    4. mihome vacuum - login failed
      dirkhe Developer last edited by
      @thomas-braun bitte noch mal neu von github holen, ich hatte da noch ein bug drin. hatte das ja alles neu geschrieben....
        Thomas Braun Most Active @dirkhe last edited by
        @dirkhe
        Nope. Get devices geht noch nicht.
        2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c68956882748fffffffffffffffffffffffffffffffff
        2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827499ffffffffffffffffffffffffffffffff
        2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:00:02.950  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274a3ffffffffffffffffffffffffffffffff
        2025-07-24 20:00:02.951  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:00:07.909  - debug: mihome-vacuum.0 (1462) discover__{}
        2025-07-24 20:00:12.954  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274adffffffffffffffffffffffffffffffff
        2025-07-24 20:00:12.955  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
        2025-07-24 20:00:22.329  - debug: mihome-vacuum.0 (1462) get params for stock Vacuum
        2025-07-24 20:00:22.330  - debug: mihome-vacuum.0 (1462) Message= {"id":142,"method":"get_status"}
        2025-07-24 20:00:22.339  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":142}
        2025-07-24 20:00:22.340  - debug: mihome-vacuum.0 (1462) setGetStatus {"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
        2025-07-24 20:00:22.342  - debug: mihome-vacuum.0 (1462) Message= {"id":143,"method":"get_network_info"}
        2025-07-24 20:00:22.350  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":"unknown_method","id":143}
        2025-07-24 20:00:22.351  - debug: mihome-vacuum.0 (1462) Message= {"id":144,"method":"get_sound_volume"}
        2025-07-24 20:00:22.361  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[90],"id":144}
        2025-07-24 20:00:24.956  - debug: mihome-vacuum.0 (1462) Helo message Timeout
          dirkhe Developer @Thomas Braun last edited by
          @thomas-braun gib mal bitte die passenden Logzeilen, die sind in dem Auschnitt nicht drin
          Thomas Braun 3 Replies Last reply Reply Quote 0
            @dirkhe
            Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
            2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
            2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
            2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
            2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
            2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
            2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
            2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
            2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
            2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
              @dirkhe
              Ah! Nochmal neugestartet, jetzt funktioniert es!
                @dirkhe
                Hi!
                Die Version aus 'latest' funktioniert nicht:
                2025-07-25 11:52:30.448  - info: mihome-vacuum.0 (59185) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
                2025-07-25 11:53:41.089  - debug: mihome-vacuum.0 (59185) CloudApi-Login gestartet…
                2025-07-25 11:53:41.090  - debug: mihome-vacuum.0 (59185) CloudApi-CloudApi-Step 1: Getting sign token
                2025-07-25 11:53:41.229  - debug: mihome-vacuum.0 (59185) CloudApi-Step 2: Authenticating user
                2025-07-25 11:53:41.327  - error: mihome-vacuum.0 (59185) CloudApi-Login failed, because no captcha resolving possible
                2025-07-25 11:53:41.328  - info: mihome-vacuum.0 (59185) discover Login failed, because no captcha resolving possible
                  @thomas-braun tja, sieht so aus, als wenn jetzt ganz viele Anfragen über diesen Weg gekommen sind, so dass der Server da jetzt die captcha Frage stellt. Ich fürchte, da können wir jetzt nichts machen, zumindest habe ich keine Idee mehr
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @dirkhe last edited by
                    @dirkhe sagte in mihome vacuum - login failed:
                    Danke für die Info.
                    Vielleicht kann ja jemand helfen?
                    @apollon77
                    @mcm1957
                    Ich meine hier schon mal gelesen zu haben, dass jemand captcha im Adapter schon umgesetzt hatte.
                    Weiß aber nicht mehr wo und wer.
                    mfg
                    Dieter
                    • bahnuhr
                      zur Info:
                      @apollon77 hat im issue geantwortet.
                      Anbei:
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                        @bahnuhr sagte in mihome vacuum - login failed:
                        Jetzt weiß ich es wieder.
                        War beim bmw Adapter.
                        Vielleicht geht ja sowas hier auch.
                        login mihome vacuum
                        447
