    5. [gelöst] exec-Baustein will nicht ausführen
    • Meister Mopper
      Meister Mopper @OliverIO last edited by Meister Mopper
      @oliverio
      Es läuft, habe gerade mit dem blockly den Service neu gestartet 😊
      thomas@pihole6:~$ systemctl status pihole-FTL.service
      ● pihole-FTL.service - Pi-hole FTL
           Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; preset: enabled)
           Active: deactivating (stop-sigterm) since Tue 2025-07-22 18:45:45 CEST; 31s ago
          Process: 9946 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
         Main PID: 9960 (pihole-FTL)
            Tasks: 5 (limit: 38112)
           Memory: 32.8M
              CPU: 59min 40.523s
           CGroup: /system.slice/pihole-FTL.service
                   └─9960 /usr/bin/pihole-FTL -f
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.762 CEST [9960M] INFO: Compiled for linux/amd64 (compiled>
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO: Wrote config file:
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 155 total entries
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 141 entries are default
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 14 entries are modified
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.767 CEST [9960M] INFO:  - 0 entries are forced through en>
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: Parsed config file /etc/pihole/pih>
      Jul 22 16:57:46 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: PID file does not exist or not rea>
      Jul 22 16:57:48 pihole6 pihole-FTL[9960]: 2025-07-22 16:57:46.769 CEST [9960M] INFO: No other running FTL process found.
      Jul 22 18:45:45 pihole6 systemd[1]: Stopping pihole-FTL.service - Pi-hole FTL...
      lines 1-21/21 (END)
      Jetzt muss ich das ganze noch in meine Doku einarbeiten und dann schaue ich mir den endpoint an.
      Kall, mei Drobbe!
      Vielen Dank an @oliverio und @Thomas-Braun => Ihr seid PRIMA!!!
      • OliverIO
        du könntest auch mal noch den befehl probieren
        sudo -u iobroker bash
        ssh-copy-id -i ~/.ssh/id_rsa.pub thomas@pihole6
        • OliverIO
          OliverIO @Meister Mopper last edited by OliverIO
          @meister-mopper
          gut du hast nun gelernt wie man per ssh verbindet
          aber hier der einfachere weg, den ich aber erst spät realisiert habe was du willst
          nur mal nebenbei
          du willst doch den dns des piholes neu starten?
          warum nutzt du nicht den endpoint
          /action/restartdns
          mittels diesem befehl im neuen pihole2 adapter?
          https://github.com/oweitman/ioBroker.pi-hole2?tab=readme-ov-file#general-sendto-function
          alternativ sicherlich auch über den blockly sendto baustein
          bin aber nicht so sehr firm in blockly
          Meister Mopper 2 Replies Last reply Reply Quote 0
          • Meister Mopper
            @oliverio sagte in exec-Baustein will nicht ausführen:
            @meister-mopper
            nur mal nebenbei
            /action/restartdns
            Die Wahrheit ist, dass ich Pi-holev6 teste und mehrmals am Tag eine dauerhafte CPU-Überlast habe, die sich mir nicht ergründet.
            Es ist nach htop der pihole-FTL.Service, der sich einfach nicht beruhigen will. Das Problem ist in Foren seit v6 bekannt, eine Lösung gibt es offenbar noch immer nicht.
            Man kann es abfangen, wenn man den Server neu startet oder eben den Service. Da war ich jetzt dran.
            Ich habe zwei Pihole laufen, einen mit der neuen Version und einen mit der v5er.
            Die neue Version ist weniger als unausgereift.
            Ich kann keinen Code schreiben, deshalb bin ich auf Klickibunti angewiesen.
            Vielen Dank!
            • Meister Mopper
              @oliverio sagte in [gelöst] exec-Baustein will nicht ausführen:
              /action/restartdns
              Ich habe versucht, den code für den endpoint zu finden, erhalte aber
              Woran scheitere ich?
              OliverIO Armilar 2 Replies Last reply Reply Quote 0
              • OliverIO
                @meister-mopper
                Oben muss am besten als protocol Version noch http ausgewählt werden
                  crunchip Forum Testing Most Active @Meister Mopper last edited by
                  @meister-mopper sagte in [gelöst] exec-Baustein will nicht ausführen:
                  oder eventuell ne Version zurückgehen, z.b. mit
                  sudo pihole checkout ftl release/v6.1
                  • Armilar
                    Armilar Most Active Forum Testing @Meister Mopper last edited by
                    @meister-mopper
                    Mal ne ganz einfache Frage... Ist der Haken in der Javascript-Instanz gesetzt?
                    • OliverIO
                      OliverIO @Armilar last edited by
                      @armilar
                      Ich gehe davon aus, weil hat ja alles funktioniert.
                      Aktuell ist er dabei die lokale api Seite von pihole aufzurufen um das mal auszuprobieren
                      • Meister Mopper
                        Hat mit deiner Hilfe natürlich funktioniert 😉
                        167
