similar to: debian
        model name      : Intel(R) Celeron(R) N5095 @ 2.00GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         00:12:58 up 10:13,  2 users,  load average: 0.26, 0.49, 0.71
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Ubuntu LTS release codenamed 'noble'!
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2025-07-18 00:12:59 CEST
                   Universal time: Thu 2025-07-17 22:12:59 UTC
                         RTC time: Thu 2025-07-17 22:12:59
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        fink
        HOME=/home/fink
        GROUPS=fink adm sudo iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.1G        1.3G        4.9G        6.1M        2.3G        6.8G
        Swap:            13G          0B         13G
        Total:           21G        1.3G         18G
        Active iob-Instances:   1
                 7721 M total memory
                 1209 M used memory
                 1120 M active memory
                 1433 M inactive memory
                 4641 M free memory
                  350 M buffer memory
                 1827 M swap cache
                13203 M total swap
                    0 M used swap
                13203 M free swap
        top - 00:12:59 up 10:13,  2 users,  load average: 0.26, 0.49, 0.71
        Tasks: 181 total,   1 running, 180 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  2.2 us,  4.4 sy,  0.0 ni, 93.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7721.1 total,   4641.0 free,   1209.6 used,   2178.7 buff/cache
        MiB Swap:  13204.0 total,  13204.0 free,      0.0 used.   6511.5 avail Mem
        *** FAILED SERVICES ***
          UNIT              LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service  loaded failed failed ioBroker Server
        * minidlna.service  loaded failed failed MiniDLNA lightweight DLNA/UPnP-AV server
        * postfix@-.service loaded failed failed Postfix Mail Transport Agent (instance -)
        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                SUB    -> The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        tmpfs          tmpfs     773M  5.6M  767M   1% /run
        /dev/sda5      ext4       41G   37G  1.8G  96% /
        tmpfs          tmpfs     3.8G     0  3.8G   0% /dev/shm
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        efivarfs       efivarfs  192K   45K  143K  24% /sys/firmware/efi/efivars
        tmpfs          tmpfs     3.8G     0  3.8G   0% /tmp
        /dev/sda8      vfat      400M  6.2M  394M   2% /boot/efi
        /dev/sda6      ext4      134G   11G  117G   9% /home
        tmpfs          tmpfs     773M   96K  773M   1% /run/user/3202
        Show mounted filesystems:
        TARGET                                   SOURCE                         FSTYPE   OPTIONS
        /                                        /dev/sda5                      ext4     rw,relatime,discard
        |-/snap/bare/5                           /dev/loop0                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/2010                      /dev/loop1                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core24/1006                      /dev/loop3                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/2045                      /dev/loop2                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core24/1055                      /dev/loop4                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firefox/6436                     /dev/loop5                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firefox/6495                     /dev/loop6                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/202                /dev/loop7                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/176                /dev/loop8                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-46-2404/117                /dev/loop9                     squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-46-2404/90                 /dev/loop10                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gtk-common-themes/1535           /dev/loop11                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/mesa-2404/495                    /dev/loop12                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/mesa-2404/887                    /dev/loop13                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/mysql-workbench-community/13     /dev/loop14                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/mysql-workbench-community/15     /dev/loop15                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd/24718                      /dev/loop17                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/var/snap/firefox/common/host-hunspell /dev/sda5[/usr/share/hunspell] ext4     ro,noexec,noatime,discard
        |-/snap/snapd/24792                      /dev/loop16                    squashfs ro,nodev,relatime,errors=continue,threads=single
        |-/boot/efi                              /dev/sda8                      vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        `-/home                                  /dev/sda6                      ext4     rw,relatime,discard
        /var:
        14G     /var/
        11G     /var/lib
        5.7G    /var/lib/snapd
        4.4G    /var/lib/mysql
        3.8G    /var/lib/snapd/snaps
        Archived and active journals take up 1.7G in the file system.
        /opt/iobroker/backups:
        3.9G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.7G    /opt/iobroker/iobroker-data/
        738M    /opt/iobroker/iobroker-data/files
        395M    /opt/iobroker/iobroker-data/Instanz1
        278M    /opt/iobroker/iobroker-data/backup-objects
        68M     /opt/iobroker/iobroker-data/files/vis
        42M     /opt/iobroker/iobroker-data/objects.jsonl_20230914
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        39M     /opt/iobroker/iobroker-data/objects.jsonl
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/2024-01-22_16-55_objects.jsonl
        USB-Devices by-id:
        No Devices found 'by-id'
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.3
        /usr/bin/node           v20.19.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
          Installed: 20.19.3-1nodesource1
          Candidate: 20.19.4-1nodesource1
          Version table:
             20.19.4-1nodesource1 600
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         *** 20.19.3-1nodesource1 600
                100 /var/lib/dpkg/status
             20.19.2-1nodesource1 600
             20.19.1-1nodesource1 600
             20.19.0-1nodesource1 600
             20.18.3-1nodesource1 600
             20.18.2-1nodesource1 600
             20.18.1-1nodesource1 600
             20.18.0-1nodesource1 600
             20.17.0-1nodesource1 600
             20.16.0-1nodesource1 600
             20.15.1-1nodesource1 600
             20.15.0-1nodesource1 600
             20.14.0-1nodesource1 600
             20.13.1-1nodesource1 600
             20.13.0-1nodesource1 600
             20.12.2-1nodesource1 600
             20.12.1-1nodesource1 600
             20.12.0-1nodesource1 600
             20.11.1-1nodesource1 600
             20.11.0-1nodesource1 600
             20.10.0-1nodesource1 600
             20.9.0-1nodesource1 600
             20.8.1-1nodesource1 600
             20.8.0-1nodesource1 600
             20.7.0-1nodesource1 600
             20.6.1-1nodesource1 600
             20.6.0-1nodesource1 600
             20.5.1-1nodesource1 600
             20.5.0-1nodesource1 600
             20.4.0-1nodesource1 600
             20.3.1-1nodesource1 600
             20.3.0-1nodesource1 600
             20.2.0-1nodesource1 600
             20.1.0-1nodesource1 600
             20.0.0-1nodesource1 600
             18.19.1+dfsg-6ubuntu5 500
                500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iob                 iob (version: 5.0.19, hostname: iob           , alive, uptime: 28012)
        iob-zwave           iob-zwave (version: 7.0.6, hostname: iob-zwave     , dead, uptime: 27278)
        js-controller:  7.0.6
        admin:          7.6.17
        javascript:     8.9.2
        nodejs modules from github:     1
        | +-- node-milight-promise@0.3.2 (git+ssh://git@github.com/Steiger04/node-milight-promise.git#f1089feac9b7990727adf2016891029436729d33)
        Adapter State
          system.adapter.accuweather.0            : accuweather           : iob                                      - disabled
          system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0
          system.adapter.alias-manager.0          : alias-manager         : iob                                      -  enabled
          system.adapter.backitup.0               : backitup              : iob                                      -  enabled
          system.adapter.chromecast.0             : chromecast            : iob                                      -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iob                                      - disabled
          system.adapter.daswetter.0              : daswetter             : iob                                      -  enabled
          system.adapter.devices.0                : devices               : iob                                      -  enabled
          system.adapter.discovery.0              : discovery             : iob                                      -  enabled
          system.adapter.dwd.0                    : dwd                   : iob                                      - disabled
          system.adapter.echarts.0                : echarts               : iob                                      -  enabled
          system.adapter.email.0                  : email                 : iob                                      -  enabled
          system.adapter.energiefluss.0           : energiefluss          : iob                                      -  enabled
          system.adapter.feiertage.0              : feiertage             : iob                                      -  enabled
          system.adapter.flot.0                   : flot                  : iob                                      -  enabled
          system.adapter.fullcalendar.0           : fullcalendar          : iob                                      -  enabled
          system.adapter.ical.0                   : ical                  : iob                                      -  enabled
          system.adapter.icons-material-svg.0     : icons-material-svg    : iob                                      - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob                                      - disabled
          system.adapter.info.0                   : info                  : iob                                      - disabled
          system.adapter.iqontrol.0               : iqontrol              : iob                                      - disabled
          system.adapter.javascript.0             : javascript            : iob                                      -  enabled
          system.adapter.javascript.1             : javascript            : iob                                      - disabled
          system.adapter.js-controller.0          : js-controller         : iob                                      -  enabled
          system.adapter.lovelace.0               : lovelace              : iob                                      - disabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.material.0               : material              : iob                                      - disabled
          system.adapter.midea.0                  : midea                 : iob                                      -  enabled
          system.adapter.milight-smart-light.0    : milight-smart-light   : iob                                      - disabled
          system.adapter.milight.0                : milight               : iob                                      -  enabled, port: 5987
          system.adapter.mobile.0                 : mobile                : iob                                      - disabled
          system.adapter.modbus.0                 : modbus                : iob                                      -  enabled
          system.adapter.mqtt.0                   : mqtt                  : iob                                      -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.net-tools.0              : net-tools             : iob                                      - disabled
          system.adapter.onkyo.0                  : onkyo                 : iob                                      -  enabled
          system.adapter.openweathermap.0         : openweathermap        : iob                                      - disabled
          system.adapter.ping.0                   : ping                  : iob                                      -  enabled
          system.adapter.proxy.0                  : proxy                 : iob                                      - disabled
          system.adapter.pvforecast.0             : pvforecast            : iob                                      -  enabled
          system.adapter.raumfeld.0               : raumfeld              : iob                                      - disabled
          system.adapter.rickshaw.0               : rickshaw              : iob                                      - disabled
          system.adapter.sayit.0                  : sayit                 : iob-zwave                                -  enabled
          system.adapter.scenes.0                 : scenes                : iob                                      -  enabled
          system.adapter.semp.0                   : semp                  : iob                                      -  enabled
          system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1889, bind: 0.0.0.0
          system.adapter.shelly.1                 : shelly                : iob                                      - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.simple-api.0             : simple-api            : iob                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.sma-em.0                 : sma-em                : iob                                      -  enabled
          system.adapter.socketio.0               : socketio              : iob                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.solarwetter.0            : solarwetter           : iob                                      -  enabled
          system.adapter.sonoff.0                 : sonoff                : iob                                      -  enabled, port: 1884, bind: 0.0.0.0
          system.adapter.sql.0                    : sql                   : iob                                      -  enabled, port: 3306
          system.adapter.statistics.0             : statistics            : iob                                      -  enabled
          system.adapter.text2command.0           : text2command          : iob                                      -  enabled
          system.adapter.upnp.0                   : upnp                  : iob                                      - disabled
          system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iob                                      -  enabled
          system.adapter.vis-bars.0               : vis-bars              : iob                                      - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob                                      - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iob                                      -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iob                                      - disabled
          system.adapter.vis-history.0            : vis-history           : iob                                      - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob                                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob                                      - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iob                                      - disabled
          system.adapter.vis-players.0            : vis-players           : iob                                      - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iob                                      - disabled
          system.adapter.vis-weather.0            : vis-weather           : iob                                      - disabled
          system.adapter.vis.0                    : vis                   : iob                                      -  enabled
          system.adapter.vuplus.0                 : vuplus                : iob                                      - disabled
          system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.webui.0                  : webui                 : iob                                      -  enabled
          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob                                      -  enabled
          system.adapter.wled.0                   : wled                  : iob                                      -  enabled
          system.adapter.worx.0                   : worx                  : iob                                      -  enabled
          system.adapter.ws.0                     : ws                    : iob                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.zigbee.0                 : zigbee                : iob-zwave                                -  enabled, port: /dev/ttyACM0
          system.adapter.zwave2.0                 : zwave2                : iob-zwave                                -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
          Hosts:
          Kann ja eigentlich nicht sein.
          andisoft1 2 Replies Last reply Reply Quote 0
          • andisoft1
            andisoft1 @Thomas Braun last edited by
            @thomas-braun Was meinst Du, die unterschiedlichen Versionen auf den Hosts ?
              @andisoft1
              Ja. Der host 'iob' wird mit 5.0.19 angezeigt, danach wird in der gleichen Installation 7.0.6 aufgeführt.
              • andisoft1
                andisoft1 @Thomas Braun last edited by andisoft1
                Hier das Protokoll an dem die Instanzen wieder gestoppt werden:
                2025-07-18 00:17:15.976  - info: javascript.0 (179504) received all objects
                2025-07-18 00:17:16.340  - info: host.iob iobroker.js-controller version 7.0.6 js-controller starting
                2025-07-18 00:17:16.342  - info: host.iob Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                2025-07-18 00:17:16.343  - info: host.iob hostname: iob, node: v20.19.3
                2025-07-18 00:17:16.343  - info: host.iob ip addresses: 192.168.1.124 fd07:3d39:28eb:0:f3eb:853d:4127:46b2 fd07:3d39:28eb:0:2cc6:17a8:6f35:58ec 2a02:8071:50f3:4660:86d9:c2c4:dbf9:d337 2a02:8071:50f3:4660:ecfe:71c9:4f5f:5f9b fe80::164:48db:5aca:446d 192.168.1.123 2a02:8071:50f3:4660:bc46:e41e:ba72:e08a 2a02:8071:50f3:4660:9ed3:2f47:9a8f:5780 fd07:3d39:28eb:0:5702:4b04:c945:7bb6 fd07:3d39:28eb:0:5517:5fe1:5cd7:ca0e fe80::470c:a2b2:79ef:a0b4
                2025-07-18 00:17:16.682  - info: javascript.0 (179504) received all states
                2025-07-18 00:17:16.953  - info: javascript.0 (179504) script.js.global.piremote_irsend: compiling TypeScript source...
                2025-07-18 00:17:18.411  - error: host.iob-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker_neu/iobroker-data/objects.jsonl"!
                2025-07-18 00:17:18.558  - error: host.iob instance system.adapter.js-controller.0 terminated with code 22 (NO_CONNECTION_TO_OBJ_DB)
                2025-07-18 00:17:18.561  - error: host.iob uncaught exception: Cannot read properties of undefined (reading 'webInstance')
                2025-07-18 00:17:18.561  - error: host.iob TypeError: Cannot read properties of undefined (reading 'webInstance')
                    at file:///opt/iobroker_neu/node_modules/iobroker.js-controller/build/esm/main.js:3533:53
                    at Immediate.<anonymous> (file:///opt/iobroker_neu/node_modules/iobroker.js-controller/build/esm/main.js:1041:31)
                    at process.processImmediate (node:internal/timers:485:21)
                2025-07-18 00:17:18.562  - info: host.iob stopInstance system.adapter.admin.0 (force=false, process=true)
                2025-07-18 00:17:18.563  - info: host.iob stopInstance system.adapter.email.0 (force=false, process=true)
                2025-07-18 00:17:18.563  - info: host.iob stopInstance system.adapter.javascript.0 (force=false, process=true)
                2025-07-18 00:17:18.563  - info: host.iob stopInstance system.adapter.javascript.1 (force=false, process=false)
                2025-07-18 00:17:18.563  - info: host.iob stopInstance system.adapter.js-controller.0 (force=false, process=false)
                Es ist auch egal ob die Instanz auf dem iob-zwave-Server läuft oder nicht ...
                • andisoft1
                  @thomas-braun Ich habe alle Versionen ausprobiert, auch die 6er. Ich kämpfe schon länger mit den Upgrade, bisher habe ich alles selbst hinbekommen. Ich habe nur keine Lust alles neu zu installieren, da steckt ja schon einiges drin.
                    Thomas Braun Most Active @andisoft1 last edited by Thomas Braun
                    @andisoft1
                    Wie kommt es denn zu diesem Installationsverzeichnis?
                    /opt/iobroker_neu/
                    Üblich ist /opt/iobroker. Da hast du zwei Installationen laufen, eine in /opt/iobroker und eine in /opt/iobroker_neu
                    Kann ich dir nicht helfen, hab ich noch nie mit zu tun gehabt.
                      arteck Developer Most Active @andisoft1 last edited by
                      dein fehler ist hier..
                      da ist die objects.jsonl nicht migriert worden
                      aber sonst kein plan was du da treibst
                        Homoran Global Moderator Administrators @andisoft1 last edited by
                        Wir hatten dich bereits im ersten Post gefragt wo du einen BUG von ioBroker siehst.
                        Nachdem du auf erneute Nachfrage dann jetzt doch den iob diag gezeigt hast, sieht es wirklich so aus
                        allerdings nicht wie
                        Im Moment sieht es wirklich eher wie eine komplett verbogene Installation aus.
                        Leider sind deine bisherigen Informationen zu der Entstehungsgeschichte deines Systems noch sehr lückenhaft.
                        Eine komplette Neuinstallation erscheint mir der einfachsten/ sicherste Weg zu sein ein sauberes System zu erhalten.
                        Das bekommst du ja auch alles wieder wenn du dein Backup auf dem neuen System wiederherstellst
                          @arteck
                          und wenn du kein backup hast..dann sicher dir JETZT zumindest
                          Ordner.
                          • andisoft1
                            andisoft1 @arteck last edited by
                            Danke für das Feedback - Backups habe ich reichlich. Ich werde es mal mit einer neuen Installation probieren.
                            572
