    4. mihome vacuum - login failed
      Thomas Braun Most Active @dirkhe last edited by
      @dirkhe
      Nope. Get devices geht noch nicht.
      2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c68956882748fffffffffffffffffffffffffffffffff
      2025-07-24 19:59:42.943  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827499ffffffffffffffffffffffffffffffff
      2025-07-24 19:59:52.947  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:00:02.950  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274a3ffffffffffffffffffffffffffffffff
      2025-07-24 20:00:02.951  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:00:07.909  - debug: mihome-vacuum.0 (1462) discover__{}
      2025-07-24 20:00:12.954  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c6895688274adffffffffffffffffffffffffffffffff
      2025-07-24 20:00:12.955  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
      2025-07-24 20:00:22.329  - debug: mihome-vacuum.0 (1462) get params for stock Vacuum
      2025-07-24 20:00:22.330  - debug: mihome-vacuum.0 (1462) Message= {"id":142,"method":"get_status"}
      2025-07-24 20:00:22.339  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[{"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}],"id":142}
      2025-07-24 20:00:22.340  - debug: mihome-vacuum.0 (1462) setGetStatus {"msg_ver":8,"msg_seq":1051,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":true,"in_cleaning":false,"fan_power":60,"dnd_enabled":false,"error_text":"No error"}
      2025-07-24 20:00:22.342  - debug: mihome-vacuum.0 (1462) Message= {"id":143,"method":"get_network_info"}
      2025-07-24 20:00:22.350  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":"unknown_method","id":143}
      2025-07-24 20:00:22.351  - debug: mihome-vacuum.0 (1462) Message= {"id":144,"method":"get_sound_volume"}
      2025-07-24 20:00:22.361  - debug: mihome-vacuum.0 (1462) MIIO RECIVE: {"result":[90],"id":144}
      2025-07-24 20:00:24.956  - debug: mihome-vacuum.0 (1462) Helo message Timeout
        dirkhe Developer @Thomas Braun last edited by
        @thomas-braun gib mal bitte die passenden Logzeilen, die sind in dem Auschnitt nicht drin
        Thomas Braun 3 Replies Last reply Reply Quote 0
          @dirkhe
          Da ist auch nicht mehr. get devices geklickt um 20:40:23.105
          2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e09ffffffffffffffffffffffffffffffff
          2025-07-24 20:40:08.922  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
          2025-07-24 20:40:18.926  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e13ffffffffffffffffffffffffffffffff
          2025-07-24 20:40:18.927  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
          2025-07-24 20:40:23.105  - debug: mihome-vacuum.0 (1462) discover__{}
          2025-07-24 20:40:28.930  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e1dffffffffffffffffffffffffffffffff
          2025-07-24 20:40:28.931  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
          2025-07-24 20:40:38.934  - debug: mihome-vacuum.0 (1462) Receive <<< Helo <<< 2131002000000000046c689568827e27ffffffffffffffffffffffffffffffff
          2025-07-24 20:40:38.935  - debug: mihome-vacuum.0 (1462) Time difference between Mihome Vacuum and ioBroker: 1 sec
            @dirkhe
            Ah! Nochmal neugestartet, jetzt funktioniert es!
              @dirkhe
              Hi!
              Die Version aus 'latest' funktioniert nicht:
              2025-07-25 11:52:30.448  - info: mihome-vacuum.0 (59185) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v24.4.1, js-controller: 7.0.7
              2025-07-25 11:53:41.089  - debug: mihome-vacuum.0 (59185) CloudApi-Login gestartet…
              2025-07-25 11:53:41.090  - debug: mihome-vacuum.0 (59185) CloudApi-CloudApi-Step 1: Getting sign token
              2025-07-25 11:53:41.229  - debug: mihome-vacuum.0 (59185) CloudApi-Step 2: Authenticating user
              2025-07-25 11:53:41.327  - error: mihome-vacuum.0 (59185) CloudApi-Login failed, because no captcha resolving possible
              2025-07-25 11:53:41.328  - info: mihome-vacuum.0 (59185) discover Login failed, because no captcha resolving possible
                @thomas-braun tja, sieht so aus, als wenn jetzt ganz viele Anfragen über diesen Weg gekommen sind, so dass der Server da jetzt die captcha Frage stellt. Ich fürchte, da können wir jetzt nichts machen, zumindest habe ich keine Idee mehr
                • bahnuhr
                  bahnuhr Forum Testing Most Active @dirkhe last edited by
                  @dirkhe sagte in mihome vacuum - login failed:
                  Danke für die Info.
                  Vielleicht kann ja jemand helfen?
                  @apollon77
                  @mcm1957
                  Ich meine hier schon mal gelesen zu haben, dass jemand captcha im Adapter schon umgesetzt hatte.
                  Weiß aber nicht mehr wo und wer.
                  mfg
                  Dieter
                  • bahnuhr
                    zur Info:
                    @apollon77 hat im issue geantwortet.
                    Anbei:
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @bahnuhr last edited by bahnuhr
                      @bahnuhr sagte in mihome vacuum - login failed:
                      Jetzt weiß ich es wieder.
                      War beim bmw Adapter.
                      Vielleicht geht ja sowas hier auch.
                      • bahnuhr
                        im issue wurde vermerkt, dass wohl oauth2 angesagt ist.
                        Jetzt muss dies "nur" noch umgesetzt werden.
                        Anbei nochmal link zum issue (wer nachlesen möchte).
                        https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/1063
                        gmtjan created this issue in iobroker-community-adapters/ioBroker.mihome-vacuum
                        open ERROR: Login failed #1063
                        login mihome vacuum
                        508
