    4. JavaScript
    5. E3DC Hauskraftwerk steuern
      psrelax @ArnoD last edited by
      @arnod sagte in E3DC Hauskraftwerk steuern:
      Hast du da ein LOG File oder kannst du Debug Log beim CC Skript einschalten und das mal mir schicken?
      Will nur sicher sein das, dass die Ursache ist.
      Meinst du wegen der Entladesperre?
      Wenn ja, hier bitte:
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 00:59:54.493  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 00:59:54.494  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 00:59:54.536  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 00:59:54.538  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 00:59:54.539  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 00:59:54.540  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 00:59:54.541  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 00:59:54.542  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 00:59:54.543  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 00:59:54.544  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 00:59:54.545  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 00:59:54.547  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 00:59:54.590  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 675W
      2025-07-07 00:59:54.591  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -669 W
      2025-07-07 00:59:54.593  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 00:59:54.593  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 00:59:54.635  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 00:59:54.677  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 00:59:54.677  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,7,10,
      2025-07-07 01:00:00.007  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: Zeitplan ausgeführt Anfang
      2025-07-07 01:00:00.010  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: 12391
      2025-07-07 01:00:00.010  - warn: javascript.0 (196) script.js.PV_Max_Watt.pv_max_watt_schreiben: Zeitplan ausgeführt Ende
      2025-07-07 01:00:00.033  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: -==== ?? Tibber output signal BatterieEntladesperre wurde in true geändert ====-
      2025-07-07 01:00:00.035  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: State 0_userdata.0.TibberSkript.OutputSignal.BatterieEntladesperre wurde durch Timer um 01:00:00 auf true gesetzt.
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = ["2025-07-07T00:00:00.000Z","2025-07-07T04:00:00.000Z"]
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = [true,false]
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = ["Entladesperre","Entladesperre"]
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.2233
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 44
      2025-07-07 01:00:00.382  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = -675
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = -5
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 2
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 5:60 h
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.2908
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3459
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 7.7.2025, 13:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 10:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = high
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 10:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 06:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 06:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 7.7.2025, 00:00:00
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = high
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.3068
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.27
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
      2025-07-07 01:00:00.383  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = true
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = true
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Batterie sperre von 02:00 Uhr bis 06:00 Uhr um Peakphase zu überbrücken (aktive Phase: high)
      2025-07-07 01:00:00.384  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,11,11/3,11/4,31,29,29/3,29,29/3,
      2025-07-07 01:00:00.384  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.17 *******************
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:03.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:03.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:03.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:03.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:03.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:03.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:03.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:03.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:03.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:03.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:03.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:03.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:03.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:03.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:03.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 681W
      2025-07-07 01:00:03.166  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = -675 W
      2025-07-07 01:00:03.179  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:03.180  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:03.237  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:03.349  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:03.349  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:12.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:12.046  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:12.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:12.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:12.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:12.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:12.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:12.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:12.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:12.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:12.103  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:12.104  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:12.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:12.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:12.148  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 386W
      2025-07-07 01:00:12.152  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:12.159  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:12.159  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:12.200  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:12.242  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:12.242  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:18.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:18.087  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:18.089  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:18.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:18.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:18.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:18.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:18.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:18.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:18.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:18.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:18.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:18.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:18.156  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 459W
      2025-07-07 01:00:18.160  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:18.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:18.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:18.205  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:18.247  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:18.247  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:24.506  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:24.507  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:24.551  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:24.553  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:24.554  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:24.555  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:24.557  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:24.558  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:24.559  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:24.560  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:24.561  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:24.562  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:24.563  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:24.563  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:24.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 405W
      2025-07-07 01:00:24.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:24.609  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:24.609  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:24.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:24.692  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:24.692  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:33.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:33.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:33.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:33.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:33.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:33.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:33.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:33.095  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:33.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:33.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:33.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:33.101  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:33.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:33.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:33.154  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 1137W
      2025-07-07 01:00:33.162  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:33.176  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:33.177  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:33.238  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:33.239  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:33.351  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:33.351  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:39.044  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:39.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:39.045  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:39.088  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:39.090  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:39.091  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:39.092  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:39.093  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:39.094  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:39.096  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:39.097  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:39.098  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:39.099  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:39.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:39.100  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:39.142  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 542W
      2025-07-07 01:00:39.143  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:39.145  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:39.145  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:39.186  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:39.228  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:39.228  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:39.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:39.229  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:39.229  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
      2025-07-07 01:00:45.005  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:45.006  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:45.049  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:45.050  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:45.052  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:45.053  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:45.054  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:45.055  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:45.056  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:45.057  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:45.058  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:45.060  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:45.102  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 539W
      2025-07-07 01:00:45.104  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:45.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:45.105  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:45.146  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:45.188  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:45.189  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,41,
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 88
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 5
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
      2025-07-07 01:00:54.605  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =3
      2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:21
      2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:21
      2025-07-07 01:00:54.606  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 15:20
      2025-07-07 01:00:54.649  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
      2025-07-07 01:00:54.650  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
      2025-07-07 01:00:54.652  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
      2025-07-07 01:00:54.653  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
      2025-07-07 01:00:54.654  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
      2025-07-07 01:00:54.656  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
      2025-07-07 01:00:54.657  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
      2025-07-07 01:00:54.659  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
      2025-07-07 01:00:54.661  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 1
      2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 1
      2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Montag: 944 Wh
      2025-07-07 01:00:54.662  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 944 Wh
      2025-07-07 01:00:54.705  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 887W
      2025-07-07 01:00:54.706  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 0 W
      2025-07-07 01:00:54.708  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 0 W
      2025-07-07 01:00:54.708  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
      2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 44 %
      2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 1 %
      2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
      2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
      2025-07-07 01:00:54.749  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
      2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
      2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
      2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 9000
      2025-07-07 01:00:54.795  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 0
      2025-07-07 01:00:54.795  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,6,4,37,
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = ["2025-07-06T23:00:00.000Z","2025-07-07T04:00:00.000Z"]
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerState = [true,false]
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = ["Entladesperre","Entladesperre"]
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.2233
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
      2025-07-07 01:01:00.282  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 44
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = 0
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = 461
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 2
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 5:33 h
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1057
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1201
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.2908
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.3459
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = 7.7.2025, 13:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = 7.7.2025, 10:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = high
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 7.7.2025, 10:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 7.7.2025, 06:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 7.7.2025, 06:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 7.7.2025, 00:00:00
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = high
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.3068
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.27
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
      2025-07-07 01:01:00.283  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 44.31 kWh
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 32.54 kWh
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = false
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = false
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = false
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = true
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = true
      2025-07-07 01:01:00.284  - info: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** Status = Batterie sperre von 01:00 Uhr bis 06:00 Uhr um Peakphase zu überbrücken (aktive Phase: high)
      2025-07-07 01:01:00.284  - warn: javascript.0 (196) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/4,19,22,32,11,11/3,11/4,31,29,29/3,29,29/3,
        psrelax @psrelax last edited by
        @ArnoD
        War heut wieder der Fall.
        Genügen dir die Logs einen Post drüber?
          ArnoD @psrelax last edited by
          @psrelax
          Ja das genügt.
          Letzten Montag hast du abends im Schnitt mehr Strom verbraucht (300 Watt mehr) als diesen Montag. Deshalb ist die Batterie-Reichweiten-Prognose aktuell nicht richtig.
          Das Skript geht davon aus, dass dein Verbrauch nächsten Montagabend ähnlich ist wie heute – also 300 Watt niedriger als letzte Woche.
          Wenn du nun einen festen Wert (Offset) zur Korrektur nutzt, wird die Schätzung nächste Woche zu niedrig sein.
          Ein fester Offset funktioniert also nicht gut, weil du ihn ständig anpassen müsstest – je nachdem, ob der Verbrauch letzte Woche höher oder niedriger war.
          Die Möglichkeit diese Berechnung zu beeinflussen hättest du bereits jetzt, indem du einfach deine Batteriekapazität vergrößerst.
          Das kannst du z.B. mit der Objekt-ID
          0_userdata.0.Charge_Control.USER_ANPASSUNGEN.10_maxEntladetiefeBatterie
          indem du hier 100 einträgst.
          oder mit der Objekt-ID
          0_userdata.0.Charge_Control.USER_ANPASSUNGEN.10_Systemwirkungsgrad
            @arnod
            0_userdata.0.Charge_Control.USER_ANPASSUNGEN.10_maxEntladetiefeBatterie war bereits auf 100%.
            0_userdata.0.Charge_Control.USER_ANPASSUNGEN.10_Systemwirkungsgrad werde ich einmal probieren. Der steht aktuell auf 88%.
            Kann man die Berechnung nicht in 2 Teile teilen?
            Teil 1 abends bis 00:00 Uhr und Teil 2 nachts 00:00 Uhr bis 06:00 Uhr
            Mein Verbrauch variiert abends, hingegen nachts ist er immer ziemlich gleich. Dies sollte bei den meisten Leuten so sein, die nachts schlafen.
            Hierdurch würde die restliche Reichweite ab Mitternacht neu mit dem Teil 2 berechnet werden, der eigentlich jeden Tag fast identisch sein sollte.
            Dies würde das Nachladen in der Nacht aufgrund der ausreichend berechneten Reichweite unterbinden, bzw. die Reichweite als noch ausreichend beurteilen.
              @psrelax
              Es ist bereits in zwei Abschnitte aufgeteilt.
              Abend 21:00 Uhr bis 05:00 Uhr des nächsten Tages oder Tag 05:00 Uhr bis 21:00 Uhr.
                @arnod
                Dann ists schon komisch, wie ChargeControl auf den höheren Verbrauch kommt. 😢
                Naja, ich hab jetzt mal den Systemwirkungsgrad auf 100 gesetzt. Mal schaun was das bringt.
                  Neue Version Charge-Control auf GitHub hochgeladen.
                  Version: 1.6.2
                  Änderungen:
                  • Kleinere Optimierungen am Code und an der Laderegelung durchgeführt.
                    MaLei @ArnoD last edited by
                    @arnod
                    Ich bekomme folgende Fehler
                    javascript.0	22:07:49.591	error
                    SyntaxError: Unexpected non-whitespace character after JSON at position 1
                        at script.js.common.E3DC.Charge_Control:187:23
                        at ScriptStart (script.js.common.E3DC.Charge_Control:187:9)
                      ArnoD @MaLei last edited by
                      @malei
                      Welche Version vom Script hattest du vorher?
                      Der Fehler tritt auf, wenn versucht wird, einen ungültigen JSON-String mit JSON.parse() zu parsen.
                      Hast du die Schritte beim Wechsel auf Version 1.6.1 berücksichtigt:
                      Es wurde der Datentyp der folgenden Objekt-IDs von array auf string geändert:
                      0_userdata.0.Charge_Control.History.PrognoseAuto_kWh
                      0_userdata.0.Charge_Control.History.PrognoseProp_kWh
                      0_userdata.0.Charge_Control.History.PrognoseSolcast90_kWh
                      0_userdata.0.Charge_Control.History.PrognoseSolcast_kWh
                      0_userdata.0.Charge_Control.History.istPV_LeistungTag_kWh
                      Vorgehensweise zur Anpassung
                      Es gibt zwei Möglichkeiten, diese Änderung durchzuführen:
                      Objekt-IDs löschen und automatisch neu erstellen lassen:
                      • Dabei gehen jedoch alle bisherigen Werte verloren.
                      Objekt-IDs manuell ändern:
                      Typ der fünf Objekt-IDs auf String setzen
                      Bei den Werten jeweils eine eckige Klammer am Anfang und Ende ergänzen, z. B.:
                          [10, 34, 19]
                        @arnod
                        Ich kam von der 1.5.23, auf die ich auch wieder zurückgewechselt bin.
                          @ArnoD
                          So wie es aussieht, wird ChargeControl immer noch deaktiviert, sobald EVCC das Auto per PV lädt.
                          Nach der Deaktivierung des PV-Ladens, hat ChargeControl wieder angefangen Logs zu produzieren. Vorher kamen nur Logs vom Tibber Script.
                          azzkikrboy A 2 Replies Last reply Reply Quote 0
                          • azzkikrboy
                            azzkikrboy @psrelax last edited by
                            @ArnoD
                            ich bekomme auch syntax error wenn ich von 1.5.23 auf 1.6.2 springen will:
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at process.processImmediate (node:internal/timers:487:21)
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
                            javascript.0
                            	2025-08-05 17:40:09.493	error	at new Script (node:vm:117:7)
                            javascript.0
                            	2025-08-05 17:40:09.493	error	SyntaxError: Identifier 'LogparserSyntax' has already been declared
                            javascript.0
                            	2025-08-05 17:40:09.493	error	^
                            javascript.0
                            	2025-08-05 17:40:09.493	error	const LogparserSyntax = true // Wenn true wird die LOG Ausgabe an Adapter Logparser angepasst
                            javascript.0
                            	2025-08-05 17:40:09.492	error	script.js.ChargeControl_1_6_2 compile failed: at script.js.ChargeControl_1_6_2:2825
                            • azzkikrboy
                              azzkikrboy @azzkikrboy last edited by
                              beim zweiten Versuch kommt das ...
                              javascript.0
                              	2025-08-05 17:48:49.972	error	script.js.ChargeControl_1_6_2: SyntaxError: Unexpected non-whitespace character after JSON at position 1 (line 1 column 2)
                              ist das ein Problem mit dem copy-paste aus Github ?? 😕
                                @psrelax
                                Kannst du mir die LOG Einträge schicken, wo du evcc auf PV umgestellt hast?
                                CC wird nur noch deaktiviert, wenn evcc.0.loadpoint.1.status.mode nicht PV ist und evcc.0.loadpoint.1.status.charging = true ist.
                                  ArnoD @azzkikrboy last edited by ArnoD
                                  @azzkikrboy
                                  Bitte auch so vorgehen wie weiter oben beschrieben und die Objekt ID's löschen oder manuell ändern.
                                  SyntaxError: Identifier 'LogparserSyntax' has already been declared ist ein anderes Problem.
                                  Das deutet eher auf ein nicht sauber beendetes Script hin. Sollte bei einem Neustart dann aber nicht mehr kommen.
                                  azzkikrboy 1 Reply Last reply Reply Quote 0
                                    psrelax @ArnoD last edited by
                                    @arnod sagte in E3DC Hauskraftwerk steuern:
                                    Hier bitte. Gibt hald von vorher nur die Logs von Tibber.
                                    2025-08-05 10:34:02.174  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.18 *******************
                                    2025-08-05 10:35:00.259  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
                                    2025-08-05 10:35:00.259  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = []
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerState = []
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = []
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.1489
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 84
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = 4311
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = -125
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 1
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 9:49 h
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.157
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1784
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.1628
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.2143
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = undefined
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = undefined
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = undefined
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 6.8.2025, 00:00:00
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 5.8.2025, 19:00:00
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 5.8.2025, 19:00:00
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 5.8.2025, 09:00:00
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = normal
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.2159
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.19
                                    2025-08-05 10:35:00.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 57.87 kWh
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 64.38 kWh
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = true
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = true
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = true
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = false
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = false
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Status = PV Prognose hoch,es wird bei Sonnenaufgang mit PV Leistung geladen (aktive Phase: normal)
                                    2025-08-05 10:35:00.261  - warn: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/2,19,21,2,30,31,
                                    2025-08-05 10:35:00.261  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.18 *******************
                                    2025-08-05 10:35:18.641  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"?? evcc Änderung: mode (LP1) ? off"}##
                                    2025-08-05 10:35:48.426  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ##{"from":"Charge-Control", "message":"?? evcc Änderung: charging (LP1) ? false"}##
                                    2025-08-05 10:35:51.044  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                    2025-08-05 10:35:51.044  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                    2025-08-05 10:35:51.044  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                    2025-08-05 10:35:51.044  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                    2025-08-05 10:35:51.044  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 100
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 0
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =4
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                                    2025-08-05 10:35:51.045  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 14:49
                                    2025-08-05 10:35:51.090  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                    2025-08-05 10:35:51.092  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                    2025-08-05 10:35:51.093  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                    2025-08-05 10:35:51.095  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                    2025-08-05 10:35:51.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                    2025-08-05 10:35:51.097  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                    2025-08-05 10:35:51.098  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                    2025-08-05 10:35:51.099  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                    2025-08-05 10:35:51.100  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 2
                                    2025-08-05 10:35:51.101  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 2
                                    2025-08-05 10:35:51.102  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Dienstag: 1338 Wh
                                    2025-08-05 10:35:51.102  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 1338 Wh
                                    2025-08-05 10:35:51.267  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 2134W
                                    2025-08-05 10:35:51.269  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 7794 W
                                    2025-08-05 10:35:51.315  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 11136 W
                                    2025-08-05 10:35:51.316  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                    2025-08-05 10:35:51.358  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 85 %
                                    2025-08-05 10:35:51.358  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 2 %
                                    2025-08-05 10:35:51.358  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                    2025-08-05 10:35:51.359  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                    2025-08-05 10:35:51.359  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                    2025-08-05 10:35:51.400  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                    2025-08-05 10:35:51.401  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                    2025-08-05 10:35:51.401  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 496
                                    2025-08-05 10:35:51.401  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 496
                                    2025-08-05 10:35:51.401  - warn: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,9,18,
                                    2025-08-05 10:35:51.446  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ueberschuss = 8762
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 100
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 0
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =4
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                                    2025-08-05 10:35:54.213  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 14:49
                                    2025-08-05 10:35:54.256  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                    2025-08-05 10:35:54.258  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                    2025-08-05 10:35:54.259  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                    2025-08-05 10:35:54.260  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                    2025-08-05 10:35:54.262  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                    2025-08-05 10:35:54.263  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                    2025-08-05 10:35:54.264  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                    2025-08-05 10:35:54.265  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                    2025-08-05 10:35:54.267  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 2
                                    2025-08-05 10:35:54.268  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 2
                                    2025-08-05 10:35:54.268  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Dienstag: 1338 Wh
                                    2025-08-05 10:35:54.268  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 1338 Wh
                                    2025-08-05 10:35:54.310  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Power_Home_W (Hausverbrauch & Wallbox) = 0W
                                    2025-08-05 10:35:54.312  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Batterie Leistung = 7665 W
                                    2025-08-05 10:35:54.313  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: PV Leistung = 11131 W
                                    2025-08-05 10:35:54.314  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Speichergroesse = 17kWh
                                    2025-08-05 10:35:54.354  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Batterie SoC = 85 %
                                    2025-08-05 10:35:54.355  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_Proz= 2 %
                                    2025-08-05 10:35:54.355  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_SOC_erreicht = false
                                    2025-08-05 10:35:54.355  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bNotstromVerwenden =false
                                    2025-08-05 10:35:54.355  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bNotstromAusNetz =false
                                    2025-08-05 10:35:54.396  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom_Status = 2
                                    2025-08-05 10:35:54.397  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bM_Notstrom = false
                                    2025-08-05 10:35:54.397  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: M_Power = 305
                                    2025-08-05 10:35:54.397  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Set_Power_Value_W = 493
                                    2025-08-05 10:35:54.397  - warn: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ProgrammAblauf = 1,3,6,4,7,9,18,19,43,
                                    2025-08-05 10:35:54.443  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ueberschuss = 10265
                                    2025-08-05 10:35:57.088  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: ueberschuss = 10265
                                    2025-08-05 10:36:00.093  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: *******************  Debug LOG Charge-Control  *******************
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Offset_sunriseEnd = 1
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_minWertPrognose_kWh = 0
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_maxEntladetiefeBatterie = 100
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 10_Systemwirkungsgrad = 100
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_minPvLeistungTag_kWh = 3
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_maxPvLeistungTag_kWh = 100
                                    2025-08-05 10:36:00.094  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_KorrekturFaktor = 0
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: 40_WirkungsgradModule = 19
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikAnwahl =true
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: bAutomatikRegelung =true
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Einstellungen =4
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Start Regelzeitraum = 07:23
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ende Regelzeitraum= 13:23
                                    2025-08-05 10:36:00.096  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende= 14:49
                                    2025-08-05 10:36:00.108  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unload = 100
                                    2025-08-05 10:36:00.115  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende = 90
                                    2025-08-05 10:36:00.158  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeende2 = 98
                                    2025-08-05 10:36:00.199  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Ladeschwelle = 70
                                    2025-08-05 10:36:00.207  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Unterer Ladekorridor = 100
                                    2025-08-05 10:36:00.249  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelbeginn = 06:00
                                    2025-08-05 10:36:00.292  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Regelende = 00:00
                                    2025-08-05 10:36:00.335  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Offset Ladeende = 06:00
                                    2025-08-05 10:36:00.339  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom min = 2
                                    2025-08-05 10:36:00.382  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Notstrom Sockel = 2
                                    2025-08-05 10:36:00.383  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Verbrauch für night am Dienstag: 1338 Wh
                                    2025-08-05 10:36:00.383  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Charge_Control: Eigenverbrauch Nacht = 1338 Wh
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ************************************************************************************
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerTarget = []
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerState = []
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** timerObjektID = []
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** minStrompreis_48h = 0.1489
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** batterieKapazitaet_kWh = 17
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Batterie_SOC = 85
                                    2025-08-05 10:36:00.384  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Power_Bat_W = 861
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Power_Grid = -8238
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** prognoseLadezeitBatterie = 1
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** reichweiteBatterie = 10:02 h
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie angewählt = true
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Nettostrompreis Batterie = 0.1565
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Bruttostrompreis Batterie = 0.1778
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Aktueller Preis Tibber = 0.1628
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Preis Tibber mit Ladeverluste = 0.2143
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].endLocale = undefined
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].startLocale = undefined
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[1].Type = undefined
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].endLocale = 6.8.2025, 00:00:00
                                    2025-08-05 10:36:00.385  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].startLocale = 5.8.2025, 19:00:00
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** naechstePhasen[0].Type = peak
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.endLocale = 5.8.2025, 19:00:00
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.startLocale = 5.8.2025, 09:00:00
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** aktivePhase.Type = normal
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert Spitzenstrompreis = 0.2159
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert hoher Strompreis = 0.19
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Schwellwert niedriger Strompreis = 0.1057
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** schneeBedeckt = false
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung heute = 57.87 kWh
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Prognose PV-Leistung morgen = 64.38 kWh
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** pvLeistungAusreichend = true
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** bReichweiteSunrise = true
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** eAutoLaden = true
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** BatterieEntladenSperren = false
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** BatterieLaden = false
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** battSperrePrio = false
                                    2025-08-05 10:36:00.386  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** Status = PV Prognose hoch,es wird bei Sonnenaufgang mit PV Leistung geladen (aktive Phase: normal)
                                    2025-08-05 10:36:00.386  - warn: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: ** ProgrammAblauf = 27,1,18,18/2,19,21,2,30,31,
                                    2025-08-05 10:36:00.387  - info: javascript.0 (195) script.js.E3DC_ChargeControl.Tibber: *******************  Debug LOG Tibber Skript Version 1.3.18 *******************
                                      @psrelax
                                      mir geht es um diese Einträge:
                                      Bei der Umstellung auf PV müsste das im LOG erscheinen: "evcc Änderung: mode (LP1) ? PV".
                                      Ist das bei dir der Fall?
                                        @arnod
                                        PV ist bei mir in EVCC standardmäßig immer ausgewählt.
                                        Ich kann dir nicht sagen, wann ich das das letzte Mal umgestellt habe, damit es von ChargeControl in die Log geschrieben wird.
                                        • azzkikrboy
                                          azzkikrboy @ArnoD last edited by
                                          @arnod
                                          komisch, das hatte ich eigentlich gemacht 🤔
                                          hab die Parameter jetzt gelöscht und neu anlegen lassen.
                                          Jetzt läufts wieder.
                                            @psrelax
                                            Ich kann das bei mir nicht nachstellen.
                                            Egal ob ich das Skript neu starte oder einfach evcc auf PV umschalte, bei mir wird CC nicht deaktiviert.
                                            Versuch mal das Skript neu zu starten, ob es dann funktioniert.
                                            3428
                                            1543388
