      Rand @Shakira1972 last edited by
      Leicht OT, aber vieleicht hilft es ja jemanden 🙂
      Hatte ja nach einem Weg gesucht den WFC01 auszulesen und nun ein einfaches JS basteln lassen:
      const gwIp = '192.168.x.y'; // Replace with your actual GW2000 IP
      const deviceId = 13443;      // Your WFC01 device ID
      const model = 1;             // Always 1 for WFC01
      const request = require('request');
      const enableLogging = true;
      const statePrefix = 'javascript.0.WFC01';
      function logDebug(msg) {
          if (enableLogging) log(msg);
      function createAndSetState(id, value, unit = '', type = 'number') {
          const fullId = `${statePrefix}.${id}`;
          if (!existsState(fullId)) {
              createState(fullId, value, {
                  type: type,
                  read: true,
                  write: false,
                  unit: unit
              logDebug(`Created state: ${fullId}`);
          setState(fullId, value, true);
          logDebug(`Updated ${fullId} → ${value}${unit}`);
      const options = {
          url: `http://${gwIp}/parse_quick_cmd_iot`,
          method: 'POST',
          headers: {
              'Content-Type': 'application/json'
          body: JSON.stringify({
              command: [{
                  cmd: "read_device",
                  model: model
          timeout: 5000
      logDebug('Sending POST request to WFC01...');
      request(options, (error, response, body) => {
          if (error) {
              logDebug(`Request error: ${error}`);
              return;
          if (response.statusCode !== 200) {
              logDebug(`Unexpected status code: ${response.statusCode}`);
              logDebug(`Response body: ${body}`);
              return;
          if (!body) {
              logDebug('Empty response body');
              return;
          try {
              const data = JSON.parse(body);
              logDebug(`Parsed JSON data: ${JSON.stringify(data)}`);
              const d = data.command[0];
              createAndSetState('flow_velocity', parseFloat(d.flow_velocity), 'L/min');
              createAndSetState('water_total', parseFloat(d.water_total), 'L');
              createAndSetState('water_status', parseInt(d.water_status));
              createAndSetState('water_temp', parseFloat(d.water_temp), '°C');
              createAndSetState('battery', parseInt(d.wfc01batt));
              createAndSetState('signal', parseInt(d.rssi));
              createAndSetState('warning', parseInt(d.warning));
              createAndSetState('run_time', parseInt(d.run_time), 's');
          } catch (e) {
              logDebug(`JSON parse error: ${e.message}`);
      Habs ohne >request< nicht hinbekommen, da hat er den call nicht sauber gemacht.
      Die Infos dazu stammen aus dem Ecowitt API document welches sie auf Anfrage verschicken (Local IOT API 20240828.docx in meinem Fall).
      S SBorg 3 Replies Last reply Reply Quote 0
        Solardach @Rand last edited by
        @rand Hallo !
        Vielen Dank für das Skript, 👍 👏
        Danach hatte ich schon länger gesucht.
        Ich habe es installiert und läuft bei mir mit der WS3900A Wetterstation als Gateway.
        Den Punkt "happen_water" habe ich noch dazu gesetzt.
        water volume when water program starts. (L = water_total - happen_water)
          @rand
          Das Problem mit dem Skript ist, das es keinen Trigger gibt.
          Es werden nur einmalig beim Skript Start die Werte eingelesen und das wars.
          Vieleicht kann man noch einen Trigger mit einbauen ?
            Rand @Solardach last edited by Rand
            @solardach
            Klar, danke, hätte vieleicht vorher prüfen sollen ob alles tut, aber es war spät;)
            Es wird auch ohne saubere Werte angelegt (nur als State, das habe ich auch noch gemacht (machen lassen ;))
            Edit: So Water_happen sollte mit drin sein, hat es beim ersten durchlauf gestern scheinbar ignoriert, aber ist auch bei mir vorhanden.
            Edit 2 - Es gab noch eine Diskrepanz zwischen State und Ihrem Datentyp (numerisch) -> ping @Solardach
            Edit 3 - Nochmal korrigiert
            const gwIp = '192.168.x.y';    // IP of your Sensaphone Web600
            const deviceId = 13443;           // Device ID of your WFC01
            const model = 1;                  // Model = 1 for WFC01
            const version = '1.0.0';          // Script version
            const statePrefix = 'javascript.0.WFC01'; // ioBroker state prefix
            // Log script version on start
            logDebug(`Starting WFC01 script, version ${version}`);
            // Recreate or update ioBroker state - Async version to avoid type errors
            async function recreateState(id, value, meta) {
                if (!(await existsStateAsync(fullId))) {
                    await createStateAsync(fullId, value, {
                        type: meta.type,
                        role: meta.role,
                        read: true,
                        write: false,
                        unit: meta.unit || ''
                await setStateAsync(fullId, { val: value, ack: true });
                logDebug(`Updated ${fullId} → ${value}${meta.unit || ''}`);
            // Metadata definitions for each field
            const fieldDefinitions = {
                flow_velocity:  { unit: 'L/min', type: 'number', role: 'value.flow' },
                water_total:    { unit: 'L',     type: 'number', role: 'value.total' },
                happen_water:   { unit: 'L',     type: 'number', role: 'value' },
                water_volume:   { unit: 'L',     type: 'number', role: 'value' },
                water_status:   {                type: 'number', role: 'value.status' },
                water_temp:     { unit: '°C',    type: 'number', role: 'value.temperature' },
                battery:        {                type: 'number', role: 'value.battery' },
                signal:         {                type: 'number', role: 'value.signal' },
                warning:        {                type: 'number', role: 'value.warning' },
                run_time:       { unit: 's',     type: 'number', role: 'value.interval' },
                publish_time:   { unit: 's',     type: 'number', role: 'value.time' },
                timeutc:        { unit: 's',     type: 'number', role: 'value.time' },
                water_action:   {                type: 'number', role: 'value' },
                water_running:  {                type: 'number', role: 'indicator.running' }
            // Poll the WFC01 device (async version)
            async function pollDeviceData() {
                const options = {
                    method: 'POST',
                    headers: { 'Content-Type': 'application/json' },
                        command: [{
                            cmd: "read_device",
                            model: model
                    timeout: 5000
                request(options, async (error, response, body) => {
                    if (error) {
                        return;
                        return;
                    if (!body) {
                        return;
                    try {
                        if (!d) {
                            logDebug('No device data in response.');
                            return;
                        // Parse and update all standard fields asynchronously
                        await recreateState('flow_velocity', parseFloat(d.flow_velocity), fieldDefinitions.flow_velocity);
                        await recreateState('water_total', parseFloat(d.water_total), fieldDefinitions.water_total);
                        await recreateState('happen_water', parseFloat(d.happen_water), fieldDefinitions.happen_water);
                        await recreateState('water_status', parseInt(d.water_status), fieldDefinitions.water_status);
                        await recreateState('water_temp', parseFloat(d.water_temp), fieldDefinitions.water_temp);
                        await recreateState('battery', parseInt(d.wfc01batt), fieldDefinitions.battery);
                        await recreateState('signal', parseInt(d.rssi), fieldDefinitions.signal);
                        await recreateState('warning', parseInt(d.warning), fieldDefinitions.warning);
                        await recreateState('run_time', parseInt(d.run_time), fieldDefinitions.run_time);
                        await recreateState('publish_time', parseInt(d.publish_time), fieldDefinitions.publish_time);
                        await recreateState('timeutc', parseInt(d.timeutc), fieldDefinitions.timeutc);
                        await recreateState('water_action', parseInt(d.water_action), fieldDefinitions.water_action);
                        await recreateState('water_running', parseInt(d.water_running), fieldDefinitions.water_running);
                        // Calculated water_volume
                        const waterTotal = parseFloat(d.water_total);
                        const happenWater = parseFloat(d.happen_water);
                        const waterVolume = waterTotal - happenWater;
                        await recreateState('water_volume', waterVolume, fieldDefinitions.water_volume);
                    } catch (e) {
            // Run initially and set interval to 1 minute
            pollDeviceData();
            setInterval(pollDeviceData, 60 * 1000);
              @rand
              Kann es sein das jetzt ein altes Skript drin steht ?
              Es verursacht mehr Probleme mit den Datentypen, und es fehlen die Werte water_happen und Volume.
                @solardach
                Ja. Der nachteil von ChatGPT, man muss immer alles doppelt und dreifach prüfen 😞
                Ich repariere es nachher.
                Edit: Habe es nochmal korrigiert, ich hoffe es tut nun
                  Shakira1972 @Boronsbruder last edited by Shakira1972
                  @boronsbruder Hallo,
                  leider aktualisieren sich die Werte nicht.
                  Die Bodenfeuchtesensoren DP100, 1 bis 9 aktualisieren sich, 10 bis 16 nach der Installation von 3.5.1 nicht mehr.
                  Es gab die erste richtige übertragung nach der Installation vor einer Woche, aber dann kamen keine Neuen Werte mehr...
                  Woran könnte dies liegen?
                  Shaki
                  Boronsbruder S 2 Replies Last reply Reply Quote 0
                  • Boronsbruder
                    Boronsbruder @Shakira1972 last edited by
                    @shakira1972
                    Da müssen wir @SBorg fragen.
                    Was is da los? 😆
                      @rand Prima ! Funktioniert.
                      • MassiveAttack
                        MassiveAttack last edited by
                        Kann mir bitte jemand helfen, diesen Fehler wegzubekommen? Der kommt mittlerweile ~ alle 30 Sekunden und spammt mir das Log voll:
                        sourceanalytix.0
                        	2025-07-24 11:23:34.128	error	Input value for javascript.0.Wetterstation.Regen_Jahr, type = string but should be a number, cannot handle calculation
                        Der Type ist aber mixed bzw. auch number. Nur der Zustand hat Typ string. Wie kann ich das ändern?
                        • Stefan81 0
                          Stefan81 0 last edited by
                          Hallo Liebe Community,
                          ich glaube ich brauche mal eure Hilfe.
                          Ich habe meine Wlan-Wetterstation WH6000 auf dem Dach installiert, und nun möchte ich natürlich die Daten auch im iobroker zur Verfügung stellen.
                          Ich stehe glaube ich kurz vorm Ziel, aber irgendwo hakt es noch denke ich.
                          das hier ist meine Info die ich geben kann.
                          Vielleicht sieht ja einer das Problem, bin leider kein IT Profi.
                          WLAN-Wetterstation V3.5.1 - (c)2019-2025 by SBorg
                          Config-Version: V3.5.1
                          Sub-Version : V3.5.1
                          'bc' installiert: [✓]
                          'jq' installiert: [✓]
                          'dc' installiert: [✓]
                          [sudo] password for wetter:
                          'nc' in der Openbsd-Variante installiert: [✓]
                          'netcat' in Openbsd-Variante aktiv, alles korrekt [✓]
                          Connection to 192.168.178.XX 8093 port [tcp/*] succeeded!
                          parse error: Invalid numeric literal at line 1, column 10
                          (standard_in) 1: syntax error
                          /home/wetter/wetterstation/wetterstation.sub: line 858: [: : integer expression expected
                          Messwerteblock:
                          Nicht alle Werte werden unterstützt (abhängig vom Modell der Wetterstation und dem verwendeten Protokoll)!
                          Temperatur Innen : °C
                          Temperatur Aussen : °C
                          Taupunkt : °C
                          Gefühlte Temperatur : °C
                          Luftfeuchte Innen : %
                          Luftfeuchte Aussen : %
                          Windgeschwindigkeit : km/h
                          Windgeschwindigkeit 10min : km/h
                          Windböengeschwindigkeit : km/h
                          Windböe max. : km/h
                          Windrichtung : °
                          Windrichtung :
                          Windrichtung 10min : °
                          Luftdruck absolut : hPa
                          Luftdruck relativ : hPa
                          Regenrate : mm/h
                          Regenstatus :
                          Regen seit Regenbeginn : mm
                          Regen Stunde : mm
                          Regen Tag : mm
                          Regen Woche : mm
                          Regen Monat : mm
                          Regen Jahr : mm
                          Regen Gesamt : mm
                          Sättigungsdefizit : kPa
                          Sonnenstrahlung : W/m²
                          UV-Index :
                          Zeitstempel :
                          Firmware :
                          Batteriestand: :
                          Gateway-Modell :
                          Zusatzsensoren: keine
                          Datenstring für ioBroker:
                          DATA von Wetterstation:
                          Debug VAR:
                          Installationsverzeichnis: /home/wetter/wetterstation
                          IPP: 192.168.178.XX:8093 WS_PORT: 1080 WS_POLL: 30 PRE_DP: 0_userdata.0.Wetterstation
                          WEB: HTTP WS_PROT: Wunderground
                          Zusatzsensoren:
                          DP10/35/40/50/60/70/100/200/250/300: 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
                          WH31: 1 || WS90: 0
                          Bresser: 7009999 [0]
                          Script-Version: V3.5.1 Config-Version: V3.5.1 Sub-Version: V3.5.1
                          Kommunikationsfehler!
                          Kommunikationsfehler! Stimmt die WS_ID in der Konfiguration mit der der WS View-App überein?
                          Ich habe schon gecheckt ob es die gleiche ID ist, die sollte passen soweit.
                          Als App nutze ich auch die richtige denke ich. Die weisse App mit der Station als Bild, WS View nennt die sich.
                          Falls noch Infos benötigt werden, kann ich gerne nachliefern.
                          Ich hoffe es kann mir jemand helfen.
                          Beste Grüße Stefan
                          Boronsbruder 1 Reply Last reply Reply Quote 0
                          • Boronsbruder
                            Boronsbruder @Stefan81 0 last edited by Boronsbruder
                            @stefan81-0
                            Die weisse Wsview ist die Alte. Die neue heisst WsView Plus. Das sollte aber nichts ändern.
                            Hilfreich wäre die Config des Skripts.
                            Dort aber die Passwörter unkenntlich machen!
                            Und ein Screenshot der Einstellungsseite "Weather Services" der App:
                            Ich persönlich benutze immer das Ecowitt-Protokoll und nicht Wunderground. Da das bei mir Probleme machte.
                            Stefan81 0 2 Replies Last reply Reply Quote 0
                            • Stefan81 0
                              Stefan81 0 @Boronsbruder last edited by
                              @boronsbruder
                              ach ok danke schon mal. Werde das mal ausprobieren.
                              Die Daten kann ich vermutlich erst morgen oder Samstag nachliefern.
                              Aber auf jeden Fall schon mal DANKE. ✌
                                Shakira1972 @Shakira1972 last edited by
                                @SBorg Ist es möglich wieder auf die Version 3.5.0 wieder zu kommen?
                                Wenn ich den Befehl ./ws_updater.sh kommen ich auf die 3.5.1, wo leider 7 Sensoren sich nicht mehr aktualisieren..
                                Dann wäre mir lieber wenn 1 Sensor nicht geht...
                                Shaki
                                @shakira1972 sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                Shaki
                                • Boronsbruder
                                  Boronsbruder @Shakira1972 last edited by Boronsbruder
                                  @shakira1972
                                  von Github die 3.5.0 herunterladen und die wetterstation.sh und die wetterstation.sub ersetzen
                                    @boronsbruder Danke für die Antwort.
                                    Leider komme ich nicht weiter.
                                    Habe nun die 3.5.0 wieder installiert.
                                    Trotzdem aktualisieren sich die Sensoren 10 bis 16 nicht mehr.
                                    Was mir aufgefallen ist, es gibt Unterschiede in den Objekten:
                                      "common": {
                                        "name": "DP100 Kanal 1 Bodenfeuchtigkeit",
                                        "type": "number",
                                        "role": "state",
                                        "unit": "%"
                                      "native": {
                                        "type": "number",
                                        "role": "state",
                                        "unit": "%"
                                      "type": "state",
                                      "_id": "0_userdata.0.Wetterstation.DP100.1.Bodenfeuchtigkeit",
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                      "user": "system.user.admin",
                                      "ts": 17537651216
                                      "common": {
                                        "name": "DP100 Kanal 16 Bodenfeuchtigkeit",
                                        "type": "number",
                                        "role": "state",
                                        "unit": "%"
                                      "native": {},
                                      "type": "state",
                                      "_id": "0_userdata.0.Wetterstation.DP100.16.Bodenfeuchtigkeit",
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                      "ts": 17537650140
                                    bei "native".
                                    und auch in den Ordnern gibt es unterschiede:
                                      "type": "folder",
                                      "common": {
                                        "name": "16"
                                      "native": {
                                        "autocreated": "by automatic ensure logic"
                                      "ts": 17537647933,
                                      "_id": "0_userdata.0.Wetterstation.DP100.16",
                                      "acl": {
                                        "object": 1636,
                                      "type": "folder",
                                      "common": {
                                        "name": "ClemYuz 3-3"
                                      "native": {
                                      "_id": "0_userdata.0.Wetterstation.DP100.1",
                                      "acl": {
                                        "object": 1636,
                                      "ts": 16910810752
                                    "from": "system.adapter.admin.0", & "from": "system.adapter.javascript.0",
                                    Hat das was zu sagen?
                                    Habe auch versucht, Sensor 16 unter den Objekten zu löschen und Neu anzulegen, aber dort kommen nun überhaupt keine Werte mehr an...
                                    Nachtrag: Im Log gab es folgende Warnungen, wenn ich den Sensor 16 über JavaScript erneut eingefügt habe:
                                    javascript.0
                                    2025-07-29 06:53:13.472	warn	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2954:25)
                                    javascript.0
                                    2025-07-29 06:53:13.471	warn	You are assigning a string to the state "0_userdata.0.Wetterstation.DP100.16.Raw" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                                    javascript.0
                                    2025-07-29 06:53:13.406	warn	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2954:25)
                                    javascript.0
                                    2025-07-29 06:53:13.405	warn	You are assigning a string to the state "0_userdata.0.Wetterstation.DP100.16.Batterie" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                                    javascript.0
                                    2025-07-29 06:53:13.329	warn	at createState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2954:25)
                                    javascript.0
                                    2025-07-29 06:53:13.319	warn	You are assigning a string to the state "0_userdata.0.Wetterstation.DP100.16.Bodenfeuchtigkeit" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                                    Leider kenne ich mich zu wenig aus, was mit String / Zahl gemeint ist...
                                    Shaki
                                    • Stefan81 0
                                      @boronsbruder
                                      so sorry für die späte Antwort, ich bekomme meine Wetterstation gar nicht in die App geladen.
                                      Es gibt keine Vorschläge in der Übersicht zu meiner.
                                      Gibt es da irgendeinen Trick?
                                      Habs ganz normal über das Wlan von der Anzeige gemacht, dann zurück in die App, aber der führt mich dann nicht weiter zu den nä. Einstellungen.
                                      Und über die ip Adresse findet er die Anlage auch nicht.
                                      In den Einstellungen habe ich "darf Geräte im Netzwerk suchen" und Standortfreigabe aktiviert.
                                      App neu geladen hab ich auch schon probiert. 🤷
                                      • Stefan81 0
                                        Stefan81 0 @Mugel80 last edited by
                                        @mugel80
                                        Einen schönen guten Abend, mit welcher App hast du denn gearbeitet?
                                        Und wie hast du deine Wetterstation dort eingebunden bekommen, ich besitze die gleiche Station, bekomme die aber nicht in die WSVIEW PRO eingebunden.
                                        Gibt es da einen Trick? 🙂
                                        Beste Grüße Stefan
                                        • Boronsbruder
                                          @shakira1972
                                          Lösche doch mal den Ordner 16.
                                          Dann das "wetterstation.js"-Skript benutzen.
                                          Achtung!! Die User-Einstellungen im Skript anpassen!
                                          //Wetterstation Datenpunkte anlegen V3.5.0
                                          let DP = "0_userdata.0.Wetterstation.";
                                          let WH31 = 0;    // Anzahl der WH31/WH25 Sensoren     (max. 1 Stück)
                                          let WS90 = 0;    // Anzahl der WS90 Sensoren          (max. 1 Stück)
                                          let DP10 = 0;    // Anzahl der DP10/WN35 Sensoren     (max. 8 Stück)
                                          let DP35 = 0;    // Anzahl der DP35/WN34 Sensoren     (max. 8 Stück)
                                          let DP40 = 0;    // Anzahl der DP40/WH32 Sensoren     (max. 1 Stück)
                                          let DP50 = 0;    // Anzahl der DP50/WH31 Sensoren     (max. 8 Stück)
                                          let DP60 = 0;    // Anzahl der DP60/WH57 Sensoren     (max. 1 Stück)
                                          let DP70 = 0;    // Anzahl der DP70/WH55 Sensoren     (max. 4 Stück)
                                          let DP100 = 0;   // Anzahl der DP100/WH51[L] Sensoren (max. 16 Stück)
                                          let DP200 = 0;   // Anzahl der DP200/WH43 Sensoren    (max. 4 Stück)
                                          let DP250 = 0;   // Anzahl der DP250/WH45 Sensoren    (max. 1 Stück)
                                          let DP300 = 0;   // Anzahl der DP300/WS68 Sensoren    (max. 1 Stück)
                                          let BR7009999 = 0; // Anzahl der Thermo-Hygro-7Ch-Sensoren (max. 4 Stück)
                                          let FT0300 = 0;  // Anzahl der FT0300 Sensoren        (max. 1 Stück)
                                          //Ende der User-Einstellungen -------------------
                                          Das Skript einmal starten - es sollte dann die fehlenden Datenpunkte anlegen.
                                          Die Fehlermeldungen sagen nur aus, dass der Datenpunkt für Zahlen angelegt ist, aber das Skript aber eine Zeichenkette reinschreiben will.
                                          Hast du nach dem Ersetzen den Dienst neugestartet?
                                          • Boronsbruder
                                            @stefan81-0
                                            Für die Station gibt es doch eine intere Setup-Seite (zumindest laut Betriebsanleitung):
                                            Was hast du hier eingetragen?
                                            Da muss man aber mal schaun, wie die Daten gesendet werden. Wahrscheinlich Wunderground-Protokoll.
                                            Stefan81 0 1 Reply Last reply Reply Quote 0
                                            152
                                            5661
                                            3762502
