    4. Mal wieder zerschossen
    • Chaot
      Chaot @wendy2702 last edited by
      @wendy2702
      haus@ioBroker:~$ iob diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
        iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
        iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub, if a package name is provided instead of an url, it will be installed from npm
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo                                                Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      haus@ioBroker:~$
      • wendy2702
        wendy2702 @Chaot last edited by
        @chaot
        curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
          Homoran Global Moderator Administrators @Chaot last edited by
          @chaot sagte in Mal wieder zerschossen:
          warum der ioBroker mal wieder zerschossen ist.
          der ioBroker zerschießt nich einfach so!
          Ein Bug von ioBroker ist das auch nicht.
          in einem Proxmox Container. Allerdings lässt er sich von Zeit zu Zeit manchmal nicht starten oder stoppen.
          Wenn der Container sich nicht stoppen lässt, hat das nichts mit ioBroker zu tun.
          der Fixer funktionieret auch nicht.
          Was soll der Fixer deiner Meinung nach den tun?
          Hattest du Rechte verbogen?
          • Chaot
            @wendy2702
            Ach so:
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-03-08
            *** BASE SYSTEM ***
               Static hostname: ioBroker
                     Icon name: computer-container
                       Chassis: container
                Virtualization: lxc
              Operating System: Ubuntu 20.04.6 LTS
                        Kernel: Linux 6.5.13-5-pve
                  Architecture: x86-64
            OS is similar to: debian
            model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             14:31:19 up 21 min,  1 user,  load average: 2.76, 2.58, 3.74
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Ubuntu Release codenamed 'focal' reached its END OF LIFE and needs to be updated to the latest LTS release 'noble' NOW!
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-07-21 14:31:19 CEST
                       Universal time: Mon 2025-07-21 12:31:19 UTC
                             RTC time: n/a
                          NTP service: n/a
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            haus
            HOME=/home/haus
            GROUPS=haus iobroker
            iobroker
            [sudo] password for haus:
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev redis
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           6.1G        3.1G        2.1G        1.0M        971M        3.1G
            Swap:          2.0G          0B        2.0G
            Total:         8.2G        3.1G        4.1G
            Active iob-Instances:   35
                     6144 M total memory
                     3076 M used memory
                     3188 M active memory
                      708 M inactive memory
                     2096 M free memory
                        0 M buffer memory
                      971 M swap cache
                     2048 M total swap
                        0 M used swap
                     2048 M free swap
            top - 14:31:25 up 21 min,  1 user,  load average: 3.16, 2.68, 3.76
            Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 28.8 us,  9.1 sy,  0.0 ni, 59.1 id,  0.0 wa,  0.0 hi,  3.0 si,  0.0 st
            MiB Mem :   6144.0 total,   2096.1 free,   3076.6 used,    971.3 buff/cache
            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   3065.8 avail Mem
            *** FAILED SERVICES ***
              UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * apparmor.service loaded failed failed Load AppArmor profiles
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                       Type   Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--110--disk--0 ext4    32G   25G  5.5G  82% /
            none                             tmpfs  492K  4.0K  488K   1% /dev
            tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
            tmpfs                            tmpfs  1.6G  1.6M  1.6G   1% /run
            tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
            tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
            [Mon Jul 21 14:02:20 2025] EXT4-fs (dm-1): mounted filesystem 15679eb9-5ea6-43b8-b91c-29a0ecca7019 ro with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:02:21 2025] EXT4-fs (dm-1): re-mounted 15679eb9-5ea6-43b8-b91c-29a0ecca7019 r/w. Quota mode: none.
            [Mon Jul 21 14:02:22 2025] EXT4-fs (sdb): mounting ext3 file system using the ext4 subsystem
            [Mon Jul 21 14:02:22 2025] EXT4-fs (sdb): mounted filesystem 72a49e33-105a-4582-a31c-1bbff15e30ec r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:02:47 2025] EXT4-fs (loop0): mounted filesystem f7913bd0-bee5-42e9-83c6-edb24bba20bc r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:02:54 2025] EXT4-fs (dm-12): mounted filesystem 32a22a38-9374-43d2-a490-0d49504c12c9 r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:03:10 2025] EXT4-fs (dm-10): mounted filesystem 1c6095f9-366b-4331-a231-4ac8e949c392 r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:03:17 2025] EXT4-fs (dm-6): mounted filesystem be54090e-144d-414f-a0ac-f457653d388a r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:03:46 2025] EXT4-fs (loop1): warning: mounting fs with errors, running e2fsck is recommended
            [Mon Jul 21 14:03:46 2025] EXT4-fs (loop1): mounted filesystem 110cdcbd-660a-4f4d-99bb-0dd7d2fffa88 r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:03:59 2025] EXT4-fs (dm-15): mounted filesystem 32e87d66-9df5-4bc2-99c5-f006705424bb r/w with ordered data mode. Quota mode: none.
            [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): error count since last fsck: 2
            [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): initial error at time 1666345607: ext4_check_bdev_write_error:217
            [Mon Jul 21 14:08:51 2025] EXT4-fs (loop1): last error at time 1666426664: ext4_journal_check_start:83
            [Mon Jul 21 14:09:38 2025] EXT4-fs (dm-12): unmounting filesystem 32a22a38-9374-43d2-a490-0d49504c12c9.
            [Mon Jul 21 14:09:41 2025] EXT4-fs (dm-12): mounted filesystem 32a22a38-9374-43d2-a490-0d49504c12c9 r/w with ordered data mode. Quota mode: none.
            Show mounted filesystems:
            TARGET                    SOURCE                           FSTYPE     OPTIONS
            /                         /dev/mapper/pve-vm--110--disk--0 ext4       rw,relatime,stripe=16
            |-/proc/cpuinfo           lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/diskstats         lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/loadavg           lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/meminfo           lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/slabinfo          lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/stat              lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/swaps             lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            |-/proc/uptime            lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            `-/sys/devices/system/cpu lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            /var:
            3.8G    /var/
            3.2G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
            3.2G    /var/log
            431M    /var/lib
            Archived and active journals take up 752.0M in the file system.
            /opt/iobroker/backups:
            267M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            2.2G    /opt/iobroker/iobroker-data/
            1018M   /opt/iobroker/iobroker-data/history
            888M    /opt/iobroker/iobroker-data/files
            299M    /opt/iobroker/iobroker-data/files/vis
            291M    /opt/iobroker/iobroker-data/files/vis/widgets
            43M     /opt/iobroker/iobroker-data/objects.jsonl
            33M     /opt/iobroker/iobroker-data/files/vis/widgets/vis-2-widgets-jaeger-design/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.0424abce.chunk.js.map
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            21M     /opt/iobroker/iobroker-data/objects.json.migrated
            21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.3
            /usr/bin/node           v20.19.3
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.32.0
            nodejs:
              Installed: 20.19.3-1nodesource1
              Candidate: 20.19.3-1nodesource1
              Version table:
             *** 20.19.3-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.19.2-1nodesource1 1001
                 20.19.1-1nodesource1 1001
                 20.19.0-1nodesource1 1001
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 10.19.0~dfsg-3ubuntu1.6 500
                    500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                    500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
                 10.19.0~dfsg-3ubuntu1 500
                    500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
            Temp directories causing deletion problem: 4
            Some problems detected, please run iob fix
            Errors in npm tree: 0
            No problems detected
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: redis
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 1313)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.7.1
            javascript:     9.0.7
            nodejs modules from github:     3
            +-- iobroker.icons-open-icon-library-png@0.1.3 invalid: "https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master" from the root project
            | `-- kodi-ws@2.4.4 invalid: "git+https://git@github.com/iobroker-community-adapters/kodi-ws.git" from node_modules/iobroker.kodi
            | +-- samsungtv@0.0.0 invalid: "https://git@github.com/luca-saggese/samsungtv" from node_modules/iobroker.samsung
            Adapter State
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 80, bind: 0.0.0.0, run as: admin
              system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : ioBroker                                 - disabled
              system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
              system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
            + system.adapter.bosch-ebike.0            : bosch-ebike           : ioBroker                                 -  enabled
              system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
              system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
              system.adapter.countdown.0              : countdown             : ioBroker                                 - disabled
              system.adapter.daswetter.0              : daswetter             : ioBroker                                 - disabled
              system.adapter.devices.0                : devices               : ioBroker                                 - disabled
              system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
            + system.adapter.drag-indicator.0         : drag-indicator        : ioBroker                                 -  enabled
              system.adapter.drops-weather.0          : drops-weather         : ioBroker                                 - disabled
              system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
              system.adapter.email.0                  : email                 : ioBroker                                 - disabled
            + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
            + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
            + system.adapter.heatingcontrol.0         : heatingcontrol        : ioBroker                                 -  enabled
            + system.adapter.history.0                : history               : ioBroker                                 -  enabled
            + system.adapter.hoover.0                 : hoover                : ioBroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
              system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
              system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
              system.adapter.ical.8                   : ical                  : ioBroker                                 -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
            + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
              system.adapter.kodi.0                   : kodi                  : ioBroker                                 - disabled, port: 9090
              system.adapter.linux-control.0          : linux-control         : ioBroker                                 - disabled
              system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
              system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
              system.adapter.mpd.0                    : mpd                   : ioBroker                                 - disabled, port: 6600
              system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 - disabled, port: 1500, bind: 0.0.0.0
            + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
            + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
            + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
              system.adapter.odl.0                    : odl                   : ioBroker                                 -  enabled
              system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
              system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
              system.adapter.phantomjs.0              : phantomjs             : ioBroker                                 - disabled
            + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
              system.adapter.proxy.0                  : proxy                 : ioBroker                                 - disabled
            + system.adapter.remeha-home.0            : remeha-home           : ioBroker                                 -  enabled
            + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
              system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
              system.adapter.rssfeed.0                : rssfeed               : ioBroker                                 - disabled
              system.adapter.scenes.0                 : scenes                : ioBroker                                 - disabled
              system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
            + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
              system.adapter.socketio.0               : socketio              : ioBroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1500, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
            + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.time-switch.0            : time-switch           : ioBroker                                 - disabled
            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
            + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
              system.adapter.upnp.0                   : upnp                  : ioBroker                                 - disabled
              system.adapter.uv-protect.0             : uv-protect            : ioBroker                                 - disabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 - disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 - disabled
              system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker                                 - disabled
              system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
              system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 - disabled
              system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
              system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
              system.adapter.wallpanel.0              : wallpanel             : ioBroker                                 - disabled
              system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
            + system.adapter.wiegand-tcpip.0          : wiegand-tcpip         : ioBroker                                 -  enabled, port: 60000, bind: 0.0.0.0
            + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
            + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            │ 2       │ 'live-default'     │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
            │ 3       │ 'live-latest'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
            Active repo(s): live-latest
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: live-latest
            Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.lgtv/io-package.json: /opt/iobroker/node_modules/iobroker.lgtv/io-package.json: Expected double-quoted property name in JSON at position 10582
            Adapter    "admin"        : 7.7.1    , installed 7.7.1
            Adapter    "alexa-timer-vis": 2.1.1  , installed 2.1.1
            Adapter    "alexa2"       : 3.27.3   , installed 3.26.7 [Updatable]
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.4  [Updatable]
            Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
            Adapter    "bosch-ebike"  : 0.1.12   , installed 0.1.12
            Adapter    "cameras"      : 2.1.2    , installed 2.1.2
            Adapter    "countdown"    : 3.0.0    , installed 3.0.0
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "devices"      : 1.2.7    , installed 1.2.7
            Adapter    "drag-indicator": 2.4.0   , installed 2.4.0
            Adapter    "drops-weather": 1.2.7    , installed 1.2.6  [Updatable]
            Adapter    "email"        : 2.0.4    , installed 2.0.4
            Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
            Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
            Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
            Adapter    "hoover"       : 0.1.4    , installed 0.1.4
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "javascript"   : 9.0.8    , installed 9.0.7  [Updatable]
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "kodi"         : 3.1.0    , installed 3.1.0
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "logparser"    : 2.4.0    , installed 2.4.0
            Adapter    "matter"       : 0.5.1    , installed 0.5.1
            Adapter    "mpd"          : 2.2.0    , installed 2.2.0
            Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
            Adapter    "mytime"       : 1.4.4    , installed 1.4.4
            Adapter    "nina"         : 0.0.26   , installed 0.0.26
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "odl"          : 5.0.0    , installed 5.0.0
            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
            Adapter    "parcel"       : 0.2.10   , installed 0.2.10
            Adapter    "phantomjs"    : 1.1.3    , installed 1.1.3
            Adapter    "ping"         : 1.7.9    , installed 1.7.9
            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
            Adapter    "proxy"        : 1.3.2    , installed 1.3.2
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "remeha-home"  : 1.0.7    , installed 1.0.7
            Adapter    "reolink"      : 1.2.3    , installed 1.2.2  [Updatable]
            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
            Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
            Adapter    "samsung"      : 0.6.1    , installed 0.6.1
            Adapter    "scenes"       : 4.0.3    , installed 4.0.2  [Updatable]
            Adapter    "schoolfree"   : 1.1.10   , installed 1.1.10
            Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
            Adapter    "socketio"     : 7.0.8    , installed 7.0.8
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "statistics"   : 4.0.0    , installed 4.0.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 4.0.1    , installed 4.0.0  [Updatable]
            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
            Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "upnp"         : 1.1.0    , installed 1.1.0
            Adapter    "uv-protect"   : 0.6.7    , installed 0.6.7
            Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
            Adapter    "vis-2"        : 2.12.12  , installed 2.12.10 [Updatable]
            Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
            Adapter    "vis-2-widgets-gauges": 2.0.1, installed 1.1.1 [Updatable]
            Adapter    "vis-2-widgets-jaeger-design": 1.4.7, installed 1.4.4 [Updatable]
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-2-widgets-sweethome3d": 0.2.0, installed 0.2.0
            Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
            Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "web"          : 7.0.9    , installed 7.0.9
            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
            Adapter    "wiegand-tcpip": 0.4.7    , installed 0.4.7
            Adapter    "wled"         : 0.7.3    , installed 0.7.3
            Adapter    "ws"           : 3.0.19   , installed 3.0.19
            Objects and States
            Objects:        32962
            States:         32247
            Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists... Done
            Pending Updates: 15
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      109        90878      186/redis-server 0.
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        91333      96/systemd-resolved
            tcp        0      0 0.0.0.0:1500            0.0.0.0:*               LISTEN      1000       97850      631/io.sonoff.0
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       93573      199/iobroker.js-con
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          89805      382/master
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          91691      271/smbd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          91048      196/sshd: /usr/sbin
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          88523      1/init
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          91692      271/smbd
            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       128122     1386/io.ws.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       124270     1116/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       94564      399/io.admin.0
            tcp6       0      0 ::1:6379                :::*                    LISTEN      109        90879      186/redis-server 0.
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          89806      382/master
            tcp6       0      0 :::445                  :::*                    LISTEN      0          91689      271/smbd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          89733      196/sshd: /usr/sbin
            tcp6       0      0 :::111                  :::*                    LISTEN      0          88527      1/init
            tcp6       0      0 :::139                  :::*                    LISTEN      0          91690      271/smbd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       119509     1278/io.wled.0
            udp        0      0 192.168.8.50:5353       0.0.0.0:*                           1000       98964      620/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        89714      155/avahi-daemon: r
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       124196     915/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       124197     915/io.tuya.0
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        91332      96/systemd-resolved
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          88524      1/init
            udp        0      0 192.168.8.50:123        0.0.0.0:*                           0          92363      191/ntpd
            udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          92361      191/ntpd
            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          92357      191/ntpd
            udp        0      0 192.168.8.255:137       0.0.0.0:*                           0          92408      160/nmbd
            udp        0      0 192.168.8.50:137        0.0.0.0:*                           0          92407      160/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          92395      160/nmbd
            udp        0      0 192.168.8.255:138       0.0.0.0:*                           0          92410      160/nmbd
            udp        0      0 192.168.8.50:138        0.0.0.0:*                           0          92409      160/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          92396      160/nmbd
            udp        0      0 0.0.0.0:42134           0.0.0.0:*                           108        89716      155/avahi-daemon: r
            udp        0      0 0.0.0.0:60001           0.0.0.0:*                           1000       113256     901/io.wiegand-tcpi
            udp6       0      0 :::5353                 :::*                                108        89715      155/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          88530      1/init
            udp6       0      0 fe80::88d5:5eff:fea:123 :::*                                0          92367      191/ntpd
            udp6       0      0 ::1:123                 :::*                                0          92365      191/ntpd
            udp6       0      0 :::123                  :::*                                0          92354      191/ntpd
            udp6       0      0 :::41998                :::*                                108        89717      155/avahi-daemon: r
            2025-07-21 14:08:47.945  - error: host.ioBroker Caught by controller[0]:     at StateRedisClient.getState (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:872:26)
            2025-07-21 14:08:47.945  - error: host.ioBroker Caught by controller[0]:     at AdapterClass._getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:9161:33)
            2025-07-21 14:08:47.946  - error: host.ioBroker Caught by controller[0]:     at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/src/lib/common/tools.ts:2336:17
            2025-07-21 14:08:49.635  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2025-07-21 14:08:49.636  - error: host.ioBroker Caught by controller[0]: Error: DB closed
            2025-07-21 14:08:49.636  - error: host.ioBroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            2025-07-21 14:08:49.637  - error: host.ioBroker Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
            2025-07-21 14:08:49.638  - error: host.ioBroker Caught by controller[0]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
            2025-07-21 14:08:49.638  - error: host.ioBroker Caught by controller[0]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
            2025-07-21 14:08:49.639  - error: host.ioBroker Caught by controller[0]:     at processImmediate (node:internal/timers:485:21)
            2025-07-21 14:08:54.753  - error: birthdays.0 (1164) Cannot check object existence of "birthdays.0.month.01": Connection is closed.
            2025-07-21 14:09:31.900  - error: heatingcontrol.0 (1600) exception in CreateDatapoints [Error: DB closed]
            2025-07-21 14:09:31.923  - error: heatingcontrol.0 (1600) exception in SetDefaults [Error: DB closed]
            2025-07-21 14:09:31.928  - error: heatingcontrol.0 (1600) exception in  main [Error: DB closed]
            2025-07-21 14:09:32.784  - error: influxdb.0 (1611) Error on "subscribeForeignStates": DB closed
            2025-07-21 14:12:06.237  - error: hoover.0 (886) Missing step4 url
            2025-07-21 14:12:06.245  - error: hoover.0 (886) "\r\n<!DOCTYPE html PUBLIC \"-//W3C//DTD XHTML 1.0 Transitional//EN\" \"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd\"><html xmlns=\"http://www.w3.org/1999/xhtml\" style=\"visibility: visible;\" lang=de xml:lang=de><head><meta name=\"viewport\" content=\"initial-scale=1.0\"/><title>Ändern Sie Ihr Kennwort. | SmartHome</title><meta name=\"format-detection\" content=\"telephone=no\" /><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/common.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/elements.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/extended.css\" rel=\"stylesheet\" type=\"text/css\"/><link href=\"/sCSS/64.0/sprites/1748341653000/Theme3/de/base/ChatterViralInviteSignup.css\" rel=\"stylesheet\" type=\"text/css\"/><link rel=\"stylesheet\" type=\"text/css\" href=\"/css/sfdc_210.css?v=5\" /><style type=\"text/css\">a{color:#0070d2;}body{background-color:#B1BAC1;}#content,.container{background-color:#ffffff;}#header{color:#51606E;}#header,#footer{color:#000000;}.primary,.primary:hover,.primary:focus{background-color:#1797C0;}.primary{color:#FFFFFF;}.primary{border:#1797C0;}.detailRow .message{width:100%;}.requiredInput{width: auto;}div#content .labelCol,div#content .data2Col{min-height: 30px; padding-top:0px; padding-bottom:15px;vertical-align: top;} body .bEditBlock .pbBottomButtons{border-top: 0px;padding-top:0px;margin-top:0px;} .pbSubheader, .mainTitle{display:none;} div.bDescription, div#content .data2Col {font-size: 95%;} .pageTitle{font-weight: bold;}.detailList, .detailList tr{display:block;width:230px;overflow:hidden;}.labelCol, .data2Col{clear:both;}.detailList td{display:block;}#editPage .pbSubsection{padding:0px;}div#content .labelCol, div#content .data2Col{min-height:10px;padding-bottom:0px;}.detailList tr{padding-top:10px;}.pbTitle{display:none;}p{text-align:initial;text-align:start;}body .btn{color:#fff;}input.primary{width:auto;padding:5px;height:auto;}input{border: 1px solid #cccccc; border-radius: 3px; height: 20px; width: 200px; font-size: 14px;}</style><script type=\"text/javascript\"></script><script src=\"/jslibrary/1743001299256/sfdc/main.js\"></script><script src=\"/jslibrary/jslabels/1752874325000/de.js\"></script><script src=\"/jslibrary/1729010880256/sfdc/ChangePassword.js\"></script><script src=\"/jslibrary/1729717492256/sfdc/Setup.js\"></script><script></script></head><body onload=\"this.bodyOnLoad&&bodyOnLoad();\" onunload=\"this.bodyOnUnload&&bodyOnUnload();\"><div id=\"main\"><div id=\"wrapper\"><div id=\"logo_wrapper\" class=\"standard_logo_wrapper mb24\"><div style=\"height: 100%; display: table-cell; vertical-align: bottom;\"><img aria-hidden=\"true\" id=\"logo\" class=\"standard_logo\" src=\"/servlet/servlet.ImageServer?id=0154O0000074vxd&amp;oid=00DU0000000Lkcq&amp;lastMod=1581701911000\" alt=\"SmartHome\" border=\"0\" name=\"logo\">                    <span class=\"zen-assistiveText\">SmartHome</span></div></div><h2 id=\"header\" class=\"mb12\">Ändern Sie Ihr Kennwort.</h2><div id=\"content\"><form  accept-charset=\"UTF-8\" action=\"/_ui/system/security/ChangePassword?setupid=ChangePassword\" autocomplete=\"off\" enctype=\"application/x-www-form-urlencoded\" id=\"editPage\" method=\"post\" name=\"editPage\" onsubmit=\"if (window.ffInAlert) { return false; }\" ><input type=\"hidden\" name=\"_CONFIRMATIONTOKEN\" id=\"_CONFIRMATIONTOKEN\" value=\"VmpFPSxNakF5TlMwd055MHlORlF4TWpveE1qb3dOaTR4T1RoYSxKU3hJTVVIRU5ONlB6UEJFbTY3MDZqdmQ5bU5TTHNTTGpaQmg3RDl0TXFRPSxZelU0T1RnNA==\" /><input type=\"hidden\" name=\"cancelURL\" id=\"cancelURL\" value=\"/setup/secur/RemoteAccessAuthorizationPage.apexp?source=CAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg==\" /><input type=\"hidden\" name=\"retURL\" id=\"retURL\" value=\"/setup/secur/RemoteAccessAuthorizationPage.apexp?source=CAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg==\" /><input type=\"hidden\" name=\"save_new_url\" id=\"save_new_url\" value=\"/_ui/system/security/ChangePassword?fromFrontdoor=1&amp;retURL=%2Fsetup%2Fsecur%2FRemoteAccessAuthorizationPage.apexp%3Fsource%3DCAAAAZgyDEjRMDAwMDAwMDAwMDAwMDAwAAABAC292TBIIZdwgLpFNr4Q_61rihjaRjwhAXX5Jv7YmClM7C7ZWsOkXtgBET4mh1dXYbkFE__-aVNuGx1YBJNkFMpa3SwchD123C56f8VWIOYaQPAj31TPeY9j0gYf1-2enh6w3s4l0eoE9BazDETkvc4-8T-oi0chdbkbXqhw0Pi6Z0NfQxasXkhI6_-dslWEuyOPzl6Zqaxgx28O5Dw6JXPMehbcmQT87vpTqFrJ_7G0IJSRDLCbm3tO38UT9hxrDM1I72g3zRp0QymtWI_Joi7Hyzqn1rZA6j1GHvekeB49LfB9X4EL8S-m-dYsZeEuHn7RBJyILpPTdxj4ofpnby9E3jnds4l55I36EG7-5a-LCK_FuPJU13EI5s2c53bUY9gytSYp2y5Ku_hR2tCx4XbrOECYBKk952ByCPa8j6JzgHhbGTl2GpUP2ZgszSTQnSe4zB-ylzM7U_efp7adZ3iWL7UtAAwW8WQVduq0LkWiXitiz9WA2Ay4OKZcxQK3S3TMJEiEBwUMgwutFlXt_2nwrht-bIj2FOP4UQFCkmRueXC3iHs9-LXg6Utie5jB8uxE7NNAC0jO6DAAc_doEPGC5IoJKLiivxa17jnUV1-pCwCgHEHFKEfMzcySgx6xg7C8FWoP_LGqzfvKiSJy_1ldmaFZeoze69Nd8jRwHrI_PXMgdvNUTPpx43fcvg-95udV_INZGU-qsuRjE2NRYrNPE1K1brJogTWtsAOy4qU30Vb0o5SXLMOuqmjmTgd8zg%3D%3D&amp;setupid=ChangePassword\" /><input type=\"hidden\" name=\"setupid\" id=\"setupid\" value=\"ChangePassword\" />\n\n<script>\n    var changePassword;\n\n    Sfdc.onload(function() {\n        changePassword = new Identity.ChangePasswordRequirements({\n            length: 8,\n            letters: false,\n            numbers: true,\n            upper: true,\n            lower: true,\n            special: false,\n            anythreeconditions: false\n        });\n    });\n</script>\n<div class=\"setup change-password\">\n<p class=\"mb16\" id=\"pwdintro\">Geben Sie ein neues Kennwort für <span class=\"important\">bernhard3008@gmail.com</span> ein.<span> </span>\n            Schließen Sie mindestens Folgendes ein:</p>\n        <ul class=\"passwordul mb16\">\n            <li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"charcounticon\">\n        <span id=\"charcount\">\n            8 Zeichen</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"uppericon\">\n        <span id=\"upper\">\n            1 Großbuchstabe</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"lowericon\">\n        <span id=\"lower\">\n            1 Kleinbuchstabe</span>\n    </li>\n<li class=\"mb8\">\n        <img src=\"/img/iconCheckDisabled.png\" class=\"passwordicon\" alt=\"Entspricht Anforderungen nicht\" id=\"numbersicon\">\n        <span id=\"numbers\">\n            1 Zahl</span>\n    </li>\n</ul>\n\n<label for=\"newpassword\" class=\"altLabel\"><span class=\"required\">*</span>&nbsp;Neues Kennwort</label>\n<div class=\"password-wrapper\">\n    <input class=\"password-input input wide mt8 mb16 password\" type=\"password\" name=\"newpassword\" aria-required=\"true\" aria-describedby=\"newpassword-message\" user-scalable=\"no\" id=\"newpassword\" autofocus>\n    <span id=\"newpassword-message\" aria-live=\"polite\" class=\"password-message\"></span>\n</div>\n\n<label for=\"confirmpassword\" class=\"altLabel\"><span class=\"required\">*</span>&nbsp;Neues Kennwort bestätigen</label>\n<div class=\"password-wrapper\">\n    <input class=\"password-input input wide mt8 mb16 password\" type=\"password\" name=\"confirmpassword\" aria-required=\"true\" aria-describedby=\"confirmpassword-message\" user-scalable=\"no\" id=\"confirmpassword\">\n    <span id=\"confirmpassword-message\" aria-live=\"polite\" class=\"password-message\"></span>\n</div>\n\n<div class=\"mb16 mt8 small\">\n    <span class=\"required\">*</span>= erforderlich</div>\n\n\n<input name=\"fromFrontdoor\" id=\"fromFrontdoor\" type=\"hidden\" value=\"1\"/><div class=\"wide\">\n        <!--[if IE 7]>\n        <button id=\"password-button\" class=\"button wide mb16\" name=\"save\" type=\"submit\">\n            Kennwort ändern</button>\n<![endif]-->\n<![if !(IE 7)|!IE]>\n        <button id=\"password-button\" class=\"button wide mb16\" name=\"save\">\n            Kennwort ändern</button>\n<![endif]>\n    </div>\n<p class=\"small\">Kennwort wurde am 15.08.2023, 13:06 zuletzt geändert.</p></div>\n<div id=\"pwcaps\" class=\"mb16\" style=\"display:none\" aria-live=\"assertive\"><img id=\"pwcapsicon\" alt=\"Feststelltaste ist aktiviert.\" width=\"12\" src=\"/img/icon/capslock_blue.png\"/> Feststelltaste ist aktiviert.</div>\n</form></div></div></div><div id=\"footer\">&copy; 2025 Candy Hoover Group Srl. Alle Rechte vorbehalten.</div><script>var p=document.getElementById('footer').parentNode;while(p.nodeName.toLowerCase()==='div'){p.style.height='100%';p=p.parentNode;}</script>\n\n\n<!-- Body events -->\n<script type=\"text/javascript\">function bodyOnLoad(){if (typeof(startSessionTimer)!='undefined') {startSessionTimer(); };if(window.PreferenceBits){window.PreferenceBits.prototype.csrfToken=\"VmpFPSxNakF5TlMwd055MHlORlF4TWpveE1qb3dOaTR5TVRGYSxUczk3U3V5RTdEeDRvVjNEWDRPM3dHTE1WSFp3OFM0Z1M3ZS1EUHdINk00PSxNR1V3WmpRdw==\";};}function bodyOnBeforeUnload(){}function bodyOnFocus(){}function bodyOnUnload(){}</script></body></html>"
            2025-07-21 14:12:56.268  - error: sourceanalytix.0 (1256) Check settings for sonoff.0.Zaehler.SML_Actual_pow ! Known valueAtDeviceReset : (31.784) > known cumulative value (31.738) cannot proceed
            2025-07-21 14:12:56.271  - error: sourceanalytix.0 (1256) Troubleshoot Data sonoff.0.Zaehler.SML_Actual_pow custom Data : {"_id":"sonoff.0.Zaehler.SML_Actual_pow","common":{"role":"value","read":true,"write":false,"type":"number","unit":"kWh","name":"Zaehler SML  Actual_pow","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","start_day":1302,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"alias":"Gesamtstrom","selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"basicRate":true,"valueAtDeviceReset":31.784,"valueAtDeviceInit":0.764}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1635757558045}
            2025-07-21 14:12:56.273  - error: sourceanalytix.0 (1256) Cannot handle calculations for sonoff.0.Zaehler.SML_Actual_pow, check log messages and adjust settings!
            2025-07-21 14:12:56.276  - error: sourceanalytix.0 (1256) Initialization of sonoff.0.Zaehler.SML_Actual_pow failed, check warn messages !
            2025-07-21 14:13:09.533  - error: heatingcontrol.0 (450) could not read target OID fritzdect.0.DECT_119600122088.tsoll in Schlafzimmer
            2025-07-21 14:13:17.973  - error: reolink.0 (1371) get white led: TypeError: Cannot read properties of undefined (reading 'WhiteLed')
            2025-07-21 14:13:18.295  - warn: reolink.0 (1371) State "reolink.0.setting.EmailNotification" has no existing object, this might lead to an error in future versions
            2025-07-21 14:14:21.254  - error: heatingcontrol.0 (450) Schlafzimmer could not read fritzdect.0.DECT_119600122088.tsoll
            • OliverIO
              OliverIO @Chaot last edited by
              @chaot
              Hinweis 1, was nichts mit dem eigentlichen Problem zu tun hat:
              Warum hast du json und Redis gemischt. Wenn dann würde ich auch die objects auf Redis umstellen.
              Hinweis2:
              Hast Du evtl. Ports am Router geöffnet?
              • Chaot
                Chaot @OliverIO last edited by
                @oliverio
                Ich hatte mal irgendwann gelesen, dass diese Kombination bei meinem System wohl schneller (besser) wäre. Aber das lässt sich ja beheben.
                Ports am Router sind für den ioBroker alle dicht.
                wendy2702 OliverIO 2 Replies Last reply Reply Quote 0
                • wendy2702
                  @chaot hast du den Proxmox Container mal neu gestartet und damit auch iob?
                  • Chaot
                    @wendy2702
                    Ja, bereits mehrfach.
                    Ich habe auch schon den kompletten Server neu gestartet
                    • OliverIO
                      OliverIO @Chaot last edited by OliverIO
                      @chaot
                      Wenn du genug ram hast ist Redis schneller.
                      Beide Systeme halten die Daten im ram und Speichern verzögert im Hintergrund. Redis hat das optimiertere Datenformat (binär) auf der Platte und ist in C geschrieben. Jsonl speichert als json und ist in JavaScript geschrieben.
                      Daher ist Redis insgesamt besser.
                      Gut, das keine offenen Ports, dann schließt sich das aus, das jemand fremdes sich da Scherze erlaubt.
                      Probiere evtl. Mal mit der physischen Platte (also nicht im Container) einen Smart Festplatten Test durchzuführen um beginnende Schäden der Platte/ssd auszuschließen. Ergebnisse kannst du durch ChatGPT interpretieren lassen.
                      Nachtrag
                      Dringend die Platte prüfen
                      Hier sind Fehler und Warnungen drin
                        Thomas Braun Most Active @Chaot last edited by Thomas Braun
                        Ganz grundsätzlich würde ich das ganze Spiel auf einer noch unterstützen Basis betreiben.
                        Und das Dateisystem scheint was zu haben:
                        • Chaot
                          Chaot @Thomas Braun last edited by
                          Das bedeutet:
                          Proxmox Platte rausschmeißen, neu machen (bzw ersetzen) und dann alle container zurück.
                          Dann iobroker auf neuen Container und Backup wieder einspielen.
                          Thomas Braun OliverIO 2 Replies Last reply Reply Quote 0
                            @chaot
                            Zum Beispiel.
                            • OliverIO
                              @chaot
                              Erst mal den physischen Status feststellen. Es können auch logische Fehler des Dateisystem sein, die sich reparieren lassen.
                              Wenn die Platte schon ein wenig älter ist, dann ja, ansonsten werden die Probleme nicht besser.
                              Der interessanteste Wert von Smart um den physischen plattenstatus zu bewerten bei ssd ist TBW total bytes written, reallocated sector count und uncorrectable error count
                              • Codierknecht
                                Codierknecht Developer Most Active @OliverIO last edited by Codierknecht
                                @oliverio sagte in Mal wieder zerschossen:
                                Jedenfalls nicht für ioBroker
                                Hoffentlich auch sonst keine Portfreigaben ❓❓❓
                                Chaot 1 Reply Last reply Reply Quote 1
                                • Chaot
                                  Chaot @Codierknecht last edited by
                                  @codierknecht Doch. zwei Ports brauche ich leider offen. Im Netzwerk hängt noch ein Kassensystem.
                                  1.0k
                                  iobroker stoppt nicht
                                  754
