    4. Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"}
    • h3adbang3r
      h3adbang3r last edited by
      Guten Morgen,
      ich versuche hier eine Adapter (https://www.npmjs.com/package/tplink-smarthome-api) zu installieren, was aber scheitert.
      iobroker	2018-02-02 11:58:12.347	info	exit 25
      iobroker	2018-02-02 11:58:12.327	error	host.ioBroker-Pi Cannot install https://github.com/plasticrake/tplink-smarthome-api/tarball/master: 254
      iobroker	2018-02-02 11:58:12.287	info	npm ERR! /npm-debug.log
      iobroker	2018-02-02 11:58:12.287	info	npm ERR! Please include the following file with any support request:
      iobroker	2018-02-02 11:58:12.085	info	npm ERR! enoent
      iobroker	2018-02-02 11:58:12.085	info	npm ERR! enoent and is related to npm not being able to find a file.
      iobroker	2018-02-02 11:58:12.085	info	npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/tplink-smarthome-api/lib/cli.js'npm ERR! enoent This is most likely not a problem with npm itself
      iobroker	2018-02-02 11:58:12.077	info	npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/tplink-smarthome-api/lib/cli.js'
      iobroker	2018-02-02 11:58:12.076	info
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! syscall chmod
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! errno -2
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! code ENOENT
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! path /opt/iobroker/node_modules/tplink-smarthome-api/lib/cli.js
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! npm v3.10.10
      iobroker	2018-02-02 11:58:12.067	info	npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/plasticrake/tplink-smarthome-api/tarball/master" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3
      iobroker	2018-02-02 11:58:12.063	info	npm ERR! Linux 4.9.59-v7+
      iobroker	2018-02-02 11:58:12.052	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      iobroker	2018-02-02 11:58:12.052	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
      iobroker	2018-02-02 11:58:12.052	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupp
      iobroker	2018-02-02 11:57:11.554	info	npm install https://github.com/plasticrake/tplink-smarthome-api/tarball/master --production --prefix "/opt/iobroker" (System call)
      iobroker	2018-02-02 11:57:11.152	info	install https://github.com/plasticrake/tplink-smarthome-api/tarball/master
      iobroker	2018-02-02 11:57:09.893	info	url "https://github.com/plasticrake/tplink-smarthome-api"
      Besonders auffällig ist, das ich bei jeder Installation dieser Fehler im Log steht:
      Wie bekomme ich dieses Problem in den Griff? Als System läuft: ioBroker Image für Raspberry Pi2/3 Stretch mit piVCCU 20171109 - http://www.iobroker.net/docu/?page_id=7502&lang=de
      • Bluefox
        Bluefox last edited by
        @h3adbang3r:
        Guten Morgen,
        Wie bekomme ich dieses Problem in den Griff? Als System läuft: ioBroker Image für Raspberry Pi2/3 Stretch mit piVCCU 20171109 - http://www.iobroker.net/docu/?page_id=7502&lang=de `
        Was gibst du ein?
        npm i tplink-smarthome-api --production
        • h3adbang3r
          @Bluefox:
          Bisher direkt aus ioBroker heraus mittels: "Installieren aus eigenem URL" und drt gebe ich die URL an. Ich probiere es jetzt aber mal aus der Shell.
          *Edit
          Hier aus der Shell:
          ` > root@ioBroker-Pi:/opt/iobroker# npm i tplink-smarthome-api –production
          iobroker@1.0.0 /opt/iobroker
          └─┬ tplink-smarthome-api@0.22.0
          ├─┬ babel-runtime@6.26.0
          │ ├── core-js@2.5.3
          │ └── regenerator-runtime@0.11.1
          ├── commander@2.13.0
          ├── lodash.defaultto@4.14.0
          ├── lodash.groupby@4.6.0
          ├── lodash.isequal@4.5.0
          ├── loglevel@1.6.1
          └── tplink-smarthome-crypto@1.0.0
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) `
            @h3adbang3r:
            ich versuche hier eine Adapter (https://www.npmjs.com/package/tplink-smarthome-api) zu installieren, was aber scheitert. `
            Das ist IMHO kein Adapter.
            Oder??
            GRuß
            Rainer
              apollon77 last edited by
              Lol, das auch
              • Bluefox
                Das ist definitiv kein Adapter. Ich dachte, dass er eigenen schreiben will.
                • h3adbang3r
                  Ja ich dachte… weil...
                   npm install https://github.com/arteck/ioBroker.hs100/tarball/master/
                  └── iobroker.hs100@0.1.3
                  host.ioBroker-Pi	2018-02-02 15:30:34.634	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
                  Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                  Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                  Caught	2018-02-02 15:30:34.633	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                  Caught	2018-02-02 15:30:34.632	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                  Caught	2018-02-02 15:30:34.632	error	by controller[0]: at Adapter.emit (events.js:185:7)
                  Caught	2018-02-02 15:30:34.632	error	by controller[0]: at emitNone (events.js:86:13)
                  Caught	2018-02-02 15:30:34.632	error	by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:27:5)
                  Caught	2018-02-02 15:30:34.632	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:482:32)
                  Caught	2018-02-02 15:30:34.631	error	by controller[0]: TypeError: Cannot read property 'length' of undefined
                  hs100.0	2018-02-02 15:30:34.608	info	terminating
                  hs100.0	2018-02-02 15:30:34.098	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  hs100.0	2018-02-02 15:30:34.098	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                  hs100.0	2018-02-02 15:30:34.098	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                  hs100.0	2018-02-02 15:30:34.098	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                  hs100.0	2018-02-02 15:30:34.098	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
                  hs100.0	2018-02-02 15:30:34.098	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                  hs100.0	2018-02-02 15:30:34.098	error	at Adapter.emit (events.js:185:7)
                  hs100.0	2018-02-02 15:30:34.098	error	at emitNone (events.js:86:13)
                  hs100.0	2018-02-02 15:30:34.098	error	at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:27:5)
                  hs100.0	2018-02-02 15:30:34.098	error	at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:482:32)
                  hs100.0	2018-02-02 15:30:34.098	error	TypeError: Cannot read property 'length' of undefined
                  hs100.0	2018-02-02 15:30:34.095	error	uncaught exception: Cannot read property 'length' of undefined
                  hs100.0	2018-02-02 15:30:34.050	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.hs100, node: v6.12.3
                  iobroker	2018-02-02 15:30:31.707	info	exit 0
                  iobroker	2018-02-02 15:30:31.697	info	host.ioBroker-Pi object system.adapter.hs100.0 created
                  host.ioBroker-Pi	2018-02-02 15:30:31.673	info	instance system.adapter.hs100.0 started with pid 23970
                  host.ioBroker-Pi	2018-02-02 15:30:31.640	info	object change system.adapter.hs100.0
                  iobroker	2018-02-02 15:30:31.593	info	host.ioBroker-Pi object system.adapter.hs100.0.alive created
                  iobroker	2018-02-02 15:30:31.550	info	host.ioBroker-Pi object system.adapter.hs100.0.connected created
                  iobroker	2018-02-02 15:30:31.513	info	host.ioBroker-Pi object system.adapter.hs100.0.memHeapUsed created
                  iobroker	2018-02-02 15:30:31.470	info	host.ioBroker-Pi object system.adapter.hs100.0.memHeapTotal created
                  iobroker	2018-02-02 15:30:31.417	info	host.ioBroker-Pi object system.adapter.hs100.0.memRss created
                  iobroker	2018-02-02 15:30:31.369	info	host.ioBroker-Pi object system.adapter.hs100.0.uptime created
                  iobroker	2018-02-02 15:30:31.330	info	host.ioBroker-Pi object system.adapter.hs100.0.inputCount created
                  iobroker	2018-02-02 15:30:31.291	info	host.ioBroker-Pi object system.adapter.hs100.0.outputCount created
                  iobroker	2018-02-02 15:30:31.269	info	host.ioBroker-Pi create instance hs100
                  admin.0	2018-02-02 15:30:31.193	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
                  iobroker	2018-02-02 15:30:31.211	info	host.ioBroker-Pi object undefined created
                  javascript.0	2018-02-02 15:30:31.203	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
                  history.0	2018-02-02 15:30:31.198	error	change ID is empty: {"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.host.ioBroker-Pi.cli","ts":1517585431181}
                  iobroker	2018-02-02 15:30:31.177	info	host.ioBroker-Pi object system.adapter.hs100 created
                  iobroker	2018-02-02 15:30:31.009	info	upload [0] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/hs100.png hs100.png image/png
                  iobroker	2018-02-02 15:30:30.894	info	upload [1] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/index.html index.html text/html
                  iobroker	2018-02-02 15:30:30.785	info	upload [2] hs100.admin /opt/iobroker/node_modules/iobroker.hs100/admin/words.js words.js application/javascript
                  iobroker	2018-02-02 15:30:30.747	info	got /opt/iobroker/node_modules/iobroker.hs100/admin
                  iobroker	2018-02-02 15:30:27.278	info	npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.hs100"
                  iobroker	2018-02-02 15:30:27.274	info	host.ioBroker-Pi install adapter hs100
                  iobroker	2018-02-02 15:30:25.438	info	add hs100
                  host.ioBroker-Pi	2018-02-02 15:30:17.022	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                  iobroker	2018-02-02 15:30:16.558	info	exit 0
                  iobroker	2018-02-02 15:30:16.420	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  iobroker	2018-02-02 15:30:16.420	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                  iobroker	2018-02-02 15:30:16.420	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupport
                  iobroker	2018-02-02 15:30:16.417	info	npm
                  iobroker	2018-02-02 15:29:05.614	info	npm install https://github.com/arteck/ioBroker.hs100/tarball/master --production --prefix "/opt/iobroker" (System call)
                  iobroker	2018-02-02 15:29:05.206	info	install https://github.com/arteck/ioBroker.hs100/tarball/master
                  iobroker	2018-02-02 15:29:03.972	info	url "https://github.com/arteck/ioBroker.hs100.git"
                  Wenn ich dann ein Gerät hinzufüge, überschlagen sich die Fehlermeldung, das ioBroker mit dem Anzeigen nicht mehr folgen kann.
                  Alles beginnt mit einem
                  *** "Dose nicht erreichbar: 172.26.63.111
                  das scrollt im hunderstel Sekundentakt durch bis es in einem
                  host.ioBroker-Pi	2018-02-02 15:36:52.969	info	instance system.adapter.hs100.0 terminated with code 0 (OK)
                  Caught	2018-02-02 15:36:52.969	error	by controller[1849]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3409): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.969	error	by controller[1849]: [PC Junior] device.send() Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.969	error	by controller[1849]: TCP Timeout
                  Caught	2018-02-02 15:36:52.969	error	by controller[1849]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3408): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.969	error	by controller[1848]: [PC Junior] device.send() Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1848]: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1848]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3407): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1848]: [PC Junior] device.send() Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1847]: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3406): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1846]: TCP Timeout
                  Caught	2018-02-02 15:36:52.968	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3405): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.967	error	by controller[1846]: TCP Timeout
                  Caught	2018-02-02 15:36:52.967	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3404): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.967	error	by controller[1846]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3403): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.967	error	by controller[1845]: TCP Timeout
                  Caught	2018-02-02 15:36:52.967	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3402): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.966	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3401): Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.966	error	by controller[1845]: [PC Junior] device.send() Error: TCP Timeout
                  Caught	2018-02-02 15:36:52.966	error	by controller[1845]: TCP Timeout
                  Caught	2018-02-02 15:36:52.966	error	by controller[1845]: (node:24413) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3400): Error: TCP Timeout
                  und dem pausieren des Adapter endet. Dieses Theater habe ich, seit ich auf das Image gewechselt habe. Vorher liefen die 3 TP-Link problemlos.
                    Du hast irgendein npm-package, das überhaupt nichts mit ioBroker zu tun hat versucht mit in ioBroker einzubinden.
                    Dass das nicht gut geht ist doch klar.
                    Rainer
                    • h3adbang3r
                      @Homoran:
                      Rainer ` Diese Fehlermeldung habe ich seit dem allererstem Start. Das hat mit meinem Fehler nichts zutun, wenn er mich auch mächtig ärgert.
                      • h3adbang3r
                        Das hatte ich am 30.01.2018, gleich nach dem erstem Start von ioBroker als ich Discovery updaten wollte.
                        https://www.facebook.com/groups/4404991 … 475053193/
                        https://www.facebook.com/groups/4404991 … 698343504/
                        Es hat also rein garnichts mit meinem Fehler zu tun. Dieser entstand deshalb weil ich hier gesucht habe um meine Steckdosen wieder verwenden zu können und ich zu dumm war alle 10 Seiten des Beitrages zur tplink-smarthome-api zu lesen. So habe ich nur die ersten 2 - 3 Seiten überflogen und dann versucht zu installieren. Von Erfolg gekrönt war das, wie man oben sieht zwar nicht, aber es ist auf keinen Fall die Ursache meines Problemes.
                          Mit den Facebook-Links kann ich nichts anfangen 😞
                          Gib mir bitte die Versionen von:
                          • js-controller
                          • admin
                          • nodejs
                          • npm
                          Rainer
                          • h3adbang3r
                            huhu
                            @Homoran:
                            • js-controller ` root@ioBroker-Pi:/home/pi# iobroker -v
                            1.2.3
                            @Homoran:
                            • admin ` ioBroker admin
                            2.0.9
                            @Homoran:
                            • nodejs ` root@ioBroker-Pi:/home/pi# node -v
                            v6.12.3
                            @Homoran:
                            • npm ` root@ioBroker-Pi:/home/pi# npm -v
                            3.10.10
                            @Homoran:
                            Rainer ` Ich danke 😉
                            Gruß Sven
                              Die Versionen passen.
                              Irgendwas übersehe ich. 😞
                              Wanted arch = any und trotzdem sagt er not supported bei arch = arm
                              Aber egal; es handelt sich nur um Optional Dependencies, also nichts notwendiges.
                              Rainer
                              • h3adbang3r
                                Es scheint als gebe es weitere mit einem Problem mit dem HS-100 Adapter.
                                https://www.facebook.com/groups/4404991 … 081562299/
                                • h3adbang3r
                                  Ich habe mein Problem erstmal damit gelöst den Wert "Abfrage Intervall[ms]" auf "20000" zu setzen. Damit kommt es nicht mehr zu den TCP Fehlern. Möglicherweise wollen die Steckdosen nicht so häufig antworten oder sind dafür auch nicht ausgelegt.
                                  2039
