    4. Fehler Backitup Grafana
    • simatec
      simatec Developer Most Active @minkhx last edited by
      @minkhx Richte das erstmal ein und dann setze den Hacken in Backitup. Du sicherst gerade ein System, das nicht vorhanden ist
      M S 3 Replies Last reply Reply Quote 0
        minkhx @simatec last edited by
        @simatec Ok, ich hatte am Anfang Influx als input gesetzt, aber noch keine Dashes angelegt. Ich versuch das mal. Mal sehen, was in influx so Verwertbares enthält.
          @simatec
          Hier der log mit ioB, flux, Grafana:
          23:10:26.402
          INFO
          gui
          Backup gestartet ...
          23:10:34.540
          DEBUG
          iobroker
          host.flowbox 193 objects saved
          23:10:34.623
          DEBUG
          iobroker
          host.flowbox 140 states saved
          23:10:34.688
          DEBUG
          iobroker
          host.flowbox Validating backup ...
          host.flowbox "config.json" is valid
          23:10:34.692
          DEBUG
          iobroker
          host.flowbox "objects.jsonl" exists
          host.flowbox "states.jsonl" exists
          23:10:35.634
          DEBUG
          iobroker
          host.flowbox The backup is valid!
          23:10:37.256
          DEBUG
          iobroker
          Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_10_28_backupiobroker.tar.gz
          23:10:37.257
          DEBUG
          iobroker
          This backup can only be restored with js-controller version 7.0 or higher
          23:10:38.296
          DEBUG
          iobroker
          done
          23:10:38.465
          DEBUG
          influxDB
          InfluxDB-Backup started ...
          23:10:38.479
          DEBUG
          influxDB
          InfluxDB Backup tmp directory created
          23:10:38.575
          DEBUG
          influxDB
          Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker.tar.gz
          23:10:38.590
          DEBUG
          influxDB
          Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker"
          23:10:38.604
          DEBUG
          influxDB
          InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker" successfully deleted
          23:10:38.641
          DEBUG
          influxDB
          InfluxDB-Backup for is finish
          23:10:38.643
          DEBUG
          influxDB
          done
          23:10:39.888
          DEBUG
          grafana
          Start Grafana Backup ...
          23:10:39.902
          DEBUG
          grafana
          Created dashboard directory
          23:10:39.932
          DEBUG
          grafana
          Created folder directory
          23:10:39.949
          DEBUG
          grafana
          Created datasource directory
          23:10:40.011
          DEBUG
          grafana
          start Grafana request ...
          23:10:40.026
          DEBUG
          grafana
          Grafana is available ... Status: 200
          23:10:40.662
          DEBUG
          grafana
          found Dashboard: tst-dashboard-gauge
          23:10:40.978
          DEBUG
          grafana
          Saved dashboard-folder mapping
          23:10:41.178
          DEBUG
          grafana
          start Grafana backup compress ...
          23:10:46.208
          DEBUG
          grafana
          Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_10_41_backupiobroker.tar.gz
          23:10:46.223
          DEBUG
          grafana
          Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
          23:10:46.265
          DEBUG
          grafana
          done
          23:10:48.183
          WARN
          clean
          No older backup files are deleted, because this backup was started manually
          23:10:48.224
          DEBUG
          clean
          done
          23:10:48.353
          DEBUG
          historyHTML
          new history html values created
          23:10:48.452
          DEBUG
          historyHTML
          done
          23:10:48.640
          DEBUG
          historyJSON
          new history json values created
          23:10:48.681
          DEBUG
          historyJSON
          done
          23:10:51.151
          DEBUG
          notification
          done
          23:10:51.315
          INFO
          gui
          Das Backup wurde erfolgreich erstellt!
          Zusätzlich noch Node-Red:
          23:11:50.291
          INFO
          gui
          23:11:58.680
          DEBUG
          iobroker
          23:11:58.775
          DEBUG
          iobroker
          host.flowbox 141 states saved
          23:11:58.787
          DEBUG
          iobroker
          23:11:59.757
          DEBUG
          iobroker
          host.flowbox JSONL lines are valid
          23:11:59.767
          DEBUG
          iobroker
          23:12:01.472
          DEBUG
          iobroker
          Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_11_52_backupiobroker.tar.gz
          23:12:01.474
          DEBUG
          iobroker
          23:12:02.514
          DEBUG
          iobroker
          done
          23:12:02.681
          DEBUG
          influxDB
          23:12:02.683
          DEBUG
          influxDB
          Start InfluxDB Backup ...
          23:12:02.725
          DEBUG
          influxDB
          23:12:02.845
          DEBUG
          influxDB
          Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker.tar.gz
          23:12:02.865
          DEBUG
          influxDB
          Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker"
          23:12:02.869
          DEBUG
          influxDB
          InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker" successfully deleted
          23:12:02.874
          DEBUG
          influxDB
          23:12:02.912
          DEBUG
          influxDB
          done
          23:12:04.180
          DEBUG
          grafana
          23:12:04.186
          DEBUG
          grafana
          Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
          23:12:04.193
          DEBUG
          grafana
          23:12:04.214
          DEBUG
          grafana
          23:12:04.227
          DEBUG
          grafana
          Created dashboards_manually_restore directory
          23:12:04.234
          DEBUG
          grafana
          23:12:04.332
          DEBUG
          grafana
          23:12:04.346
          DEBUG
          grafana
          23:12:05.041
          DEBUG
          grafana
          23:12:05.355
          DEBUG
          grafana
          23:12:05.529
          DEBUG
          grafana
          23:12:10.600
          DEBUG
          grafana
          Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_12_06_backupiobroker.tar.gz
          23:12:10.605
          DEBUG
          grafana
          Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
          23:12:10.622
          DEBUG
          grafana
          23:12:10.661
          DEBUG
          grafana
          done
          23:12:11.383
          DEBUG
          nodered
          Created nodered tmp directory
          23:12:11.401
          DEBUG
          nodered
          Node-Red tmp copy finish
          23:12:11.427
          DEBUG
          nodered
          Backup created: /opt/iobroker/backups/nodered.0_2025_05_23-23_12_12_backupiobroker.tar.gz
          23:12:11.438
          DEBUG
          nodered
          Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
          23:12:11.441
          DEBUG
          nodered
          node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
          23:12:11.494
          DEBUG
          nodered
          done
          23:12:12.652
          WARN
          clean
          23:12:12.693
          DEBUG
          clean
          done
          23:12:12.824
          DEBUG
          historyHTML
          23:12:12.923
          DEBUG
          historyHTML
          done
          23:12:13.131
          DEBUG
          historyJSON
          23:12:13.171
          DEBUG
          historyJSON
          done
          23:12:15.641
          DEBUG
          notification
          done
          23:12:15.791
          INFO
          gui
          Das funzt auch mit DNS statt IP.
          Oh, srry, mein Fehler. Ich hab da iwie die Fehlermeldung ganz anders interpretiert...
          Das Dash ist zwar leer bzw. visualisiert "keine Daten", aber das reicht scheinbar erstmal.
          Backitup ist durchdacht und zweckmäßig, brauche ich:) Ich lass euch was cash rüberwachsen.
            SabineT @simatec last edited by
            @simatec es wäre praktisch, wenn es für das "Grafana Backup" auch so einen Knopf "JETZT SICHERN" geben würde, wie bei ioBroker oder Homematic. Gerade wenn man testen will, ob das Backup funktioniert.
            • simatec
              simatec Developer Most Active @SabineT last edited by
              @sabinet das ist nicht geplant. Backups wie Grafana, zigbee und Co sind zusätzliche Backup Optionen zum ioBroker Backup
                saeft_2003 Most Active @simatec last edited by
                @simatec
                Hi. Mit der 3.3.5 funktioniert das grafana backup nicht mehr. Es fehlt die Möglichkeit den Benutzernamen und das Passwort einzugeben. Nach einem downgrad auf 3.2.2 funktioniert wieder alles wie gewohnt.
                Ist der Fehler bekannt?
                • simatec
                  simatec Developer Most Active @saeft_2003 last edited by
                  @saeft_2003 Benutzername und Passwort werden nicht mehr benötigt... Der Token übernimmt alles
                    @simatec
                    Geht aber nicht bei mir. Langt ein normaler viewer token?
                    • simatec
                      @saeft_2003 nein immer ein Admin Token. Steht auch so in der Doku
                      S 1 Reply Last reply Reply Quote 2
                        @simatec
                        Ok danke bis jetzt hatte es mit dem viewer token funktioniert. Ich probiere jetzt den admin…
                        6434
