    4. Sonos-HTTP-API Installation für Newbies, Dummies und mich
      dodi666 @Qlink last edited by
      @qlink Hi,
      ist mir gestern beim testen auch aufgefallen. Und habe ein Github Issue dazu aufgemacht.
      https://github.com/dwm66/iobroker-scripts/issues/5
      Die Version des Skriptes die du nutzt, ist nicht die aktuelle. Bei dieser tritt die Warnung aber auch auf...
      https://github.com/dwm66/iobroker-scripts/blob/master/SonosAPI/sonosapi.js
      dodi666 created this issue in dwm66/iobroker-scripts
      closed Skript Warnung: "More than 100 subscriptions registered" #5
      O Q 2 Replies Last reply Reply Quote 0
      • O
        oFbEQnpoLKKl6mbY5e13 @dodi666 last edited by oFbEQnpoLKKl6mbY5e13
        @dodi666 & @Qlink
        Kann man in den Einstellungen des Javascript-Adapters anpassen.
        • Q
          Qlink @dodi666 last edited by Qlink
          @dodi666
          Danke für den Hinweis.
          Leider funktioniert das neue Skript nicht bei mir:
          var http = require('http');
          var url  = require('url');
          var debuglevel = 2;
          var debugchannel = 'info';
          var AdapterId = "javascript."+instance;
          var develMode = false;
          var version = "0.11.3";
          var stateBasePath = AdapterId + '.SonosAPI';
          // untested, but should work:
          // var stateBasePath = '0_userdata.0.SonosAPI';
          // Modify these settings
          // BaseURL: the URL of the SonosAPI. Example: "http://10.22.1.40:5005"
          var BaseURL = "http://192.168.30.91:5005";
          // SonosAPIAuth: Authentication data for the Sonos API, if there a user and password is
          // declared.
          // Example:
          var SonosAuthUser = "username";
          var SonosAuthPass = "Password123";
          // var SonosAPIAuth = "Basic " + new Buffer("username" + ":" + "Password123").toString("base64");
          // the port where this script should be reachable from the SonosAPI webhook mechanism.
          // example:
          var webHookPort = 1884;
          // using this example, the settings.json on the Sonos API must contain:
            "webhook": "http://192.168.30.91:1884/"
          // replace "iobroker_uri" with the address of your iobroker machine.
          // var webHookPort = 1884;
          Ich bekomme immer folgenden Fehler:
          javascript.0	07:35:06.377	info	Stopping script script.js.Sonos.iobroker2SonosAPI-V_0_11_3
          javascript.0	07:35:06.383	info	Start JavaScript script.js.Sonos.iobroker2SonosAPI-V_0_11_3 (Javascript/js)
          javascript.0	07:35:06.384	error	script.js.Sonos.iobroker2SonosAPI-V_0_11_3 compile failed: at script.js.Sonos.iobroker2SonosAPI-V_0_11_3:36
          Die 0.9.6 funktioniert ohne Fehlermeldung ...
          D S 2 Replies Last reply Reply Quote 0
            @qlink
            Bei mir sind die Zeilen:
            auskommentiert.
            //"webhook": "http://192.168.30.91:1884/"
            Vielleicht solltest du den originalen Code von Github nochmal nehmen, und entsprechend parametrieren. Bei mir läuft die letzte Version einwandfrei...
            • Q
              @dodi666
              Wenn ich den Code von Github 1:1 nehme und nur die BaseURL anpasse bekomme ich folgende Fehlermeldungen:
              javascript.0	09:29:15.228	info	Stopping script script.js.Sonos.iobroker2SonosAPI-V_0_11_3
              javascript.0	09:29:17.066	info	Start JavaScript script.js.Sonos.iobroker2SonosAPI-V_0_11_3 (Javascript/js)
              javascript.0	09:29:17.073	error	script.js.Sonos.iobroker2SonosAPI-V_0_11_3: ReferenceError: dwmlog is not defined
              javascript.0	09:29:17.074	error	at requestSonosAPI (script.js.Sonos.iobroker2SonosAPI-V_0_11_3:106:5)
              javascript.0	09:29:17.074	error	at requestSonosZones (script.js.Sonos.iobroker2SonosAPI-V_0_11_3:953:5)
              javascript.0	09:29:17.074	error	at script.js.Sonos.iobroker2SonosAPI-V_0_11_3:1082:1
              javascript.0	09:29:17.074	error	at script.js.Sonos.iobroker2SonosAPI-V_0_11_3:1093:3
                skorpil @Qlink last edited by
                @qlink ich sehe da im Script „require“. Soweit ich weiß, wurde dieser Aufruf in neueren JavaScript Adapter Versionen abgeschaltet. Ersetzt wurde er durch „httpget“. Vielleicht ist das der Fehler. Ich bin aber kein Experte, nur eine plausible Vermutung. Ich kann auch keine Lösung anbieten. Aber vielleicht ist das eine Spur, die man mal prüfen könnte
                  @qlink Dir fehlt das "dwmlog". Wenn du es verwendest, musst du es auch einbinden...
                  function dwmlog( message, level, channel) {
                      if (typeof channel === 'undefined') {
                          channel = debugchannel;
                      if ( typeof level === 'undefined')
                          level = debuglevel;
                      if ( debuglevel >= level ) {
                          log (message, channel );
                  Ich habe das so einfach unter den Konfigurationsteil eingefügt.
                  • Q
                    @dodi666
                    Keine Ahnung wozu das gut ist ... 😁
                    Ich hab deinen Code eingefügt und jetzt läuft das Skript ohne Fehler durch!
                    Besten Dank für die Hilfe!
                      mojo1986 last edited by mojo1986
                      Hallo Zusammen funktioniert denn bei euch mit dem Skript von link text auch der webhook? also wenn ihr die Lautstärke ändert in der Sonos App wird
                      das vom Datenpunkt im iobroker übernommen zum Beispiel?
                      Kann jemand schauen was bei meinem code falsch sein kann`?
                      Settings.json datei inhalt
                      "webhook": "http://192.168.1.49:1884/"
                      //"webhook": "http://192.168.1.49:5007/",
                      "auth": {
                          "username": "lmo",
                          "password": "volumax1"
                      Skript im Iobroker:
                              level = debuglevel;
                      var debuglevel = 2;
                      var BaseURL = "http://192.168.1.49:5005";
                      // declared.
                      // Example:
                      var SonosAuthUser = "lmo";
                      var SonosAuthPass = "volumax1";
                      // example:
                      //   "webhook": "http://iobroker_uri:1884/"
                      // SSML Mode für sayEx. Unterstützt nur "Polly". Wenn auf "Polly gestellt ist, wird die Stimme auf"
                      // 90% Geschwindigkeit gesetzt.
                      var SSMLMode = "Polly";
                      // datapoint where the sayEx function can get the current temperature
                      var TempSensorId = "alias.0.Klima.Aussen.TEMPERATURE";
                      // URL of a fallback album art picture
                      var fallbackAlbumURL = '/icons-mfd-svg/audio_sound.svg';
                      var TVAlbumURL = '/icons-mfd-svg/it_television.svg';
                      // If setting a Favorite, it is reset to "" after this time (seconds).
                      // If you don't want that behavior, set to 0.
                      var resetFavoriteTime = 5;
                      // Album crap - base url
                      var getaaurl = 'http://10.22.1.27:1400';
                      var basePath = stateBasePath+".Rooms";
                      // intermediate storage for paused Sonos in TV mode
                      // part of workaround for https://github.com/jishi/node-sonos-http-api/issues/741
                      var pauseTVBuffer = {};
                      var VolumeTimeout = null;
                      function requestSonosAPI( req, cb, cbParam ){
                          var url = BaseURL+req;
                          dwmlog("requestSonosAPI URL: "+url,3);
                          if (develMode) return;
                          let reqoptions =
                          request({
                              uri: url,
                              method: "GET",
                              timeout: 120000,
                              followRedirect: true,
                              maxRedirects: 10,
                              headers : {
                                  "Authorization" : SonosAPIAuth
                          }, function(error, response, body) {
                              // dwmlog("Sonos Error " + error,2);
                              dwmlog("Sonos Response: " + JSON.stringify(response,0,4),5);
                              // dwmlog("Sonos Body: " + body,5);
                              if (error === null) {
                                  if (cb) cb(JSON.parse(body),cbParam);
                              } else {
                                  dwmlog ("Error occured during SonosAPI call: "+error,1,"warn");
                          httpGet(url, { timeout: 120000, basicAuth: { user: SonosAuthUser, password: SonosAuthPass } }, (err, response) => {
                              if (!err) {
                                  if (cb) cb(JSON.parse(response.data),cbParam);
                              } else {
                                  dwmlog ("Error occured during SonosAPI call: "+err,1,"warn");
                      function createOrSetState(name,value,forceCreate,spec){
                          dwmlog("createOrSetState "+name+" to: "+value,5);
                          if (value === undefined ) value = "n/a";
                          existsState(name,(err,isExists)=>{
                              if (!isExists) {
                                  dwmlog("Variable "+name+" undefined yet",5);
                                  createState(name,value,forceCreate,spec);
                              } else {
                                  let state = getState(name);
                                  if (state.val !== value || state.ack !== true )
                                      setState(name,value,true);
                      function setStateProtected(dp,val,ack){
                          if (ack === undefined ) ack=false;
                          if (val === undefined ) val = "n/a";
                          setState(dp,val,ack);
                      function getAlbumUri(stateData,absolute){
                          var result = "";
                          dwmlog ("getAlbumUri: "+JSON.stringify(stateData),3);
                          if (absolute) result = stateData.currentTrack.absoluteAlbumArtUri;
                          // else result = stateData.currentTrack.albumArtUri;
                          if (result === undefined) {
                              if (absolute) result = fallbackAlbumURL; else {
                                  result = url.parse(fallbackAlbumURL,true).pathname;
                          if (stateData.currentTrack.uri.startsWith("x-file-cifs")){
                              result=fallbackAlbumURL;
                          if (isTVMode(stateData.currentTrack.uri)){
                              result=TVAlbumURL;
                          if (stateData.currentTrack.absoluteAlbumArtUri == stateData.currentTrack.uri){
                              dwmlog("getAlbumUri mp3: "+stateData.currentTrack.absoluteAlbumArtUri+" == "+stateData.currentTrack.uri,3);
                              if (stateData.currentTrack.albumArtUri !== undefined) result=getaaurl+stateData.currentTrack.albumArtUri;
                              else {
                                  result=getaaurl+'getaa?u='+encodeURIComponent(stateData.currentTrack.uri);
                          dwmlog ("getAlbumUri returning: "+result,3);
                          return result;
                      function getNiceElement(stateElement,htmlElement){
                          let result = "";
                          if (stateElement !== undefined && stateElement !== null && stateElement != "" && !stateElement.includes('x-sonos')){
                              if (htmlElement !== "")
                                  result = "<"+htmlElement+">"+stateElement+"</"+htmlElement+"><br/>";
                              else
                                  result = stateElement+'</br>';
                          return result;
                      function getURIType (stateData) {
                          var result = stateData.currentTrack.type;
                          return result;
                      function getNiceHTMLInfo(stateData) {
                          let result = "";
                          result += getNiceElement(stateData.currentTrack.title,'b');
                          if ( stateData.currentTrack.type == 'radio' ){
                              if (stateData.currentTrack.title != stateData.currentTrack.artist && stateData.currentTrack.artist != stateData.currentTrack.stationName)
                                  result += getNiceElement(stateData.currentTrack.artist,'i');
                              if (stateData.currentTrack.album !== undefined )
                                  result += getNiceElement(stateData.currentTrack.album,'');
                              if (stateData.currentTrack.title != stateData.currentTrack.stationName)
                                  result += getNiceElement(stateData.currentTrack.stationName,'');
                          } else {
                              if (stateData.currentTrack.title != stateData.currentTrack.artist && stateData.currentTrack.artist != stateData.currentTrack.album)
                              if (stateData.currentTrack.title != stateData.currentTrack.album)
                          return result;
                       * TV mode workaround:
                      function isTVMode( uri ){
                          dwmlog ("isTVMode called with uri: "+uri,5);
                          if (typeof(uri)!=="string") return false;
                          let result = uri.startsWith('x-sonos-htastream:') && uri.endsWith ('spdif');
                          return result;
                      function setTVModeBuffer(ZoneName, TVModeUri, sourceAction ){
                          let data = { uri: TVModeUri, sourceAction: sourceAction };
                          pauseTVBuffer[ZoneName] = data;
                          dwmlog ("setTVModeBuffer for "+ZoneName+" pauseTVBuffer is: "+JSON.stringify(pauseTVBuffer),5);
                      function checkTVModeDatapoint(ZoneName,stateData){
                          dwmlog("Checking TV mode for "+ZoneName+" and uri "+stateData.currentTrack.uri,5);
                              dwmlog ("TV mode detected",5);
                              if ( getState(basePath+"."+ZoneName+".action.setTVMode").notExist ){
                                  createState(basePath+"."+ZoneName+".action.setTVMode",true,forceCreate,{ type: "boolean", name: "setTVMode action for "+ZoneName, role: "button"});
                                  dwmlog("Created TVMode datapoint for "+ZoneName);
                      function calcTVModeUri (ZoneName){
                          return "x-sonos-htastream:"+getState(basePath+"."+ZoneName+".uuid").val+":spdif";
                      function processState(ZoneName,stateData){
                          dwmlog ("Sonos processState for Zone "+ZoneName+" with data: "+JSON.stringify(stateData),5);
                          setStateProtected(basePath+"."+ZoneName+".state.volume",stateData.volume,true);
                          setStateProtected(basePath+"."+ZoneName+".state.mute",stateData.mute,true);
                          setStateProtected(basePath+"."+ZoneName+".state.playbackState",stateData.playbackState,true);
                          setStateProtected(basePath+"."+ZoneName+".state.playbackStateSimple",stateData.playbackState=="PLAYING",true);
                          // current track Information
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.artist",stateData.currentTrack.artist,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.title",stateData.currentTrack.title,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.album",stateData.currentTrack.album,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.duration",stateData.currentTrack.duration,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.uri",stateData.currentTrack.uri,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.trackUri",stateData.currentTrack.trackUri,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.type",stateData.currentTrack.type,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.stationName",stateData.currentTrack.stationName,true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.albumArtUri",getAlbumUri( stateData, false),true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.absoluteAlbumArtUri",getAlbumUri(stateData, true),true);
                          setStateProtected(basePath+"."+ZoneName+".state.currentTrack.niceInfoHTML",getNiceHTMLInfo(stateData),true);
                          setState(basePath+"."+ZoneName+".state.trackNo",stateData.trackNo,true);
                          setState(basePath+"."+ZoneName+".state.elapsedTime",stateData.elapsedTime,true);
                          setState(basePath+"."+ZoneName+".state.elapsedTimeFormatted",stateData.elapsedTimeFormatted,true);
                          setState(basePath+"."+ZoneName+".state.playMode.repeat",stateData.playMode.repeat,true);
                          setState(basePath+"."+ZoneName+".state.playMode.shuffle",stateData.playMode.shuffle,true);
                          setState(basePath+"."+ZoneName+".state.playMode.crossfade",stateData.playMode.crossfade,true);
                          checkTVModeDatapoint(ZoneName, stateData );
                          dwmlog ("processState ends",5);
                      function initSingleZone(zoneData,coordinator,members,forceCreate){
                          if (forceCreate === undefined) forceCreate=false;
                          // forceCreate=true;
                          dwmlog ("SingleZoneInit: "+JSON.stringify(zoneData),5);
                          var ZoneName = zoneData.roomName;
                          var group = zoneData.roomName;
                          if (coordinator.roomName == zoneData.roomName ){
                              group = coordinator.roomName ;
                              if (members.length>0) group += ' / '+members.join(' / ');
                          } else {
                              group += " => "+coordinator.roomName;
                          createOrSetState(basePath+"."+ZoneName+".name",zoneData.roomName,forceCreate,{ type: "string", name: "Sonos Roomname for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".uuid",zoneData.uuid,forceCreate,{ type: "string", name: "Sonos UUID for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".coordinator",coordinator.roomName,forceCreate,{ type: "string", name: "Sonos Group Coordinator for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".group",group,forceCreate,{ type: "string", name: "Sonos group for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.volume",zoneData.state.volume,forceCreate,{ type: "number", name: "Sonos Volume for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.mute",zoneData.state.mute,forceCreate,{ type: "boolean", name: "Sonos Mute State for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.playbackState",zoneData.state.playbackState,forceCreate,{ type: "string", name: "Sonos Play State for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.playbackStateSimple",zoneData.state.playbackState=="PLAYING",forceCreate,{ type: "boolean", name: "Sonos Simple Play State for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.groupVolume",zoneData.groupState.volume,forceCreate,{ type: "number", name: "Sonos group volume for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.artist",zoneData.state.currentTrack.artist,forceCreate,{ type: "string", name: "Sonos current track artist for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.title",zoneData.state.currentTrack.title,forceCreate,{ type: "string", name: "Sonos current track title for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.album",zoneData.state.currentTrack.album,forceCreate,{ type: "string", name: "Sonos current track album for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.duration",zoneData.state.currentTrack.duration,forceCreate,{ type: "number", name: "Sonos current track duration for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.uri",zoneData.state.currentTrack.uri,forceCreate,{ type: "string", name: "Sonos current uri for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.trackUri",zoneData.state.currentTrack.trackUri,forceCreate,{ type: "string", name: "Sonos current track uri for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.type",zoneData.state.currentTrack.type,forceCreate,{ type: "string", name: "Sonos current play type for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.stationName",zoneData.state.currentTrack.stationName,forceCreate,{ type: "string", name: "Sonos current station name for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.albumArtUri",getAlbumUri( zoneData.state, false),forceCreate,{ type: "string", name: "Sonos album art for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.absoluteAlbumArtUri",getAlbumUri( zoneData.state, true),forceCreate,{ type: "string", name: "Sonos absolute album art URI for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.currentTrack.niceInfoHTML",getNiceHTMLInfo( zoneData.state ),forceCreate,{ type: "string", name: "Sonos absolute album art URI for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.trackNo",zoneData.state.trackNo,forceCreate,{ type: "number", name: "Sonos track number for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.elapsedTime",zoneData.state.elapsedTime,forceCreate,{ type: "number", name: "Sonos track elapsed time for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.elapsedTimeFormatted",zoneData.state.elapsedTimeFormatted,forceCreate,{ type: "string", name: "Sonos track elapsed time formatted for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.playMode.repeat",zoneData.state.playMode.repeat,forceCreate,{ type: "string", name: "Sonos repeat playmode for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.playMode.shuffle",zoneData.state.playMode.shuffle,forceCreate,{ type: "boolean", name: "Sonos shuffle playmode for "+zoneData.roomName});
                          createOrSetState(basePath+"."+ZoneName+".state.playMode.crossfade",zoneData.state.playMode.crossfade,forceCreate,{ type: "boolean", name: "Sonos crossfade playmode for "+zoneData.roomName});
                          // create Actions
                          createState(basePath+"."+ZoneName+".action.play",true,forceCreate,{ type: "boolean", name: "Play action for "+zoneData.roomName, role: "button"});
                          createState(basePath+"."+ZoneName+".action.playpause",true,forceCreate,{ type: "boolean", name: "Toggle play action for "+zoneData.roomName, role: "button"});
                          createState(basePath+"."+ZoneName+".action.pause",true,forceCreate,{ type: "boolean", name: "Pause action for "+zoneData.roomName, role: "button"});
                          createState(basePath+"."+ZoneName+".action.next",true,forceCreate,{ type: "boolean", name: "Pause action for "+zoneData.roomName, role: "button"});
                          createState(basePath+"."+ZoneName+".action.previous",true,forceCreate,{ type: "boolean", name: "Pause action for "+zoneData.roomName, role: "button"});
                          // sayit Actions
                          createState(basePath+"."+ZoneName+".action.say","",forceCreate,{ type: "string", name: "Say action for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".action.clip","",forceCreate,{ type: "string", name: "Clip action for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".settings.clipVolume",30,forceCreate,{ type: "number", name: "Clip and say volume for "+zoneData.roomName});
                          // favorite action
                          createState(basePath+"."+ZoneName+".action.favorite","",forceCreate,{ type: "string", name: "Set favorite action for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".action.playlist","",forceCreate,{ type: "string", name: "Set playlist action for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".settings.defaultFavorite","",forceCreate,{ type: "string", name: "Default favorite for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".settings.lastFavorite","",forceCreate,{ type: "string", name: "Last favorite selected for "+zoneData.roomName});
                          createState(basePath+"."+ZoneName+".settings.lastPlaylist","",forceCreate,{ type: "string", name: "Last playlist selected for "+zoneData.roomName});
                          // sayit Extended functionality
                          createState(basePath+"."+ZoneName+".action.sayEx",{},forceCreate,{ type: "string", name: "Say extended action for "+zoneData.roomName});
                          checkTVModeDatapoint(ZoneName, zoneData.state );
                      function initZone(zoneData,forceCreate){
                          var ZoneName = zoneData.coordinator.roomName;
                          var ZoneList = [];
                          initSingleZone(zoneData.coordinator,zoneData.coordinator,forceCreate);
                          let ZoneListObj={ name: zoneData.coordinator.roomName, isCoordinator: true,  members:[] };
                          for (let i = 0; i<zoneData.members.length; i++){
                              if (zoneData.members[i].uuid != zoneData.coordinator.uuid){
                                  dwmlog("Group member for "+ZoneName+" detected: "+zoneData.members[i].roomName,5);
                                  initSingleZone(zoneData.members[i],zoneData.coordinator,forceCreate);
                                  ZoneListObj.members.push(zoneData.members[i].roomName);
                                  ZoneList.push({name: zoneData.members[i].roomName, isCoordinator: false, coordinator: ZoneListObj.name });
                          initSingleZone(zoneData.coordinator,zoneData.coordinator,ZoneListObj.members,forceCreate);
                          ZoneList.push(ZoneListObj);
                          dwmlog("ZoneList init: "+JSON.stringify(ZoneList),5);
                          return ZoneList;
                      function getRoomFromObj(objName){
                          let objPathArr = objName.split(".");
                          let basePathArrLen = stateBasePath.split(".").length+1;
                          // dwmlog("Room is: "+objPathArr[basePathArrLen],4);
                          return objPathArr[basePathArrLen];
                      // get preset from path. Yes, its the same as for the rooms,
                      // nevertheless, lets treat it in a different function.
                      function getPresetFromObj(objName){
                          return objPathArr[objPathArr.length - 2];
                       * canPlay - whats that?
                       * After switching on Power, the current track is simply empty.
                       * If "Play" is pressed in that state, simply nothing happens - as there is nothing to play.
                       * This function should detect such a state, so that the "play" handler can act accordingly.
                      function canPlay(ZoneName){
                          var result = true;
                          let base=basePath+"."+ZoneName+".state.currentTrack.";
                          let currentTrack={};
                          currentTrack.title=getState(base+"title").val;
                          currentTrack.artist=getState(base+"artist").val;
                          currentTrack.duration=getState(base+"duration").val;
                          currentTrack.album=getState(base+"album").val;
                          currentTrack.uri=getState(base+"uri").val;
                          dwmlog ("canPlay: currentTrack state for "+ZoneName+" is: "+JSON.stringify(currentTrack,null,4),5);
                          if ( currentTrack.title == ""
                              && currentTrack.artist == ""
                              && currentTrack.duration == 0
                              && currentTrack.album == ""
                              && currentTrack.uri == "" ) {
                              result = false;
                          if (currentTrack.title.startsWith("polly-"))
                              result=false;
                          return result;
                      function isGroupedWith( ZoneName ){
                          // check if a room is still in the list, if not, set to "inactive"
                          let resultArr = [];
                          let CoordinatorName = getState(basePath+"."+ZoneName+".coordinator").val;
                          dwmlog ("Searching group for "+ZoneName+" having coordinator "+CoordinatorName,4 );
                          $(stateBasePath+".Rooms.*.coordinator").each(function(id,index){
                              let RoomName = getRoomFromObj(id);
                              if (getState(id).val == CoordinatorName) resultArr.push(RoomName);
                          dwmlog("Group for "+ZoneName+" is "+JSON.stringify(resultArr),5);
                          return resultArr;
                      function sayExtended (ZoneName, theObj ) {
                          var now = new Date();
                          var messagebefore = theObj.messagebefore;
                          var messagebehind = theObj.messagebehind;
                          var sayTime = theObj.sayTime;
                          var sayTemp = theObj.sayTemp;
                          var sayDate = theObj.sayDate;
                          var intro   = theObj.introClip;
                          var introlen = theObj.introClipLen;
                          if (messagebefore === undefined && messagebehind===undefined){
                              dwmlog("sayExtended got invalid data",2,"warn");
                              return;
                          let theTemp = Math.round(getState(TempSensorId).val);
                          if (sayTime === undefined) sayTime = true;
                          if (sayTemp === undefined) sayTemp = true;
                          if (sayDate === undefined) sayDate = true;
                          if (intro === undefined) {
                              intro = null;
                              introlen = 0;
                          var messagedelay = introlen;
                          if (introlen>0) introlen+=500;
                          var message = "";
                          if (messagebefore !== undefined && messagebefore !== null) message += messagebefore;
                          if (sayTime) message += " Es ist " + formatDate(now, "h:mm")+" Uhr!";
                          if (sayDate) message += " Heute ist "+formatDate(now, "WW, der DD. OO.");
                          if (sayTemp) message += " Die Außentemperatur beträgt " + theTemp + "°";
                          if (messagebehind !== undefined && messagebehind !== null) {
                              if (SSMLMode=="Polly") message += '<break time="1s"/>'; else message += "; ";
                              message += messagebehind;
                          if (SSMLMode == "Polly")
                              message = '<speak><prosody rate="90%">' + message + '</prosody></speak>';
                          dwmlog (message +" -- Länge: "+message.length,5);
                          if (ZoneName=="all"){
                              if (intro !== null ) {
                                  // setState(stateBasePath+".clipAll",intro);
                              // setStateDelayed(stateBasePath+".sayAll",message,messagedelay);
                              setState(stateBasePath+".sayAll",message);
                          } else {
                                  setState(basePath+'.'+ZoneName+".action.clip",intro);
                              setStateDelayed(basePath+'.'+ZoneName+".action.say",message,messagedelay);
                      function createSubscribes(){
                          // mute
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.mute")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Mute action from "+JSON.stringify(obj),5);
                          // play
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.play")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Play action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              let ZoneName=getRoomFromObj(obj.id);
                              if (! canPlay(ZoneName) ){
                                  if ( pauseTVBuffer[ZoneName] !== undefined ) {
                                      // its a "paused" Sonos, which was in TV Mode before
                                      dwmlog ("TV mode workaround active - setting uri to "+pauseTVBuffer[ZoneName].uri,5);
                                      requestAction( getRoomFromObj(obj.id), "setavtransporturi", encodeURIComponent(pauseTVBuffer[ZoneName].uri), obj.id)
                                      pauseTVBuffer[ZoneName] = undefined; // delete from Buffer afterwards
                                  } else {
                                      let newfav = getState(basePath+"."+ZoneName+".settings.lastFavorite").val;
                                      if (newfav == ""){
                                          newfav = getState(basePath+"."+ZoneName+".settings.defaultFavorite").val;
                                      if (newfav == ""){
                                          let FavList = getState(stateBasePath+".FavList").val;
                                          newfav=FavList.split(';')[0];
                                      setState(basePath+"."+ZoneName+".action.favorite",newfav,false);
                              else requestAction( ZoneName, "play", null, obj.id );
                          // pause
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.pause")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Pause action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              // workaround: SPDIF TV mode cannot be paused, causing crashes in SonosAPI
                              let uri = getState(basePath+"."+ZoneName+".state.currentTrack.uri").val;
                              if (isTVMode(uri)){
                                  requestAction( getRoomFromObj(obj.id), "setavtransporturi", "", obj.id );
                                  setTVModeBuffer ( ZoneName, uri, "pause" );
                              } else {
                                  requestAction( getRoomFromObj(obj.id), "pause", null, obj.id );
                          // play
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.playpause")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Toggle play action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              // TODO: canPlay - muss/soll man das hier ebenfalls einbinden?
                              requestAction( getRoomFromObj(obj.id), "playpause", null, obj.id );
                          // next
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.next")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Next action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              requestAction( getRoomFromObj(obj.id), "next", null, obj.id );
                          // previous
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.previous")), val: true, ack: false, change:"any"}, function (obj) {
                              dwmlog("Previous action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              requestAction( getRoomFromObj(obj.id), "previous", null, obj.id );
                          // volume change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.volume")), ack: false, change:"ne"}, function (obj) {
                              dwmlog("Volume change action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              requestAction(  getRoomFromObj(obj.id), "volume", obj.state.val, obj.id)
                          // groupVolume change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.groupVolume")), ack: false, change:"ne"}, function (obj) {
                              dwmlog("Group volume change action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),3);
                              requestAction(  getRoomFromObj(obj.id), "groupVolume", obj.state.val, obj.id)
                          // mute change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.mute")), ack: false, change:"ne"}, function (obj) {
                              dwmlog("Mute change action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              if (obj.state.val)
                                  requestAction(  getRoomFromObj(obj.id), "mute", null, obj.id);
                              else
                                  requestAction(  getRoomFromObj(obj.id), "unmute", null, obj.id);
                          // repeat
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.playMode.repeat")), ack: false, change:"ne"}, function (obj) {
                              dwmlog("Playmode repeat action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              let valid=['none','one','all'];
                              if (valid.includes(obj.state.val)){
                                  requestAction(  getRoomFromObj(obj.id), "repeat", obj.state.val, obj.id);
                              } else {
                                  // revert changes if not valid
                                  setStateProtected(basePath+".*.state.playMode.repeat",obj.oldState.val, true);
                          // shuffle change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.playMode.shuffle")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Playmode shuffle action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              if (obj.state.val){
                                  requestAction(  getRoomFromObj(obj.id), "shuffle", "on", obj.id)
                              } else {
                                  requestAction(  getRoomFromObj(obj.id), "shuffle", "off", obj.id)
                          // crossfade change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.playMode.crossfade")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Playmode crossfade action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              if (obj.state.val){
                                  requestAction(  getRoomFromObj(obj.id), "crossfade", "on", obj.id)
                              } else {
                                  requestAction(  getRoomFromObj(obj.id), "crossfade", "off", obj.id)
                          // URI change
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.currentTrack.uri")), ack: false, change:"any"}, function (obj) {
                              dwmlog("URI set action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id),5);
                              requestAction(  getRoomFromObj(obj.id), "setavtransporturi", encodeURIComponent(obj.state.val), obj.id)
                          // say
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.say")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Say action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id)+" saying: "+encodeURIComponent(obj.state.val),5);
                              let vol = getState(basePath+"."+ZoneName+".settings.clipVolume").val;
                              requestAction(  getRoomFromObj(obj.id), "say", encodeURIComponent(obj.state.val)+'/'+vol, obj.id)
                          // clip
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.clip")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Clip action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id)+" playing: "+encodeURIComponent(obj.state.val),5);
                              requestAction(  getRoomFromObj(obj.id), "clip", encodeURIComponent(obj.state.val)+'/'+vol, obj.id)
                          // favorite
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.favorite")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Favorite action from "+JSON.stringify(obj)+" in Room "+ZoneName+" playing: "+encodeURIComponent(obj.state.val),5);
                              if (obj.state.val === "TVMode") {
                                  requestAction(  ZoneName, "setavtransporturi", encodeURIComponent(calcTVModeUri(ZoneName) ), obj.id)
                              } else if (obj.state.val !== "") {
                                  requestAction(  ZoneName, "favorite", encodeURIComponent(obj.state.val), obj.id)
                                  setState(basePath+"."+ZoneName+".settings.lastFavorite",obj.state.val,true);
                              if (resetFavoriteTime > 0)
                                  setStateDelayed(basePath+"."+ZoneName+".action.favorite","",true,resetFavoriteTime*1000);
                          // playlist
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.playlist")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Playlist action from "+JSON.stringify(obj)+" in Room "+ZoneName+" playing: "+encodeURIComponent(obj.state.val),5);
                                  requestAction(  ZoneName, "playlist", encodeURIComponent(obj.state.val), obj.id)
                                  setState(basePath+"."+ZoneName+".settings.lastPlaylist",obj.state.val,true);
                              setStateDelayed(basePath+"."+ZoneName+".action.playlist","",true,5000);
                          // trackseek
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.trackNo")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Trackseek action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id)+" jumping to: "+obj.state.val,5);
                              requestAction(  getRoomFromObj(obj.id), "trackseek", encodeURIComponent(obj.state.val), obj.id)
                          // simple playbackstate
                          on({id: Array.prototype.slice.apply($(basePath+".*.state.playbackStateSimple")), ack: false, change:"any"}, function (obj) {
                              dwmlog("Simple playback state action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id)+" setting to: "+obj.state.val,5);
                              if (obj.state.val){
                                  requestAction( getRoomFromObj(obj.id), "play", null, obj.id );
                              } else {
                          // sayEx
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.sayEx")), ack: false, change:"any"}, function (obj) {
                              dwmlog("SayEx action from "+JSON.stringify(obj)+" in Room "+getRoomFromObj(obj.id)+" saying: "+obj.state.val,5);
                              sayExtended(getRoomFromObj(obj.id), JSON.parse(obj.state.val));
                          // pauseAll
                          on({id: stateBasePath+".pauseAll", val: true, change: "any"}, function(obj){
                              dwmlog ("PauseAll Action ",5);
                              let TVModesDetected = false;
                              $(basePath+'.*.state.currentTrack.uri').each( function (id,i){
                                  dwmlog("PauseAll checks URI: "+JSON.stringify(id),5);
                                  let uri=getState(id).val;
                                  if (isTVMode(uri)){
                                      let ZoneName = getRoomFromObj(id);
                                      requestAction( ZoneName, "setavtransporturi", "", id );
                                      setTVModeBuffer ( ZoneName, uri, "pauseall" );
                                      TVModesDetected = true;
                              if (TVModesDetected)
                                  setTimeout( requestSonosAPI,200,'/pauseall'); // call after short timeout
                              else
                                  requestSonosAPI('/pauseall');
                          // resumeAll
                          on({id: stateBasePath+".resumeAll", val: true, change: "any"}, function(obj){
                              dwmlog ("resumeAll Action ",5);
                              requestSonosAPI('/resumeall');
                              $(basePath+'.*.name').each(function (id,i){
                                  let ZoneName = getState(id).val;
                                  if (pauseTVBuffer[ZoneName] !== undefined && pauseTVBuffer[ZoneName].sourceAction === "pauseall"){
                                      requestAction( ZoneName,  'setavtransporturi', pauseTVBuffer[ZoneName].uri);
                          // clipAll
                          on({id: stateBasePath+".clipAll", ack: false, change: "any"}, function(obj){
                              dwmlog("Clip ALL action, playing: "+encodeURIComponent(obj.state.val),3);
                              let vol=getState(stateBasePath+".genericSettings.clipAllVolume").val;
                              requestSonosAPI("/clipall/"+encodeURIComponent(obj.state.val)+'/'+vol);
                          // sayAll
                          on({id: stateBasePath+".sayAll", ack: false, change: "any"}, function(obj){
                              dwmlog("Say ALL action, playing: "+encodeURIComponent(obj.state.val),3);
                              requestSonosAPI("/sayall/"+encodeURIComponent(obj.state.val)+'/'+vol);
                          // sayAllEx
                          on({id: stateBasePath+".sayAllEx", ack: false, change: "any"}, function(obj){
                              dwmlog("SayAllEx action, playing: "+obj.state.val,3);
                              sayExtended("all", JSON.parse(obj.state.val));
                          // TV mode
                          on({id: Array.prototype.slice.apply($(basePath+".*.action.setTVMode")), val: true, change:"any"}, function (obj) {
                              dwmlog("TV mode action from "+JSON.stringify(obj)+" in Room "+ZoneName,5);
                         // coordinator, grouping
                          on({id: Array.prototype.slice.apply($(basePath+".*.coordinator")), ack:false, change:"ne"}, function (obj) {
                              dwmlog("Coordinator set from "+JSON.stringify(obj)+" in Room "+ZoneName,5);
                              let coordinators = getState(stateBasePath+".CoordinatorList").val.split(";");
                              if (obj.state.val !== ""){
                                  if (coordinators.includes(obj.state.val) && obj.state.val!=ZoneName){
                                      dwmlog("Grouping: "+ZoneName+" joins "+obj.state.val,5);
                                      requestAction( ZoneName, "join", [obj.state.val], obj.id );
                                  } else {
                                      if (obj.state.val==ZoneName){
                                          requestAction( ZoneName, "leave", null, obj.id );
                                      } else {
                                          // TODO: reset DP when input was illegal
                              } else {
                      function processZones( AllZoneData, cbParam ) {
                          let forceCreate = false;
                          dwmlog ("Zone Data: "+JSON.stringify(AllZoneData,null,4),5);
                          let ZoneListArr=[];
                          let ZoneListSimple=[];
                          let CoordListSimple=[];
                          for (let i=0; i<AllZoneData.length; i++){
                              let ZoneResult = initZone(AllZoneData[i])
                              ZoneListArr = ZoneListArr.concat(ZoneResult);
                          for (let i=0; i<ZoneListArr.length; i++){
                              ZoneListSimple.push(ZoneListArr[i].name);
                              if (ZoneListArr[i].isCoordinator) CoordListSimple.push(ZoneListArr[i].name);
                          dwmlog ("ZoneListArr: "+JSON.stringify(ZoneListArr),5);
                          $(stateBasePath+".Rooms.*.name").each(function(id,index){
                              let RoomName=getState(id).val;
                              let ZoneName=RoomName;
                              if (ZoneListSimple.includes(RoomName)){
                                  dwmlog ("Room "+RoomName+" is active",5);
                                  createState(basePath+"."+ZoneName+".active",true,forceCreate,{ type: "boolean", name: "Set active state for "+RoomName});
                              } else {
                                  dwmlog ("Room "+RoomName+" is NOT active",5);
                                  createState(basePath+"."+ZoneName+".active",false,forceCreate,{ type: "boolean", name: "Set active state for "+RoomName});
                          dwmlog ("Zone List String: "+ZoneListSimple.join(';'),5);
                          createOrSetState(stateBasePath+".RoomList",ZoneListSimple.join(';'),forceCreate,{ type: "string", name: "Sonos zone list"});
                          createOrSetState(stateBasePath+".CoordinatorList",CoordListSimple.join(';'),forceCreate,{ type: "string", name: "Sonos coordinator list"});
                          createState(stateBasePath+".pauseAll",true,forceCreate,{ type: "boolean", name: "Pause all players", role: "button"});
                          createState(stateBasePath+".resumeAll",true,forceCreate,{ type: "boolean", name: "Resume all players", role: "button"});
                          createState(stateBasePath+".sayAll","",forceCreate,{ type: "string", name: "say on all players"});
                          createState(stateBasePath+".clipAll","",forceCreate,{ type: "string", name: "clip on all players"});
                          createState(stateBasePath+".sayAllEx","",forceCreate,{ type: "string", name: "say on all players, extended"});
                          createState(stateBasePath+".genericSettings.clipAllVolume",40,forceCreate,{ type: "number", name: "SonosAPI clipAll Volume"});
                      function processVolumeChange ( VolumeData ){
                          dwmlog ("Process Volume Data: "+JSON.stringify(VolumeData,null,4),5);
                          var ZoneName = VolumeData.roomName;
                          setStateProtected(basePath+"."+ZoneName+".state.volume",VolumeData.newVolume,true);
                          if (isGroupedWith(ZoneName).length>1){
                              dwmlog (ZoneName+" is grouped, requesting update of zones to get new group Volume",5);
                              if (VolumeTimeout != null) clearTimeout(VolumeTimeout);
                              VolumeTimeout = setTimeout(requestSonosZones,200);
                          } else {
                              // shortcut, reduce net traffic!
                              setStateProtected(basePath+"."+ZoneName+".state.groupVolume",VolumeData.newVolume,true);
                      function processFavorites(FavData, cbParam ){
                          let forceCreate=false;
                          if (Array.isArray(FavData)){
                              var FavListStr = FavData.join(';');
                              // dwmlog ("Process Favorites Data: "+JSON.stringify(FavData,null,4)+" gives List "+FavListStr,5);
                              createOrSetState(stateBasePath+".FavList",FavListStr,forceCreate,{ type: 'string', name: "Sonos Favorites list"});
                          } else {
                              dwmlog("SonosAPI processFavorites got invalid data: "+JSON.stringify(FavData),2,"warn");
                      function processPlaylists(PlaylistData, cbParam ){
                          if (Array.isArray(PlaylistData)){
                              var PlayListStr = PlaylistData.join(';');
                              createOrSetState(stateBasePath+".Playlists",PlayListStr,forceCreate,{ type: 'string', name: "Sonos Playlist list"});
                          } else {
                              dwmlog("SonosAPI processPlaylists got invalid data: "+JSON.stringify(PlaylistData),2,"warn");
                      function createPresetSubscribe(presetName){
                          dwmlog ("creating subscribes for preset "+presetName,5);
                          on({id: stateBasePath+".Presets."+presetName+".set", val: true, change:"any"},function(obj){
                              let presetName=getPresetFromObj(obj.id)
                              dwmlog("Preset set action for preset "+presetName,3);
                              requestSonosAPI('/preset/'+presetName);
                          on({id: stateBasePath+".Presets."+presetName+".say", ack: false, change:"any"},function(obj){
                              dwmlog("Preset say action for preset "+presetName,3);
                              requestSonosAPI('/saypreset/'+presetName+'/'+obj.state.val);
                          on({id: stateBasePath+".Presets."+presetName+".clip", ack: false, change:"any"},function(obj){
                              dwmlog("Preset clip action for preset "+presetName,3);
                              requestSonosAPI('/clippreset/'+presetName+'/'+obj.state.val);
                      function createAllPresetSubscribes(){
                          $(stateBasePath+'.Presets.*.set').each(function(obj,i){
                              let preset=getPresetFromObj(obj);
                              createPresetSubscribe(preset);
                      function deleteStateIfExists(id) {
                          existsState(id,(err,isExists) => {
                              if (isExists) {
                                  unsubscribe(id);
                                  setTimeout(deleteState,50,id);
                              } else {
                                  dwmlog('Trying to delete non-existing state '+id,2,"warn");
                      function processPresets(PresetListData, cbParam ){
                          var PresetListStr = PresetListData.join(';');
                          createOrSetState(stateBasePath+".Presets.presetList",PresetListStr,forceCreate,{ type: 'string', name: "Sonos API presets list"});
                          let processedPresets=[];
                              // dwmlog("processPresets - already in System: "+JSON.stringify(obj),5);
                              let preset = getPresetFromObj(obj);
                              if (PresetListData.includes(preset)){
                                  dwmlog("Preset "+preset+" is in presets structure",4);
                              } else {
                                  dwmlog("Preset "+preset+" not in presets any more, deleting subscribes and object",2);
                                  deleteStateIfExists(stateBasePath+".Presets."+preset+".set");
                                  deleteStateIfExists(stateBasePath+".Presets."+preset+".say");
                                  deleteStateIfExists(stateBasePath+".Presets."+preset+".clip");
                                  setTimeout(deleteStateIfExists,100,stateBasePath+".Presets."+preset);
                              processedPresets.push(preset);
                          var newPresets = PresetListData.filter(function(x) {
                              // checking second array does not contain element "x"
                              if(processedPresets.indexOf(x) == -1)
                                  return true;
                              else
                                  return false;
                          if (newPresets.length>0){
                              dwmlog("New presets are: "+JSON.stringify(newPresets),3);
                              newPresets.forEach(function(element,i){
                                  createState(stateBasePath+".Presets."+element+".set",true,forceCreate,{ type: "boolean", name: "setting preset "+element, role: "button"});
                                  createState(stateBasePath+".Presets."+element+".say",'',forceCreate,{ type: "string", name: "say for preset "+element });
                                  createState(stateBasePath+".Presets."+element+".clip",'',forceCreate,{ type: "string", name: "clip for preset "+element });
                      function processMuteChange( MuteData ){
                          dwmlog ("Process Mute Data: "+JSON.stringify(MuteData,null,4),5);
                          var ZoneName = MuteData.roomName;
                          setStateProtected(basePath+"."+ZoneName+".state.mute",MuteData.newMute,true);
                      function requestSonosZones(){
                          if (VolumeTimeout !== null){
                          requestSonosAPI("/zones",processZones);
                      function requestAction(room,action,parameters,triggerId ){
                          let theURI = '/'+room+'/'+action;
                          if ( parameters !== undefined && parameters !== null ){
                              if (typeof(parameters)==='array'){
                                  for (let i=0; i<parameters.length; i++){
                                      theURI+='/'+parameters[i];
                              } else {
                                  theURI+='/'+parameters;
                          requestSonosAPI(theURI);
                      // TODO!!
                      function requestQueue(room){
                          let theURI = '/'+room+'/queue';
                          requestSonosAPI(theURI,processQueue);
                      function requestFavorites(){
                          requestSonosAPI('/favorites',processFavorites);
                      function requestPlaylists(){
                          requestSonosAPI('/playlists',processPlaylists);
                      function requestPresets(){
                          requestSonosAPI('/preset',processPresets);
                      function collectRequestData(request, callback) {
                          const FORM_JSONENCODED = 'application/json';
                          dwmlog ("Request headers:"+JSON.stringify(request.headers),5);
                          if(request.headers['content-type'] === FORM_JSONENCODED) {
                              let body = '';
                              request.on('data', chunk => {
                                  body += chunk.toString();
                              request.on('end', () => {
                                  // dwmlog ("collectRequestData got: "+body,5);
                                  var theObj = null;
                                  try {
                                      theObj=JSON.parse(body);
                                  catch (theErr) { dwmlog ("JSON error: "+body+" => "+theErr.message,1,"error"); }
                                  callback(theObj);
                          else {
                              callback(null);
                      var server = http.createServer(function(req,res){
                          var url_parts = url.parse(req.url, true);
                          dwmlog(JSON.stringify(url_parts),5);
                          var pathsplit = url_parts.pathname.split("/");
                          dwmlog (JSON.stringify(pathsplit),5);
                          switch (req.method) {
                              case 'POST':
                                  dwmlog ("Received Post",3);
                                  collectRequestData(req, result => {
                                      dwmlog("Result: "+JSON.stringify(result),3);
                                      let code = 200;
                                      let answer = { result: "success" };
                                      try {
                                          if (result.type) {
                                              switch (result.type){
                                                  case "transport-state":
                                                      processState(result.data.roomName,result.data.state);
                                                      break;
                                                  case "topology-change":
                                                      processZones(result.data);
                                                      break;
                                                  case "volume-change":
                                                      processVolumeChange(result.data);
                                                      break;
                                                  case "mute-change":
                                                      processMuteChange(result.data);
                                                      break;
                                                  default:
                                                      code=400;
                                                      answer={ result: "error", message: "Unknown request type: "+result.type };
                                      } catch (theErr) {
                                          dwmlog("Error: "+theErr.message + " from body: "+result,1,"error");
                                          code=500;
                                          answer={ result: "error", message: theErr.message };
                                      res.writeHead(code, {
                                          'Content-type': 'application/json' });
                                      res.end(JSON.stringify(answer));
                                  break;
                              case 'GET':
                                  let code = 404;
                                  let answer = { result: "error", message: "Unknown request"};
                                  if (pathsplit[0]=="" && pathsplit[1]=="info") {
                                      code = 200;
                                      let answer = { code: 200, data: { version: version }};
                                      answer.data.sonosAPI=BaseURL;
                                      answer.data.SSMLMode=SSMLMode;
                                  break;
                              default:
                          } // switch (Method)
                      // close connection if script stopped
                      onStop(function (callback) {
                          server.close();
                      }, 100 /*ms*/);
                      server.listen(webHookPort);
                      requestSonosZones();
                      schedule('* * * * *',requestFavorites);
                      schedule('13 * * * * *',requestPlaylists);
                      schedule('17 * * * * *',requestPresets);
                      setTimeout(createSubscribes,200);
                      setTimeout(createAllPresetSubscribes,300);
                      dwm66 created this issue in jishi/node-sonos-http-api
                      open Calling pauseall on soundbar with TV input causes Error 500 #741
                      • matze55
                        matze55 last edited by
                        Funktioniert dieser Code noch? Und muss ich die Datenpunkte selber anlegen?
                        on({id: '0_userdata.0.Sonos.state', change: "ne"}, function (obj) {
                          var value = obj.state.val;
                          if (getState("0_userdata.0.Sonos.state").val == true)
                              var tablet;
                              var kueche;
                              var wohnl;
                              var wohnr;
                                var test;
                            try {
                                  require("request")('http://192.168.178.56:5005/tablet/state/', function (error, response, result)
                        			  tablet =  JSON.parse(result);
                        			  setState("0_userdata.0.Sonos.lautstaerke_tablet", tablet.volume);
                                      setState("0_userdata.0.Sonos.stationName", tablet.currentTrack.stationName);
                                      setState("0_userdata.0.Sonos.artist", tablet.currentTrack.artist);
                                      setState("0_userdata.0.Sonos.title", tablet.currentTrack.title);
                              }).on("error", function (e) {console.error(e);});
                            } catch (e) { console.error(e); }
                           try {
                                  require("request")('http://192.168.178.56:5005/kueche/state/', function (error, response, result)
                        			  kueche =  JSON.parse(result);
                        			                setState("0_userdata.0.Sonos.lautstaerke_kueche", kueche.volume);
                             try {
                                  require("request")('http://192.168.178.56:5005/wohnl/state/', function (error, response, result)
                        			  wohnl =  JSON.parse(result);
                        			                setState("0_userdata.0.Sonos.lautstaerke_wohnl", wohnl.volume);
                             try {
                                  require("request")('http://192.168.178.56:5005/wohnr/state/', function (error, response, result)
                        			  wohnr =  JSON.parse(result);
                        			                setState("0_userdata.0.Sonos.lautstaerke_wohnr", wohnr.volume);
                             setState("0_userdata.0.Sonos.state", false);
                        sonos
                        50
                        438
                        99520
