    3. Cloud Dienste
    4. Iobroker skill in Alexa nicht verfügbar
    • haselchen
      haselchen Most Active @apollon77 last edited by
      @apollon77
      Wie lange wird der „alte“ Skill noch funktionieren?
      Wenn der zeitnah deaktiviert wird, wäre das vermutlich ein Supergau für viele hier .
      • realwax
        realwax last edited by Samson71
        Herzlichen Dank!
        Nun muss man natürlich alte Geräte löschen - Alle - und die neuen wieder in die richtigen Räume adden. Hauptsache er ist wieder da.
        Spannenderweise klappt aber meine alte Config mit den Lichtern von Deconz nicht mehr.
        sobald ich jene in der Alexa App schalte erhalte ich...
        deconz.0
        2025-07-23 20:27:25.837	warn	{"address":"/lights/40/state/bri","description":"invalid value, true, for parameter, bri","type":7}
        deconz.0
        2025-07-23 20:27:25.837	warn	Failed action "bri" on light 40! Description: invalid value, true, for parameter, bri
        deconz.0
        2025-07-23 20:27:25.832	warn	{"address":"/lights/40/state/sat","description":"parameter, sat, is not modifiable. Device is set to off.","type":201}
        deconz.0
        2025-07-23 20:27:25.831	warn	Failed action "sat" on light 40! Description: parameter, sat, is not modifiable. Device is set to off.
        deconz.0
        2025-07-23 20:27:25.830	warn	Code 400: Bad request set light state 40: [{"error":{"address":"/lights/40/state","description":"body contains invalid JSON","type":2}}]
        iot.0
        2025-07-23 20:27:25.819	info	State value to set for "deconz.0.Lights.40.sat" has to be type "number" but received type "boolean"
        iot.0
        2025-07-23 20:27:25.819	info	State value to set for "deconz.0.Lights.40.hue" has to be type "number" but received type "boolean"
        iot.0
        2025-07-23 20:27:25.818	info	State value to set for "deconz.0.Lights.40.bri" has to be type "number" but received type "boolean"
        iot.0
        2025-07-23 20:27:25.818	info	State value to set for "0_userdata.0.lights.colortemp.colortemp_ledoffice" has to be type "number" but received type "boolean"
        Mod-Edit
        Bitte Code-Tags </> benutzen
          Sebart78 last edited by
          Ich will hier zwischendrin einfach mal ein Lob und einen riesen Dank an die loswerden, die sich hier um Skills, Adapter und Co. kümmern! Ihr macht echt einen geilen Job und ihr habt meine volle Bewunderung für das, was ihr tut. Ich bin schon froh, wenn ich mit meinem Halbwissen und etlichen Anleitungen die ganzen Sachen irgendwie zum Laufen bekomme. Ohne euch wäre das alles nicht möglich. Das verdient Anerkennung und keine unangemessene Kritik, wie man sie leider immer wieder liest.
          • Michael Schmitt
            Michael Schmitt @apollon77 last edited by
            @apollon77 sagte in Iobroker skill in Alexa nicht verfügbar:
            @michael-schmitt Am besten schau Dir doch mal den Matter Thread an (https://forum.iobroker.net/topic/79493/iobroker-matter-adapter/2) - bzw dort den entsprechenden Unterthead zum Thema Devices und Bridges (https://forum.iobroker.net/topic/79497/matter-devices-und-bridges). Deine Fragen dann auch am besten dort hin
            So läuft nur hier auch 🙂 hat nur ein paar Kaffee gebraucht.
            • totocotonio
              totocotonio last edited by
              Hi, ich habe den Skill auch wieder aktiviert aber er findet die Geräte von Node Red nicht mehr.
              Hat da jemand eine Idee?
              Gruß TM
                apollon77 @haselchen last edited by
                @haselchen Das kann ich Dir nicht sagen. Wir werden aktiv nichts tun um den abzuschalten - und falls es doch aus irgendeinem Grund nötig werden sollte werden wir das mit Vorlauf kommunizieren.
                Aktuell geht der Alte Skill malnoch so lange bis man es selbst aus welchem Grund auch immer deaktiviert ... es kann also jeder planen was er tun will oder auf Risiko gehen.
                Aber das erklären wir alles wenn der neue Skill wirklich da ist
                  apollon77 @SevGu last edited by
                  @sevgu Dann weisst Du mehr als ich. Also der neue Skill bis wir offiziell kommunizieren wäre dann mal "auf eigene Gefahr ":-)
                    apollon77 @realwax last edited by
                    @realwax Naja der neue Skill ist jetzt Alexa V3 basiert, also andere Schnittstelle und Logik. Bitte issue im iot Anlagen und am besten Debug log erstellen und anhängen. Scheinbar müssen wir bei v3 noch letzte Probleme fixen
                      apollon77 @totocotonio last edited by
                      @totocotonio Ehrlich ... Ohne das du genauer sagst was "Geräte von node-red" sind ... nein 🙂
                      totocotonio 1 Reply Last reply Reply Quote 0
                      • totocotonio
                        totocotonio @apollon77 last edited by totocotonio
                        @apollon77
                        HI, ich habe Flows in Node Red. zB. so:
                        Amazon-HUB----Geräte
                        Hat immer funktioniert. Nun findet er halt diese Geräte nicht mehr.
                        Gruß TM
                        Basti97 1 Reply Last reply Reply Quote 0
                          Bongo last edited by Bongo
                          ich habe den Skill auch wieder aktiviert. IOT Pro Passwort eingegeben.
                          Alle Geräte sind noch da. Schalter/Licht Ein/Aus funktioniert.
                          Aber wenn ich Routinen benutze und und in Alexa2 Trigger/Rescann anstoße, bekomme ich keine Rückmeldung.
                          Alexa2 und iot neu gestartet. Hat aber nichts gebracht.
                          Jetzt ist der Stand so wie der Skill noch verschwunden war.
                          Hab ich was vergessen? Muss ich noch was machen?
                          Edit:
                          Hm, manchmal kommt bei Trigger/Rescann nichts zurück und manchmal dauert es größer 10 Sekunden.
                          Edit:
                          Heute reagiert Trigger/Rescann nach ca. 2 Sekunden. Jetzt scheint alles wie gewohnt zu laufen.
                          realwax 1 Reply Last reply Reply Quote 0
                          • realwax
                            realwax @Bongo last edited by realwax
                            Ich habe einige Probleme im Zusammenhang mit dem neuen iobroker.assistent skill. Den iobroker.iot skill gibt es ja nicht mehr.
                            Der neue scheint nur via der V3 Beta zu kommunizieren. Diese hat aber im iobroker.iot adapter einige Themen wie es scheint. Ich bekomme meine Lichter (deconz adapter) nicht im iot adapter auf der V3 Seite hinein. Es kommt die Fehlermeldung Gerät konnte nicht hinzugefügt werden. Bei der alten Version habe ich bei solchen Fehlern immer das Objekt selbst modifiziert
                            "custom": {
                               "iot.0": {
                                 "smartName": {
                                   "de": "Esstisch",
                                   "smartType": "LIGHT",
                                   "byON": "90"
                            aber das scheint der V3 egal zu sein. Das Problem dadurch. Ich bekomme meine Geräte nicht mehr in Alexa und funktionierend.... Wie kann ich das manuell fixen?
                            Also danke dass der Skill wieder da ist, aber aktuell funktionieren keine Lichter bei mir via deconz da ich sich nicht einbinden kann... Szenen kommen auch nicht durch.
                            Selbst manche einfach Schalter/Steckdosen existieren unter Alexa Geräte, aber nicht unter Alexa Geräte V3. Dort kann man sie nicht adden, und somit kommen sie auch nicht in die Alexa app. Kann ich manuell nachbessern? Config ähnlich wie mit der custom config im objekt. Diese scheint aber nur V1/2 zu betreffen...
                            Bin gerade ratlos, auch wenn alles wieder up ist, funktioniert gerade wenig...
                            Ich habe 58 Einträge in der V1/V2 Geräte Seite und 14 unter V3 und keine Chance dort welche zu adden.
                            https://github.com/ioBroker/ioBroker.iot/issues/938
                            Danke für Hilfe, oder Tipps.
                            Wolfgang
                            realwax created this issue in ioBroker/ioBroker.iot
                            closed iobroker.assistent adapter with Alexa V3 beta adding devices error #938
                            • Master67
                              Master67 @Michael Schmitt last edited by
                              @michael-schmitt sagte in Iobroker skill in Alexa nicht verfügbar:
                              irgendwie steig ich da nicht durch . Könnte mal jemand ein kleines Howto für dummies wie mich machen. Wie nutzt man das ganze um einfach seine Lichter mit Alexa zu steuern? So das man den Iot Adapter nicht mehr braucht.
                              Ich würde das unterstützen 👍
                              Matter mach mir echt Probleme, sobald die USB-Sticks (Sender/Empfänger) Stromlos waren muss ich alles neu in den Matter Adapter Eintragen, ich glaube nicht dass das so sein soll.
                              @apollon77 die links zum Thema "Matter" kennen ich, sind aber für jemanden der das erste mal was mit Matter zu tun hat, sehr Umfangreich und echt verwirrende, die Anleitung zur Einrichtung der Geräte passt, aber hier mache ich wohl schon was falsch, denn wenn es richtig wäre, würden die Geräte nach der neuen Stromzufuhr immer noch da sein 🙂
                              Und nun, soll man noch seine Alexa in Matter einbauen? tja ohne Anleitung für DAUs (ich bin ein DAU) wird das wohl nichts werden 🙂
                              • ChristianM
                                ChristianM last edited by
                                Läuft ja bei mir, bergab und rückwärts. Screenshot_20250725-191425_Samsung Internet.jpg
                                • Fabio
                                  Fabio @apollon77 last edited by Fabio
                                  Guten morgen @apollon77 gibt es was neues?
                                  Bin jetzt auch raus, seid gestern Abend. 😒
                                  Habe dann den iot Adapter auf Version Alexa V 3 umgestellt und nach mehrmaligen versuchen klappt es auch wieder mit dem Alexa Skill.
                                  Jetzt habe ich alle Geräte doppelt in Alexa.
                                  Eben kam dann von ioBroker eine Email das ich zu viele Anfragen gestellt habe und bis Mitternacht gesperrt bin. Habe aber laut iobroker Clout 748 also noch einiges bis 1000. iobrkerclout.jpg
                                  Ganz erlich ich verstehe hier nur noch Bahnhof.
                                  Ich würde mich sehr darüber freuen wenn ihr euch mal bitte äußern könntet wie es weiter geht und evtl. und auch wie?
                                  Herzliche Grüße und Danke schön 😉
                                  Fabio
                                  PS: In diesem Moment kam dann das:
                                  1001 Heute wurden zu viele Befehle gesendet. Sie haben eine ungültige Konfiguration mit hoher Wahrscheinlichkeit.
                                  Duffy apollon77 3 Replies Last reply Reply Quote 0
                                  • Duffy
                                    Duffy @Fabio last edited by
                                    Hallo an Alle,
                                    ich bin total verwirrt.
                                    Kann vielleich jemand in einfachen Worten zusammenfassen ob und wie man wieder Lichter über Alexa schalten kann?
                                    Ich blick da leider überhaupt nicht mehr durch, Matter, iobroker.iot, iobroker.assistent Alexa 2 Alexa 3 vip6 ......
                                    Ich finde nicht mal einen Ansatz um bei mir den Fehler zu beheben.
                                    Dazu auch mein Post: (https://forum.iobroker.net/topic/81749/alexa-sprachsteuerung-in-iob-nur-noch-sehr-eingeschränkt)
                                    Vielleicht ist die Frage von mir wirklich so dämlich das ich keine Antwort bekomme aber ich würde mich echt freuen wenn mir jemand den Hirnknoten mit einer Antwort entfernen könnte.
                                    Es grüsst euch Duffy
                                    • Basti97
                                      Basti97 Most Active @totocotonio last edited by
                                      @totocotonio Funktioniert bei dir die Verbindung richtig? Bei mir gibt es eine verzögerung erst dreht sich der ring dann sagt Alexa "Gerät reagiert nicht" und dann schaltet sie es trotzdem. Finde den Fehler in meinen Geräten nicht schon zich mal neugestartet Skill neu Installiert. Aber trotzdem die verzögerung. aber ich bin glücklich das es überhaupt noch funktoniert was man so hier ließt. Geräte werden als Online in Nodered angezeigt.
                                        apollon77 @ChristianM last edited by
                                        @christianm Naja, DAS hat jetzt mit dem Skill eher nix zu tun 🙂
                                          apollon77 @Fabio last edited by
                                          @fabio sagte in Iobroker skill in Alexa nicht verfügbar:
                                          Sobald ich Infos von Denis und der von Amazon hat werden wir das auch tun. Ich kann nichts sagen was ich nicht weiss.
                                          Fabio 1 Reply Last reply Reply Quote 1
                                            apollon77 @Duffy last edited by
                                            @duffy Du hast den Thread hier schon richtig gefunden. Aktuell ist der ioBroker.io Skill von Amazon deaktiviert. Es wird einen Nachfolgerskill geben und wir werden kommunizieren sobald alles geklärt ist.
                                            1.4k
                                            219
                                            24483
