    4. [gelöst] Hetzner API, nutzt die jemand von Euch?
    • metaxa
      metaxa @metaxa last edited by metaxa
      @OliverIO
      Datei "rc.local" erstellt und Inhalt eingefügt.
      VM neu gestartet.
      Danach:
      sudo mount.cifs -o vers=3.0,seal,user=xxx,pass=xxx //xxx.your-storagebox.de /mnt/hetzner
      Rückmeldung:
      mount error(22): Invalid argument
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
       sudo dmesg
      [    0.000000] Linux version 6.1.0-37-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.140-1 (2025-05-22)
      [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-amd64 root=UUID=b011ad49-2226-4c89-8e94-60ee6403f995 ro quiet
      [    0.000000] BIOS-provided physical RAM map:
      [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
      [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
      [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
      [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043fffffff] usable
      [    0.000000] BIOS-e820: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
      [    0.000000] NX (Execute Disable) protection: active
      [    0.000000] SMBIOS 2.8 present.
      [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
      [    0.000000] Hypervisor detected: KVM
      [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
      [    0.000001] kvm-clock: using sched offset of 10455311468 cycles
      [    0.000002] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
      [    0.000004] tsc: Detected 2894.562 MHz processor
      [    0.000772] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
      [    0.000774] e820: remove [mem 0x000a0000-0x000fffff] usable
      [    0.061295] AGP: No AGP bridge found
      [    0.061827] last_pfn = 0x440000 max_arch_pfn = 0x400000000
      [    0.061872] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
      [    0.061880] last_pfn = 0xbffda max_arch_pfn = 0x400000000
      [    0.063929] found SMP MP-table at [mem 0x000f5440-0x000f544f]
      [    0.064437] RAMDISK: [mem 0x344f9000-0x36273fff]
      [    0.064444] ACPI: Early table checksum verification disabled
      [    0.064446] ACPI: RSDP 0x00000000000F5200 000014 (v00 BOCHS )
      [    0.064450] ACPI: RSDT 0x00000000BFFE2F47 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064453] ACPI: FACP 0x00000000BFFE2D19 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064457] ACPI: DSDT 0x00000000BFFDF040 003CD9 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064459] ACPI: FACS 0x00000000BFFDF000 000040
      [    0.064461] ACPI: APIC 0x00000000BFFE2D8D 000090 (v03 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064463] ACPI: SSDT 0x00000000BFFE2E1D 0000CA (v01 BOCHS  VMGENID  00000001 BXPC 00000001)
      [    0.064465] ACPI: HPET 0x00000000BFFE2EE7 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064467] ACPI: WAET 0x00000000BFFE2F1F 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
      [    0.064468] ACPI: Reserving FACP table memory at [mem 0xbffe2d19-0xbffe2d8c]
      [    0.064469] ACPI: Reserving DSDT table memory at [mem 0xbffdf040-0xbffe2d18]
      [    0.064470] ACPI: Reserving FACS table memory at [mem 0xbffdf000-0xbffdf03f]
      [    0.064471] ACPI: Reserving APIC table memory at [mem 0xbffe2d8d-0xbffe2e1c]
      [    0.064471] ACPI: Reserving SSDT table memory at [mem 0xbffe2e1d-0xbffe2ee6]
      [    0.064472] ACPI: Reserving HPET table memory at [mem 0xbffe2ee7-0xbffe2f1e]
      [    0.064472] ACPI: Reserving WAET table memory at [mem 0xbffe2f1f-0xbffe2f46]
      [    0.064748] No NUMA configuration found
      [    0.064748] Faking a node at [mem 0x0000000000000000-0x000000043fffffff]
      [    0.064755] NODE_DATA(0) allocated [mem 0x43ffc9000-0x43fff3fff]
      [    0.064935] Zone ranges:
      [    0.064935]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
      [    0.064936]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
      [    0.064937]   Normal   [mem 0x0000000100000000-0x000000043fffffff]
      [    0.064938]   Device   empty
      [    0.064939] Movable zone start for each node
      [    0.064941] Early memory node ranges
      [    0.064942]   node   0: [mem 0x0000000000001000-0x000000000009efff]
      [    0.064943]   node   0: [mem 0x0000000000100000-0x00000000bffd9fff]
      [    0.064944]   node   0: [mem 0x0000000100000000-0x000000043fffffff]
      [    0.064946] Initmem setup node 0 [mem 0x0000000000001000-0x000000043fffffff]
      [    0.065143] On node 0, zone DMA: 1 pages in unavailable ranges
      [    0.065164] On node 0, zone DMA: 97 pages in unavailable ranges
      [    0.075322] On node 0, zone Normal: 38 pages in unavailable ranges
      [    0.076304] ACPI: PM-Timer IO Port: 0x608
      [    0.076315] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
      [    0.076345] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
      [    0.076347] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
      [    0.076348] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
      [    0.076349] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
      [    0.076350] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
      [    0.076351] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
      [    0.076353] ACPI: Using ACPI (MADT) for SMP configuration information
      [    0.076354] ACPI: HPET id: 0x8086a201 base: 0xfed00000
      [    0.076361] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
      [    0.076384] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
      [    0.076385] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
      [    0.076386] PM: hibernation: Registered nosave memory: [mem 0xbffda000-0xffffffff]
      [    0.076388] [mem 0xc0000000-0xfeffbfff] available for PCI devices
      [    0.076389] Booting paravirtualized kernel on KVM
      [    0.076391] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
      [    0.079797] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
      [    0.080088] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
      [    0.080092] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
      [    0.080094] pcpu-alloc: [0] 0 1 2 3
      [    0.080117] kvm-guest: PV spinlocks enabled
      [    0.080119] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
      [    0.080126] Fallback order for Node 0: 0
      [    0.080128] Built 1 zonelists, mobility grouping on.  Total pages: 4128474
      [    0.080129] Policy zone: Normal
      [    0.080130] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-amd64 root=UUID=b011ad49-2226-4c89-8e94-60ee6403f995 ro quiet
      [    0.080164] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-amd64", will be passed to user space.
      [    0.082355] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
      [    0.084042] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
      [    0.084069] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
      [    0.084071] AGP: Checking aperture...
      [    0.145473] AGP: No AGP bridge found
      [    0.146008] software IO TLB: area num 4.
      [    0.171800] Memory: 3179640K/16776672K available (14343K kernel code, 2339K rwdata, 9096K rodata, 2800K init, 17380K bss, 438440K reserved, 0K cma-reserved)
      [    0.171977] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
      [    0.171997] ftrace: allocating 40346 entries in 158 pages
      [    0.177287] ftrace: allocated 158 pages with 5 groups
      [    0.177980] Dynamic Preempt: voluntary
      [    0.178440] rcu: Preemptible hierarchical RCU implementation.
      [    0.178442] rcu:     RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
      [    0.178444]  Trampoline variant of Tasks RCU enabled.
      [    0.178444]  Rude variant of Tasks RCU enabled.
      [    0.178445]  Tracing variant of Tasks RCU enabled.
      [    0.178445] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
      [    0.178446] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
      [    0.181756] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
      [    0.181937] rcu: srcu_init: Setting srcu_struct sizes based on contention.
      [    0.196953] Console: colour VGA+ 80x25
      [    0.196962] printk: console [tty0] enabled
      [    0.196983] ACPI: Core revision 20220331
      [    0.197119] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
      [    0.197231] APIC: Switch to symmetric I/O mode setup
      [    0.197410] x2apic enabled
      [    0.197618] Switched APIC routing to physical x2apic.
      [    0.198557] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
      [    0.198578] tsc: Marking TSC unstable due to TSCs unsynchronized
      [    0.198583] Calibrating delay loop (skipped) preset value.. 5789.12 BogoMIPS (lpj=11578248)
      [    0.198750] Last level iTLB entries: 4KB 512, 2MB 255, 4MB 127
      [    0.198751] Last level dTLB entries: 4KB 512, 2MB 255, 4MB 127, 1GB 0
      [    0.198756] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
      [    0.198757] Spectre V2 : Mitigation: Retpolines
      [    0.198758] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
      [    0.198762] x86/fpu: x87 FPU will use FXSAVE
      [    0.210793] Freeing SMP alternatives memory: 36K
      [    0.210798] pid_max: default: 32768 minimum: 301
      [    0.210847] LSM: Security Framework initializing
      [    0.210861] landlock: Up and running.
      [    0.210861] Yama: disabled by default; enable with sysctl kernel.yama.*
      [    0.210881] AppArmor: AppArmor initialized
      [    0.210882] TOMOYO Linux initialized
      [    0.210886] LSM support for eBPF active
      [    0.211121] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
      [    0.211128] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
      [    0.319440] smpboot: CPU0: AMD Common KVM processor (family: 0xf, model: 0x6, stepping: 0x1)
      [    0.319565] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.319566] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.319577] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.319578] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.319587] cblist_init_generic: Setting adjustable number of callback queues.
      [    0.319587] cblist_init_generic: Setting shift to 2 and lim to 1.
      [    0.319596] Performance Events: AMD PMU driver.
      [    0.319607] ... version:                0
      [    0.319607] ... bit width:              48
      [    0.319608] ... generic registers:      4
      [    0.319608] ... value mask:             0000ffffffffffff
      [    0.319609] ... max period:             00007fffffffffff
      [    0.319609] ... fixed-purpose events:   0
      [    0.319610] ... event mask:             000000000000000f
      [    0.319674] signal: max sigframe size: 1440
      [    0.319688] rcu: Hierarchical SRCU implementation.
      [    0.319688] rcu:     Max phase no-delay instances is 1000.
      [    0.319922] smp: Bringing up secondary CPUs ...
      [    0.319994] x86: Booting SMP configuration:
      [    0.319995] .... node  #0, CPUs:      #1 #2 #3
      [    0.320404] smp: Brought up 1 node, 4 CPUs
      [    0.320404] smpboot: Max logical packages: 2
      [    0.320404] smpboot: Total of 4 processors activated (23156.49 BogoMIPS)
      [    0.348536] node 0 deferred pages initialised in 32ms
      [    0.351124] devtmpfs: initialized
      [    0.351124] x86/mm: Memory block size: 128MB
      [    0.351540] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
      [    0.351540] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
      [    0.351540] pinctrl core: initialized pinctrl subsystem
      [    0.351540] NET: Registered PF_NETLINK/PF_ROUTE protocol family
      [    0.351637] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
      [    0.351813] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
      [    0.352034] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
      [    0.352052] audit: initializing netlink subsys (disabled)
      [    0.352077] thermal_sys: Registered thermal governor 'fair_share'
      [    0.352077] thermal_sys: Registered thermal governor 'bang_bang'
      [    0.352077] thermal_sys: Registered thermal governor 'step_wise'
      [    0.352077] thermal_sys: Registered thermal governor 'user_space'
      [    0.352077] thermal_sys: Registered thermal governor 'power_allocator'
      [    0.352077] cpuidle: using governor ladder
      [    0.352077] cpuidle: using governor menu
      [    0.352077] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
      [    0.352077] PCI: Using configuration type 1 for base access
      [    0.355207] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
      [    0.355213] audit: type=2000 audit(1753268521.471:1): state=initialized audit_enabled=0 res=1
      [    0.355216] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
      [    0.355216] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
      [    0.355216] ACPI: Added _OSI(Module Device)
      [    0.355216] ACPI: Added _OSI(Processor Device)
      [    0.355216] ACPI: Added _OSI(3.0 _SCP Extensions)
      [    0.355216] ACPI: Added _OSI(Processor Aggregator Device)
      [    0.355911] ACPI: 2 ACPI AML tables successfully acquired and loaded
      [    0.358728] ACPI: Interpreter enabled
      [    0.358736] ACPI: PM: (supports S0 S5)
      [    0.358737] ACPI: Using IOAPIC for interrupt routing
      [    0.358747] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
      [    0.358748] PCI: Using E820 reservations for host bridge windows
      [    0.358889] ACPI: Enabled 3 GPEs in block 00 to 0F
      [    0.361467] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
      [    0.361472] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI HPX-Type3]
      [    0.361474] acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
      [    0.361479] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
      [    0.361751] acpiphp: Slot [3] registered
      [    0.361764] acpiphp: Slot [5] registered
      [    0.361777] acpiphp: Slot [18] registered
      [    0.361823] acpiphp: Slot [4] registered
      [    0.361836] acpiphp: Slot [6] registered
      [    0.361848] acpiphp: Slot [7] registered
      [    0.361860] acpiphp: Slot [8] registered
      [    0.361872] acpiphp: Slot [9] registered
      [    0.361884] acpiphp: Slot [10] registered
      [    0.361896] acpiphp: Slot [11] registered
      [    0.361907] acpiphp: Slot [12] registered
      [    0.361920] acpiphp: Slot [13] registered
      [    0.361932] acpiphp: Slot [14] registered
      [    0.361943] acpiphp: Slot [15] registered
      [    0.361954] acpiphp: Slot [16] registered
      [    0.361966] acpiphp: Slot [17] registered
      [    0.361977] acpiphp: Slot [19] registered
      [    0.361990] acpiphp: Slot [20] registered
      [    0.362002] acpiphp: Slot [21] registered
      [    0.362013] acpiphp: Slot [22] registered
      [    0.362024] acpiphp: Slot [23] registered
      [    0.362036] acpiphp: Slot [24] registered
      [    0.362049] acpiphp: Slot [25] registered
      [    0.362060] acpiphp: Slot [26] registered
      [    0.362266] acpiphp: Slot [27] registered
      [    0.362280] acpiphp: Slot [28] registered
      [    0.362290] acpiphp: Slot [29] registered
      [    0.362301] PCI host bridge to bus 0000:00
      [    0.362303] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
      [    0.362305] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
      [    0.362306] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
      [    0.362307] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
      [    0.362308] pci_bus 0000:00: root bus resource [mem 0xc000000000-0xc08000bfff window]
      [    0.362309] pci_bus 0000:00: root bus resource [bus 00-ff]
      [    0.362352] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
      [    0.362791] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
      [    0.363370] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
      [    0.367046] pci 0000:00:01.1: reg 0x20: [io  0xe0c0-0xe0cf]
      [    0.368878] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
      [    0.368882] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
      [    0.368883] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
      [    0.368884] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
      [    0.369067] pci 0000:00:01.2: [8086:7020] type 00 class 0x0c0300
      [    0.371574] pci 0000:00:01.2: reg 0x20: [io  0xe080-0xe09f]
      [    0.373413] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
      [    0.373886] pci 0000:00:01.3: quirk: [io  0x0600-0x063f] claimed by PIIX4 ACPI
      [    0.373895] pci 0000:00:01.3: quirk: [io  0x0700-0x070f] claimed by PIIX4 SMB
      [    0.374104] pci 0000:00:02.0: [1234:1111] type 00 class 0x030000
      [    0.375701] pci 0000:00:02.0: reg 0x10: [mem 0xfd000000-0xfdffffff pref]
      [    0.380819] pci 0000:00:02.0: reg 0x18: [mem 0xfea50000-0xfea50fff]
      [    0.389798] pci 0000:00:02.0: reg 0x30: [mem 0xfea40000-0xfea4ffff pref]
      [    0.392533] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
      [    0.394522] pci 0000:00:03.0: [1af4:1002] type 00 class 0x00ff00
      [    0.395596] pci 0000:00:03.0: reg 0x10: [io  0xe000-0xe03f]
      [    0.400552] pci 0000:00:03.0: reg 0x20: [mem 0xc080000000-0xc080003fff 64bit pref]
      [    0.405143] pci 0000:00:05.0: [1af4:1004] type 00 class 0x010000
      [    0.407462] pci 0000:00:05.0: reg 0x10: [io  0xe040-0xe07f]
      [    0.409129] pci 0000:00:05.0: reg 0x14: [mem 0xfea51000-0xfea51fff]
      [    0.415452] pci 0000:00:05.0: reg 0x20: [mem 0xc080004000-0xc080007fff 64bit pref]
      [    0.420389] pci 0000:00:12.0: [1af4:1000] type 00 class 0x020000
      [    0.421417] pci 0000:00:12.0: reg 0x10: [io  0xe0a0-0xe0bf]
      [    0.422326] pci 0000:00:12.0: reg 0x14: [mem 0xfea52000-0xfea52fff]
      [    0.428760] pci 0000:00:12.0: reg 0x20: [mem 0xc080008000-0xc08000bfff 64bit pref]
      [    0.430584] pci 0000:00:12.0: reg 0x30: [mem 0xfea00000-0xfea3ffff pref]
      [    0.431565] pci 0000:00:1e.0: [1b36:0001] type 01 class 0x060400
      [    0.432572] pci 0000:00:1e.0: reg 0x10: [mem 0xc000000000-0xc0000000ff 64bit]
      [    0.434101] pci 0000:00:1f.0: [1b36:0001] type 01 class 0x060400
      [    0.435428] pci 0000:00:1f.0: reg 0x10: [mem 0xc000001000-0xc0000010ff 64bit]
      [    0.437591] pci_bus 0000:01: extended config space not accessible
      [    0.437721] acpiphp: Slot [27-2] registered
      [    0.437748] acpiphp: Slot [0] registered
      [    0.437763] acpiphp: Slot [1-2] registered
      [    0.437776] acpiphp: Slot [2] registered
      [    0.437790] acpiphp: Slot [3-2] registered
      [    0.437803] acpiphp: Slot [4-2] registered
      [    0.437816] acpiphp: Slot [5-2] registered
      [    0.437829] acpiphp: Slot [6-2] registered
      [    0.437842] acpiphp: Slot [7-2] registered
      [    0.437855] acpiphp: Slot [8-2] registered
      [    0.437868] acpiphp: Slot [9-2] registered
      [    0.437883] acpiphp: Slot [10-2] registered
      [    0.437896] acpiphp: Slot [11-2] registered
      [    0.437910] acpiphp: Slot [12-2] registered
      [    0.437923] acpiphp: Slot [13-2] registered
      [    0.437936] acpiphp: Slot [14-2] registered
      [    0.437949] acpiphp: Slot [15-2] registered
      [    0.437964] acpiphp: Slot [16-2] registered
      [    0.437977] acpiphp: Slot [17-2] registered
      [    0.437991] acpiphp: Slot [18-2] registered
      [    0.438004] acpiphp: Slot [19-2] registered
      [    0.438018] acpiphp: Slot [20-2] registered
      [    0.438031] acpiphp: Slot [21-2] registered
      [    0.438047] acpiphp: Slot [22-2] registered
      [    0.438060] acpiphp: Slot [23-2] registered
      [    0.438074] acpiphp: Slot [24-2] registered
      [    0.438087] acpiphp: Slot [25-2] registered
      [    0.438102] acpiphp: Slot [26-2] registered
      [    0.438115] acpiphp: Slot [28-2] registered
      [    0.438129] acpiphp: Slot [29-2] registered
      [    0.438143] acpiphp: Slot [30] registered
      [    0.438154] acpiphp: Slot [31] registered
      [    0.438418] pci 0000:01:1b.0: [1b36:000d] type 00 class 0x0c0330
      [    0.438808] pci 0000:01:1b.0: reg 0x10: [mem 0xfe800000-0xfe803fff 64bit]
      [    0.442777] pci 0000:00:1e.0: PCI bridge to [bus 01]
      [    0.442809] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
      [    0.442824] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
      [    0.442855] pci 0000:00:1e.0:   bridge window [mem 0xc060000000-0xc07fffffff 64bit pref]
      [    0.443375] pci_bus 0000:02: extended config space not accessible
      [    0.443510] acpiphp: Slot [0-2] registered
      [    0.443528] acpiphp: Slot [1-3] registered
      [    0.443541] acpiphp: Slot [2-2] registered
      [    0.443553] acpiphp: Slot [3-3] registered
      [    0.443567] acpiphp: Slot [4-3] registered
      [    0.443581] acpiphp: Slot [5-3] registered
      [    0.443594] acpiphp: Slot [6-3] registered
      [    0.443608] acpiphp: Slot [7-3] registered
      [    0.443623] acpiphp: Slot [8-3] registered
      [    0.443637] acpiphp: Slot [9-3] registered
      [    0.443651] acpiphp: Slot [10-3] registered
      [    0.443665] acpiphp: Slot [11-3] registered
      [    0.443678] acpiphp: Slot [12-3] registered
      [    0.443692] acpiphp: Slot [13-3] registered
      [    0.443707] acpiphp: Slot [14-3] registered
      [    0.443721] acpiphp: Slot [15-3] registered
      [    0.443734] acpiphp: Slot [16-3] registered
      [    0.443748] acpiphp: Slot [17-3] registered
      [    0.443762] acpiphp: Slot [18-3] registered
      [    0.443775] acpiphp: Slot [19-3] registered
      [    0.443801] acpiphp: Slot [20-3] registered
      [    0.443815] acpiphp: Slot [21-3] registered
      [    0.443829] acpiphp: Slot [22-3] registered
      [    0.443843] acpiphp: Slot [23-3] registered
      [    0.443856] acpiphp: Slot [24-3] registered
      [    0.443869] acpiphp: Slot [25-3] registered
      [    0.443883] acpiphp: Slot [26-3] registered
      [    0.443898] acpiphp: Slot [27-3] registered
      [    0.443913] acpiphp: Slot [28-3] registered
      [    0.443926] acpiphp: Slot [29-3] registered
      [    0.443941] acpiphp: Slot [30-2] registered
      [    0.443955] acpiphp: Slot [31-2] registered
      [    0.444201] pci 0000:00:1f.0: PCI bridge to [bus 02]
      [    0.444218] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
      [    0.444234] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
      [    0.444265] pci 0000:00:1f.0:   bridge window [mem 0xc040000000-0xc05fffffff 64bit pref]
      [    0.445327] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
      [    0.445422] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
      [    0.445504] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
      [    0.445582] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
      [    0.445634] ACPI: PCI: Interrupt link LNKS configured for IRQ 9
      [    0.445903] iommu: Default domain type: Translated
      [    0.445903] iommu: DMA domain TLB invalidation policy: lazy mode
      [    0.445903] pps_core: LinuxPPS API ver. 1 registered
      [    0.445903] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
      [    0.445903] PTP clock support registered
      [    0.445903] EDAC MC: Ver: 3.0.0
      [    0.446700] NetLabel: Initializing
      [    0.446701] NetLabel:  domain hash size = 128
      [    0.446701] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
      [    0.446711] NetLabel:  unlabeled traffic allowed by default
      [    0.446712] PCI: Using ACPI for IRQ routing
      [    0.446713] PCI: pci_cache_line_size set to 64 bytes
      [    0.446906] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
      [    0.446907] e820: reserve RAM buffer [mem 0xbffda000-0xbfffffff]
      [    0.446921] pci 0000:00:02.0: vgaarb: setting as boot VGA device
      [    0.446921] pci 0000:00:02.0: vgaarb: bridge control possible
      [    0.446921] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
      [    0.446921] vgaarb: loaded
      [    0.446921] hpet: 3 channels of 0 reserved for per-cpu timers
      [    0.446921] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
      [    0.446921] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
      [    0.450673] clocksource: Switched to clocksource kvm-clock
      [    0.450834] VFS: Disk quotas dquot_6.6.0
      [    0.450845] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
      [    0.450966] AppArmor: AppArmor Filesystem Enabled
      [    0.450983] pnp: PnP ACPI init
      [    0.451072] pnp 00:02: [dma 2]
      [    0.451980] pnp: PnP ACPI: found 4 devices
      [    0.459384] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
      [    0.459447] NET: Registered PF_INET protocol family
      [    0.459738] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
      [    0.461680] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
      [    0.461708] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
      [    0.461968] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
      [    0.462325] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
      [    0.462408] TCP: Hash tables configured (established 131072 bind 65536)
      [    0.462506] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
      [    0.462548] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
      [    0.462820] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
      [    0.462885] NET: Registered PF_UNIX/PF_LOCAL protocol family
      [    0.462891] NET: Registered PF_XDP protocol family
      [    0.462903] pci 0000:00:1e.0: PCI bridge to [bus 01]
      [    0.462938] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
      [    0.463534] pci 0000:00:1e.0:   bridge window [mem 0xfe800000-0xfe9fffff]
      [    0.463930] pci 0000:00:1e.0:   bridge window [mem 0xc060000000-0xc07fffffff 64bit pref]
      [    0.464782] pci 0000:00:1f.0: PCI bridge to [bus 02]
      [    0.464807] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
      [    0.465348] pci 0000:00:1f.0:   bridge window [mem 0xfe600000-0xfe7fffff]
      [    0.465685] pci 0000:00:1f.0:   bridge window [mem 0xc040000000-0xc05fffffff 64bit pref]
      [    0.466378] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
      [    0.466381] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
      [    0.466383] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
      [    0.466384] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff window]
      [    0.466385] pci_bus 0000:00: resource 8 [mem 0xc000000000-0xc08000bfff window]
      [    0.466387] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
      [    0.466388] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe9fffff]
      [    0.466389] pci_bus 0000:01: resource 2 [mem 0xc060000000-0xc07fffffff 64bit pref]
      [    0.466391] pci_bus 0000:02: resource 0 [io  0xc000-0xcfff]
      [    0.466392] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff]
      [    0.466393] pci_bus 0000:02: resource 2 [mem 0xc040000000-0xc05fffffff 64bit pref]
      [    0.466480] pci 0000:00:01.0: PIIX3: Enabling Passive Release
      [    0.466493] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
      [    0.467003] ACPI: \_SB_.LNKD: Enabled at IRQ 11
      [    0.468053] ACPI: \_SB_.LNKB: Enabled at IRQ 10
      [    0.468921] ACPI: \_SB_.LNKA: Enabled at IRQ 10
      [    0.469628] PCI: CLS 0 bytes, default 64
      [    0.469697] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
      [    0.469698] software IO TLB: mapped [mem 0x00000000bbfda000-0x00000000bffda000] (64MB)
      [    0.469855] Trying to unpack rootfs image as initramfs...
      [    0.470042] Initialise system trusted keyrings
      [    0.470054] Key type blacklist registered
      [    0.470285] workingset: timestamp_bits=36 max_order=22 bucket_order=0
      [    0.471603] zbud: loaded
      [    0.471971] integrity: Platform Keyring initialized
      [    0.471975] integrity: Machine keyring initialized
      [    0.471977] Key type asymmetric registered
      [    0.471977] Asymmetric key parser 'x509' registered
      [    0.709732] Freeing initrd memory: 30188K
      [    0.714222] alg: self-tests for CTR-KDF (hmac(sha256)) passed
      [    0.714247] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.714363] io scheduler mq-deadline registered
      [    0.715294] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF0_)
      [    0.715301] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
      [    0.715306] shpchp 0000:00:1e.0: Cannot get control of SHPC hotplug
      [    0.715347] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF8_)
      [    0.715350] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
      [    0.715352] shpchp 0000:00:1f.0: Cannot get control of SHPC hotplug
      [    0.715357] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
      [    0.715658] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
      [    0.716131] Linux agpgart interface v0.103
      [    0.716191] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
      [    0.716708] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
      [    0.717473] serio: i8042 KBD port at 0x60,0x64 irq 1
      [    0.717479] serio: i8042 AUX port at 0x60,0x64 irq 12
      [    0.717640] mousedev: PS/2 mouse device common for all mice
      [    0.717663] rtc_cmos 00:03: RTC can wake from S4
      [    0.718216] rtc_cmos 00:03: registered as rtc0
      [    0.718338] rtc_cmos 00:03: setting system clock to 2025-07-23T11:02:01 UTC (1753268521)
      [    0.718408] rtc_cmos 00:03: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
      [    0.718673] ledtrig-cpu: registered to indicate activity on CPUs
      [    0.718888] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
      [    0.726952] NET: Registered PF_INET6 protocol family
      [    0.730596] Segment Routing with IPv6
      [    0.730610] In-situ OAM (IOAM) with IPv6
      [    0.730645] mip6: Mobile IPv6
      [    0.730649] NET: Registered PF_PACKET protocol family
      [    0.730810] mpls_gso: MPLS GSO support
      [    0.731213] IPI shorthand broadcast: enabled
      [    0.731381] registered taskstats version 1
      [    0.731387] Loading compiled-in X.509 certificates
      [    0.742655] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
      [    0.742673] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
      [    0.743301] zswap: loaded using pool lzo/zbud
      [    0.743672] Key type .fscrypt registered
      [    0.743674] Key type fscrypt-provisioning registered
      [    0.746237] Key type encrypted registered
      [    0.746240] AppArmor: AppArmor sha1 policy hashing enabled
      [    0.746248] ima: No TPM chip found, activating TPM-bypass!
      [    0.746249] ima: Allocated hash algorithm: sha256
      [    0.746256] ima: No architecture policies found
      [    0.746262] evm: Initialising EVM extended attributes:
      [    0.746263] evm: security.selinux
      [    0.746263] evm: security.SMACK64 (disabled)
      [    0.746264] evm: security.SMACK64EXEC (disabled)
      [    0.746264] evm: security.SMACK64TRANSMUTE (disabled)
      [    0.746265] evm: security.SMACK64MMAP (disabled)
      [    0.746265] evm: security.apparmor
      [    0.746265] evm: security.ima
      [    0.746266] evm: security.capability
      [    0.746266] evm: HMAC attrs: 0x1
      [    0.804118] Unstable clock detected, switching default tracing clock to "global"
                     If you want to keep using the local clock, then add:
                       "trace_clock=local"
                     on the kernel command line
      [    0.804134] clk: Disabling unused clocks
      [    0.805129] Freeing unused decrypted memory: 2036K
      [    0.805571] Freeing unused kernel image (initmem) memory: 2800K
      [    0.805574] Write protecting the kernel read-only data: 26624k
      [    0.806150] Freeing unused kernel image (text/rodata gap) memory: 2040K
      [    0.806366] Freeing unused kernel image (rodata/data gap) memory: 1144K
      [    0.834994] x86/mm: Checked W+X mappings: passed, no W+X pages found.
      [    0.835002] Run /init as init process
      [    0.835003]   with arguments:
      [    0.835004]     /init
      [    0.835004]   with environment:
      [    0.835005]     HOME=/
      [    0.835005]     TERM=linux
      [    0.835006]     BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-amd64
      [    0.894359] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revision 0
      [    0.900008] SCSI subsystem initialized
      [    0.902511] ACPI: \_SB_.LNKC: Enabled at IRQ 11
      [    0.906789] ACPI: bus type USB registered
      [    0.906807] usbcore: registered new interface driver usbfs
      [    0.906813] usbcore: registered new interface driver hub
      [    0.906821] usbcore: registered new device driver usb
      [    0.909043] FDC 0 is a S82078B
      [    0.915978] uhci_hcd 0000:00:01.2: UHCI Host Controller
      [    0.915988] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
      [    0.916006] uhci_hcd 0000:00:01.2: detected 2 ports
      [    0.916125] uhci_hcd 0000:00:01.2: irq 11, io port 0x0000e080
      [    0.916213] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
      [    0.916215] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.916216] usb usb1: Product: UHCI Host Controller
      [    0.916217] usb usb1: Manufacturer: Linux 6.1.0-37-amd64 uhci_hcd
      [    0.916218] usb usb1: SerialNumber: 0000:00:01.2
      [    0.916310] hub 1-0:1.0: USB hub found
      [    0.916314] hub 1-0:1.0: 2 ports detected
      [    0.918482] libata version 3.00 loaded.
      [    0.922255] ata_piix 0000:00:01.1: version 2.13
      [    0.924603] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input3
      [    0.925234] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input2
      [    0.925567] scsi host0: ata_piix
      [    0.925658] scsi host1: ata_piix
      [    0.925678] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xe0c0 irq 14
      [    0.925680] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xe0c8 irq 15
      [    0.926307] xhci_hcd 0000:01:1b.0: xHCI Host Controller
      [    0.926313] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus number 2
      [    0.926676] xhci_hcd 0000:01:1b.0: hcc params 0x00087001 hci version 0x100 quirks 0x0000000000000010
      [    0.927489] xhci_hcd 0000:01:1b.0: xHCI Host Controller
      [    0.927492] xhci_hcd 0000:01:1b.0: new USB bus registered, assigned bus number 3
      [    0.927494] xhci_hcd 0000:01:1b.0: Host supports USB 3.0 SuperSpeed
      [    0.927554] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
      [    0.927555] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.927556] usb usb2: Product: xHCI Host Controller
      [    0.927557] usb usb2: Manufacturer: Linux 6.1.0-37-amd64 xhci-hcd
      [    0.927558] usb usb2: SerialNumber: 0000:01:1b.0
      [    0.927638] hub 2-0:1.0: USB hub found
      [    0.927713] hub 2-0:1.0: 15 ports detected
      [    0.928233] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
      [    0.928245] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
      [    0.928246] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    0.928247] usb usb3: Product: xHCI Host Controller
      [    0.928248] usb usb3: Manufacturer: Linux 6.1.0-37-amd64 xhci-hcd
      [    0.928249] usb usb3: SerialNumber: 0000:01:1b.0
      [    0.928294] hub 3-0:1.0: USB hub found
      [    0.928367] hub 3-0:1.0: 15 ports detected
      [    0.931428] scsi host2: Virtio SCSI HBA
      [    0.933111] scsi 2:0:0:0: Direct-Access     QEMU     QEMU HARDDISK    2.5+ PQ: 0 ANSI: 5
      [    1.337285] ata2: found unknown device (class 0)
      [    1.337853] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
      [    1.339187] scsi 1:0:0:0: CD-ROM            QEMU     QEMU DVD-ROM     2.5+ PQ: 0 ANSI: 5
      [    1.396890] usb 1-1: new full-speed USB device number 2 using uhci_hcd
      [    1.397049] sr 1:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
      [    1.397051] cdrom: Uniform CD-ROM driver Revision: 3.20
      [    1.413009] virtio_net virtio2 ens18: renamed from eth0
      [    1.450023] sr 1:0:0:0: Attached scsi CD-ROM sr0
      [    1.464827] usb 2-1: new full-speed USB device number 2 using xhci_hcd
      [    1.498202] sd 2:0:0:0: Power-on or device reset occurred
      [    1.498324] sd 2:0:0:0: [sda] 67108864 512-byte logical blocks: (34.4 GB/32.0 GiB)
      [    1.498361] sd 2:0:0:0: [sda] Write Protect is off
      [    1.498362] sd 2:0:0:0: [sda] Mode Sense: 63 00 00 08
      [    1.498420] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [    1.499351]  sda: sda1 sda2 < sda5 >
      [    1.499487] sd 2:0:0:0: [sda] Attached SCSI disk
      [    1.554082] usb 1-1: not running at top speed; connect to a high speed hub
      [    1.587163] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
      [    1.587175] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
      [    1.587178] usb 1-1: Product: QEMU USB Tablet
      [    1.587181] usb 1-1: Manufacturer: QEMU
      [    1.587184] usb 1-1: SerialNumber: 28754-0000:00:01.2-1
      [    1.595843] hid: raw HID events driver (C) Jiri Kosina
      [    1.601519] usbcore: registered new interface driver usbhid
      [    1.601522] usbhid: USB HID core driver
      [    1.603293] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
      [    1.603359] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
      [    1.643700] usb 2-1: New USB device found, idVendor=051d, idProduct=0002, bcdDevice= 0.90
      [    1.643704] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [    1.643706] usb 2-1: Product: Back-UPS RS 1500G FW:878.L5 .I USB FW:L5
      [    1.643707] usb 2-1: Manufacturer: American Power Conversion
      [    1.643708] usb 2-1: SerialNumber: 3B1815X81867
      [    1.654084] hid-generic 0003:051D:0002.0002: hiddev0,hidraw1: USB HID v1.00 Device [American Power Conversion Back-UPS RS 1500G FW:878.L5 .I USB FW:L5 ] on usb-0000:01:1b.0-1/input0
      [    2.032761] usb 2-2: new full-speed USB device number 3 using xhci_hcd
      [    2.195242] usb 2-2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
      [    2.195253] usb 2-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
      [    2.195256] usb 2-2: Product: USB Serial
      [    2.260371] PM: Image not found (code -22)
      [    2.413310] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [    2.439439] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
      [    2.504376] systemd[1]: Inserted module 'autofs4'
      [    2.521834] systemd[1]: systemd 252.38-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
      [    2.521838] systemd[1]: Detected virtualization kvm.
      [    2.521841] systemd[1]: Detected architecture x86-64.
      [    2.523294] systemd[1]: Hostname set to <iOProduktiv>.
      [    2.556363] systemd-rc-local-generator[224]: /etc/rc.local is not marked executable, skipping.
      [    2.652158] systemd[1]: Queued start job for default target graphical.target.
      [    2.665426] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
      [    2.665655] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
      [    2.665818] systemd[1]: Created slice system-nut\x2ddriver.slice - Slice /system/nut-driver.
      [    2.665932] systemd[1]: Created slice user.slice - User and Session Slice.
      [    2.665972] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
      [    2.665998] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
      [    2.666092] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
      [    2.666106] systemd[1]: Expecting device dev-disk-by\x2duuid-3d21f018\x2ddee7\x2d41bb\x2daa47\x2da4a998bb5b64.device - /dev/disk/by-uuid/3d21f018-dee7-41bb-aa47-a4a998bb5b64...
      [    2.666117] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
      [    2.666131] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
      [    2.666161] systemd[1]: Reached target slices.target - Slice Units.
      [    2.666183] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
      [    2.669278] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
      [    2.669399] systemd[1]: Listening on syslog.socket - Syslog Socket.
      [    2.669461] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
      [    2.669517] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
      [    2.669746] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
      [    2.669817] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
      [    2.669887] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
      [    2.670411] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
      [    2.670476] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
      [    2.671124] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
      [    2.671709] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
      [    2.672539] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
      [    2.673297] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
      [    2.673348] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
      [    2.674465] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
      [    2.675073] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
      [    2.675696] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
      [    2.676299] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
      [    2.676982] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
      [    2.677599] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
      [    2.678703] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
      [    2.679375] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
      [    2.679459] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
      [    2.680584] systemd[1]: Starting systemd-journald.service - Journal Service...
      [    2.682363] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
      [    2.683418] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
      [    2.684381] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
      [    2.685643] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
      [    2.685743] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
      [    2.685804] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
      [    2.685859] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
      [    2.686040] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
      [    2.686266] systemd[1]: modprobe@configfs.service: Deactivated successfully.
      [    2.686350] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
      [    2.687254] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
      [    2.687291] device-mapper: uevent: version 1.0.3
      [    2.687382] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
      [    2.687464] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
      [    2.688316] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
      [    2.688445] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
      [    2.690920] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
      [    2.691904] fuse: init (API version 7.38)
      [    2.692787] systemd[1]: modprobe@fuse.service: Deactivated successfully.
      [    2.692877] loop: module loaded
      [    2.692919] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
      [    2.693604] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
      [    2.693841] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
      [    2.693933] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
      [    2.694111] systemd[1]: modprobe@loop.service: Deactivated successfully.
      [    2.694191] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
      [    2.694280] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
      [    2.695854] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
      [    2.698778] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
      [    2.699483] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
      [    2.702228] EXT4-fs (sda1): re-mounted. Quota mode: none.
      [    2.703453] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
      [    2.703568] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
      [    2.703592] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
      [    2.704145] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
      [    2.704713] systemd[1]: Starting systemd-sysusers.service - Create System Users...
      [    2.708713] ACPI: bus type drm_connector registered
      [    2.709231] systemd[1]: modprobe@drm.service: Deactivated successfully.
      [    2.709342] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
      [    2.714283] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
      [    2.717842] systemd[1]: Finished systemd-sysusers.service - Create System Users.
      [    2.718524] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
      [    2.726981] systemd[1]: Started systemd-journald.service - Journal Service.
      [    2.735563] systemd-journald[248]: Received client request to flush runtime journal.
      [    2.783707] audit: type=1400 audit(1753268523.560:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=288 comm="apparmor_parser"
      [    2.784787] audit: type=1400 audit(1753268523.564:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=289 comm="apparmor_parser"
      [    2.784792] audit: type=1400 audit(1753268523.564:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=289 comm="apparmor_parser"
      [    2.784908] audit: type=1400 audit(1753268523.564:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=291 comm="apparmor_parser"
      [    2.784910] audit: type=1400 audit(1753268523.564:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=291 comm="apparmor_parser"
      [    2.784912] audit: type=1400 audit(1753268523.564:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=291 comm="apparmor_parser"
      [    2.790856] audit: type=1400 audit(1753268523.568:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=290 comm="apparmor_parser"
      [    2.790860] audit: type=1400 audit(1753268523.568:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=290 comm="apparmor_parser"
      [    2.790862] audit: type=1400 audit(1753268523.568:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=290 comm="apparmor_parser"
      [    2.828590] sd 2:0:0:0: Attached scsi generic sg0 type 0
      [    2.829078] sr 1:0:0:0: Attached scsi generic sg1 type 5
      [    2.853976] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
      [    2.868686] ACPI: button: Power Button [PWRF]
      [    2.879929] Free page reporting enabled
      [    2.881164] input: PC Speaker as /devices/platform/pcspkr/input/input6
      [    2.885209] usbcore: registered new interface driver usbserial_generic
      [    2.885218] usbserial: USB Serial support registered for generic
      [    2.887387] powernow_k8: Power state transitions not supported
      [    2.887398] powernow_k8: Power state transitions not supported
      [    2.887407] powernow_k8: Power state transitions not supported
      [    2.887412] powernow_k8: Power state transitions not supported
      [    2.887456] usbcore: registered new interface driver ch341
      [    2.887462] usbserial: USB Serial support registered for ch341-uart
      [    2.888199] ch341 2-2:1.0: ch341-uart converter detected
      [    2.890330] Adding 998396k swap on /dev/sda5.  Priority:-2 extents:1 across:998396k FS
      [    2.904859] usb 2-2: ch341-uart converter now attached to ttyUSB0
      [    2.977136] powernow_k8: Power state transitions not supported
      [    2.977156] powernow_k8: Power state transitions not supported
      [    2.977170] powernow_k8: Power state transitions not supported
      [    2.977179] powernow_k8: Power state transitions not supported
      [    2.981856] bochs-drm 0000:00:02.0: vgaarb: deactivate vga console
      [    2.983970] Console: switching to colour dummy device 80x25
      [    2.984091] [drm] Found bochs VGA, ID 0xb0c5.
      [    2.984092] [drm] Framebuffer size 16384 kB @ 0xfd000000, mmio @ 0xfea50000.
      [    2.985980] [drm] Found EDID data blob.
      [    2.986132] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on minor 0
      [    2.986770] fbcon: bochs-drmdrmfb (fb0) is primary device
      [    3.024982] Console: switching to colour frame buffer device 160x50
      [    3.033550] bochs-drm 0000:00:02.0: [drm] fb0: bochs-drmdrmfb frame buffer device
      [    3.356659] random: crng init done
      [    3.747288] RPC: Registered named UNIX socket transport module.
      [    3.747292] RPC: Registered udp transport module.
      [    3.747292] RPC: Registered tcp transport module.
      [    3.747293] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [   25.263101] FS-Cache: Loaded
      [   25.264345] Key type dns_resolver registered
      [   25.325519] Key type cifs.spnego registered
      [   25.325523] Key type cifs.idmap registered
      [   25.325777] CIFS: Attempting to mount \\192.168.0.98\backups
      [  319.342255] Malformed UNC in devname
      [  319.342286] CIFS: VFS: Malformed UNC in devname
      Leider nein 😞
      OliverIO Thomas Braun 2 Replies Last reply Reply Quote 0
      • OliverIO
        OliverIO @metaxa last edited by
        @metaxa
        Ok muss bei mir mal schauen.
        Gemäß der Doku müsste das in bookworm enthalten sein
        https://manpages.debian.org/bookworm/cifs-utils/mount.cifs.8.en.html
        metaxa 1 Reply Last reply Reply Quote 1
          Thomas Braun Most Active @metaxa last edited by
          @metaxa sagte in Hetzner API, nutzt die jemand von Euch?:
          Schau dir die Freigabe an. Und stell vers=3.0 nach Möglichkeit auf vers=3.1.1 um.
          • metaxa
            metaxa @Thomas Braun last edited by metaxa
            @thomas-braun sagte in Hetzner API, nutzt die jemand von Euch?:
            Ist ja wirklich zu blöd von mir, dass war es. Die Doku von Hetzner ist da meiner Meinung nach falsch/unvollständig. In WIN musste ich ja auch hinten nach "/backup" anhängen.
            Mit Freigabe:
            richtig=
            sudo mount.cifs -o vers=3.0,seal,user=xxx,pass=xxx //xxx.your-storagebox.de/backup /mnt/hetzner
            falsch=
            Nur in der Freigabe von 3.0 auf 3.1.1 ändern?
            Ich versuche mich jetzt an der fstab und dann mit dem automounten.
            Danke @Thomas-Braun !
            • metaxa
              metaxa @OliverIO last edited by
              @oliverio Ganz lieben Dank für deine tolle Unterstützung!
              Mit deiner Rechnung warte noch bitte ein bissi - wie oben geschrieben - versuche ich mich jetzt an der fstab und dem automounten.
              Oder zuvor an deinem Script. >> wird das ein Problem wenn der Mountpunkt mehrere Verzeichnisse hat?
              /mnt/hetzner$ ls
              Ablage  backup  Backup  Outlook  Photo
              • OliverIO
                @metaxa
                Bei der Version würde ich nur 3 angeben.
                Dann wird die höchste mögliche smb3 Version genommen
                sudo mount.cifs -o vers=3,seal,user=xxx,pass=xxx //xxx.your-storagebox.de /mnt/hetzner
                • metaxa
                  metaxa @OliverIO last edited by metaxa
                  @oliverio ich erlaube mir bitte nochmal:
                  dein Script funktioniert natürlich, verursacht aber einen Fehler den ich nicht deuten kann:
                  let path = "/mnt/hetzner"; // hier den Pfad erfassen
                  let cmd = `df --output=source,size,used,avail,pcent,file,target ${path} | tail -n 1`;
                  exec(cmd, function (error, stdout, stderr) {
                      const [source,size,used,avail,pcent,file,target] = stdout.split(/\s+/);
                      console.log(`source ${source}`);
                      console.log(`size ${size}`);
                      console.log(`used ${used}`);
                      console.log(`avail ${avail}`);
                      console.log(`pcent ${pcent}`);
                      console.log(`file ${file}`);
                      console.log(`target ${target}`);
                      setState('0_userdata.0.VIS.IT.speicherbelegung_hetzner',avail);
                  Die Ausgabe im Scriptlog:
                  Die Ausgabe auf de VM:
                  Dateisystem                         Größe Benutzt Verf. Verw% Eingehängt auf
                  //xxx.your-storagebox.de/backup  1,0T    398G  627G   39% /mnt/hetzner
                  Der angelegt DP:
                  Diese unschöne Warnmeldung: Was muß ich ändern?
                  Die unterschiedlichen Werte: Woher der Unterschied?
                  Sonst ist es schon grenzgenial!!!!! Eventuell gehe ich gleich auf Prozente 🙂
                  • OliverIO
                    OliverIO @metaxa last edited by OliverIO
                    @metaxa
                    hm, schade die fehlermeldung nicht richtig ausgegeben wird.
                    Im iobroker log sieht man dann den kompletten Text, allerdings dann wieder ohne skriptbezug und zeilennummer.
                    Die Aufteilung der Ausgabe ergeben strings.
                    Daher muss der Datentyp des Datenpunkts entweder string sein
                    oder man muss den String dann noch in eine Zahl umwandeln, wenn man den Datentyp als number angelegt hat.
                        setState('0_userdata.0.freierSpeicher',parseInt(avail));
                    Zu den abweichenden Werten:
                    Die Ausgabe erfolgt ja in Bytes.
                    Die normale Ausgabe von df formatiert die Werte. Ich gehe mal davon aus, das da dann mit 1kb=1024 bytes gerechnet wird
                    yup, gerade mal mit
                    man df
                    nachgeschaut
                    https://man7.org/linux/man-pages/man1/df.1.html
                       -h, --human-readable
                              print sizes in powers of 1024 (e.g., 1023M)
                    • metaxa
                      @OliverIO
                      Ich bin durch und strahle mit der untergehnden Abendsonne um die Wette 🙂
                      Durch den Richtungsdeut von @Thomas-Braun und vor Allem deiner unermüdlichen Unterstützung konnte ich das Cloud Verzeichnis verschlüsselt einbinden.
                      Danach habe ich mich an dein Script gewagt. Mit deinen Erklärungen (String, Kb und Kbit) und viel Tante Goo... habe ich dein Script für mich verschlimmbessert. Die Werte passen mir jetzt in meinen Überblick. 👌
                      schedule("0 * * * *", async () => {
                              /* console.log(`source ${source}`);
                              console.log(`size ${size}`); //string
                              console.log(`used ${used}`); //string
                              console.log(`avail ${avail}`); //string
                              console.log(`pcent ${pcent}`); //string
                              console.log(`file ${file}`); //string
                              console.log(`target ${target}`);*/
                              // setState('0_userdata.0.VIS.IT.hetzner_storage_box.kapazitaet_gb',parseInt(size) / 1024000); //number GB
                              setState('0_userdata.0.VIS.IT.hetzner_storage_box.kapazitaet_gb',Math.round((size / 1024000)*100)/100,true); //number GB, 2 Kommastellen, ack true
                              // setState('0_userdata.0.VIS.IT.hetzner_storage_box.belegt_gb',parseInt(used) / 1024000); //number GB
                              setState('0_userdata.0.VIS.IT.hetzner_storage_box.belegt_gb',Math.round((used / 1024000)*100)/100,true); //number GB, 2 Kommastellen, ack true
                              // setState('0_userdata.0.VIS.IT.hetzner_storage_box.frei_gb',parseInt(avail) / 1024000); //number GB
                              setState('0_userdata.0.VIS.IT.hetzner_storage_box.frei_gb',Math.round((avail / 1024000)*100)/100,true); //number GB, 2 Kommastellen, ack true
                              setState('0_userdata.0.VIS.IT.hetzner_storage_box.belegt_proz',pcent, true); //string mit unit %, , ack true
                      Danach noch die "fstab" erweitert und die "credentials" lt. Anleitung erstellt, zuvor das Verzeichnis ausgehängt und dann mit
                      systemctl daemon-reload
                      die fstab neu gestartet.
                      BINGO!!!! Alles da!
                      Ich denle, jetzt bist du mich fürs Erste los und ich bedanke mich - zum wiederholten Male - herzlichst für deine überaus wertvolle Unterstützung 👍
                      mxa
                      • OliverIO
                        @metaxa
                        Wunderbar, freut mich
                        Wenn dir die eigentlichen Ausgaben lieber gewesen wäre hättest eigentlich der df komandozeile als zusätzliche Option noch
                        -h
                        Anfügen müssen.
                        Dann hätte er das auch als MB oder GB ausgegeben
                        355
