    4. [SourceAnalytix 0.4.8-Final] Released !
      bishop9191 @crunchip last edited by
      @crunchip in den Objekten, bei den Datenpunkten das Menü von SourceAnalytix, dass ich Datenpunkte für SourceAnalytix definieren kann
      B crunchip 2 Replies Last reply Reply Quote 0
        Beowolf @bishop9191 last edited by
        @bishop9191
        Welche anderen "Dinge" sind denn auswählbar?
          bishop9191 @Beowolf last edited by
          @beowolf telegram und sql
            crunchip Forum Testing Most Active @bishop9191 last edited by
            @bishop9191 mach mal ein
            iob upload all
            Per konsole
              @crunchip hat nichts bewirkt 😐
                @bishop9191 dann mal
                iob diag
                  @crunchip was ist hier interessant? die komplette diag oder ein bestimmter bereich?
                    @bishop9191 die vollständige Ausgabe
                      @crunchip
                      Script v.2025-03-08
                      *** BASE SYSTEM ***
                      Failed to query system properties: Failed to activate service 'org.freedesktop.hostname1': timed out (service_start_timeout=25000ms)
                      OS is similar to:
                      model name      : Intel(R) Core(TM) i5-6400T CPU @ 2.20GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                      22:13:35 up 277 days, 23:42,  2 users,  load average: 0.09, 0.33, 0.71
                      CPU threads: 2
                      *** LIFE CYCLE STATUS ***
                      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                      *** TIME AND TIMEZONES ***
                      Failed to query server: Connection timed out
                      Failed to parse bus message: Connection timed out
                      *** Users and Groups ***
                      User that called 'iob diag':
                      steven
                      HOME=/home/steven
                      GROUPS=steven sudo iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server: false
                      Desktop:
                      Terminal:
                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                      *** MEMORY ***
                      Mem:            4.1G        2.7G        745M        0.0K        635M        1.4G
                      Swap:           512M         98M        413M
                      Total:          4.6G        2.8G        1.2G
                      Active iob-Instances:   32
                              4096 M total memory
                              2714 M used memory
                               575 M active memory
                              2524 M inactive memory
                               745 M free memory
                                 0 M buffer memory
                               635 M swap cache
                               512 M total swap
                                98 M used swap
                               413 M free swap
                      top - 22:14:50 up 277 days, 23:43,  2 users,  load average: 0.07, 0.26, 0.65
                      Tasks:  58 total,   1 running,  57 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   4096.0 total,    745.4 free,   2714.7 used,    635.9 buff/cache
                      MiB Swap:    512.0 total,    413.1 free,     98.9 used.   1381.3 avail Mem
                      *** FAILED SERVICES ***
                       UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
                      * logrotate.service         loaded failed failed Rotate log files
                      * nftables.service          loaded failed failed nftables
                      * systemd-hostnamed.service loaded failed failed Hostname Service
                      * systemd-logind.service    loaded failed failed User Login Management
                      * systemd-networkd.service  loaded failed failed Network Service
                      * systemd-resolved.service  loaded failed failed Network Name Resolution
                      * systemd-timedated.service loaded failed failed Time & Date Service
                      * systemd-networkd.socket   loaded failed failed Network Service Netlink Socket
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      8 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                       Type   Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--100--disk--0 ext4    16G  6.3G  8.6G  43% /
                      none                             tmpfs  492K  4.0K  488K   1% /dev
                      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
                      tmpfs                            tmpfs  3.2G   60K  3.2G   1% /run
                      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
                      [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Feb 16 01:02:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Feb 16 01:04:49 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Feb 23 01:02:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Feb 23 01:04:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sat Mar  1 00:02:37 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sat Mar  1 00:04:59 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar  2 01:02:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar  2 01:04:55 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Fri Mar  7 22:26:08 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:26:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:37:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:37:38 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:41:18 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Fri Mar  7 22:51:11 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:52:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Fri Mar  7 22:57:57 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Fri Mar  7 23:26:43 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 08:31:33 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 08:51:59 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 08:52:22 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 09:04:21 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 09:04:35 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sat Mar  8 09:06:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sat Mar  8 16:40:34 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 17:26:44 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Sat Mar  8 22:08:41 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sat Mar  8 22:09:13 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                      [Sun Mar  9 01:02:43 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                      [Sun Mar  9 01:05:17 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                      [Sun Mar 16 01:02:51 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): write access unavailable, skipping orphan cleanup
                      [Sun Mar 16 01:05:24 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Mon Mar 17 21:05:59 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Wed Mar 19 21:48:16 2025] EXT4-fs (dm-13): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Wed Mar 19 22:11:29 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:11:45 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:35:50 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:36:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:39:16 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:39:36 2025] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                      [Wed Mar 19 22:48:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Wed Mar 19 22:48:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar 23 01:03:00 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar 23 01:05:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Thu Mar 27 12:21:06 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar 30 01:03:08 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Mar 30 01:05:18 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Tue Apr  1 00:03:09 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Tue Apr  1 00:05:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr  6 01:03:14 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr  6 01:05:21 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 13 01:03:25 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 13 01:05:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 20 01:03:31 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 20 01:06:04 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 27 01:03:41 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Apr 27 01:06:16 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Tue Apr 29 22:17:50 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Thu May  1 00:03:43 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Thu May  1 00:06:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May  4 01:03:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May  4 01:06:34 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 11 01:03:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 11 01:06:36 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 18 01:04:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 18 01:06:39 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 25 01:04:13 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun May 25 01:06:35 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  1 00:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  1 00:06:51 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  1 01:04:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  1 01:06:24 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  8 01:04:29 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun  8 01:06:33 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 15 01:04:32 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 15 01:06:42 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 22 01:04:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 22 01:06:47 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 29 01:04:48 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jun 29 01:08:40 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Tue Jul  1 00:04:52 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Tue Jul  1 00:07:17 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jul  6 01:04:56 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jul  6 01:07:54 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jul 13 01:05:05 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                      [Sun Jul 13 01:07:27 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                      Show mounted filesystems:
                      TARGET SOURCE                           FSTYPE OPTIONS
                      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      1.5G    /var/
                      876M    /var/log
                      793M    /var/log/journal/1fced0e2937f4858ba466b3b64b52574
                      471M    /var/cache
                      Archived and active journals take up 56.0M in the file system.
                      /opt/iobroker/backups:
                      6.3M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      382M    /opt/iobroker/iobroker-data/
                      250M    /opt/iobroker/iobroker-data/files
                      98M     /opt/iobroker/iobroker-data/backup-objects
                      48M     /opt/iobroker/iobroker-data/files/iot.admin
                      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      24M     /opt/iobroker/iobroker-data/objects.jsonl
                      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                      12M     /opt/iobroker/iobroker-data/states.jsonl
                      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      Zigbee Network Settings on your coordinator/in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      To unmask the settings run 'iob diag --unmask'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.19.0
                      /usr/bin/node           v20.19.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.31.0
                      nodejs:
                       Installed: 20.19.0-1nodesource1
                       Candidate: 20.19.4-1nodesource1
                       Version table:
                          20.19.4-1nodesource1 600
                             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                          20.19.3-1nodesource1 600
                          20.19.2-1nodesource1 600
                          20.19.1-1nodesource1 600
                      *** 20.19.0-1nodesource1 600
                             100 /var/lib/dpkg/status
                          20.18.3-1nodesource1 600
                          20.18.2-1nodesource1 600
                          20.18.1-1nodesource1 600
                          20.18.0-1nodesource1 600
                          20.17.0-1nodesource1 600
                          20.16.0-1nodesource1 600
                          20.15.1-1nodesource1 600
                          20.15.0-1nodesource1 600
                          20.14.0-1nodesource1 600
                          20.13.1-1nodesource1 600
                          20.13.0-1nodesource1 600
                          20.12.2-1nodesource1 600
                          20.12.1-1nodesource1 600
                          20.12.0-1nodesource1 600
                          20.11.1-1nodesource1 600
                          20.11.0-1nodesource1 600
                          20.10.0-1nodesource1 600
                          20.9.0-1nodesource1 600
                          20.8.1-1nodesource1 600
                          20.8.0-1nodesource1 600
                          20.7.0-1nodesource1 600
                          20.6.1-1nodesource1 600
                          20.6.0-1nodesource1 600
                          20.5.1-1nodesource1 600
                          20.5.0-1nodesource1 600
                          20.4.0-1nodesource1 600
                          20.3.1-1nodesource1 600
                          20.3.0-1nodesource1 600
                          20.2.0-1nodesource1 600
                          20.1.0-1nodesource1 600
                          20.0.0-1nodesource1 600
                          12.22.12~dfsg-1~deb11u7 500
                             500 http://security.debian.org bullseye-security/main amd64 Packages
                          12.22.12~dfsg-1~deb11u4 500
                             500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 9880798)
                      Core adapters versions
                      js-controller:  7.0.6
                      admin:          7.6.17
                      javascript:     8.9.2
                      nodejs modules from github:     1
                      +-- iobroker.mercedesme@0.3.8 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#426508912896a6de0257cee3c07f2a3d3b624aa4)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                       system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
                       system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                      + system.adapter.easee.0                  : easee                 : ioBroker                                 -  enabled
                      + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
                      + system.adapter.evcc.0                   : evcc                  : ioBroker                                 -  enabled, port: 7070
                      + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
                       system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                       system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                      + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
                      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                       system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 - disabled
                      + system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 -  enabled
                      + system.adapter.plenticore.0             : plenticore            : ioBroker                                 -  enabled, port: 80
                      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                      + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                      + system.adapter.sql.0                    : sql                   : ioBroker                                 -  enabled, port: 3306
                      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                       system.adapter.twinkly.0                : twinkly               : ioBroker                                 - disabled
                       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                       system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                       system.adapter.vis-map.0                : vis-map               : ioBroker                                 -  enabled
                       system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                       system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                      + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 192.168.178.31, run as: admin
                       system.adapter.yeelight-2.0             : yeelight-2            : ioBroker                                 - disabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.6.17   , installed 7.6.17
                      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                      Adapter    "easee"        : 1.0.10   , installed 1.0.10
                      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
                      Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
                      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "hue"          : 3.16.1   , installed 3.16.1
                      Adapter    "ical"         : 1.16.2   , installed 1.16.2
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "sql"          : 3.0.1    , installed 3.0.1
                      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                      Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "yeelight-2"   : 1.5.2    , installed 1.5.2
                      Objects and States
                      Objects:        22035
                      States:         19307
                      Hit:1 http://security.debian.org bullseye-security InRelease
                      Hit:2 http://ftp.debian.org/debian bullseye InRelease
                      Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 90
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       453697404  294150/iobroker.js-
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       453697409  294150/iobroker.js-
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          28547      322/master
                      tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       780288979  421774/io.hm-rpc.0
                      tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       453701383  294365/io.hm-rpc.1
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          26664      1/init
                      tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       453703328  294613/io.ws.0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       879481053  458892/io.shelly.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          28548      322/master
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       684842571  387474/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       890512494  463082/io.web.0
                      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       453701218  294324/go2rtc
                      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       453701217  294324/go2rtc
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          26843      1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          28137      1/init
                      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       453701224  294324/go2rtc
                      tcp6       0      0 :::20002                :::*                    LISTEN      1001       890511518  463089/io.web.1
                      udp        0      0 0.0.0.0:56913           0.0.0.0:*                           1001       892075443  463100/io.eusec.0
                      udp        0      0 0.0.0.0:40582           0.0.0.0:*                           1001       890511570  463100/io.eusec.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28134      1/init
                      udp        0      0 0.0.0.0:57613           0.0.0.0:*                           1001       892937403  463100/io.eusec.0
                      udp        0      0 0.0.0.0:59550           0.0.0.0:*                           1001       890511565  463100/io.eusec.0
                      udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       850668389  447064/io.tr-064.0
                      udp        0      0 0.0.0.0:46664           0.0.0.0:*                           1001       890511583  463100/io.eusec.0
                      udp        0      0 0.0.0.0:47128           0.0.0.0:*                           1001       892393915  463100/io.eusec.0
                      udp        0      0 0.0.0.0:55852           0.0.0.0:*                           1001       892263694  463100/io.eusec.0
                      udp6       0      0 :::111                  :::*                                0          28140      1/init
                      udp6       0      0 :::8555                 :::*                                1001       453701219  294324/go2rtc
                      2025-07-19 21:53:49.286  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 78
                      2025-07-19 21:54:05.635  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
                      2025-07-19 21:56:14.090  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      2025-07-19 22:00:00.006  - info: javascript.0 (393714) script.js.common.Skripte_Pool.Pool_Pumpensteuerung: Zeit
                      2025-07-19 22:00:38.022  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 469153
                      2025-07-19 22:00:38.903  - info: daswetter.0 (469153) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
                      2025-07-19 22:00:43.308  - info: daswetter.0 (469153) still wrong data structure from server received! repaired...
                      2025-07-19 22:00:44.303  - info: daswetter.0 (469153) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                      2025-07-19 22:00:44.809  - info: daswetter.0 (469153) cleaned everything up...
                      2025-07-19 22:00:44.820  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 469153 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-07-19 22:01:14.091  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      2025-07-19 22:05:18.275  - info: web.1 (463089) ==> Connected system.user.admin from ::ffff:192.168.178.35
                      2025-07-19 22:06:14.092  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      2025-07-19 22:09:06.799  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplusplugs-80646fd66974" connected from 192.168.178.62!
                      2025-07-19 22:09:10.246  - info: shelly.0 (458892) [MQTT] Device with client id "shellyplus1-7c87ce63d79c" connected from 192.168.178.65!
                      2025-07-19 22:09:11.315  - error: sql.0 (294236) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES (55, 1752955751310, 10.69, 1, 3, 0);: Error: Duplicate entry '55-1752955751310' for key 'PRIMARY' (id: ProxMox_Verbrauch)
                      2025-07-19 22:09:56.093  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P312224379C. Connection seems lost. Try to reconnect...
                      2025-07-19 22:09:56.094  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P312224379C
                      2025-07-19 22:09:57.368  - warn: eusec.0 (463100) [p2p] [P2PClientProtocol.sendPing] Heartbeat check failed for station T8400P2020490E69. Connection seems lost. Try to reconnect...
                      2025-07-19 22:09:57.368  - info: eusec.0 (463100) [http] [Station.onDisconnect] Disconnected from station T8400P2020490E69
                      2025-07-19 22:10:01.211  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P312224379C on host 192.168.178.121 and port 14681
                      2025-07-19 22:10:01.678  - info: eusec.0 (463100) [http] [Station.onConnect] Connected to station T8400P2020490E69 on host 192.168.178.101 and port 11225
                      2025-07-19 22:10:21.319  - info: mercedesme.0 (466526) No Data since 180 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 79
                      2025-07-19 22:11:14.093  - info: fhem.0 (294529) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                      2025-07-19 22:13:50.630  - info: web.1 (463089) <== Disconnect system.user.admin from ::ffff:192.168.178.35 vis.0
                      Ro75 1 Reply Last reply Reply Quote 0
                      • Ro75
                        Ro75 @bishop9191 last edited by
                        @bishop9191 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                        das sieht gar nicht gesund aus.
                        Ro75.
                          Thomas Braun Most Active @Ro75 last edited by Thomas Braun
                          @ro75 sagte in [SourceAnalytix 0.4.8-Final] Released !:
                          Aber nicht nur an der Stelle. Der Patient hat auch noch andere Baustellen.
                          Ich würde da gleich was aktuelles sauber neuausrollen.
                            bishop9191 @Thomas Braun last edited by bishop9191
                            ========== Start marking the full check here ===========
                            Script v.2025-03-08
                            *** BASE SYSTEM ***
                             Static hostname: ioBroker
                                   Icon name: computer-container
                                     Chassis: container ☐
                              Virtualization: lxc
                                      Kernel: Linux 5.15.158-2-pve
                                Architecture: x86-64
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             18:02:25 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                            CPU threads: 2
                            Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                           Local time: Wed 2025-07-23 18:02:26 CEST
                                       Universal time: Wed 2025-07-23 16:02:26 UTC
                                             RTC time: n/a
                                          NTP service: inactive
                                      RTC in local TZ: no
                            steven
                            HOME=/home/steven
                            GROUPS=steven sudo users iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.3G        2.4G        1.3G        131K        658M        1.9G
                            Swap:           536M          0B        536M
                            Total:          4.8G        2.4G        1.8G
                            Active iob-Instances:   31
                                     4096 M total memory
                                     2241 M used memory
                                      337 M active memory
                                     2384 M inactive memory
                                     1226 M free memory
                                        0 M buffer memory
                                      627 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            top - 18:02:26 up 18:30,  3 users,  load average: 0.54, 0.52, 0.82
                            Tasks:  61 total,   1 running,  60 sleeping,   0 stopped,   0 zombie
                            MiB Mem :   4096.0 total,   1224.9 free,   2243.2 used,    627.9 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1852.8 avail Mem
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--104--disk--1 ext4    16G  3.5G   12G  24% /
                            tmpfs                            tmpfs  3.2G  124K  3.2G   1% /run
                            tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
                            [Sat Jul 19 23:57:00 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 00:06:41 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 00:10:52 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 00:11:59 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 01:05:11 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 01:08:00 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Sun Jul 20 21:28:03 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 21:55:29 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 22:52:02 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 23:01:04 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 23:01:36 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 23:30:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 23:30:52 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                            [Sun Jul 20 23:49:35 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Mon Jul 21 23:05:30 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Mon Jul 21 23:09:32 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Mon Jul 21 23:12:32 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Tue Jul 22 21:32:51 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Tue Jul 22 22:23:09 2025] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Tue Jul 22 22:32:42 2025] EXT4-fs (dm-14): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            [Tue Jul 22 23:36:43 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Tue Jul 22 23:37:30 2025] EXT4-fs (dm-14): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                            [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): write access unavailable, skipping orphan cleanup
                            [Tue Jul 22 23:48:30 2025] EXT4-fs (dm-12): mounted filesystem without journal. Opts: noload. Quota mode: none.
                            /      /dev/mapper/pve-vm--104--disk--1 ext4   rw,relatime,stripe=16
                            /var:
                            407M    /var/
                            219M    /var/cache
                            215M    /var/cache/apt
                            147M    /var/lib
                            139M    /var/cache/apt/archives
                            Archived and active journals take up 16.0M in the file system.
                            6.9M    /opt/iobroker/backups/
                            327M    /opt/iobroker/iobroker-data/
                            247M    /opt/iobroker/iobroker-data/files
                            25M     /opt/iobroker/iobroker-data/objects.jsonl
                            21M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/nodejs         v20.19.4
                            /usr/bin/node           v20.19.4
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.32.0
                            nodejs:
                              Installed: 20.19.4-1nodesource1
                              Version table:
                             *** 20.19.4-1nodesource1 600
                                 18.19.0+dfsg-6~deb12u2 500
                                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                 18.19.0+dfsg-6~deb12u1 500
                                    500 http://security.debian.org bookworm-security/main amd64 Packages
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 66604)
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                              system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                            + instance is alive
                            Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                            Adapter    "ws"           : 2.6.2    , installed 3.0.19
                            Objects and States
                            Objects:        21330
                            States:         18700
                            Hit:1 http://security.debian.org bookworm-security InRelease
                            Hit:2 http://deb.debian.org/debian bookworm InRelease
                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                            Pending Updates: 0
                            tcp        0      0 192.168.178.31:2001     0.0.0.0:*               LISTEN      1001       914893137  737/io.hm-rpc.1
                            tcp        0      0 192.168.178.31:2010     0.0.0.0:*               LISTEN      1001       917882617  3279/io.hm-rpc.0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          914886797  1/init
                            tcp        0      0 192.168.178.31:8084     0.0.0.0:*               LISTEN      1001       914897248  1202/io.ws.0
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       914891678  837/io.shelly.0
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          914887169  291/master
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       914887805  125/iobroker.js-con
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       914887312  125/iobroker.js-con
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          914887170  291/master
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       914887662  419/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       914903136  1235/io.web.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          914886803  1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          914884445  1/init
                            tcp6       0      0 :::8554                 :::*                    LISTEN      1001       914903160  1262/go2rtc
                            tcp6       0      0 :::8555                 :::*                    LISTEN      1001       914903163  1262/go2rtc
                            tcp6       0      0 :::1984                 :::*                    LISTEN      1001       914903168  1262/go2rtc
                            tcp6       0      0 :::20002                :::*                    LISTEN      1001       914903133  1228/io.web.1
                            udp        0      0 0.0.0.0:56374           0.0.0.0:*                           1001       914900410  1217/io.eusec.0
                            udp        0      0 0.0.0.0:56523           0.0.0.0:*                           1001       916315494  1217/io.eusec.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          914886800  1/init
                            udp        0      0 0.0.0.0:60675           0.0.0.0:*                           1001       914900419  1217/io.eusec.0
                            udp        0      0 0.0.0.0:36146           0.0.0.0:*                           1001       914903173  1217/io.eusec.0
                            udp        0      0 192.168.178.31:5353     0.0.0.0:*                           1001       914894872  863/io.tr-064.0
                            udp6       0      0 :::111                  :::*                                0          914886806  1/init
                            udp6       0      0 :::8555                 :::*                                1001       914903164  1262/go2rtc
                            2025-07-23 18:00:21.772  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE_STATUS to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE_STATUS"
                            2025-07-23 18:00:21.775  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_DEVICE to "Gartenhaus_Temperatur_0.RSSI_DEVICE"
                            2025-07-23 18:00:21.777  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.OPERATING_VOLTAGE to "Gartenhaus_Temperatur_0.OPERATING_VOLTAGE"
                            2025-07-23 18:00:21.780  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.TEMPERATURE_OUT_OF_RANGE to "Gartenhaus_Temperatur_0.TEMPERATURE_OUT_OF_RANGE"
                            2025-07-23 18:00:21.782  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.RSSI_PEER to "Gartenhaus_Temperatur_0.RSSI_PEER"
                            2025-07-23 18:00:21.784  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.ERROR_CODE to "Gartenhaus_Temperatur_0.ERROR_CODE"
                            2025-07-23 18:00:21.786  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.0.UPDATE_PENDING to "Gartenhaus_Temperatur_0.UPDATE_PENDING"
                            2025-07-23 18:00:21.788  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1 to "Gartenhaus_Temperatur_1"
                            2025-07-23 18:00:21.791  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY to "Gartenhaus_Temperatur_1.HUMIDITY"
                            2025-07-23 18:00:21.793  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.HUMIDITY_STATUS to "Gartenhaus_Temperatur_1.HUMIDITY_STATUS"
                            2025-07-23 18:00:21.802  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE"
                            2025-07-23 18:00:21.805  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.1.ACTUAL_TEMPERATURE_STATUS to "Gartenhaus_Temperatur_1.ACTUAL_TEMPERATURE_STATUS"
                            2025-07-23 18:00:21.807  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.2 to "Gartenhaus_Temperatur_2"
                            2025-07-23 18:00:21.809  - info: hm-rega.0 (692) renamed hm-rpc.0.000EDA498FD2EE.3 to "Gartenhaus_Temperatur_3"
                            2025-07-23 18:00:51.014  - info: host.ioBroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 3294
                            2025-07-23 18:00:51.919  - info: daswetter.0 (3294) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.4, js-controller: 7.0.6
                            2025-07-23 18:00:55.829  - info: daswetter.0 (3294) still wrong data structure from server received! repaired...
                            2025-07-23 18:00:56.765  - info: daswetter.0 (3294) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                            2025-07-23 18:00:57.271  - info: daswetter.0 (3294) cleaned everything up...
                            2025-07-23 18:00:57.280  - info: host.ioBroker instance system.adapter.daswetter.0 having pid 3294 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2025-07-23 18:01:09.763  - info: sql.0 (500) enabled logging of Gartenhaus_Temperatur, Alias=true, WriteNulls=true
                            2025-07-23 18:01:10.365  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Temperatur
                            2025-07-23 18:01:28.788  - info: sql.0 (500) enabled logging of Gartenhaus_Luftfeuchtigkeit, Alias=true, WriteNulls=true
                            2025-07-23 18:01:28.851  - info: sql.0 (500) changed history configuration to pin detected datatype for Gartenhaus_Luftfeuchtigkeit
                            2025-07-23 18:01:51.265  - info: admin.0 (419) <== Disconnect system.user.admin from ::ffff:192.168.178.13 admin
                            Habe neu aufgesetzt auf Debian 12 und über Backitup die ioBroker Konfig zurückgespielt.
                            Die Fehlermeldungen:
                            sind laut meinen Recherchen "normal", während eines Backupvorgangs in Proxmox. Zumindest habe ich das so im Proxmox Forum gefunden...
                            Das Problem mit SourceAnalytix besteht leider weiterhin 😧
                            • MassiveAttack
                              MassiveAttack last edited by MassiveAttack
                              Kann mir bitte jemand helfen, diesen Fehler wegzubekommen? Der kommt mittlerweile ~ alle 30 Sekunden und spammt mir das Log voll:
                              sourceanalytix.0
                              	2025-07-24 11:23:34.128	error	Input value for javascript.0.Wetterstation.Regen_Jahr, type = string but should be a number, cannot handle calculation
                              Der Type ist aber mixed bzw. auch number. Nur der Zustand hat Typ string. Wie kann ich das ändern?
                              6d6515d5-456f-4e9b-93e8-4a4d7fdb2a91-1753349201961-a48c6706-3dc6-4b79-b029-8765e864bca6-da22c1b4-e01c-4be4-9dae-6eee45755a3a.png
                                michihorn @MassiveAttack last edited by michihorn
                                @massiveattack Ich habe das so gemacht:
                                Ich habe einen Datenpunkt "mqtt.1.logger.GTHRN.Solar.Umwandlung" als Zahl angelegt und diesen dann per Script gefüttert. (Okay, hätte ich besser in userdata gemacht, aber egal)
                                Das Zauberwort heißt "parseFloat", siehe Script. ParseFlot wandet Text in Zahl.
                                Ich habe dann diesen Datenpunkt in SourceAnaytix ausgewertet anstatt des "Orginalen"
                                /*****Solar ErtragNL in Zahl umwandeln*************************
                                * Juli 2025
                                * Adapter:
                                * geä:23.07.25
                                const id_ertrag="mqtt.1.logger.GTHRN.Solar.totalEnergie"
                                const id_umwandlung ="mqtt.1.logger.GTHRN.Solar.Umwandlung"
                                //const id_umwandlung ="0_userdata.0.Giethoorn.Energie.Zählerstände.Umwandlung"
                                on({ id: id_ertrag, change: "any" }, async function (obj) {
                                var zahl = parseFloat(getState(id_ertrag).val)
                                log(zahl)
                                setState(id_umwandlung,zahl)
                                Michael
                                MassiveAttack 1 Reply Last reply Reply Quote 0
                                • MassiveAttack
                                  MassiveAttack @michihorn last edited by
                                  @michihorn sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                  * Juli 2025
                                  * Adapter:
                                  * geä:23.07.25
                                  log(zahl)
                                  Michael
                                  Danke, werde ich mal bei Gelegenheit testen.
                                  Aber was ist das eigentliche Problem? Kann der Typ nicht mehr geändert werden?
                                  2302
                                  1157306
