      Toysman @TT-Tom last edited by Toysman
      @tt-tom
      @ticaki
      TFT 4.9.1 wird gerade installiert, danach dann auf die 4.9.2 hochziehen?
        TT-Tom @Toysman last edited by
        @toysman
        wenn sie durch läuft, ja
          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
          @toysman
          so, die Version 4.9.2 läuft und das neue Script auch.... fast 😠
          in den LOGs vo ioBroker bekomme ich folgende Fehler:
          javascript.0
          	2025-07-27 19:06:17.624	warn	script.js.NSPanels.NSPanel_Office: error at function HandleScreensaverUpdate: Cannot read properties of null (reading 'substring')
          javascript.0
          	2025-07-27 19:06:17.623	warn	at Object.<anonymous> (script.js.NSPanels.NSPanel_Office:4088:12)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at __awaiter (script.js.NSPanels.NSPanel_Office:4:12)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at new Promise (<anonymous>)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at script.js.NSPanels.NSPanel_Office:8:71
          javascript.0
          	2025-07-27 19:06:17.623	warn	at Object.next (script.js.NSPanels.NSPanel_Office:14:53)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at step (script.js.NSPanels.NSPanel_Office:33:23)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at Object.<anonymous> (script.js.NSPanels.NSPanel_Office:4092:17)
          javascript.0
          	2025-07-27 19:06:17.623	warn	at HandleScreensaverUpdate (script.js.NSPanels.NSPanel_Office:13651:37)
          javascript.0
          	2025-07-27 19:06:17.622	warn	getState "daswetter.0.NextDays.Location_1.Day_1.Tag_value" not found (3)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at Object.<anonymous> (script.js.NSPanels.NSPanel_Office:4088:12)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at __awaiter (script.js.NSPanels.NSPanel_Office:4:12)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at new Promise (<anonymous>)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at script.js.NSPanels.NSPanel_Office:8:71
          javascript.0
          	2025-07-27 19:06:17.622	warn	at Object.next (script.js.NSPanels.NSPanel_Office:14:53)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at step (script.js.NSPanels.NSPanel_Office:33:23)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at Object.<anonymous> (script.js.NSPanels.NSPanel_Office:4092:17)
          javascript.0
          	2025-07-27 19:06:17.622	warn	at HandleScreensaverUpdate (script.js.NSPanels.NSPanel_Office:13650:35)
          javascript.0
          	2025-07-27 19:06:17.622	warn	getState "daswetter.0.NextDays.Location_1.Day_1.Maximale_Temperatur_value" not found (3)
          javascript.0
          javascript.0
          javascript.0
          	2025-07-27 19:06:17.621	warn	at new Promise (<anonymous>)
          javascript.0
          	2025-07-27 19:06:17.621	warn	at script.js.NSPanels.NSPanel_Office:8:71
          javascript.0
          	2025-07-27 19:06:17.621	warn	at Object.next (script.js.NSPanels.NSPanel_Office:14:53)
          javascript.0
          	2025-07-27 19:06:17.621	warn	at step (script.js.NSPanels.NSPanel_Office:33:23)
          javascript.0
          	2025-07-27 19:06:17.621	warn	at Object.<anonymous> (script.js.NSPanels.NSPanel_Office:4092:17)
          javascript.0
          	2025-07-27 19:06:17.621	warn	at HandleScreensaverUpdate (script.js.NSPanels.NSPanel_Office:13649:35)
          javascript.0
          	2025-07-27 19:06:17.619	warn	getState "daswetter.0.NextDays.Location_1.Day_1.Minimale_Temperatur_value" not found (3)
          In den Objekten im ioBroker habe ich aber nicht daswetter.0.NextDays.Location_1.Day_1 sondern "nur" daswetter.0.NextHours.Location_1.Day_1
          Im der Instanz ist eingestellt: Pfad 3: XML-Datei mit Wettervorhersage für die nächsten 5 Tage und stündliche Informationen
          Kann ich da etwas ändern?
          Danke & Gruß
            @toysman
            ist es den im alten Script gelaufen, welche Version hast du den da genutzt?
            ich kenne den Adapter nicht, da muss dir @armilar weiterhelfen ode jemand der das Wetter nutzt.
            T 2 Replies Last reply Reply Quote 1
              @toysman
              im alten Script habe ich accuweather genutzt, aber wegen der Warnung wollte ich auf daswetter umsteigen.
              Nun läuft wieder accuweather und das LOG bleibt leer 🙂
              Armilar teletapi 2 Replies Last reply Reply Quote 1
              • Armilar
                Armilar Most Active Forum Testing @Toysman last edited by Armilar
                @toysman
                Habe eben mal einen Test mit DasWetter gemacht... Ich kann keine Probleme feststellen...
                Das ist mein Wetteralias für DasWetter
                Bei Das Wetter gabe es ja auch so die ein oder andere API Änderung in letzter Zeit...
                Das sind meine aktuellen Einstellungen und damit funktioniert es (localidad und affiliate_id unkenntlich gemacht):
                Die Struktur der Datenpunkte stimmt auch:
                • teletapi
                  teletapi @teletapi last edited by teletapi
                  @Gargano es geht leider nicht so
                  Gargano 1 Reply Last reply Reply Quote 0
                  • teletapi
                    teletapi @Toysman last edited by
                    @toysman ich nutze Openweathermap und hatte Accuweather nur für das NSpanel installiert. Openweathermap ist da aber deutlich freundlicher und funktionierte direkt perfekt nach der umstellung.
                    • Gargano
                      Gargano @teletapi last edited by
                      @teletapi Ich habe es jetzt mal probiert (mit dem Script, nicht mit Adapter):
                      let Rollos : PageType =
                          'type': 'cardEntities',
                          'heading': 'Abschattung',
                          'useColor': true,
                          'subPage': false,
                          'items': [
                              { id: "alias.0.Rollos.Wohn1", icon: "window-shutter", name: "Wohn 1", interpolateColor: true},
                             	{ id: "alias.0.Rollos.Wohn2", icon: "window-shutter", name: "Wohn 2", interpolateColor: true}
                      Und beim Draufdrücken von Wohn 1 kommt :
                      Wobei dies jetzt richtig rum ist.
                      Original level ist dann so :
                      Konvertierungsfunktion einschalten
                      Man muß ACTUAL und SET die Konvertierung einschalten.
                      teletapi 1 Reply Last reply Reply Quote 2
                      • teletapi
                        teletapi @Gargano last edited by teletapi
                        @gargano Zunächst einmal, Danke das du dir da Gedanken machst und mir helfen möchtest, ich denke ich habs jetzt und ja es war richtig von dir und natürlich auch von den anderen. Bei dem vielen Testen hatte ich im nspanel script noch die min und max value vertauscht dann konnte das nix werden jetzt hab ich 100-val in actual und set steht damit zeigt mir das Panel dann zb. 70% geschlossen während mir die CCU3 halt 30%geöffnet anzeigt aber damit kann ich leben. Danke nochmal allen
                        Wenn in nächster zeit die Umstellung auf den Adapter ansteht komm ich nochmal und nerve euch noch ein wenig... 😉
                          ticaki Developer @Gargano last edited by
                          @gargano
                          https://forum.iobroker.net/post/1285952
                            @tt-tom
                            war ein paar Tage dienstlich unterwegs, deshalb erst heute eine Reaktion meinerseits.
                            Im LOG vom TS Script bekomme ich folgende Meldung:
                            javascript.0	18:01:38.970	warn	Adjust data (T) for the QR page under 0_userdata.0.Datenpunkte.NSPanels.GuestWiFi.data. Follow the instructions in the wiki.
                            Der gesetzte Datenpunkt lautet aber:
                            'alias.0.Geräte_für_NSPanels.GaesteWLAN.GaesteWLAN'
                            Wo finde ich denn den DP im LOG, um ihn zu korrigieren?
                              @armilar sagte in SONOFF NSPanel mit Lovelace UI:
                              @toysman
                              hast Du mal bitte den aktuellen Link zur API Seite von DASWETTER zur Hand.... Danke
                              • Armilar
                                Armilar Most Active Forum Testing last edited by Armilar
                                @toysman
                                ja - und sogar ausprobiert 😊
                                https://www.daswetter.com/api/#/login
                                Das Ergebnis wird dich allerdings nicht zufrieden stellen
                                Ich hätte angenommen, dass sich neue User so mittlerweile wieder anmelden können. Dem ist nicht so...
                                Wer also keinen "alten" Zugang zu DasWetter hat (das funktioniert nämlich noch), dem bleibt aktuell wohl nur die Option: OpenWeatherMap
                                Ich hatte das mal ne Weile verfolgt und ging immer davon aus, dass die das Wetter wieder zugänglich machen... Scheinbar nur noch für Handys und Webseiten als Plugin... Aktuell wären der Stand dann wohl:
                                • OpenWeatherMap - funktioniert uneingeschränkt
                                • DasWetter - funktioniert nur mit Accounts die vor der Umstellung existierten
                                • AccuWeather - funktioniert nur noch bis zur API-Deaktivierung
                                Armilar 1 Reply Last reply Reply Quote 1
                                • Armilar
                                  Armilar Most Active Forum Testing @Armilar last edited by Armilar
                                  Update NSPanelTs.ts v4.9.3.1
                                  Für den Fall, dass bereits jemand den Beta JS-Adapter 9.0.11 benutzen möchte, gibt es jetzt von unserer Seite ein "Go"...
                                  Das Skript ist auf die neue Version des JavaSkript-Adapters v.9.0.11 (wieder mal restriktiver geworden, @ticaki hat's gestern mal final angepasst) abgestimmt und funktioniert bei uns allen auch fehlerfrei. Es funktioniert jedoch ebenfalls mit der aktuellen stable JS-Adapter v8.9.2. Somit besteht für alle nicht Beta-Nutzer auch nach wie vor kein Grund umzusteigen... In absehbarer Zeit wird die JS v9.0.x ohnehin das Stable-Repository erreichen...
                                  hier das NSPanel Skript, wie immer den unteren Teil austauschen...
                                  https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                                  Zu diesem Update gehört die TFT in der Version 58/4.9.3 für folgende Versionen:
                                  EU STABLE Version:
                                  FlashNextion http://nspanel.de/nspanel-v4.9.3.tft
                                  US-L STABLE Version:
                                  FlashNextion http://nspanel.de/nspanel-us-l-v4.9.3.tft
                                  US-P STABLE Version:
                                  FlashNextion http://nspanel.de/nspanel-us-p-v4.9.3.tft
                                  Außerdem haben wir noch einen weiteren optionalen pageItem-Parameter für das popupShutter2 eingeführt:
                                  shutterZeroIsClosed: true oder false (bzw. weglassen)
                                  Dieser bewirkt, dass die prozentuale Angabe unter dem Shutter invertiert werden kann.
                                  Die US-Versionen haben ebenfalls jetzt den neuen grafischen Splash/Startup
                                  Viel Spaß mit der v4.9.3.1 😊
                                  @TT-Tom , @ticaki , @Armilar und @Kuckuckmann (hat diesesmal nichts angestellt 😉 )
                                  teletapi 1 Reply Last reply Reply Quote 6
                                  • teletapi
                                    teletapi @Armilar last edited by teletapi
                                    @armilar Beim TFT Update bekomme ich einen Fehler nachdem ich das script an mein Panel angepasst und gestartet habe. dann auf TFT update 4.9.3 und dann kommt der folgende Bildschirm
                                    Per Konsole hat es allerdings funktioniert
                                      @toysman
                                      hast du die Datenpunkte automatisch anlegen lassen oder selbst? mit
                                      { id: 'alias.0.NSPanel.GuestWifi', hidePassword: false, autoCreateALias: true }
                                      werden die Datenpunkte automatisch angelegt.
                                      Dein log nennt dir den Datenpunkt unter 0_userdata.0.xxx
                                      zeige mal deine pageOR config.
                                      • Armilar
                                        Armilar Most Active Forum Testing @teletapi last edited by Armilar
                                        @teletapi
                                        Hast du dich in der Zeile vergriffen?
                                        Für EU ist
                                        EDIT:
                                        Das ist doch ein EU-Panel im Bild?, oder?
                                        Ansonsten mal:
                                        Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
                                        und dann nochmal:
                                          @armilar
                                          Wenn ich es richtig verstanden habe, hat es über Konsole funktioniert. Nur mit Script nicht.
                                          teletapi 1 Reply Last reply Reply Quote 1
                                          • teletapi
                                            teletapi @TT-Tom last edited by teletapi
                                            @tt-tom Ja genauso über die Tasmota konsole konnte ich das Display updaten und per webui des Panels nicht da bekam ich den Fehler
                                            PageQR
                                            let GuestWifi: PageType =
                                                'type': "cardQR",
                                                'heading': "Gäste Wlan",
                                                'subPage': true,
                                                'parent': Programmseite,
                                                'items': [{ id: 'alias.0.NSPanel.Guest_Wifi',
                                                           hidePassword: true, // true = Switch; false = Password
                                                           hideEntity2: false,   // true = Switch or Password is Hide
                                                           autoCreateALias: true}
                                            lovelace ui nspanel sonoff
                                            268
                                            7580
                                            6141293
